UM3510DA
UM3510DA
    UNION(英联)
    WDFN6
UM3510DA 数据手册
UM3510 1A, 2.25MHz, Synchronous Step-Down DC-DC Converter UM3510S SOT23-6 UM3510DA DFN6 2.0×2.0 General Description The UM3510 is a high efficiency pulse-width-modulated (PWM) synchronous step-down DC-DC converter with an input voltage range of 2.5V to 6.0V. It provides up to 1000mA output current from a single Li-ion cell. The UM3510 operates at 2.25MHz fixed switching frequency and enters Power Save Mode to maintain high efficiency at light load condition. For low noise applications, the device can be forced into fixed frequency PWM mode by pulling the MODE pin high. The UM3510 enters shutdown mode and consumes less than 1μA when EN pin is pulled low. Other features include lower internal reference voltage with 2% accuracy, over temperature protection and over current protection. The UM3510 is available in SOT23-6 and 2mm×2mm 6-pin DFN packages. Applications Features           Cellular and Smart Phones Microprocessors and DSP Core Supplies Wireless and DSL Modems PDAs, GPS WLAN Portable Instruments     High Efficiency: Up to 95% 2.25MHz Constant Switching Frequency 1000mA Output Current Integrated Main Switch and Synchronous Rectifier. No Schottky Diode Required. 2.5V to 6.0V Input Voltage Range Low Quiescent Current: 56µA Thermal Fault Protection
UM3510DA 价格&库存
很抱歉,暂时无法提供与“UM3510DA”相匹配的价格&库存,您可以联系我们找货
