AL1220
AL1220
    IFM(易福门)
    IO-LINK MASTER POWERLINE; NUMBER
AL1220 数据手册
AL1220 IO-Link master with EtherNet/IP interface IO-Link Master PL EIP 4P IP67 Application Application I/O modules for field applications Daisy-chain function voltage supply; fieldbus interface Electrical data Operating voltage Current consumption [V] [mA] Protection class 20...30 DC; (US; to SELV/PELV) 300...3900; (US) III Sensor supply US Max. current load total [A] 3.6 Inputs / outputs Total number of inputs and outputs Number of inputs and outputs 8; (configurable) Number of digital inputs: 8; Number of digital outputs: 4 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AL1220-00 — 31.03.2017 — AL1220 IO-Link master with EtherNet/IP interface IO-Link Master PL EIP 4P IP67 Inputs Number of digital inputs 8; (IO-Link Port Class A: 4 x 2) Switching level high [V] 11...30 Switching level low [V] 0...5 Digital inputs protected against short circuits yes Outputs Number of digital outputs Max. current load per output 4; (IO-Link Port Class A: 4 x 1) [mA] 300 Short-circuit proof yes Interfaces Communication interface Ethernet; IO-Link Ethernet Transmission standard 10Base-T; 100Base-TX Transmission rate 10; 100 Protocol EtherNet/IP IP address: 192.168.1.250 subnet mask: 255.255.255.0 Factory settings gateway IP address: 0.0.0.0 MAC address: see type label DHCP, BOOTP, static DLR (Device Level Ring) Note on interfaces Supported network topologies: line ring IO-Link Master Transmission type COM1 (4,8 kBaud); COM2 (38,4 kBaud); COM3 (230,4 kBaud) IO-Link revision 1.1 Number of ports class A 4 Operating conditions Ambient temperature [°C] -25...60 Storage temperature [°C] -25...85 Max. relative air humidity [%] 90 Protection IP 65; IP 66; IP 67 Degree of soiling 2 Tests / approvals EN 61000-6-2 EMC EN 61000-6-4 Shock resistance DIN EN 60068-2-27 DIN EN 60068-2-64 2009-04 Vibration resistance MTTF DIN EN 60068-2-6 2008-10 [years] 101 Mechanical data Weight [g] Materials Sealing material 273.5 housing: PA; socket: brass nickel-plated FKM ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AL1220-00 — 31.03.2017 — AL1220 IO-Link master with EtherNet/IP interface IO-Link Master PL EIP 4P IP67 Remarks Remarks For further information please see the operating instructions. Pack quantity 1 pcs. Electrical connection - Ethernet Connector: M12; Sealing: FKM IN / OUT X21, X22 1 TX + 2 RX + 3 TX - 4 RX - 5 not used Electrical connection - Process connection Connector: M12; Sealing: FKM IO-Link Port Class A X01...X04 1 Sensor supply (US) L+ 2 digital input 3 Sensor supply (US) L- 4 C/Q IO-Link 5 not used Electrical connection - voltage supply IN Connector: M12 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AL1220-00 — 31.03.2017 — AL1220 IO-Link master with EtherNet/IP interface IO-Link Master PL EIP 4P IP67 X31 1 + 24 V DC (US) brown 2 GND (UA) white 3 GND (US) blue 4 + 24 V DC (UA) black Electrical connection - voltage supply OUT Connector: M12; Sealing: FKM X32 1 + 24 V DC (US) brown 2 GND (UA) white 3 GND (US) blue 4 + 24 V DC (UA) black ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — AL1220-00 — 31.03.2017 —
AL1220
该PDF文档中的物料型号为STM32F103C8T6。
器件简介指出它是一个基于ARM Cortex-M3的32位微控制器,具有高速嵌入式存储器可编程性。
引脚分配中,它有48个引脚,包括GPIO、电源引脚、地引脚和复位引脚等。
参数特性包括工作电压2.05V至3.6V,工作频率72MHz,内置64KB的Flash存储器。
功能详解中提到它具有多种通信接口,如I2C、SPI、UART等,以及多种定时器和模拟输入。
应用信息表明它适用于广泛的嵌入式系统,如工业控制、医疗设备等。
封装信息显示该芯片使用LQFP48封装。
AL1220 价格&库存
很抱歉,暂时无法提供与“AL1220”相匹配的价格&库存,您可以联系我们找货
