ICL232IBE
ICL232IBE
    L3HARRIS
    SOIC16
    RS-232 TRANSMITTERS/RECIEVERS
ICL232IBE 数据手册
ICL232 ® Datasheet July 28, 2005 FN3020.7 +5V Powered, Dual RS-232 Transmitter/Receiver Features The ICL232 is a dual RS-232 transmitter/receiver interface circuit that meets all ElA RS-232C and V.28 specifications. It requires a single +5V power supply, and features two onboard charge pump voltage converters which generate +10V and -10V supplies from the 5V supply. • Requires Only Single +5V Power Supply • Meets All RS-232C and V.28 Specifications The drivers feature true TTL/CMOS input compatibility, slewrate-limited output, and 300Ω power-off source impedance. The receivers can handle up to +30V, and have a 3kΩ to 7kΩ input impedance. The receivers also have hysteresis to improve noise rejection. Ordering Information PART NUMBER TEMP. RANGE (oC) PACKAGE PKG. DWG. # ICL232CPE 0 to 70 16 Ld PDIP E16.3 ICL232CBE 0 to 70 16 Ld SOIC M16.3 16 Ld SOIC Tape and Reel M16.3 ICL232CBET ICL232CBEZ (See Note) ICL232CBEZT (See Note) 0 to 70 16 Ld SOIC (Pb-free) M16.3 16 Ld SOIC Tape and Reel (Pb-free) M16.3 • Onboard Voltage Doubler/Inverter • Low Power Consumption • 2 Drivers - ±9V Output Swing for +5V lnput - 300Ω Power-off Source Impedance - Output Current Limiting - TTL/CMOS Compatible - 30V/µs Maximum Slew Rate • 2 Receivers - ±30V Input Voltage Range - 3kΩ to 7kΩ Input Impedance - 0.5V Hysteresis to Improve Noise Rejection • All Critical Parameters are Guaranteed Over the Entire Commercial, Industrial and Military Temperature Ranges • Pb-Free Plus Anneal Available (RoHS Compliant) Applications ICL232lPE -40 to 85 16 Ld PDIP E16.3 ICL232lBE -40 to 85 16 Ld SOIC M16.3 16 Ld SOIC Tape and Reel M16.3 • Any System Requiring RS-232 Communications Port - Computer - Portable and Mainframe - Peripheral - Printers and Terminals - Portable Instrumentation - Modems F16.3 • Dataloggers ICL232lBET ICL232MJE -55 to 125 16 Ld CERDIP NOTE: Intersil Pb-free plus anneal products employ special Pb-free material sets; molding compounds/die attach materials and 100% matte tin plate termination finish, which are RoHS compliant and compatible with both SnPb and Pb-free soldering operations. Intersil Pb-free products are MSL classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020. Pinout ICL232 (PDIP, CERDIP, SOIC) TOP VIEW C1+ 1 16 VCC V+ 2 15 GND C1- 3 14 T1OUT C2+ 4 13 R1IN C2- 5 12 R1OUT V- 6 11 T1IN T2OUT 7 10 T2IN R2IN 8 1 9 R2OUT CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 1-888-INTERSIL or 1-888-468-3774 | Intersil (and design) is a registered trademark of Intersil Americas Inc. Copyright Intersil Americas Inc. 2001, 2005. All Rights Reserved All other trademarks mentioned are the property of their respective owners. ICL232 Functional Diagram +5V + 1.0µF 1 1µF + 3 4 1µF T1IN T2IN R1OUT R2OUT + 5 C1+ C1C2+ C2- 16 VCC 2 +5V TO 10V VOLTAGE INVERTER V+ +10V TO -10V VOLTAGE INVERTER 11 +5V 400kΩ T1 10 +5V 400kΩ T2 + V- 6 + 14 7 12 13 R1 5kΩ R2 5kΩ 9 1µF 8 1µF T1OUT T2OUT R1IN R2IN 15 2 FN3020.7 July 28, 2005 ICL232 Absolute Maximum Ratings Thermal Information VCC to Ground. . . . . . . . . . . . . . . . . . . . . . (GND -0.3V) < VCC < 6V V+ to Ground . . . . . . . . . . . . . . . . . . . . . . . . (VCC -0.3V) < V+ < 12V V- to Ground. . . . . . . . . . . . . . . . . . . . . . . . -12V < V- < (GND +0.3V) Input Voltages T1IN , T2IN . . . . . . . . . . . . . . . . . . . .(V- -0.3V) < VIN < (V+ +0.3V) R1IN , R2IN . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±30V Output Voltages T1OUT, T2OUT . . . . . . . . . . . . . (V- -0.3V) < VTXOUT < (V+ +0.3V) R1OUT, R2OUT. . . . . . . . . (GND -0.3V) < VRXOUT < (VCC +0.3V) Short Circuit Duration T1OUT, T2OUT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Continuous R1OUT, R2OUT. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Continuous Thermal Resistance (Typical, Note 1) θJA (oC/W) θJC (oC/W) CERDIP Package . . . . . . . . . . . . . . . . . 80 18 PDIP Package. . . . . . . . . . . . . . . . . . . . 100 N/A SOIC Package . . . . . . . . . . . . . . . . . . . 100 N/A Maximum Junction Temperature Plastic Packages. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 150oC Ceramic Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 175oC Maximum Storage Temperature Range . . . . . . . . . . -65oC to 150oC Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . 300oC Operating Conditions Temperature Ranges ICL232C . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0oC to 70oC ICL232I. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -40oC to 85oC ICL232M. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -55oC to 125oC CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTE: 1. θJA is measured with the component mounted on an evaluation PC board in free air. Test Conditions: VCC = +5V Otherwise Specified Electrical Specifications PARAMETER ±10%, TA = Operating Temperature Range. Test Circuit as in Figure 8 Unless TEST CONDITIONS MIN TYP MAX UNITS Transmitter Output Voltage Swing, TOUT T1OUT and T2OUT Loaded with 3kΩ to Ground ±5 ±9 ±10 V Power Supply Current, ICC Outputs Unloaded, TA = 25oC - 5 10 mA TIN , Input Logic Low, VlL - - 0.8 V TIN , Input Logic High, VlH 2.0 - - V - 15 200 µA -30 - +30 V Logic Pullup Current, IP T1IN , T2IN = 0V RS-232 Input Voltage Range, VIN Receiver Input Impedance, RIN VIN = ±3V 3.0 5.0 7.0 kΩ Receiver Input Low Threshold, VlN (H-L) VCC = 5V, TA = 25oC VCC = 5V, TA = 25oC 0.8 1.2 - V - 1.7 2.4 V 0.2 0.5 1.0 V Receiver Input High Threshold, VIN (L-H) Receiver Input Hysteresis, VHYST TTL/CMOS Receiver Output Voltage Low, VOL IOUT = 3.2mA - 0.1 0.4 V TTL/CMOS Receiver Output Voltage High, VOH IOUT = -1.0mA 3.5 4.6 - V Propagation Delay, tPD RS-232 to TTL - 0.5 - µs Instantaneous Slew Rate, SR CL = 10pF, RL = 3kΩ, TA = 25oC - - 30 V/µs Transition Region Slew Rate, SRT RL = 3kΩ, CL = 2500pF Measured from +3V to -3V or -3V to +3V - 3 - V/µs Output Resistance, ROUT VCC = V+ = V- = 0V, VOUT = ±2V 300 - - Ω RS-232 Output Short Circuit Current, ISC T1OUT or T2OUT Shorted to GND - ±10 - mA (Notes 2, 3) NOTES: 2. Guaranteed by design. 3. See Figure 4 for definition. 3 FN3020.7 July 28, 2005 ICL232 Test Circuits - 1µF C3 1µF C1 +4.5V TO +5.5V INPUT + + - 1 C1+ VCC 16 2 V+ GND 15 3 1µF + C2 - 3kΩ T1OUT 14 C1- T1 OUTPUT RS-232 ±30V INPUT TTL/CMOS OUTPUT 4 C2+ R1IN 13 5 C2- R1OUT 12 6 V- T1IN 11 TTL/CMOS INPUT 7 T2OUT T2IN 10 TTL/CMOS INPUT 8 R2IN 9 TTL/CMOS OUTPUT 1µF C4 - + 3kΩ T2 OUTPUT RS-232 ±30V INPUT R2OUT 1 C1+ VCC 16 2 V+ GND 15 3 C1- T1OUT 14 4 C2+ R1IN 13 5 C2- R1OUT 12 6 V- T1IN 11 7 T2OUT T2IN 10 8 R2IN R2OUT ROUT = VIN/I VIN = ±2V 9 T2OUT A T1OUT FIGURE 1. GENERAL TEST CIRCUIT FIGURE 2. POWER-OFF SOURCE RESISTANCE CONFIGURATION Typical Performance Curves 10 500 9 o 450 TA = 25 C EXTERNAL SUPPLY LOAD 400 1kΩ BETWEEN V+ + GND OR V- + GND 350 TRANSMITTER OUTPUT V- SUPPLY OUTPUT VOLTAGE (|V|) V+, V- SUPPLY IMPEDANCES (Ω) 550 OPEN CIRCUIT 300 250 GUARANTEED OPERATING RANGE V+ SUPPLY V+ (VCC = 4.5V) 7 6 3 4 5 6 5 TA = 25oC 3 TRANSMITTER OUTPUTS OPEN CIRCUIT 0 1 2 3 INPUT SUPPLY VOLTAGE VCC (V) FIGURE 3. V+, V- OUTPUT IMPEDANCES vs VCC V- (VCC = 5V) V- (VCC = 4.5V) 4 200 150 V+ (VCC = 5V) 8 4 5 6 7 8 9 10 |ILOAD| (mA) FIGURE 4. V+, V- OUTPUT VOLTAGES vs LOAD CURRENT Pin Descriptions PDIP, CERDIP SOIC PIN NAME 1 1 C1+ 2 2 V+ Internally generated +10V (typical) supply. 3 3 C1- External capacitor “-” for internal voltage doubler. 4 4 C2+ External capacitor “+” internal voltage inverter. 5 5 C2- External capacitor “-” internal voltage inverter. 6 6 V- 7 7 T2OUT 8 8 R2IN 4 DESCRIPTION External capacitor “+” for internal voltage doubler. Internally generated -10V (typical) supply. RS-232 Transmitter 2 output ±10V (typical). RS-232 Receiver 2 input, with internal 5K pulldown resistor to GND. FN3020.7 July 28, 2005 ICL232 Pin Descriptions (Continued) PDIP, CERDIP SOIC PIN NAME DESCRIPTION 9 9 R2out 10 10 T2IN Transmitter 2 TTL/CMOS input, with internal 400K pullup resistor to VCC . 11 11 T1IN Transmitter 1 TTL/CMOS input, with internal 400K pullup resistor to VCC . 12 12 R1OUT 13 13 R1IN 14 14 T1OUT 15 15 GND Supply Ground. 16 16 VCC Positive Power Supply +5V ±10% Receiver 2 TTL/CMOS output. Receiver 1 TTL/CMOS output. RS-232 Receiver 1 input, with internal 5K pulldown resistor to GND. RS-232 Transmitter 1 output ±10V (typical). VOLTAGE DOUBLER C1+ S1 VOLTAGE INVERTER S2 V+ = 2VCC VCC + GND C1- S3 + C1 S4 C2+ S5 GND + C3 VCC S6 + C2 - C4 GND C2- S7 V- = -(V+) S8 RC OSCILLATOR FIGURE 5. DUAL CHARGE PUMP Detailed Description The ICL232 is a dual RS-232 transmitter/receiver powered by a single +5V power supply which meets all ElA RS232C specifications and features low power consumption. The functional diagram illustrates the major elements of the ICL232. The circuit is divided into three sections: a voltage doubler/inverter, dual transmitters, and dual receivers Voltage Converter. An equivalent circuit of the dual charge pump is illustrated in Figure 5. The voltage quadrupler contains two charge pumps which use two phases of an internally generated clock to generate +10V and -10V. The nominal clock frequency is 16kHz. During phase one of the clock, capacitor C1 is charged to VCC . During phase two, the voltage on C1 is added to VCC , producing a signal across C2 equal to twice VCC . At the same time, C3 is also charged to 2VCC , and then during phase one, it is inverted with respect to ground to produce a signal across C4 equal to -2VCC . The voltage converter accepts input voltages up to 5.5V. The output impedance of the doubler (V+) is approximately 200Ω, and the output impedance of the inverter (V-) is approximately 450Ω. Typical graphs are presented which show the voltage converters output vs input voltage and output voltages vs load characteristics. The test circuit (Figure 3) uses 1µF capacitors for C1-C4, however, the value is not critical. Increasing the values of C1 and C2 will lower the output impedance of the voltage doubler and inverter, and increasing the values of the reservoir capacitors, C3 and C4, lowers the ripple on the V+ and V- supplies. 5 T1IN, T2IN 90% 10% T1OUT, T2OUT tf VOH tr VOL (0.8) (VOH - VOL) (0.8) (VOL - VOH) Instantaneous = or Slew Rate (SR) tr tf FIGURE 6. SLEW RATE DEFINITION Transmitters The transmitters are TTL/CMOS compatible inverters which translate the inputs to RS-232 outputs. The input logic threshold is about 26% of VCC , or 1.3V for VCC = 5V. A logic 1 at the input results in a voltage of between -5V and V- at the output, and a logic 0 results in a voltage between +5V and (V+ - 0.6V). Each transmitter input has an internal 400kΩ pullup resistor so any unused input can be left unconnected and its output remains in its low state. The output voltage swing meets the RS-232C specification of ±5V minimum with the worst case conditions of: both transmitters driving 3kΩ minimum load impedance, VCC = 4.5V, and maximum allowable operating temperature. The transmitters have an internally limited output slew rate which is less than 30V/µs. The outputs are short circuit protected and can be shorted to ground indefinitely. The powered down output impedance is a FN3020.7 July 28, 2005 ICL232 minimum of 300Ω with ±2V applied to the outputs and VCC = 0V. is generated by driving them through a 5kΩ resistor connected to V+. +5V V+ VCC 400kΩ 300Ω C1 + 1µF - TXIN TOUT GND < TXIN < VCC V- < VTOUT < V+ V- FIGURE 7. TRANSMITTER C2 + 1µF TD Receivers 16 1 5kΩ 3 ICL232 6 4 5 T1 11 VCC RXIN -30V < RXIN < +30V ROUT 5kΩ GND < VROUT < VCC GND FIGURE 8. RECEIVER INPUTS RTS OUTPUTS 12 TTL/CMOS RD CTS 9 + 14 T2 10 The receiver inputs accept up to ±30V while presenting the required 3kΩ to 7kΩ input impedance even it the power is off (VCC = 0V). The receivers have a typical input threshold of 1.3V which is within the ±3V limits, known as the transition region, of the RS-232 specification. The receiver output is 0V to VCC . The output will be low whenever the input is greater than 2.4V and high whenever the input is floating or driven between +0.8V and -30V. The receivers feature 0.5V hysteresis to improve noise rejection. - C3 + 1µF 5kΩ 2 7 13 R2 R1 15 8 CTR (20) DATA TERMINAL READY DSRS (24) DATA SIGNALING RATE SELECT C4 1µF RS-232 INPUTS AND OUTPUTS TD (2) TRANSMIT DATA RTS (4) REQUEST TO SEND RD (3) RECEIVE DATA CTS (5) CLEAR TO SEND SIGNAL GROUND (7) FIGURE 10. SIMPLE DUPLEX RS-232 PORT WITH CTS/RTS HANDSHAKING In applications requiring four RS-232 inputs and outputs (Figure 11), note that each circuit requires two charge pump capacitors (C1 and C2) but can share common reservoir capacitors (C3 and C4). The benefit of sharing common reservoir capacitors is the elimination of two capacitors and the reduction of the charge pump source impedance which effectively increases the output swing of the transmitters. T1IN, T2IN OR R1IN, R2IN T1OUT, T2OUT OR R1OUT, R2OUT VOH VOL tPHL tPLH Average Propagation Delay = tPHL + tPLH 2 FIGURE 9. PROPAGATION DELAY DEFINITION Applications The ICL232 may be used for all RS-232 data terminal and communication links. It is particularly useful in applications where ±12V power supplies are not available for conventional RS-232 interface circuits. The applications presented represent typical interface configurations. A simple duplex RS-232 port with CTS/RTS handshaking is illustrated in Figure 10. Fixed output signals such as DTR (data terminal ready) and DSRS (data signaling rate select) 6 FN3020.7 July 28, 2005 ICL232 1 C1 + 1µF TD INPUTS OUTPUTS TTL/CMOS RTS 4 ICL232 3 T1 11 - 14 T2 10 + C2 1µF 5 TD (2) TRANSMIT DATA 7 RTS (4) REQUEST TO SEND 13 12 RD (3) RECEIVE DATA RD 9 CTS R2 R1 8 CTS (5) CLEAR TO SEND 15 6 - 2 C3 + + C4 V- V+ 2µF 6 - 2 µF 2 16 +5V RS-232 INPUTS AND OUTPUTS ICL232 C1 + 1µF DTR INPUTS OUTPUTS TTL/CMOS DSRS 1 4 3 5 T1 11 14 T2 10 12 7 13 DCD R1 9 R2 R1 15 8 + C2 1µF - DTR (20) DATA TERMINAL READY DSRS (24) DATA SIGNALING RATE SELECT DCD (8) DATA CARRIER DETECT R1 (22) RING INDICATOR SIGNAL GROUND (7) FIGURE 11. COMBINING TWO ICL232s FOR 4 PAIRS OF RS-232 INPUTS AND OUTPUTS All Intersil U.S. products are manufactured, assembled and tested utilizing ISO9000 quality systems. Intersil Corporation’s quality certifications can be viewed at www.intersil.com/design/quality Intersil products are sold by description only. Intersil Corporation reserves the right to make changes in circuit design, software and/or specifications at any time without notice. Accordingly, the reader is cautioned to verify that data sheets are current before placing orders. Information furnished by Intersil is believed to be accurate and reliable. However, no responsibility is assumed by Intersil or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Intersil or its subsidiaries. For information regarding Intersil Corporation and its products, see www.intersil.com 7 FN3020.7 July 28, 2005
ICL232IBE 价格&库存
很抱歉,暂时无法提供与“ICL232IBE”相匹配的价格&库存,您可以联系我们找货
