SD210115
SD210115
    CARLOGAVAZZI
    Box
    SENSOR PROX INDUCTIVE IP20 BOX
SD210115 数据手册
Proximity Sensors Inductive Namur Amplifier Relays Types SD 110, SD 210, SD 170, SD 270 • According to DIN 19 234 • SD 110/210: Amplifier with relay output • SD 170/270: Set/reset amplifier with relay output for 2 proximity switches • Power supply to proximity switch 8.2 VDC/1 kΩ • Galvanically separated output relay • Load: 10 A SPDT or 8 A DPDT relay • LED-indication for output ON • AC or DC power supply Product Description Ordering Key Namur amplifier relay for inductive or capacitive Namur proximity switches. Single amplifier, set-reset functions. Housing Output type Power supply Short circuit and cable failure monitoring. Mounting socket type S 411. SD 110 024 Type Selection Namur Amplifier Relay Plug Supply 10 A SPDT relay 8 A DPDT relay Set-reset Amplifier for 2 Namur Proximity Switches 10 A SPDT relay 8 A DPDT relay Circular 24 VAC 115 VAC 230 VAC 24 VDC SD 110 024 SD 110 115 SD 110 230 SD 110 724 SD 210 024 SD 210 115 SD 210 230 SD 210 724 SD 170 024 SD 170 115 SD 170 230 SD 170 724 Input Specifications Inputs Proximity switch voltage Proximity switch current - activated - not activated Internal resistance Operating frequency Pulse time Connection cable - max. resistance Output Specifications SD110, SD210 SD170, SD270 1 8.2 VDC 2 8.2 VDC ≤ 1.2 mA ≥ 2.1 mA 1 kΩ 10 Hz ≥ 20 ms Unshielded 50 Ω ≤ 1.2 mA ≥ 2.1 mA 1 kΩ 10 Hz ≥ 20 ms Unshielded 50 Ω Specifications are subject to change without notice SD 270 024 SD 270 115 SD 270 230 SD 270 724 SD110, SD170 Output Rated insulation voltage SD210, SD270 SPDT relay 250 VAC (rms) (cont./elec.) DPDT relay 250 VAC (rms) (cont./elec., cont./cont.) Contact ratings (AgCdO) µ (micro gap) µ (micro gap) Resistive loads AC1 10 A/250 VAC 8 A/250 VAC (2500 VA) (2000 VA) DC1 1 A/250 VDC 0.4 A/250 VDC (250 W) (100 W) or 10 A/25 VDC 4 A/25 VDC (250 W) (100 W) Small inductive loads AC15 2.5 A/230 VAC 2.5 A/230 VAC DC13 5 A/24 VDC 5 A/24 VDC Mechanical life ≥ 30 x 106 op. ≥ 30 x 106 op. Electrical life AC 1 ≥ 2.5 x 105 op. ≥ 2.5 x 105 op. (at max. load) Operating frequency ≤ 7200 op./h ≤ 7200 op./h Dielectric strength 2 kVAC (rms) Dielectric voltage 2 kVAC (rms) (cont./elec.) (cont./elec.) Rated impulse withstand voltage 4 kV (1.2/50 µs) 4 kV (1.2/50 µs) (cont./elec.) (cont./elec.) (IEC 60664) (IEC 60664) 1 SD 110, SD 210, SD 170, SD 270 Supply Specifications General Specifications Power supply AC types Rated operational volt. 230 Through pins 2 & 10 115 024 Voltage interruption Dielectric voltage Rated impulse withstand volt. Power supply DC types Rated operational volt. 724 Dielectric voltage Rated impulse withstand volt. Rated operational power AC supply DC supply Indication for Output ON Environment Degree of protection Pollution degree Operating temperature Storage temperature Weight AC types DC types Overvoltage cat. III (IEC 60664) 230 VAC ± 15%, 50 to 60 Hz 115 VAC ± 15%, 50 to 60 Hz 24 VAC ± 15%, 50 to 60 Hz ≤ 40 ms ≥ 2 kVAC (rms) (supply/elec.) 2 kV (1.2/50 µs) (line/neutral) Overvoltage cat. III (IEC 60664) 24 VDC ± 15% None 800 V (1.2/50 µs) LED, red IP 20 B 2 (IEC 60664) -20° to +50°C (-4° to +122°F) -50° to +85°C (-58° to +185°F) 200 g 125 g Wiring Diagrams 2.5 VA 1.5 W Mode of Operation SD x10 Example 1 The relay operates when the proximity switch is activated. The relay releases automatically in case of interruption or short-circuit of proximity switch or cable. Example 2 The relay operates when the proximity switch is inactive or the cable is interrupted. The relay operates in case of short-circuit of proximity switch or cable. SD x70 The set-reset relays SD 170/270 are used with 2 proximity switches in the following way: The relay operates when proximity switch S1 is activated momentarily and subsequently remains on. When proximity switch S2 is activated momentarily or the power supply is interrupted, the relay releases. Power supply SD 110/210 Power supply SD 110/210 Example 1 Power supply SD 170/270 Example 2 Dimensions If both proximity switches are activated at the same time, S2 has priority and the relay therefore releases. Accessories Socket◊ Hold down spring◊ Mounting rack Socket cover Front mounting bezel S 411 HF SM 13 BB 4 FRS 2 Operation Diagrams SD x10 Power supply Proximity switch Cable breakdown Example 1: Relay Example 2: Relay SD x70 Power supply Proximity switch S1 Proximity switch S2 Relay 2 Specifications are subject to change without notice
SD210115 价格&库存
很抱歉,暂时无法提供与“SD210115”相匹配的价格&库存,您可以联系我们找货
