S-8255AAA-TET1S
S-8255AAA-TET1S
    ABLIC(艾普凌科)
    TSSOP20
    IC BATT MON LI-ION 3-5CL 20TSSOP
S-8255AAA-TET1S 数据手册
S-8255A Series www.ablic.com BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK © ABLIC Inc., 2018 Rev.1.4_00 The S-8255A Series is a monitoring IC for 3-serial to 5-serial cell lithium-ion rechargeable batteries, which includes high-accuracy voltage detection circuits and delay circuits. The S-8255A Series can monitor the status of 3-serial to 5-serial cell lithium-ion rechargeable battery packs. Cascade connection using the S-8255A Series realizes monitoring 6-serial or more cells lithium-ion rechargeable battery packs. Connecting an NTC, it allows for the temperature detection at four different points: high temperature detection during charging, low temperature detection during charging, high temperature detection during discharging, and low temperature detection during discharging.  Features  High-accuracy voltage detection function for each cell Overcharge detection voltage n (n = 1 to 5): 3.550 V to 4.600 V (50 mV step) Accuracy 20 mV Overcharge release voltage n (n = 1 to 5): 3.150 V to 4.600 V*1 Accuracy 50 mV Overdischarge detection voltage n (n = 1 to 5): 2.000 V to 3.200 V (100 mV step) Accuracy 80 mV *2 Accuracy 100 mV Overdischarge release voltage n (n = 1 to 5): 2.000 V to 3.400 V  Each delay time is settable by external capacitor (Temperature detection delay time is internally fixed)  Independent control of charge inhibition, discharge inhibition, and power-saving by each control pin  0 V battery detection function is selectable: Available, unavailable  CO and DO pin output voltage is limited to 8 V max. respectively  Switching control for 3-serial to 5-serial cell is possible by inputting voltage to the SEL1 pin and the SEL2 pin  Monitoring of 6-serial or more cells is possible by cascade connection  Temperature detection is possible at four different points by connecting an NTC High temperature detection ratio during charging / discharging: 0.600 to 0.900 (0.005 step) Accuracy 0.005 Low temperature detection ratio during charging / discharging: 0.030 to 0.400 (0.005 step) Accuracy 0.005  High-withstand voltage: Absolute maximum rating 28 V  Wide operation voltage range: 5 V to 24 V  Wide operation temperature range: Ta = 40C to 85C  Low current consumption During operation: 19 A max. (Ta = 25C) During power-saving: 0.1 A max. (Ta = 25C)  Lead-free, halogen-free *1. Overcharge release voltage = Overcharge detection voltage  Overcharge hysteresis voltage (Overcharge hysteresis voltage n (n = 1 to 5) is selectable in 0 V to 0.4 V in 50 mV step) *2. Overdischarge release voltage = Overdischarge detection voltage  Overdischarge hysteresis voltage (Overdischarge hysteresis voltage n (n = 1 to 5) is selectable in 0 V to 0.7 V in 100 mV step)  Application  Rechargeable lithium-ion battery pack  Package  20-Pin TSSOP 1 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00  Block Diagram VDD Temperature detection circuit TH VC1   Overcharge 1   Overdischarge 1   Overcharge 2   Overdischarge 2 Voltage regulator VREG CTLC VC2 CTLD PSI VC3   Overcharge 3   Overdischarge 3 CCT CDT VC4   Overcharge 4   Overdischarge 4 Control circuit CO pin output voltage limit circuit CO VC5     Overcharge 5 Overdischarge 5 CO pin output voltage limit circuit VSS DO SEL1 SEL2 PSO THC/DX Remark Diodes in the figure are parasitic diodes. Figure 1 2 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00  Product Name Structure 1. Product name S-8255A xx - TET1 S Environmental code S: Lead-free, halogen-free Package abbreviation and IC packing specifications*1 TET1: 20-Pin TSSOP, Tape Serial code*2 Sequentially set from AA to ZZ *1. Refer to the tape drawing. *2. Refer to "3. Product name list". 2. Package Table 1 Package Drawing Code Package Name 20-Pin TSSOP Dimension FT020-B-P-SD Tape FT020-B-C-SD Reel FT020-B-R-SD 3. Product name list Table 2 (1 / 2) Product Name S-8255AAA-TET1S S-8255AAB-TET1S Overcharge Detection Voltage [VCU] 4.100 V 4.250 V Overcharge Release Voltage [VCL] 4.050 V 4.150 V Overdischarge Detection Voltage [VDL] 2.600 V 2.500 V Overdischarge Release Voltage [VDU] 2.700 V 3.000 V 0 V Battery Detection Function*1 Unavailable Available Table 2 (2 / 2) Low Temperature High Temperature Detection Ratio Detection Ratio Product Name during Charging during Charging [rTHCL] [rTHCH] S-8255AAA-TET1S 0.670 0.270 S-8255AAB-TET1S 0.670 0.270 *1. 0 V battery detection function "available" / "unavailable" is selectable. High Temperature Detection Ratio during Discharging [rTHDH] 0.795 0.795 Low Temperature Detection Ratio during Discharging [rTHDL] 0.190 0.190 Remark Please contact our sales office for products other than those specified above. 3 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00  Pin Configuration 1. 20-Pin TSSOP Table 3 Top view 1 2 3 4 5 6 7 8 9 10 Pin No. 20 19 18 17 16 15 14 13 12 11 Figure 2 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 4 Symbol TH Description Input pin for temperature detection Input pin for positive power supply, VDD connection pin for positive voltage of battery 1 VC1 Connection pin for positive voltage of battery 1 Connection pin for negative voltage of battery 1, VC2 connection pin for positive voltage of battery 2 Connection pin for negative voltage of battery 2, VC3 connection pin for positive voltage of battery 3 Connection pin for negative voltage of battery 3, VC4 connection pin for positive voltage of battery 4 Connection pin for negative voltage of battery 4, VC5 connection pin for positive voltage of battery 5 Input pin for negative power supply, VSS connection pin for negative voltage of battery 5 Switching pins for number of cells in series SEL1 [SEL1, SEL2] = ["L", "L"] : 5-serial cell [SEL1, SEL2] = ["L", "H"] : 4-serial cell [SEL1, SEL2] = ["H", "L"] : 3-serial cell SEL2 [SEL1, SEL2] = ["H", "H"] : Setting inhibited Capacitor connection pin for delay CCT for overcharge detection voltage Capacitor connection pin for delay CDT for overdischarge detection voltage PSO Output pin for power-saving signal (CMOS output) DO Connection pin of discharge control FET gate (CMOS output) CO Connection pin of charge control FET gate (CMOS output) THC/DX Switching pin for detection temperature CTLC Control pin for CO pin output CTLD Control pin for DO pin output PSI Control pin for Power-saving VREG Voltage output pin for temperature detection BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00  Absolute Maximum Ratings Table 4 (Ta = 25°C unless otherwise specified) Item Symbol Applied Pin Absolute Maximum Rating Unit Input voltage between VDD pin and VSS pin VDS VDD VSS  0.3 to VSS  28 V VC1, VC2, VC3, VC4, VC5, Input pin voltage 1 VIN1 CCT, CDT, SEL1, SEL2, VSS  0.3 to VDD  0.3 V TH, THC/DX Input pin voltage 2 VIN2 PSI VDD  28 to VDD  0.3 V Input pin voltage 3 VIN3 CTLC, CTLD VSS  0.3 to VSS  28 V Output pin voltage VOUT CO, DO, PSO, VREG VSS  0.3 to VDD  0.3 V Operation ambient temperature Topr  40 to 85 °C Storage temperature Tstg  40 to 125 °C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Table 5 Item Symbol Condition Board A Board B Junction-to-ambient thermal resistance*1 JA 20-Pin TSSOP Board C Board D Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Min.      Typ. 68 59    Max.      Unit C/W C/W C/W C/W C/W Remark Refer to " Power Dissipation" and "Test Board" for details. 5 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00  Electrical Characteristics Table 6 (1 / 2) Item Detection Voltage Overcharge detection voltage n (n = 1 to 5) Overcharge release voltage n (n = 1 to 5) Overdischarge detection voltage n (n = 1 to 5) Overdischarge release voltage n (n = 1 to 5) Delay Time Function*1 CCT pin internal resistance CDT pin internal resistance Symbol VCUn (V1 = V2 = V3 = V4 = V5 = 3.5 V, Ta = 25°C unless otherwise specified) Test Condition Min. Typ. Max. Unit Circuit V1 = V2 = V3 = V4 = V5 = VCUn  0.050 V VCLn  VDLn  VDUn  RCCT RCDT V1 = VCU  0.025 V1 = VDL  0.085 CCT pin detection voltage VCCT V1 = VCU  0.025 CDT pin detection voltage VCDT V1 = VDL  0.085 VDSOP Fixed output voltage of DO pin and CO pin Input Voltage Operation voltage between VDD pin and VSS pin Input Current Current consumption during operation Current consumption during power-saving VC1 pin current VC2 pin current VC3 pin current VC4 pin current VC5 pin current Output Pin CO pin voltage "H"*2 DO pin voltage "H"*3 CO pin source current CO pin sink current DO pin source current DO pin sink current PSO pin source current PSO pin sink current 0 V Battery Detection Function 0 V battery detection voltage n (n = 1 to 5) *1. *2. *3. VCUn  0.020 VCLn  0.050 VDLn  0.080 VDUn  0.100 VCLn VDLn VDUn VCUn  0.020 VCLn  0.050 VDLn  0.080 VDUn  0.100 V 1 V 1 V 1 V 1 6.15 615 VDS  0.68 VDS  0.68 8.31 831 VDS  0.70 VDS  0.70 10.20 1020 VDS  0.72 VDS  0.72 M k 1 1 V 1 V 1 5  24 V  IOPE   10 19 A 1 IPSV    0.1 A 1 IVC1 IVC2 IVC3 IVC4 IVC5       0.8 0.8 0.8 0.8 0.25 0.0 0.0 0.0 0.0 0.50 0.8 0.8 0.8 0.8 A A A A A 1 1 1 1 1  V1 = V2 = V3 = V4 = V5 = 5.6 V    V1 = V2 = V3 = V4 = V5 = 1.9 V 4.0 4.0 10 10 10 10 10 10 6.0 6.0       8.0 8.0       V V A A A A A A 1 1 1 1 1 1 1 1 1.0 1.3 1.5 V 1 VCOH VDOH ICOH ICOL IDOH IDOL IPSOH IPSOL V0INHn VCOH  VDS VDOH  VDS 0 V battery detection function "available" Refer to "4. Delay time setting" in " Operation" for details of the delay time function. When VCOH  VDS, VCOH = VDD When VDOH  VDS, VDOH = VDD Remark VDS: Input voltage between VDD pin and VSS pin (V1  V2  V3  V4  V5) 6 VCUn BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00 Table 6 (2 / 2) Item Control Pin SEL1 pin voltage "H" SEL2 pin voltage "H" SEL1 pin voltage "L" SEL2 pin voltage "L" CTLC pin reverse voltage CTLD pin reverse voltage PSI pin reverse voltage CTLC pin response delay time CTLD pin response delay time PSI pin response delay time CTLC pin curent "H" CTLC pin curent "L" CTLD pin curent "H" CTLD pin curent "L" PSI pin curent "H" PSI pin curent "L" CTLC pin reverse voltage during communication CTLD pin reverse voltage during communication PSI pin reverse voltage during communication Temperature Detection Function Output voltage for temperature detection High temperature detection ratio during charging Low temperature detection ratio during charging High temperature detection ratio during discharging Low temperature detection ratio during discharging THC/DX pin voltage "H" THC/DX pin voltage "L" Temperature detection delay time Symbol VSEL1H VSEL2H VSEL1L VSEL2L VCTLC VCTLD VPSI tCTLC tCTLD tPSI ICTLCH ICTLCL ICTLDH ICTLDL IPSIH IPSIL VCTLC_C VCTLD_C VPSI_C (V1 = V2 = V3 = V4 = V5 = 3.5 V, Ta = 25°C unless otherwise specified) Test Condition Min. Typ. Max. Unit Circuit  VDS  0.95  VDS  0.95      0.1  0.1  0.1  0.275  0.275  0.3  0.1  0.45  0.1  0.45  0.0  0.1 5.1 M resistance connected VDS  0.2 to the CTLC pin 5.1 M resistance connected VDS  0.2 to the CTLD pin 5.1 M resistance connected VSS  1.9 to the PSI pin VREG Voltage between VDD pin and VREG pin rTHCH rTHCH = (VREG  VTH) / VREG rTHCL rTHCL = (VREG  VTH) / VREG rTHDH rTHDH = (VREG  VTH) / VREG rTHDL rTHDL = (VREG  VTH) / VREG VTHH VTHL tTH    4.0 rTHCH  0.005 rTHCL  0.005 rTHDH  0.005 rTHDL  0.005 VDS  2.0 0.5 1.0     0.7 0.7 4.0 0.500 0.500 0.9 0.0 0.20 0.0 0.20 0.2 0.0   VDS  0.05 VDS  0.05 2.0 2.0 8.0 0.725 0.725 3.0 0.1 0.05 0.1 0.05 0.4 0.1 V V V V V V V ms ms ms A A A A A A     1 1 1 1 1 1 1 1 1 1 1 1 VDS  0.7 VDS  1.3 V 3 VDS  0.7 VDS  1.3 V 3 VSS  1.0 VSS  0.3 V 3 5.0 6.0 V 2  2  2  2  2 V V s 2 2 2 rTHCH rTHCL rTHDH rTHDL VDS  1.5 1.0 2.0 rTHCH  0.005 rTHCL  0.005 rTHDH  0.005 rTHDL  0.005 VDS  1.0 1.5 3.0 7 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00  Test Circuits Unless otherwise specified, for the CO pin output voltage (VCO), DO pin output voltage (VDO), and PSO pin output voltage (VPSO), "L" or "H" is judged as follows. L : [VCO, VDO, VPSO]  VDS  0.1 V H : [VCO, VDO, VPSO]  VDS  0.1 V Remark VDS: Input voltage between VDD pin and VSS pin (V1  V2  V3  V4  V5) 1. Test circuit 1 10 k 0.1 F 10 k 1 TH V1 V2 V3 V4 V5 VREG 20 2 VDD PSI 19 A A 3 VC1 CTLD 18 A A 4 VC2 CTLC 17 A A 5 VC3 THC/DX 16 A A 6 VC4 CO 15 A A 7 VC5 DO 14 A A 8 VSS PSO 13 A 9 SEL1 CDT 12 A 10 SEL2 CCT 11 A S-8255A SW1 SW2 V6 SW3 V7 V SW4 V8 V SW5 V9 V V10 V11 V12 V13 V14 Figure 3 Test Circuit 1 This section provides explanations of Test items using Test circuit 1. Perform each test after setting as shown in Table 7. Table 7 V1 3.5 V V2 3.5 V V3 3.5 V Table 7 V11 0V 8 V12 0V V13 0V Initial Setting of Test Circuit 1 (1 / 2) V4 3.5 V V5 3.5 V V6  V7  V8  V9  Initial Setting of Test Circuit 1 (2 / 2) V14 VDS SW1 OFF SW2 OFF SW3 OFF SW4 OFF SW5 OFF V10  Rev.1.4_00 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series 1. 1 Overcharge detection voltage n (VCUn), overcharge release voltage n (VCLn) When the voltage V1 is gradually increased after setting V1 = V2 = V3 = V4 = V5 = VCUn  0.05 V and VCO changes from "H" to "L", V1 is defined as the overcharge detection voltage 1 (VCU1). When the voltage V1 is then gradually decreased and VCO changes from "L" to "H", V1 is defined as the overcharge release voltage 1 (VCL1). Overcharge detection voltage n (VCUn) and overcharge release voltage n (VCLn) (n = 2 to 5) can be determined in the same way as when n = 1. 1. 2 Overdischarge detection voltage n (VDLn), overdischarge release voltage n (VDUn) When the voltage V1 is gradually decreased and VDO changes from "H" to "L", V1 is defined as the overdischarge detection voltage 1 (VDL1). When the voltage V1 is then gradually increased and VDO changes from "L" to "H", V1 is defined as the overdischarge release voltage 1 (VDU1). Overdischarge detection voltage n (VDLn) and overdischarge release voltage n (VDUn) (n = 2 to 5) can be determined in the same way as when n = 1. 1. 3 CCT pin internal resistance (RCCT), CCT pin detection voltage (VCCT) The CCT pin internal resistance (RCCT) is defined by RCCT = VDS / ICCT under the set conditions of V1 = VCU1  0.025 V after setting V6 = 0 V and setting SW1 to ON. When the voltage V6 is then gradually increased and VCO changes from "H" to "L", V6 is defined as the CCT pin detection voltage (VCCT). 1. 4 CDT pin internal resistance (RCDT), CDT pin detection voltage (VCDT) The CDT pin internal resistance (RCDT) is defined by RCDT = VDS / ICDT under the set conditions of V1 = VDL1  0.085 V after setting V7 = 0 V and setting SW2 to ON. When the voltage V7 is then gradually increased and VDO changes from "H" to "L", V7 is defined as the CDT pin detection voltage (VCDT). 1. 5 Current consumption during operation (IOPE) The current consumption during operation (IOPE) is IVSS under the initial setting shown in Table 7. 1. 6 Current consumption during power-saving (IPSV) The current consumption during power-saving (IPSV) is IVSS when V14 = 0 V. 1. 7 CO pin source current (ICOH) The CO pin source current (ICOH) is ICO when V10 = VCOH  0.5 V and SW5 is ON. 1. 8 CO pin sink current (ICOL) The CO pin sink current (ICOL) is ICO when V1 = V2 = V3 = V4 = V5 = 4.6 V, V10 = 0.5 V, and SW5 is ON. 1. 9 DO pin source current (IDOH) The DO pin source current (IDOH) is IDO when V9 = VDOH  0.5 V and SW4 is ON. 1. 10 DO pin sink current (IDOL) The DO pin sink current (IDOL) is IDO when V1 = V2 = V3 = V4 = V5 = 1.9 V, V9 = 0.5 V, and SW4 is ON. 1. 11 PSO pin source current (IPSOH) The PSO pin source current (IPSOH) is IPSO when V14 = 0 V, V8 = VDS  0.5 V, and SW3 is ON. 1. 12 PSO pin sink current (IPSOL) The PSO pin sink current (IPSOL) is IPSO when V8 = 0.5 V and SW3 is ON. 9 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00 1. 13 0 V battery detection voltage n (V0INHn) (0 V battery detection function "available") When the voltage V1 is gradually decreased and VCO changes from "H" to "L", V1 is defined as the 0 V battery detection voltage 1 (V0INH1). 0 V battery detection voltage n (V0INHn) (n = 2 to 5) can be determined in the same way as when n = 1. 1. 14 CTLC pin reverse voltage (VCTLC) When the voltage V12 is gradually increased and VCO changes from "H" to "L", V12 is defined as the CTLC pin reverse voltage (VCTLC). 1. 15 CTLD pin reverse voltage (VCTLD) When the voltage V13 is gradually increased and VDO changes from "H" to "L", V13 is defined as the CTLD pin reverse voltage (VCTLD). 1. 16 PSI pin reverse voltage (VPSI) When the voltage V14 is gradually decreased and VPSO changes from "L" to "H", V14 is defined as the PSI pin reverse voltage (VPSI). 1. 17 CTLC pin response delay time (tCTLC) The CTLC pin response delay time (tCTLC) is the time period from when the voltage V12 changes to V12 = VDS until when VCO changes from "H" to "L". 1. 18 CTLD pin response delay time (tCTLD) The CTLD pin response delay time (tCTLD) is the time period from when the voltage V13 changes to V13 = VDS until when VDO changes from "H" to "L". 1. 19 PSI pin response delay time (tPSI) The PSI pin response delay time (tPSI) is the time period from when the voltage V14 changes to V14 = 0 V until when VPSO changes from "L" to "H". 1. 20 CTLC pin current "H" (ICTLCH), CTLC pin current "L" (ICTLCL) The CTLC pin current "H" (ICTLCH) is ICTLC when V12 = VDS. The CTLC pin current "L" (ICTLCL) is ICTLC when V12 = 0 V. 1. 21 CTLD pin current "H" (ICTLDH), CTLD pin current "L" (ICTLDL) The CTLD pin current "H" (ICTLDH) is ICTLD when V13 = VDS. The CTLD pin current "L" (ICTLDL) is ICTLD when V13 = 0 V. 1. 22 PSI pin current "H" (IPSIH), PSI pin current "L" (IPSIL) The PSI pin current "H" (IPSIH) is IPSI when V14 = VDS. The PSI pin current "L" (IPSIL) is IPSI when V14 = 0 V. 10 Rev.1.4_00 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series 2. Test circuit 2 V V7 1 TH V1 V2 V3 V4 V5 0.1 F VREG 20 2 VDD PSI 19 3 VC1 CTLD 18 4 VC2 CTLC 17 5 VC3 THC/DX 16 6 VC4 20 k CO 15 S-8255A 7 VC5 DO 14 8 VSS PSO 13 9 SEL1 CDT 12 10 SEL2 CCT 11 V V V6 Figure 4 Test Circuit 2 This section provides explanations of Test items using Test circuit 2. Perform each test after setting as shown in Table 8. Table 8 Initial Setting of Test Circuit 2 V1 V2 V3 3.5 V 3.5 V 3.5 V *1. V7 is an absolute value. V4 3.5 V V5 3.5 V V6 0V V7*1 2.5 V 2. 1 Output voltage for temperature detection (VREG) The maximum voltage between the VDD pin and VREG pin is defined as the output voltage for temperature detection (VREG). 2. 2 High temperature detection ratio during charging (rTHCH) When the voltage V7 is gradually decreased after setting V6 = VDS and VCO changes from "H" to "L", the high temperature detection ratio during charging (rTHCH) is defined by (VREG  V7) / VREG. 2. 3 Low temperature detection ratio during charging (rTHCL) When the voltage V7 is gradually increased after setting V6 = VDS and VCO changes from "H" to "L", the low temperature detection ratio during charging (rTHCL) is defined by (VREG  V7) / VREG. 2. 4 High temperature detection ratio during discharging (rTHDH) When the voltage V7 is gradually decreased and VCO changes from "H" to "L" and VDO changes from "H" to "L", the high temperature detection ratio during discharging (rTHDH) is defined by (VREG  V7) / VREG. 2. 5 Low temperature detection ratio during discharging (rTHDL) When the voltage V7 is gradually increased and VCO changes from "H" to "L" and VDO changes from "H" to "L", the low temperature detection ratio during discharging (rTHDL) is defined by (VREG  V7) / VREG. 11 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00 2. 6 THC/DX pin voltage "H" (VTHH) When the voltage V6 is gradually increased after setting (1  rTHDH)  VREG  V7  (1  rTHCH)  VREG and VDO changes from "L" to "H", V6 is defined as the THC/DX pin voltage "H" (VTHH). 2. 7 THC/DX pin voltage "L" (VTHL) When the voltage V6 is gradually decreased after setting (1  rTHDH)  VREG  V7  (1  rTHCH)  VREG and VDO changes from "H" to "L", V6 is defined as the THC/DX pin voltage "L" (VTHL). 2. 8 Temperature detection delay time (tTH) The temperature detection delay time (tTH) is the time period from when the voltage V7 changes to 0 V until when VCO changes from "H" to "L" and VDO changes from "H" to "L". 3. Test circuit 3 10 k 0.1 F 10 k 1 TH V1 V2 V3 VREG 20 2 VDD PSI 19 3 VC1 CTLD 18 4 VC2 CTLC 17 5 VC3 THC/DX 16 6 VC4 V4 V5 S-8255A 5.1 M 5.1 M 5.1 M CO 15 7 VC5 DO 14 8 VSS PSO 13 9 SEL1 CDT 12 10 SEL2 CCT 11 V V V6 V7 V8 Figure 5 Test Circuit 3 This section provides explanations of Test items using Test circuit 3. Perform each test after setting as shown in Table 9. Table 9 Initial Setting of Test Circuit 3 V1 3.5 V V2 3.5 V V3 3.5 V V4 3.5 V V5 3.5 V V6 VDS  2.0 V V7 VDS  2.0 V V8 2.0 V 3. 1 CTLC pin reverse voltage during communication (VCTLC_C) When the voltage V6 is gradually decreased and VCO changes from "H" to "L", V6 is defined as the CTLC pin reverse voltage during communication (VCTLC_C). 3. 2 CTLD pin reverse voltage during communication (VCTLD_C) When the voltage V7 is gradually decreased and VDO changes from "H" to "L", V7 is defined as the CTLD pin reverse voltage during communication (VCTLD_C). 3. 3 PSI pin reverse voltage during communication (VPSI_C) When the voltage V8 is gradually increased and VPSO changes from "L" to "H", V8 is defined as the PSI pin reverse voltage during communication (VPSI_C). 12 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00  Operation Remark Refer to " Connection Examples of Battery Protection IC". 1. Normal status The status when CO pin output voltage (VCO) = "H", DO pin output voltage (VDO) = "H" and PSO pin output voltage (VPSO) = "L" is the normal status. All the conditions mentioned below should be satisfied for returning to the normal status.  The voltage of each of the batteries is in the range from overcharge detection voltage n (VCUn) to overdischarge detection voltage n (VDLn).  CTLC pin voltage and CTLD pin voltage are lower than CTLC pin reverse voltage (VCTLC) and CTLD pin reverse voltage (VCTLD), respectively, and PSI pin voltage is higher than PSI pin reverse voltage (VPSI).  Either (1) or (2) below is satisfied for TH pin voltage (VTH). (1) When VTHC/DX  VTHH: (1  rTHCH)  VREG  VTH  (1  rTHCL)  VREG (2) When VTHC/DX  VTHL: (1  rTHDH)  VREG  VTH  (1  rTHDL)  VREG Caution After the battery is connected, there may be cases when discharging cannot be performed. In this case, the S-8255A Series returns to the normal status when the following condition is satisfied.  Changing the PSI pin voltage to be VDS  0 V  VDS Remark VTHC/DX: VTHH: VTHL: rTHCH: rTHCL: rTHDH: rTHDL: VREG: VDS: THC/DX pin voltage THC/DX pin voltage "H" THC/DX pin voltage "L" High temperature detection ratio during charging Low temperature detection ratio during charging High temperature detection ratio during discharging Low temperature detection ratio during discharging Output voltage for temperature detection Input voltage between VDD pin and VSS pin (V1  V2  V3  V4  V5) 2. Overcharge status When the voltage of any of the batteries exceeds the overcharge detection voltage n (VCUn) and the status continues *1 for the overcharge detection delay time (tCU) or longer, the CO pin changes to the VSS level. This is the overcharge status. The overcharge status is released if the following condition is satisfied.  Voltage of battery  VCLn *1. Refer to "4. Remark VCLn: Delay time setting" for details. Overcharge release voltage n (n = 1 to 5) 13 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00 3. Overdischarge status When the voltage of any of the batteries falls below the overdischarge detection voltage n (VDLn) and the status *1 continues for the overdischarge detection delay time (tDL) or longer, the DO pin changes to the VSS level. This is the overdischarge status. The overdischarge status is released if the following condition is satisfied.  Voltage of battery  VDUn *1. Refer to "4. Remark VDUn: Delay time setting" for details. Overdischarge release voltage n (n = 1 to 5) 4. Delay time setting Users are able to set delay time for the period from when the S-8255A Series detects change in the voltage of any of the batteries until when it outputs to the CO pin or DO pin. Each delay time is determined by a resistor in the S-8255A Series and an external capacitor. In the overchage detection, when the voltage of any of the batteries exceeds overcharge detection voltage n (VCUn), the S-8255A Series starts charging to the CCT pin's capacitor (CCCT) via the CCT pin internal resistance (RCCT). After a certain period, the CO pin changes to the VSS level when the voltage at the CCT pin reaches the CCT pin detection voltage (VCCT). This period is overcharge detection delay time (tCU). tCU is calculated using the following equation. tCU [s] = ln (1  VCCT / VDS)  CCCT [F]  RCCT [M] = ln (1  0.7 typ.)  CCCT [F]  8.31 [M] typ. = 10.0 [M] typ.  CCCT [F] Overdischarge detection delay time (tDL) is calculated using the following equations as well. tDL [ms] = ln (1  VCDT / VDS)  CCDT [F]  RCDT [k] When CCCT = CCDT = 0.1 [F], each delay time is calculated as follows. tCU [s] = 10.0 [M] typ.  0.1 [F] = 1.0 [s] typ. tDL [ms] = 1000 [k] typ.  0.1 [F] = 100 [ms] typ. Remark VDS: Input voltage between VDD pin and VSS pin (V1  V2  V3  V4  V5) 5. 0 V Battery detection function For detection function of self-discharged battery (0 V battery), "available" / "unavailable" is selectable.  0 V battery detection function "available" The voltage VCO changes to the VSS level when the voltage of any of the batteries is V0INHn or lower. 14 Caution When the VDD pin voltage is lower than the minimum value of operation voltage between VDD pin and VSS pin (VDSOP), the S-8255A Series' operation is not assured. Remark V0INHn: VCO: 0 V battery detection voltage n (n = 1 to 5) CO pin voltage Rev.1.4_00 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series 6. SEL1 pin and SEL2 pin Switching control for 3-serial to 5-serial cell is possible by inputting voltage to the SEL1 pin and the SEL2 pin. Be sure to use the SEL1 pin and the SEL2 pin at the "H" or "L" level. Table 10 Settings of SEL1 Pin and SEL2 Pin SEL1 Pin "L" "L" "H" "H" Remark SEL2 Pin "L" "H" "L" "H" Setting 5-serial cell monitoring 4-serial cell monitoring 3-serial cell monitoring Setting inhibited "H" is the status when VSEL1  VSEL1H, VSEL2  VSEL2H, and "L" is the status when VSEL1  VSEL1L, VSEL2  VSEL2L. VSEL1H: VSEL2H: VSEL1L: VSEL2L: SEL1 pin voltage "H" SEL2 pin voltage "H" SEL1 pin voltage "L" SEL2 pin voltage "L" 7. CTLC pin and CTLD pin The CTLC pin controls the CO pin, and the CTLD pin controls the DO pin. Thus it is possible for users to control the CO pin and the DO pin respectively. These controls precede the battery monitoring circuit. Table 11 Status Set by CTLC Pin CTLC Pin VSS level  CTLC pin voltage  VCTLC VCTLC  CTLC pin voltage  VDD level VDD level  CTLC pin voltage  VCTLC_C VCTLC_C  CTLC pin voltage Remark CO Pin "H" VSS level VSS level "H" CTLC pin is at the VDD level or higher in cascade connection. Connect a resistor of 5.1 M to the CTLC pin in this case. VCTLC: CTLC pin reverse voltage VCTLC_C: CTLC pin reverse voltage during communication Table 12 Status Set by CTLD Pin CTLD Pin VSS level  CTLD pin voltage  VCTLD VCTLD  CTLD pin voltage  VDD level VDD level  CTLD pin voltage  VCTLD_C VCTLD_C  CTLD pin voltage Remark DO Pin "H" VSS level VSS level "H" CTLD pin is at the VDD level or higher in cascade connection. Connect a resistor of 5.1 M to the CTLD pin in this case. VCTLD: CTLD pin reverse voltage VCTLD_C: CTLD pin reverse voltage during communication 15 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00 8. PSI pin When the PSI pin is activated, the power-saving function starts to operate, and most operations halt. In this case, the CO pin and DO pin change to the VSS level, and the PSO pin changes to the VDD level. Table 13 Status Set by PSI Pin PSI Pin CO Pin DO Pin PSO Pin VPSI  PSI pin voltage  VDD level "H" "H" VSS level VSS level  PSI pin voltage  VPSI VSS level VSS level VDD level VPSI_C  PSI pin voltage  VSS level VSS level VSS level VDD level PSI pin voltage  VPSI_C "H" "H" VSS level Remark PSI pin is at the VSS level or lower in cascade connection. Connect a resistor of 5.1 M to the PSI pin in this case. VPSI: VPSI_C: PSI pin reverse voltage PSI pin reverse voltage during communication The S-8255A Series is initialized and the power-saving function is released by deactivating the PSI pin. As a result, each detection operation is carried out after returning to the normal status. 9. Temperature detection Serially connect an NTC and a low temperature-dependent resistor (RTH) between the VDD pin and the VREG pin, and then connect their middle point to the TH pin. It allows for temperature detection at four different points: high temperature detection during charging, low temperature detection during charging, high temperature detection during discharging, low temperature detection during discharging. When the temperature rises, according to the NTC temperature characteristics, the resistance (RNTC) decreases, and the ratio between RNTC and RTH changes, and then the TH pin voltage (VTH) increases. When the temperature falls, according to the NTC temperature characteristics, the resistance (RNTC) increases, and the ratio between RNTC and RTH changes, and then the TH pin voltage (VTH) decreases. The temperature detection during charging and temperature detection during discharging switch by comparing THC/DX pin voltage (VTHC/DX) and either of THC/DX pin voltage "H" or "L" (VTHH, VTHL). If the relation between RNTC, RTH, and VTHC/DX satisfies the itemized condition in Table 14 in each temperature detection, and each status continues for the temperature detection delay time (tTH) or longer, the CO pin changes to the VSS level and the DO pin changes to the "H" or VSS level. This is the temperature protection status. If the itemized condition in Table 14 is not satisfied in each temperature detection, and each status continues for tTH or longer, the temperature protection status is released. Table 14 Conditions for Each Temperature Detection Item High temperature detection during charging Low temperature detection during charging High temperature detection during discharging Low temperature detection during discharging Remark 16 rTHCH: rTHCL: rTHDH: rTHDL: TH Pin rTHCH  RTH / (RNTC  RTH) rTHCL  RTH / (RNTC  RTH) rTHDH  RTH / (RNTC  RTH) rTHDL  RTH / (RNTC  RTH) High temperature detection ratio during charging Low temperature detection ratio during charging High temperature detection ratio during discharging Low temperature detection ratio during discharging THC/DX Pin VTHC/DX  VTHH VTHC/DX  VTHH VTHC/DX  VTHL VTHC/DX  VTHL CO Pin DO Pin "H" VSS level VSS level Rev.1.4_00 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series The detection temperature can be set according to the NTC and RTH characteristics. *1 For example, if RNTC and RTH (10 k) are connected to S-8255AAA, each detection temperature is as follows. Table 15 Item Temperature for high temperature detection during charging Temperature for low temperature detection during charging Temperature for high temperature detection during discharging Temperature for low temperature detection during discharging RNTC Detection Temperature rTHCH = 0.670 4.9 k 45C rTHCL = 0.270 27.0 k 0C rTHDH = 0.795 2.6 k 65C rTHDL = 0.190 42.6 k 10C Temperature Detection Ratio *1. The calculation method for RNTC is as follows. rTHCL = RTH / (RNTC  RTH) RNTC = RTH / rTHCL  RTH = 10 k / 0.270  10 k = 27.0 k RNTC [k] When low temperature during charging is detected, RNTC = 27.0 k, so detection temperature = 0C according to the RNTC characteristics shown in Figure 6. 200 180 160 140 120 100 80 60 40 20 0 RNTC = 10 k, Ta = 25C, B constant (25 / 85C) = 3434K 40 25 0 25 Ta [C] 50 75 85 Figure 6 Example of RNTC Characteristics Remark Temperature detection is carried out intermittently for 512 ms typ. per cycle, of which 1 ms typ. is the detection operation period. The VREG pin voltage is output only during detection operation. During other periods, the VREG pin is at the VDD level. Regarding details of intermittent operation, refer to "2. Temperature detection (High temperature detection during charging)" in " Timing Charts". 17 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00  Timing Charts 1. Overcharge detection, overdischarge detection VCUn VCLn Battery voltage VDUn VDLn (n = 1 to 5) VDOH DO pin voltage VSS VCOH CO pin voltage VEB Overcharge detection delay time (tCU) Status *1 (1) (2) (1) *1. (1) : Normal status (2) : Overcharge status (3) : Overdischarge status Figure 7 18 Overdischarge detection delay time (tDL) (3) (1) BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00 2. Temperature detection (High temperature detection during charging) VDD VTHCH = (1  rTHCH)  VREG TH pin voltage VTHCL = (1  rTHCL)  VREG VDOH DO pin voltage VSS VCOH CO pin voltage VSS VDD VTHH THC/DX pin voltage VTHL VSS Status *1 (2) (3) (2) (3) Temperature detection delay time (tTH) (2) (2) (3) (2) (3) (1) (3) (2) (4) *1. (1) : Normal status (2) : Temperature detection sleep time (3) : Temperature detection awake time (4) : Temperature protection status Figure 8 19 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00  Connection Example of Battery Monitoring IC 1. S-8255A Series (10-serial cell) EB NTC1 CTH1 RTH1 RVC11 RVC21 VREG 20 1 TH RVDD1 CVDD1 CVC11 CVC21 RVC31 CVC31 RVC41 CVC41 RVC51 CVC51 RSEL11 2 VDD PSI 19 3 VC1 CTLD 18 4 VC2 CTLC 17 5 VC3 THC/DX 16 6 VC4 S-8255A RCTLD RCTLC RTHC / DX1 CO 15 7 VC5 DO 14 8 VSS PSO 13 9 SEL1 CDT 12 10 SEL2 CCT 11 RSEL21 CCCT1 CPSI_C CCDT1 RCTLD_C RCTLC_C RPSI_C NTC2 CTH2 RTH2 1 TH RVDD2 RVC12 RVC22 RVC32 CVDD2 CVC12 CVC22 CVC32 RVC42 CVC42 RVC52 CVC52 RSEL12 RSEL22 VREG 20 2 VDD PSI 19 3 VC1 CTLD18 4 VC2 CTLC 17 5 VC3 THC/DX 16 6 VC4 S-8255A CCTLD_C CCTLC_C RPSI RTHC / DX2 CO 15 7 VC5 DO 14 8 VSS PSO 13 9 SEL1 CDT 12 10 SEL2 CCT 11 CCCT2 OD OC CCDT2 EB Remark 20 Regarding the recommended values for external components, refer to "Table 16 Components". Figure 9 Constants for External Rev.1.4_00 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Table 16 Constants for External Components Symbol RVDD1*1, RVDD2*1 RVCn1, RVCn2 (n = 1 to 5)*1 RSEL11, RSEL12, RSEL21, RSEL22 RCTLC, RCTLD, RPSI RTHC/DX1, RTHC/DX2 RCTLC_C, RCTLD_C, RPSI_C NTC1, NTC2 RTH1, RTH2 CVDD1, CVDD2*1 CVCn1, CVCn2 (n = 1 to 5)*1 CCTLC_C, CCTLD_C, CPSI_C CCCT1, CCCT2 CCDT1, CCDT2 CTH1, CTH2 *1. Min. Typ. Max. Unit 68 0.68 1 1.0 1.0 4.0   0.68 0.068 470 0.01 0.01 0.1 100 1.00 1 2.0 1.0 5.1 10 10 1.00 0.100 470 0.10 0.10 0.1 100 1.00  5.1  6.0   10.00 1.000    0.1  k k k k M k k F F pF F F F RVDD1  CVDD1 = RVDD2  CVDD2 = 100 F   is recommended. Set filter constants to satisfy RVC1  CVC1 = RVC2  CVC2 = RVC3  CVC3 = RVC4  CVC4 = RVC5  CVC5 = RVDD1  CVDD1. Caution 1. 2. 3. The above constants may be changed without notice. Sufficient evaluation of transient power supply fluctuation and overcurrent protection function with the actual application is needed to determine the proper constants when setting the filter constants between the VDD pin and VSS pin. Contact our sales office if setting the constants between the VDD pin and VSS pin to anything other than the recommended values. It has not been confirmed whether the operation is normal or not in circuits other than the connection example. In addition, the connection example and the constants do not guarantee proper operation. Perform thorough evaluation using the actual application to set the constants. 21 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00  Precautions  The application conditions for the input voltage, output voltage, and load current should not exceed the power dissipation.  Batteries can be connected in any order; however, there may be cases when discharging cannot be performed after a battery is connected. In this case, the S-8255A Series returns to the normal status when the following condition is satisfied.  Changing the PSI pin voltage to be VDS  0 V  VDS Remark VDS: Input voltage between VDD pin and VSS pin (V1  V2  V3  V4  V5)  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit.  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 22 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00  Characteristics (Typical Data) 1. Current consumption 1. 1 IOPE vs. VDS 1. 2 IOPE vs. Ta 40 30 30 IOPE [A] IOPE [A] Ta = 25C 40 20 10 20 15 0 0 0 5 10 15 20 VDS [V] 25 30 1. 3 IPSV vs. VDS VDS = 17.5 V 40 25 0 25 Ta [C] 75 85 1. 4 IPSV vs. Ta Ta = 25C VDS = 17.5 V 0.5 0.5 0.4 0.4 IPSV [A] IPSV [A] 50 0.3 0.2 0.3 0.2 0.1 0.1 0.0 0.0 0 5 10 15 20 VDS [V] 25 30 40 25 0 25 Ta [C] 50 75 85 23 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series 2. Detection voltage, release voltage S-8255AAA 4.12 S-8255AAA 4.100 4.11 4.075 VCL [V] 2. 2 VCU [V] 2. 1 VCU vs. Ta 4.10 4.09 4.08 4.025 40 25 4.000 0 25 Ta [C] 50 75 85 40 25 2. 3 VDL vs. Ta 2. 4 S-8255AAA 2.68 S-8255AAA 2.80 VDU [V] VDL [V] 2.60 2.52 0 25 Ta [C] 50 75 85 0 25 Ta [C] 50 75 85 VDU vs. Ta 2.75 2.70 2.65 2.56 2.60 40 25 0 25 Ta [C] 50 75 85 40 25 Delay time function 3. 1 RCCT vs. Ta 3. 2 VDS = 19 V 12 4 40 25 12.0 0 25 Ta [C] 50 75 85 3. 4 VDS = 15.5 V 1500 40 25 0 25 Ta [C] 50 75 85 VCDT vs. Ta VDS = 15.5 V 12 1250 11 1000 VCDT [V] RCDT [k] 13.0 12.5 3. 3 RCDT vs. Ta 750 500 10 9 250 0 VDS = 19 V 13.5 8 0 VCCT vs. Ta 14.0 VCCT [V] RCCT [M] 16 24 VCL vs. Ta 4.050 2.64 3. Rev.1.4_00 40 25 8 0 25 Ta [C] 50 75 85 40 25 0 25 Ta [C] 50 75 85 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00 4. Output pin 4. 1 ICOH vs. VDS 4. 2 ICOL vs. VDS Ta = 25C 500 300 400 ICOL [A] ICOH [A] Ta = 25C 400 200 100 0 0 5 10 15 20 VDS [V] 25 200 100 30 4. 3 IDOH vs. VDS 300 0 5 10 15 20 VDS [V] Ta = 25C 500 2500 400 2000 IDOL [A] IDOH [A] 30 4. 4 IDOL vs. VDS Ta = 25C 300 200 100 1500 1000 500 0 0 5 10 15 20 VDS [V] 25 0 30 4. 5 IPSOH vs. VDS 0 5 10 15 20 VDS [V] 25 30 4. 6 IPSOL vs. VDS Ta = 25C 120 100 250 80 200 60 40 Ta = 25C 300 IPSOL [A] IPSOH [A] 25 150 100 50 20 0 0 0 5 10 15 20 VDS [V] 25 30 0 5 10 15 20 VDS [V] 25 30 25 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series 5. Temperature detection function 5. 1 rTHCH vs. Ta 5. 2 rTHCL vs. Ta VDS = 17.5 V 0.8 0.8 0.6 0.6 0.4 0.2 0.0 VDS = 17.5 V 1.0 rTHCL rTHCH 1.0 0.4 0.2 40 25 0.0 0 25 Ta [C] 50 75 85 5. 3 rTHDH vs. Ta 40 25 0 25 Ta [C] 0.8 0.8 0.6 0.6 rTHDL rTHDH 1.0 0.4 0.2 40 25 0.0 0 25 Ta [C] 50 75 85 5. 6 VDS = 17.5 V 6.0 40 25 0 25 Ta [C] 50 75 85 tTH vs. Ta VDS = 17.5 V 3.0 2.5 tTH [s] 5.5 VREG [V] 0.4 0.2 5. 5 VREG vs. Ta 5.0 4.5 4.0 75 85 VDS = 17.5 V 1.0 0.0 50 5. 4 rTHDL vs. Ta VDS = 17.5 V 26 Rev.1.4_00 2.0 1.5 40 25 1.0 0 25 Ta [C] 50 75 85 40 25 0 25 Ta [C] 50 75 85 BATTERY MONITORING IC FOR 3-SERIAL TO 5-SERIAL CELL PACK S-8255A Series Rev.1.4_00  Power Dissipation 20-Pin TSSOP Tj = 125C max. 2.0 Power dissipation (PD) [W] B 1.5 A 1.0 0.5 0.0 0 25 50 75 100 125 150 175 Ambient temperature (Ta) [C] Board A B C D E Power Dissipation (PD) 1.47 W 1.69 W     27 20-Pin TSSOP Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. TSSOP20-A-Board-SD-1.0 ABLIC Inc. 6.5±0.3 0.65 20 11 1 10 +0.1 0.15 -0.05 0.22±0.1 No. FT020-B-P-SD-1.0 TITLE TSSOP20-B-PKG Dimensions No. FT020-B-P-SD-1.0 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 4.0±0.1 2.0±0.1 0.3±0.05 +0.1 8.0±0.1 ø1.5 -0 6.9±0.1 1 20 10 11 Feed direction No. FT020-B-C-SD-1.0 TITLE TSSOP20-B-Carrier Tape No. FT020-B-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 60° 17.4±1.0 21.4±1.0 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.2 No. FT020-B-R-SD-1.0 TITLE TSSOP20-B-Reel No. FT020-B-R-SD-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 4.000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-8255AAA-TET1S 价格&库存
很抱歉,暂时无法提供与“S-8255AAA-TET1S”相匹配的价格&库存,您可以联系我们找货
