FDG6303N
FDG6303N
    VBSEMI(微碧)
    SOT-363
    MOS管 Dual N-Channel VDS=20V VGS=±12V ID=2.3A RDS(ON)=86mΩ@4.5V SOT363
FDG6303N 数据手册
FDG6303N www.VBsemi.tw Dual N-Channel 20 V (D-S) MOSFET FEATURES PRODUCT SUMMARY RDS(on) (Ω) ID (A)a 0.086 at VGS = 4.5 V 2.6a 0.110 at VGS = 2.5 V 2.5 a 0.180 at VGS = 1.8 V 2.3 a VDS (V) 20 Qg (Typ.) 5.0 nC • Halogen-free According to IEC 61249-2-21 Definition • TrenchFET® Power MOSFET • 100 % Rg Tested • Typical ESD Protection 2100 V HBM • Compliant to RoHS Directive 2002/95/EC APPLICATIONS • Load Switch for Portable Applications SOT-363 SC-70 D1 S1 1 6 D1 G1 2 5 G2 D2 3 4 S2 G1 D2 G2 Top View S1 S2 ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted) Symbol Limit Drain-Source Voltage VDS 20 Gate-Source Voltage VGS ± 12 Parameter TC = 70 °C TA = 25 °C 2.2a ID 2.3a, b, c 1.8b, c TA = 70 °C Pulsed Drain Current Continuous Source-Drain Diode Current IDM TC = 25 °C TA = 25 °C Maximum Power Dissipation TA = 25 °C 2.3 IS 2.10b, c 2.70 1.70 PD W 1.5 b, c 1.0 b, c TA = 70 °C Operating Junction and Storage Temperature Range A 8 TC = 25 °C TC = 70 °C V 2.6a TC = 25 °C Continuous Drain Current (TJ = 150 °C) Unit TJ, Tstg °C - 55 to 150 THERMAL RESISTANCE RATINGS Parameter Symbol Typical Maximum Maximum Junction-to-Ambientb, d t≤5s RthJA 130 170 Maximum Junction-to-Foot (Drain) Steady State RthJF 80 100 Unit °C/W Notes: a. Package limited. b. Surface mounted on 1" x 1" FR4 board. c. t = 5 s. d. Maximum under steady state conditions is 220 °C/W. E-mail:China@VBsemi TEL:86-755-83251052 1 FDG6303N www.VBsemi.tw SPECIFICATIONS (TJ = 25 °C, unless otherwise noted) Parameter Symbol Test Conditions Min. VDS VGS = 0 V, ID = 250 µA 20 Typ. Max. Unit Static Drain-Source Breakdown Voltage VDS Temperature Coefficient ΔVDS/TJ VGS(th) Temperature Coefficient ΔVGS(th)/TJ Gate-Source Threshold Voltage VGS(th) ID = 250 µA VDS = VGS, ID = 250 µA V 20 0.5 2.0 VDS = 0 V, VGS = ± 8 V ± 25 VDS = 0 V, VGS = ± 4.5 V 1 VDS = 20 V, VGS = 0 V 1 VDS = 20 V, VGS = 0 V, TJ = 55 °C 10 Gate-Source Leakage IGSS Zero Gate Voltage Drain Current IDSS On-State Drain Currenta ID(on) VDS ≤ 5 V, VGS = 4.5 V VGS = 4.5 V, ID = 1 A 0.086 RDS(on) VGS = 2.5 V, ID = 1 A 0.110 VGS = 1.8 V, ID = 0.2 A 0.180 VDS = 4 V, ID = 1.5 A 4 VDS = 10 V, VGS = 8 V, ID = 1.5 A 5.0 VDS = 10 V, VGS = 4.5 V, ID = 1.5 A 1.0 Drain-Source On-State Resistancea Forward Transconductancea gfs mV/°C - 2.3 4 V µA µA A Ω S Dynamicb Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Gate Resistance Rg Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-on Delay Time Rise Time Turn-Off Delay Time Fall Time 3.0 nC 2.0 f = 1 MHz 0.4 1.9 3.8 43 65 80 120 480 720 tf 220 330 td(on) 22 33 td(on) tr td(off) tr td(off) VDD = 10 V, RL = 8.3 Ω ID ≅ 1.2 A, VGEN = 4.5 V, Rg = 1 Ω VDD = 10 V, RL = 8.3 Ω ID ≅ 1.2 A, VGEN = 8 V, Rg = 1 Ω tr 46 70 645 968 215 323 kΩ ns Drain-Source Body Diode Characteristics Continuous Source-Drain Diode Current IS Pulse Diode Forward Current ISM Body Diode Voltage VSD Body Diode Reverse Recovery Time trr Body Diode Reverse Recovery Charge Qrr Reverse Recovery Fall Time ta Reverse Recovery Rise Time tb TC = 25 °C 2.6 A 4 IS = 1.2 A, VGS = 0 V IF = 1.2 A, dI/dt = 100 A/µs, TJ = 25 °C 0.8 1.2 V 9 18 ns 2 4 nC 5 4 ns Notes: a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %. b. Guaranteed by design, not subject to production testing. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. E-mail:China@VBsemi TEL:86-755-83251052 2 FDG6303N www.VBsemi.tw TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 10-3 0.5 10-4 10-5 IG - Gate Current (A) IG - Gate Current (mA) 0.4 0.3 TJ = 25 °C 0.2 TJ = 150 °C 10-6 10-7 TJ = 25 °C 10-8 0.1 10-9 10-10 0 0 3 6 9 12 VGS - Gate-to-Source Voltage (V) 0 15 Gate Current vs. Gate-to-Source Voltage 3 6 9 12 VGS - Gate-to-Source Voltage (V) 15 Gate Current vs. Gate-to-Source Voltage 1.0 4 V GS = 5 V thr u 3 V 0.8 ID - Drain Current (A) ID - Drain Current (A) 3 V GS = 1.5 V 2 0.6 T C = 25 °C 0.4 T C = 125 °C 1 0.2 V GS = 1 V 0 0.0 0.5 1.0 1.5 0.0 0.0 2.0 0.3 0.6 0.9 1.2 VDS - Drain-to-Source Voltage (V) VGS - Gate-to-Source Voltage (V) Output Characteristics Transfer Characteristics 1.5 8 VGS - Gate-to-Source Voltage (V) 0.25 RDS(on) - On-Resistance (Ω) T C = - 55 °C V GS = 1.8 V 0.20 0.15 V GS = 2.5 V 0.10 V GS = 4.5 V 0.05 0 1 2 3 4 ID = 1.5 A 6 V DS = 10 V V DS = 16 V V DS = 5 V 4 2 0 0.0 0.5 1.0 1.5 ID - Drain Current (A) Qg - Total Gate Charge (nC) On-Resistance vs. Drain Current Gate Charge E-mail:China@VBsemi TEL:86-755-83251052 2.0 3 FDG6303N www.VBsemi.tw TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 10 ID = 1 A 1.5 V GS = 2.5 V IS - Source Current (A) RDS(on) - On-Resistance (Normalized) 1.7 1.3 V GS = 4.5 V 1.1 T J = 150 °C T J = 25 °C 1 0.9 0.7 - 50 0.1 - 25 0 25 50 75 100 TJ - Junction Temperature (°C) 125 0.0 150 0.3 0.6 0.9 1.2 1.5 VSD - Source-to-Drain Voltage (V) On-Resistance vs. Junction Temperature Source-Drain Diode Forward Voltage 0.80 0.4 0.65 0.3 ID = 250 μA T J = 125 °C 0.2 VGS(th) (V) RDS(on) - On-Resistance (Ω) ID = 1 A T J = 25 °C 0.50 0.35 0.1 0.20 - 50 0.0 1 2 3 4 5 - 25 0 VGS - Gate-to-Source Voltage (V) On-Resistance vs. Gate-to-Source Voltage 25 50 75 100 TJ - Temperature (°C) 125 150 Threshold Voltage 10 5 Limited by RDS(on)* 100 μs ID - Drain Current (A) Power (W) 4 3 2 1 1 ms 10 ms 0.1 100 ms 1 TA = 25 °C Single Pulse 0 0.01 0.1 1 10 100 Time (s) Single Pulse Power, Junction-to-Ambient E-mail:China@VBsemi TEL:86-755-83251052 600 0.01 0.1 1 s, 10 s DC BVDSS Limited 100 1 10 VDS - Drain-to-Source Voltage (V) * VGS > minimum VGS at which RDS(on) is specified Safe Operating Area, Junction-to-Ambient 4 FDG6303N www.VBsemi.tw TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 2.4 ID - Drain Current (A) 1.8 Package Limited 1.2 0.6 0.0 0 25 50 75 100 TC - Case Temperature (°C) 125 150 1.5 0.75 1.2 0.60 0.9 0.45 Power (W) Power (W) Current Derating* 0.6 0.3 0.30 0.15 0.0 0.00 0 25 50 75 100 TF - Case Temperature (°C) Power, Junction-to-Foot 125 150 0 25 50 75 100 125 150 TA - Ambient Temperature (°C) Power, Junction-to-Ambient * The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package limit. E-mail:China@VBsemi TEL:86-755-83251052 5 FDG6303N www.VBsemi.tw TYPICAL CHARACTERISTICS (25 C, unless otherwise noted) 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 Notes: 0.1 P DM 0.1 0.05 t1 t2 1. Duty Cycle, D = t1 t2 2. Per Unit Base = R thJA = 170 °C/W 0.02 3. T JM - TA = PDMZthJA(t) Single Pulse 0.01 10 -4 4. Surface Mounted 10 -3 10 -2 10 -1 1 Square Wave Pulse Duration (s) 10 100 600 Normalized Thermal Transient Impedance, Junction-to-Ambient Normalized Effective Transient Thermal Impedance 2 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10-4 10-3 10-2 10-1 Square Wave Pulse Duration (s) 1 10 Normalized Thermal Transient Impedance, Junction-to-Foot E-mail:China@VBsemi TEL:86-755-83251052 6 FDG6303N www.VBsemi.tw Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives ( collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.tw) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: ( 1) any application and all liability arising out of or use of any products; ( 2) any and all liability, including but not limited to special, consequential damages or incidental ; ( 3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be R oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 R i Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.tw) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A. E-mail:China@VBsemi TEL:86-755-83251052 7
FDG6303N 价格&库存
很抱歉,暂时无法提供与“FDG6303N”相匹配的价格&库存,您可以联系我们找货
FDG6303N
  • 1+1.08480
  • 10+1.01700
  • 50+0.91530
  • 150+0.84750
  • 300+0.80004
  • 500+0.77970
