TP9237
TP9237
    IFM(易福门)
    MEASURED SIGNAL CONVERTER FOR TE
TP9237 数据手册
TP9237 Evaluation unit for PT100/PT1000 temperature sensors TP- CEC -B-DVG/US/ 1 2 connection for voltage supply and output signals connection for temperature sensor Product characteristics Number of inputs and outputs Number of analogue outputs: 1 Measuring range -50...300 °C -58...572 °F Application Special feature Gold-plated contacts Application for Pt100 and Pt1000 measuring elements Electrical data Operating voltage [V] 18...32 DC Protection class III Reverse polarity protection Power-on delay time yes [s] 1 Integrated watchdog yes Inputs / outputs Number of inputs and outputs Number of analogue outputs: 1 Outputs Total number of outputs 1 Output signal analogue signal; IO-Link; (configurable) Number of analogue outputs 1 Analogue voltage output [V] 0...10 Min. load resistance [Ω] 2000 Short-circuit protection yes Type of short-circuit protection pulsed Overload protection yes Measuring/setting range Measuring range Factory setting -50...300 °C -58...572 °F 0...100 °C ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — TP9237-00 — 17.01.2011 — TP9237 Evaluation unit for PT100/PT1000 temperature sensors TP- CEC -B-DVG/US/ Accuracy / deviations Precision analogue output [K] ± 0,3 + (± 0,1 % MS) Temperature coefficient [% of the span / 10 K] 0,1 Response times Max. measuring/display cycle [ms] 100 Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 Operating conditions Ambient temperature [°C] -25...70 Storage temperature [°C] -40...85 Protection IP 67 Tests / approvals EMC EN 61326-1 Shock resistance DIN IEC 68-2-27 50 g (11 ms) Vibration resistance DIN IEC 68-2-6 20 g (10...2000 Hz) MTTF [years] 505.11 Mechanical data Weight [g] Dimensions [mm] 40 M12 x 1 Thread designation M12 x 1 Materials PA; PET Sealing material FKM Remarks Remarks Pack quantity operating voltage "supply class 2" according to cULus MS = set measuring span 1 pcs. Electrical connection Connector: 1 x M12; Moulded body: TPU; Locking: stainless steel (1.4404 / 316L); Sealing: FKM; Contacts: gold-plated ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — TP9237-00 — 17.01.2011 — TP9237 Evaluation unit for PT100/PT1000 temperature sensors TP- CEC -B-DVG/US/ Connection 1: two-wire sensor 2: four-wire sensor B: link ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — TP9237-00 — 17.01.2011 —
TP9237 价格&库存
很抱歉,暂时无法提供与“TP9237”相匹配的价格&库存,您可以联系我们找货
TP9237
    • 1+1255.44013
    • 5+1205.24543
    • 10+1155.00909
    库存:9
