ASNT8050-PQB
ASNT8050-PQB
    ADSANTEC(先进科技)
    VFQFN-40
    PROGRAMBL PLL W/ INTEGRATED VCOS
ASNT8050-PQB 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT8050-PQB 7.4-8.8GHz and 10.8-12.7GHz Programmable PLL with integrated VCOs oncml vee vee phs2 phs1 vee vcc clop vcc clon vcc vcc vcc chop vcc chon ASNT8050 vcc vcc lol 1 vee offpll off12g vee ftr2 vcc ftr1 vcc offcho cen off16b vcc vee cep cr16n vcc cr16p Rev. 1.7.2 vcc vcc vcc Programmable clock multiplier (CMU) with two selectable frequency ranges of internal PLL Optional operational mode as a clock divider with PLL disabled Closed-Loop SSB phase noise at 10MHz offset better than 98dB/Hz Selectable internal divider ratio of 8 or 16 On-chip Loss-of-Lock control circuit External RC loop filter LVDS or CML input reference clock interface Full-rate CML clock input and output interfaces LVDS divided clock output with optional 90°-step phase adjustment Exhibits low jitter and limited temperature variation over industrial temperature range Single +3.3V power supply Power consumption: 630mW Fabricated in SiGe for high performance, yield, and reliability Standard MLF/QFN 40-pin package vee               February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION ce HS CIB offpll off12g lol ftr1 ftr2 cr16 oncml off16b PLL /16 LS CIB C ref offcho CPR phs1 phs2 LS COB clo HS COB cho Fig. 1. Functional Block Diagram ASNT8050-PQB is a clock multiplication unit (CMU) with a dual-range phase-locked loop (PLL) incorporating high-speed voltage-controlled oscillators (VCOs). The part features several control functions shown in Table 1. All functions are further described in the specified sections. Table 1. PLL Control Functions Control Logic State Described signal in “0” Not connected (default) “1” Higher VCO range Same as “0” state Lower VCO range PLL off12g HS COB enabled Same as “0” state HS COB disabled HS COB offcho See Table 4 CPR phs1/phs2 Clock division ratio of 16 Same as “0” state Clock division ratio of 8 PLL, CPR off16b PLL enabled Same as “0” state PLL disabled PLL offpll LVDS input interface Same as “0” state CML input interface LS CIB oncml One of the two frequency ranges can be selected by the control signal off12g. In the main operational mode, the IC shown in Fig. 1 accepts a low-speed reference clock cr16p/cr16n with the frequency f/8 or f/16 and converts it into a high-speed output clock cho with the frequency f and the low-speed output clock clo with the corresponding frequency f/8 or f/16. The frequency of the reference and output clocks is defined by the settings of the control signal off16b. The high-speed clock output buffer can be enabled/disabled by the control signal offcho. One of four 90° shifted phases of the low-speed output clock with the frequency f/16 can be selected by control signals phs1 and phs2. This phase selection is not available for the output clock with the frequency f/8. When operating in the closed-loop mode, the PLL requires an external loop filter connected to pins ftr1 and ftr2. The output signal lol indicates the locked or unlocked state of the PLL. The PLL also supports an open-loop mode of operation with its selected VCO controlled externally by voltages applied to the filter pins ftr1 and ftr2. Rev. 1.7.2 2 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com The chip can operate as a divider of the input high-speed clock cep/cen if the PLL is disabled by the control signal offpll. The division ratio of 8 or 16 can be selected by the control signal off16b. The IC uses a single +3.3V power supply and is characterized for operation from −25°C to 125°C of junction temperature. HS CIB The High-Speed Clock Input Buffer (HS CIB) can process an external clock signal cep/cen with frequencies from DC to the specified maximum value. The clock inputs support the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination. In the DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in ELECTRICAL CHARACTERISTICS. In the AC-coupling mode, the input termination provides the required common mode voltage automatically. The differential DC signaling mode is recommended for optimal performance. LS CIB The Low-Speed Clock Input Buffer (LS CIB) is a proprietary universal input buffer (UIB) that can run at a high frequency. The UIB’s input termination impedance is controlled by the CMOS signal oncml and is set to 100Ohm differential if oncml=”0” (true LVDS mode, default state) or 50Ohm single-ended to vcc if oncml=”1” (CML mode). Possible input clock application schemes are detailed in Table 2, where Vcm is the common-mode voltage of the input clock signal. Table 2. LS Input Clock Application Schemes Interface type LVDS (oncml =”0”) CML (oncml =”1”) Clock cr16p signal type Swing, mV Connection Vcm, V Diff. 70-to-500 DC 1.2±1.0 SE 140-to-900 AC Threshold DC vee-to-vcc Diff. 70-to-500 DC vcc -Swing/2 AC SE 140-to-900 AC 140-to-900 AC Not connected Threshold DC vcc cr16n signal Swing, mV Connection Vcm, V 70-to-500 DC 1.2±1.0 Threshold DC vee-to-vcc 140-to-900 AC 70-to-500 DC vcc-Swing/2 AC Not connected Threshold DC vcc 140-to-900 AC 140-to-900 AC - As can be seen, the UIB is designed to accept differential signals with DC common mode voltages between the negative (vee) and the positive (vcc) supply rails, as well as AC common mode noise with a frequency up to 5MHz and voltage levels from vee to vee+2.4V. It can also receive single-ended signals with a threshold voltage between vee and vcc applied to the unused pin of the differential input interface. PLL The PLL contains a phase frequency detector, a charge pump, an on-chip integrator with an additional offchip filter connected between pins ftr1 and ftr2, and two selectable LC-tank VCOs with different central frequencies. The recommended parameters of the external filter schematic components shown in Fig. 2 are for reference only and can be modified based on specific requirements. Rev. 1.7.2 3 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Fig. 2. Recommended External Filter Schematic The PLL is activated by the external control signal offpll=”0”. In case of offpll=”1” (default state), the PLL is disabled and the chip operates as a divider by 8 or 16. The division ratio is defined by the CMOS control signal off16b (division by 8 if off16b=”1”; division by 16 if off16b=”0”, default state). The main function of the PLL is to synthesize the full-rate clock C by aligning the phase and frequency of the divided clock from the internal divider to the externally applied reference clock cr16. Selection of the required VCO is defined by the CMOS control signal off12g (lower-speed VCO if off12g=”1”; higherspeed VCO if off12g=”0”, default state). The frequency of the required reference clock is defined by the CMOS control signal off16b (divided-by-8 if off16b=”1”; divided-by-16 if off16b=”0”, default state). The state of the PLL is indicated by the output CMOS loss-of-lock alarm signal lol (lol=”1” if PLL is not locked, lol=”0” if phases and frequencies of internal and reference clocks are matching). If required, the selected VCO can be externally controlled by voltages applied to the pins ftr1 and ftr2 as shown in Table 3. In this case, the PLL is operating in the open-loop mode. The unused VCO is completely disabled to save power. Table 3. VCO External Control Modes ftr1 signal, V Vccm+0.8=3.1 Vccm-0.8=1.5 Vccm=2.3 Vccm=2.3 ftr2 signal, V VCO frequency Vccm=2.3 min Vccm=2.3 max Vccm+0.8=3.1 max Vccm-0.8=1.5 min Divider-by-16 The Divider-by-16 (/16) includes 4 divide-by-2 circuits connected in series. The clocks divided by 8 and 16 are supplied to the PLL’s phase detector and to the clock processor CPR. CPR The clock processor (CPR) receives divided clocks from the divider and supplies the selected clock to the low-speed clock output buffer. The type of the clock is defined by the CMOS control signal off16b (divided-by-8 if off16b=”1”; divided-by-16 if off16b=”0”, default state). The phase of the divided-by-16 clock C16 can be altered utilizing the CMOS control pins phs1 and phs2 as shown in Table 4. Table 4. Output Clock Phase Selection phs1 phs2 C16 phase vee (default) vee (default) 0° 90° vee vcc 180° vcc vee 270° vcc vcc Rev. 1.7.2 4 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com HS COB The High Speed Clock Output Buffer (HS COB) receives the high-speed clock from the PLL and converts it into the CML output signal cho. The buffer can be enabled or disabled by the external CMOS control signal offcho (disabled if offcho=”1”; enabled if offcho=”0”, default state). LS COB The LVDS Low-Speed Clock Output Buffer (LS COB) converts the signal from the CPR into the LVDS output signal clo. The proprietary low-power LVDS output buffer utilizes a special architecture that ensures operation at frequencies up to 2.0GHz with a low power consumption level of 30mW. The buffer satisfies all requirements of the IEEE Std. 1596.3-1996 and ANSI/TIA/EIA-644-1995. For the correct operation, it requires external differential 100Ohm DC termination at the receiver side. These pins should NEVER be CONNECTED to devices with 50Ohm termination to ground WITHOUT DC BLOCKS! ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 5 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vee). Table 5. Absolute Maximum Ratings Parameter Supply Voltage (vcc) Power Consumption RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Rev. 1.7.2 Min -40 10 10 5 Max 3.6 0.7 1.0 +90 +100 98 98 Units V W V ºC ºC % % February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com TERMINAL FUNCTIONS TERMINAL Name No. Type cep cen chop chon 14 13 17 16 CML input CML output cr16p cr16n clop clon 1 2 20 19 Input off16b offcho off12g offpll oncml phs2 phs1 ftr1 ftr2 lol Name vcc vee Rev. 1.7.2 4 5 9 11 21 24 25 7 8 6 DESCRIPTION High-Speed I/Os CML differential external clock inputs with internal SE 50Ohm termination to vcc CML differential clock outputs with internal SE 50Ohm termination to vcc. Require external SE 50Ohm termination to vcc Low-Speed I/Os LVDS/CML clock inputs. See LS CIB for allowed application schemes Output LVDS clock outputs. See LS COB for a detailed description Input Controls 3.3V CMOS control signals Input Pins for connecting the external loop filter. Can be also used for VCO external control in the open-loop mode Output 3.3V CMOS control output Supply and Termination Voltages Description Pin Number Positive power supply (+3.3V) 12, 15, 18, 27, 28, 29, 31, 32, 33, 34, 35, 36, 37, 38, 39 Negative power supply (0V) 3, 10, 22, 23, 26, 30, 40 6 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER MAX UNIT COMMENTS General Parameters 0.0 V External ground vee 3.1 3.3 3.5 V ±6% vcc Ivcc 185 195 mA Power consumption 630 mW Junction temperature -40 25 125 °C HS Input Clock (cep/cen) Frequency DC 14 GHz Swing 220 800 mV Differential or SE, p-p, at 14GHz 50 800 mV Differential or SE, p-p, at 4GHz CM Voltage Level vcc-0.8 vcc V Must match for both inputs Duty Cycle 40% 50% 60% LS Input Clock (cr16p/cr16n) Frequency DC 1600 MHz Swing 140 900 mV Differential or SE, p-p CM Voltage Level vee 1.6 vcc V Must match for both inputs HS Output Clock (chop/chon) Frequency DC 14 GHz Logic “1” level V vcc Logic “0” level vcc-0.85 V Jitter 6 ps Peak-to-peak at 12.5GHz Duty Cycle 50% LS Output Clock (clop/clon) Frequency DC 1750 MHz Interface LVDS Meets the IEEE Std. CMOS control inputs and outputs (off16b, offcho, off12g, offpll, oncml, phs1, phs2, lol) Logic “1” level vcc-0.3 V Logic “0” level vee+0.3 V VCOs Low frequency of 10.8 GHz Higher-speed VCO. VCO 1 Active if off12g =”0” High frequency of 12.7 GHz VCO 1 Low frequency of 7.4 GHz Lower-speed VCO. VCO 2 Active if off12g =”1” High frequency of 8.8 GHz VCO 2 External control 2.3 V In the open-loop mode common mode vccm External control vccm-0.8 vccm+0.8 V In the open-loop mode voltage range Rev. 1.7.2 MIN TYP 7 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com PACKAGE INFORMATION The chip die is housed in a standard 40-pin QFN package shown in Fig. 3. It is recommended that the center heat slug located on the back side of the package is soldered to the vee plain that is ground for the positive supply. The part’s identification label is ASNT8050-PQB. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. ASNT8050 Fig. 3. QFN 40-Pin Package Drawing (All Dimensions in mm) Rev. 1.7.2 8 February 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision 1.7.2 1.6.2 1.6.1 1.5.1 Date 02-2020 07-2019 08-2015 08-2014 1.4.1 1.3.1 05-2013 03-2013 1.2.1 03-2013 1.1 1.0 05-2012 04-2012 Rev. 1.7.2 Changes Updated Package Information Updated Letterhead Correct Fig. 2 External Filter Schematic Corrected format Corrected default state of the offpll input Corrected clock names in Table 2 Corrected name of the supply in the Absolute Maximum Ratings table Removed broken link Revised title Revised description Revised absolute maximum ratings Revised terminal functions Revised electrical characteristics Revised package information Updated format Corrected supply information First release 9 February 2020
ASNT8050-PQB 价格&库存
很抱歉,暂时无法提供与“ASNT8050-PQB”相匹配的价格&库存,您可以联系我们找货
