DD2503
Evaluation unit for speed monitoring
MONITOR/FR-1 /110-240VAC/DC
1
2
3
OLED display
programming buttons
LEDs
Product characteristics
Housing
housing for DIN rail mounting
Dimensions
[mm]
78 x 45 x 124.7
Application
pulse evaluation system with microprocessor for frequency;
rotational speed; speed; pulses and machine cycles
Application
Electrical data
Nominal voltage AC
[V]
110...240
Nominal voltage DC
[V]
27
Nominal voltage tolerance
< 10
Nominal voltage tolerance 2
20...10
Nominal frequency AC
[Hz]
50...60
Power consumption
[W]
3
Auxiliary energy for sensors
DC
[V]
19.6...27.7; (SELV, ≤ 15 mA)
Inputs / outputs
Number of inputs and outputs
Number of analogue outputs: 1; Number of relay outputs: 2
Outputs
2
Contact rating
6 A (250 V AC); B300, R300
Analogue current output
Max. load
1
[mA]
4...20
[Ω]
500
[Hz]
0.1...1000
[Imp/min]
1...60000
Measuring/setting range
Setting range Hz
Setting range
ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — DD2503-00 — 13.05.2015 —
DD2503
Operating conditions
Ambient temperature
[°C]
-40...60
Storage temperature
[°C]
-40...85
Max. relative air humidity
80; (40 °C: 50 %)
Protection
IP 50
Protection rating terminals
IP 20
Tests / approvals
EN 61010
2011
EMV 89/336/EWG
EMC
MTTF
EN 61000-6-2
2005
EN 61000-6-4
2007
[years]
152
Mechanical data
Weight
[g]
381.5
Housing
Dimensions
[mm]
78 x 45 x 124.7
Materials
plastics
Displays / operating elements
OLED display, 128 x 64 pixels luminous
Display
switching status
LED, green
Remarks
Remarks
The unit complies with overvoltage category II; degree of soiling 2
DD2503
Electrical connection
dual-chamber terminals: 2 x ...2.5 mm²; AWG 14
1
DC supply voltage (L-)
2
DC supply voltage (L+)
3
current supply transistor outputs (L+)
4
sensor signal pnp
5
DC Sensor supply (L+)
6
DC Sensor supply (L-)
7
AC supply voltage (L)
8
AC supply voltage (N)
9
not used
10
sensor signal npn
11
not used
12
not used
13
relay 1 common
14
relay 1 normally open
15
relay 1 normally closed
16
transistor output 1 pnp
17
reset 1 pnp
18
reset 2 pnp
19
relay 2 common
relay 2 normally open
21
relay 2 normally closed
22
analogue output (+)
23
analogue output (-)
24
transistor output 2 pnp
很抱歉,暂时无法提供与“DD2503”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3680.681101+475.51530
