CD74ACT245M
CD74ACT245M
    L3HARRIS
    SOIC20
    IC TXRX NON-INVERT 5.5V 20SOIC
CD74ACT245M 数据手册
CD54/74AC245, CD54/74ACT245 Data sheet acquired from Harris Semiconductor SCHS245B Octal-Bus Transceiver, Three-State, Non-Inverting September 1998 - Revised October 2000 Features Description • Buffered Inputs The ’AC245 and ’ACT245 are octal-bus transceivers that utilize Advanced CMOS Logic technology. They are noninverting three-state bidirectional transceiver-buffers intended for two-way transmission from “A” bus to “B” bus or “B” bus to “A”. The logic level present on the direction input (DIR) determines the data direction. When the output enable input (OE) is HIGH, the outputs are in the high-impedance state. • Typical Propagation Delay - 4ns at VCC = 5V, TA = 25oC, CL = 50pF • Exceeds 2kV ESD Protection per MIL-STD-883, Method 3015 [ /Title (CD74 AC245 , CD74 ACT24 5) /Subject (OctalBus Transceiver, ThreeState, NonInverting) /Autho r () /Keywords (Harris Semiconductor, Advan ced CMOS , Harris Semicon- • SCR-Latchup-Resistant CMOS Process and Circuit Design Ordering Information • Speed of Bipolar FAST™/AS/S with Significantly Reduced Power Consumption PART NUMBER • Balanced Propagation Delays • AC Types Feature 1.5V to 5.5V Operation and Balanced Noise Immunity at 30% of the Supply • ±24mA Output Drive Current - Fanout to 15 FAST™ ICs - Drives 50Ω Transmission Lines TEMP. RANGE (oC) PACKAGE CD54AC245F3A -55 to 125 20 Ld CERDIP CD74AC245E -55 to 125 20 Ld PDIP CD74AC245M -55 to 125 20 Ld SOIC CD74AC245SM -55 to 125 20 Ld SSOP CD54ACT245F3A -55 to 125 20 Ld CERDIP CD74ACT245E -55 to 125 20 Ld PDIP CD74ACT245M -55 to 125 20 Ld SOIC CD74ACT245SM -55 to 125 20 Ld SSOP NOTES: 1. When ordering, use the entire part number. Add the suffix 96 to obtain the variant in the tape and reel. 2. Wafer and die for this part number is available which meets all electrical specifications. Please contact your local TI sales office or customer service for ordering information. Pinout CD54AC245, CD54ACT245 (CERDIP) CD74AC245, CD74ACT245 (PDIP, SOIC, SSOP) TOP VIEW DIR 1 A0 2 19 OE A1 3 18 B0 A2 4 17 B1 A3 5 16 B2 A4 6 15 B3 A5 7 14 B4 A6 8 13 B5 A7 9 12 B6 GND 10 11 B7 20 VCC CAUTION: These devices are sensitive to electrostatic discharge. Users should follow proper IC Handling Procedures. FAST™ is a Trademark of Fairchild Semiconductor. Copyright © 2000, Texas Instruments Incorporated 1 CD54/74AC245, CD54/74ACT245 Functional Diagram A0 A1 A2 A3 A4 A5 A6 A7 2 18 3 17 4 16 5 15 6 14 7 13 8 12 9 11 B0 B1 B2 B3 B4 B5 B6 B7 1 DIR 19 OE TRUTH TABLE CONTROL INPUTS OE DIR OPERATION L L B Data to A Bus L H A Data to B Bus H X Isolation H = High Level, L = Low Level, X = Irrelevant To prevent excess currents in the High-Z (isolation) modes, all I/O terminals should be terminated with 10kΩ to 1MΩ resistors. 2 CD54/74AC245, CD54/74ACT245 Absolute Maximum Ratings Thermal Information DC Supply Voltage, VCC . . . . . . . . . . . . . . . . . . . . . . . . -0.5V to 6V DC Input Diode Current, IIK For VI < -0.5V or VI > VCC + 0.5V . . . . . . . . . . . . . . . . . . . . . .±20mA DC Output Diode Current, IOK For VO < -0.5V or VO > VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±50mA DC Output Source or Sink Current per Output Pin, IO For VO > -0.5V or VO < VCC + 0.5V . . . . . . . . . . . . . . . . . . . .±50mA DC VCC or Ground Current, ICC or IGND (Note 3) . . . . . . . . .±100mA Thermal Resistance (Typical, Note 5) θJA (oC/W) E Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 69 M Package. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 58 SM Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70 Maximum Junction Temperature (Plastic Package) . . . . . . . . . . 150oC Maximum Storage Temperature Range . . . . . . . . . .-65oC to 150oC Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . . 300oC Operating Conditions Temperature Range, TA . . . . . . . . . . . . . . . . . . . . . . -55oC to 125oC Supply Voltage Range, VCC (Note 4) AC Types. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .1.5V to 5.5V ACT Types . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .4.5V to 5.5V DC Input or Output Voltage, VI, VO . . . . . . . . . . . . . . . . . 0V to VCC Input Rise and Fall Slew Rate, dt/dv AC Types, 1.5V to 3V . . . . . . . . . . . . . . . . . . . . . . . . . 50ns (Max) AC Types, 3.6V to 5.5V . . . . . . . . . . . . . . . . . . . . . . . . 20ns (Max) ACT Types, 4.5V to 5.5V. . . . . . . . . . . . . . . . . . . . . . . 10ns (Max) CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTES: 3. For up to 4 outputs per device, add ±25mA for each additional output. 4. Unless otherwise specified, all voltages are referenced to ground. 5. The package thermal impedance is calculated in accordance with JESD 51-7. DC Electrical Specifications TEST CONDITIONS PARAMETER -40oC TO 85oC 25oC -55oC TO 125oC SYMBOL VI (V) IO (mA) VCC (V) MIN MAX MIN MAX MIN MAX UNITS VIH - - 1.5 1.2 - 1.2 - 1.2 - V 3 2.1 - 2.1 - 2.1 - V 5.5 3.85 - 3.85 - 3.85 - V 1.5 - 0.3 - 0.3 - 0.3 V 3 - 0.9 - 0.9 - 0.9 V 5.5 - 1.65 - 1.65 - 1.65 V 1.5 1.4 - 1.4 - 1.4 - V AC TYPES High Level Input Voltage Low Level Input Voltage High Level Output Voltage VIL VOH - VIH or VIL - -0.05 -0.05 3 2.9 - 2.9 - 2.9 - V -0.05 4.5 4.4 - 4.4 - 4.4 - V -4 3 2.58 - 2.48 - 2.4 - V -24 4.5 3.94 - 3.8 - 3.7 - V -75 (Note 6, 7) 5.5 - - 3.85 - - - V -50 (Note 6, 7) 5.5 - - - - 3.85 - V 3 CD54/74AC245, CD54/74ACT245 DC Electrical Specifications (Continued) TEST CONDITIONS PARAMETER Low Level Output Voltage -40oC TO 85oC 25oC -55oC TO 125oC SYMBOL VI (V) IO (mA) VCC (V) MIN MAX MIN MAX MIN MAX UNITS VOL VIH or VIL 0.05 1.5 - 0.1 - 0.1 - 0.1 V 0.05 3 - 0.1 - 0.1 - 0.1 V 0.05 4.5 - 0.1 - 0.1 - 0.1 V 12 3 - 0.36 - 0.44 - 0.5 V 24 4.5 - 0.36 - 0.44 - 0.5 V 75 (Note 6, 7) 5.5 - - - 1.65 - - V 50 (Note 6, 7) 5.5 - - - - - 1.65 V Input Leakage Current II VCC or GND - 5.5 - ±0.1 - ±1 - ±1 µA Three-State Leakage Current IOZ VIH or VIL VO = VCC or GND - 5.5 - ±0.5 - ±5 - ±10 µA Quiescent Supply Current MSI ICC VCC or GND 0 5.5 - 8 - 80 - 160 µA High Level Input Voltage VIH - - 4.5 to 5.5 2 - 2 - 2 - V Low Level Input Voltage VIL - - 4.5 to 5.5 - 0.8 - 0.8 - 0.8 V High Level Output Voltage VOH VIH or VIL -0.05 4.5 4.4 - 4.4 - 4.4 - V -24 4.5 3.94 - 3.8 - 3.7 - V -75 (Note 6, 7) 5.5 - - 3.85 - - - V -50 (Note 6, 7) 5.5 - - - - 3.85 - V 0.05 4.5 - 0.1 - 0.1 - 0.1 V 24 4.5 - 0.36 - 0.44 - 0.5 V 75 (Note 6, 7) 5.5 - - - 1.65 - - V 50 (Note 6, 7) 5.5 - - - - - 1.65 V ACT TYPES Low Level Output Voltage VOL VIH or VIL II VCC or GND - 5.5 - ±0.1 - ±1 - ±1 µA Three-State or Leakage Current IOZ VIH or VIL VO = VCC or GND - 5.5 - ±0.5 - ±5 - ±10 µA Quiescent Supply Current MSI ICC VCC or GND 0 5.5 - 8 - 80 - 160 µA ∆ICC VCC -2.1 - 4.5 to 5.5 - 2.4 - 2.8 - 3 mA Input Leakage Current Additional Supply Current per Input Pin TTL Inputs High 1 Unit Load NOTES: 6. Test one output at a time for a 1-second maximum duration. Measurement is made by forcing current and measuring voltage to minimize power dissipation. 7. Test verifies a minimum 50Ω transmission-line-drive capability at 85oC, 75Ω at 125oC. 4 CD54/74AC245, CD54/74ACT245 ACT Input Load Table INPUT UNIT LOAD An, Bn 0.83 OE 0.64 DIR 0.25 NOTE: Unit load is ∆ICC limit specified in DC Electrical Specifications Table, e.g., 2.4mA max at 25oC. Switching Specifications Input tr, tf = 3ns, CL = 50pF (Worst Case) -40oC TO 85oC PARAMETER -55oC TO 125oC SYMBOL VCC (V) MIN TYP MAX MIN TYP MAX UNITS tPLH, tPHL 1.5 - - 96 - - 106 ns 3.3 (Note 9) 3.2 - 10.8 3 - 11.9 ns 5 (Note 10) 2.2 - 7.7 2.1 - 8.5 ns 1.5 - - 159 - - 175 ns 3.3 4.7 - 15.9 4.4 - 17.5 ns 5 3.7 - 12.7 3.5 - 14 ns 1.5 - - 159 - - 175 ns 3.3 5.6 - 19 5.3 - 21 ns 5 3.7 - 12.7 3.5 - 14 ns AC TYPES Propagation Delay, Data to Output Propagation Delay, Output Disable to Output Propagation Delay, Output Enable to Output tPLZ, tPHZ tPZL, tPZH Minimum (Valley) VOH During Switching of Other Outputs (Output Under Test Not Switching) VOHV See Figure 1 5 - 4 at 25oC - - 4 at 25oC - V Maximum (Peak) VOL During Switching of Other Outputs (Output Under Test Not Switching) VOLP See Figure 1 5 - 1 at 25oC - - 1 at 25oC - V Three-State Output Capacitance CO - - 15 - - 15 - pF Input Capacitance CI - - - 10 - - 10 pF CPD (Note 11) - - 57 - - 57 - pF Propagation Delay, Data to Output tPLH, tPHL 5 (Note 10) 2.7 - 9.1 2.5 - 10 ns Propagation Delay, Output Disable to Output tPLZ, tPHZ 5 3.7 12.7 3.5 14 ns Propagation Delay, Output Enable to Output tPZL, tPZH 5 3.8 13.1 3.6 14.4 ns Minimum (Valley) VOH During Switching of Other Outputs (Output Under Test Not Switching) VOHV See Figure 1 5 - 4 at 25oC - - 4 at 25oC - V Maximum (Peak) VOL During Switching of Other Outputs (Output Under Test Not Switching) VOLP See Figure 1 5 - 1 at 25oC - - 1 at 25oC - V Power Dissipation Capacitance ACT TYPES 5 CD54/74AC245, CD54/74ACT245 Switching Specifications Input tr, tf = 3ns, CL = 50pF (Worst Case) (Continued) -40oC TO 85oC -55oC TO 125oC SYMBOL VCC (V) MIN TYP MAX MIN TYP MAX UNITS Three-State Output Capacitance CO - - 15 - - 15 - pF Input Capacitance CI - - - 10 - - 10 pF CPD (Note 11) - - 57 - - 57 - pF PARAMETER Power Dissipation Capacitance NOTES: 8. Limits tested 100% 9. 3.3V Min is at 3.6V, Max is at 3V. 10. 5V Min is at 5.5V, Max is at 4.5V. 11. CPD is used to determine the dynamic power consumption per channel. AC: PD = VCC2 fi (CPD + CL) ACT: PD = VCC2 fi (CPD + CL) + VCC ∆ICC where fi = input frequency, CL = output load capacitance, VCC = supply voltage. VOH OTHER OUTPUTS VOL VOH VOHV OUTPUT UNDER TEST VOLP VOL NOTES: 12. Input pulses have the following characteristics: PRR ≤ 1MHz, tr = 3ns, SKEW 1ns. 13. R.F. fixture with 700MHz design rules required. IC should be soldered into test board and bypassed with 0.1µF capacitor. Scope and probes require 700MHz bandwidth. FIGURE 1. SIMULTANEOUS SWITCHING TRANSIENT WAVEFORMS 6 CD54/74AC245, CD54/74ACT245 tf = 3ns tr = 3ns INPUT LEVEL 90% OUTPUTS DISABLED VS 10% tPLZ GND tPZL OUTPUT: LOW TO OFF TO LOW VS 0.2 VCC tPHZ VOL (≠ VCC) tPZH 0.8 VCC VS OUTPUT: HIGH TO OFF TO HIGH OUTPUTS ENABLED OUTPUTS DISABLED OUTPUTS ENABLED GND (tPHZ, tPZH) OTHER INPUTS TIED HIGH OR LOW OUTPUT DISABLE OPEN (tPHL, tPLH) 2 VCC (tPLZ, tPZL) RL 500Ω (OPEN DRAIN) OUT RL CL 500Ω 50pF (NOTE 14) DUT WITH THREESTATE OUTPUT NOTE: 14. For AC Series only: When VCC = 1.5V, RL = 1kΩ. FIGURE 2. THREE-STATE PROPAGATION DELAY TIMES AND TEST CIRCUIT tr = 3ns tf = 3ns INPUT LEVEL 90% VS 10% An GND tPHL tPLH VS Bn FIGURE 3. PROPAGATION DELAY TIMES OUTPUT RL (NOTE) 500Ω DUT OUTPUT LOAD CL 50pF NOTE: For AC Series Only: When VCC = 1.5V, RL = 1kΩ. AC ACT VCC 3V Input Switching Voltage, VS 0.5 VCC 1.5V Output Switching Voltage, VS 0.5 VCC 0.5 VCC Input Level FIGURE 4. PROPAGATION DELAY TIMES 7 PACKAGE OPTION ADDENDUM www.ti.com 6-Feb-2020 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Op Temp (°C) Device Marking (4/5) CD54AC245F3A ACTIVE CDIP J 20 1 TBD Call TI N / A for Pkg Type -55 to 125 CD54AC245F3A CD54ACT245F3A ACTIVE CDIP J 20 1 TBD Call TI N / A for Pkg Type -55 to 125 CD54ACT245F3A CD74AC245E ACTIVE PDIP N 20 20 Pb-Free (RoHS) NIPDAU N / A for Pkg Type -55 to 125 CD74AC245E CD74AC245EE4 ACTIVE PDIP N 20 20 Pb-Free (RoHS) NIPDAU N / A for Pkg Type -55 to 125 CD74AC245E CD74AC245M ACTIVE SOIC DW 20 25 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 AC245M CD74AC245M96 ACTIVE SOIC DW 20 2000 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 AC245M CD74ACT245E ACTIVE PDIP N 20 20 Pb-Free (RoHS) NIPDAU N / A for Pkg Type -55 to 125 CD74ACT245E CD74ACT245EE4 ACTIVE PDIP N 20 20 Pb-Free (RoHS) NIPDAU N / A for Pkg Type -55 to 125 CD74ACT245E CD74ACT245M ACTIVE SOIC DW 20 25 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 ACT245M CD74ACT245M96 ACTIVE SOIC DW 20 2000 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 ACT245M CD74ACT245M96G4 ACTIVE SOIC DW 20 2000 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 ACT245M CD74ACT245MG4 ACTIVE SOIC DW 20 25 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 ACT245M CD74ACT245SM96 ACTIVE SSOP DB 20 2000 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 ACT245SM (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. Addendum-Page 1 Samples PACKAGE OPTION ADDENDUM www.ti.com 6-Feb-2020 (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
CD74ACT245M 价格&库存
很抱歉,暂时无法提供与“CD74ACT245M”相匹配的价格&库存,您可以联系我们找货
