Application Note: SY7069
5.5V Maximum Output, 3A Valley Current, 1MHz
Synchronous Boost with Auto Bypass Function
General Description
Features
SY7069 is a high efficiency, synchronous, step-up
boost converter designed for one-cell Li-Ion or Lipolymer, or a two to three-cell alkaline Ni-Cd or NiMH battery powered applications. It can convert down
to 2.5V input voltage and up to 5.5V output voltage. It
adopts NMOS for the main switch and PMOS for the
synchronous switch.
SY7069 can disconnect the output from input during
the shutdown mode. When input voltage exceeds the
regulated output voltage, SY7069 enters bypass mode
automatically.
Ordering Information
SY7069 □(□□)□
Package type
TSOT23-6
2.5V minimum input voltage
Adjustable output voltage from 2.5V to 5.5V
Min 3A valley current limit
Capable for seamless transition between boost and
bypass mode
Load disconnect during shutdown
Low RDS(ON) (main switch/synchronous switch) at
5.0V output: 50mΩ/90mΩ
Output OVP protection
Compact package TSOT23-6 package
Applications
Temperature Code
Package Code
Optional Spec Code
Ordering Number
SY7069ADC
All Single Cell Li or Dual Cell Battery Operated
Products as MP-3 Player, PDAs, and Other
Portable Equipment.
Note
Typical Applications
Figure 1. Schematic Diagram
AN_SY7069 Rev. 0.9
Silergy Corp. Confidential- Prepared for Customer Use Only
1
SY7069
Pinout (top view)
FB
1
6
EN
IN
2
5
LX
GND
3
4
OUT
(TSOT23-6)
Top mark: Iexyz (Device code: Ie, x=year code, y=week code, z= lot number code)
Name
TSOT23-6
FB
1
IN
2
GND
OUT
LX
EN
3
4
5
6
Description
Output Feedback Pin. Connect this pin to the center point of the output resistor divider
(as shown in Figure 1) to program the output voltage: VOUT=1.2× (1+RH/RL).
Signal input pin. Decouple this pin to GND pin with at least 1uF ceramic cap for noise
immunity consideration.
Ground pin.
Output pin. Decouple this pin to GND pin with at least 22µF ceramic cap.
Inductor node. Connect an inductor between IN pin and LX pin.
Enable pin. Pull high to turn on. Do not leave it floating.
Absolute Maximum Ratings (Note 1)
All Pins------------------------------------------------------------------------------------------------------------------------------- -- 6.0V
Power Dissipation, PD@ TA=25°C, TSOT23-6----------------------------------------------------------------------------- --1.92W
Package Thermal Resistance (Note 2)
θ JA---------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 52°C/W
θ JC---------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 32°C/W
Junction Temperature Range------------------------------------------------------------------------------------------------------ 150°C
Lead Temperature (Soldering, 10 sec.)------------------------------------------------------------------------------------------260°C
Storage Temperature Range-------------------------------------------------------------------------------------------- 65°C to 150°C
Recommended Operating Conditions (Note 3)
IN------------------------------------------------------------------------------------------------------------------------------ 2.5V to 5.5V
OUT------------------------------------------------------------------------------------------------------------------------ -- 2.5V to 5.5V
EN, FB-------------------------------------------------------------------------------------------------------------------- V to VOUT+0.3V
All other pins------------------------------------------------------------------------------------------------------------------------ 0-5.5V
Junction Temperature Range--------------------------------------------------------------------------------------------40°C to 125°C
Ambient Temperature Range---------------------------------------------------------------------------------------------40°C to 85°C
AN_SY7069 Rev. 0.9
2
SY7069
Electrical Characteristics
(VIN =3.0V, VOUT=5.0V, IOUT=500mA, TA = 25°C unless otherwise specified)
Parameter
Symbol
Test Conditions
VIN
Input Voltage
VOUT
Output Voltage Range
V
IN
Quiescent
IQ
Io=0A,VEN=VIN=3.0V,
VOUT
Current
VOUT=5.0V,VFB=105%VREF
ISHDN
Shutdown Current
VEN=0V, VIN=3.0V
ICHARGE
Linear Charge Current
VOUT
很抱歉,暂时无法提供与“SY7069ADC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.43922
- 50+1.98989
- 150+1.79732
- 500+1.11612
- 国内价格
- 1+1.54000
- 100+1.18800
- 750+0.99220
- 1500+0.90090
- 3000+0.83600
- 国内价格
- 5+2.68812
- 50+2.19294
- 150+1.98072
- 500+1.23002
- 3000+1.11219
- 6000+1.04145
