OO5003
OO5003
    IFM(易福门)
    FIBRE-OPTIC AMPLIFIER; FIBRE OPT
OO5003 数据手册
OO5003 Fibre-optic amplifier OOF-FPKG/M16/KL8 1 mounting on DIN rail Product characteristics Type of light red light Housing Dimensions rectangular [mm] 76.5 x 105.4 x 70.7 Application Special feature Function check output Electrical data Operating voltage [V] 12...36 DC Current consumption [mA] 50; ((24 V)) Max. power consumption [VA] 1.3 Protection class III Reverse polarity protection yes Type of light Wave length red light [nm] 630 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OO5003-01 — 27.11.2008 — OO5003 Fibre-optic amplifier OOF-FPKG/M16/KL8 Outputs Electrical design PNP Output function light-on/dark-on mode; (programmable) Max. voltage drop switching output DC [V] 2 Function check output yes Max. current load for function [mA] check output 200 Permanent current rating of switching output DC [mA] 200 Switching frequency DC [Hz] 800 Notes on switching frequency typical Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Time function [s] 0.001...0.1 Range [m] < 3.8; (Through-beam sensor) Range [mm] Detection zone 0...300; (Diffuse reflection sensor) Range adjustable yes Software / programming Parameter setting options automatic and manual switch point setting; logic functions AND, OR; second switch point Operating conditions Ambient temperature [°C] -20...60 Protection IP 65 Tests / approvals EN 60947-5-2 EMC EN 55011 class B Mechanical data Weight [g] 556.5 Housing Dimensions rectangular [mm] 76.5 x 105.4 x 70.7 Number of channels 8 Fibre optic connection Materials FE-11 / FT-11 housing: ABS; display window: PMMA; LED window: SEPS; cover: diecast zinc plastic coated (PA) Lens alignment side lens Displays / operating elements full graphic LCD display, rotation of the display by 180° possible language selection (German, English, French) Display switching status Electronic lock 8 x LED, yellow yes Accessories Items supplied rail: 1 x 94 mm, EN 60715 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OO5003-01 — 27.11.2008 — OO5003 Fibre-optic amplifier OOF-FPKG/M16/KL8 Remarks Remarks operating voltage "supply class 2" according to cULus Pack quantity 1 pcs. Electrical connection Connector: 1 x M16 Connection O Function check output ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — OO5003-01 — 27.11.2008 —
OO5003 价格&库存
很抱歉,暂时无法提供与“OO5003”相匹配的价格&库存,您可以联系我们找货
