TMR1302HT
TMR1302HT
    MDT(多维)
    TO226-3
    TMR SENSOR OMNI 17G 1.5UA FAST
TMR1302HT 数据手册
Datasheet V1.2 TMR1302H TMR Omnipolar Switch General Description The TMR1302H is a digital omnipolar magnetic switch that integrates TMR and CMOS technology in order to provide a magnetically triggered digital switch with high sensitivity, high speed, high response frequency and ultra-low power consumption. It integrates a push-pull half-bridge TMR magnetic sensor and CMOS signal processing circuitry within the same package. Designed for use in applications that are both power-critical and performance-demanding, this device includes an on-chip TMR voltage generator for precise magnetic sensing, TMR voltage amplifier and comparator, a Schmitt trigger to provide switching hysteresis for noise rejection, and CMOS push-pull output. An internal band gap regulator is used to provide temperature compensated supply voltage for internal circuits, and it allows a wide range of operating supply voltages. The TMR1302H draws only 1.5μA resulting in ultra-low power operation, additionally it has fast response at 5kHz, accurate switching points, excellent thermal stability, and a wide range of supply voltages. It is available in two packaging form factors: SOT23-3 (P/N TMR1302HS), or TO-92S (P/N TMR1302HT). Features and Benefits  Tunneling Magnetoresistance (TMR) Technology  Ultra-low Power Consumption at 1.5uA  High Frequency Response at 5kHz  Operation with North or South Pole  Low Operate Points for High Sensitivity  Compatible with a Wide Range of Supply Voltages  Excellent Thermal Stability Applications  Utility Meters including Water, Gas, and Heat Meters TMR1302HS (Left), TMR1302HT (Right)  Proximity Switches  Speed Sensing  Rotary and Linear Position Sensing Block Diagram 1/5 Datasheet V1.2 Pin Configuration Pin No. Pin Name TO-92S TO-92S SOT23-3 Pin Function VOUT 1 2 Output GND 2 3 Ground VCC 3 1 Supply Voltage SOT23-3 Absolute Maximum Ratings Parameter Symbol Limit Unit Supply Voltage VCC 7 V Reverse Supply Voltage VRCC 0.3 V Output Current IOUTSINK 9 mA Magnetic Flux Density B 2800 G ESD level(HBM) VESD 4 kV Operating Ambient Temperature TA -40 ~125 °C Storage Temperature Tstg -50 ~ 150 °C Electrical Characteristics (VCC=3.0V, TA=25°C) Parameter Symbol Conditions Min Typ. Max Unit Supply Voltage VCC Operating 1.8 3.0 5.5 V Output High Voltage VOH Vcc-0.3 Vcc V Output Low Voltage VOL 0 0.2 V Supply Current ICC Response Frequency F Output Open μA 1.5 5000 Hz Note: a 100nF capacitor is connected between VCC and GND during all tests in the above table. Magnetic Characteristics (VCC = 3.0V, TA = 25°C) Parameters Operate Point Release Point Hysteresis Symbol Min Typ. Max Units BOPS 17 G BOPN -17 G BRPS 10 G BRPN -10 G BH 7 G 2/5 Datasheet V1.2 Voltage and Temperature Characteristics Output Behavior vs. Magnetic Polarity Magnetic Polarity South North Test Conditions Output B > BOPS Low (On) 0< B < BRPS High (Off) B < BOPN Low (On) 0 > B > BRPN High (Off) Note: when power is turned on under zero magnetic field, the output is “High”. Sensing Direction of Magnetic Field Magnetic Flux Application Information The output of the TMR1302H switches low (turns on) when a magnetic field parallel to the TMR sensor exceeds the operate point threshold, BOP. When the magnetic field is reduced below the release point, BRP, the device output goes high (turns off). The difference between the magnetic operate point and release point is the hysteresis BH of the device. It is strongly recommended that an external bypass capacitor be connected in close proximity to the device between the supply and ground to reduce noise. The typical value of the external capacitor is 0.1μF. 3/5 Datasheet V1.2 Package Information SOT23-3 package drawing TO-92S package drawing TMR Sensor Position Top view and side view (unit: mm) 4/5 Datasheet V1.2 MultiDimension Technology Co., Ltd. Address: No.7 Guangdong Road, Zhangjiagang Free Trade Zone, Jiangsu, 215634, China Web: www.dowaytech.com/en Email: info@dowaytech.com The information provided herein by MultiDimension Technology Co., Ltd. (hereinafter MultiDimension) is believed to be accurate and reliable. Publication neither conveys nor implies any license under patent or other industrial or intellectual property rights. MultiDimension reserves the right to make changes to product specifications for the purpose of improving product quality, reliability, and functionality. MultiDimension does not assume any liability arising out of the application and use of its products. MultiDimension’s customers using or selling this product for use in appliances, devices, or systems where malfunction can reasonably be expected to result in personal injury do so at their own risk and agree to fully indemnify MultiDimension for any damages resulting from such applications. 5/5
TMR1302HT
物料型号:TMR1302H
器件简介:TMR1302H是一款集成了TMR(隧道磁阻)和CMOS技术的数字全极性磁开关,具有高灵敏度、高速度、高响应频率和超低功耗的特点。它在一个封装内集成了推挽半桥TMR磁传感器和CMOS信号处理电路。
引脚分配: - TO-92S封装:VOUT(1)、GND(2)、Vcc(3) - SOT23-3封装:VOUT(2)、GND(3)、Vcc(1)
参数特性: - 超低功耗:1.5μA - 高频响应:5kHz - 可与北或南极磁铁操作 - 低操作点:高灵敏度 - 兼容宽范围的供电电压 - 优秀的热稳定性
功能详解: - 设备包括片上TMR电压发生器、放大器和比较器、施密特触发器(提供噪声抑制的开关迟滞)以及CMOS推挽输出。 - 内部带隙稳压器提供温度补偿的供电电压,允许宽范围的运行供电电压。
应用信息: - 用于水表、气表和热量表等公用事业仪表 - 接近开关 - 速度感应 - 旋转和线性位置感应
封装信息: - 提供SOT23-3(型号TMR1302HS)和TO-92S(型号TMR1302HT)两种封装形式。
TMR1302HT 价格&库存
很抱歉,暂时无法提供与“TMR1302HT”相匹配的价格&库存,您可以联系我们找货
