NJM2904CM-TE2
NJM2904CM-TE2
    JRC(⽇本无线)
    DMP8_5X5MM
    IC OPAMP GP 2 CIRCUIT 8DMP
NJM2904CM-TE2 数据手册
NJM2904C / NJM2904CA SINGLE-SUPPLY DUAL OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM2904C / NJM2904CA consists of two independent, high gain, internally frequency compensated operation amplifiers, which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. Application areas include transducer amplifiers, DC gain blocks, and all the conventional op amp circuits, which now can be more easily implemented in single power supply systems. For example, the NJM2904C can be directly operated off of the standard +5V power supply voltage, which is used in digital systems and will easily provide the required interface electronics without requiring the additional ±15V power supplies. ■ FEATURES ● Single Supply ● Operating Voltage ● Low Operating Current ● Slew Rate ● Bipolar Technology ● Package Outline ● Internal ESD protection ● Wide temperature range ● Input Offset Voltage Grade NJM2904CG NJM2904CAG (SOP8) NJM2904CM NJM2904CAM (DMP8) NJM2904CRB1 NJM2904CARB1 (MSOP8(TVSP8)) NJM2904CV NJM2904CAV (SSOP8) NJM2904CME2 (EQFN12-E2) +3V to +32V 0.7mA typ. 0.6V/μs typ. SOP8, DMP8 ,SSOP8, EQFN12-E2, MSOP8 (TVSP8) **MEET JEDEC MO-187-DA / THIN TYPE Human body model (HBM) ±2000V typ. -40℃ to +125℃ NJM2904C(Normal-Grade) 7mV max. NJM2904CA(A-Grade) 2mV max. ■ PIN CONFIGURATION * NJM2904CME2 don’t have a A version. (Top View) (Top View) (Top View) PIN FUNCTION 1.A OUTPUT 2.A - INPUT A 2 7 3.A + INPUT 4.V B 3 6 5.B + INPUT 6.B - INPUT 4 5 7.B OUTPUT + 8.V NJM2904CG/2904CAG NJM2904CM/2904CAM NJM2904CRB1/2904CARB1 NJM2904CV/2904CAV 1 ■ PACKAGE OUTLINE 12 11 (Bottom View) (Bottom View) 10 10 11 12 8 1 9 9 2 8 8 3 7 7 4 5 6 1 2 PAD 3 6 5 4 PIN FUNCTION 1. A OUTPUT 2. A –INPUT 3. A +INPUT 4. NC 5. V 6. NC 7. B +INPUT 8. B –INPUT 9. B OUTPUT 10. NC + 11. V 12. NC NJM2904CME2 (Note1, 2, 3) (Note1) The PAD have to be wired as short as possible to connect with a V− terminal. (Note2) The PAD is electronically connected to the backside of the die. But, there cannot be used as V- pin. (Note3) The NC pin is not internally connected. ■ EQUIVALENT CIRCUIT ( 1/2 Shown ) V+ -INPUT +INPUT OUTPUT V- Ver.12 -1- NJM2904C / NJM2904CA ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER SYMBOL + Supply Voltage RATINGS - UNIT V -V +32 V Differential Input Voltage (Note4) VID ±32 V Input Voltage VIN (Note5) Output Terminal Input Voltage Vo Power Dissipation PD Operating Temperature Range Topr Storage Temperature Range Tstg - - V - + V V - 0.3 to V + 32 SOP DMP MSOP SSOP EQFN V - 0.3 to V +0.3 : 690 (Note6) 1000(Note7) : 470 (Note6) 600 (Note7) : 510 (Note6) 680 (Note7) : 430 (Note6) 540(Note7) : 440 (Note8) 680(Note9) -40 to +125 mW ˚C -65 to +150 ˚C (Note4)Differential voltage is the voltage difference between +INPUT and -INPUT. (Note5) Input voltage is the voltage should be allowed to apply to the input terminal independent of the magnitude of V+. The normal operation will establish when any input is within the Common Mode Input Voltage Range of electrical characteristics. (Note6) EIA/JEDEC STANDARD Test board (76.2 x 114.3 x 1.6mm, 2layers, FR-4) mounting (Note7) EIA/JEDEC STANDARD Test board (76.2 x 114.3 x 1.6mm, 4layers, FR-4) mounting (Note8) EIA/JEDEC STANDARD Test board (101.5 x 114.3 x 1.6mm, 2layers, FR-4) mounting (Note9) EIA/JEDEC STANDARD Test board (101.5 x 114.3 x 1.6mm, 4layers, FR-4) mounting ■ELECTRICAL CARACTERISTICS + - (V =5V, V =0V, Ta=25ºC, unless otherwise noted.) PARAMETER Supply Current (All amplifiers) Input Offset Voltage SYMBOL ISUPPLY VIO TEST CONDITION MIN. TYP. MAX. + - 0.7 1.2 V =30V, no signal + - - 2 RS=0Ω - 0.5 7 RS=0Ω , NJM2904CA - 0.5 2 V =5V, no signal UNIT mA mV Input Bias Current IB - 20 150 nA Input Offset Current IIO - 2 30 nA Open-Loop Voltage Gain Supply Voltage Rejection Ratio Common Mode Input Voltage Range Common Mode Rejection Ratio Output Source Current Output Sink Current AV RL≥2kΩ 94 100 - dB + 65 100 - dB V =30V, CMR>70dB + 0 - V -1.5 V Rs
NJM2904CM-TE2 价格&库存
很抱歉,暂时无法提供与“NJM2904CM-TE2”相匹配的价格&库存,您可以联系我们找货
