Application Note: AN_SY8003/SY8003A
High Efficiency 5.5V, 3A continuous, 1MHz
Synchronous Step Down Regulator
General Description
Features
The SY8003 and SY8003A are high-efficiency, high
frequency synchronous step-down DC-DC regulator IC
capable of delivering up to 3A output current. The
SY8003 and SY8003A operate over a wide input voltage
range from 2.7V to 5.5V and integrate main
switch and synchronous switch with very low RDS(ON)
to minimize the conduction loss.
Low RDS(ON) for internal switches
(top/bottom):110mΩ/80mΩ
3A continuous load current capability
2.7-5.5V input voltage range
High switching frequency minimizes the external
components: 1MHz
Internal softstart limits the inrush curre t
Reliable short circuit protection:
SY8003: Latch off pro ec ion
SY8003A: Hic-cup m de protection
Reliable over-voltage protection:
SY8003: Latch off protection
SY8003A: No latch off protection
100% dropout operation
RoHS Compliant and Halogen Free
Compact package: DFN2X2-8.
Low output voltage ripple and small external inductor
and capacitor sizes are achieved with 1MHz switching
frequency.
SY8003 and SY8003A integrate reliable short circuit
and over-voltage protection.
Ordering Information
SY8003
Package type
DFN2x2-8
DFN2x2-8
Applications
Temperature Code
Package Code
Optional Spec Code
Ordering Number
SY8003DFC
SY8003ADFC
Note①
LCD TV
Set Top Box
Net PC
Mini-Notebook PC
Access Point Router
Typical Applications
2
VIN: 2.7-5.5V
3
PG
IN
LX
CIN
22µF
ON/ OFF
7
FB
6
L1:2.2µH
1
EN
PGND SGND
4
8
Figure 1.Schematic diagram
VOUT: 1.8V
R1
200k
R2
100k
C1
COUT
22pF 22µFх2
Ef
fic
ie
n
cy
Figure 2. Efficiency vs Load Current
AN_SY8003/A Rev. 0.9Silergy Corp. Confidential- Prepared for Customer Use Only
1
SY8003/SY8003A
Pinout (top view)
FB
1
PG
2
8
SGND
7
EN
PGND
IN
3
6
LX
PGND
4
5
NC
Part Number
SY8003DFC
SY8003ADFC
Package type
DFN2x2-8
DFN2x2-8
Top Mark①
JDxyz
KWxyz
Note① : x=year code, y=week code, z= lot number code.
Pin Name
EN
PGND
SGND
LX
IN
PG
Pin Number
7
4/Exposed
Paddle
8
6
3
2
FB
1
NC
5
Pin Description
Enable control. Pull high to turn on. Do not float.
Power ground pin.
Signal ground pin.
Inductor pin. Connect this pin to the switching node of inductor.
Power input pin. Decouple this pin to GND pin with at least 10µF ceramic cap.
Power good indicator(Open drain output). Low if the output < 90% of regulation
voltage or >120% regulation voltage; High otherwise. Connect a pull-up resistor to the
input.
Output Feedback Pin. Connect this pin to the center point of the output resistor divider
(as shown in Figure 1) to progr m the output voltage: Vout=0.6*(1+R1/R2).
No connection.
Absolute Maximum Ratings (Note 1)
Supply Input Voltage -----------------------------------------------------------------------------------------------0.3V to 6.0V
Enable, FB Voltage------------------------------------------------------------------------------------------ - 0.3V to VIN + 0.6V
LX Voltage----------------------------------------------------------------------------------------------------- - 0.3V(*1) to 6V(*2)
Power Dissipation, PD @ TA = 25°C DFN2x2-8 , ------ -------------------------------------------------------------------1W
Package Thermal Resistance (Note 2)
θ JA ----------------------------------------------------------------------------------------------------------------120°C/W
θ JC -----------------------------------------------------------------------------------------------------------------8.2°C/W
Junction Temperature Range ----------------------------------------------------------------------------------------------150°C
Lead Temperature (S ldering, 10 sec.) -----------------------------------------------------------------------------------260°C
Storage Temperature Range -------------------------------------------------------------------------------------65°C to 150°C
(*1)
LX Voltage tested down to -5V
很抱歉,暂时无法提供与“SY8003ADFC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.75338
- 50+1.35918
- 150+1.19016
- 500+0.97935
- 3000+0.88550
- 6000+0.82923
- 国内价格
- 1+1.44035
- 10+1.41874
- 600+0.77230
- 国内价格
- 1+1.11100
- 200+0.85690
- 1500+0.74470
- 3000+0.69410
