M1~M7
SURFACE MOUNT GENERAL RECTIFIER
SMA/DO-214AC
FEATURES
Low coat construction
Low forward voltage drop
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
260℃/10 secods/.375”(9.5mm)lead length at 5 lbs(2.3kg) tension
0.177(4.50)
0.157(3.99)
0.012(0.305)
0.006(0.152)
0.096(2.42)
0.078(1.98)
MECHANICAL DATA
0.110(2.80)
0.100(2.54)
0.067 (1.70)
0.051 (1.30)
Case: Transfer molded plastic
Epoxy: UL94V-O rate flame retardant
Polarity: Color band denotes cathode end
Lead: Plated axial lead, solderable per MIL-STD-202E method 208C
Mounting position: Any
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
0.208(5.28)
0.188(4.80)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25OC ambient temperature unless otherwise specified
Single Phase, half wave, 60Hz, resistive or inductive load
For capacitive load derate current by 20%
M1
50
35
50
SYMBOLS
VRRM
VRMS
VDC
Maximum Repetitive Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
0.375”(9.5mm) lead length at T A= 25℃
Peak Forward Surge Current
8.3mS single half sine wave superimposed on
rated load (JEDEC method)
M2
100
70
100
M3
200
140
200
M4
400
280
400
M5
600
420
600
M6
800
560
800
M7
1000
700
1000
UNIT
Volts
Volts
Volts
I(AV)
1.0
Amps
IFSM
30
Amps
VF
1.1
5.0
50
Volts
IR(AV)
30
µA
CJ
13
pF
Typical Thermal Resistance (Note 2)
RθJA
50
℃/W
Operating Junction Temperature Range
TJ
TSTG
-55 to +150
-55 to +150
Maximum Instantaneous Forward Voltage @ 1.0A
Maximum DC Reverse Current at Rated
DC Blocking Voltage per element
TA = 25℃
TA = 100℃
Maximum Full Load Reverse Current, full cycle average
0.375”(9.5mm)lead length at TL=75℃
Typical Junction Capacitance (Note 1)
Storage Temperature Range
IR
Notes:
1. Measured at 1.0MHz and Applied Reverse Voltage of 4.0V DC.
2. Thermal Resistance from junction to terminal 6.0mm2 copper pads to each terminal.
www.slkormicro.com
1
µA
M1~M7
RATING AND CHRACTERISTIC CURVES
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
FIG.2-MAXIMUM NON-REPETITIVE PEAK
FORWARD SURGE CURRENT
30
0.8
0.6
0.4
Single Phase
Half Wave 60Hz
0.2
Resistive or
Inductive Load
75
50
150
125
25
CURRENT, (A)
PEAK FORWARD SURGE
1.0
(A)
AVERAGE FORWARD CURRENT,
1.2
8.3ms Single Half Sine-Wave
(JEDEC Method) =T T j
jmax
5
2
1
8
50
100
NUMBER OF CYCLES AT 60 Hz
AMBIENT TEMPERATURE, (° C)
FIG.3-TYPICAL INSTANTANEOUS
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
FORWARD CHARACTERISTICS
10
INSTANTANEOUS REVERSE CURRENT,
(mA)
1
(A)
INSTANTANEOUS FORWARD CURRENT,
10
0.1
T =25° C
j
Pulse Width=300us
1% Duty Cycle
0.01
0.6
0.8
1.0
1.2
1.4
1.6
1.8
2.0
Tj =100° C
1.0
0.1
Tj =25° C
0.01
INSTANTANEOUS FORWARD VOLTAGE,(V)
60
80
PERCENT OF RATED PEAK
REVERSE VOLTAGE,(%)
FIG.5-TYPICAL JUNCTION CAPACITANCE
CAPACITANCE,(pF)
100
10
TJ=25° C F=1MHz
10
0.1
1.0
4.0
10.0
100
REVERSE VOLTAGE,(VOLTS)
www.slkormicro.com
2
100
120
140
很抱歉,暂时无法提供与“M7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.06296
- 400+0.05039
- 800+0.04963
- 2000+0.03891
- 10000+0.03465
- 20000+0.03109
- 国内价格
- 50+0.06869
- 500+0.05498
- 2000+0.04245
- 4000+0.03780
- 24000+0.03392
- 50000+0.03176
- 国内价格
- 1+0.07282
- 50+0.03641
- 2000+0.02761
