AL1101
AL1101
    IFM(易福门)
    IO-LINK MASTER STANDARDLINE; NUM
AL1101 数据手册
AL1101 IO-Link master with PROFINET interface IO-Link Master SL PN 4P IP69K Application Application hygienic systems; I/O modules for field applications Daisy-chain function fieldbus interface Electrical data Operating voltage Current consumption [V] [mA] Protection class 20...30 DC; (US; to SELV/PELV) 300...3900; (US) III Sensor supply US Max. current load total [A] 3.6 Inputs / outputs Total number of inputs and outputs Number of inputs and outputs 8; (configurable) Number of digital inputs: 8; Number of digital outputs: 4 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AL1101-00 — 24.03.2017 — AL1101 IO-Link master with PROFINET interface IO-Link Master SL PN 4P IP69K Inputs Number of digital inputs 8; (IO-Link Port Class A: 4 x 2) Switching level high [V] 11...30 Switching level low [V] 0...5 Digital inputs protected against short circuits yes Outputs Number of digital outputs Max. current load per output 4; (IO-Link Port Class A: 4 x 1) [mA] 300 Short-circuit proof yes Interfaces Communication interface Ethernet; IO-Link Ethernet - PROFINET Transmission standard 10Base-T; 100Base-TX Transmission rate 10; 100 Protocol PROFINET IP address: 0.0.0.0 subnet mask: 0.0.0.0 Factory settings gateway IP address: 0.0.0.0 MAC address: see type label CC-C (Conformance Class C) (IRT-Switch) Netload Class III SNMP (Simple Network Management Protocol) Note on interfaces MRP (Media Redundancy Protocol) Supported network topologies: line ring IO-Link Master Transmission type COM1 (4,8 kBaud); COM2 (38,4 kBaud); COM3 (230,4 kBaud) IO-Link revision 1.1 Number of ports class A 4 Operating conditions Ambient temperature [°C] -25...60 Storage temperature [°C] -25...85 Max. relative air humidity [%] 90 Protection IP 65; IP 66; IP 67; IP 69K; (operation with stainless steel protective caps: IP 69K) Degree of soiling 2 Tests / approvals EN 61000-6-2 EMC EN 61000-6-4 Shock resistance DIN EN 60068-2-27 DIN EN 60068-2-64 2009-04 Vibration resistance MTTF DIN EN 60068-2-6 2008-10 [years] 96 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AL1101-00 — 24.03.2017 — AL1101 IO-Link master with PROFINET interface IO-Link Master SL PN 4P IP69K Mechanical data Weight [g] Materials 273.5 housing: PA grey; socket: stainless steel (1.4404 / 316L) Sealing material EPDM Accessories Items supplied Protective cap: 1 x M12, stainless steel, E12542 Remarks Remarks For further information please see the operating instructions. Pack quantity 1 pcs. Electrical connection - Ethernet Connector: M12; Sealing: EPDM IN / OUT X21, X22 1 TX + 2 RX + 3 TX - 4 RX - 5 not used Electrical connection - Process connection Connector: M12; Sealing: EPDM IO-Link Port Class A X01...X04 1 Sensor supply (US) L+ 2 digital input 3 Sensor supply (US) L- 4 C/Q IO-Link 5 not used Electrical connection - voltage supply Connector: M12 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AL1101-00 — 24.03.2017 — AL1101 IO-Link master with PROFINET interface IO-Link Master SL PN 4P IP69K X31 1 + 24 V DC (US) 2 not used 3 GND (US) 4 not used ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AL1101-00 — 24.03.2017 —
AL1101 价格&库存
很抱歉,暂时无法提供与“AL1101”相匹配的价格&库存,您可以联系我们找货
AL1101
  • 1+5152.56871
库存:1
