LM2902M
LM2902M
    L3HARRIS
    SOIC14
    IC GP OPAMP 4 CIRCUIT 14SOP
LM2902M 数据手册
Is Now Part of To learn more about ON Semiconductor, please visit our website at www.onsemi.com Please note: As part of the Fairchild Semiconductor integration, some of the Fairchild orderable part numbers will need to change in order to meet ON Semiconductor’s system requirements. Since the ON Semiconductor product management systems do not have the ability to manage part nomenclature that utilizes an underscore (_), the underscore (_) in the Fairchild part numbers will be changed to a dash (-). This document may contain device numbers with an underscore (_). Please check the ON Semiconductor website to verify the updated device numbers. The most current and up-to-date ordering information can be found at www.onsemi.com. Please email any questions regarding the system integration to Fairchild_questions@onsemi.com. ON Semiconductor and the ON Semiconductor logo are trademarks of Semiconductor Components Industries, LLC dba ON Semiconductor or its subsidiaries in the United States and/or other countries. ON Semiconductor owns the rights to a number of patents, trademarks, copyrights, trade secrets, and other intellectual property. A listing of ON Semiconductor’s product/patent coverage may be accessed at www.onsemi.com/site/pdf/Patent-Marking.pdf. ON Semiconductor reserves the right to make changes without further notice to any products herein. ON Semiconductor makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ON Semiconductor assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. Buyer is responsible for its products and applications using ON Semiconductor products, including compliance with all laws, regulations and safety requirements or standards, regardless of any support or applications information provided by ON Semiconductor. “Typical” parameters which may be provided in ON Semiconductor data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. ON Semiconductor does not convey any license under its patent rights nor the rights of others. ON Semiconductor products are not designed, intended, or authorized for use as a critical component in life support systems or any FDA Class 3 medical devices or medical devices with a same or similar classification in a foreign jurisdiction or any devices intended for implantation in the human body. Should Buyer purchase or use ON Semiconductor products for any such unintended or unauthorized application, Buyer shall indemnify and hold ON Semiconductor and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that ON Semiconductor was negligent regarding the design or manufacture of the part. ON Semiconductor is an Equal Opportunity/Affirmative Action Employer. This literature is subject to all applicable copyright laws and is not for resale in any manner. www.fairchildsemi.com LM324/LM324A, LM2902/LM2902A Quad Operational Amplifier Features Description • Internally Frequency Compensated for Unity Gain • Large DC Voltage Gain: 100dB • Wide Power Supply Range: LM324/LM324A : 3V~32V (or ±1.5 ~ 16V) LM2902/LM2902A: 3V~26V (or ±1.5V ~ 13V) • Input Common Mode Voltage Range Includes Ground • Large Output Voltage Swing: 0V to VCC -1.5V • Power Drain Suitable for Battery Operation The LM324/LM324A, LM2902/LM2902A consist of four independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide voltage range. operation from split power supplies is also possible so long as the difference between the two supplies is 3 volts to 32 volts. Application areas include transducer amplifier, DC gain blocks and all the conventional OP Amp circuits which now can be easily implemented in single power supply systems. 14-DIP 1 14-SOP 1 Internal Block Diagram 14 OUT4 OUT1 1 IN1 (-) 2 IN1 (+) 3 1 _ + + 4 _ 13 IN4 (-) 12 IN4 (+) VCC 4 11 GND IN2 (+) 5 _ + IN2 (-) 6 2 OUT2 7 + _ 10 IN3 (+) 3 9 IN3 (-) 8 OUT3 Rev. 1.0.9 ©2012 Fairchild Semiconductor Corporation LM324/LM324A, LM2902/LM2902A Schematic Diagram (One Section Only) VCC Q5 Q12 Q6 Q17 Q19 Q20 Q2 Q3 R1 C1 Q4 IN(-) Q18 Q1 R2 IN(+) Q11 OUTPUT Q21 Q10 Q7 Q8 Q9 Q15 Q13 Q14 Q16 GND Absolute Maximum Ratings Parameter Symbol LM324/LM324A LM2902/LM2902A Unit VCC ±16 or 32 ±13 or 26 V VI(DIFF) 32 26 V Input Voltage VI -0.3 to +32 -0.3 to +26 V Output Short Circuit to GND Vcc≤15V, TA=25°C(one Amp) - Continuous Continuous - PD 1310 640 1310 640 mW Operating Temperature Range TOPR 0 ~ +70 -40 ~ +85 °C Storage Temperature Range TSTG -65 ~ +150 -65 ~ +150 °C Power Supply Voltage Differential Input Voltage Power Dissipation, TA=25°C 14-DIP 14-SOP Thermal Data Parameter Thermal Resistance Junction-Ambient Max. 14-DIP 14-SOP 2 Symbol Value Unit Rθja 95 195 °C/W LM324/LM324A, LM2902/LM2902A Electrical Characteristics (VCC = 5.0V, VEE = GND, TA = 25°C, unless otherwise specified) Parameter Symbol Conditions Input Offset Voltage VIO Input Offset Current LM324 LM2902 Unit Min. Typ. Max. Min. Typ. Max. VCM = 0V to VCC -1.5V VO(P) = 1.4V, RS = 0Ω (Note1) - 1.5 7.0 - 1.5 7.0 mV IIO VCM = 0V - 3.0 50 - 3.0 50 nA Input Bias Current IBIAS VCM = 0V - 40 250 - 40 250 nA Input Common-Mode Voltage Range VI(R) Note1 0 - VCC -1.5 0 - VCC -1.5 V Supply Current ICC RL = ∞,VCC = 30V (LM2902,VCC=26V) - 1.0 3 - 1.0 3 mA RL = ∞,VCC = 5V - 0.7 1.2 - 0.7 1.2 mA VCC = 15V,RL=2kΩ VO(P) = 1V to 11V 25 100 - 25 100 - V/mV RL = 2kΩ 26 - - 22 - - V RL=10kΩ 27 28 - 23 24 - V - 5 20 - 5 100 mV Large Signal Voltage Gain Output Voltage Swing GV VO(H) Note1 VO(L) VCC = 5V, RL=10kΩ Common-Mode Rejection Ratio CMRR - 65 75 - 50 75 - dB Power Supply Rejection Ratio PSRR - 65 100 - 50 100 - dB Channel Separation CS f = 1kHz to 20kHz (Note2) - 120 - - 120 - dB Short Circuit to GND ISC VCC = 15V - 40 60 - 40 60 mA VI(+) = 1V, VI(-) = 0V VCC = 15V, VO(P) = 2V 20 40 - 20 40 - mA VI(+) = 0V, VI(-) = 1V VCC = 15V, VO(P) = 2V 10 13 - 10 13 - mA VI(+) = 0V, VI(-) = 1V VCC = 15V, VO(R) = 200mV 12 45 - - - - μA - - VCC - - VCC V ISOURCE Output Current ISINK Differential Input Voltage VI(DIFF) - Note : 1. VCC=30V for LM324 , VCC = 26V for LM2902 2. This parameter, although guaranteed, is not 100% tested in production. 3 LM324/LM324A, LM2902/LM2902A Electrical Characteristics (Continued) (VCC = 5.0V, VEE = GND, unless otherwise specified) The following specification apply over the range of 0°C ≤ TA ≤ +70°C for the LM324 ; and the -40°C ≤ TA ≤ +85°C for the LM2902 Parameter Input Offset Voltage Input Offset Voltage Drift Input Offset Current Input Offset Current Drift LM324 Conditions VIO VICM = 0V to VCC -1.5V VO(P) = 1.4V, RS = 0Ω (Note1) - - 9.0 - - 10.0 mV RS = 0Ω (Note2) - 7.0 - - 7.0 - μV/°C VCM = 0V - - 150 - - 200 nA RS = 0Ω (Note2) - 10 - - 10 - pA/°C ΔVIO/ΔT IIO ΔIIO/ΔT Min. Typ. Max. Min. Typ. Max. Unit Input Bias Current IBIAS VCM = 0V - - 500 - - 500 nA Input Common-Mode Voltage Range VI(R) Note1 0 - VCC -2.0 0 - VCC -2.0 V Large Signal Voltage Gain GV VCC = 15V, RL = 2.0kΩ VO(P) = 1V to 11V 15 - - 15 - - V/mV RL=2kΩ 26 - - 22 - - V RL=10kΩ 27 28 - 23 24 - V - 5 20 - 5 100 mV Output Voltage Swing VO(H) VO(L) Differential Input Voltage Note1 VCC = 5V, RL=10kΩ ISOURCE VI(+) = 1V, VI(-) = 0V VCC = 15V, VO(P) = 2V 10 20 - 10 20 - mA ISINK VI(+) = 0V, VI(-) = 1V VCC = 15V, VO(P) = 2V 5 8 - 5 8 - mA VI(DIFF) - - - VCC - - VCC V Output Current Note: 1. VCC=30V for LM324 , VCC = 26V for LM2902 2. These parameters, although guaranteed, are not 100% tested in production. 4 LM2902 Symbol LM324/LM324A, LM2902/LM2902A Electrical Characteristics (Continued) (VCC = 5.0V, VEE = GND, TA = 25°C, unless otherwise specified) Parameter LM324A LM2902A Symbol Conditions Input Offset Voltage VIO VCM = 0V to VCC -1.5V VO(P) = 1.4V, RS = 0Ω (Note1) - 1.5 3.0 - 1.5 2.0 mV Input Offset Current IIO VCM = 0V - 3.0 30 - 3.0 50 nA Input Bias Current IBIAS VCM = 0V - 40 100 - 40 250 nA Input Common-Mode Voltage Range VI(R) VCC = 30V 0 - VCC -1.5 0 - VCC -1.5 V Supply Current ICC VCC = 30V, RL = ∞ (LM2902,VCC=26V) - 1.5 3 - 1.0 3 mA VCC = 5V, RL = ∞ - 0.7 1.2 - 0.7 1.2 mA 25 100 - 25 100 - V/mV RL = 2kΩ 26 - - 22 - - V RL = 10kΩ 27 28 - 23 24 - V - 5 20 - 5 100 mV Large Signal Voltage Gain Output Voltage Swing GV Min. Typ. Max. Min. VCC = 15V, RL= 2kΩ VO(P) = 1V to 11V VO(H) Note1 VO(L) VCC = 5V, RL=10kΩ Typ. Max. Unit Common-Mode Rejection Ratio CMRR - 65 85 - 50 75 - dB Power Supply Rejection Ratio PSRR - 65 100 - 50 100 - dB Channel Separation CS f = 1kHz to 20kHz (Note2) - 120 - - 120 - dB Short Circuit to GND ISC VCC = 15V - 40 60 - 40 60 mA VI(+) = 1V, VI(-) = 0V VCC =15V, VO(P) = 2V 20 40 - 20 40 - mA VI(+) = 0V, VI(-) = 1V VCC = 15V, VO(P) = 2V 10 20 - 10 13 - mA VI(+) = 0V, VI(-) = 1V VCC = 15V, VO(P) = 200mV 12 50 - - - - μA - - VCC - - VCC V ISOURCE Output Current ISINK Differential Input Voltage VI(DIFF) - Note: 1. VCC=30V for LM324A ; VCC=26V for LM2902A 2. This parameter, although guaranteed, is not 100% tested in production. 5 LM324/LM324A, LM2902/LM2902A Electrical Characteristics (Continued) (VCC = 5.0V, VEE = GND, unless otherwise specified) The following specification apply over the range of 0°C ≤ TA ≤ +70°C for the LM324A ; and the -40°C ≤ TA ≤ +85°C for the LM2902A Parameter Input Offset Voltage Input Offset Voltage Drift Input Offset Current Input Offset Current Drift Symbol Conditions VIO ΔVIO/ΔT IIO ΔIIO/ΔT Input Bias Current IBIAS Input Common-Mode Voltage Range VI(R) Large Signal Voltage Gain Output Voltage Swing GV Unit Typ. Max. Min. Typ. Max. VCM = 0V to VCC -1.5V VO(P) = 1.4V, RS = 0Ω (Note1) - - 5.0 - - 6.0 mV RS = 0Ω (Note2) - 7.0 30 - 7.0 - μV/°C VCM = 0V - - 75 - - 200 nA RS = 0Ω (Note2) - 10 300 - 10 - pA/°C - 40 200 - - 500 nA Note1 0 - VCC -2.0 0 - VCC -2.0 V VCC = 15V, RL= 2.0kΩ 15 - - 15 - - V/mV RL = 2kΩ 26 - - 22 - - V RL = 10kΩ 27 28 - 23 24 - V - 5 20 - 5 100 mV - Note1 VO(L) VCC = 5V, RL= 10kΩ ISOURCE VI(+) = 1V, VI(-) = 0V VCC = 15V, VO(P) = 2V 10 20 - 10 20 - mA ISINK VI(+) = 0V, VI(-) = 1V VCC = 15V, VO(P) = 2V 5 8 - 5 8 - mA VI(DIFF) - - - VCC - - VCC V Note: 1. VCC=30V for LM324A ; VCC=26V for LM2902A. 2. These parameters, although guaranteed, are not 100% tested in production. 6 LM2902A Min. VO(H) Output Current Differential Input Voltage LM324A LM324/LM324A, LM2902/LM2902A Typical Performance Characteristics Supply Voltage(v) Figure 1. Input Voltage Range vs Supply Voltage Supply Voltage (V) Figure 3. Supply Current vs Supply Voltage Frequency (Hz) Figure 5. Open Loop Frequency Response Temperature Tj ( °C) Figure 2. Input Current vs Temperature Supply Voltage (V) Figure 4. Voltage Gain vs Supply Voltage Frequency (Hz) Figure 6. Common mode Rejection Ratio 7 LM324/LM324A, LM2902/LM2902A Typical Performance Characteristics (Continued) 8 Figure 7. Voltage Follower Pulse Response Figure 8. Voltage Follower Pulse Response (Small Signal) Figure 9. Large Signal Frequency Response Figure 10. Output Characteristics vs Current Sourcing Figure 11. Output Characteristics vs Current Sinking Figure 12. Current Limiting vs Temperature LM324/LM324A, LM2902/LM2902A Mechanical Dimensions Package Dimensions in millimeters 2.08 ) 0.082 14-DIP 7.62 0.300 3.25 ±0.20 0.128 ±0.008 5.08 MAX 0.200 1.50 ±0.10 0.059 ±0.004 #8 2.54 0.100 #7 19.40 ±0.20 0.764 ±0.008 #14 19.80 MAX 0.780 #1 0.46 ±0.10 0.018 ±0.004 ( 6.40 ±0.20 0.252 ±0.008 0.20 0.008 MIN 3.30 ±0.30 0.130 ±0.012 +0.10 0.25 –0.05 0~15° +0.004 0.010 –0.002 9 LM324/LM324A, LM2902/LM2902A Mechanical Dimensions (Continued) Package Dimensions in millimeters 14-SOP   $   %           3,1,'   7239,(:   ( 0$; &+$0)(5237,21$/ & $   (     & $///($'7,36  0   (  & $ % (1'9,(: 6,'(9,(: *$8*( 3/$1( 127(681/(6627+(5:,6(63(&,),(' $7+,63$&.$*(5()(5(1&(72-('(&06 9$5,$7,21$% %$//',0(16,216$5(,10,//,0(7(56 &',0(16,216$5((;&/86,9(2)%8556 02/')/$6+$1'7,(%$5(;7586,216 '',0(16,216$1'72/(5$1&(6$63(5$60(
LM2902M 价格&库存
很抱歉,暂时无法提供与“LM2902M”相匹配的价格&库存,您可以联系我们找货
