SV250115
SV250115
    CARLOGAVAZZI
    Module
    SENSOR PROX CAPACITIVE IP20 MOD
SV250115 数据手册
Level Sensors Amplifier, Capacitive Types SV 150/250, SV 160/260 • Level control for solid, fluid, or granulated substances • SV 150/250: Max./min. control of DISCHARGING • SV 160/260: Max./min. control of CHARGING • Factory-set sensitivity • For capacitive sensors VR.. and VRY.. • 10 A SPDT or 8 A DPDT output relay • LED-indication: SV 150/250: Power supply and relay ON • SV 160/260: Relay ON • AC or DC power supply SV 150/250 SV 160/260 Product Description Ordering Key Level control relays for capacitive sensors, types VR and VRY. The relays can con- Housing Output Power supply trol one or two levels of charging (SV 160/260) or discharging (SV 150/250). SV 150 024 Type Selection Plug Output Function Supply: 24 VAC Supply: 115 VAC Supply: 230 VAC Supply: 24 VDC Circular SPDT DPDT SPDT DPDT Discharging Discharging Charging Charging SV SV SV SV SV SV SV SV SV SV SV SV SV SV SV SV 150 250 160 260 024 024 024 024 150 250 160 260 115 115 115 115 150 250 160 260 230 230 230 230 Input Specifications Supply Specifications Sensitivity Power supply AC-types Rated operational voltage through pin 2 & 10 230 115 024 Rated insulation voltage Rated impulse withstand voltage Sensor voltage Sensor current Activated Not activated Sensor short-circuit current Depends on sensor type and material Max. 24 VDC Terminal 6 is negative Min. 15 mA, max. 20 mA Max. < 5 mA Max. 45 mA General Specifications Indication for Output ON Power supply Environment Degree of protection Pollution degree Operating temperature Storage temperature Approvals CE-marking 150 250 160 260 724 724 724 724 Overvoltage cat. II (IEC 60664) 230 VAC ± 15% 115 VAC ± 15% 24 VAC ± 15% ≥ 2.0 kVAC (rms) 4 kV (1.2/50 µs) (line/neutral) Power supply DC-types Installation cat. II (IEC 60664) Rated operational voltage 724 24 VDC ±15% (pin 2 pos.) Rated insulation voltage None Rated transient protection volt. 800 V (1.2/50 µs) LED, red LED, green (only SV 150/250) IP 20 B 3 (IEC 60664) -20° to +50°C (-4° to +122°F) -50° to +85°C (-58° to +185°F) UL, CSA Yes Specifications are subject to change without notice (11.06.03) 1 SV 150/250, SV 160/260 Output Specifications Output Rated insulation voltage Contact ratings (Ag-CdO) Resistive loads AC 1 DC 1 or AC 15 DC 13 Small inductive loads Mechanical life Electrical life Operation frequency Insulation voltages Rated insulation voltage AC DC AC Rated impulse withstand voltage DC SV150/SV160 SV250/SV260 SPDT relay 250 VAC (rms) (cont./elec.) µ (micro gap) 10 A/250 VAC (2500 VAC) 1 A/250 VAC (250 W) 10 A/25 VDC (250 W) 2.5 A/230 VAC 5 A/24 VDC ≥ 5 x 107 operations ≥105 operations ≤ 7200 operations/h DPDT relay 250 VAC (rms) (Cont./elec., cont./cont.) µ (micro gap) 8 A/250 VAC (200 VA) 0,4 A/250 VDC (100 W) 4 A/25 VDC (100 W) 2.5 A/230 VAC 5 A/24 VDC ≥ 5 x 107 operations ≥105 operations ≤ 7200 operations/h ≥ 2.0 kVAC (rms) (cont./elect.) None 4 kV (1.2/50 µs) (cont./elect.) (IEC 60664) 800 V ≥ 2.0 kVAC (rms) (cont./elect.) None 4 kV (1.2/50 µs) (cont./elect.) (IEC 60664) 800 V Mode of Operation Max. and/or min. control of solid, fluid or granulated substances, e.g. sand, gravel, sugar or chemicals. SV 150/250: Relay control of DISCHARGING SV 160/260: Relay control of CHARGING Example 1 The diagram shows the level control connected as max. and min. control, i.e. registration of 2 levels during charging (discharging). The relay releases (operates) when the max. sensor is in contact with the substance, provided that the min. sensor is immersed. The relay operates (releases) when the min. sensor is no longer in contact with the substance. of 1 level during charging (discharging). The relay releases (operates) when the sensor is in contact with the substance. Example 1 The diagram shows the level control connected as max. or min. control, i.e. registration Wiring Diagrams Example 1: Two levels max./min. 6 5 8 3 9 7 4 8 9 3 10 2 1 11 Power supply 2 Max. 10 2 6 5 7 4 1 Example 2: One level Min. 11 Min. or max. Power supply Specifications are subject to change without notice (11.06.03) SV 150/250, SV 160/260 Operation Diagrams SV 150/250 DISCHARGING SV 160/260 CHARGING Example 1 Example 1 Power supply Power supply Max. Max. Min. Min. Relay on Relay on Example 2 Example 2 Power supply Power supply Max./Min. Max./Min. Relay on Relay on Accessories Sensors: Types VR and VRY Bases Hold down spring Base covers Front mounting bezel Optical: VP Capacitive: DR, EC Specifications are subject to change without notice (11.06.03) 3
SV250115 价格&库存
很抱歉,暂时无法提供与“SV250115”相匹配的价格&库存,您可以联系我们找货
