S-5742NBH0B-Y3N2U
S-5742NBH0B-Y3N2U
    ABLIC(艾普凌科)
    TO226-3
    MAGNETIC SWITCH BIPOLAR TO92S
S-5742NBH0B-Y3N2U 数据手册
S-5742 B Series www.ablic.com www.ablicinc.com 125°C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.2.1_02 © ABLIC Inc., 2016-2017 This IC, developed by CMOS technology, is a bipolar Hall effect latch IC with high-withstand voltage, high-speed detection and high-accuracy magnetic characteristics. The output voltage changes when this IC detects the intensity level of magnetic flux density and a polarity change. Using this IC with a magnet makes it possible to detect the rotation status in various devices. This IC includes an output current limit circuit. This IC is available in various systems by using the insertion TO-92S package. Due to its high-accuracy magnetic characteristics, this IC can make operation's dispersion in the system combined with magnet smaller. ABLIC Inc. offers a "magnetic simulation service" that provides the ideal combination of magnets and our Hall ICs for customer systems. Our magnetism simulation service will reduce prototype production, development period and development costs. In addition, it will contribute to optimization of parts to realize high cost performance. For more information regarding our magnetism simulation service, contact our sales office.  Features  Pole detection: *1  Output logic : *1  Output form :  Magnetic sensitivity*1:  Chopping frequency:  Output delay time:  Power supply voltage range:  Built-in regulator  Built-in output current limit circuit  Operation temperature range:  Lead-free (Sn 100%), halogen-free Bipolar latch VOUT = "L" at S pole detection VOUT = "H" at S pole detection Nch open-drain output Nch driver  built-in pull-up resistor BOP = 1.8 mT typ. BOP = 3.0 mT typ. BOP = 6.0 mT typ. fC = 500 kHz typ. tD = 8.0 s typ. VDD = 3.5 V to 26.0 V Ta = 40C to 125C *1. The option can be selected.  Applications  Home appliance  DC brushless motor  Housing equipment  Industrial equipment  Packages  TO-92S (Straight)  TO-92S (Forming) 1 125C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.2.1_02 S-5742 B Series  Block Diagrams 1. Nch open-drain output product VDD OUT Regulator Chopping stabilized amplifier *1 Output current limit circuit VSS *1. Parasitic diode Figure 1 2. Nch driver  built-in pull-up resistor product VDD OUT Regulator Chopping stabilized amplifier Output current limit circuit VSS *1. Parasitic diode Figure 2 2 *1 125C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.2.1_02 S-5742 B Series  Product Name Structure 1. Product name S-5742 x B x x B - Y3 x x U Environmental code U: Lead-free (Sn 100%), halogen-free Pin shape 2: Straight 3: Forming Packing specifications B: Bulk (500 pcs / bag) Z: Tape and ammo (2000 pcs / case) Package abbreviation Y3: TO-92S Operation temperature B: Ta = 40°C to 125°C Magnetic sensitivity 0: BOP = 1.8 mT typ. 1: BOP = 3.0 mT typ. 2: BOP = 6.0 mT typ. Output logic L: VOUT = "L" at S pole detection H: VOUT = "H" at S pole detection Pole detection B: Bipolar latch Output form N: Nch open-drain output R: Nch driver  built-in pull-up resistor 2. Packages Table 1 Package Name Bulk TO-92S (Straight) Tape and ammo Bulk TO-92S (Forming) Tape and ammo Package Drawing Codes Dimension YB003-A-P-SD YB003-B-P-SD Tape  YC003-A-C-SD  YC003-B-C-SD Ammo Packing  YC003-A-Z-SD  YC003-B-Z-SD 3 125C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.2.1_02 S-5742 B Series 3. Product name list 3. 1 TO-92S (Straight) Table 2 Product Name*1 Pole Detection Output Form Output logic S-5742NBL0B-Y3n2U Nch open-drain output Bipolar latch S-5742NBL1B-Y3n2U Nch open-drain output Bipolar latch S-5742NBL2B-Y3n2U Nch open-drain output Bipolar latch S-5742NBH0B-Y3n2U Nch open-drain output Bipolar latch S-5742NBH1B-Y3n2U Nch open-drain output Bipolar latch S-5742NBH2B-Y3n2U Nch open-drain output Bipolar latch S-5742RBL0B-Y3n2U Nch driver  built-in pull-up resistor Bipolar latch S-5742RBL1B-Y3n2U Nch driver  built-in pull-up resistor Bipolar latch S-5742RBL2B-Y3n2U Nch driver  built-in pull-up resistor Bipolar latch S-5742RBH0B-Y3n2U Nch driver  built-in pull-up resistor Bipolar latch S-5742RBH1B-Y3n2U Nch driver  built-in pull-up resistor Bipolar latch S-5742RBH2B-Y3n2U Nch driver  built-in pull-up resistor Bipolar latch *1. "n" changes according to the packing specification as follows. B: Bulk, Z: Tape and ammo VOUT = "L" at S pole detection VOUT = "L" at S pole detection VOUT = "L" at S pole detection VOUT = "H" at S pole detection VOUT = "H" at S pole detection VOUT = "H" at S pole detection VOUT = "L" at S pole detection VOUT = "L" at S pole detection VOUT = "L" at S pole detection VOUT = "H" at S pole detection VOUT = "H" at S pole detection VOUT = "H" at S pole detection Magnetic Sensitivity (BOP) 1.8 mT typ. 3.0 mT typ. 6.0 mT typ. 1.8 mT typ. 3.0 mT typ. 6.0 mT typ. 1.8 mT typ. 3.0 mT typ. 6.0 mT typ. 1.8 mT typ. 3.0 mT typ. 6.0 mT typ. Remark Please contact our sales office for products other than the above. 3. 2 TO-92S (Forming) Table 3 Magnetic Sensitivity (BOP) S-5742NBL1B-Y3n3U Nch open-drain output Bipolar latch VOUT = "L" at S pole detection 3.0 mT typ. S-5742NBL2B-Y3n3U Nch open-drain output Bipolar latch VOUT = "L" at S pole detection 6.0 mT typ. S-5742RBH1B-Y3n3U Nch driver  built-in pull-up resistor Bipolar latch VOUT = "H" at S pole detection 3.0 mT typ. *1. "n" changes according to the packing specification as follows. B: Bulk, Z: Tape and ammo Product Name*1 Pole Detection Output Form Output logic Remark Please contact our sales office for products other than the above.  Pin Configuration 1. TO-92S Table 4 Pin No. Bottom view 1 2 3 Figure 3 4 Symbol Description 1 VDD Power supply pin 2 VSS GND pin 3 OUT Output pin 125C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.2.1_02 S-5742 B Series  Absolute Maximum Ratings Table 5 Item Symbol Power supply voltage VDD Output current IOUT Output voltage Nch open-drain output product Nch driver  built-in pull-up resistor product Operation ambient temperature Storage temperature VOUT (Ta = 25C unless otherwise specified) Absolute Maximum Rating Unit VSS  0.3 to VSS  28.0 20 V mA VSS  0.3 to VSS  28.0 V VSS  0.3 to VDD  0.3 V Topr 40 to 125 C Tstg 40 to 150 C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Table 6 Item Junction-to-ambient thermal resistance *1. When not mounted on board Remark Symbol JA Condition TO-92S Min.  Typ. 153*1 Max. Unit  C/W Refer to " Power Dissipation" for details. 5 125C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.2.1_02 S-5742 B Series  Electrical Characteristics Item Table 7 (Ta = 25C, VDD = 12.0 V, VSS = 0 V unless otherwise specified) Test Condition Min. Typ. Max. Unit Circuit Symbol Power supply voltage VDD Current consumption IDD Output voltage VOUT Output drop voltage VD Leakage current ILEAK  Nch open-drain output product Average value Nch driver  built-in pull-up resistor product Average value, VOUT = "H" Nch open-drain output product Output transistor Nch, VOUT = "L", IOUT = 10 mA Nch driver  built-in pull-up resistor product Output transistor Nch, VOUT = "L", IOUT = 10 mA Nch driver  built-in pull-up resistor product VOUT = "H", VD = VDD  VOUT Nch open-drain output product Output transistor Nch, VOUT = "H" = 26.0 V 3.5 12.0 26.0 V   3.0 4.0 mA 1  3.0 4.0 mA 1   0.4 V 2   0.5 V 2   20 mV 2   10 A 3 Output limit current IOM VOUT = 12.0 V 22  70 mA 3 Output delay time Chopping frequency Start up time tD fC tPON    8.0 500 20    s kHz s   4   2.0 s 5 Output rise time tR    Nch open-drain output product C = 20 pF, R = 820  Nch driver  built-in pull-up resistor product C = 20 pF C = 20 pF, R = 820    6.0 s 5  2.0 13 5 7  10 s Nch driver  built-in pull-up resistor product k  Output fall time Pull-up resistor tF RL S pole BOP 0 Magnetic flux density applied to this IC (B) BRP N pole tD tD tF Output voltage (VOUT) (Product with VOUT = "L" at S pole detection) tR 90% 10% tD tD tR 90% Output voltage (VOUT) (Product with VOUT = "H" at S pole detection) 10% Figure 4 6 Operation Timing tF 125C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.2.1_02 S-5742 B Series  Magnetic Characteristics 1. Product with BOP = 1.8 mT typ. Table 8 (Ta = 25C, VDD = 12.0 V, VSS = 0 V unless otherwise specified) Item Operation point*1 S pole Release point*2 N pole *3 Hysteresis width 2. Symbol BOP BRP BHYS Condition   BHYS = BOP  BRP Min. 0.3 3.3  Typ. 1.8 1.8 3.6 Max. 3.3 0.3  Unit mT mT mT Test Circuit 4 4 4 Product with BOP = 3.0 mT typ. Table 9 (Ta = 25C, VDD = 12.0 V, VSS = 0 V unless otherwise specified) Item Operation point*1 S pole Release point*2 N pole Hysteresis width*3 3. Symbol BOP BRP BHYS Condition   BHYS = BOP  BRP Min. 1.5 4.5  Typ. 3.0 3.0 6.0 Max. 4.5 1.5  Unit mT mT mT Test Circuit 4 4 4 Product with BOP = 6.0 mT typ. Table 10 (Ta = 25C, VDD = 12.0 V, VSS = 0 V unless otherwise specified) Item Symbol Condition Min. Typ. Max. Unit Test Circuit *1 Operation point  3.0 6.0 9.0 mT 4 S pole BOP Release point*2  9.0 6.0 3.0 mT 4 N pole BRP Hysteresis width*3 BHYS = BOP  BRP  12.0  mT 4 BHYS *1. BOP: Operation point BOP is the value of magnetic flux density when the output voltage (VOUT) changes after the magnetic flux density applied to this IC by the magnet (S pole) is increased (by moving the magnet closer). VOUT retains the status until a magnetic flux density of the N pole higher than BRP is applied. *2. BRP: Release point BRP is the value of magnetic flux density when the output voltage (VOUT) changes after the magnetic flux density applied to this IC by the magnet (N pole) is increased (by moving the magnet closer). VOUT retains the status until a magnetic flux density of the S pole higher than BOP is applied. *3. BHYS: Hysteresis width BHYS is the difference of magnetic flux density between BOP and BRP. Remark The unit of magnetic flux density mT can be converted by using the formula 1 mT = 10 Gauss. 7 125C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.2.1_02 S-5742 B Series  Test Circuits A *1 VDD R 820  S-5742 B Series OUT VSS *1. Resistor (R) is unnecessary for Nch driver  built-in pull-up resistor product. Figure 5 Test Circuit 1 VDD S-5742 B Series OUT VSS Figure 6 A V Test Circuit 2 VDD S-5742 B Series OUT VSS A V Figure 7 Test Circuit 3 *1 VDD R 820  S-5742 B Series OUT VSS *1. Resistor (R) is unnecessary for Nch driver  built-in pull-up resistor product. Figure 8 8 V Test Circuit 4 125C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.2.1_02 S-5742 B Series *1 VDD S-5742 OUT B Series VSS *1. R 820  C 20 pF V Resistor (R) is unnecessary for Nch driver  built-in pull-up resistor product. Figure 9 Test Circuit 5  Standard Circuit *1 VDD CIN 0.1 F *1. R 820  S-5742 B Series OUT VSS Resistor (R) is unnecessary for Nch driver  built-in pull-up resistor product. Figure 10 Caution The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. 9 125C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.2.1_02 S-5742 B Series  Operation 1. Direction of applied magnetic flux This IC detects the magnetic flux density which is vertical to the marking surface. Figure 11 shows the direction in which magnetic flux is being applied. N S Marking surface Figure 11 2. Position of Hall sensor Figure 12 shows the position of Hall sensor. The center of this Hall sensor is located in the area indicated by a circle, which is in the center of a package as described below. The center of Hall sensor; in this  0.3 mm Figure 12 10 125C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.2.1_02 S-5742 B Series 3. Basic operation This IC changes the output voltage (VOUT) according to the level of the magnetic flux density and a polarity change (N pole or S pole) applied by a magnet. 3. 1 Product with VOUT = "L" at S pole detection When the magnetic flux density of the S pole perpendicular to the marking surface exceeds the operation point (BOP) after the S pole of a magnet is moved closer to the marking surface of this IC, VOUT changes from "H" to "L". When the N pole of a magnet is moved closer to the marking surface of this IC and the magnetic flux density of the N pole is higher than the release point (BRP), VOUT changes from "L" to "H". In case of BRP  B  BOP, VOUT retains the status. Figure 13 shows the relationship between the magnetic flux density and VOUT. VOUT BHYS H L N pole 0 BRP BOP S pole Magnetic flux density (B) Figure 13 3. 2 Product with VOUT = "H" at S pole detection When the magnetic flux density of the S pole perpendicular to the marking surface exceeds BOP after the S pole of a magnet is moved closer to the marking surface of this IC, V OUT changes from "L" to "H". When the N pole of a magnet is moved closer to the marking surface of this IC and the magnetic flux density of the N pole is higher than BRP, VOUT changes from "H" to "L". In case of BRP  B  BOP, VOUT retains the status. Figure 14 shows the relationship between the magnetic flux density and VOUT. VOUT BHYS H L N pole BRP 0 BOP S pole Magnetic flux density (B) Figure 14 11 125C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.2.1_02 S-5742 B Series 4. Timing chart Figure 15 shows the operation timing at power-on. The initial output voltage at rising of power supply voltage (VDD) is either "H" or "L". In case of B  BOP (operation point) or B BRP (release point) at the time when the start up time (tPON) is passed after rising of VDD, this IC outputs VOUT according to the applied magnetic flux density. In case of BRP  B  BOP at the time when tPON is passed after rising of VDD, this IC maintains the initial output voltage. Product with VOUT = "L" at S pole detection Product with VOUT = "H" at S pole detection Power supply voltage (VDD) Power supply voltage (VDD) tPON tPON Output voltage (VOUT) (B  BOP) "H" / "L" "L" Output voltage (VOUT) (B  BOP) "H" / "L" "H" Output voltage (VOUT) (B  BRP) "H" / "L" "H" Output voltage (VOUT) (B  BRP) "H" / "L" "L" Output voltage (VOUT) (BRP  B  BOP) "H" / "L" Latching Output voltage (VOUT) (BRP  B  BOP) "H" / "L" Figure 15 12 Latching 125C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.2.1_02 S-5742 B Series  Precautions  If the impedance of the power supply is high, the IC may malfunction due to a supply voltage drop caused by feedthrough current. Take care with the pattern wiring to ensure that the impedance of the power supply is low.  Note that the IC may malfunction if the power supply voltage rapidly changes. When the IC is used under the environment where the power supply voltage rapidly changes, it is recommended to judge the output voltage of the IC by reading it multiple times.  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit.  Although this IC has a built-in output current limit circuit, it may suffer physical damage such as product deterioration under the environment where the absolute maximum ratings are exceeded.  The application conditions for the power supply voltage, the pull-up voltage, and the pull-up resistor should not exceed the power dissipation.  Large stress on this IC may affect on the magnetic characteristics. Avoid large stress which is caused by the handling during or after mounting the IC on a board.  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 13 125C OPERATION HIGH-WITHSTAND VOLTAGE HIGH-SPEED BIPOLAR HALL EFFECT LATCH IC Rev.2.1_02 S-5742 B Series  Power Dissipation TO-92S Tj = 150C max. Power dissipation (PD) [W] 1.0 0.8 0.6 0.4 0.2 0.0 0 25 50 75 100 125 150 Ambient temperature (Ta) [C] Power Dissipation (PD) 0.82 W (when not mounted on board) 14 175 1.62max. 4.1max. Marked side 0.55max. 0.65max. 0.51max. 0.48max. 1.27 No. YB003-A-P-SD-1.0 TITLE TO92S-C-PKG Dimensions YB003-A-P-SD-1.0 No. ANGLE UNIT mm ABLIC Inc. 12.7±0.3 1.0max. Marked side Marked side Marked side 1#pin 1.0max. 1.0max. Marked side 3#pin 1.45max. ø4.0±0.2 6.35±0.3 12.7±0.2 Marked side Marked side Marked side Feed direction No. YC003-A-C-SD-1.1 TITLE TO92S-E-Radial Tape No. YC003-A-C-SD-1.1 ANGLE UNIT mm ABLIC Inc. Spacer(Sponge) 310 15 35 Side spacer placed in front side 157 320 Space more than 4 strokes 162 333 43 No. YC003-A-Z-SD-1.0 TITLE TO92S-E-Ammo Packing YC003-A-Z-SD-1.0 No. ANGLE UNIT QTY. mm ABLIC Inc. 2,000 1.62max. 4.1max. Marked side 0.55max. 0.65max. 0.48max. 0.51max. 2.5±0.3 1.27 No. YB003-B-P-SD-1.0 TITLE TO92S-D-PKG Dimensions YB003-B-P-SD-1.0 No. ANGLE UNIT mm ABLIC Inc. 12.7±0.3 1.0max. Marked side Marked side Marked side 1#pin 1.0max. 1.0max. Marked side 3#pin 1.45max. ø4.0±0.2 6.35±0.3 12.7±0.2 Marked side Marked side Marked side Feed direction No. YC003-B-C-SD-1.1 TITLE TO92S-F-Radial Tape No. YC003-B-C-SD-1.1 ANGLE UNIT mm ABLIC Inc. Spacer(Sponge) 310 15 35 Side spacer placed in front side 157 320 Space more than 4 strokes 162 333 43 No. YC003-B-Z-SD-1.0 TITLE TO92S-F-Ammo Packing YC003-B-Z-SD-1.0 No. ANGLE UNIT QTY. mm ABLIC Inc. 2,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-5742NBH0B-Y3N2U
物料型号: - S-5742 B系列
器件简介: - 该集成电路采用CMOS技术开发,是一种具有高耐压、高速检测和高精度磁性特性的双极霍尔效应锁存集成电路。 - 当检测到磁场强度和极性变化时,输出电压会发生变化。 - 该集成电路包含输出电流限制电路。 - 通过使用插入式TO-92S封装,可在各种系统中使用。 - ABLIC公司提供“磁性模拟服务”,为顾客系统的磁铁和霍尔集成电路提供理想组合。
引脚分配: - VDD:电源引脚 - VSS:地引脚 - OUT:输出引脚
参数特性: - 工作电压范围:3.5V至26.0V - 工作温度范围:-40°C至+125°C - 漏电流:在VOUT = "H"时,最大10nA - 输出限制电流:在VOUT = 12.0V时,22mA至70mA - 输出延迟时间:典型值8.0μs - 斩波频率:典型值500kHz - 启动时间:典型值20μs - 输出上升时间:在Nch开漏输出产品中,典型值2.0μs - 输出下降时间:在Nch开漏输出产品中,典型值2.0μs - 内置上拉电阻:在Nch驱动器+内置上拉电阻产品中,典型值10kΩ
功能详解: - 该集成电路能够检测磁场强度的变化,并根据磁场的极性(N极或S极)改变输出电压。 - 具有双极锁存功能,可以检测磁场的极性。 - 输出形式为Nch开漏输出或Nch驱动器+内置上拉电阻。
应用信息: - 家用电器 - 直流无刷电机 - 住宅设备 - 工业设备
封装信息: - TO-92S(直插式) - TO-92S(成型式)
S-5742NBH0B-Y3N2U 价格&库存
很抱歉,暂时无法提供与“S-5742NBH0B-Y3N2U”相匹配的价格&库存,您可以联系我们找货
