S-1711C2525-M6T1U
S-1711C2525-M6T1U
    ABLIC(艾普凌科)
    SOT23-6
    IC REG LIN 2.5V/2.5V 150MA SOT23
S-1711C2525-M6T1U 数据手册
S-1711 Series www.ablic.com 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR © ABLIC Inc., 2004-2019 Rev.3.2_00 The S-1711 Series is a 2-channel positive voltage regulator with a low dropout voltage, high-accuracy output voltage, and low current consumption (150 mA output current) developed based on CMOS technology. A 1.0 μF small ceramic capacitor can be used, and a 2-circuit voltage regulator with ±1.0% high-accuracy output voltage is incorporated in SOT-23-6 or super-small SNT-6A package. A/ B/ E/ F type is provided with a discharge shunt function allowing high-speed output response when the ON/OFF pin is used. Compared with the conventional 150 mA output current 2-channel CMOS voltage regulators, high-density mounting is realized by using super-small SNT-6A package and a small ceramic capacitor. Also, the low current consumption makes the S-1711 Series ideal for mobile devices.  Features • Output voltage: • Input voltage: • Output voltage accuracy: • Dropout voltage: • Current consumption: 1.5 V to 5.5 V, selectable in 0.1 V step 2.0 V to 6.5 V ±1.0% 200 mV typ. (3.0 V output product, IOUT = 150 mA) During operation: 70 μA typ., 90 μA max. (Per circuit) During power-off: 0.1 μA typ., 1.0 μA max. Possible to output 150 mA (VIN ≥ VOUT(S) + 1.0 V)*1 (Per circuit) • Output current: • Input and output capacitors: A ceramic capacitor of 1.0 μF or more can be used. • Ripple rejection: 70 dB typ. (f = 1.0 kHz) • Built-in overcurrent protection circuit: Limits overcurrent of output transistor. • Built-in ON/OFF circuit: Ensures long battery life. Discharge shunt function "available" / "unavailable" is selectable. Pull-down function "available" / "unavailable" is selectable. • Operation temperature range: Ta = −40°C to +85°C • Lead-free, Sn 100%, halogen-free*2 *1. Attention should be paid to the power dissipation of the package when the output current is large. *2. Refer to “ Product Name Structure” for details.  Applications • Constant-voltage power supply for cellular phone • Constant-voltage power supply for battery-powered device • Constant-voltage power supply for home electric appliance  Packages • SNT-6A • SOT-23-6 1 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00  Block Diagrams 1. S-1711 Series A type *1 ON/OFF1 6 1 VOUT1 5 VSS 3 VOUT2 1 VOUT1 5 VSS 3 VOUT2 Overcurrent protection circuit ON/OFF circuit + − Function ON/OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “H” Available None Available Function ON/OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “H” Available None None *1 Reference voltage circuit VIN 2 *1 Overcurrent protection circuit ON/OFF circuit + − *1 Reference voltage circuit ON/OFF2 4 *1. Parasitic diode Figure 1 2. S-1711 Series B type *1 ON/OFF1 6 Overcurrent protection circuit ON/OFF circuit + − *1 Reference voltage circuit VIN 2 *1 Overcurrent protection circuit ON/OFF circuit + − *1 Reference voltage circuit ON/OFF2 4 *1. Parasitic diode Figure 2 2 Rev.3.2_00 3. 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series S-1711 Series C type *1 ON/OFF1 6 1 VOUT1 5 VSS 3 VOUT2 1 VOUT1 5 VSS 3 VOUT2 Overcurrent protection circuit ON/OFF circuit Function ON/OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “H” None None Available Function ON/OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “H” None None None + − Reference voltage circuit VIN 2 *1 Overcurrent protection circuit ON/OFF circuit + − Reference voltage circuit ON/OFF2 4 *1. Parasitic diode Figure 3 4. S-1711 Series D type *1 ON/OFF1 6 Overcurrent protection circuit ON/OFF circuit + − Reference voltage circuit VIN 2 *1 Overcurrent protection circuit ON/OFF circuit + − Reference voltage circuit ON/OFF2 4 *1. Parasitic diode Figure 4 3 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series 5. Rev.3.2_00 S-1711 Series E type *1 ON/OFF1 6 1 VOUT1 5 VSS 3 VOUT2 1 VOUT1 5 VSS 3 VOUT2 Overcurrent protection circuit ON/OFF circuit + − Function ON/OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “L” Available Available None Function ON/OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “L” Available None None *1 Reference voltage circuit VIN 2 *1 Overcurrent protection circuit ON/OFF circuit + − *1 Reference voltage circuit ON/OFF2 4 *1. Parasitic diode Figure 5 6. S-1711 Series F type *1 ON/OFF1 6 Overcurrent protection circuit ON/OFF circuit + − *1 Reference voltage circuit VIN 2 *1 Overcurrent protection circuit ON/OFF circuit + − *1 Reference voltage circuit ON/OFF2 4 *1. Parasitic diode Figure 6 4 Rev.3.2_00 7. 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series S-1711 Series G type *1 ON/OFF1 6 1 VOUT1 5 VSS 3 VOUT2 1 VOUT1 5 VSS 3 VOUT2 Overcurrent protection circuit ON/OFF circuit Function ON/OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “L” None Available None Function ON/OFF logic Discharge shunt function Pull-up resistor Pull-down resistor Status Active “L” None None None + − Reference voltage circuit VIN 2 *1 Overcurrent protection circuit ON/OFF circuit + − Reference voltage circuit ON/OFF2 4 *1. Parasitic diode Figure 7 8. S-1711 Series H type *1 ON/OFF1 6 Overcurrent protection circuit ON/OFF circuit + − Reference voltage circuit VIN 2 *1 Overcurrent protection circuit ON/OFF circuit + − Reference voltage circuit ON/OFF2 4 *1. Parasitic diode Figure 8 5 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00  Product Name Structure Users can select the product type, output voltage, and package type for the S-1711 Series. Refer to "1. Product name" regarding the contents of product name, "2. Function list of product type" regarding the product type, "3. Packages" regarding the package drawings, "4. Product name list" regarding details of the product name. 1. Product name 1. 1 SNT-6A S-1711 x xx xx - I6T1 U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 I6T1: SNT-6A, Tape Output voltage of voltage regulator 2 15 to 55 (e.g., when the output voltage is 1.5 V, it is expressed as 15.) Output voltage of voltage regulator 1 15 to 55 (e.g., when the output voltage is 1.5 V, it is expressed as 15.) Product type *2 A to H *1. Refer to the tape drawing. *2. Refer to “2. Function list of product type”. 1. 2 SOT-23-6 S-1711 x xx xx - M6T1 x Environmental code U: Lead-free (Sn 100%), halogen-free G: Lead-free (for details, please contact our sales representatives.) Package abbreviation and IC packing specifications*1 M6T1: SOT-23-6, Tape Output voltage of voltage regulator 2 15 to 55 (e.g., when the output voltage is 1.5 V, it is expressed as 15.) Output voltage of voltage regulator 1 15 to 55 (e.g., when the output voltage is 1.5 V, it is expressed as 15.) Product type*2 A to H *1. Refer to the tape drawing. *2. Refer to “2. Function list of product type”. 6 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00 2. Function list of product type Table 1 Product Type 3. ON/OFF Logic Discharge Shunt Function Pull-up Resistor Pull-down Resistor A Active “H” Available None Available B Active “H” Available None None C Active “H” None None Available D Active “H” None None None E Active “L” Available Available None F Active “L” Available None None G Active “L” None Available None H Active “L” None None None Packages Package Name SNT-6A SOT-23-6 Package PG006-A-P-SD MP006-A-P-SD Drawing Code Tape Reel PG006-A-C-SD PG006-A-R-SD MP006-A-C-SD MP006-A-R-SD Land PG006-A-L-SD ⎯ 7 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series 4. Rev.3.2_00 Product name list 4. 1 S-1711 Series A type ON/OFF logic: Discharge Shunt Function: Active “H” Available Pull-up Resistor: Pull-down Resistor: None Available Table 2 (1 / 2) 8 Voltage Regulator 1 Output Voltage Voltage Regulator 2 Output Voltage 1.5 V ±1.0% 1.5 V ±1.0% 1.5 V ±1.0% 1.5 V ±1.0% 1.5 V ±1.0% 1.5 V ±1.0% 1.5 V ±1.0% 1.8 V ±1.0% 1.8 V ±1.0% 1.8 V ±1.0% 1.8 V ±1.0% 1.8 V ±1.0% 1.8 V ±1.0% 1.8 V ±1.0% 1.8 V ±1.0% 1.8 V ±1.0% 1.8 V ±1.0% 1.8 V ±1.0% 1.85 V ±1.0% 2.0 V ±1.0% 2.3 V ±1.0% 2.3 V ±1.0% 2.4 V ±1.0% 2.4 V ±1.0% 2.5 V ±1.0% 2.5 V ±1.0% 2.5 V ±1.0% 2.5 V ±1.0% 2.5 V ±1.0% 2.5 V ±1.0% 2.5 V ±1.0% 2.6 V ±1.0% 2.6 V ±1.0% 2.6 V ±1.0% 2.6 V ±1.0% 2.6 V ±1.0% 2.7 V ±1.0% 2.8 V ±1.0% 2.8 V ±1.0% 2.8 V ±1.0% 2.8 V ±1.0% 1.5 V ±1.0% 1.8 V ±1.0% 2.6 V ±1.0% 2.8 V ±1.0% 2.85 V ±1.0% 2.9 V ±1.0% 3.3 V ±1.0% 1.5 V ±1.0% 1.8 V ±1.0% 2.5 V ±1.0% 2.7 V ±1.0% 2.75 V ±1.0% 2.7 V ±1.0% 2.85 V ±1.0% 2.9 V ±1.0% 3.0 V ±1.0% 3.2 V ±1.0% 3.3 V ±1.0% 2.8 V ±1.0% 4.5 V ±1.0% 3.2 V ±1.0% 3.3 V ±1.0% 2.4 V ±1.0% 2.5 V ±1.0% 1.5 V ±1.0% 1.8 V ±1.0% 2.2 V ±1.0% 2.5 V ±1.0% 2.8 V ±1.0% 2.9 V ±1.0% 3.3 V ±1.0% 1.8 V ±1.0% 2.6 V ±1.0% 2.8 V ±1.0% 2.9 V ±1.0% 3.0 V ±1.0% 1.8 V ±1.0% 1.5 V ±1.0% 1.8 V ±1.0% 1.9 V ±1.0% 2.5 V ±1.0% SNT-6A S-1711A1515-I6T1U S-1711A1518-I6T1U S-1711A1526-I6T1U S-1711A1528-I6T1U S-1711A152J-I6T1U ⎯ S-1711A1533-I6T1U S-1711A1815-I6T1U S-1711A1818-I6T1U ⎯ S-1711A1827-I6T1U S-1711A182H-I6T1U S-1711A1828-I6T1U S-1711A182J-I6T1U S-1711A1829-I6T1U S-1711A1830-I6T1U ⎯ S-1711A1833-I6T1U S-1711A1J28-I6T1U ⎯ S-1711A2332-I6T1U S-1711A2333-I6T1U S-1711A2424-I6T1U S-1711A2425-I6T1U S-1711A2515-I6T1U S-1711A2518-I6T1U ⎯ S-1711A2525-I6T1U S-1711A2528-I6T1U ⎯ S-1711A2533-I6T1U ⎯ S-1711A2626-I6T1U S-1711A2628-I6T1U S-1711A2629-I6T1U S-1711A2630-I6T1U ⎯ S-1711A2815-I6T1U S-1711A2818-I6T1U ⎯ ⎯ SOT-23-6 S-1711A1515-M6T1x ⎯ ⎯ S-1711A1528-M6T1x ⎯ S-1711A1529-M6T1x S-1711A1533-M6T1x S-1711A1815-M6T1x S-1711A1818-M6T1x S-1711A1825-M6T1x S-1711A1827-M6T1x S-1711A182H-M6T1x S-1711A1828-M6T1x S-1711A182J-M6T1x S-1711A1829-M6T1x S-1711A1830-M6T1x S-1711A1832-M6T1x S-1711A1833-M6T1x S-1711A1J28-M6T1x S-1711A2045-M6T1x ⎯ ⎯ S-1711A2424-M6T1x S-1711A2425-M6T1x S-1711A2515-M6T1x S-1711A2518-M6T1x S-1711A2522-M6T1x S-1711A2525-M6T1x S-1711A2528-M6T1x S-1711A2529-M6T1x S-1711A2533-M6T1x S-1711A2618-M6T1x ⎯ ⎯ ⎯ ⎯ S-1711A2718-M6T1x S-1711A2815-M6T1x S-1711A2818-M6T1x S-1711A2819-M6T1x S-1711A2825-M6T1x Rev.3.2_00 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Table 2 (2 / 2) Voltage Regulator 1 Output Voltage Voltage Regulator 2 Output Voltage SNT-6A SOT-23-6 2.8 V ±1.0% 2.8 V ±1.0% S-1711A2828-I6T1U S-1711A2828-M6T1x 2.8 V ±1.0% 2.9 V ±1.0% S-1711A2829-I6T1U S-1711A2829-M6T1x 2.8 V ±1.0% 3.0 V ±1.0% S-1711A2830-I6T1U S-1711A2830-M6T1x 2.8 V ±1.0% 3.1 V ±1.0% S-1711A2831-I6T1U ⎯ 2.8 V ±1.0% 3.2 V ±1.0% S-1711A2832-I6T1U S-1711A2832-M6T1x 2.8 V ±1.0% 3.3 V ±1.0% S-1711A2833-I6T1U S-1711A2833-M6T1x 2.85 V ±1.0% 1.5 V ±1.0% S-1711A2J15-I6T1U ⎯ 2.85 V ±1.0% 1.8 V ±1.0% S-1711A2J18-I6T1U ⎯ 2.85 V ±1.0% 2.85 V ±1.0% S-1711A2J2J-I6T1U S-1711A2J2J-M6T1x 2.85 V ±1.0% 3.0 V ±1.0% ⎯ S-1711A2J30-M6T1x 2.85 V ±1.0% 3.3 V ±1.0% S-1711A2J33-I6T1U ⎯ 2.9 V ±1.0% 2.9 V ±1.0% S-1711A2929-I6T1U S-1711A2929-M6T1x 2.9 V ±1.0% 3.3 V ±1.0% ⎯ S-1711A2933-M6T1x 3.0 V ±1.0% 1.5 V ±1.0% S-1711A3015-I6T1U S-1711A3015-M6T1x 3.0 V ±1.0% 1.8 V ±1.0% S-1711A3018-I6T1U S-1711A3018-M6T1x 3.0 V ±1.0% 2.5 V ±1.0% S-1711A3025-I6T1U S-1711A3025-M6T1x 3.0 V ±1.0% 2.8 V ±1.0% S-1711A3028-I6T1U ⎯ 3.0 V ±1.0% 3.0 V ±1.0% S-1711A3030-I6T1U S-1711A3030-M6T1x 3.0 V ±1.0% 3.3 V ±1.0% S-1711A3033-I6T1U S-1711A3033-M6T1x 3.1 V ±1.0% 2.8 V ±1.0% S-1711A3128-I6T1U ⎯ 3.3 V ±1.0% 1.8 V ±1.0% S-1711A3318-I6T1U ⎯ 3.3 V ±1.0% 2.5 V ±1.0% ⎯ S-1711A3325-M6T1x 3.3 V ±1.0% 2.8 V ±1.0% ⎯ S-1711A3328-M6T1x 3.3 V ±1.0% 3.0 V ±1.0% ⎯ S-1711A3330-M6T1x 3.3 V ±1.0% 3.3 V ±1.0% S-1711A3333-I6T1U S-1711A3333-M6T1x 3.3 V ±1.0% 4.8 V ±1.0% S-1711A3348-I6T1U S-1711A3348-M6T1x 3.3 V ±1.0% 5.0 V ±1.0% S-1711A3350-I6T1U ⎯ 3.4 V ±1.0% 3.4 V ±1.0% S-1711A3434-I6T1U ⎯ 4.0 V ±1.0% 2.0 V ±1.0% ⎯ S-1711A4020-M6T1x 5.0 V ±1.0% 2.5 V ±1.0% S-1711A5025-I6T1U S-1711A5025-M6T1x 5.0 V ±1.0% 3.0 V ±1.0% S-1711A5030-I6T1U ⎯ Remark 1. Please contact our sales representatives for products other than the above. 2. x: G or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 9 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series 4. 2 Rev.3.2_00 S-1711 Series B type ON/OFF logic: Active “H” Discharge Shunt Function: Available Pull-up Resistor: Pull-down Resistor: None None Table 3 Voltage Regulator 1 Output Voltage Voltage Regulator 2 Output Voltage SNT-6A SOT-23-6 1.5 V ±1.0% 1.8 V ±1.0% S-1711B1518-I6T1U S-1711B1518-M6T1x 1.5 V ±1.0% 2.8 V ±1.0% S-1711B1528-I6T1U ⎯ 1.5 V ±1.0% 2.9 V ±1.0% ⎯ S-1711B1529-M6T1x 1.8 V ±1.0% 2.5 V ±1.0% S-1711B1825-I6T1U S-1711B1825-M6T1x 1.8 V ±1.0% 2.8 V ±1.0% S-1711B1828-I6T1U S-1711B1828-M6T1x 1.8 V ±1.0% 3.2 V ±1.0% ⎯ S-1711B1832-M6T1x S-1711B1833-I6T1U 1.8 V ±1.0% 3.3 V ±1.0% S-1711B1833-M6T1x 2.5 V ±1.0% 1.5 V ±1.0% ⎯ S-1711B2515-M6T1x 2.5 V ±1.0% 1.8 V ±1.0% S-1711B2518-I6T1U S-1711B2518-M6T1x 2.5 V ±1.0% 2.8 V ±1.0% S-1711B2528-I6T1U S-1711B2528-M6T1x 2.6 V ±1.0% 1.8 V ±1.0% ⎯ S-1711B2618-M6T1x 2.7 V ±1.0% 1.8 V ±1.0% ⎯ S-1711B2718-M6T1x 2.8 V ±1.0% 1.5 V ±1.0% S-1711B2815-I6T1U S-1711B2815-M6T1x 2.8 V ±1.0% 1.8 V ±1.0% S-1711B2818-I6T1U S-1711B2818-M6T1x 2.8 V ±1.0% 2.5 V ±1.0% ⎯ S-1711B2825-M6T1x S-1711B2828-I6T1U 2.8 V ±1.0% 2.8 V ±1.0% S-1711B2828-M6T1x 2.8 V ±1.0% 3.3 V ±1.0% S-1711B2833-I6T1U ⎯ 3.0 V ±1.0% 3.0 V ±1.0% ⎯ S-1711B3030-M6T1x 3.0 V ±1.0% 3.3 V ±1.0% S-1711B3033-I6T1U S-1711B3033-M6T1x 3.0 V ±1.0% 3.6 V ±1.0% ⎯ S-1711B3036-M6T1x 3.3 V ±1.0% 3.3 V ±1.0% S-1711B3333-I6T1U S-1711B3333-M6T1x Remark 1. Please contact our sales representatives for products other than the above. 2. x: G or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 10 Rev.3.2_00 4. 3 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series S-1711 Series C type ON/OFF logic: Active “H” Discharge Shunt Function: None Pull-up Resistor: Pull-down Resistor: None Available Table 4 Voltage Regulator 1 Output Voltage Voltage Regulator 2 Output Voltage SNT-6A SOT-23-6 1.5 V ±1.0% 1.5 V ±1.0% S-1711C1515-I6T1U S-1711C1515-M6T1x 1.8 V ±1.0% 1.5 V ±1.0% S-1711C1815-I6T1U S-1711C1815-M6T1x 1.8 V ±1.0% 2.5 V ±1.0% ⎯ S-1711C1825-M6T1x 1.8 V ±1.0% 2.7 V ±1.0% S-1711C1827-I6T1U S-1711C1827-M6T1x 1.8 V ±1.0% 2.75 V ±1.0% S-1711C182H-I6T1U S-1711C182H-M6T1x 1.8 V ±1.0% 2.8 V ±1.0% S-1711C1828-I6T1U ⎯ 1.8 V ±1.0% 3.2 V ±1.0% ⎯ S-1711C1832-M6T1x 1.85 V ±1.0% 2.8 V ±1.0% S-1711C1J28-I6T1U S-1711C1J28-M6T1x 2.4 V ±1.0% 2.4 V ±1.0% S-1711C2424-I6T1U S-1711C2424-M6T1x 2.4 V ±1.0% 2.5 V ±1.0% S-1711C2425-I6T1U S-1711C2425-M6T1x 2.5 V ±1.0% 1.5 V ±1.0% S-1711C2515-I6T1U S-1711C2515-M6T1x 2.5 V ±1.0% 1.8 V ±1.0% S-1711C2518-I6T1U S-1711C2518-M6T1x 2.5 V ±1.0% 2.5 V ±1.0% S-1711C2525-I6T1U S-1711C2525-M6T1x 2.8 V ±1.0% 1.5 V ±1.0% S-1711C2815-I6T1U S-1711C2815-M6T1x 2.8 V ±1.0% 1.8 V ±1.0% S-1711C2818-I6T1U S-1711C2818-M6T1x 2.8 V ±1.0% 2.8 V ±1.0% S-1711C2828-I6T1U S-1711C2828-M6T1x 2.8 V ±1.0% 2.9 V ±1.0% S-1711C2829-I6T1U S-1711C2829-M6T1x 2.8 V ±1.0% 3.0 V ±1.0% S-1711C2830-I6T1U S-1711C2830-M6T1x 2.8 V ±1.0% 3.3 V ±1.0% S-1711C2833-I6T1U S-1711C2833-M6T1x 2.85 V ±1.0% 2.85 V ±1.0% S-1711C2J2J-I6T1U S-1711C2J2J-M6T1x 2.9 V ±1.0% 2.9 V ±1.0% S-1711C2929-I6T1U S-1711C2929-M6T1x 3.0 V ±1.0% 1.5 V ±1.0% S-1711C3015-I6T1U S-1711C3015-M6T1x 3.0 V ±1.0% 1.8 V ±1.0% S-1711C3018-I6T1U S-1711C3018-M6T1x 3.0 V ±1.0% 2.5 V ±1.0% S-1711C3025-I6T1U S-1711C3025-M6T1x 3.0 V ±1.0% 3.0 V ±1.0% S-1711C3030-I6T1U S-1711C3030-M6T1x 3.0 V ±1.0% 3.3 V ±1.0% S-1711C3033-I6T1U S-1711C3033-M6T1x 3.1 V ±1.0% 3.1 V ±1.0% ⎯ S-1711C3131-M6T1x Remark 1. Please contact our sales representatives for products other than the above. 2. x: G or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 11 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series 4. 4 Rev.3.2_00 S-1711 Series D type ON/OFF logic: Active “H” Discharge Shunt Function: None Pull-up Resistor: Pull-down Resistor: None None Table 5 4. 5 Voltage Regulator 1 Output Voltage Voltage Regulator 2 Output Voltage 1.8 V ±1.0% 1.8 V ±1.0% 1.8 V ±1.0% 1.8 V ±1.0% 1.9 V ±1.0% 2.5 V ±1.0% 2.5 V ±1.0% 2.5 V ±1.0% 2.6 V ±1.0% 2.8 V ±1.0% 2.85 V ±1.0% 4.2 V ±1.0% 2.5 V ±1.0% 2.6 V ±1.0% 2.8 V ±1.0% 3.2 V ±1.0% 2.5 V ±1.0% 1.8 V ±1.0% 2.8 V ±1.0% 2.85 V ±1.0% 2.9 V ±1.0% 1.5 V ±1.0% 2.85 V ±1.0% 3.0 V ±1.0% SNT-6A SOT-23-6 ⎯ ⎯ S-1711D1828-I6T1U ⎯ S-1711D1925-I6T1U S-1711D2518-I6T1U S-1711D2528-I6T1U S-1711D252J-I6T1U ⎯ S-1711D2815-I6T1U S-1711D2J2J-I6T1U ⎯ S-1711D1825-M6T1x S-1711D1826-M6T1x S-1711D1828-M6T1x S-1711D1832-M6T1x S-1711D1925-M6T1x S-1711D2518-M6T1x S-1711D2528-M6T1x ⎯ S-1711D2629-M6T1x S-1711D2815-M6T1x ⎯ S-1711D4230-M6T1x S-1711 Series E type ON/OFF logic: Active “L” Discharge Shunt Function: Available Pull-up Resistor: Pull-down Resistor: Available None Table 6 4. 6 Voltage Regulator 1 Output Voltage Voltage Regulator 2 Output Voltage 1.8 V ±1.0% 2.8 V ±1.0% 3.3 V ±1.0% 3.3 V ±1.0% 1.8 V ±1.0% 3.3 V ±1.0% SNT-6A SOT-23-6 ⎯ S-1711E2818-I6T1U ⎯ S-1711E1833-M6T1x S-1711E2818-M6T1x S-1711E3333-M6T1x S-1711 Series F type ON/OFF logic: Active “L” Discharge Shunt Function: Available Pull-up Resistor: Pull-down Resistor: None None Table 7 Voltage Regulator 1 Output Voltage Voltage Regulator 2 Output Voltage SNT-6A SOT-23-6 2.8 V ±1.0% 1.8 V ±1.0% S-1711F2818-I6T1U ⎯ Remark 1. Please contact our sales representatives for products other than the above. 2. x: G or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 12 Rev.3.2_00 4. 7 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series S-1711 Series G type ON/OFF logic: Active “L” Discharge Shunt Function: None Pull-up Resistor: Pull-down Resistor: Available None Table 8 4. 8 Voltage Regulator 1 Output Voltage Voltage Regulator 2 Output Voltage 2.8 V ±1.0% 3.0 V ±1.0% SNT-6A SOT-23-6 ⎯ S-1711G2830-I6T1U S-1711 Series H type ON/OFF logic: Active “L” Discharge Shunt Function: None Pull-up Resistor: Pull-down Resistor: None None Table 9 Voltage Regulator 1 Output Voltage Voltage Regulator 2 Output Voltage SNT-6A SOT-23-6 2.5 V ±1.0% 1.8 V ±1.0% ⎯ S-1711H2518-M6T1x Remark 1. Please contact our sales representatives for products other than the above. 2. x: G or U 3. Please select products of environmental code = U for Sn 100%, halogen-free products. 13 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00  Pin Configurations 1. SNT-6A Table 10 Top view 1 2 3 6 5 4 Figure 9 2. Pin No. Symbol 1 VOUT1 2 VIN 3 VOUT2 4 ON/OFF2 Description Output voltage pin 1 Input voltage pin 5 VSS 6 ON/OFF1 Output voltage pin 2 ON/OFF pin 2 GND pin ON/OFF pin 1 SOT-23-6 Table 11 Top view 6 5 4 1 2 3 Figure 10 14 Pin No. Symbol 1 VOUT1 2 VIN 3 VOUT2 4 ON/OFF2 5 VSS 6 ON/OFF1 Description Output voltage pin 1 Input voltage pin Output voltage pin 2 ON/OFF pin 2 GND pin ON/OFF pin 1 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00  Absolute Maximum Ratings Table 12 Item (Ta = 25°C unless otherwise specified) Absolute Maximum Rating Unit Symbol VSS−0.3 to VSS+7 V VON/OFF1, VON/OFF2 VSS−0.3 to VIN+0.3 V VOUT1, VOUT2 VSS−0.3 to VIN+0.3 V VIN Input voltage Output voltage 400*1 mW 300 (When not mounted on board) mW 650*1 mW −40 to +85 −40 to +125 °C °C SNT-6A Power dissipation PD SOT-23-6 Operation ambient temperature Topr Storage temperature Tstg *1. When mounted on board [Mounted board] (1) Board size: 114.3 mm × 76.2 mm × t1.6 mm (2) Name: JEDEC STANDARD51-7 Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. (1) When mounted on board (2) When not mounted on board 500 600 Power Dissipation (PD) [mW] Power Dissipation (PD) [mW] 700 SOT-23-6 500 400 300 200 SNT-6A 100 0 0 50 100 150 Ambient Temperature (Ta) [°C] 400 300 SOT-23-6 200 100 0 0 50 100 150 Ambient Temperature (Ta) [°C] Figure 11 Power Dissipation of Package 15 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00  Electrical Characteristics Table 13 Total (2 circuits) Item Current consumption Symbol ISS Condition ⎯ VIN = 6.5 V, no load Voltage regulator 1 or Voltage regulator 2 (Per circuit) Item Symbol Condition Output voltage*1 VOUT(E) VIN = VOUT(S) + 1.0 V, IOUT = 30 mA Output current*2 Dropout voltage*3 IOUT Vdrop VIN ≥ VOUT(S) + 1.0 V IOUT = 150 mA Line regulation Load regulation Output voltage temperature coefficient*4 Current consumption during operation Current consumption during power-off Input voltage ON/OFF pin input voltage “H” ON/OFF pin input voltage “L” (Ta = 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VOUT(S) = 1.5 V VOUT(S) = 1.6 V VOUT(S) = 1.7 V 1.8 V ≤ VOUT(S) ≤ 2.0 V 2.1 V ≤ VOUT(S) ≤ 2.7 V 2.8 V ≤ VOUT(S) ≤ 5.5 V 140 180 μA 1 (Ta = 25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit V 2, 3 ⎯ 0.54 0.44 0.34 0.26 0.24 0.20 VOUT(S) × 1.01 ⎯ 0.58 0.48 0.39 0.39 0.36 0.35 mA V V V V V V 4, 5 2, 3 2, 3 2, 3 2, 3 2, 3 2, 3 VOUT(S) × 0.99 150*5 0.50 0.40 0.30 0.20 ⎯ ⎯ VOUT(S) ΔVOUT1 ΔVIN• VOUT ΔVOUT2 ΔVOUT ΔTa • VOUT VOUT(S) + 0.5 V ≤ VIN ≤ 6.5 V, IOUT = 30 mA ⎯ 0.02 0.1 %/V 2, 3 VIN = VOUT(S) + 1.0 V, 1.0 mA ≤ IOUT ≤ 150 mA VIN = VOUT(S) + 1.0 V, IOUT = 30 mA, −40°C ≤ Ta ≤ +85°C ⎯ 20 40 2, 3 ⎯ ±100 ⎯ mV ppm / °C ISS1 VIN = VOUT(S) + 1.0 V, ON/OFF pin = ON, no load ⎯ 70 90 μA 1 ISS2 VIN = VOUT(S) + 1.0 V, ON/OFF pin = OFF, no load ⎯ 0.1 1.0 μA 1 2.0 ⎯ 6.5 V 1 ⎯ VIN 2, 3 VSH VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ 1.5 ⎯ ⎯ V 6, 7 VSL VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ ⎯ ⎯ 0.3 V 6, 7 ON/OFF pin input current “H” ISH VIN = 6.5 V, VON/OFF = 6.5 V 6, 7 ON/OFF pin input current “L” ISL Ripple rejection Short-circuit current RR Ishort 1.0 2.5 4.2 μA B/ D/ E/ F/ G/ H type E/ G type VIN = 6.5 V, VON/OFF = 0 V A/ B/ C/ D/ F/ H type VIN = VOUT(S) + 1.0 V, f = 1.0 kHz, ΔVrip = 0.5 Vrms, IOUT = 30 mA −0.1 1.0 −0.1 ⎯ 2.5 ⎯ 0.1 4.2 0.1 μA μA μA ⎯ 70 ⎯ dB 8, 9 VIN = VOUT(S) + 1.0 V, ON/OFF pin = ON, VOUT = 0 V ⎯ 170 ⎯ mA 4, 5 Min. Typ. Max. Unit Test Circuit ⎯ 100 ⎯ Ω 4, 5 Condition Min. Typ. Max. Unit Test Circuit ⎯ 1.0 2.6 5.0 MΩ 6, 7 A/ C type 6, 7 S-1711 Series A/B/E/F type (With discharge shunt function) Item Symbol Discharge shunt resistance RLOW during power-off Condition VOUT = 0.1 V, VIN = 6.5 V S-1711 Series A/C/E/G type (With pull-up/pull-down resistor) Item Power-off pull-up/pull-down resistor 16 Symbol RPD Rev.3.2_00 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT(=30 mA) and inputting VOUT(S) + 1.0 V *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V and IOUT = 150 mA. VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. *4. A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa • VOUT [ppm/°C]*3 ÷ 1000 ΔTa *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. The output current can be at least this value. Due to restrictions on the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation of the package when the output current is large. This specification is guaranteed by design. 17 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series  Test Circuits + 1. A VOUT2 *1 VIN VOUT1 ON/OFF2 ON/OFF1 VSS *1 *1. Set to VIN or GND Figure 12 2. VOUT2 *1 + A + V VIN VOUT1 ON/OFF2 ON/OFF1 VSS *2 *1. Set to OFF *2. Set to ON Figure 13 3. + A VOUT2 + V *1 VIN VOUT1 ON/OFF2 ON/OFF1 VSS *2 *1. Set to ON *2. Set to OFF Figure 14 4. VOUT2 *1 VIN VOUT1 ON/OFF2 ON/OFF1 VSS A *2 *1. Set to OFF *2. Set to VIN or GND Figure 15 5. A + V VOUT2 *1 VIN VOUT1 ON/OFF2 ON/OFF1 VSS *1. Set to VIN or GND *2. Set to OFF Figure 16 18 *2 + V Rev.3.2_00 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00 6. VIN VOUT1 VOUT2 *1 ON/OFF2 ON/OFF1 VSS A + + V RL *1. Set to OFF Figure 17 7. RL V + + VOUT2 A VIN VOUT1 ON/OFF2 ON/OFF1 VSS *1 *1. Set to OFF Figure 18 8. VOUT2 *1 VIN VOUT1 ON/OFF2 ON/OFF1 VSS *2 + V RL *1. Set to OFF *2. Set to ON Figure 19 9. VOUT2 RL + V *1 VIN VOUT1 ON/OFF2 ON/OFF1 VSS *2 *1. Set to ON *2. Set to OFF Figure 20 19 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00  Standard Circuit Input Output 1 VIN VOUT1 ON/OFF1 VOUT2 Output 2 ON/OFF2 VSS CIN*1 CL1 *2 *2 CL2 Single GND GND *1. CIN is a capacitor for stabilizing the input. *2. A ceramic capacitor of 1.0 μF or more can be used for CL1 and CL2. Figure 21 Caution The above connection diagram and constants will not guarantee successful operation. thorough evaluation using the actual application to set the constants. Perform  Condition of Application Input capacitor (CIN): Output capacitor (CL1, CL2): ESR of output capacitor: 1.0 μF or more 1.0 μF or more 1.0 Ω or less Caution Generally a series regulator may cause oscillation, depending on the selection of external parts. Confirm that no oscillation occurs in the application for which the above capacitors are used. Use input/output capacitor which has good temperature characteristics (conforming to the ceramic capacitor EIA X5R (JIS B) characteristics).  Selection of Input and Output Capacitors (CIN, CL1, CL2) The S-1711 Series requires an output capacitor between the VOUT and VSS pins for phase compensation. Operation is stabilized by a ceramic capacitor with an output capacitance of 1.0 μF or more in the entire temperature range. When using an OS capacitor, a tantalum capacitor, or an aluminum electrolytic capacitor, the capacitance must be 1.0 μF or more, and the ESR must be 1.0 Ω or less. The value of the output overshoot or undershoot transient response varies depending on the value of the output capacitor. The required capacitance of the input capacitor differs depending on the application. The recommended capacitance for an application is CIN ≥ 1.0 μF, CL1 ≥ 1.0 μF, CL2 ≥ 1.0 μF; however, when selecting the output capacitor, perform sufficient evaluation, including evaluation of temperature characteristics, on the actual device. 20 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00  Explanation of Terms 1. Low dropout voltage regulator This voltage regulator has the low dropout voltage due to its built-in low on-resistance transistor. 2. Low ESR A capacitor whose ESR (Equivalent Series Resistance) is low. The S-1711 Series enables use of a low ESR capacitor, such as a ceramic capacitor, for the output capacitor CL1, CL2. ESR of 1.0 Ω or less can be used. 3. Output voltage (VOUT) The accuracy of the output voltage is ensured at ±1.0% under the specified conditions of fixed input voltage*1, fixed output current, and fixed temperature. *1. Differs depending on the product. Caution 4. If the above conditions change, the output voltage value may vary and exceed the accuracy range of the output voltage. Refer to “ Electrical Characteristics” and “ Characteristics (Typical Data) (Per circuit)” for details. ΔVOUT1  ΔVIN • VOUT  Line regulation  Indicates the dependency of the output voltage on the input voltage. That is, the values show how much the output voltage changes due to a change in the input voltage with the output current remaining unchanged. 5. Load regulation (ΔVOUT2) Indicates the dependency of the output voltage on the output current. That is, the values show how much the output voltage changes due to a change in the output current with the input voltage remaining unchanged. 6. Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when; decreasing input voltage (VIN) gradually until the output voltage has dropped out to the value of 98% of output voltage (VOUT3), which is at VIN = VOUT(S) + 1.0 V. Vdrop = VIN1 − (VOUT3 × 0.98) 21 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series 7. Rev.3.2_00 ΔVOUT  ΔTa • VOUT  Output voltage temperature coefficient  The shaded area in Figure 22 is the range where VOUT varies in the operation temperature range when the output voltage temperature coefficient is ±100 ppm/°C. Example of VOUT = 2.8 V typ. product VOUT [V] +0.28 mV/°C *1 VOUT(E) −0.28 mV/°C −40 +25 +85 Ta [°C] *1. VOUT(E) is the value of the output voltage measured at Ta = +25°C. Figure 22 A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa • VOUT [ppm/°C]*3 ÷ 1000 ΔTa *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient 22 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00  Operation 1. Basic operation Figure 23 shows the block diagram of the S-1711 Series. The error amplifier compares the reference voltage (Vref) with feedback voltage (Vfb), which is the output voltage resistance-divided by feedback resistors (Rs and Rf). It supplies the gate voltage necessary to maintain the constant output voltage which is not influenced by the input voltage and temperature change, to the output transistor. VIN *1 Current supply Error amplifier Vref VOUT − Rf + Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 23 2. Output transistor In the S-1711 Series, a low on-resistance P-channel MOS FET is used as the output transistor. Be sure that VOUT does not exceed VIN + 0.3 V to prevent the voltage regulator from being damaged due to reverse current flowing from the VOUT pin through a parasitic diode to the VIN pin, when the potential of VOUT became higher than VIN. 23 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series 3. Rev.3.2_00 ON/OFF pin 1 and 2 These pins start and stop the regulator. When the ON/OFF pin is set to OFF level, the entire internal circuit stops operating, and the built-in P-channel MOS FET output transistor between the VIN pin and the VOUT pin is turned off, reducing current consumption significantly. Since the S-1711 Series A/ B/ E/ F type has a built-in discharge shunt circuit to discharge the output capacitance, the VOUT pin is forcibly set to VSS level. In the S-1711 Series C/ D/ G/ H type, the VOUT pin is set to VSS level through several hundred kΩ internal divided resistors between the VOUT pin and the VSS pin. Note that the current consumption increases when a voltage of 0.3 V to VIN − 0.3 V is applied to the ON/OFF pin. The ON/OFF pin is configured as shown in Figure 24 and Figure 25. In the S-1711 Series A/ C/ E/ G type, the ON/OFF pin is internally pulled up or pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. In the S-1711 Series B/ D/ F/ H type, the ON/OFF pin is not internally pulled up or pulled down, so do not use the ON/OFF pin in the floating status. When not using the ON/OFF pin, connect it to the VIN pin in the product B/ D type, and connect it to the VSS pin in F/ H type. Table 14 Product Type ON/OFF Pin Internal Circuit VOUT Pin Voltage Current Consumption ISS1*1 ISS2 ISS2 ISS1*1 A/ B/ C/ D “H”: ON Operate Set value A/ B/ C/ D “L”: OFF Stop VSS level E/ F/ G/ H “H”: OFF Stop VSS level E/ F/ G/ H “L”: ON Operate Set value *1. Note that the IC’s current consumption increases as much as current flows into the pull-up/pull-down resistor when; the ON/OFF pin is connected to the VIN pin in the A/ C type, the ON/OFF pin is connected to the VSS pin in the E/ G type (Refer to Figure 24). (1) S-1711 Series A/ C/ E/ G Type (2) S-1711 Series B/ D/ F/ H Type VIN VIN E/G type ON/OFF ON/OFF A/C type VSS Figure 24 24 VSS Figure 25 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00 4. Discharge shunt function (S-1711 Series A/ B/ E/ F type) The S-1711 Series A/ B/ E/ F type has a built-in discharge shunt circuit to discharge the output capacitance. When the ON/OFF pin is set to OFF level, turns the output transistor off, and turns the discharge shunt circuit on so that the output capacitor discharges. These types allow the VOUT pin to reach VSS level faster than the S-1711 Series C / D / G / H type that does not have a discharge shunt circuit. Output transistor : OFF S-1711 Series *1 VOUT VIN Discharge shunt circuit : ON ON/OFF *1 ON/OFF circuit Output capacitor (CL) ON/OFF Pin: OFF Current flow GND VSS *1. Parasitic diode Figure 26 5. Pull-down/pull-up resistor (S-1711 Series A/ C/ E/ G type) In the S-1711 Series A/ C/ E/ G type, the ON/OFF pin is internally pulled up to the VIN pin or pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. Note that the IC’s current consumption increases as much as current flows into the pull-up / pull-down resistor when; the ON / OFF pin is connected to the VIN pin in the A / C type, the ON / OFF pin is connected to the VSS pin in the E / G type. 25 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00  Precautions • Wiring patterns for the VIN pin, the VOUT pin and GND should be designed so that the impedance is low. When mounting an output capacitor between the VOUT pin and the VSS pin (CL1, CL2) and a capacitor for stabilizing the input between the VIN pin and the VSS pin (CIN), the distance from the capacitors to these pins should be as short as possible. • Note that generally the output voltage may increase when a series regulator is used at low load current (1.0 mA or less). • Note that generally the output voltage may increase due to the leakage current from an output driver when a series regulator is used at high temperature. • Generally a series regulator may cause oscillation, depending on the selection of external parts. The following conditions are recommended for the S-1711 Series. However, be sure to perform sufficient evaluation under the actual usage conditions for selection, including evaluation of temperature characteristics. Input capacitor (CIN): Output capacitor (CL1, CL2): Equivalent series resistance (ESR): 1.0 μF or more 1.0 μF or more 1.0 Ω or less Use input/output capacitor which has good temperature characteristics (conforming to the ceramic capacitor EIA X5R (JIS B) characteristics). • The voltage regulator may oscillate when the impedance of the power supply is high and the input capacitance is small or an input capacitor is not connected. • If the output capacitance is small, power supply’s fluctuation and the characteristics of load fluctuation become worse. Sufficiently evaluate the output voltage’s fluctuation with the actual device. • Overshoot may occur in the output voltage momentarily if the voltage is rapidly raised at power-on or when the power supply fluctuates. Sufficiently evaluate the output voltage at power-on with the actual device. • The application conditions for the input voltage, the output voltage, and the load current should not exceed the package power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • In determining the output current, attention should be paid to the output current value specified in Table 13 in “ Electrical Characteristics” and footnote *5 of the table. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 26 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00  Characteristics (Typical Data) (Per circuit) 1. Output Voltage vs. Output Current (When Load Current Increases) (Ta = 25°C) 1.5 VIN = 1.8 V 2.0 V 2.5 V 6.5 V 1.0 0.5 0 0 100 VOUT = 3.0 V 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 VOUT [V] VOUT [V] VOUT = 1.5 V 2.0 200 IOUT [mA] 300 400 VIN = 3.3 V 3.5 V 4.0 V 6.5 V 0 100 200 IOUT [mA] 300 400 VOUT = 5.0 V 6 VOUT [V] 5 VIN = 5.3 V 5.5 V 6.0 V 6.5 V 4 3 2 Remark In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *5 specified in Table 13 in the “ Electrical Characteristics” 2. The package power dissipation 1 0 2. 0 100 200 IOUT [mA] 300 400 Output Voltage vs. Input Voltage (Ta = 25°C) VOUT = 1.5 V 1.6 VOUT = 3.0 V 3.1 3.0 1.4 VOUT [V] VOUT [V] 1.5 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA 1.3 1.2 1.1 2.9 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA 2.8 2.7 2.6 1.0 2.5 1.0 1.5 2.0 2.5 VIN [V] 3.0 3.5 2.5 3.0 3.5 4.0 VIN [V] 4.5 5.0 VOUT = 5.0 V 5.5 VOUT [V] 5.0 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA 4.5 4.0 3.5 3.0 2.5 2.0 3.0 4.0 5.0 VIN [V] 6.0 7.0 27 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Dropout Voltage vs. Output Current VOUT = 1.5 V 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 VOUT = 3.0 V 0.25 Vdrop [V] -40 °C 200 150 Vdrop [V] 85 °C 25 °C -40 °C 0 100 IOUT [mA] 50 200 150 Dropout Voltage vs. Set Output Voltage Vdrop [V] 25 °C 0.10 -40 °C 0 100 IOUT [mA] 50 VOUT = 5.0 V 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 150 mA 100 mA 80 mA 50 mA 30 mA 10 mA 0 28 85 °C 0.15 0.05 0 4. 0.20 85 °C 25 °C Vdrop [V] 3. Rev.3.2_00 1 2 3 4 VOUT(S) [V] 5 6 0 50 100 IOUT [mA] 150 200 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00 5. Output Voltage vs. Ambient Temperature VOUT = 1.5 V 1.60 VOUT = 3.0 V 3.20 3.15 3.10 3.05 3.00 2.95 2.90 2.85 2.80 VOUT [V] VOUT [V] 1.55 1.50 1.45 1.40 -40 -25 0 25 Ta [°C] 50 75 85 -40 -25 0 25 Ta [°C] 50 75 85 -40 -25 0 25 Ta [°C] 50 75 85 VOUT = 5.0 V 5.3 VOUT [V] 5.2 5.1 5.0 4.9 4.8 4.7 Current Consumption vs. Input Voltage ISS1 [μA] VOUT = 1.5 V 100 90 80 70 60 50 40 30 20 10 0 25 °C -40 °C ISS1 [μA] VOUT = 5.0 V 100 90 80 70 60 50 40 30 20 10 0 85 °C 0 1 2 VOUT = 3.0 V 100 90 80 70 60 50 40 30 20 10 0 ISS1 [μA] 6. 3 4 VIN [V] 5 6 7 3 4 VIN [V] 5 6 7 85 °C 25 °C -40 °C 0 1 2 3 4 VIN [V] 5 6 7 25 °C 85 °C -40 °C 0 1 2 29 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series 7. Rev.3.2_00 Ripple Rejection (Ta = 25°C) VOUT = 1.5 V VOUT = 3.0 V 100 80 60 IOUT = 1 mA IOUT = 30 mA IOUT = 150 mA 40 20 0 10 100 1k 10k 100k Frequency [Hz] VIN = 4.0 V, CLn = 1.0 μF Ripple Rejection [dB] Ripple Rejection [dB] VIN = 2.5 V, CLn = 1.0 μF 100 80 40 1M Ripple Rejection [dB] VIN = 6.0 V, CLn = 1.0 μF 100 IOUT = 1 mA 60 40 IOUT = 30 mA IOUT = 150 mA 20 0 10 100 1k 10k 100k Frequency [Hz] 1M Remark CLn: Output capacitor set to the VOUTn pin externally (n = 1, 2) 30 IOUT = 30 mA IOUT = 150 mA 20 VOUT = 5.0 V 80 IOUT = 1 mA 60 0 10 100 1k 10k 100k Frequency [Hz] 1M Rev.3.2_00 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series  Reference Data (Per circuit) Input Transient Response Characteristics (Ta = 25°C) Common to VR1 and 2 VOUT [V] 3 VOUT 3.00 2 1 0 2.98 -40 -20 0 20 40 60 80 100 120 140 t [μs] Load Transient Response Characteristics (Ta = 25°C) 1.60 1.55 1.50 IOUT 100 3.15 50 3.10 0 VOUT -50 IOUT [mA] 1.65 VOUT = 3.0 V VIN = 4.0 V, CLn = 1.0 μF, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA 3.20 150 100 IOUT 3.05 50 0 VOUT 3.00 -50 1.45 -100 2.95 -100 1.40 -150 2.90 -150 -20 -10 0 10 20 30 40 50 60 70 t [μs] -20 -10 0 IOUT [mA] VOUT = 1.5 V VIN = 2.5 V, CLn = 1.0 μF, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA 1.70 150 VOUT [V] 3.01 4 2.99 VOUT [V] 2. 5 VIN 3.02 VIN [V] 8 7 6 5 4 3 2 1 0 3.03 VOUT [V] VOUT = 5.0 V IOUT = 30 mA, tr = tf = 5.0 μs, CLn = 1.0 μF, CIN = 1.0 μF 5.06 5.05 VIN 5.04 5.03 5.02 5.01 VOUT 5.00 4.99 4.98 -40 -20 0 20 40 60 80 100 120 140 t [μs] VOUT = 3.0 V IOUT = 30 mA, tr = tf = 5.0 μs, CLn = 1.0 μF, CIN = 1.0 μF 3.04 6 VIN [V] 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 VOUT [V] VOUT = 1.5 V IOUT = 30 mA, tr = tf = 5.0 μs, CLn = 1.0 μF, CIN = 1.0 μF 1.56 1.55 VIN 1.54 1.53 1.52 1.51 VOUT 1.50 1.49 1.48 -40 -20 0 20 40 60 80 100 120 140 t [μs] VIN [V] 1. 10 20 30 40 50 60 70 t [μs] VOUT = 5.0 V VIN =6.0 V, CLn = 1.0 μF, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA 5.20 150 5.10 5.05 5.00 100 IOUT 50 0 VOUT -50 4.95 -100 4.90 -150 -20 -10 0 IOUT [mA] VOUT [V] 5.15 10 20 30 40 50 60 70 t [μs] Remark CLn: Output capacitor set to the VOUTn pin externally (n = 1, 2) 31 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series VOUT [V] 4. VON/OFF [V] VOUT = 3.0 V VIN = 4.0 V, CLn = 1.0 μF, CIN = 1.0 μF, IOUT = 100 mA 6 7 6 4 VON/OFF 5 2 4 0 -2 3 2 -4 1 -6 VOUT 0 -8 -1 -10 0 -50 200 50 150 100 t [μs] VOUT [V] VOUT [V] VOUT = 1.5 V VIN = 2.5 V, CLn = 1.0 μF, CIN = 1.0 μF, IOUT = 100 mA 3 3.5 3.0 2 VON/OFF 2.5 1 2.0 0 -1 1.5 1.0 -2 0.5 -3 VOUT 0 -4 -0.5 -5 0 -50 200 50 150 100 t [μs] VOUT = 5.0 V VIN = 6.0 V, CLn = 1.0 μF, CIN = 1.0 μF, IOUT = 100 mA 8 17.5 15.0 6 VON/OFF 12.5 4 10.0 2 0 7.5 5.0 -2 2.5 -4 VOUT 0 -6 -2.5 -8 0 -50 200 50 150 100 t [μs] VON/OFF [V] ON / OFF Pin Transient Response Characteristics (Ta = 25°C) VIN/OFF [V] 3. Rev.3.2_00 Output Capacitance vs. Discharge Time Characteristics (Ta = 25°C) S-1711 Series A / B type (with discharge shunt function) VIN = VOUT + 1.0 V, IOUT = no load, VON/OFF = VOUT + 1.0 V → VSS, tf = 1 μs 1 μs tDSC [ms] VON/OFF 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 VOUT(S) = 5.0 V VOUT(S) = 3.0 V VOUT(S) = 1.5 V 0 2 4 6 8 CLn [μF] 10 VSS tDSC VOUT 12 VOUT × 10% VIN = VOUT + 1.0 V VON/OFF = VOUT + 1.0 V → VSS Figure 27 Figure 28 Remark CLn: Output capacitor set to the VOUTn pin externally (n = 1, 2) 32 Measurement Condition of Discharge Time 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00  Marking Specifications 1. SNT-6A Top view 6 5 (1) to (3) (4) to (6) 4 : Product code (Refer to Product name vs. Product code) : Lot number (1) (2) (3) (4) (5) (6) 1 2 3 Product name vs. Product code (a) S-1711 Series A type Product Name S-1711A1515-I6T1U S-1711A1518-I6T1U S-1711A1526-I6T1U S-1711A1528-I6T1U S-1711A152J-I6T1U S-1711A1533-I6T1U S-1711A1815-I6T1U S-1711A1818-I6T1U S-1711A1827-I6T1U S-1711A182H-I6T1U S-1711A1828-I6T1U S-1711A182J-I6T1U S-1711A1829-I6T1U S-1711A1830-I6T1U S-1711A1833-I6T1U S-1711A1J28-I6T1U S-1711A2332-I6T1U S-1711A2333-I6T1U S-1711A2424-I6T1U S-1711A2425-I6T1U S-1711A2515-I6T1U S-1711A2518-I6T1U S-1711A2525-I6T1U S-1711A2528-I6T1U S-1711A2533-I6T1U S-1711A2626-I6T1U S-1711A2628-I6T1U S-1711A2629-I6T1U (1) Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Product code (2) (3) R Q V V Q V R V R R R V V V R R V V R R R R R V V V V V A D T I I W Y F P Q 5 S L H 7 Z U V R S L E T D E M 7 8 Product Name S-1711A2630-I6T1U S-1711A2815-I6T1U S-1711A2818-I6T1U S-1711A2828-I6T1U S-1711A2829-I6T1U S-1711A2830-I6T1U S-1711A2831-I6T1U S-1711A2832-I6T1U S-1711A2833-I6T1U S-1711A2J15-I6T1U S-1711A2J18-I6T1U S-1711A2J2J-I6T1U S-1711A2J33-I6T1U S-1711A2929-I6T1U S-1711A3015-I6T1U S-1711A3018-I6T1U S-1711A3025-I6T1U S-1711A3028-I6T1U S-1711A3030-I6T1U S-1711A3033-I6T1U S-1711A3128-I6T1U S-1711A3318-I6T1U S-1711A3333-I6T1U S-1711A3348-I6T1U S-1711A3350-I6T1U S-1711A3434-I6T1U S-1711A5025-I6T1U S-1711A5030-I6T1U (1) Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Product code (2) (3) V R R R R R Q R R Q Q R Q R R R R V R R Q V R V V V V R 9 U V B 2 D A F G F G H C J X W M Z K N B R 3 J 2 6 3 8 33 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series (b) S-1711 Series B type Product Name S-1711B1518-I6T1U S-1711B1528-I6T1U S-1711B1825-I6T1U S-1711B1828-I6T1U S-1711B1833-I6T1U S-1711B2518-I6T1U S-1711B2528-I6T1U S-1711B2815-I6T1U S-1711B2818-I6T1U S-1711B2828-I6T1U S-1711B2833-I6T1U S-1711B3033-I6T1U S-1711B3333-I6T1U (d) S-1711 Series D type Product code (1) (2) (3) Q Q Q Q Q Q Q Q Q Q Q Q Q U Z U U U U U U U U Z Z Z H C K B J A C D E F D A B (c) S-1711 Series C type Product Name S-1711C1515-I6T1U S-1711C1815-I6T1U S-1711C1827-I6T1U S-1711C182H-I6T1U S-1711C1828-I6T1U S-1711C1J28-I6T1U S-1711C2424-I6T1U S-1711C2425-I6T1U S-1711C2515-I6T1U S-1711C2518-I6T1U S-1711C2525-I6T1U S-1711C2815-I6T1U S-1711C2818-I6T1U S-1711C2828-I6T1U S-1711C2829-I6T1U S-1711C2830-I6T1U S-1711C2833-I6T1U S-1711C2J2J-I6T1U S-1711C2929-I6T1U S-1711C3015-I6T1U S-1711C3018-I6T1U S-1711C3025-I6T1U S-1711C3030-I6T1U S-1711C3033-I6T1U 34 Rev.3.2_00 Product Name S-1711D1828-I6T1U S-1711D1925-I6T1U S-1711D2518-I6T1U S-1711D2528-I6T1U S-1711D252J-I6T1U S-1711D2815-I6T1U S-1711D2J2J-I6T1U (1) Q Q Q Q Q Q Q Product code (2) (3) U U U U U U U N R O P Y Q U (e) S-1711 Series E type Product code (1) (2) (3) Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q S S S S S S S S S S S S S S S S S S S S S S S S A B C D Z E F G H I J K L M N O P Q R S T U V W Product Name S-1711E2818-I6T1U (1) Q Product code (2) (3) T A (f) S-1711 Series F type Product Name S-1711F2818-I6T1U Product code (1) (2) (3) Q T F (g) S-1711 Series G type Product Name S-1711G2830-I6T1U (1) Q Product code (2) (3) T K 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series Rev.3.2_00 2. SOT-23-6 Top view 6 5 4 (1) to (3): (4): Product code (Refer to Product name vs. Product code) Lot number (1) (2) (3) (4) 1 2 3 Product name vs. Product code (a) S-1711 Series A type Product Name (1) Product code (2) (3) Product Name (1) Product code (2) (3) S-1711A1515-M6T1x Q R A S-1711A2718-M6T1x Q S-1711A1528-M6T1x Q V I S-1711A2815-M6T1x Q S-1711A1529-M6T1x Q V K S-1711A2818-M6T1x Q S-1711A1533-M6T1x Q V W S-1711A2819-M6T1x Q S-1711A1815-M6T1x Q R Y S-1711A2825-M6T1x Q S-1711A1818-M6T1x Q V F S-1711A2828-M6T1x Q S-1711A1825-M6T1x Q R 4 S-1711A2829-M6T1x Q S-1711A1827-M6T1x Q R P S-1711A2830-M6T1x Q S-1711A182H-M6T1x Q R Q S-1711A2832-M6T1x Q S-1711A1828-M6T1x Q R 5 S-1711A2833-M6T1x Q S-1711A182J-M6T1x Q V S S-1711A2J2J-M6T1x Q S-1711A1829-M6T1x Q V L S-1711A2J30-M6T1x Q S-1711A1830-M6T1x Q V H S-1711A2929-M6T1x Q S-1711A1832-M6T1x Q V N S-1711A2933-M6T1x Q S-1711A1833-M6T1x Q R 7 S-1711A3015-M6T1x Q S-1711A1J28-M6T1x Q R Z S-1711A3018-M6T1x Q S-1711A2045-M6T1x Q V G S-1711A3025-M6T1x Q S-1711A2424-M6T1x Q R R S-1711A3030-M6T1x Q S-1711A2425-M6T1x Q R S S-1711A3033-M6T1x Q S-1711A2515-M6T1x Q R L S-1711A3325-M6T1x Q S-1711A2518-M6T1x Q R E S-1711A3328-M6T1x Q S-1711A2522-M6T1x Q V O S-1711A3330-M6T1x Q S-1711A2525-M6T1x Q R T S-1711A3333-M6T1x Q S-1711A2528-M6T1x Q V D S-1711A3348-M6T1x Q S-1711A2529-M6T1x Q R 9 S-1711A4020-M6T1x Q S-1711A2533-M6T1x Q V E S-1711A5025-M6T1x Q S-1711A2618-M6T1x Q V 4 Remark 1. x: G or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. V R R V V R R R R R R V R V R R R R R V V R R V V V 5 U V P C B 2 D F G H X J Y X W M K N A B 6 3 J Q 3 35 6.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR S-1711 Series (b) S-1711 Series B type Product Name S-1711B1518-M6T1x S-1711B1529-M6T1x S-1711B1825-M6T1x S-1711B1828-M6T1x S-1711B1832-M6T1x S-1711B1833-M6T1x S-1711B2515-M6T1x S-1711B2518-M6T1x S-1711B2528-M6T1x S-1711B2618-M6T1x S-1711B2718-M6T1x S-1711B2815-M6T1x S-1711B2818-M6T1x S-1711B2825-M6T1x S-1711B2828-M6T1x S-1711B3030-M6T1x S-1711B3033-M6T1x S-1711B3036-M6T1x S-1711B3333-M6T1x (d) S-1711 Series D type Product code (1) (2) (3) Q U H Q U I Q U K Q U B Q U M Q U J Q U G Q U A Q U C Q Z G Q Z H Q U D Q U E Q U L Q U F Q Z I Q Z A Q Z F Q Z B (c) S-1711 Series C type Product Name Rev.3.2_00 Product Name S-1711D1825-M6T1x S-1711D1826-M6T1x S-1711D1828-M6T1x S-1711D1832-M6T1x S-1711D1925-M6T1x S-1711D2518-M6T1x S-1711D2528-M6T1x S-1711D2629-M6T1x S-1711D2815-M6T1x S-1711D4230-M6T1x (1) Q Q Q Q Q Q Q Q Q Q Product code (2) (3) U S U W U N U T U R U O U P U X U Q U V (1) Q Q Q Product code (2) (3) T C T A T B (e) S-1711 Series E type Product code (1) (2) (3) Q S A Q S B Q S 2 Q S C Q S D Q S X Q S E Q S F Q S G Q S H Q S I Q S J Q S K Q S L Q S M Q S N Q S O Q S P Q S Q Q S R Q S S Q S T Q S U Q S V Q S W Q S Y Product Name S-1711C1515-M6T1x S-1711E1833-M6T1x S-1711C1815-M6T1x S-1711E2818-M6T1x S-1711C1825-M6T1x S-1711E3333-M6T1x S-1711C1827-M6T1x S-1711C182H-M6T1x (f) S-1711 Series H type S-1711C1832-M6T1x S-1711C1J28-M6T1x Product code Product Name S-1711C2424-M6T1x (1) (2) (3) S-1711C2425-M6T1x S-1711H2518-M6T1x Q T P S-1711C2515-M6T1x S-1711C2518-M6T1x S-1711C2525-M6T1x S-1711C2815-M6T1x S-1711C2818-M6T1x S-1711C2828-M6T1x S-1711C2829-M6T1x S-1711C2830-M6T1x S-1711C2833-M6T1x S-1711C2J2J-M6T1x S-1711C2929-M6T1x S-1711C3015-M6T1x S-1711C3018-M6T1x S-1711C3025-M6T1x S-1711C3030-M6T1x S-1711C3033-M6T1x S-1711C3131-M6T1x Remark 1. x: G or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 36 1.57±0.03 6 1 5 4 2 3 +0.05 0.08 -0.02 0.5 0.48±0.02 0.2±0.05 No. PG006-A-P-SD-2.1 TITLE SNT-6A-A-PKG Dimensions No. PG006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 4.0±0.1 2.0±0.05 0.25±0.05 +0.1 1.85±0.05 ø0.5 -0 4.0±0.1 0.65±0.05 3 2 1 4 5 6 Feed direction No. PG006-A-C-SD-2.0 TITLE SNT-6A-A-Carrier Tape No. PG006-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PG006-A-R-SD-1.0 SNT-6A-A-Reel TITLE No. PG006-A-R-SD-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 5,000 0.52 1.36 2 0.52 0.2 0.3 1. 2. 1 (0.25 mm min. / 0.30 mm typ.) (1.30 mm ~ 1.40 mm) 0.03 mm SNT 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package ( 1.30 mm ~ 1.40 mm ). Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. 1. 2. (0.25 mm min. / 0.30 mm typ.) (1.30 mm ~ 1.40 mm) No. PG006-A-L-SD-4.1 TITLE SNT-6A-A -Land Recommendation No. PG006-A-L-SD-4.1 ANGLE UNIT mm ABLIC Inc. 2.9±0.2 1.9±0.2 6 0.95 4 5 1 2 3 +0.1 0.15 -0.05 0.95 0.35±0.15 No. MP006-A-P-SD-2.1 TITLE SOT236-A-PKG Dimensions No. MP006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 6 Feed direction No. MP006-A-C-SD-3.1 TITLE SOT236-A-Carrier Tape No. MP006-A-C-SD-3.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP006-A-R-SD-2.1 TITLE SOT236-A-Reel No. MP006-A-R-SD-2.1 ANGLE QTY UNIT mm ABLIC Inc. 3,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-1711C2525-M6T1U
物料型号:S-1711系列
器件简介: S-1711系列是一款基于CMOS技术开发的2通道正电压调节器,具有低 dropout 电压、高精度输出电压和低电流消耗(150 mA输出电流)。该系列提供了A、B、E、F等不同型号,具备放电旁路功能,允许高速输出响应。S-1711系列采用SOT-23-6或超小型SNT-6A封装,适合移动设备使用。
引脚分配: - SNT-6A和SOT-23-6封装的1号引脚为VOUT1(第一个输出电压引脚) - 2号引脚为VIN(输入电压引脚) - 3号引脚为VOUT2(第二个输出电压引脚) - 4号引脚为ON/OFF2(第二个通道的开关控制引脚) - 5号引脚为VSS(地引脚) - 6号引脚为ON/OFF1(第一个通道的开关控制引脚)
参数特性: - 输出电压:1.5 V至5.5 V,以0.1 V步进选择 - 输入电压:2.0 V至6.5 V - 输出电压精度:±1.0% - Dropout电压:典型值200 mV(3.0 V输出产品,IOUT = 150 mA) - 工作时电流消耗:典型值70 μA,最大90 μA(每个电路) - 关闭时电流消耗:典型值0.1 μA,最大1.0 μA - 输出电流:每个电路可达150 mA(VIN ≥ VOUT(S) + 1.0 V) - 纹波抑制:典型值70 dB(f = 1.0 kHz) - 内置过流保护电路:限制输出晶体管的过流 - 工作温度范围:Ta = −40°C至+85°C
功能详解: S-1711系列提供了多种功能,包括但不限于: - 可编程的输出电压 - 低dropout电压操作 - 内置的过流保护 - ON/OFF控制功能,具有放电旁路功能 - 可选的上拉/下拉电阻功能
应用信息: 适用于手机的恒压电源、电池供电设备的恒压电源、家用电器的恒压电源等。
封装信息: - SNT-6A封装 - SOT-23-6封装
S-1711C2525-M6T1U 价格&库存
很抱歉,暂时无法提供与“S-1711C2525-M6T1U”相匹配的价格&库存,您可以联系我们找货
S-1711C2525-M6T1U
  • 3000+6.174103000+0.80028
  • 6000+5.865396000+0.76027
  • 15000+5.6448915000+0.73169
