S-1335C24-N4T1U3
S-1335C24-N4T1U3
    ABLIC(艾普凌科)
    SC82A
    IC REG LINEAR 2.4V 150MA SC82AB
S-1335C24-N4T1U3 数据手册
S-1335 Series www.ablic.com 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 © ABLIC Inc., 2012-2019 The S-1335 Series, developed by using the CMOS technology, is a positive voltage regulator IC of 150 mA output current, which has low dropout voltage, high-accuracy output voltage and soft-start function. The rising time of output voltage immediately after power-on or after the ON / OFF pin is set to ON is adjustable. A 1.0 μF small ceramic capacitor can be used. It operates with low current consumption of 36 μA typ. Furthermore the overcurrent protection circuit prevents the load current from exceeding the capacity of output transistor. SOT-23-5, SC-82AB and super small HSNT-4 (1010) packages realize high-density mounting.  Features • Output voltage: • Input voltage: • Output voltage accuracy: • Dropout voltage: • Current consumption: • Output current: • Input and output capacitors: • Ripple rejection: • Built-in soft-start circuit: • Built-in overcurrent protection circuit: • Built-in ON / OFF circuit: • Operation temperature range: • Lead-free (Sn 100%), halogen-free *1. 1.0 V to 3.6 V, selectable in 0.05 V step 1.5 V to 5.5 V ±1.0% (1.0 V to 1.45 V output product: ±15 mV) 70 mV typ. (2.8 V output product, IOUT = 100 mA) During operation: 36 μA typ., 54 μA max. During power-off: 0.1 μA typ., 1.0 μA max. Possible to output 150 mA (VIN ≥ VOUT(S) + 1.0 V)*1 A ceramic capacitor of 1.0 μF or more can be used. 70 dB typ. (f = 10 kHz, VOUT(S) ≤ 2.5 V) 80 dB typ. (f = 1.0 kHz) The rising time of output voltage immediately after power-on or after the ON / OFF pin is set to ON is adjustable. The soft-start time of SOT-23-5 can be switched to tSS0 = 0.1 ms typ. / tSS1 = 1.0 ms typ. with the SST pin. The soft-start time of SC-82AB is fixed to tSS0 = 0.1 ms typ. The soft-start time of HSNT-4 (1010) is fixed to either tSS0 = 0.1 ms typ. or tSS1 = 1.0 ms typ. Limits overcurrent of output transistor. Ensures long battery life. Discharge shunt function "available" / "unavailable" is selectable. Pull-down function "available" / "unavailable" is selectable. Ta = −40°C to +85°C Attention should be paid to the power dissipation of the package when the output current is large.  Applications • Constant-voltage power supply for digital still camera, TV • Constant-voltage power supply for battery-powered device • Constant-voltage power supply for cellular phone • Constant-voltage power supply for portable equipment  Packages • SOT-23-5 • SC-82AB • HSNT-4 (1010) 1 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series  Block Diagrams 1. S-1335 Series A / E type *1 VIN VOUT Overcurrent protection circuit Soft-start circuit ON / OFF circuit ON / OFF Function ON / OFF logic Discharge shunt function Pull-down resistor Soft-start time (typ.) Status Active "H" Available Available A type: 0.1 ms E type: 1.0 ms + − Reference voltage circuit *1 VSS *1. Parasitic diode Figure 1 2. S-1335 Series B / F type *1 VIN VOUT Overcurrent protection circuit Soft-start circuit ON / OFF ON / OFF circuit + − Reference voltage circuit *1 VSS *1. Parasitic diode Figure 2 2 Function ON / OFF logic Discharge shunt function Pull-down resistor Soft-start time (typ.) Status Active "H" Available Unavailable B type: 0.1 ms F type: 1.0 ms 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 3. S-1335 Series C / G type *1 VIN VOUT Overcurrent protection circui Soft-start circuit ON / OFF circuit ON / OFF Function ON / OFF logic Discharge shunt function Pull-down resistor Soft-start time (typ.) Status Active "H" Unavailable Available C type: 0.1 ms G type: 1.0 ms + − Reference voltage circuit VSS *1. Parasitic diode Figure 3 4. S-1335 Series D / H type *1 VIN VOUT Overcurrent protection circuit Soft-start circuit ON / OFF ON / OFF circuit Function ON / OFF logic Discharge shunt function Pull-down resistor Soft-start time (typ.) Status Active "H" Unavailable Unavailable D type: 0.1 ms H type: 1.0 ms + − Reference voltage circuit VSS *1. Parasitic diode Figure 4 3 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 5. S-1335 Series J type *1 VIN VOUT Overcurrent protection circuit SST Soft-start circuit ON / OFF circuit ON / OFF Function ON / OFF logic Discharge shunt function Pull-down resistor Soft-start time (typ.) Status Active "H" Available Available 0.1 ms / 1.0 ms (Switchable) + − Reference voltage circuit *1 VSS *1. Parasitic diode Figure 5 6. S-1335 Series K type *1 VIN SST VOUT Overcurrent protection circuit Soft-start circuit ON / OFF ON / OFF circuit + − Reference voltage circuit *1 VSS *1. Parasitic diode Figure 6 4 Function ON / OFF logic Discharge shunt function Pull-down resistor Soft-start time (typ.) Status Active "H" Available Unavailable 0.1 ms / 1.0 ms (Switchable) 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 7. S-1335 Series L type *1 VIN SST VOUT Overcurrent protection circuit Soft-start circuit ON / OFF circuit ON / OFF Function ON / OFF logic Discharge shunt function Pull-down resistor Soft-start time (typ.) Status Active "H" Unavailable Available 0.1 ms / 1.0 ms (Switchable) + − Reference voltage circuit VSS *1. Parasitic diode Figure 7 8. S-1335 Series M type *1 VIN SST VOUT Overcurrent protection circuit Soft-start circuit ON / OFF ON / OFF circuit Function ON / OFF logic Discharge shunt function Pull-down resistor Soft-start time (typ.) Status Active "H" Unavailable Unavailable 0.1 ms / 1.0 ms (Switchable) + − Reference voltage circuit VSS *1. Parasitic diode Figure 8 5 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series  Product Name Structure Users can select the product type, output voltage, and package type for the S-1335 Series. Refer to "1. Product name" regarding the contents of product name, "2. Function list of product type" regarding the product type, "3. Packages" regarding the package drawings, "4. Product name list" regarding details of the product name. 1. Product name S-1335 x xx - xxxx U 3 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 M5T1: SOT-23-5, Tape N4T1: SC-82AB, Tape A4T2: HSNT-4 (1010), Tape Output voltage*2 10 to 36 (e.g., when the output voltage is 1.0 V, it is expressed as 10.) Product type*3 A to M *1. *2. *3. 2. Refer to the tape drawing. Contact our sales representatives when the product which has 0.05 V step is necessary. Refer to "2. Function list of product type". Function list of product type Table 1 Product ON / OFF Type Logic 6 Discharge Shunt Function Pull-down Resistor Soft-start Time (typ.) A Active "H" Available Available 0.1 ms B Active "H" Available Unavailable 0.1 ms C Active "H" Unavailable Available 0.1 ms D Active "H" Unavailable Unavailable 0.1 ms E F G H J K L M Active Active Active Active Active Active Active Active Available Available Unavailable Unavailable Available Available Unavailable Unavailable Available Unavailable Available Unavailable Available Unavailable Available Unavailable "H" "H" "H" "H" "H" "H" "H" "H" 0.1 0.1 0.1 0.1 ms ms ms ms / / / / 1.0 ms 1.0 ms 1.0 ms 1.0 ms 1.0 ms (Switchable) 1.0 ms (Switchable) 1.0 ms (Switchable) 1.0 ms (Switchable) Package SC-82AB, HSNT-4 (1010) SC-82AB, HSNT-4 (1010) SC-82AB, HSNT-4 (1010) SC-82AB, HSNT-4 (1010) HSNT-4 (1010) HSNT-4 (1010) HSNT-4 (1010) HSNT-4 (1010) SOT-23-5 SOT-23-5 SOT-23-5 SOT-23-5 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 3. Packages Table 2 Package Name 4. Package Drawing Codes Dimension Tape Reel Land SOT-23-5 MP005-A-P-SD MP005-A-R-SD − SC-82AB NP004-A-P-SD NP004-A-R-SD − HSNT-4 (1010) PL004-A-P-SD MP005-A-C-SD NP004-A-C-SD NP004-A-C-S1 PL004-A-C-SD PL004-A-R-SD PL004-A-L-SD Product name list 4. 1 S-1335 Series A type ON / OFF logic: Discharge shunt function: Pull-down resistor: Soft-start time: Active "H" Available Available 0.1 ms typ. Table 3 SC-82AB HSNT-4 (1010) Output Voltage S-1335A10-N4T1U3 S-1335A10-A4T2U3 1.0 V ± 15 mV S-1335A11-N4T1U3 S-1335A11-A4T2U3 1.1 V ± 15 mV S-1335A12-N4T1U3 S-1335A12-A4T2U3 1.2 V ± 15 mV S-1335A13-N4T1U3 S-1335A13-A4T2U3 1.3 V ± 15 mV S-1335A14-N4T1U3 S-1335A14-A4T2U3 1.4 V ± 15 mV S-1335A15-N4T1U3 S-1335A15-A4T2U3 1.5 V ± 1.0% S-1335A16-N4T1U3 S-1335A16-A4T2U3 1.6 V ± 1.0% S-1335A17-N4T1U3 S-1335A17-A4T2U3 1.7 V ± 1.0% S-1335A18-N4T1U3 S-1335A18-A4T2U3 1.8 V ± 1.0% S-1335A19-N4T1U3 S-1335A19-A4T2U3 1.9 V ± 1.0% S-1335A20-N4T1U3 S-1335A20-A4T2U3 2.0 V ± 1.0% S-1335A21-N4T1U3 S-1335A21-A4T2U3 2.1 V ± 1.0% S-1335A22-N4T1U3 S-1335A22-A4T2U3 2.2 V ± 1.0% S-1335A23-A4T2U3 S-1335A23-N4T1U3 2.3 V ± 1.0% S-1335A24-A4T2U3 S-1335A24-N4T1U3 2.4 V ± 1.0% S-1335A25-A4T2U3 S-1335A25-N4T1U3 2.5 V ± 1.0% S-1335A26-N4T1U3 S-1335A26-A4T2U3 2.6 V ± 1.0% S-1335A27-N4T1U3 S-1335A27-A4T2U3 2.7 V ± 1.0% S-1335A28-A4T2U3 S-1335A28-N4T1U3 2.8 V ± 1.0% S-1335A2J-N4T1U3 S-1335A2J-A4T2U3 2.85 V ± 1.0% S-1335A29-N4T1U3 S-1335A29-A4T2U3 2.9 V ± 1.0% S-1335A30-N4T1U3 S-1335A30-A4T2U3 3.0 V ± 1.0% S-1335A31-N4T1U3 S-1335A31-A4T2U3 3.1 V ± 1.0% S-1335A32-N4T1U3 S-1335A32-A4T2U3 3.2 V ± 1.0% S-1335A33-N4T1U3 S-1335A33-A4T2U3 3.3 V ± 1.0% S-1335A34-N4T1U3 S-1335A34-A4T2U3 3.4 V ± 1.0% S-1335A35-N4T1U3 S-1335A35-A4T2U3 3.5 V ± 1.0% S-1335A36-N4T1U3 S-1335A36-A4T2U3 3.6 V ± 1.0% Remark Please contact our sales representatives for products other than the above. 7 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 4. 2 S-1335 Series B type ON / OFF logic: Discharge shunt function: Pull-down resistor: Soft-start time: Active "H" Available Unavailable 0.1 ms typ. Table 4 SC-82AB HSNT-4 (1010) Output Voltage S-1335B10-N4T1U3 S-1335B10-A4T2U3 1.0 V ± 15 mV S-1335B11-N4T1U3 S-1335B11-A4T2U3 1.1 V ± 15 mV S-1335B12-N4T1U3 S-1335B12-A4T2U3 1.2 V ± 15 mV S-1335B13-N4T1U3 S-1335B13-A4T2U3 1.3 V ± 15 mV S-1335B14-N4T1U3 S-1335B14-A4T2U3 1.4 V ± 15 mV S-1335B15-N4T1U3 S-1335B15-A4T2U3 1.5 V ± 1.0% S-1335B16-N4T1U3 S-1335B16-A4T2U3 1.6 V ± 1.0% S-1335B17-N4T1U3 S-1335B17-A4T2U3 1.7 V ± 1.0% S-1335B18-N4T1U3 S-1335B18-A4T2U3 1.8 V ± 1.0% S-1335B19-N4T1U3 S-1335B19-A4T2U3 1.9 V ± 1.0% S-1335B20-N4T1U3 S-1335B20-A4T2U3 2.0 V ± 1.0% S-1335B21-N4T1U3 S-1335B21-A4T2U3 2.1 V ± 1.0% S-1335B22-N4T1U3 S-1335B22-A4T2U3 2.2 V ± 1.0% S-1335B23-A4T2U3 S-1335B23-N4T1U3 2.3 V ± 1.0% S-1335B24-A4T2U3 S-1335B24-N4T1U3 2.4 V ± 1.0% S-1335B25-A4T2U3 S-1335B25-N4T1U3 2.5 V ± 1.0% S-1335B26-N4T1U3 S-1335B26-A4T2U3 2.6 V ± 1.0% S-1335B27-N4T1U3 S-1335B27-A4T2U3 2.7 V ± 1.0% S-1335B28-A4T2U3 S-1335B28-N4T1U3 2.8 V ± 1.0% S-1335B2J-N4T1U3 S-1335B2J-A4T2U3 2.85 V ± 1.0% S-1335B29-N4T1U3 S-1335B29-A4T2U3 2.9 V ± 1.0% S-1335B30-N4T1U3 S-1335B30-A4T2U3 3.0 V ± 1.0% S-1335B31-N4T1U3 S-1335B31-A4T2U3 3.1 V ± 1.0% S-1335B32-N4T1U3 S-1335B32-A4T2U3 3.2 V ± 1.0% S-1335B33-N4T1U3 S-1335B33-A4T2U3 3.3 V ± 1.0% S-1335B34-N4T1U3 S-1335B34-A4T2U3 3.4 V ± 1.0% S-1335B35-N4T1U3 S-1335B35-A4T2U3 3.5 V ± 1.0% S-1335B36-N4T1U3 S-1335B36-A4T2U3 3.6 V ± 1.0% Remark Please contact our sales representatives for products other than the above. 8 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 4. 3 S-1335 Series C type ON / OFF logic: Discharge shunt function: Pull-down resistor: Soft-start time: Active "H" Unavailable Available 0.1 ms typ. Table 5 SC-82AB HSNT-4 (1010) Output Voltage S-1335C10-N4T1U3 S-1335C10-A4T2U3 1.0 V ± 15 mV S-1335C11-N4T1U3 S-1335C11-A4T2U3 1.1 V ± 15 mV S-1335C12-N4T1U3 S-1335C12-A4T2U3 1.2 V ± 15 mV S-1335C13-N4T1U3 S-1335C13-A4T2U3 1.3 V ± 15 mV S-1335C14-N4T1U3 S-1335C14-A4T2U3 1.4 V ± 15 mV S-1335C15-N4T1U3 S-1335C15-A4T2U3 1.5 V ± 1.0% S-1335C16-N4T1U3 S-1335C16-A4T2U3 1.6 V ± 1.0% S-1335C17-N4T1U3 S-1335C17-A4T2U3 1.7 V ± 1.0% S-1335C18-N4T1U3 S-1335C18-A4T2U3 1.8 V ± 1.0% S-1335C19-N4T1U3 S-1335C19-A4T2U3 1.9 V ± 1.0% S-1335C20-N4T1U3 S-1335C20-A4T2U3 2.0 V ± 1.0% S-1335C21-N4T1U3 S-1335C21-A4T2U3 2.1 V ± 1.0% S-1335C22-N4T1U3 S-1335C22-A4T2U3 2.2 V ± 1.0% S-1335C23-A4T2U3 S-1335C23-N4T1U3 2.3 V ± 1.0% S-1335C24-A4T2U3 S-1335C24-N4T1U3 2.4 V ± 1.0% S-1335C25-A4T2U3 S-1335C25-N4T1U3 2.5 V ± 1.0% S-1335C26-N4T1U3 S-1335C26-A4T2U3 2.6 V ± 1.0% S-1335C27-N4T1U3 S-1335C27-A4T2U3 2.7 V ± 1.0% S-1335C28-A4T2U3 S-1335C28-N4T1U3 2.8 V ± 1.0% S-1335C2J-N4T1U3 S-1335C2J-A4T2U3 2.85 V ± 1.0% S-1335C29-N4T1U3 S-1335C29-A4T2U3 2.9 V ± 1.0% S-1335C30-N4T1U3 S-1335C30-A4T2U3 3.0 V ± 1.0% S-1335C31-N4T1U3 S-1335C31-A4T2U3 3.1 V ± 1.0% S-1335C32-N4T1U3 S-1335C32-A4T2U3 3.2 V ± 1.0% S-1335C33-N4T1U3 S-1335C33-A4T2U3 3.3 V ± 1.0% S-1335C34-N4T1U3 S-1335C34-A4T2U3 3.4 V ± 1.0% S-1335C35-N4T1U3 S-1335C35-A4T2U3 3.5 V ± 1.0% S-1335C36-N4T1U3 S-1335C36-A4T2U3 3.6 V ± 1.0% Remark Please contact our sales representatives for products other than the above. 9 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 4. 4 S-1335 Series D type ON / OFF logic: Discharge shunt function: Pull-down resistor: Soft-start time: Active "H" Unavailable Unavailable 0.1 ms typ. Table 6 SC-82AB HSNT-4 (1010) Output Voltage S-1335D10-N4T1U3 S-1335D10-A4T2U3 1.0 V ± 15 mV S-1335D11-N4T1U3 S-1335D11-A4T2U3 1.1 V ± 15 mV S-1335D12-N4T1U3 S-1335D12-A4T2U3 1.2 V ± 15 mV S-1335D13-N4T1U3 S-1335D13-A4T2U3 1.3 V ± 15 mV S-1335D14-N4T1U3 S-1335D14-A4T2U3 1.4 V ± 15 mV S-1335D15-N4T1U3 S-1335D15-A4T2U3 1.5 V ± 1.0% S-1335D16-N4T1U3 S-1335D16-A4T2U3 1.6 V ± 1.0% S-1335D17-N4T1U3 S-1335D17-A4T2U3 1.7 V ± 1.0% S-1335D18-N4T1U3 S-1335D18-A4T2U3 1.8 V ± 1.0% S-1335D19-N4T1U3 S-1335D19-A4T2U3 1.9 V ± 1.0% S-1335D20-N4T1U3 S-1335D20-A4T2U3 2.0 V ± 1.0% S-1335D21-N4T1U3 S-1335D21-A4T2U3 2.1 V ± 1.0% S-1335D22-N4T1U3 S-1335D22-A4T2U3 2.2 V ± 1.0% S-1335D23-A4T2U3 S-1335D23-N4T1U3 2.3 V ± 1.0% S-1335D24-A4T2U3 S-1335D24-N4T1U3 2.4 V ± 1.0% S-1335D25-A4T2U3 S-1335D25-N4T1U3 2.5 V ± 1.0% S-1335D26-N4T1U3 S-1335D26-A4T2U3 2.6 V ± 1.0% S-1335D27-N4T1U3 S-1335D27-A4T2U3 2.7 V ± 1.0% S-1335D28-A4T2U3 S-1335D28-N4T1U3 2.8 V ± 1.0% S-1335D2J-N4T1U3 S-1335D2J-A4T2U3 2.85 V ± 1.0% S-1335D29-N4T1U3 S-1335D29-A4T2U3 2.9 V ± 1.0% S-1335D30-N4T1U3 S-1335D30-A4T2U3 3.0 V ± 1.0% S-1335D31-N4T1U3 S-1335D31-A4T2U3 3.1 V ± 1.0% S-1335D32-N4T1U3 S-1335D32-A4T2U3 3.2 V ± 1.0% S-1335D33-N4T1U3 S-1335D33-A4T2U3 3.3 V ± 1.0% S-1335D34-N4T1U3 S-1335D34-A4T2U3 3.4 V ± 1.0% S-1335D35-N4T1U3 S-1335D35-A4T2U3 3.5 V ± 1.0% S-1335D36-N4T1U3 S-1335D36-A4T2U3 3.6 V ± 1.0% Remark Please contact our sales representatives for products other than the above. 10 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 4. 5 S-1335 Series E type ON / OFF logic: Discharge shunt function: Pull-down resistor: Soft-start time: Active "H" Available Available 1.0 ms typ. Table 7 Remark HSNT-4 (1010) Output Voltage S-1335E10-A4T2U3 1.0 V ± 15 mV S-1335E11-A4T2U3 1.1 V ± 15 mV S-1335E12-A4T2U3 1.2 V ± 15 mV S-1335E13-A4T2U3 1.3 V ± 15 mV S-1335E14-A4T2U3 1.4 V ± 15 mV S-1335E15-A4T2U3 1.5 V ± 1.0% S-1335E16-A4T2U3 1.6 V ± 1.0% S-1335E17-A4T2U3 1.7 V ± 1.0% S-1335E18-A4T2U3 1.8 V ± 1.0% S-1335E19-A4T2U3 1.9 V ± 1.0% S-1335E20-A4T2U3 2.0 V ± 1.0% S-1335E21-A4T2U3 2.1 V ± 1.0% S-1335E22-A4T2U3 2.2 V ± 1.0% S-1335E23-A4T2U3 2.3 V ± 1.0% S-1335E24-A4T2U3 2.4 V ± 1.0% S-1335E25-A4T2U3 2.5 V ± 1.0% S-1335E26-A4T2U3 2.6 V ± 1.0% S-1335E27-A4T2U3 2.7 V ± 1.0% S-1335E28-A4T2U3 2.8 V ± 1.0% S-1335E2J-A4T2U3 2.85 V ± 1.0% S-1335E29-A4T2U3 2.9 V ± 1.0% S-1335E30-A4T2U3 3.0 V ± 1.0% S-1335E31-A4T2U3 3.1 V ± 1.0% S-1335E32-A4T2U3 3.2 V ± 1.0% S-1335E33-A4T2U3 3.3 V ± 1.0% S-1335E34-A4T2U3 3.4 V ± 1.0% S-1335E35-A4T2U3 3.5 V ± 1.0% S-1335E36-A4T2U3 3.6 V ± 1.0% Please contact our sales representatives for products other than the above. 11 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 4. 6 S-1335 Series F type ON / OFF logic: Discharge shunt function: Pull-down resistor: Soft-start time: Active "H" Available Unavailable 1.0 ms typ. Table 8 Remark 12 HSNT-4 (1010) Output Voltage S-1335F10-A4T2U3 1.0 V ± 15 mV S-1335F11-A4T2U3 1.1 V ± 15 mV S-1335F12-A4T2U3 1.2 V ± 15 mV S-1335F13-A4T2U3 1.3 V ± 15 mV S-1335F14-A4T2U3 1.4 V ± 15 mV S-1335F15-A4T2U3 1.5 V ± 1.0% S-1335F16-A4T2U3 1.6 V ± 1.0% S-1335F17-A4T2U3 1.7 V ± 1.0% S-1335F18-A4T2U3 1.8 V ± 1.0% S-1335F19-A4T2U3 1.9 V ± 1.0% S-1335F20-A4T2U3 2.0 V ± 1.0% S-1335F21-A4T2U3 2.1 V ± 1.0% S-1335F22-A4T2U3 2.2 V ± 1.0% S-1335F23-A4T2U3 2.3 V ± 1.0% S-1335F24-A4T2U3 2.4 V ± 1.0% S-1335F25-A4T2U3 2.5 V ± 1.0% S-1335F26-A4T2U3 2.6 V ± 1.0% S-1335F27-A4T2U3 2.7 V ± 1.0% S-1335F28-A4T2U3 2.8 V ± 1.0% S-1335F2J-A4T2U3 2.85 V ± 1.0% S-1335F29-A4T2U3 2.9 V ± 1.0% S-1335F30-A4T2U3 3.0 V ± 1.0% S-1335F31-A4T2U3 3.1 V ± 1.0% S-1335F32-A4T2U3 3.2 V ± 1.0% S-1335F33-A4T2U3 3.3 V ± 1.0% S-1335F34-A4T2U3 3.4 V ± 1.0% S-1335F35-A4T2U3 3.5 V ± 1.0% S-1335F36-A4T2U3 3.6 V ± 1.0% Please contact our sales representatives for products other than the above. 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 4. 7 S-1335 Series G type ON / OFF logic: Discharge shunt function: Pull-down resistor: Soft-start time: Active "H" Unavailable Available 1.0 ms typ. Table 9 Remark HSNT-4 (1010) Output Voltage S-1335G10-A4T2U3 1.0 V ± 15 mV S-1335G11-A4T2U3 1.1 V ± 15 mV S-1335G12-A4T2U3 1.2 V ± 15 mV S-1335G13-A4T2U3 1.3 V ± 15 mV S-1335G14-A4T2U3 1.4 V ± 15 mV S-1335G15-A4T2U3 1.5 V ± 1.0% S-1335G16-A4T2U3 1.6 V ± 1.0% S-1335G17-A4T2U3 1.7 V ± 1.0% S-1335G18-A4T2U3 1.8 V ± 1.0% S-1335G19-A4T2U3 1.9 V ± 1.0% S-1335G20-A4T2U3 2.0 V ± 1.0% S-1335G21-A4T2U3 2.1 V ± 1.0% S-1335G22-A4T2U3 2.2 V ± 1.0% S-1335G23-A4T2U3 2.3 V ± 1.0% S-1335G24-A4T2U3 2.4 V ± 1.0% S-1335G25-A4T2U3 2.5 V ± 1.0% S-1335G26-A4T2U3 2.6 V ± 1.0% S-1335G27-A4T2U3 2.7 V ± 1.0% S-1335G28-A4T2U3 2.8 V ± 1.0% S-1335G2J-A4T2U3 2.85 V ± 1.0% S-1335G29-A4T2U3 2.9 V ± 1.0% S-1335G30-A4T2U3 3.0 V ± 1.0% S-1335G31-A4T2U3 3.1 V ± 1.0% S-1335G32-A4T2U3 3.2 V ± 1.0% S-1335G33-A4T2U3 3.3 V ± 1.0% S-1335G34-A4T2U3 3.4 V ± 1.0% S-1335G35-A4T2U3 3.5 V ± 1.0% S-1335G36-A4T2U3 3.6 V ± 1.0% Please contact our sales representatives for products other than the above. 13 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 4. 8 S-1335 Series H type ON / OFF logic: Discharge shunt function: Pull-down resistor: Soft-start time: Active "H" Unavailable Unavailable 1.0 ms typ. Table 10 Remark 14 HSNT-4 (1010) Output Voltage S-1335H10-A4T2U3 1.0 V ± 15 mV S-1335H11-A4T2U3 1.1 V ± 15 mV S-1335H12-A4T2U3 1.2 V ± 15 mV S-1335H13-A4T2U3 1.3 V ± 15 mV S-1335H14-A4T2U3 1.4 V ± 15 mV S-1335H15-A4T2U3 1.5 V ± 1.0% S-1335H16-A4T2U3 1.6 V ± 1.0% S-1335H17-A4T2U3 1.7 V ± 1.0% S-1335H18-A4T2U3 1.8 V ± 1.0% S-1335H19-A4T2U3 1.9 V ± 1.0% S-1335H20-A4T2U3 2.0 V ± 1.0% S-1335H21-A4T2U3 2.1 V ± 1.0% S-1335H22-A4T2U3 2.2 V ± 1.0% S-1335H23-A4T2U3 2.3 V ± 1.0% S-1335H24-A4T2U3 2.4 V ± 1.0% S-1335H25-A4T2U3 2.5 V ± 1.0% S-1335H26-A4T2U3 2.6 V ± 1.0% S-1335H27-A4T2U3 2.7 V ± 1.0% S-1335H28-A4T2U3 2.8 V ± 1.0% S-1335H2J-A4T2U3 2.85 V ± 1.0% S-1335H29-A4T2U3 2.9 V ± 1.0% S-1335H30-A4T2U3 3.0 V ± 1.0% S-1335H31-A4T2U3 3.1 V ± 1.0% S-1335H32-A4T2U3 3.2 V ± 1.0% S-1335H33-A4T2U3 3.3 V ± 1.0% S-1335H34-A4T2U3 3.4 V ± 1.0% S-1335H35-A4T2U3 3.5 V ± 1.0% S-1335H36-A4T2U3 3.6 V ± 1.0% Please contact our sales representatives for products other than the above. 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 4. 9 S-1335 Series J type ON / OFF logic: Discharge shunt function: Pull-down resistor: Soft-start time: Active "H" Available Available 0.1 ms typ. / 1.0 ms typ. (Switchable) Table 11 Remark SOT-23-5 Output Voltage S-1335J10-M5T1U3 1.0 V ± 15 mV S-1335J11-M5T1U3 1.1 V ± 15 mV S-1335J12-M5T1U3 1.2 V ± 15 mV S-1335J13-M5T1U3 1.3 V ± 15 mV S-1335J14-M5T1U3 1.4 V ± 15 mV S-1335J15-M5T1U3 1.5 V ± 1.0% S-1335J16-M5T1U3 1.6 V ± 1.0% S-1335J17-M5T1U3 1.7 V ± 1.0% S-1335J18-M5T1U3 1.8 V ± 1.0% S-1335J19-M5T1U3 1.9 V ± 1.0% S-1335J20-M5T1U3 2.0 V ± 1.0% S-1335J21-M5T1U3 2.1 V ± 1.0% S-1335J22-M5T1U3 2.2 V ± 1.0% S-1335J23-M5T1U3 2.3 V ± 1.0% S-1335J24-M5T1U3 2.4 V ± 1.0% S-1335J25-M5T1U3 2.5 V ± 1.0% S-1335J26-M5T1U3 2.6 V ± 1.0% S-1335J27-M5T1U3 2.7 V ± 1.0% S-1335J28-M5T1U3 2.8 V ± 1.0% S-1335J2J-M5T1U3 2.85 V ± 1.0% S-1335J29-M5T1U3 2.9 V ± 1.0% S-1335J30-M5T1U3 3.0 V ± 1.0% S-1335J31-M5T1U3 3.1 V ± 1.0% S-1335J32-M5T1U3 3.2 V ± 1.0% S-1335J33-M5T1U3 3.3 V ± 1.0% S-1335J34-M5T1U3 3.4 V ± 1.0% S-1335J35-M5T1U3 3.5 V ± 1.0% S-1335J36-M5T1U3 3.6 V ± 1.0% Please contact our sales representatives for products other than the above. 15 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 4. 10 S-1335 Series K type ON / OFF logic: Discharge shunt function: Pull-down resistor: Soft-start time: Active "H" Available Unavailable 0.1 ms typ. / 1.0 ms typ. (Switchable) Table 12 Remark 16 SOT-23-5 Output Voltage S-1335K10-M5T1U3 1.0 V ± 15 mV S-1335K11-M5T1U3 1.1 V ± 15 mV S-1335K12-M5T1U3 1.2 V ± 15 mV S-1335K13-M5T1U3 1.3 V ± 15 mV S-1335K14-M5T1U3 1.4 V ± 15 mV S-1335K15-M5T1U3 1.5 V ± 1.0% S-1335K16-M5T1U3 1.6 V ± 1.0% S-1335K17-M5T1U3 1.7 V ± 1.0% S-1335K18-M5T1U3 1.8 V ± 1.0% S-1335K19-M5T1U3 1.9 V ± 1.0% S-1335K20-M5T1U3 2.0 V ± 1.0% S-1335K21-M5T1U3 2.1 V ± 1.0% S-1335K22-M5T1U3 2.2 V ± 1.0% S-1335K23-M5T1U3 2.3 V ± 1.0% S-1335K24-M5T1U3 2.4 V ± 1.0% S-1335K25-M5T1U3 2.5 V ± 1.0% S-1335K26-M5T1U3 2.6 V ± 1.0% S-1335K27-M5T1U3 2.7 V ± 1.0% S-1335K28-M5T1U3 2.8 V ± 1.0% S-1335K2J-M5T1U3 2.85 V ± 1.0% S-1335K29-M5T1U3 2.9 V ± 1.0% S-1335K30-M5T1U3 3.0 V ± 1.0% S-1335K31-M5T1U3 3.1 V ± 1.0% S-1335K32-M5T1U3 3.2 V ± 1.0% S-1335K33-M5T1U3 3.3 V ± 1.0% S-1335K34-M5T1U3 3.4 V ± 1.0% S-1335K35-M5T1U3 3.5 V ± 1.0% S-1335K36-M5T1U3 3.6 V ± 1.0% Please contact our sales representatives for products other than the above. 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 4. 11 S-1335 Series L type ON / OFF logic: Discharge shunt function: Pull-down resistor: Soft-start time: Active "H" Unavailable Available 0.1 ms typ. / 1.0 ms typ. (Switchable) Table 13 Remark SOT-23-5 Output Voltage S-1335L10-M5T1U3 1.0 V ± 15 mV S-1335L11-M5T1U3 1.1 V ± 15 mV S-1335L12-M5T1U3 1.2 V ± 15 mV S-1335L13-M5T1U3 1.3 V ± 15 mV S-1335L14-M5T1U3 1.4 V ± 15 mV S-1335L15-M5T1U3 1.5 V ± 1.0% S-1335L16-M5T1U3 1.6 V ± 1.0% S-1335L17-M5T1U3 1.7 V ± 1.0% S-1335L18-M5T1U3 1.8 V ± 1.0% S-1335L19-M5T1U3 1.9 V ± 1.0% S-1335L20-M5T1U3 2.0 V ± 1.0% S-1335L21-M5T1U3 2.1 V ± 1.0% S-1335L22-M5T1U3 2.2 V ± 1.0% S-1335L23-M5T1U3 2.3 V ± 1.0% S-1335L24-M5T1U3 2.4 V ± 1.0% S-1335L25-M5T1U3 2.5 V ± 1.0% S-1335L26-M5T1U3 2.6 V ± 1.0% S-1335L27-M5T1U3 2.7 V ± 1.0% S-1335L28-M5T1U3 2.8 V ± 1.0% S-1335L2J-M5T1U3 2.85 V ± 1.0% S-1335L29-M5T1U3 2.9 V ± 1.0% S-1335L30-M5T1U3 3.0 V ± 1.0% S-1335L31-M5T1U3 3.1 V ± 1.0% S-1335L32-M5T1U3 3.2 V ± 1.0% S-1335L33-M5T1U3 3.3 V ± 1.0% S-1335L34-M5T1U3 3.4 V ± 1.0% S-1335L35-M5T1U3 3.5 V ± 1.0% S-1335L36-M5T1U3 3.6 V ± 1.0% Please contact our sales representatives for products other than the above. 17 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 4. 12 S-1335 Series M type ON / OFF logic: Discharge shunt function: Pull-down resistor: Soft-start time: Active "H" Unavailable Unavailable 0.1 ms typ. / 1.0 ms typ. (Switchable) Table 14 Remark 18 SOT-23-5 Output Voltage S-1335M10-M5T1U3 1.0 V ± 15 mV S-1335M11-M5T1U3 1.1 V ± 15 mV S-1335M12-M5T1U3 1.2 V ± 15 mV S-1335M13-M5T1U3 1.3 V ± 15 mV S-1335M14-M5T1U3 1.4 V ± 15 mV S-1335M15-M5T1U3 1.5 V ± 1.0% S-1335M16-M5T1U3 1.6 V ± 1.0% S-1335M17-M5T1U3 1.7 V ± 1.0% S-1335M18-M5T1U3 1.8 V ± 1.0% S-1335M19-M5T1U3 1.9 V ± 1.0% S-1335M20-M5T1U3 2.0 V ± 1.0% S-1335M21-M5T1U3 2.1 V ± 1.0% S-1335M22-M5T1U3 2.2 V ± 1.0% S-1335M23-M5T1U3 2.3 V ± 1.0% S-1335M24-M5T1U3 2.4 V ± 1.0% S-1335M25-M5T1U3 2.5 V ± 1.0% S-1335M26-M5T1U3 2.6 V ± 1.0% S-1335M27-M5T1U3 2.7 V ± 1.0% S-1335M28-M5T1U3 2.8 V ± 1.0% S-1335M2J-M5T1U3 2.85 V ± 1.0% S-1335M29-M5T1U3 2.9 V ± 1.0% S-1335M30-M5T1U3 3.0 V ± 1.0% S-1335M31-M5T1U3 3.1 V ± 1.0% S-1335M32-M5T1U3 3.2 V ± 1.0% S-1335M33-M5T1U3 3.3 V ± 1.0% S-1335M34-M5T1U3 3.4 V ± 1.0% S-1335M35-M5T1U3 3.5 V ± 1.0% S-1335M36-M5T1U3 3.6 V ± 1.0% Please contact our sales representatives for products other than the above. 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series  Pin Configurations 1. SOT-23-5 Table 15 Top view 5 4 1 2 3 Pin No. 1 2 3 Symbol VIN VSS ON / OFF 4 SST 5 VOUT Description Input voltage pin GND pin ON / OFF pin Switching pin for soft-start time "H": tSS0 = 0.1 ms typ. "L": tSS1 = 1.0 ms typ. Output voltage pin Figure 9 Remark 2. The soft-start time can be switched to tSS0 = 0.1 ms typ. / tSS1 = 1.0 ms typ. with the SST pin. Refer to "2. Function list of product type" in " Product Name Structure" for details. SC-82AB Table 16 Top view 4 3 1 2 Pin No. 1 2 3 4 Symbol ON / OFF VSS VOUT VIN Description ON / OFF pin GND pin Output voltage pin Input voltage pin Figure 10 Remark 3. The soft-start time is fixed to tSS0 = 0.1 ms typ. Refer to "2. Function list of product type" in " Product Name Structure" for details. HSNT-4 (1010) Table 17 Top view 1 2 4 3 Bottom view 4 3 Pin No. 1 2 3 4 Symbol VOUT VSS ON / OFF VIN Description Output voltage pin GND pin ON / OFF pin Input voltage pin 1 2 *1 Figure 11 *1. Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. Remark The soft-start time is fixed to either tSS0 = 0.1 ms typ. or tSS1 = 1.0 ms typ. Refer to "2. Function list of product type" in " Product Name Structure" for details. 19 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series  Absolute Maximum Ratings Table 18 Item (Ta = +25°C unless otherwise specified) Absolute Maximum Rating Unit Symbol VIN VON / OFF VSST VOUT IOUT Input voltage Output voltage Output current SOT-23-5 Power dissipation PD SC-82AB HSNT-4 (1010) Operation ambient temperature Topr Storage temperature Tstg *1. When mounted on board [Mounted board] (1) Board size: 114.3 mm × 76.2 mm × t1.6 mm (2) Name: JEDEC STANDARD51-7 Caution VSS − 0.3 to VSS + 6.0 VSS − 0.3 to VSS + 6.0 VSS − 0.3 to VSS + 6.0 VSS − 0.3 to VIN + 0.3 200 600*1 400*1 340*1 −40 to +85 −40 to +125 The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. Power dissipation (PD) [mW] 1200 1000 HSNT-4 (1010) 800 SC-82AB Figure 12 SOT-23-5 600 400 200 0 20 V V V V mA mW mW mW °C °C 0 150 100 50 Ambient temperature (Ta) [°C] Power Dissipation of Package (When Mounted on Board) 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series Power Dissipation of HSNT-4 (1010) (Reference) Power dissipation of package differs depending on the mounting conditions. Consider the power dissipation characteristics under the following conditions as reference. [Mounted board] (1) Board size: (2) Board material: (3) Wiring ratio: (4) Test conditions: (5) Land pattern: 40 mm × 40 mm × t0.8 mm Glass epoxy resin (four layers) 50% When mounted on board (wind speed: 0 m/s) Refer to the recommended land pattern (drawing code: PL004-A-L-SD) Power dissipation (PD) [mW] 1200 1000 800 600 400 200 0 Figure 13 0 150 100 50 Ambient temperature (Ta) [°C] Power Dissipation of Package (When Mounted on Board) Table 19 Condition HSNT-4 (1010) (When mounted on board) Power Dissipation (Reference) 870 mW Thermal Resistance Value (θj-a) 115°C/W 21 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series  Electrical Characteristics 1. S-1335 Series A / B / C / D / E / F / G / H type Table 20 Item Output voltage*1 Output current*2 Dropout voltage*3 Line regulation Load regulation Output voltage temperature coefficient*4 Current consumption during operation Current consumption during power-off Input voltage ON / OFF pin input voltage "H" ON / OFF pin input voltage "L" Symbol VOUT(E) IOUT Vdrop ΔVOUT1 ΔVIN• VOUT ΔVOUT2 ΔVOUT ΔTa • VOUT ISS1 ISS2 VIN VSH VSL ON / OFF pin input current "H" ISH ON / OFF pin input current "L" ISL Ripple rejection Short-circuit current RR Ishort tSS0 Soft-start time*6 tSS1 Discharge shunt resistance RLOW during power-off Power-off pull-down resistance 22 RPD Condition VIN = VOUT(S) + 1.0 V, IOUT = 30 mA (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit 1.0 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) ≤ 3.6 V VIN ≥ VOUT(S) + 1.0 V IOUT = 100 mA 1.0 V ≤ VOUT(S) < 1.1 V 1.1 V ≤ VOUT(S) < 1.2 V 1.2 V ≤ VOUT(S) < 1.3 V 1.3 V ≤ VOUT(S) < 1.4 V 1.4 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) < 1.7 V 1.7 V ≤ VOUT(S) < 2.0 V 2.0 V ≤ VOUT(S) < 2.5 V 2.5 V ≤ VOUT(S) < 2.8 V 2.8 V ≤ VOUT(S) ≤ 3.6 V VOUT(S) − 0.015 VOUT(S) × 0.99 150*5 0.130 − − − − − − − − − VOUT(S) VOUT(S) − 0.250 0.225 0.194 0.160 0.124 0.104 0.094 0.084 0.077 0.070 VOUT(S) V + 0.015 VOUT(S) V × 1.01 − mA 0.350 V 0.275 V 0.224 V 0.187 V 0.167 V 0.157 V 0.140 V 0.127 V 0.117 V 0.103 V 1 1 3 1 1 1 1 1 1 1 1 1 1 VOUT(S) + 0.5 V ≤ VIN ≤ 5.5 V, IOUT = 30 mA − 0.05 0.2 %/V 1 VIN = VOUT(S) + 1.0 V, 1 mA ≤ IOUT ≤ 150 mA VIN = VOUT(S) + 1.0 V, IOUT = 30 mA, −40°C ≤ Ta ≤ +85°C VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, no load VIN = VOUT(S) + 1.0 V, ON / OFF pin = OFF, no load − VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ determined by VOUT output level VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ determined by VOUT output level B / D / F / H type (without pull-down resistor) VIN = 5.5 V, VON / OFF = 5.5 V A / C / E / G type (with pull-down resistor) − 15 40 mV 1 − ±100 − ppm/°C 1 − 36 54 μA 2 − 0.1 1.0 μA 2 1.5 − 5.5 V − 1.0 − − V 4 − − 0.3 V 4 −0.1 − 0.1 μA 4 1.0 2.5 5.0 μA 4 −0.1 − 0.1 μA 4 − 70 − dB 5 − 65 − dB 5 − 80 − dB 5 − 50 − mA 3 0.08 0.1 0.13 ms 1 0.8 1.0 1.2 ms 1 − 35 − Ω 3 1.1 2.2 5.5 MΩ 4 VIN = 5.5 V, VON / OFF = 0 V VIN = VOUT(S) + 1.0 V, f = 10 kHz, 1.0 V ≤ VOUT(S) ≤ 2.5 V ΔVrip = 0.5 Vrms, IOUT = 30 mA 2.5 V < VOUT(S) ≤ 3.6 V VIN = VOUT(S) + 1.0 V, f = 1.0 kHz, 1.0 V ≤ VOUT(S) ≤ 3.6 V ΔVrip = 0.5 Vrms, IOUT = 30 mA VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, VOUT = 0 V VIN = VOUT(S) + 1.0 V, A / B / C / D type (0.1 ms typ.) IOUT = 100 mA, CL = 1.0 μF, E / F / G / H type tr = 1.0 μs (1.0 ms typ.) VIN = 5.5 V, A / B / E / F type VOUT = 0.1 V (with discharge shunt function) A / C / E / G type − (with pull-down resistor) 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT (= 30 mA) and inputting VOUT(S) + 1.0 V *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V and IOUT = 100 mA. VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. *4. A change in temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•VOUT [ppm/°C]*3 ÷ 1000 ΔTa *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. The output current can be at least this value. Due to restrictions on the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation of the package when the output current is large. This specification is guaranteed by design. *6. Soft-start time shows the time period from when the input voltage reaches 50% until the output voltage rises to 99%, immediately after power-on or when the ON / OFF pin is set to ON (tr = 1.0 μs). Refer to "8. Soft-start function" in " Operation" for details. 23 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 2. S-1335 Series J / K / L / M type Table 21 Item Output voltage*1 Output current*2 Dropout voltage*3 Line regulation Load regulation Output voltage temperature coefficient*4 Current consumption during operation Current consumption during power-off Input voltage ON / OFF pin input voltage "H" ON / OFF pin input voltage "L" Symbol VOUT(E) IOUT Vdrop ΔVOUT1 ΔVIN• VOUT ΔVOUT2 ΔVOUT ΔTa • VOUT ISS1 ISS2 VIN VSH VSL ON / OFF pin input current "H" ISH ON / OFF pin input current "L" ISL Ripple rejection Short-circuit current Soft-start time*6 RR Ishort tSS0 tSS1 Discharge shunt resistance RLOW during power-off Power-off pull-down RPD resistance SST pin input voltage "H" VSH2 SST pin input voltage "L" VSL2 SST pin input current "H" ISH2 SST pin input current "L" ISL2 SST pin pull-up RPU resistance 24 Condition VIN = VOUT(S) + 1.0 V, IOUT = 30 mA 1.0 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) ≤ 3.6 V VIN ≥ VOUT(S) + 1.0 V IOUT = 100 mA 1.0 V ≤ VOUT(S) < 1.1 V 1.1 V ≤ VOUT(S) < 1.2 V 1.2 V ≤ VOUT(S) < 1.3 V 1.3 V ≤ VOUT(S) < 1.4 V 1.4 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) < 1.7 V 1.7 V ≤ VOUT(S) < 2.0 V 2.0 V ≤ VOUT(S) < 2.5 V 2.5 V ≤ VOUT(S) < 2.8 V 2.8 V ≤ VOUT(S) ≤ 3.6 V (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VOUT(S) VOUT(S) VOUT(S) V 6 − 0.015 + 0.015 VOUT(S) VOUT(S) VOUT(S) V 6 × 0.99 × 1.01 150*5 − − mA 8 0.130 0.250 0.350 V 6 0.225 0.275 V 6 − 0.194 0.224 V 6 − 0.160 0.187 V 6 − 0.124 0.167 V 6 − 0.104 0.157 V 6 − 0.094 0.140 V 6 − 0.084 0.127 V 6 − 0.077 0.117 V 6 − 0.070 0.103 V 6 − VOUT(S) + 0.5 V ≤ VIN ≤ 5.5 V, IOUT = 30 mA − 0.05 0.2 %/V 6 VIN = VOUT(S) + 1.0 V, 1 mA ≤ IOUT ≤ 150 mA VIN = VOUT(S) + 1.0 V, IOUT = 30 mA, −40°C ≤ Ta ≤ +85°C VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, no load VIN = VOUT(S) + 1.0 V, ON / OFF pin = OFF, no load − VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ determined by VOUT output level VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ determined by VOUT output level K / M type (without pull-down resistor) VIN = 5.5 V, VON / OFF = 5.5 V J / L type (with pull-down resistor) − 15 40 mV 6 − ±100 − ppm/°C 6 − 36 54 μA 7 − 0.1 1.0 μA 7 1.5 − 5.5 V − 1.0 − − V 9 − − 0.3 V 9 −0.1 − 0.1 μA 9 1.0 2.5 5.0 μA 9 −0.1 − 0.1 μA 9 − 70 − dB 10 − 65 − dB 10 − 80 − dB 10 − 0.08 0.8 50 0.1 1.0 − 0.13 1.2 mA ms ms 8 6 6 − 35 − Ω 8 1.1 2.2 5.5 MΩ 9 1.0 − − V 9 − − 0.3 V 9 −0.1 1.0 − 2.5 0.1 5.0 μA μA 9 9 1.1 2.2 5.5 MΩ 9 VIN = 5.5 V, VON / OFF = 0 V VIN = VOUT(S) + 1.0 V, f = 10 kHz, 1.0 V ≤ VOUT(S) ≤ 2.5 V ΔVrip = 0.5 Vrms, IOUT = 30 mA 2.5 V < VOUT(S) ≤ 3.6 V VIN = VOUT(S) + 1.0 V, f = 1.0 kHz, 1.0 V ≤ VOUT(S) ≤ 3.6 V ΔVrip = 0.5 Vrms, IOUT = 30 mA VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, VOUT = 0 V VIN = VOUT(S) + 1.0 V, IOUT = 100 mA, VSST = "H" VSST = "L" CL = 1.0 μF, tr = 1.0 μs VIN = 5.5 V, J / K type VOUT = 0.1 V (with discharge shunt function) J / L type − (with pull-down resistor) VIN = VON / OFF = VOUT(S) + 1.0 V, RL = 1.0 kΩ, determined by VOUT output level VIN = VON / OFF = VOUT(S) + 1.0 V, RL = 1.0 kΩ, determined by VOUT output level VIN = 5.5 V, VSST = 5.5 V VIN = 5.5 V, VSST = 0 V − 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT (= 30 mA) and inputting VOUT(S) + 1.0 V *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V and IOUT = 100 mA. VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. *4. A change in temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•VOUT [ppm/°C]*3 ÷ 1000 ΔTa *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. The output current can be at least this value. Due to restrictions on the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation of the package when the output current is large. This specification is guaranteed by design. *6. Soft-start time shows the time period from when the input voltage reaches 50% until the output voltage rises to 99%, immediately after power-on or when the ON / OFF pin is set to ON (tr = 1.0 μs). Refer to "8. Soft-start function" in " Operation" for details. 25 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series  Test Circuits 1. S-1335 Series A / B / C / D / E / F / G / H type + VOUT VIN ON / OFF VSS V A + Set to ON Figure 14 + A Test Circuit 1 VOUT VIN ON / OFF VSS Set to VIN or GND Figure 15 Test Circuit 2 VOUT VIN ON / OFF A V + VSS Set to VIN or GND Figure 16 Test Circuit 3 VOUT VIN + A ON / OFF V + VSS Figure 17 Test Circuit 4 VOUT VIN ON / OFF V VSS Set to ON Figure 18 26 RL Test Circuit 5 + RL 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 2. S-1335 Series J / K / L / M type + VOUT VIN ON / OFF SST V VSS A + Set to ON Figure 19 + A Test Circuit 6 VOUT VIN ON / OFF SST VSS Set to VIN or GND Figure 20 Test Circuit 7 VOUT VIN ON / OFF A SST V + VSS Set to VIN or GND Figure 21 Test Circuit 8 VOUT VIN + A ON / OFF Figure 22 SST A + V + RL Test Circuit 9 VOUT VIN ON / OFF SST VSS V + RL Set to ON Figure 23 Test Circuit 10 27 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series  Standard Circuit Input Output VOUT VIN CIN*1 *3 ON / OFF SST VSS Single GND *1. *2. *3. CL *2 GND CIN is a capacitor for stabilizing the input. A Ceramic capacitor of 1.0 μF or more can be used as CL. S-1335 Series J / K / L / M type only. Figure 24 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constants.  Condition of Application Input capacitor (CIN): Output capacitor (CL): Caution 1. 2. 1.0 μF or more 1.0 μF or more Set input capacitor (CIN) and output capacitor (CL) as CIN = CL. Generally a series regulator may cause oscillation, depending on the selection of external parts. Confirm that no oscillation occurs in the application for which the above capacitors are used.  Selection of Input and Output Capacitors (CIN, CL) The S-1335 Series requires an output capacitor between the VOUT pin and the VSS pin for phase compensation. Operation is stabilized by a ceramic capacitor with an output capacitance of 1.0 μF or more over the entire temperature range. When using an OS capacitor, a tantalum capacitor, or an aluminum electrolytic capacitor, the capacitance must be 1.0 μF or more. The values of output overshoot and undershoot, which are transient response characteristics, vary depending on the value of output capacitor. The required value of capacitance for the input capacitor differs depending on the application. Set the value for input capacitor (CIN) and output capacitor (CL) as follows. Define the values by sufficient evaluation including the temperature characteristics under the usage condition. • CIN ≥ 1.0 μF • CL ≥ 1.0 μF • CIN = CL 28 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series  Explanation of Terms 1. Low dropout voltage regulator This voltage regulator has the low dropout voltage due to its built-in low on-resistance transistor. 2. Output voltage (VOUT) The accuracy of the output voltage is ensured at ±1.0% or ±15 mV*1 under the specified conditions of fixed input voltage*2, fixed output current, and fixed temperature. *1. *2. When VOUT < 1.5 V: ±15 mV, when VOUT ≥1.5 V: ±1.0% Differs depending on the product. Caution 3. If the above conditions change, the output voltage value may vary and exceed the accuracy range of the output voltage. Refer to " Electrical Characteristics" and " Characteristics (Typical Data)" for details. ΔVOUT1  Line regulation  ΔVIN•VOUT  Indicates the dependency of the output voltage on the input voltage. That is, the values show how much the output voltage changes due to a change in the input voltage with the output current remaining unchanged. 4. Load regulation (ΔVOUT2) Indicates the dependency of the output voltage on the output current. That is, the values show how much the output voltage changes due to a change in the output current with the input voltage remaining unchanged. 5. Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when; decreasing input voltage (VIN) gradually until the output voltage has dropped out to the value of 98% of output voltage (VOUT3), which is at VIN = VOUT(S) + 1.0 V. Vdrop = VIN1 − (VOUT3 × 0.98) 29 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 6. ΔVOUT  Output voltage temperature coefficient  ΔTa•VOUT  The shaded area in Figure 25 is the range where VOUT varies in the operation temperature range when the output voltage temperature coefficient is ±100 ppm/°C. Example of S-1335A30 typ. product VOUT [V] +0.30 mV/°C *1 VOUT(E) −0.30 mV/°C −40 *1. +25 +85 Ta [°C] VOUT(E) is the value of the output voltage measured at Ta = +25°C. Figure 25 A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•VOUT [ppm/°C]*3 ÷ 1000 ΔTa *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient 30 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series  Operation 1. Basic operation Figure 26 shows the block diagram of the S-1335 Series. The error amplifier compares the reference voltage (Vref) with feedback voltage (Vfb), which is the output voltage resistance-divided by feedback resistors (Rs and Rf). It supplies the gate voltage necessary to maintain the constant output voltage which is not influenced by the input voltage and temperature change, to the output transistor. VIN *1 Current supply Error amplifier Vref VOUT − Rf + Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 26 2. Output transistor In the S-1335 Series, a low on-resistance P-channel MOS FET is used as the output transistor. Be sure that VOUT does not exceed VIN + 0.3 V to prevent the voltage regulator from being damaged due to inverse current flowing from the VOUT pin through a parasitic diode to the VIN pin, when the potential of VOUT became higher than VIN. 31 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 3. ON / OFF pin This pin starts and stops the regulator. When the ON / OFF pin is set to OFF level, the entire internal circuit stops operating, and the built-in P-channel MOS FET output transistor between the VIN pin and the VOUT pin is turned off, reducing current consumption significantly. Note that the current consumption increases when a voltage of 0.3 V to 1.0 V is applied to the ON / OFF pin. The ON / OFF pin is configured as shown in Figure 27 and Figure 28. 3. 1 S-1335 Series A / C / E / G / J / L type The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. 3. 2 S-1335 Series B / D / F / H / K / M type The ON / OFF pin is not internally pulled up or pulled down to the VSS pin, so do not use it in the floating status. When not using the ON / OFF pin, connect the pin to the VIN pin. Table 22 Product Type ON / OFF Pin Internal Circuit VOUT Pin Voltage Current Consumption A/B/C/D/E/F/ Operate Set value "H": ON ISS1*1 G/H/J/K/L/M A/B/C/D/E/F/ Stop VSS level "L": OFF ISS2 G/H/J/K/L/M *1. Note that the IC's current consumption increases as much as current flows into the pull-down resistor of 2.2 MΩ typ. when the ON / OFF pin is connected to the VIN pin and the S-1335 Series A / C / E / G / J / L type is operating (refer to Figure 27). VIN VIN ON / OFF ON / OFF VSS Figure 27 32 S-1335 Series A / C / E / G / J / L type VSS Figure 28 S-1335 Series B / D / F / H / K / M type 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 4. Discharge shunt function (S-1335 Series A / B / E / F / J / K type) The S-1335 Series A / B / E / F / J / K type has a built-in discharge shunt circuit to discharge the output capacitance. The output capacitance is discharged as follows so that the VOUT pin reaches the VSS level. (1) The ON / OFF pin is set to OFF level. (2) The output transistor is turned off. (3) The discharge shunt circuit is turned on. (4) The output capacitor discharges. Since the S-1335 Series C / D / G / H / L / M type does not have a discharge shunt circuit, the VOUT pin is set to the VSS level through several hundred kΩ internal divided resistors between the VOUT pin and the VSS pin. The S-1335 Series A / B / E / F / J / K type allows the VOUT pin to reach the VSS level rapidly due to the discharge shunt circuit. S-1335 Series A / B / E / F / J / K type Output transistor: OFF *1 VOUT VIN Discharge shunt circuit : ON *1 ON / OFF ON / OFF circuit Output capacitor (CL) ON / OFF pin: OFF Current flow GND VSS *1. Parasitic diode Figure 29 5. Pull-down resistor (S-1335 Series A / C / E / G / J / L type) The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. Note that the IC’s current consumption increases as much as current flows into the pull-down resistor of 2.2 MΩ typ. when the ON / OFF pin is connected to the VIN pin. 33 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 6. Overcurrent protection circuit The S-1335 Series includes an overcurrent protection circuit having the characteristics shown in "1. Output voltage vs. Output current (When load current increases) (Ta = +25°C)" in " Characteristics (Typical Data)", in order to protect the output transistor against an excessive output current and short circuiting between the VOUT pin and the VSS pin. The current when the output pin is short-circuited (Ishort) is internally set at approx. 50 mA typ., and the normal value is restored for the output voltage, if releasing a short circuit once. Caution This overcurrent protection circuit does not work as for thermal protection. If this IC long keeps short circuiting inside, pay attention to the conditions of input voltage and load current so that, under the usage conditions including short circuit, the loss of the IC will not exceed power dissipation of the package. 7. SST pin (S-1335 Series J / K / L / M type only) In the S-1335 Series J / K / L / M type, the soft-start time can be switched with the SST pin. The soft-start time is set to 0.1 ms typ. if "H" is input to the SST pin, and set to 1.0 ms typ. if "L" is input to the SST pin. Refer to "8. 2 Switching of soft-start time (S-1335 Series J / K / L / M type only)" for details. The SST pin is configured as shown in Figure 30. Note that the current consumption increases when a voltage of 0.3 V to 1.0 V is applied to the SST pin. Since the SST pin is pulled up by the VIN pin internally, the soft-start time is fixed to 0.1 ms typ. on floating status. Note that the IC’s current consumption increases as much as current flows into the pull-up resistor of 2.2 MΩ typ. when the SST pin is connected to the VSS pin and the S-1335 Series J / K / L / M type is operating (refer to Figure 30). Table 23 SST Pin Input "H" "L" Soft-start Time (typ.) 0.1 ms 1.0 ms VIN SST VSS Figure 30 34 S-1335 Series J / K / L / M type 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 8. Soft-start function 8. 1 Basic operation The S-1335 Series has a built-in soft-start circuit to suppress the inrush current and overshoot of the output voltage generated at power-on or at the time when the ON / OFF pin is set to ON. Immediately after power-on or after the ON / OFF pin is set to ON, the output voltage slowly rises. Immediately after power-on or when the ON / OFF pin is set to ON (tr = 1.0 μs), the soft-start time (tSS) is the time period from when the input voltage reaches 50% until the output voltage rises to 99%. tr = 1.0 μs VOUT(S) + 1.0 V VIN × 0.50 Input voltage (VIN) VOUT × 0.99 Output voltage (VOUT) Soft-start time (tSS) Figure 31 Basic Operation The inrush current can be suppressed greatly by the soft-start function. Figure 32 shows the waveform example of the inrush current. Input voltage (VIN) Without soft-start function With soft-start function Inrush current (IRUSH) Figure 32 Waveform Example of Inrush Current 35 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 8. 2 Switching of soft-start time (S-1335 Series J / K / L / M type only) In the S-1335 Series J / K / L / M type, the soft-start time can be switched to tSS0 = 0.1 ms typ. / tSS1 = 1.0 ms typ. with the SST pin. However, the soft-start time (tSS) is as follows when the SST pin is switched within the soft-start time tSS0 = 0.1 ms typ. / tSS1 = 1.0 ms typ. 8. 2. 1 When SST pin voltage (VSST) is switched from "H" to "L" The soft-start time (tSS) is calculated by using the following equation. tSS = tSS0' + tSS1 × {1 − VOUT(E)' / (VOUT(E) × 0.99)} tSS0': The time period that VSST is switched from "H" to "L" after power-on tSS1: The soft-start time when VSST = "L" VOUT(E)': The output voltage when VSST is switched from "H" to "L" VOUT(E): The output voltage after the end of the soft-start time tr = 1.0 μs Input voltage (VIN) VOUT(S) + 1.0 V VIN × 0.50 SST pin voltage (VSST) VSL2 VOUT(E) × 0.99 Output voltage (VOUT) VOUT(E) VOUT(E)' tSS0' Soft-start time (tSS) Figure 33 VSST = "H" → "L" tr = 1.0 μs Input voltage (VIN) VOUT(S) + 1.0 V VIN × 0.50 SST pin voltage (VSST) VOUT(E) Output voltage (VOUT) Soft-start time (tSS1) Figure 34 VSST = "L" 36 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 8. 2. 2 When SST pin voltage (VSST) is switched from "L" to "H" The soft-start time (tSS) is calculated by using the following equation. tSS = tSS1' + tSS0 × {1 − VOUT(E)' / (VOUT(E) × 0.99)} tSS1': The time period that VSST is switched from "L" to "H" after power-on tSS0: The soft-start time when VSST = "H" VOUT(E)': The output voltage when VSST is switched from "L" to "H" VOUT(E): The output voltage after the end of the soft-start time tr = 1.0 μs VOUT(S) + 1.0 V Input voltage (VIN) VIN × 0.50 SST pin voltage (VSST) VSH2 VOUT(E) × 0.99 VOUT(E)' Output voltage (VOUT) VOUT(E) tSS1' Soft-start time (tSS) Figure 35 VSST = "L" → "H" tr = 1.0 μs Input voltage (VIN) VOUT(S) + 1.0 V VIN × 0.50 SST pin voltage (VSST) VOUT(E) Output voltage (VOUT) Soft-start time (tSS0) Figure 36 VSST = "H" 37 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series  Precautions • Wiring patterns for the VIN pin, the VOUT pin and GND should be designed so that the impedance is low. When mounting an output capacitor between the VOUT pin and the VSS pin (CL) and a capacitor for stabilizing the input between the VIN pin and the VSS pin (CIN), the distance from the capacitors to these pins should be as short as possible. • Note that generally the output voltage may increase when a series regulator is used at low load current (1.0 mA or less). • Note that generally the output voltage may increase due to the leakage current from an output driver when a series regulator is used at high temperature. • Note that the output voltage may increase due to the leakage current from an output driver even if the ON / OFF pin is at OFF level when a series regulator is used at high temperature. • Generally a series regulator may cause oscillation, depending on the selection of external parts. The following conditions are recommended for the S-1335 Series. However, be sure to perform sufficient evaluation under the actual usage conditions for selection, including evaluation of temperature characteristics. Refer to "6. Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C)" in " Reference Data" for the equivalent series resistance (RESR) of the output capacitor. Input capacitor (CIN): Output capacitor (CL): 1.0 μF or more 1.0 μF or more • The voltage regulator may oscillate when the impedance of the power supply is high and the input capacitance is small or an input capacitor is not connected. • If the output capacitance is small, power supply's fluctuation and the characteristics of load fluctuation become worse. Sufficiently evaluate the output voltage's fluctuation with the actual device. • Overshoot may occur in the output voltage momentarily if the voltage is rapidly raised at power-on or when the power supply fluctuates. Sufficiently evaluate the output voltage at power-on with the actual device. • The application conditions for the input voltage, the output voltage, and the load current should not exceed the package power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • In determining the output current, attention should be paid to the output current value specified in Table 20 and Table 21 in " Electrical Characteristics" and footnote *5 of the table. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 38 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series  Characteristics (Typical Data) Output voltage vs. Output current (When load current increases) (Ta = +25°C) VOUT [V] 1. 1 VOUT [V] 1. 3 VOUT = 3.6 V 4.0 3.6 3.2 VIN = 4.1 V 2.8 VIN = 4.6 V 2.4 VIN = 5.5 V 2.0 1.6 1.2 0.8 0.4 0 0 50 100 150 200 250 300 350 400 IOUT [mA] 1. 2 Remark VOUT = 2.5 V 2.8 2.4 VIN = 3.0 V 2.0 VIN = 3.5 V 1.6 VIN = 4.5 V 1.2 0.8 VIN = 5.5 V 0.4 0 0 50 100 150 200 250 300 350 400 IOUT [mA] In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *5 in Table 20 and Table 21 in " Electrical Characteristics" 2. The package power dissipation Output voltage vs. Input voltage (Ta = +25°C) VOUT [V] 2. 1 VOUT [V] 2. 3 VOUT = 1.0 V 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 0 1 VOUT = 3.6 V 4.5 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 1 0 2. 2 VOUT = 2.5 V 3.0 2.5 VOUT [V] 2. VOUT = 1.0 V 1.4 VIN = 5.5 V 1.2 1.0 0.8 VIN = 2.0 V VIN = 3.0 V 0.6 0.4 0.2 VIN = 1.5 V 0 0 50 100 150 200 250 300 350 400 IOUT [mA] VOUT [V] 1. IOUT = 100 mA IOUT = 30 mA IOUT = 1 mA IOUT = 100 μA 2.0 IOUT = 100 mA IOUT = 30 mA IOUT = 1 mA IOUT = 100 μA 1.5 1.0 0.5 0 2 3 VIN [V] 4 5 6 0 1 2 3 VIN [V] 4 5 6 IOUT = 100 mA IOUT = 30 mA IOUT = 1 mA IOUT = 100 μA 2 3 VIN [V] 4 5 6 39 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series Dropout voltage vs. Output current Vdrop [V] 3. 1 VOUT = 1.0 V 0.40 0.35 Ta = +85°C 0.30 Ta = +25°C 0.25 Ta = −40°C 0.20 0.15 0.10 0.05 0 0 50 100 25 75 IOUT [mA] 125 150 125 150 Vdrop [V] 3. 3 VOUT = 3.6 V 0.40 0.35 0.30 0.25 Ta = +85°C 0.20 Ta = +25°C 0.15 Ta = −40°C 0.10 0.05 0 0 50 100 25 75 IOUT [mA] Vdrop [V] 4. Dropout voltage vs. Set output voltage 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 IOUT = 150 mA IOUT = 100 mA IOUT = 30 mA IOUT = 10 mA IOUT = 1 mA 1.0 40 1.6 2.2 2.8 VOUT(S) [V] 3. 2 VOUT = 2.5 V 0.40 0.35 0.30 0.25 Ta = +85°C 0.20 Ta = +25°C 0.15 Ta = −40°C 0.10 0.05 0 0 50 100 25 75 IOUT [mA] Vdrop [V] 3. 3.4 4.0 125 150 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 5. Output voltage vs. Ambient temperature 5. 1 VOUT = 1.0 V 1.10 5. 2 2.6 VOUT [V] VOUT [V] 1.05 1.00 5. 3 2.5 2.4 0.95 0.90 VOUT = 2.5 V 2.7 −40 −25 2.3 0 25 Ta [°C] 50 75 85 0 25 Ta [°C] 50 75 85 −40 −25 0 25 Ta [°C] 75 85 50 VOUT = 3.6 V 3.8 3.7 VOUT [V] 3.6 3.5 3.4 3.3 3.2 Current consumption vs. Input voltage ISS1 [μA] 6. 1 ISS1 [μA] 6. 3 VOUT = 1.0 V 40 35 30 25 20 15 10 5 0 0 1 VOUT = 3.6 V 40 35 30 25 20 15 10 5 0 0 1 6. 2 ISS1 [μA] 6. −40 −25 Ta = −40°C Ta = +25°C Ta = +85°C 2 3 VIN [V] 4 5 6 VOUT = 2.5 V 40 35 30 25 20 15 10 5 0 0 1 Ta = −40°C Ta = +25°C Ta = +85°C 2 3 VIN [V] 4 5 6 Ta = −40°C Ta = +25°C Ta = +85°C 2 3 VIN [V] 4 5 6 41 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 7. Ripple rejection (Ta = +25°C) 7. 1 VOUT = 1.0 V 7. 2 VOUT = 2.5 V 100 80 60 IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA IOUT = 150 mA 40 20 0 10 7. 3 100 1k 10k 100k Frequency [Hz] 1M VOUT = 3.6 V Ripple Rejection [dB] VIN = 4.6 V, CL = 1.0 μF 120 100 80 60 IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA IOUT = 150 mA 40 20 0 10 42 100 VIN = 3.5 V, CL = 1.0 μF Ripple Rejection [dB] Ripple Rejection [dB] VIN = 2.0 V, CL = 1.0 μF 120 1k 10k 100k Frequency [Hz] 1M 120 100 80 60 IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA IOUT = 150 mA 40 20 0 10 100 1k 10k 100k Frequency [Hz] 1M 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series  Reference Data Transient response characteristics when input (Ta = +25°C) 1. 1 VOUT = 1.0 V 1. 2 VOUT = 2.5 V IOUT = 30 mA, CIN = CL = 1.0 μF, VIN = 3.5 V ↔ 4.5 V, tr = tf = 5.0 μs 3.5 2.70 6.0 1.15 3.0 2.65 5.0 1.10 2.5 2.60 1.05 2.0 1.00 0.95 VIN 0.90 −100 −50 1. 3 1.5 VOUT 0 VOUT [V] 1.20 VIN [V] VOUT [V] IOUT = 30 mA, CIN = CL = 1.0 μF, VIN = 2.0 V ↔ 3.0 V, tr = tf = 5.0 μs 4.0 2.55 VIN 3.0 2.50 VOUT 2.0 1.0 2.45 0.5 2.40 −100 −50 50 100 150 200 250 t [μs] 1.0 0 0 50 100 150 200 250 t [μs] VOUT = 3.6 V IOUT = 30 mA, CIN = CL = 1.0 μF, VIN = 4.6 V ↔ 5.5 V, tr = tf = 5.0 μs 6.0 3.80 VOUT [V] 3.70 VIN 4.0 3.0 3.65 3.60 3.55 2.0 VOUT 3.50 −100 −50 VIN [V] 5.0 3.75 1.0 0 0 50 100 150 200 250 t [μs] 43 VIN [V] 1. 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series Transient response characteristics of load (Ta = +25°C) VOUT = 1.0 V 1.10 IOUT 100 1.30 100 0 1.20 −200 1.00 VOUT 0.90 −100 −50 2. 2 200 −100 1.05 0.95 1.40 0 50 100 150 200 250 t [μs] VOUT [V] VOUT [V] 1.15 200 IOUT [mA] 1.20 VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 1 mA ↔ 150 mA 0.90 0.80 −100 −50 50 100 150 200 250 t [μs] −400 2.90 200 100 2.80 100 0 2.70 −200 VOUT 0 50 100 150 200 250 t [μs] 2.60 2.50 0 IOUT −100 −200 VOUT −300 2.40 −400 2.30 −100 −50 −300 0 50 100 150 200 250 t [μs] −400 VOUT = 3.6 V VIN = 4.6 V, CIN = CL = 1.0 μF, IOUT = 50 mA ↔ 100 mA VIN = 4.6 V, CIN = CL = 1.0 μF, IOUT = 1 mA ↔ 150 mA 200 4.00 200 3.75 100 3.90 100 0 3.80 3.70 IOUT 3.65 −100 3.60 −200 VOUT 3.55 3.50 −100 −50 0 50 100 150 200 250 t [μs] VOUT [V] 3.80 IOUT [mA] VOUT [V] 0 200 −100 2.40 −100 −50 44 −300 VIN = 3.5 V, CIN = CL = 1.0 μF, IOUT = 1 mA ↔ 150 mA VOUT [V] IOUT 2.55 2. 3 −200 VOUT −400 IOUT [mA] VOUT [V] 2.65 2.45 −100 VOUT = 2.5 V 2.70 2.50 1.00 0 IOUT −300 VIN = 3.5 V, CIN = CL = 1.0 μF, IOUT = 50 mA ↔ 100 mA 2.60 1.10 IOUT [mA] VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 50 mA ↔ 100 mA IOUT [mA] 2. 1 3.70 3.60 0 IOUT −100 −200 VOUT −300 3.50 −400 3.40 −100 −50 −300 0 50 100 150 200 250 t [μs] −400 IOUT [mA] 2. 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series Transient response characteristics of ON / OFF pin (Ta = +25°C) 3. 1 VOUT = 1.0 V 3. 1. 1 tSS = 0.1 ms 3. 1. 2 3 4 4 2 2 0 VOUT 1 −2 0 0 40 80 120 t [μs] 160 200 3 −4 0 0 −2 VOUT [V] 1 VON / OFF [V] VOUT [V] VIN = 3.5 V, CIN = CL = 1.0 μF, IOUT = 100 mA, VON / OFF = 0 V → 3.5 V, tr = 1.0 μs 2 0 −4 2 0 1 −2 0 3. 3. 2 VIN = 4.6 V, CIN = CL = 1.0 μF, IOUT = 100 mA, VON / OFF = 0 V → 4.6 V, tr = 1.0 μs 6 5 4 4 2 2 0 1 −2 0 40 80 120 t [μs] 160 200 −4 VOUT [V] 3 400 800 1200 t [μs] 1600 2000 −4 tSS = 1.0 ms VIN = 4.6 V, CIN = CL = 1.0 μF, IOUT = 100 mA, VON / OFF = 0 V → 4.6 V, tr = 1.0 μs VON / OFF [V] VOUT [V] VOUT 0 6 0 3. 3 VOUT = 3.6 V 3. 3. 1 tSS = 0.1 ms 4 tSS = 1.0 ms VOUT 2 VON / OFF −4 3 2 5 2000 4 VOUT 200 1600 VON / OFF 3 160 800 1200 t [μs] 4 4 120 t [μs] 400 5 VON / OFF 0 −2 6 4 80 0 VOUT 3. 2. 2 5 2 2 VIN = 3.5 V, CIN = CL = 1.0 μF, IOUT = 100 mA, VON / OFF = 0 V → 3.5 V, tr = 1.0 μs 40 4 VON / OFF 1 3. 2 VOUT = 2.5 V 3. 2. 1 tSS = 0.1 ms 0 6 VON / OFF [V] VON / OFF 5 VOUT [V] VOUT [V] 4 6 VON / OFF [V] 5 VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 100 mA, VON / OFF = 0 V → 2.0 V, tr = 1.0 μs VON / OFF [V] VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 100 mA, VON / OFF = 0 V → 2.0 V, tr = 1.0 μs tSS = 1.0 ms 6 VON / OFF 4 VOUT 3 2 2 0 1 −2 0 0 400 800 1200 t [μs] 1600 2000 VON / OFF [V] 3. −4 45 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series Inrush current characteristics (Ta = +25°C) 4. 1 VOUT = 1.0 V 4. 1. 1 tSS = 0.1 ms 4. 1. 2 VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 0.1 mA, VON / OFF = 0 V → 2.0 V, tr = 1.0 μs 6 300 VOUT 0 −2 200 100 IOUT 0 50 100 t [μs] 200 4. 2 VOUT = 2.5 V 4. 2. 1 tSS = 0.1 ms 400 VON / OFF 2 −2 100 0 VIN = 3.5 V, CIN = CL = 1.0 μF, IOUT = 0.1 mA, VON / OFF = 0 V → 3.5 V, tr = 1.0 μs 400 300 VOUT 0 200 −2 −4 100 IOUT VON / OFF, VOUT [V] 2 0 0 50 100 t [μs] 150 500 2 0 200 −2 −2 100 IOUT 0 0 50 100 t [μs] 150 200 VON / OFF, VOUT [V] 200 IOUT [mA] VON / OFF, VOUT [V] 0 −4 46 300 100 IOUT 0 500 1000 t [μs] 0 1500 2000 tSS = 1.0 ms 6 400 2 300 VIN = 4.6 V, CIN = CL = 1.0 μF, IOUT = 0.1 mA, VON / OFF = 0 V → 4.6 V, tr = 1.0 μs 500 VOUT 400 VOUT VIN = 4.6 V, CIN = CL = 1.0 μF, IOUT = 0.1 mA, VON / OFF = 0 V → 4.6 V, tr = 1.0 μs 4 2000 VON / OFF 4. 3. 2 VON / OFF 0 1500 tSS = 1.0 ms 4 −4 200 4. 3 VOUT = 3.6 V 4. 3. 1 tSS = 0.1 ms 6 1000 t [μs] 6 IOUT [mA] VON / OFF, VOUT [V] 4 500 VIN = 3.5 V, CIN = CL = 1.0 μF, IOUT = 0.1 mA, VON / OFF = 0 V → 3.5 V, tr = 1.0 μs 500 VON / OFF 200 IOUT 4. 2. 2 6 300 VOUT 0 −4 0 150 4 IOUT [mA] 2 500 IOUT [mA] 400 VON / OFF VON / OFF, VOUT [V] 500 4 −4 VIN = 2.0 V, CIN = CL = 1.0 μF, IOUT = 0.1 mA, VON / OFF = 0 V → 2.0 V, tr = 1.0 μs IOUT [mA] VON / OFF, VOUT [V] 6 tSS = 1.0 ms 500 4 400 VON / OFF 2 300 VOUT 0 −2 −4 200 100 IOUT 0 500 0 1000 t [μs] 1500 2000 IOUT [mA] 4. 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 5. Output capacitance vs. Characteristics of discharge time (Ta = +25°C) tDSC [ms] VIN = VOUT + 1.0 V, IOUT = no load, VON / OFF = VOUT + 1.0 V → VSS, tf = 1.0 μs 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 1.0 μs VON / OFF VOUT(S) = 1.0 V VOUT(S) = 2.5 V VOUT(S) = 3.6 V VSS tDSC VOUT 0 2 4 6 CL [μF] 8 10 12 VOUT × 10% VIN = VOUT + 1.0 V VON / OFF = VOUT + 1.0 V → VSS Figure 37 Figure 38 Test Condition of Discharge Time Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C) CIN = CL = 1.0 μF VIN 100 VOUT CIN RESR [Ω] 6. S-1335 Series A / B / E / F / J / K Type (With Discharge Shunt Function) Stable ON / OFF 0 0.1 S-1335 Series VSS CL SST *1 *2 RESR 150 IOUT [mA] Figure 39 *1. *2. CL: TDK Corporation C1608X7R1C105K (1.0 μF) S-1335 Series J / K / L / M type only. Figure 40 47 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series  Marking Specifications 1. SOT-23-5 Top view 5 (1) to (3): (4): 4 Product code (Refer to Product name vs. Product code) Lot number (1) (2) (3) (4) 1 2 3 Product name vs. Product code 1. 1 S-1335 Series J type Product Name S-1335J10-M5T1U3 S-1335J11-M5T1U3 S-1335J12-M5T1U3 S-1335J13-M5T1U3 S-1335J14-M5T1U3 S-1335J15-M5T1U3 S-1335J16-M5T1U3 S-1335J17-M5T1U3 S-1335J18-M5T1U3 S-1335J19-M5T1U3 S-1335J20-M5T1U3 S-1335J21-M5T1U3 S-1335J22-M5T1U3 S-1335J23-M5T1U3 S-1335J24-M5T1U3 S-1335J25-M5T1U3 S-1335J26-M5T1U3 S-1335J27-M5T1U3 S-1335J28-M5T1U3 S-1335J2J-M5T1U3 S-1335J29-M5T1U3 S-1335J30-M5T1U3 S-1335J31-M5T1U3 S-1335J32-M5T1U3 S-1335J33-M5T1U3 S-1335J34-M5T1U3 S-1335J35-M5T1U3 S-1335J36-M5T1U3 48 1. 2 (1) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Product Code (2) (3) V A V B V C V D V E V F V G V H V J V K V L V N V O V P V Q V R V S V T V U V 7 V V V X V Y V Z V 1 V 2 V 3 V 4 S-1335 Series K type Product Name S-1335K10-M5T1U3 S-1335K11-M5T1U3 S-1335K12-M5T1U3 S-1335K13-M5T1U3 S-1335K14-M5T1U3 S-1335K15-M5T1U3 S-1335K16-M5T1U3 S-1335K17-M5T1U3 S-1335K18-M5T1U3 S-1335K19-M5T1U3 S-1335K20-M5T1U3 S-1335K21-M5T1U3 S-1335K22-M5T1U3 S-1335K23-M5T1U3 S-1335K24-M5T1U3 S-1335K25-M5T1U3 S-1335K26-M5T1U3 S-1335K27-M5T1U3 S-1335K28-M5T1U3 S-1335K2J-M5T1U3 S-1335K29-M5T1U3 S-1335K30-M5T1U3 S-1335K31-M5T1U3 S-1335K32-M5T1U3 S-1335K33-M5T1U3 S-1335K34-M5T1U3 S-1335K35-M5T1U3 S-1335K36-M5T1U3 (1) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Product Code (2) (3) X A X B X C X D X E X F X G X H X J X K X L X N X O X P X Q X R X S X T X U X 7 X V X X X Y X Z X 1 X 2 X 3 X 4 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 1. 3 S-1335 Series L type Product Name S-1335L10-M5T1U3 S-1335L11-M5T1U3 S-1335L12-M5T1U3 S-1335L13-M5T1U3 S-1335L14-M5T1U3 S-1335L15-M5T1U3 S-1335L16-M5T1U3 S-1335L17-M5T1U3 S-1335L18-M5T1U3 S-1335L19-M5T1U3 S-1335L20-M5T1U3 S-1335L21-M5T1U3 S-1335L22-M5T1U3 S-1335L23-M5T1U3 S-1335L24-M5T1U3 S-1335L25-M5T1U3 S-1335L26-M5T1U3 S-1335L27-M5T1U3 S-1335L28-M5T1U3 S-1335L2J-M5T1U3 S-1335L29-M5T1U3 S-1335L30-M5T1U3 S-1335L31-M5T1U3 S-1335L32-M5T1U3 S-1335L33-M5T1U3 S-1335L34-M5T1U3 S-1335L35-M5T1U3 S-1335L36-M5T1U3 1. 4 Product Code (1) (2) (3) 2 Y A 2 Y B 2 Y C 2 Y D 2 Y E 2 Y F 2 Y G 2 Y H 2 Y J 2 Y K 2 Y L 2 Y N 2 Y O 2 Y P 2 Y Q 2 Y R 2 Y S 2 Y T 2 Y U 2 Y 7 2 Y V 2 Y X 2 Y Y 2 Y Z 2 Y 1 2 Y 2 2 Y 3 2 Y 4 S-1335 Series M type Product Name S-1335M10-M5T1U3 S-1335M11-M5T1U3 S-1335M12-M5T1U3 S-1335M13-M5T1U3 S-1335M14-M5T1U3 S-1335M15-M5T1U3 S-1335M16-M5T1U3 S-1335M17-M5T1U3 S-1335M18-M5T1U3 S-1335M19-M5T1U3 S-1335M20-M5T1U3 S-1335M21-M5T1U3 S-1335M22-M5T1U3 S-1335M23-M5T1U3 S-1335M24-M5T1U3 S-1335M25-M5T1U3 S-1335M26-M5T1U3 S-1335M27-M5T1U3 S-1335M28-M5T1U3 S-1335M2J-M5T1U3 S-1335M29-M5T1U3 S-1335M30-M5T1U3 S-1335M31-M5T1U3 S-1335M32-M5T1U3 S-1335M33-M5T1U3 S-1335M34-M5T1U3 S-1335M35-M5T1U3 S-1335M36-M5T1U3 Product Code (1) (2) (3) 2 Z A 2 Z B 2 Z C 2 Z D 2 Z E 2 Z F 2 Z G 2 Z H 2 Z J 2 Z K 2 Z L 2 Z N 2 Z O 2 Z P 2 Z Q 2 Z R 2 Z S 2 Z T 2 Z U 2 Z 7 2 Z V 2 Z X 2 Z Y 2 Z Z 2 Z 1 2 Z 2 2 Z 3 2 Z 4 49 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 2. SC-82AB Top view 4 (1) to (3): 3 Product code (Refer to Product name vs. Product code) (1) (2) (3) 1 2 Product name vs. Product code 2. 1 S-1335 Series A type Product Name S-1335A10-N4T1U3 S-1335A11-N4T1U3 S-1335A12-N4T1U3 S-1335A13-N4T1U3 S-1335A14-N4T1U3 S-1335A15-N4T1U3 S-1335A16-N4T1U3 S-1335A17-N4T1U3 S-1335A18-N4T1U3 S-1335A19-N4T1U3 S-1335A20-N4T1U3 S-1335A21-N4T1U3 S-1335A22-N4T1U3 S-1335A23-N4T1U3 S-1335A24-N4T1U3 S-1335A25-N4T1U3 S-1335A26-N4T1U3 S-1335A27-N4T1U3 S-1335A28-N4T1U3 S-1335A2J-N4T1U3 S-1335A29-N4T1U3 S-1335A30-N4T1U3 S-1335A31-N4T1U3 S-1335A32-N4T1U3 S-1335A33-N4T1U3 S-1335A34-N4T1U3 S-1335A35-N4T1U3 S-1335A36-N4T1U3 50 2. 2 (1) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Product Code (2) (3) 5 A 5 B 5 C 5 D 5 E 5 F 5 G 5 H 5 J 5 K 5 L 5 N 5 O 5 P 5 Q 5 R 5 S 5 T 5 U 5 7 5 V 5 X 5 Y 5 Z 5 1 5 2 5 3 5 4 S-1335 Series B type Product Name S-1335B10-N4T1U3 S-1335B11-N4T1U3 S-1335B12-N4T1U3 S-1335B13-N4T1U3 S-1335B14-N4T1U3 S-1335B15-N4T1U3 S-1335B16-N4T1U3 S-1335B17-N4T1U3 S-1335B18-N4T1U3 S-1335B19-N4T1U3 S-1335B20-N4T1U3 S-1335B21-N4T1U3 S-1335B22-N4T1U3 S-1335B23-N4T1U3 S-1335B24-N4T1U3 S-1335B25-N4T1U3 S-1335B26-N4T1U3 S-1335B27-N4T1U3 S-1335B28-N4T1U3 S-1335B2J-N4T1U3 S-1335B29-N4T1U3 S-1335B30-N4T1U3 S-1335B31-N4T1U3 S-1335B32-N4T1U3 S-1335B33-N4T1U3 S-1335B34-N4T1U3 S-1335B35-N4T1U3 S-1335B36-N4T1U3 (1) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Product Code (2) (3) 6 A 6 B 6 C 6 D 6 E 6 F 6 G 6 H 6 J 6 K 6 L 6 N 6 O 6 P 6 Q 6 R 6 S 6 T 6 U 6 7 6 V 6 X 6 Y 6 Z 6 1 6 2 6 3 6 4 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 2. 3 S-1335 Series C type Product Name S-1335C10-N4T1U3 S-1335C11-N4T1U3 S-1335C12-N4T1U3 S-1335C13-N4T1U3 S-1335C14-N4T1U3 S-1335C15-N4T1U3 S-1335C16-N4T1U3 S-1335C17-N4T1U3 S-1335C18-N4T1U3 S-1335C19-N4T1U3 S-1335C20-N4T1U3 S-1335C21-N4T1U3 S-1335C22-N4T1U3 S-1335C23-N4T1U3 S-1335C24-N4T1U3 S-1335C25-N4T1U3 S-1335C26-N4T1U3 S-1335C27-N4T1U3 S-1335C28-N4T1U3 S-1335C2J-N4T1U3 S-1335C29-N4T1U3 S-1335C30-N4T1U3 S-1335C31-N4T1U3 S-1335C32-N4T1U3 S-1335C33-N4T1U3 S-1335C34-N4T1U3 S-1335C35-N4T1U3 S-1335C36-N4T1U3 2. 4 Product Code (1) (2) (3) 2 7 A 2 7 B 2 7 C 2 7 D 2 7 E 2 7 F 2 7 G 2 7 H 2 7 J 2 7 K 2 7 L 2 7 N 2 7 O 2 7 P 2 7 Q 2 7 R 2 7 S 2 7 T 2 7 U 2 7 7 2 7 V 2 7 X 2 7 Y 2 7 Z 2 7 1 2 7 2 2 7 3 2 7 4 S-1335 Series D type Product Name S-1335D10-N4T1U3 S-1335D11-N4T1U3 S-1335D12-N4T1U3 S-1335D13-N4T1U3 S-1335D14-N4T1U3 S-1335D15-N4T1U3 S-1335D16-N4T1U3 S-1335D17-N4T1U3 S-1335D18-N4T1U3 S-1335D19-N4T1U3 S-1335D20-N4T1U3 S-1335D21-N4T1U3 S-1335D22-N4T1U3 S-1335D23-N4T1U3 S-1335D24-N4T1U3 S-1335D25-N4T1U3 S-1335D26-N4T1U3 S-1335D27-N4T1U3 S-1335D28-N4T1U3 S-1335D2J-N4T1U3 S-1335D29-N4T1U3 S-1335D30-N4T1U3 S-1335D31-N4T1U3 S-1335D32-N4T1U3 S-1335D33-N4T1U3 S-1335D34-N4T1U3 S-1335D35-N4T1U3 S-1335D36-N4T1U3 Product Code (1) (2) (3) 2 8 A 2 8 B 2 8 C 2 8 D 2 8 E 2 8 F 2 8 G 2 8 H 2 8 J 2 8 K 2 8 L 2 8 N 2 8 O 2 8 P 2 8 Q 2 8 R 2 8 S 2 8 T 2 8 U 2 8 7 2 8 V 2 8 X 2 8 Y 2 8 Z 2 8 1 2 8 2 2 8 3 2 8 4 51 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 3. HSNT-4 (1010) Top view 4 3 (1) to (3): (4), (5): Product code (Refer to Product name vs. Product code) Lot number (1) (2) (3) (4) (5) 1 2 Product name vs. Product code 3. 1 S-1335 Series A type Product Name S-1335A10-A4T2U3 S-1335A11-A4T2U3 S-1335A12-A4T2U3 S-1335A13-A4T2U3 S-1335A14-A4T2U3 S-1335A15-A4T2U3 S-1335A16-A4T2U3 S-1335A17-A4T2U3 S-1335A18-A4T2U3 S-1335A19-A4T2U3 S-1335A20-A4T2U3 S-1335A21-A4T2U3 S-1335A22-A4T2U3 S-1335A23-A4T2U3 S-1335A24-A4T2U3 S-1335A25-A4T2U3 S-1335A26-A4T2U3 S-1335A27-A4T2U3 S-1335A28-A4T2U3 S-1335A2J-A4T2U3 S-1335A29-A4T2U3 S-1335A30-A4T2U3 S-1335A31-A4T2U3 S-1335A32-A4T2U3 S-1335A33-A4T2U3 S-1335A34-A4T2U3 S-1335A35-A4T2U3 S-1335A36-A4T2U3 52 3. 2 Product Code (1) (2) (3) 2 5 A 2 5 B 2 5 C 2 5 D 2 5 E 2 5 F 2 5 G 2 5 H 2 5 J 2 5 K 2 5 L 2 5 N 2 5 O 2 5 P 2 5 Q 2 5 R 2 5 S 2 5 T 2 5 U 2 5 7 2 5 V 2 5 X 2 5 Y 2 5 Z 2 5 1 2 5 2 2 5 3 2 5 4 S-1335 Series B type Product Name S-1335B10-A4T2U3 S-1335B11-A4T2U3 S-1335B12-A4T2U3 S-1335B13-A4T2U3 S-1335B14-A4T2U3 S-1335B15-A4T2U3 S-1335B16-A4T2U3 S-1335B17-A4T2U3 S-1335B18-A4T2U3 S-1335B19-A4T2U3 S-1335B20-A4T2U3 S-1335B21-A4T2U3 S-1335B22-A4T2U3 S-1335B23-A4T2U3 S-1335B24-A4T2U3 S-1335B25-A4T2U3 S-1335B26-A4T2U3 S-1335B27-A4T2U3 S-1335B28-A4T2U3 S-1335B2J-A4T2U3 S-1335B29-A4T2U3 S-1335B30-A4T2U3 S-1335B31-A4T2U3 S-1335B32-A4T2U3 S-1335B33-A4T2U3 S-1335B34-A4T2U3 S-1335B35-A4T2U3 S-1335B36-A4T2U3 (1) 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 Product Code (2) (3) 6 A 6 B 6 C 6 D 6 E 6 F 6 G 6 H 6 J 6 K 6 L 6 N 6 O 6 P 6 Q 6 R 6 S 6 T 6 U 6 7 6 V 6 X 6 Y 6 Z 6 1 6 2 6 3 6 4 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 3. 3 S-1335 Series C type Product Name S-1335C10-A4T2U3 S-1335C11-A4T2U3 S-1335C12-A4T2U3 S-1335C13-A4T2U3 S-1335C14-A4T2U3 S-1335C15-A4T2U3 S-1335C16-A4T2U3 S-1335C17-A4T2U3 S-1335C18-A4T2U3 S-1335C19-A4T2U3 S-1335C20-A4T2U3 S-1335C21-A4T2U3 S-1335C22-A4T2U3 S-1335C23-A4T2U3 S-1335C24-A4T2U3 S-1335C25-A4T2U3 S-1335C26-A4T2U3 S-1335C27-A4T2U3 S-1335C28-A4T2U3 S-1335C2J-A4T2U3 S-1335C29-A4T2U3 S-1335C30-A4T2U3 S-1335C31-A4T2U3 S-1335C32-A4T2U3 S-1335C33-A4T2U3 S-1335C34-A4T2U3 S-1335C35-A4T2U3 S-1335C36-A4T2U3 3. 4 Product Code (1) (2) (3) 2 7 A 2 7 B 2 7 C 2 7 D 2 7 E 2 7 F 2 7 G 2 7 H 2 7 J 2 7 K 2 7 L 2 7 N 2 7 O 2 7 P 2 7 Q 2 7 R 2 7 S 2 7 T 2 7 U 2 7 7 2 7 V 2 7 X 2 7 Y 2 7 Z 2 7 1 2 7 2 2 7 3 2 7 4 S-1335 Series D type Product Name S-1335D10-A4T2U3 S-1335D11-A4T2U3 S-1335D12-A4T2U3 S-1335D13-A4T2U3 S-1335D14-A4T2U3 S-1335D15-A4T2U3 S-1335D16-A4T2U3 S-1335D17-A4T2U3 S-1335D18-A4T2U3 S-1335D19-A4T2U3 S-1335D20-A4T2U3 S-1335D21-A4T2U3 S-1335D22-A4T2U3 S-1335D23-A4T2U3 S-1335D24-A4T2U3 S-1335D25-A4T2U3 S-1335D26-A4T2U3 S-1335D27-A4T2U3 S-1335D28-A4T2U3 S-1335D2J-A4T2U3 S-1335D29-A4T2U3 S-1335D30-A4T2U3 S-1335D31-A4T2U3 S-1335D32-A4T2U3 S-1335D33-A4T2U3 S-1335D34-A4T2U3 S-1335D35-A4T2U3 S-1335D36-A4T2U3 Product Code (1) (2) (3) 2 8 A 2 8 B 2 8 C 2 8 D 2 8 E 2 8 F 2 8 G 2 8 H 2 8 J 2 8 K 2 8 L 2 8 N 2 8 O 2 8 P 2 8 Q 2 8 R 2 8 S 2 8 T 2 8 U 2 8 7 2 8 V 2 8 X 2 8 Y 2 8 Z 2 8 1 2 8 2 2 8 3 2 8 4 53 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 3. 5 S-1335 Series E type Product Name S-1335E10-A4T2U3 S-1335E11-A4T2U3 S-1335E12-A4T2U3 S-1335E13-A4T2U3 S-1335E14-A4T2U3 S-1335E15-A4T2U3 S-1335E16-A4T2U3 S-1335E17-A4T2U3 S-1335E18-A4T2U3 S-1335E19-A4T2U3 S-1335E20-A4T2U3 S-1335E21-A4T2U3 S-1335E22-A4T2U3 S-1335E23-A4T2U3 S-1335E24-A4T2U3 S-1335E25-A4T2U3 S-1335E26-A4T2U3 S-1335E27-A4T2U3 S-1335E28-A4T2U3 S-1335E2J-A4T2U3 S-1335E29-A4T2U3 S-1335E30-A4T2U3 S-1335E31-A4T2U3 S-1335E32-A4T2U3 S-1335E33-A4T2U3 S-1335E34-A4T2U3 S-1335E35-A4T2U3 S-1335E36-A4T2U3 54 3. 6 Product Code (1) (2) (3) 2 1 A 2 1 B 2 1 C 2 1 D 2 1 E 2 1 F 2 1 G 2 1 H 2 1 J 2 1 K 2 1 L 2 1 N 2 1 O 2 1 P 2 1 Q 2 1 R 2 1 S 2 1 T 2 1 U 2 1 7 2 1 V 2 1 X 2 1 Y 2 1 Z 2 1 1 2 1 2 2 1 3 2 1 4 S-1335 Series F type Product Name S-1335F10-A4T2U3 S-1335F11-A4T2U3 S-1335F12-A4T2U3 S-1335F13-A4T2U3 S-1335F14-A4T2U3 S-1335F15-A4T2U3 S-1335F16-A4T2U3 S-1335F17-A4T2U3 S-1335F18-A4T2U3 S-1335F19-A4T2U3 S-1335F20-A4T2U3 S-1335F21-A4T2U3 S-1335F22-A4T2U3 S-1335F23-A4T2U3 S-1335F24-A4T2U3 S-1335F25-A4T2U3 S-1335F26-A4T2U3 S-1335F27-A4T2U3 S-1335F28-A4T2U3 S-1335F2J-A4T2U3 S-1335F29-A4T2U3 S-1335F30-A4T2U3 S-1335F31-A4T2U3 S-1335F32-A4T2U3 S-1335F33-A4T2U3 S-1335F34-A4T2U3 S-1335F35-A4T2U3 S-1335F36-A4T2U3 Product Code (1) (2) (3) 2 2 A 2 2 B 2 2 C 2 2 D 2 2 E 2 2 F 2 2 G 2 2 H 2 2 J 2 2 K 2 2 L 2 2 N 2 2 O 2 2 P 2 2 Q 2 2 R 2 2 S 2 2 T 2 2 U 2 2 7 2 2 V 2 2 X 2 2 Y 2 2 Z 2 2 1 2 2 2 2 2 3 2 2 4 5.5 V INPUT, 150 mA VOLTAGE REGULATOR WITH SOFT-START FUNCTION Rev.1.4_00 S-1335 Series 3. 7 S-1335 Series G type Product Name S-1335G10-A4T2U3 S-1335G11-A4T2U3 S-1335G12-A4T2U3 S-1335G13-A4T2U3 S-1335G14-A4T2U3 S-1335G15-A4T2U3 S-1335G16-A4T2U3 S-1335G17-A4T2U3 S-1335G18-A4T2U3 S-1335G19-A4T2U3 S-1335G20-A4T2U3 S-1335G21-A4T2U3 S-1335G22-A4T2U3 S-1335G23-A4T2U3 S-1335G24-A4T2U3 S-1335G25-A4T2U3 S-1335G26-A4T2U3 S-1335G27-A4T2U3 S-1335G28-A4T2U3 S-1335G2J-A4T2U3 S-1335G29-A4T2U3 S-1335G30-A4T2U3 S-1335G31-A4T2U3 S-1335G32-A4T2U3 S-1335G33-A4T2U3 S-1335G34-A4T2U3 S-1335G35-A4T2U3 S-1335G36-A4T2U3 3. 8 Product Code (1) (2) (3) 2 3 A 2 3 B 2 3 C 2 3 D 2 3 E 2 3 F 2 3 G 2 3 H 2 3 J 2 3 K 2 3 L 2 3 N 2 3 O 2 3 P 2 3 Q 2 3 R 2 3 S 2 3 T 2 3 U 2 3 7 2 3 V 2 3 X 2 3 Y 2 3 Z 2 3 1 2 3 2 2 3 3 2 3 4 S-1335 Series H type Product Name S-1335H10-A4T2U3 S-1335H11-A4T2U3 S-1335H12-A4T2U3 S-1335H13-A4T2U3 S-1335H14-A4T2U3 S-1335H15-A4T2U3 S-1335H16-A4T2U3 S-1335H17-A4T2U3 S-1335H18-A4T2U3 S-1335H19-A4T2U3 S-1335H20-A4T2U3 S-1335H21-A4T2U3 S-1335H22-A4T2U3 S-1335H23-A4T2U3 S-1335H24-A4T2U3 S-1335H25-A4T2U3 S-1335H26-A4T2U3 S-1335H27-A4T2U3 S-1335H28-A4T2U3 S-1335H2J-A4T2U3 S-1335H29-A4T2U3 S-1335H30-A4T2U3 S-1335H31-A4T2U3 S-1335H32-A4T2U3 S-1335H33-A4T2U3 S-1335H34-A4T2U3 S-1335H35-A4T2U3 S-1335H36-A4T2U3 Product Code (1) (2) (3) 2 9 A 2 9 B 2 9 C 2 9 D 2 9 E 2 9 F 2 9 G 2 9 H 2 9 J 2 9 K 2 9 L 2 9 N 2 9 O 2 9 P 2 9 Q 2 9 R 2 9 S 2 9 T 2 9 U 2 9 7 2 9 V 2 9 X 2 9 Y 2 9 Z 2 9 1 2 9 2 2 9 3 2 9 4 55 2.9±0.2 1.9±0.2 4 5 1 2 +0.1 0.16 -0.06 3 0.95±0.1 0.4±0.1 No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 Feed direction No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP005-A-R-SD-1.1 SOT235-A-Reel TITLE No. MP005-A-R-SD-1.1 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 2.0±0.2 1.3±0.2 4 3 0.05 0.3 +0.1 -0.05 +0.1 0.16 -0.06 2 1 +0.1 0.4 -0.05 No. NP004-A-P-SD-2.0 TITLE SC82AB-A-PKG Dimensions NP004-A-P-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 4.0±0.1 2.0±0.05 1.1±0.1 4.0±0.1 0.2±0.05 ø1.05±0.1 (0.7) 2.2±0.2 2 1 3 4 Feed direction No. NP004-A-C-SD-3.0 TITLE SC82AB-A-Carrier Tape No. NP004-A-C-SD-3.0 ANGLE UNIT mm ABLIC Inc. 4.0±0.1 2.0±0.1 ø1.5 1.1±0.1 +0.1 -0 4.0±0.1 0.2±0.05 ø1.05±0.1 2.3±0.15 2 1 3 4 Feed direction No. NP004-A-C-S1-2.0 TITLE SC82AB-A-Carrier Tape No. NP004-A-C-S1-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. NP004-A-R-SD-1.1 TITLE SC82AB-A-Reel No. NP004-A-R-SD-1.1 QTY. ANGLE UNIT mm ABLIC Inc. 3,000 0.38±0.02 0.65 3 4 1 2 1.00±0.04 0.20±0.05 +0.05 0.08 -0.02 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PL004-A-P-SD-1.1 TITLE HSNT-4-B-PKG Dimensions No. PL004-A-P-SD-1.1 ANGLE UNIT mm ABLIC Inc. 2.0±0.05 +0.1 ø1.5 -0 4.0±0.05 0.25±0.05 +0.1 1.12±0.05 2 1 3 4 ø0.5 -0 2.0±0.05 0.5±0.05 Feed direction No. PL004-A-C-SD-2.0 TITLE HSNT-4-B-C a r r i e r Tape No. PL004-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. +1.0 9.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PL004-A-R-SD-1.0 HSNT-4-B-Reel TITLE PL004-A-R-SD-1.0 No. QTY. ANGLE UNIT mm ABLIC Inc. 10,000 Land Pattern 0.30min. 0.38~0.48 0.38~0.48 0.07 0.65±0.02 (1.02) Caution It is recommended to solder the heat sink to a board in order to ensure the heat radiation. PKG Metal Mask Pattern Aperture ratio Aperture ratio Caution Mask aperture ratio of the lead mounting part is 100%. Mask aperture ratio of the heat sink mounting part is 40%. Mask thickness: t0.10mm to 0.12 mm 100% 40% t0.10mm ~ 0.12 mm TITLE No. PL004-A-L-SD-2.0 HSNT-4-B -Land Recommendation PL004-A-L-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-1335C24-N4T1U3 AI解析
物料型号:S-1335 Series
器件简介: - S-1335系列是一款使用CMOS技术开发的正电压调节器集成电路,提供150mA的输出电流。 - 它具有低 dropout 电压、高精度输出电压和软启动功能。
引脚分配: - SOT-23-5、SC-82AB 和 HSNT-4 (1010) 封装类型具有不同的引脚分配,具体如下: - SOT-23-5:1. VIN 输入电压引脚,2. VSS 地引脚,3. ON/OFF 使能/禁用引脚,4. SST 软启动时间选择引脚,5. VOUT 输出电压引脚。 - SC-82AB 和 HSNT-4 (1010):1. ON/OFF 使能/禁用引脚,2. VSS 地引脚,3. VOUT 输出电压引脚,4. VIN 输入电压引脚。
参数特性: - 输出电压:1.0V 至 3.6V,步进 0.05V。 - 输入电压:1.5V 至 5.5V。 - 输出电压精度:±1.0%(1.0V 至 1.45V 输出产品:±15mV)。 - dropout 电压:典型值 70mV(2.8V 输出产品,输出电流100mA)。 - 电流消耗:典型值 36μA,最大值 54μA。 - 软启动时间:可调节,典型值 0.1ms 或 1.0ms。
功能详解: - 内置软启动电路,可调整输出电压上升时间。 - 内置过流保护电路,防止输出电流超过晶体管容量。 - 可选择的放电分流功能和下拉功能。 - 操作温度范围:-40°C 至 +85°C。
应用信息: - 数码相机、电视等恒压电源。 - 电池供电设备的恒压电源。 - 手机、便携设备的恒压电源。
封装信息: - 提供SOT-23-5、SC-82AB 和超小型 HSNT-4 (1010) 封装,实现高密度安装。
*介绍内容由AI识别生成
S-1335C24-N4T1U3 价格&库存
很抱歉,暂时无法提供与“S-1335C24-N4T1U3”相匹配的价格&库存,您可以联系我们找货
