FDC5661N
FDC5661N
    VBSEMI(微碧)
    TSOP-6
    MOS管 N-Channel VDS=60V VGS=±20V ID=7A RDS(ON)=35mΩ@4.5V TSOP6
FDC5661N 数据手册
FDC5661N www.VBsemi.tw N-Channel 60 V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS (V) • TrenchFET® power MOSFET • 100 % Rg and UIS tested 60 RDS(on) () at VGS = 10 V 0.030 RDS(on) () at VGS = 4.5 V 0.035 ID (A) 7 Configuration Single TSOP-6 D 1 6 D D 2 5 D G 3 4 S Top View ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted) SYMBOL LIMIT Drain-Source Voltage VDS 60 Gate-Source Voltage VGS ± 20 PARAMETER Continuous Drain Current TC = 25 °C TC = 125 °C Continuous Source Current (Diode Conduction) Pulsed Drain Current a Single Pulse Avalanche Current Single Pulse Avalanche Energy Maximum Power Dissipation a L = 0.1 mH TC = 25 °C TC = 125 °C Operating Junction and Storage Temperature Range ID 4 6 IDM 29 IAS 10 EAS 5 TJ, Tstg V 7 IS PD UNIT 5 1.6 A mJ W - 55 to +175 °C SYMBOL LIMIT UNIT RthJA 110 RthJF 30 THERMAL RESISTANCE RATINGS PARAMETER Junction-to-Ambient Junction-to-Foot (Drain) PCB Mount b °C/W Notes a. Pulse test; pulse width  300 μs, duty cycle  2 %. b. When mounted on 1" square PCB (FR-4 material). E-mail:China@VBsemi TEL:86-755-83251052 1 FDC5661N www.VBsemi.tw SPECIFICATIONS (TC = 25 °C, unless otherwise noted) PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Static Drain-Source Breakdown Voltage Gate-Source Threshold Voltage Gate-Source Leakage Zero Gate Voltage Drain Current On-State Drain Current a Drain-Source On-State Resistance a Forward Transconductance a VDS VGS = 0, ID = 250 μA 60 - - VGS(th) VDS = VGS, ID = 250 μA 1.0 - 2.5 VDS = 0 V, VGS = ± 12 V - - ± 500 nA VDS = 0 V, VGS = ± 20 V - - ±1 mA 1 IGSS IDSS ID(on) RDS(on) gfs VGS = 0 V VDS = 60 V - - VGS = 0 V VDS = 60 V, TJ = 125 °C - - 50 VGS = 0 V VDS = 60 V, TJ = 175 °C - - 150 VGS = 10 V VDS5 V 10 - - VGS = 10 V ID = 5 A - 0.030 - VGS = 10 V ID = 5 A, TJ = 125 °C - 0.050 - VGS = 10 V ID = 5 A, TJ = 175 °C - 0.070 - VGS = 4.5 V ID = 4 A - 0.035 - - 12 - - 560 700 - 85 105 VDS = 15 V, ID = 4 A V μA A  S Dynamic b Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss - 55 70 Total Gate Charge c Qg - 7.6 12 - 2.1 - - 4.1 - f = 1 MHz 1.2 2.4 3.6 - 9 14 VDD = 30 V, RL = 7.5  ID  4 A, VGEN = 10 V, Rg = 1  - 12 18 - 19 29 tf - 7 11 Pulsed Current a ISM - - 29 A Forward Voltage VSD - 0.75 1.2 V Gate-Source Charge c Qgs Gate-Drain Charge c Qgd Gate Resistance Rg Turn-On Delay Time c VDS = 30 V, f = 1 MHz VGS = 4.5 V VDS = 30 V, ID = 4 A td(on) Rise Time c Turn-Off Delay Time c VGS = 0 V tr td(off) Fall Time c pF nC  ns Source-Drain Diode Ratings and Characteristics b IF = 1.6 A, VGS = 0 Notes a. Pulse test; pulse width  300 μs, duty cycle  2 %. b. Guaranteed by design, not subject to production testing. c. Independent of operating temperature.     Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.  E-mail:China@VBsemi TEL:86-755-83251052 2 FDC5661N www.VBsemi.tw TYPICAL CHARACTERISTICS (TA = 25 °C, unless otherwise noted) 15 15 VGS = 10 V thru 5 V 12 I D - Drain Current (A) I D - Drain Current (A) 12 VGS = 4 V 9 6 9 6 TC = 25 °C 3 3 TC = 125 °C VGS = 3 V TC = - 55 °C 0 0 0 0 5 1 2 3 4 VDS - Drain-to-Source Voltage (V) 1 3 4 5 Transfer Characteristics Output Characteristics 25 0.15 20 R DS(on) - On-Resistance (Ω) g fs - Transconductance (S) 2 VGS - Gate-to-Source Voltage (V) TC = - 55 °C 15 TC = 25 °C 10 TC = 125 °C 5 0 0.12 0.09 VGS = 4.5 V 0.06 0.03 VGS = 10 V 0.00 0 2 4 6 I D - Drain Current (A) 10 8 0 Transconductance 3 6 9 ID - Drain Current (A) 12 15 On-Resistance vs. Drain Current 10 1000 VGS - Gate-to-Source Voltage (V) VDS = 30 V ID = 4 A C - Capacitance (pF) 800 Ciss 600 400 Coss 200 8 6 4 2 Crss 0 0 0 10 20 30 40 VDS - Drain-to-Source Voltage (V) Capacitance E-mail:China@VBsemi TEL:86-755-83251052 50 60 0 4 8 12 16 20 Qg - Total Gate Charge (nC) Gate Charge 3 FDC5661N www.VBsemi.tw TYPICAL CHARACTERISTICS (TA = 25 °C, unless otherwise noted) 10-2 100 10 I S - Source Current (A) I GSS - Gate Current (A) 10-4 TJ = 150 °C 10-6 TJ = 25 °C 10-8 TJ = 150 °C 1 TJ = 25 °C 0.1 0.01 10-10 0 6 12 18 24 0.001 0.0 30 0.2 Gate Current vs. Gate-Source Voltage 0.8 0.6 1.0 1.2 Source-Drain Diode Forward Voltage 0.6 2.1 ID = 3.2 A 0.3 1.8 VGS = 10 V VGS(th) Variance (V) R DS(on) - On-Resistance (Normalized) 0.4 VSD - Source-to-Drain Voltage (V) VGS - Gate-to-Source Voltage (V) 1.5 1.2 0.0 - 0.3 ID = 5 mA - 0.6 ID = 250 µA 0.9 - 0.9 0.6 - 50 - 25 0 50 25 75 100 125 150 175 - 1.2 - 50 - 25 0 TJ - Junction Temperature (°C) On-Resistance vs. Junction Temperature 50 75 100 25 TJ - Temperature (°C) 125 150 175 125 150 175 Threshold Voltage 80 0.20 VDS - Drain-to-Source Voltage (V) R DS(on) - On-Resistance (Ω) ID = 1 mA 0.16 0.12 TJ = 150 °C 0.08 0.04 TJ = 25 °C 0.00 0 1 2 3 4 5 6 7 8 9 VGS - Gate-to-Source Voltage (V) On-Resistance vs. Gate-Source Voltage E-mail:China@VBsemi TEL:86-755-83251052 10 76 72 68 64 60 - 50 - 25 0 25 50 75 100 TJ - Junction Temperature (°C) Drain-Source Breakdown vs. Junction Temperature 4 FDC5661N www.VBsemi.tw THERMAL RATINGS (TA = 25 °C, unless otherwise noted) IDM Limited ID - Drain Current (A) 10 100 μs Limited by RDS(on)* 1 ms 1 10 ms 100 ms 1 s, 10 s, DC 0.1 BVDSS Limited TC = 25 °C Single Pulse 0.01 0.01 0.1 1 10 100 VDS - Drain-to-Source Voltage (V) * VGS > minimum VGS at which RDS(on) is specified Safe Operating Area 1 Normalized Effective Transient Thermal Impedance Duty Cycle = 0.5 0.2 0.1 Notes: 0.05 PDM 0.1 t1 t2 1. Duty Cycle, D = t1 t2 2. Per Unit Base = RthJA = 110 °C/W 0.02 3. TJM - TA = PDMZthJA(t) Single Pulse 4. Surface Mounted 0.01 10 -4 10 -3 10 -2 10 -1 1 Square Wave Pulse Duration (s) 10 100 1000 Normalized thermal Transient Impedance, Junction-to-Ambient E-mail:China@VBsemi TEL:86-755-83251052 5 FDC5661N www.VBsemi.tw THERMAL RATINGS (TA = 25 °C, unless otherwise noted) 1 Normalized Effective Transient Thermal Impedance Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10 -4 10 -3 10 -2 10 -1 1 Square Wave Pulse Duration (s) Normalized thermal Transient Impedance, Junction-to-Foot Note • The characteristics shown in the two graphs - Normalized Transient Thermal Impedance Junction to Ambient (25 °C) - Normalized Transient Thermal Impedance Junction to Foot (25 °C) are given for general guidelines only to enable the user to get a “ball park” indication of part capabilities. The data are extracted from single pulse transient thermal impedance characteristics which are developed from empirical measurements. The latter is valid for the part mounted on printed circuit board - FR4, size 1" x 1" x 0.062", double sided with 2 oz. copper, 100 % on both sides. The part capabilities can widely vary depending on actual application parameters and operating conditions.                    E-mail:China@VBsemi TEL:86-755-83251052 6 FDC5661N www.VBsemi.tw Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives ( collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.tw) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: ( 1) any application and all liability arising out of or use of any products; ( 2) any and all liability, including but not limited to special, consequential damages or incidental ; ( 3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be R oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 R i Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.tw) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A. E-mail:China@VBsemi TEL:86-755-83251052 7
FDC5661N 价格&库存
很抱歉,暂时无法提供与“FDC5661N”相匹配的价格&库存,您可以联系我们找货
FDC5661N
  • 1+1.35680
  • 10+1.27200
  • 50+1.14480
  • 150+1.06000
  • 300+1.00064
  • 500+0.97520
