DF-G3-PI-Q5
DF-G3-PI-Q5
    BANNER(邦纳)
    FIBER AMPLIFIER 1 PNP OUT
DF-G3-PI-Q5 数据手册
DF-G3 Long Range Expert™ Dual Display Fiber Amplifier with Analog Output Quick Start Guide Advanced sensor with dual digital displays for use with plastic and glass fiber optic assemblies; analog current or voltage output models with an independent NPN or PNP discrete output are available. This guide is designed to help you set up and install the DF-G3 Long Range Expert Dual Display Fiber Amplifier with Analog Output. For complete information on programming, performance, troubleshooting, dimensions, and accessories, please refer to the Instruction Manual at www.bannerengineering.com. Search for p/n 190341 to view the Instruction Manual. Use of this document assumes familiarity with pertinent industry standards and practices. WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or deenergized (off) output condition. Overview Figure 1. DF-G3 Dual Output Analog with Discrete Output 1 Analog and Discrete Output LEDs 2 CH1/CH2 Switch 3 RUN/PRG/ADJ Mode Switch 4 Lever Action Fiber Clamp 5 Red Signal Level 6 Green CH1 Analog Output Signal or CH2 Threshold 7 +/SET/- Rocker Button Models Model Sensing Beam Color Reference Sensing Range 1 DF-G3-NU-2M DF-G3-PU-2M DF-G3-NI-2M Outputs Voltage and NPN Discrete Visible red, 635 nm 3000 mm Voltage and PNP Discrete Current and NPN Discrete DF-G3-PI-2M Current and PNP Discrete DF-G3IR-NU-2M Voltage and NPN Discrete DF-G3IR-PU-2M DF-G3IR-NI-2M Connector 2 Infrared, 850 nm 6000 mm DF-G3IR-PI-2M Voltage and PNP Discrete Current and NPN Discrete 2 m (6.5 ft) cable, 5-wire 2 m (6.5 ft) cable, 5-wire Current and PNP Discrete Water Detection Models DF-G3LIR-NU-2M DF-G3LIR-PU-2M DF-G3LIR-NI-2M Voltage and NPN Discrete Long infrared, 1450 nm 900 mm DF-G3LIR-PI-2M Voltage and PNP Discrete Current and NPN Discrete 2 m (6.5 ft) cable, 5-wire Current and PNP Discrete 1 Excess gain = 1 (high sensitivity), opposed mode sensing. PIT46U plastic fiber used for visible models, IT.83.3ST5M6 glass fiber used for IR models. 2 Connector options: • A model with a QD connector requires a mating cordset (see Instruction Manual) • For 9 m (29.5 ft) cable, change the suffix 2M to 9M in the 2 m model number (DF-G3-NS-9M) • For 150 mm (6 in) PVC cable with a M8/Pico-style QD model, change the suffix 2M to Q3 in the 2 m model number (DF-G3-NS-Q3) • For 150 mm (6 in) PVC cable with a M12/Euro-style model, change the suffix 2M to Q5 in the 2 m model number (DF-G3-NS-Q5) • For integral M8/Pico-style model, change the suffix 2M to Q7in the 2 m model number (DF-G3-NS-Q7) • For Q3 and Q7 Dual Output models, use a 5-pin M8/Pico-style or a 6-pin M8/Pico-style mating cordset Original Document 190340 Rev. C 10 September 2021 190340 DF-G3 Long Range Expert™ Dual Display Fiber Amplifier with Analog Output Installation Instructions Mounting Instructions Mount on a DIN Rail 1. Hook the DIN rail clip on the bottom of the DF-G3 over the edge of the DIN rail (1). 2. Push the DF-G3 up on the DIN rail (1). 3. Pivot the DF-G3 onto the DIN rail, pressing until it snaps into place (2). Mount to the Accessory Bracket (SA-DIN-BRACKET) 1. Position the DF-G3 in the SA-DIN-BRACKET. 2. Insert the supplied M3 screws. 3. Tighten the screws. Remove from a DIN rail 1. Push the DF-G3 up on the DIN rail (1). 2. Pivot the DF-G3 away from the DIN rail and remove it (2). Installing the Fibers in a DF-Gx Sensor Follow these steps to install glass or plastic fibers. 1. 2. 3. 4. 5. Open the dust cover. Move the fiber clamp forward to unlock it. Insert the fiber(s) into the fiber port(s) until they stop. Move the fiber clamp backward to lock the fiber(s). Close the dust cover. Move forward to release the fibers Fiber Clamp Fiber Receiver Port Fiber Emitter Port Note: For optimum performance of IR models, if applicable, glass fibers must be used. Fiber Adapters Note: If a thin fiber with less than 2.2 mm outer diameter is used, install the fiber adapter provided with the fiber assembly to ensure a reliable fit in the fiber holder. Align the fibers to the end of the adaptors. Banner includes the adapters with all fiber assemblies. 2 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 190340 Rev. C DF-G3 Long Range Expert™ Dual Display Fiber Amplifier with Analog Output TO FIBERS TO SENSOR Fiber Outer Diameter (mm) Adapter Color Ø 1.0 Black Ø 1.3 Red Ø 2.2 No adapter needed When connecting coaxial-type fiber assemblies to the amplifier, install the single-core (center) fiber to the Transmitter port, and the multi-core (outer) fiber to the Receiver port. This will result in the most reliable detection. RECEIVER Multi-core fiber Single-core fiber TRANSMITTER Wiring Diagrams NPN Models 1 + 4 1 10-30V dc (Current Models) 12-30V dc (Voltage Models) 3 2 PNP Models – Load Load 5 2 D_Out 4 Input Wire + 10-30V dc (Current Models) 12-30V dc (Voltage Models) 3 A_Out 5 Key – Load Load A_Out D_Out 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray (6 = no connection) Input Wire Note: Open lead wires must be connected to a terminal block. Note: When using multiple sensors in Master/Slave mode, the gray wires from each sensor should be connected together. The remote programming function cannot be used. Top Panel Interface Opening the dust cover provides access to the top panel interface. The top panel interface consists of the RUN/PRG/ADJ mode switch, CH1/CH2 switch, +/SET/- rocker button, dual red/green digital displays, and output LED(s). RUN/PRG/ADJ Mode Switch The RUN/PRG/ADJ mode switch puts the sensor in RUN, PRG (Program), or ADJ (Adjust) mode. • RUN mode allows the sensor to operate normally and prevents unintentional programming changes via the +/SET/- rocker button. • PRG mode allows the sensor to be programmed through the display-driven programming menu (see Program Mode). • ADJ mode allows the user to perform Expert TEACH/SET methods and Manual Adjust (see Adjust Mode on p. 6). P/N 190340 Rev. C www.bannerengineering.com - Tel: + 1 888 373 6767 3 DF-G3 Long Range Expert™ Dual Display Fiber Amplifier with Analog Output CH1/CH2 Switch The CH1/CH2 switch selects which output's parameters can be accessed and changed in the interface of the display. • CH1 selects the Analog Output • CH2 selects the Discrete Output +/SET/- Rocker Button The +/SET/- rocker button is a 3-way button. The +/- positions are engaged by rocking the button left/right. The SET position is engaged by clicking down the button while the rocker is in the middle position. All three button positions are used during PRG mode to navigate the display-driven programming menu. In ADJ mode, SET is used to perform TEACH/SET methods and +/- are used to manually adjust the threshold(s). In CH1 RUN mode, the rocker button is used to view the analog endpoints and midpoint signal values. The rocker button is disabled during CH2 RUN mode, except when using Window SET (see Window SET). Red/Green Digital Displays During RUN and ADJ modes, the Red display shows the signal level, and the Green display shows the analog output in volts or milliamps when CH1 is selected or the threshold when CH2 is selected. During PRG mode, both displays are used to navigate the display-driven programming menu. Dual Output LEDs The output LEDs provide a visible indication of when the associated output is active. • 1 represents the Channel 1 analog output. When on, it indicates that the signal is within the analog range. • 2 represents the Channel 2 discrete output. When on, it indicates that the output is conducting. Operating Instructions Remote Input For more information about how to perform TEACH/SET methods and to program the sensor remotely, see www.bannerengineering.com and search 190341. Run Mode Run mode allows the sensor to operate normally and prevents unintentional programming changes. In CH1 RUN mode, the +/SET/rocker button is used to view the analog endpoints and midpoint signal values. The rocker button is disabled during CH2 RUN mode, except when using Window SET (see Window SET on p. 8). 4 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 190340 Rev. C P/N 190340 Rev. C Return to Menu List Note: The CH1 settings programmed for rESP SPd, inPt SEL, diSP rEAd and GAin SEL also apply to CH2. www.bannerengineering.com - Tel: + 1 888 373 6767 Menu available in 1Pt SEt only Auto GAin to set value diSP 1234 GAin SEL (+) or (-) diSP rEAd DISPLAY LOOP Click SET to enter choice list to set value to set value on display represents a “w” (display flips 180˚) DISPLAY LOOP Click SET to enter choice list on display represents a “m” Click SET to select and save a choice in any list (+) or (-) to set value DISPLAY LOOP Click SET to enter choice list default setting Click SET to enter choice list DISPLAY LOOP oFF DISPLAY LOOP 1 inPt SEL DISPLAY LOOP FLtr CntS DISPLAY LOOP 0 to 10 V DISPLAY LOOP AOut RnGE Click SET to enter choice list POS Click SET to enter choice list 10 Pct AOut SLPE Click SET to enter choice list OFSt Pct1 Click SET to enter choice list rocker button 2 ms Menu List 2-pt tch rESP SPd Fixed Gain Set DISPLAY LOOP Click SET to enter choice list DISPLAY LOOP Click SET to enter choice list To scroll through menu lists: Press “+” or “-” To enter a choice list or to select and save: Click SET To exit a choice list without saving: Press and hold SET for 2 seconds tch SEL1 Press and hold SET to exit choice list without saving Channel 1 Analog Menu Program (PRG) mode allows the following settings to be programmed in the DF-G3. CH1 Analog Factory Default Settings: Mode Switch to “PRG” PROGRAM MODE DF-G3 Long Range Expert™ Dual Display Fiber Amplifier with Analog Output Program Mode 5 on display represents a “m” Return to Menu List on display represents a “w” (+) or (-) to set value (+) or (-) to set value Click SET to select and save a choice in any list Click SET Available in Lt, dr or wind set only Not available in CAL Set (+) or (-) to set value DISPLAY LOOP DISPLAY LOOP DISPLAY LOOP DISPLAY LOOP DISPLAY LOOP Click SET (+) or (-) to set value (+) or (-) to set value Click SET Click SET DISPLAY LOOP Click SET to enter choice list (+) or (-) to set value Menu List Switch Mode to “PRG” PROGRAM MODE (+) or (-) to set value Std Click SET oFF SEnS SEL2 Click SET dLY SEL2 Click SET to enter choice list oFF Click SET to enter choice list 10 pct Auto thr2 Click SET to enter choice list OFSt Pct2 Click SET to enter choice list 2-pt tch Click SET to enter choice list LO rocker button Out SEL2 tch SEL2 setting-specific CH2 Discrete Factory Default Settings: default setting Channel 2 Discrete Menu Program (PRG) mode allows the following settings to be programmed in the DF-G3. When CH2 is selected in Program mode, the settings below can be configured for CH2 discrete output and are independent from CH1 settings. To scroll through menu lists: Press “+” or “-” To enter a choice list or to select and save: Click SET To exit a choice list without saving: Press and hold SET for 2 seconds DF-G3 Long Range Expert™ Dual Display Fiber Amplifier with Analog Output Press and hold SET to exit choice list without saving Adjust Mode Sliding the RUN/PRG/ADJ mode switch to the ADJ position allows the user to perform Expert TEACH/SET methods and Manual Adjustment of the threshold and the midpoint or endpoints of the analog output depending on whether a 1-point SET or 2-point TEACH was used. Note: For threshold and analog endpoints, when teaching CH2, the gain setting will be the same as the gain setting made during the CH1 teach. Reteaching CH1 may invalidate the previous CH2 teach. TEACH Procedures The instruction manual has detailed instructions for these TEACH modes: CH1 Analog • • 6 Two-Point TEACH One-Point SET CH2 Discrete • • • • • • Two-Point TEACH Dynamic TEACH Window SET Light SET Dark SET Calibration SET www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 190340 Rev. C DF-G3 Long Range Expert™ Dual Display Fiber Amplifier with Analog Output CH1 Analog Output Two-Point TEACH • Establishes defined endpoints for the analog output range • Analog endpoints can be adjusted by using the "+" and "-" rocker button (Manual Adjust) Two-Point TEACH is used when two conditions can be presented statically to the sensor. The first taught condition is set to 0 V (4 mA), and the second taught condition to 10 V (20 mA). The order of the taught points determines the slope. If the first taught condition is darker, the slope will be positive. If the first taught condition is lighter, the slope will be negative. Reverse the slope of the analog output by changing the AOut SLPE menu setting. Note: Depending on the application configuration and fibers used, the analog function may or may not behave linearly. The received light intensity will be dictated by the inverse square properties of light. Figure 2. Two-Point TEACH (Light Operate shown) Current-Sourcing Models Voltage-Sourcing Models 20 mA 10V dc LO Slope DO Slope 4 mA 0V dc Dark Light Signal One-Point SET • Defines the 5 V (12 mA) midpoint of the analog output • Analog midpoint can be adjusted by using the "+" and "-" rocker button (Manual Adjust) A single sensing condition is presented, and the sensor positions the midpoint of its analog range (5 V or 12 mA) exactly at the presented condition. The size of the window is determined by the OFSt Pct1 menu setting. The slope of the analog output is determined by the AOut SLPE setting. Figure 3. One-Point SET (Light Operate shown) Voltage-Sourcing Models Current-Sourcing Models 20 mA 10V dc LO Slope 12 mA Single Point Taught 5V dc DO Slope 4 mA 0V dc - OFSt Pct1 + OFSt Pct1 Signal CH2 Discrete Output Two-Point TEACH • Establishes a single switching threshold • Threshold can be adjusted by using the "+" and "-" rocker button (Manual Adjust) Two-Point TEACH is used when two conditions can be presented statically to the sensor. The sensor locates a single sensing threshold (the switch point) midway between the two taught conditions, with the Output ON condition on one side, and the Output OFF condition on the other. P/N 190340 Rev. C www.bannerengineering.com - Tel: + 1 888 373 6767 7 DF-G3 Long Range Expert™ Dual Display Fiber Amplifier with Analog Output Figure 4. Two-Point TEACH (Light Operate shown) Darkest Taught Condition Lightest Taught Condition Sensor positions threshold midway between taught conditions Output OFF Darkest (no signal) Output ON Position adjusted by Manual Adjust Most Light (saturated signal) The Output ON and OFF conditions can be reversed by using the LO/DO (Light Operate/ Dark Operate) switch or through the program interface for the dual output model. Dynamic TEACH • • • Teaches on-the-fly Establishes a single switching threshold Threshold can be adjusted using "+" and "-" rocker button (Manual Adjust) Dynamic TEACH is best used when a machine or process may not be stopped for teaching. The sensor learns during actual sensing conditions, taking multiple samples of the light and dark conditions and automatically setting the threshold at the optimum level. Figure 5. Dynamic TEACH (Light Operate shown) Darkest Taught Condition Lightest Taught Condition Sensor positions threshold midway between taught conditions Output OFF Darkest (no signal) Output ON Position adjusted by Manual Adjust Most Light (saturated signal) Reverse the CH2 Output ON and OFF conditions by using the LO/DO (Light Operate/ Dark Operate) selection through the program interface. Window SET • • • • Sets window thresholds that extend a programmable % offset above and below the presented condition All other conditions (lighter or darker) cause the output to change state Sensing window center can be adjusted using "+" and "-" rocker button (Manual Adjust) Recommended for applications where a product may not always appear in the same place, or when other signals may appear • See Program Mode for programming the Offset Percent setting A single sensing condition is presented, and the sensor positions window thresholds a programmable % offset above and below the presented condition. In LO mode, Window SET designates a sensing window with the Output ON condition inside the window, and the Output OFF conditions outside the window. Figure 6. Window SET (Light Operate shown) Sensing window center adjusted by Manual Adjust Output OFF Darkest (no signal) 8 Output ON Condition Presented Sensor positions window thresholds a programmable % offset from the presented condition Output OFF Most Light (saturated signal) www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 190340 Rev. C DF-G3 Long Range Expert™ Dual Display Fiber Amplifier with Analog Output Reverse the Output ON and OFF conditions by using the LO/DO (Light Operate/ Dark Operate) selection through the program interface for the dual output model. Light SET • • • • • Sets a threshold a programmable % offset below the presented condition Changes output state on any condition darker than the threshold condition Threshold can be adjusted using "+" and "-" rocker button (Manual Adjust) Recommended for applications where only one condition is known, for example a stable light background with varying darker targets See Program Mode for programming the Offset Percent setting A single sensing condition is presented, and the sensor positions a threshold a programmable % offset below the presented condition. When a condition darker than the threshold is sensed, the output either turns ON or OFF, depending on the LO/DO setting. Figure 7. Light SET (Light Operate shown) Threshold position adjusted by Manual Adjust Sensor positions threshold a programmable % offset below the presented condition Output OFF Output ON Condition Presented Darkest (no signal) Most Light (saturated signal) Dark SET • • • • • Sets a threshold a programmable % offset above the presented condition Any condition lighter than the threshold condition causes the output to change state Threshold can be adjusted using "+" and "-" rocker button (Manual Adjust) Recommended for applications where only one condition is known, for example a stable dark background with varying lighter targets See Program Mode for programming the Offset Percent setting Note: Offset Percent MUST be programmed to Minimum Offset to accept conditions of no signal (0 counts). A single sensing condition is presented, and the sensor positions a threshold a programmable % offset above the presented condition. When a condition lighter than the threshold is sensed, the output either turns ON or OFF, depending on the LO/DO setting. Figure 8. Dark SET (Light Operate shown) Threshold position adjusted by Manual Adjust Sensor positions threshold a programmable % offset above the presented condition Output OFF Darkest (no signal) Condition Presented Output ON Most Light (saturated signal) Calibration SET • Sets a threshold exactly at the presented condition • Threshold can be adjusted using "+" and "-" rocker button (Manual Adjust) A single sensing condition is presented, and the sensor positions a threshold exactly at the presented condition. When a condition lighter than the threshold is sensed, the output either turns ON or OFF, depending on the LO/DO setting. P/N 190340 Rev. C www.bannerengineering.com - Tel: + 1 888 373 6767 9 DF-G3 Long Range Expert™ Dual Display Fiber Amplifier with Analog Output Figure 9. Calibration SET (Light Operate shown) Threshold position adjusted by Manual Adjust Sensor positions threshold exactly at the presented condition Output OFF Output ON Condition Presented Darkest (no signal) Most Light (saturated signal) Specifications Sensing Beam DF-G3: Visible red, 635 nm DF-G3IR: Infrared, 850 nm DF-G3LIR: Long infrared, 1450 nm Supply Voltage Voltage output models: 12 V DC to 30 V DC Class 2 (10% maximum ripple) Current output models: 10 V DC to 30 V DC Class 2 (10% maximum ripple) Power and Current Consumption (exclusive of load) Standard display mode: 840 mW, Current consumption < 35 mA at 24 V DC ECO display mode: 672 mW, Current consumption < 28 mA at 24 V DC Supply Protection Circuitry Protected against reverse polarity, overvoltage, and transient voltages Delay at Power-Up 500 milliseconds maximum; outputs do not conduct during this time Output Configuration Voltage Output Models: 1 analog voltage output (user configurable as 1 V to 5 V or 0 V to 10 V) with 1 NPN or 1 PNP discrete output, depending on model. Current Output Models: 1 analog current output (4 mA to 20 mA) with 1 NPN or 1 PNP discrete output, depending on model Discrete Output Rating 100 mA maximum combined load—analog plus discrete outputs (derate 1 mA per °C above 30 °C) OFF-state leakage current: < 5 µA at 30 V DC ON-state saturation voltage: NPN: < 1.5 V; PNP: < 2 V Analog Output Recovery Time < 2 times the selected response speed Analog Output Ripple Content (p-p) < 0.5% of the full scale analog output Analog Output Rating Voltage Outputs: 2.5 kOhm minimum load resistance Current Outputs: 1 kOhm maximum load resistance at 24 V; maximum load resistance = [(Vcc - 4)/.02] Ohms Output Protection Protected against output short-circuit, continuous overload, transient overvoltages, and false pulse on power-up Response Speed and Features Description Response Speed Repetition Period Repeatability Cross-Talk Avoidance Energy Efficient Light Resistance Maximum Range, Red 3 Maximum Range, IR850 4 High Speed 500 µs 100 µs Fast 1000 µs 100 µs 100 µs No No 1200 mm 2400 mm 150 µs Yes No 1500 mm Standard 2 ms 3000 mm 100 µs 180 µs Yes Yes 1500 mm Long Range 3000 mm 8 ms 100 µs 180 µs Yes Yes 1950 mm Extra Long Range 3900 mm 24 ms 100 µs 180 µs Yes Yes 3000 mm 6000 mm Operating Conditions Temperature: –10 °C to +55 °C (+14 °F to +131 °F) Storage Temperature: –20 °C to +85 °C (–4 °F to +185 °F) Humidity: 50% at +50 °C maximum relative humidity (non-condensing) Environmental Rating IP50, NEMA 1 Connections PVC-jacketed 2 m or 9 m (6.5 ft or 30 ft) 5-wire integral cable; or integral 5-pin M8 quick disconnect; or 150 mm (6 in) cable with a 5-pin M8 quick disconnect; or 150 mm (6 in) cable with a 5-pin M12 quick disconnect For Q3 or Q7 models, either a 5-pin M8 or a 6-pin M8 mating cordset may be used Construction Black ABS/polycarbonate alloy (UL94 V-0 rated) housing, clear polycarbonate cover 3 4 10 Excess gain = 1 (high sensitivity), opposed mode sensing. PIT46U plastic fiber used for visible LED models. Excess gain = 1 (high sensitivity), opposed mode sensing. IT.83.3ST5M6 glass fiber used for IR models. www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 190340 Rev. C DF-G3 Long Range Expert™ Dual Display Fiber Amplifier with Analog Output Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Certifications Industrial Control Equipment 3TJJ Class 2 power Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
DF-G3-PI-Q5 价格&库存
很抱歉,暂时无法提供与“DF-G3-PI-Q5”相匹配的价格&库存,您可以联系我们找货
DF-G3-PI-Q5
  • 1+2820.100211+364.82302
库存:1
