ICL3221E, ICL3222E, ICL3223E,
ICL3232E, ICL3241E, ICL3243E
Data Sheet
September 15, 2008
±15kV ESD Protected, +3V to +5.5V,
1Microamp, 250kbps, RS-232
Transmitters/Receivers
FN4910.20
Features
• ESD Protection for RS-232 I/O Pins to ±15kV (IEC61000)
The Intersil ICL32xxE devices are 3.0V to 5.5V powered
RS-232 transmitters/receivers which meet ElA/TIA-232 and
V.28/V.24 specifications, even at VCC = 3.0V. Additionally,
they provide ±15kV ESD protection (IEC61000-4-2 Air Gap
and Human Body Model) on transmitter outputs and receiver
inputs (RS-232 pins). Targeted applications are PDAs,
Palmtops, and notebook and laptop computers where the
low operational, and even lower standby, power
consumption is critical. Efficient on-chip charge pumps,
coupled with manual and automatic power-down functions
(except for the ICL3232E), reduce the standby supply
current to a 1µA trickle. Small footprint packaging, and the
use of small, low value capacitors ensure board space
savings as well. Data rates greater than 250kbps are
guaranteed at worst case load conditions. This family is fully
compatible with 3.3V-only systems, mixed 3.3V and 5.0V
systems, and 5.0V-only systems.
The ICL324XE are 3-driver, 5-receiver devices that provide a
complete serial port suitable for laptop or notebook
computers. Both devices also include noninverting
always-active receivers for “wake-up” capability.
The ICL3221E, ICL3223E and ICL3243E, feature an
automatic power-down function which powers down the
on-chip power-supply and driver circuits. This occurs when
an attached peripheral device is shut off or the RS-232 cable
is removed, conserving system power automatically without
changes to the hardware or operating system. These
devices power up again when a valid RS-232 voltage is
applied to any receiver input.
Table 1 summarizes the features of the devices represented
by this data sheet, while Application Note AN9863
summarizes the features of each device comprising the
ICL32xxE 3V family.
• Drop in Replacements for MAX3221E, MAX3222E,
MAX3223E, MAX3232E, MAX3241E, MAX3243E,
SP3243E
• ICL3221E is a Low Power, Pin Compatible Upgrade for 5V
MAX221E
• ICL3222E is a Low Power, Pin Compatible Upgrade for 5V
MAX242E, and SP312E
• ICL3232E is a Low Power Upgrade for HIN232E, ICL232
and Pin Compatible Competitor Devices
• RS-232 Compatible with VCC = 2.7V
• Meets EIA/TIA-232 and V.28/V.24 Specifications at 3V
• Latch-Up Free
• On-Chip Voltage Converters Require Only Four External
0.1µF Capacitors
• Manual and Automatic Power-down Features
• Guaranteed Mouse Driveability (ICL324XE Only)
• Receiver Hysteresis For Improved Noise Immunity
• Guaranteed Minimum Data Rate . . . . . . . . . . . . . 250kbps
• Wide Power Supply Range . . . . . . . Single +3V to +5.5V
• Low Supply Current in Power-down State . . . . . . . . . .1µA
• Pb-Free Available (RoHS Compliant)
Applications
• Any System Requiring RS-232 Communication Ports
- Battery Powered, Hand-Held, and Portable Equipment
- Laptop Computers, Notebooks, Palmtops
- Modems, Printers and other Peripherals
- Digital Cameras
- Cellular/Mobile Phones
Related Literature
• Technical Brief TB363 “Guidelines for Handling and
Processing Moisture Sensitive Surface Mount Devices
(SMDs)”
TABLE 1. SUMMARY OF FEATURES
PART
NUMBER
NUMBER NUMBER
OF Tx
OF Rx
NUMBER OF
MONITOR
RECEIVERS
(ROUTB)
DATA
RATE
(kbps)
RECEIVER
ENABLE
FUNCTION?
READY
OUTPUT?
AUTOMATIC
POWER-DOWN
MANUAL
FUNCTION?
POWER-DOWN?
ICL3221E
1
1
Yes
No
Yes
ICL3222E
2
2
Yes
No
Yes
No
ICL3223E
2
2
Yes
No
Yes
Yes
ICL3232E
2
2
No
No
No
No
ICL3241E
3
5
2
250
Yes
No
Yes
No
ICL3243E
3
5
1
250
No
No
Yes
Yes
1
Yes
CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures.
1-888-INTERSIL or 1-888-468-3774 | Intersil (and design) is a registered trademark of Intersil Americas Inc.
Copyright Intersil Americas Inc. 2000-2005, 2007, 2008. All Rights Reserved
All other trademarks mentioned are the property of their respective owners.
ICL3221E, ICL3222E, ICL3223E, ICL3232E, ICL3241E, ICL3243E
Ordering Information
PART
NUMBER
PART
MARKING
TEMP RANGE
(°C)
PKG.
DWG. #
PACKAGE
ICL3221ECA*
ICL 3221ECA
0 to +70
16 Ld SSOP
M16.209
ICL3221ECAZ* (Note)
ICL32 21ECAZ
0 to +70
16 Ld SSOP (Pb-free)
M16.209
ICL3221ECAZA* (Note)
ICL32 21ECAZ
0 to +70
M16.209
ICL3221ECV*
3221 ECV
0 to +70
16 Ld TSSOP
M16.173
ICL3221ECVZ* (Note)
3221 ECVZ
0 to +70
16 Ld TSSOP (Pb-free)
M16.173
ICL3221EIA*
ICL 3221EIA
-40 to +85
16 Ld SSOP
M16.209
ICL3221EIAZ* (Note)
ICL32 21EIAZ
-40 to +85
M16.209
ICL3221EIV*
3221 EIV
-40 to +85
16 Ld TSSOP
M16.173
ICL3221EIVZ* (Note)
3221 EIVZ
-40 to +85
M16.173
ICL3222ECA*
ICL 3222ECA
0 to +70
20 Ld SSOP
M20.209
ICL3222ECAZ* (Note)
ICL32 22ECAZ
0 to +70
20 Ld SSOP (Pb-free)
M20.209
ICL3222ECP
ICL3222ECP
0 to +70
18 Ld PDIP
E18.3
ICL3222ECV*
ICL 3222ECV
0 to +70
20 Ld TSSOP
M20.173
ICL3222ECVZ* (Note)
ICL32 22ECVZ
0 to +70
20 Ld TSSOP (Pb-free)
M20.173
ICL3222EIA*
ICL 3222EIA
-40 to +85
20 Ld SSOP
M20.209
ICL3222EIAZ* (Note)
ICL32 22EIAZ
-40 to +85
M20.209
ICL3222EIB*
ICL3222EIB
-40 to +85
18 Ld SOIC
M18.3
ICL3222EIBZ* (Note)
3222EIBZ
-40 to +85
18 Ld SOIC (Pb-free)
M18.3
ICL3222EIV*
ICL 3222EIV
-40 to +85
20 Ld TSSOP
M20.173
ICL3222EIVZ* (Note)
ICL32 22EIVZ
-40 to +85
M20.173
ICL3223ECA*
ICL 3223ECA
0 to +70
20 Ld SSOP
M20.209
ICL3223ECAZ* (Note)
ICL32 23ECAZ
0 to +70
M20.209
ICL3223ECV*
ICL 3223ECV
0 to +70
20 Ld TSSOP
M20.173
ICL3223ECVZ* (Note)
ICL32 23ECVZ
0 to +70
M20.173
ICL3223EIA*
ICL 3223EIA
-40 to +85
20 Ld SSOP
M20.209
ICL3223EIAZ* (Note)
ICL32 23EIAZ
-40 to +85
M20.209
ICL3223EIV*
ICL 3223EIV
-40 to +85
20 Ld TSSOP
M20.173
ICL3223EIVZ* (Note)
ICL32 23EIVZ
-40 to +85
M20.173
ICL3232ECA*
ICL 3232ECA
0 to +70
16 Ld SSOP
M16.209
ICL3232ECAZ* (Note)
3232 ECAZ
0 to +70
M16.209
ICL3232ECB*
ICL3232ECB
0 to +70
16 Ld SOIC
M16.3
ICL3232ECBZ* (Note)
3232ECBZ
0 to +70
16 Ld SOIC (Pb-free)
M16.3
ICL3232ECBN*
3232ECBN
0 to +70
16 Ld SOIC
M16.15
ICL3232ECBNZ* (Note)
3232ECBNZ
0 to +70
M16.15
ICL3232ECV-16*
3232E CV-16
0 to +70
16 Ld TSSOP
M16.173
ICL3232ECV-16Z* (Note)
3232E CV-16Z
0 to +70
M16.173
ICL3232ECV-20*
ICL3232 ECV-20
0 to +70
20 Ld TSSOP
M20.173
ICL3232ECV-20Z *(Note)
ICL3232 ECV-20Z
0 to +70
M20.173
ICL3232EIA*
ICL3232 EIA
-40 to +85
16 Ld SSOP
M16.209
ICL3232EIAZ* (Note)
3232 EIAZ
-40 to +85
M16.209
2
FN4910.20
September 15, 2008
(Continued)
PART
NUMBER
PART
MARKING
TEMP RANGE
(°C)
PKG.
DWG. #
PACKAGE
ICL3232EIB*
ICL3232EIB
-40 to +85
16 Ld SOIC
M16.3
ICL3232EIBZ* (Note)
3232EIBZ
-40 to +85
M16.3
ICL3232EIBNZ* (Note)
3232EIBNZ
-40 to +85
M16.15
ICL3232EIV-16*
3232E IV-16
-40 to +85
16 Ld TSSOP
M16.173
ICL3232EIV-16Z* (Note)
3232E IV-16Z
-40 to +85
M16.173
ICL3232EIV-20*
ICL3232 EIV-20
-40 to +85
20 Ld TSSOP
M20.173
ICL3232EIV-20Z* (Note)
ICL3232 EIV-20Z
-40 to +85
M20.173
ICL3241ECA*
ICL 3241ECA
0 to +70
28 Ld SSOP
M28.209
ICL3241ECAZ* (Note)
ICL3241 ECAZ
0 to +70
28 Ld SSOP (Pb-free)
M28.209
ICL3241ECB*
ICL3241ECB
0 to +70
28 Ld SOIC
M28.3
ICL3241ECBZ* (Note)
ICL3241ECBZ
0 to +70
28 Ld SOIC (Pb-free)
M28.3
ICL3241ECV*
ICL3241 ECV
0 to +70
28 Ld TSSOP
M28.173
ICL3241ECVZ* (Note)
ICL3241 ECVZ
0 to +70
28 Ld TSSOP (Pb-free)
M28.173
ICL3241EIA*
ICL 3241EIA
-40 to +85
28 Ld SSOP
M28.209
ICL3241EIAZ* (Note)
ICL3241 EIAZ
-40 to +85
M28.209
ICL3241EIB*
ICL3241EIB
-40 to +85
28 Ld SOIC
M28.3
ICL3241EIBZ* (Note)
ICL3241EIBZ
-40 to +85
M28.3
ICL3241EIV*
ICL3241 EIV
-40 to +85
28 Ld TSSOP
M28.173
ICL3241EIVZ* (Note)
ICL3241 EIVZ
-40 to +85
M28.173
ICL3243ECA*
ICL 3243ECA
0 to +70
28 Ld SSOP
M28.209
ICL3243ECAZ* (Note)
ICL32 43ECAZ
0 to +70
M28.209
ICL3243ECB*
ICL3243ECB
0 to +70
28 Ld SOIC
M28.3
ICL3243ECBZ* (Note)
ICL3243ECBZ
0 to +70
M28.3
ICL3243ECV*
ICL3243 ECV
0 to +70
28 Ld TSSOP
M28.173
ICL3243ECVZA* (Note)
ICL3243 ECVZ
0 to +70
M28.173
ICL3243ECVZ* (Note)
ICL3243 ECVZ
0 to +70
M28.173
ICL3243EIA*
ICL 3243EIA
-40 to +85
28 Ld SSOP
M28.209
ICL3243EIAZ* (Note)
ICL32 43EIAZ
-40 to +85
M28.209
ICL3243EIV*
ICL3243 EIV
-40 to +85
28 Ld TSSOP
M28.173
ICL3243EIVZ* (Note)
ICL3243 EIVZ
-40 to +85
M28.173
*Add “-T” suffix for tape and reel. Please refer to TB347 for details on reel specifications.
NOTE: These Intersil Pb-free plastic packaged products employ special Pb-free material sets, molding compounds/die attach materials, and 100%
matte tin plate plus anneal (e3 termination finish, which is RoHS compliant and compatible with both SnPb and Pb-free soldering operations). Intersil
Pb-free products are MSL classified at Pb-free peak reflow temperatures that meet or exceed the Pb-free requirements of IPC/JEDEC J STD-020.
3
FN4910.20
September 15, 2008
Pinouts
ICL3222E
(18 LD PDIP, SOIC)
TOP VIEW
ICL3221E
(16 LD SSOP, TSSOP)
TOP VIEW
16 FORCEOFF
EN 1
EN 1
18 SHDN
C1+ 2
15 VCC
C1+ 2
17 VCC
V+ 3
14 GND
V+ 3
16 GND
C1- 4
13 T1OUT
C1- 4
15 T1OUT
C2+ 5
12 FORCEON
C2+ 5
14 R1IN
C2- 6
11 T1IN
C2- 6
13 R1OUT
10 INVALID
V- 7
9 R1OUT
R1IN 8
V- 7
12 T1IN
T2OUT 8
11 T2IN
R2IN 9
ICL3222E
(20 LD SSOP, TSSOP)
TOP VIEW
20 SHDN
EN 1
C1+ 2
19 VCC
V+ 3
18 GND
10 R2OUT
ICL3223E
(20 LD SSOP, TSSOP)
TOP VIEW
EN 1
20 FORCEOFF
C1+ 2
19 VCC
V+ 3
18 GND
C1- 4
17 T1OUT
C1- 4
17 T1OUT
C2+ 5
16 R1IN
C2+ 5
16 R1IN
C2- 6
15 R1OUT
C2- 6
15 R1OUT
14 NC
V- 7
V- 7
14 FORCEON
T2OUT 8
13 T1IN
T2OUT 8
13 T1IN
R2IN 9
12 T2IN
R2IN 9
12 T2IN
11 NC
R2OUT 10
R2OUT 10
11 INVALID
ICL3232E
(20 LD TSSOP-20)
TOP VIEW
ICL3232E
(16 LD SOIC, SSOP, TSSOP-16)
TOP VIEW
C1+ 1
16 VCC
NC 1
V+ 2
15 GND
C1+ 2
19 VCC
V+ 3
18 GND
20 NC
C1- 3
14 T1OUT
C2+ 4
13 R1IN
C1- 4
17 T1OUT
C2- 5
12 R1OUT
C2+ 5
16 R1IN
V- 6
11 T1IN
C2- 6
15 R1OUT
T2OUT 7
10 T2IN
V- 7
14 T1IN
T2OUT 8
13 T2IN
9 R2OUT
R2IN 8
R2IN 9
NC 10
4
12 R2OUT
11 NC
FN4910.20
September 15, 2008
Pinouts
(Continued)
ICL3243E
(28 LD SOIC, SSOP, TSSOP)
TOP VIEW
ICL3241E
TOP VIEW
C2+ 1
28 C1+
C2+ 1
28 C1+
C2- 2
27 V+
C2- 2
27 V+
V- 3
26 VCC
V- 3
26 VCC
R1IN 4
25 GND
R1IN 4
25 GND
R2IN 5
24 C1-
R2IN 5
24 C1-
R3IN 6
23 EN
R3IN 6
23 FORCEON
R4IN 7
22 SHDN
R4IN 7
22 FORCEOFF
R5IN 8
21 R1OUTB
R5IN 8
21 INVALID
T1OUT 9
20 R2OUTB
T1OUT 9
20 R2OUTB
T2OUT 10
19 R1OUT
T2OUT 10
19 R1OUT
T3OUT 11
18 R2OUT
T3OUT 11
18 R2OUT
T3IN 12
17 R3OUT
T3IN 12
17 R3OUT
T2IN 13
16 R4OUT
T2IN 13
16 R4OUT
T1IN 14
15 R5OUT
T1IN 14
15 R5OUT
Pin Descriptions
PIN
VCC
FUNCTION
System power supply input (3.0V to 5.5V).
V+
Internally generated positive transmitter supply (+5.5V).
V-
Internally generated negative transmitter supply (-5.5V).
GND
Ground connection.
C1+
External capacitor (voltage doubler) is connected to this lead.
C1-
C2+
External capacitor (voltage inverter) is connected to this lead.
C2-
TIN
TTL/CMOS compatible transmitter Inputs.
TOUT
RIN
ROUT
±15kV ESD Protected, RS-232 level (nominally ±5.5V) transmitter outputs.
±15kV ESD Protected, RS-232 compatible receiver inputs.
TTL/CMOS level receiver outputs.
ROUTB
TTL/CMOS level, noninverting, always enabled receiver outputs.
INVALID
Active low output that indicates if no valid RS-232 levels are present on any receiver input.
EN
SHDN
Active low receiver enable control; doesn’t disable ROUTB outputs.
Active low input to shut down transmitters and on-board power supply, to place device in low power mode.
FORCEOFF Active low to shut down transmitters and on-chip power supply. This overrides any automatic circuitry and FORCEON (see Table 2).
FORCEON
Active high input to override automatic power-down circuitry thereby keeping transmitters active (FORCEOFF must be high).
5
FN4910.20
September 15, 2008
Typical Operating Circuits
ICL3221E
C3 (OPTIONAL CONNECTION, NOTE)
+3.3V
0.1µF
15
2
+ C1+
4
C15
+ C2+
6
C2-
C1
0.1µF
C2
0.1µF
T1IN
TTL/CMOS
LOGIC LEVELS
R1OUT
VCC
3
V- 7
C4
+ 0.1µF
T1
11
+ C3
0.1µF
V+
13
9
T1OUT
8
R1IN
RS-232
LEVELS
5kΩ
R1
1 EN
16
VCC
FORCEOFF
12
FORCEON
GND
INVALID
10
TO POWER
CONTROL LOGIC
14
NOTE: The negative terminal of C3 can be connected to either VCC or GND
ICL3222E
C1
0.1µF
C2
0.1µF
T1IN
T2IN
TTL/CMOS
LOGIC LEVELS
R1OUT
0.1µF
2
4
5
6
+3.3V
17
C1+
VCC
3
V+
C1C2+
V-
C2-
12
11
+ C3
0.1µF
7
T1
15
T2
C4
0.1µF
T1OUT
8
T2OUT
14
13
R1IN
RS-232
LEVELS
5kΩ
R1
9
10
R2OUT
R2IN
1 EN
5kΩ
R2
SHDN
18
VCC
GND
16
6
FN4910.20
September 15, 2008
(Continued)
ICL3223E
+3.3V
0.1µF
2
4
C1
0.1µF
5
6
C2
0.1µF
T1IN
T2IN
TTL/CMOS
LOGIC LEVELS
R1OUT
R2OUT
19
C1+
VCC
C1C2+
C2-
3
+ C3
0.1µF
V- 7
C4
0.1µF
V+
T1
13
17
T2
12
8
15
5kΩ
R2
5kΩ
10
1
9
EN
FORCEOFF
14
T2OUT
16
R1
INVALID
FORCEON
T1OUT
R1IN
RS-232
LEVELS
R2IN
VCC
TO POWER
CONTROL LOGIC
GND
18
ICL3232E
C1
0.1µF
C2
0.1µF
T1IN
TTL/CMOS
LOGIC LEVELS
T2IN
R1OUT
0.1µF
1
3
4
5
11
10
C1+
+3.3V
16
VCC
V+
C1C2+
V-
C2T1
2
+ C3
0.1µF
6
C4
0.1µF
14
T2
T1OUT
7
T2OUT
13
12
R1
R1IN
RS-232
LEVELS
5kΩ
9
8
R2OUT
R2
R2IN
5kΩ
GND
15
7
FN4910.20
September 15, 2008
(Continued)
ICL3241E
+3.3V
C1
0.1µF
C2
0.1µF
T1IN
ICL3243E
+3.3V
0.1µF
28
24
1
2
C1+
VCC
V+
C1C2+
V-
C2-
T1
14
3
C4
0.1µF
C2
0.1µF
C11
C2+
2
C2-
C1+
26
27
VCC
V+
24
VT1
3
T2OUT
RS-232
LEVELS
T2IN
11
13
10
T2OUT
T3
RS-232
LEVELS
11
T3IN
R1OUTB
C4
0.1µF
T1OUT
T2
12
T3OUT
21
C3
0.1µF
9
T1IN
10
T3IN
T3OUT
R2OUTB
R2OUTB
19
4
R1OUT
R1
18
17
R1IN
R1
TTL/CMOS
LOGIC
LEVELS
R2IN
5kΩ
18
16
R2IN
RS-232
LEVELS
R4
17
15
R3IN
EN
5kΩ
R5
R4IN
R4
R5IN
5kΩ
15
8
R5OUT
R5IN
23
5kΩ
R5
FORCEON
GND
25
VCC
TO POWER
CONTROL
LOGIC
8
RS-232
LEVELS
7
R4OUT
22
SHDN
5kΩ
16
8
R5OUT
6
R3
R4IN
5kΩ
5kΩ
R3OUT
7
R4OUT
5
R2
R3IN
5kΩ
R3
5kΩ
R2OUT
6
R3OUT
4
R1OUT
5
R2
23
19
R1IN
5kΩ
R2OUT
VCC
28
C1
0.1µF
14
T1OUT
T3
12
+ C3
0.1µF
9
T2
13
27
T2IN
TTL/CMOS
LOGIC
LEVELS
0.1µF
26
22
FORCEOFF
21
INVALID
GND
25
FN4910.20
September 15, 2008
Absolute Maximum Ratings
Thermal Information
VCC to GND. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -0.3V to 6V
V+ to GND . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -0.3V to 7V
V- to GND. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +0.3V to -7V
V+ to V- . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14V
Input Voltages
TIN, FORCEOFF, FORCEON, EN, SHDN . . . . . . . . . -0.3V to 6V
RIN . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±25V
Output Voltages
TOUT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±13.2V
ROUT, INVALID. . . . . . . . . . . . . . . . . . . . . . . . -0.3V to VCC +0.3V
Short Circuit Duration
TOUT . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Continuous
ESD Rating . . . . . . . . . . . . . . . . . . . . . . . . . See Specification Table
Thermal Resistance (Typical, Note 1)
Operating Conditions
θJA (°C/W)
18 Ld PDIP Package* . . . . . . . . . . . . . . . . . . . . . . .
80
16 Ld Wide SOIC Package . . . . . . . . . . . . . . . . . . .
100
16 Ld Narrow SOIC Package. . . . . . . . . . . . . . . . . .
115
18 Ld SOIC Package . . . . . . . . . . . . . . . . . . . . . . . .
75
28 Ld SOIC Package . . . . . . . . . . . . . . . . . . . . . . . .
75
16 Ld SSOP Package . . . . . . . . . . . . . . . . . . . . . . .
135
20 Ld SSOP Package . . . . . . . . . . . . . . . . . . . . . . .
122
16 Ld TSSOP Package . . . . . . . . . . . . . . . . . . . . . .
145
20 Ld TSSOP Package . . . . . . . . . . . . . . . . . . . . . .
140
28 Ld SSOP and TSSOP Packages . . . . . . . . . . . .
100
Maximum Junction Temperature (Plastic Package) . . . . . . +150°C
Maximum Storage Temperature Range . . . . . . . . . .-65°C to +150°C
Pb-free reflow profile . . . . . . . . . . . . . . . . . . . . . . . . . .see link below
http://www.intersil.com/pbfree/Pb-FreeReflow.asp
Temperature Range
ICL32xxECX. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to +70°C
ICL32xxEIX . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .-40°C to +85°C
CAUTION: Do not operate at or near the maximum ratings listed for extended periods of time. Exposure to such conditions may adversely impact product reliability and
result in failures not covered by warranty.
NOTE:
1. θJA is measured with the component mounted on a low effective thermal conductivity test board in free air. See Tech Brief TB379 for details.
Electrical Specifications
Test Conditions: VCC = 3V to 5.5V, C1 - C4 = 0.1µF; Unless Otherwise Specified.
Typicals are at TA = +25°C.
PARAMETER
TEST CONDITIONS
TEMP
(°C)
MIN
(Note 3)
TYP
MAX
(Note 3) UNITS
DC CHARACTERISTICS
Supply Current, Automatic
Power-down
All RIN Open, FORCEON = GND, FORCEOFF = VCC
(ICL3221E, ICL3223E, ICL3243E Only)
25
1.0
10
µA
Supply Current, Power-down
FORCEOFF = SHDN = GND (Except ICL3232E)
25
1.0
10
µA
Supply Current,
Automatic Power-down Disabled
VCC = 3.0V, ICL3241,
All Outputs Unloaded,
FORCEON = FORCEOFF = ICL3243
SHDN = VCC
VCC = 3.0V, ICL3223
25
0.3
1.0
mA
25
0.7
3.0
mA
25
0.3
1.0
mA
VCC = 3.15V, ICL3221,
ICL3222, ICL3223, ICL3232
LOGIC AND TRANSMITTER INPUTS AND RECEIVER OUTPUTS
Input Logic Threshold Low
TIN, FORCEON, FORCEOFF, EN, SHDN
Full
0.8
V
Input Logic Threshold High
TIN, FORCEON,
FORCEOFF, EN, SHDN
VCC = 3.3V
Full
2.0
V
VCC = 5.0V
Full
2.4
V
Input Leakage Current
Full
±0.01
±1.0
µA
Output Leakage Current
(Except ICL3232E)
FORCEOFF = GND or EN = VCC
Full
±0.05
±10
µA
Output Voltage Low
IOUT = 1.6mA
Full
0.4
V
Output Voltage High
IOUT = -1.0mA
Full
VCC - 0.6
VCC - 0.1
V
AUTOMATIC POWER-DOWN (ICL3221E, ICL3223E, ICL3243E Only, FORCEON = GND, FORCEOFF = VCC)
Receiver Input Thresholds to
Enable Transmitters
ICL32xxE Powers Up (see Figure 6)
Full
-2.7
2.7
V
Disable Transmitters
ICL32xxE Powers Down (see Figure 6)
Full
-0.3
0.3
V
INVALID Output Voltage Low
IOUT = 1.6mA
Full
0.4
V
INVALID Output Voltage High
IOUT = -1.0mA
Full
VCC - 0.6
V
9
FN4910.20
September 15, 2008
Typicals are at TA = +25°C. (Continued)
TEMP
(°C)
MIN
(Note 3)
TYP
Receiver Threshold to Transmitters
Enabled Delay (tWU)
25
100
µs
Receiver Positive or Negative
Threshold to INVALID High Delay
(tINVH)
25
1
µs
Threshold to INVALID Low Delay
(tINVL)
25
30
µs
25
-25
25
V
1.2
V
PARAMETER
TEST CONDITIONS
MAX
(Note 3) UNITS
RECEIVER INPUTS
Input Voltage Range
Input Threshold Low
VCC = 3.3V
25
0.6
VCC = 5.0V
25
0.8
1.5
V
Input Threshold High
VCC = 3.3V
25
1.5
2.4
V
VCC = 5.0V
25
1.8
2.4
V
Input Hysteresis
25
0.5
V
Input Resistance
25
3
5
7
kΩ
TRANSMITTER OUTPUTS
Output Voltage Swing
All Transmitter Outputs Loaded with 3kΩ to Ground
Full
±5.0
±5.4
V
Output Resistance
VCC = V+ = V- = 0V, Transmitter Output = ±2V
Full
300
10M
Ω
Full
±35
±60
mA
Full
±25
µA
T1IN = T2IN = GND, T3IN = VCC, T3OUT Loaded with 3kΩ
to GND, T1OUT and T2OUT Loaded with 2.5mA Each
Full
±5
V
Maximum Data Rate
RL = 3kΩ, CL = 1000pF, One Transmitter Switching
Full
250
500
kbps
Receiver Propagation Delay
Receiver Input to Receiver
Output, CL = 150pF
tPHL
25
0.15
µs
tPLH
25
0.15
μs
Output Short-Circuit Current
VOUT = ±12V, VCC = 0V or 3V to 5.5V,
Automatic Power-down or FORCEOFF = SHDN = GND
MOUSE DRIVEABILITY (ICL324XE Only)
Transmitter Output Voltage
(see Figure 9)
TIMING CHARACTERISTICS
Receiver Output Enable Time
Normal Operation (Except ICL3232E)
25
200
ns
Receiver Output Disable Time
25
200
ns
Transmitter Skew
tPHL to tPLH (Note 2)
25
100
ns
Receiver Skew
tPHL to tPLH
25
50
ns
Transition Region Slew Rate
CL = 150pF to 2500pF
VCC = 3.3V,
RL = 3kΩ to 7kΩ,
CL = 150pF to 1000pF
Measured from 3V to -3V or
-3V to 3V
25
4
30
V/μs
25
6
30
V/μs
ESD PERFORMANCE
RS-232 Pins (TOUT, RIN)
All Other Pins
Human Body Model
25
±15
kV
IEC61000-4-2 Contact Discharge
25
±8
kV
IEC61000-4-2 Air Gap Discharge
25
±15
kV
Human Body Model
25
±2
kV
NOTES:
2. Transmitter skew is measured at the transmitter zero crossing points.
3. Parts are 100% tested at +25°C. Full temp limits are guaranteed by bench and tester characterization
10
FN4910.20
September 15, 2008
Detailed Description
ICL32xxE interface ICs operate from a single +3V to +5.5V
supply, guarantee a 250kbps minimum data rate, require
only four small external 0.1µF capacitors, feature low power
consumption, and meet all ElA RS-232C and V.28
specifications. The circuit is divided into three sections:
charge pump, transmitters and receivers.
Charge-Pump
Intersil’s new ICL32xxE family utilizes regulated on-chip dual
charge pumps as voltage doublers, and voltage inverters to
generate ±5.5V transmitter supplies from a VCC supply as
low as 3.0V. This allows these devices to maintain RS-232
compliant output levels over the ±10% tolerance range of
3.3V powered systems. The efficient on-chip power supplies
require only four small, external 0.1µF capacitors for the
voltage doubler and inverter functions at VCC = 3.3V. See
“Capacitor Selection” on page 14 and Table 3 on page 14 for
capacitor recommendations for other operating conditions.
The charge pumps operate discontinuously (i.e., they turn off
as soon as the V+ and V- supplies are pumped up to the
nominal values), resulting in significant power savings.
Transmitters
The transmitters are proprietary, low dropout, inverting
drivers that translate TTL/CMOS inputs to EIA/TIA-232
output levels. Coupled with the on-chip ±5.5V supplies,
these transmitters deliver true RS-232 levels over a wide
range of single supply system voltages.
Except for the ICL3232E, all transmitter outputs disable and
assume a high impedance state when the device enters the
power-down mode (see Table 2). These outputs may be
driven to ±12V when disabled.
All devices guarantee a 250kbps data rate for full load
conditions (3kΩ and 1000pF), VCC ≥ 3.0V, with one
transmitter operating at full speed. Under more typical
conditions of VCC ≥ 3.3V, RL = 3kΩ, and CL = 250pF, one
transmitter easily operates at 900kbps.
Transmitter inputs float if left unconnected, and may cause
ICC increases. Connect unused inputs to GND for the best
performance.
Receivers
All the ICL32xxE devices contain standard inverting receivers
that three-state (except for the ICL3232E) via the EN or
FORCEOFF control lines. Additionally, the two ICL324XE
products include noninverting (monitor) receivers (denoted by
the ROUTB label) that are always active, regardless of the
state of any control lines. All the receivers convert RS-232
signals to CMOS output levels and accept inputs up to ±25V
while presenting the required 3kW to 7kW input impedance
(see Figure 1) even if the power is off (VCC = 0V). The
receivers’ Schmitt trigger input stage uses hysteresis to
increase noise immunity and decrease errors due to slow
input signal transitions.
11
The ICL3221E, ICL3222E, ICL3223E, ICL3241E inverting
receivers disable only when EN is driven high. ICL3243E
receivers disable during forced (manual) power-down, but
not during automatic power-down (see Table 2).
ICL3241E and ICL3243E monitor receivers remain active
even during manual power-down and forced receiver disable,
making them extremely useful for Ring Indicator monitoring.
Standard receivers driving powered down peripherals must be
disabled to prevent current flow through the peripheral’s
protection diodes (see Figures 2 and 3). This renders them
useless for wake up functions, but the corresponding monitor
receiver can be dedicated to this task as shown in Figure 3.
VCC
RXIN
-25V ≤ VRIN ≤ +25V
RXOUT
5kΩ
GND ≤ VROUT ≤ VCC
GND
FIGURE 1. INVERTING RECEIVER CONNECTIONS
Low Power Operation
These 3V devices require a nominal supply current of
0.3mA, even at VCC = 5.5V, during normal operation (not in
power-down mode). This is considerably less than the 5mA
to 11mA current required by comparable 5V RS-232 devices,
allowing users to reduce system power simply by switching
to this new family.
Pin Compatible Replacements for 5V Devices
The ICL3221E, ICL3222E, ICL3232E are pin compatible
with existing 5V RS-232 transceivers - See the “Features”
section on page 1 for details.
This pin compatibility coupled with the low ICC and wide
operating supply range, make the ICL32xxE potential lower
power, higher performance drop-in replacements for existing
5V applications. As long as the ±5V RS-232 output swings are
acceptable, and transmitter input pull-up resistors aren’t
required, the IICL32xxE should work in most 5V applications.
When replacing a device in an existing 5V application, it is
acceptable to terminate C3 to VCC as shown on the “Typical
Operating Circuits” on page 6. Nevertheless, terminate C3 to
GND if possible, as slightly better performance results from
this configuration.
Power-down Functionality
(Except ICL3232E)
The already low current requirement drops significantly when
the device enters power-down mode. In power-down, supply
current drops to 1µA, because the on-chip charge pump turns
off (V+ collapses to VCC, V- collapses to GND), and the
transmitter outputs three-state. Inverting receiver outputs may
or may not disable in power-down; refer to Table 2 for details.
This micro-power mode makes these devices ideal for
battery powered and portable applications.
FN4910.20
September 15, 2008
Software Controlled (Manual) Power-down
The ICL3221E, ICL3223E, and ICL3243E utilize a two pin
approach where the FORCEON and FORCEOFF inputs
determine the IC’s mode. For always enabled operation,
FORCEON and FORCEOFF are both strapped high. To
switch between active and power-down modes, under logic
or software control, only the FORCEOFF input need be
driven. The FORCEON state isn’t critical, as FORCEOFF
dominates over FORCEON. Nevertheless, if strictly manual
control over power-down is desired, the user must strap
FORCEON high to disable the automatic power-down
circuitry. ICL3243E inverting (standard) receiver outputs also
disable when the device is in manual power-down, thereby
eliminating the possible current path through a shutdown
peripheral’s input protection diode (see Figures 2 and 3).
Most devices in the ICL32xxE family provide pins that allow
the user to force the IC into the low power, standby state.
On the ICL3222E and ICL3241E, the power-down control is
via a simple shutdown (SHDN) pin. Driving this pin high
enables normal operation, while driving it low forces the IC
into its power-down state. Connect SHDN to VCC if the
power-down function isn’t needed. Note that all the receiver
outputs remain enabled during shutdown (see Table 2). For
the lowest power consumption during power-down, the
receivers should also be disabled by driving the EN input
high (see next section, and Figures 2 and 3).
TABLE 2. POWER-DOWN AND ENABLE LOGIC TRUTH TABLE
RS-232
SIGNAL
PRESENT
AT
RECEIVER
INPUT?
FORCEOFF
ROUTB
OR SHDN FORCEON
EN
TRANSMITTER RECEIVER OUTPUTS INVALID
INPUT
INPUT
INPUT
OUTPUTS
OUTPUTS (NOTE 4) OUTPUT
MODE OF OPERATION
ICL3222E, ICL3241E
N/A
L
N/A
L
High-Z
Active
Active
N/A
Manual Power-down
N/A
L
N/A
H
High-Z
High-Z
Active
N/A
Manual Power-down with Receiver
Disabled
N/A
H
N/A
L
Active
Active
Active
N/A
Normal Operation
N/A
H
N/A
H
Active
High-Z
Active
N/A
Normal Operation withReceiver
Disabled
ICL3221E, ICL3223E
No
H
H
L
Active
Active
N/A
L
No
H
H
H
Active
High-Z
N/A
L
Normal Operation
(Auto Power-down Disabled)
Yes
H
L
L
Active
Active
N/A
H
Yes
H
L
H
Active
High-Z
N/A
H
No
H
L
L
High-Z
Active
N/A
L
No
H
L
H
High-Z
High-Z
N/A
L
Yes
L
X
L
High-Z
Active
N/A
H
Manual Power-down
Yes
L
X
H
High-Z
High-Z
N/A
H
Disabled
No
L
X
L
High-Z
Active
N/A
L
Manual Power-down
No
L
X
H
High-Z
High-Z
N/A
L
Disabled
No
H
H
N/A
Active
Active
Active
L
Normal Operation
Yes
H
L
N/A
Active
Active
Active
H
Normal Operation
(Auto Power-down Enabled)
No
H
L
N/A
High-Z
Active
Active
L
Power-down Due to Auto Power-down
Logic
Yes
L
X
N/A
High-Z
High-Z
Active
H
Manual Power-down
No
L
X
N/A
High-Z
High-Z
Active
L
Manual Power-down
Normal Operation
Logic
ICL3243E
NOTE:
4. Applies only to the ICL3241E and ICL3243E.
12
FN4910.20
September 15, 2008
The INVALID output always indicates whether or not a valid
RS-232 signal is present at any of the receiver inputs (see
Table 2), giving the user an easy way to determine when the
interface block should power down. In the case of a
disconnected interface cable where all the receiver inputs
are floating (but pulled to GND by the internal receiver pull
down resistors), the INVALID logic detects the invalid levels
and drives the output low. The power management logic
then uses this indicator to power down the interface block.
Reconnecting the cable restores valid levels at the receiver
inputs, INVALID switches high, and the power management
logic wakes up the interface block. INVALID can also be
used to indicate the DTR or RING INDICATOR signal, as
long as the other receiver inputs are floating, or driven to
GND (as in the case of a powered down driver). Connecting
FORCEOFF and FORCEON together disables the
automatic power-down feature, enabling them to function as
a manual SHUTDOWN input (see Figure 4).
VCC
VCC
VOUT = VCC
Rx
POWERED
DOWN
UART
Tx
SHDN = GND
GND
FORCEON
INVALID
ICL3221E,
ICL3223E,
ICL3243E
I/O
UART
CPU
FIGURE 4. CONNECTIONS FOR MANUAL POWER-DOWN
WHEN NO VALID RECEIVER SIGNALS ARE
PRESENT
With any of the control schemes, the time required to exit
power-down, and resume transmission is only 100µs. A
mouse, or other application, may need more time to wake up
from shutdown. If automatic power-down is being utilized,
the RS-232 device will reenter power-down if valid receiver
levels aren’t reestablished within 30µs of the ICL32xxE
powering up. Figure 5 illustrates a circuit that keeps the
ICL32xxE from initiating automatic power-down for 100ms
after powering up. This gives the slow-to-wake peripheral
circuit time to reestablish valid RS-232 output levels.
CURRENT
FLOW
VCC
FORCEOFF
PWR
MGT
LOGIC
OLD
RS-232 CHIP
FIGURE 2. POWER DRAIN THROUGH POWERED DOWN
PERIPHERAL
POWER
MANAGEMENT
UNIT
MASTER POWER-DOWN LINE
0.1µF
FORCEOFF
VCC
FIGURE 5. CIRCUIT TO PREVENT AUTO POWER-DOWN
FOR 100ms AFTER FORCED POWERUP
ICL324XE
VCC
R2OUTB
RX
POWERED
DOWN
UART
VOUT = HI-Z
R2OUT
TX
R2IN
T1IN
T1OUT
FORCEOFF = GND
OR SHDN = GND, EN = VCC
FIGURE 3. DISABLED RECEIVERS PREVENT POWER DRAIN
13
FORCEON
TRANSITION
DETECTOR
TO
WAKE-UP
LOGIC
1MΩ
Even greater power savings is available by using the
devices which feature an automatic power-down function.
When no valid RS-232 voltages (see Figure 6) are sensed
on any receiver input for 30µs, the charge pump and
transmitters power-down, thereby reducing supply current to
1µA. Invalid receiver levels occur whenever the driving
peripheral’s outputs are shut off (powered down) or when the
RS-232 interface cable is disconnected. The ICL32xxE
powers back up whenever it detects a valid RS-232 voltage
level on any receiver input. This automatic power-down
feature provides additional system power savings without
changes to the existing operating system.
FN4910.20
September 15, 2008
VALID RS-232 LEVEL - ICL32xxE IS ACTIVE
2.7V
INDETERMINATE - POWER-DOWN MAY OR
MAY NOT OCCUR
0.3V
INVALID LEVEL - POWER-DOWN OCCURS AFTER 30µs
Capacitor Selection
-0.3V
MAY NOT OCCUR
-2.7V
FIGURE 6. DEFINITION OF VALID RS-232 RECEIVER LEVELS
Automatic power-down operates when the FORCEON input
is low, and the FORCEOFF input is high. Tying FORCEON
high disables automatic power-down, but manual powerdown is always available via the overriding FORCEOFF
input. Table 2 summarizes the automatic power-down
functionality.
Devices with the automatic power-down feature include an
INVALID output signal, which switches low to indicate that
invalid levels have persisted on all of the receiver inputs for
more than 30µs (see Figure 7). INVALID switches high 1µs
after detecting a valid RS-232 level on a receiver input.
INVALID operates in all modes (forced or automatic
power-down, or forced on), so it is also useful for systems
employing manual power-down circuitry. When automatic
power-down is utilized, INVALID = 0 indicates that the
ICL32xxE is in power-down mode.
The time to recover from automatic power-down mode is
typically 100µs.
INVALID
} REGION
RECEIVER
INPUTS
TRANSMITTER
OUTPUTS
INVALID
OUTPUT
(standard) receiver outputs placing them in a high
impedance state. This is useful to eliminate supply current,
due to a receiver output forward biasing the protection diode,
when driving the input of a powered down (VCC = GND)
peripheral (see Figure 2). The enable input has no effect on
transmitter nor monitor (ROUTB) outputs.
VCC
PWR UP
AUTOPWDN
When using minimum required capacitor values, make sure
that capacitor values do not degrade excessively with
temperature. If in doubt, use capacitors with a larger nominal
value. The capacitor’s equivalent series resistance (ESR)
usually rises at low temperatures and it influences the
amount of ripple on V+ and V-.
TABLE 3. REQUIRED CAPACITOR VALUES
VCC
(V)
C1
(µF)
C2, C3, C4
(µF)
3.0 to 3.6
0.1
0.1
4.5 to 5.5
0.047
0.33
3.0 to 5.5
0.1
0.47
Power Supply Decoupling
In most circumstances a 0.1µF bypass capacitor is
adequate. In applications that are particularly sensitive to
power supply noise, decouple VCC to ground with a
capacitor of the same value as the charge-pump capacitor C1.
Connect the bypass capacitor as close as possible to the IC.
Operation Down to 2.7V
tINVH
tINVL
The charge pumps require 0.1µF capacitors for 3.3V
operation. For other supply voltages refer to Table 3 for
capacitor values. Do not use values smaller than those listed
in Table 3. Increasing the capacitor values (by a factor of 2)
reduces ripple on the transmitter outputs and slightly
reduces power consumption. C2, C3, and C4 can be
increased without increasing C1’s value, however, do not
increase C1 without also increasing C2, C3, and C4 to
maintain the proper ratios (C1 to the other capacitors).
V+
ICL32xxE transmitter outputs meet RS-562 levels (±3.7V), at
full data rate, with VCC as low as 2.7V. RS-562 levels
typically ensure interoperability with RS-232 devices.
VCC
Transmitter Outputs when Exiting
Power-down
V-
FIGURE 7. AUTOMATIC POWER-DOWN AND INVALID
TIMING DIAGRAMS
Receiver ENABLE Control
(ICL3221E, ICL3222E, ICL3223E, ICL3241E Only)
Several devices also feature an EN input to control the
receiver outputs. Driving EN high disables all the inverting
14
Figure 8 shows the response of two transmitter outputs
when exiting power-down mode. As they activate, the two
transmitter outputs properly go to opposite RS-232 levels,
with no glitching, ringing, nor undesirable transients. Each
transmitter is loaded with 3kΩ in parallel with 2500pF. Note
that the transmitters enable only when the magnitude of the
supplies exceed approximately 3V.
FN4910.20
September 15, 2008
VCC
5V/DIV
0.1µF
FORCEOFF
T1
C1+
VCC
C1-
ICL32xxE
V+
C3
C1
2V/DIV
V-
C2+
C4
C2
C2TIN
T2
TOUT
EN
TIME (20µs/DIV)
FIGURE 8. TRANSMITTER OUTPUTS WHEN EXITING
POWER-DOWN
VCC
Mouse Driveability
1000pF
RIN
ROUT
VCC = +3.3V
C1 - C4 = 0.1µF
5K
SHDN OR
FORCEOFF
FIGURE 10. TRANSMITTER LOOPBACK TEST CIRCUIT
The ICL3241E and ICL3243E have been specifically
designed to power a serial mouse while operating from low
voltage supplies. Figure 9 shows the transmitter output
voltages under increasing load current. The on-chip
switching regulator ensures the transmitters will supply at
least ±5V during worst case conditions (15mA for paralleled
V+ transmitters, 7.3mA for single V- transmitter). The
Automatic Power-down feature does not work with a mouse,
so FORCEOFF and FORCEON should be connected to VCC.
5V/DIV
T1IN
T1OUT
TRANSMITTER OUTPUT VOLTAGE (V)
6
5
R1OUT
VOUT+
4
VCC = +3.3V
C1 - C4 = 0.1µF
3
VCC = 3.0V
2
1
5µs/DIV
T1
FIGURE 11. LOOPBACK TEST AT 120kbps
VOUT+
-1
T2
-2
ICL3241E, ICL3243E
-3
VCC
-4
5V/DIV
VOUT -
T3
VOUT T1IN
-5
-6
2
3
4
5
6
7
8
9
10
LOAD CURRENT PER TRANSMITTER (mA)
FIGURE 9. TRANSMITTER OUTPUT VOLTAGE vs LOAD
CURRENT (PER TRANSMITTER, i.e., DOUBLE
CURRENT AXIS FOR TOTAL VOUT+ CURRENT)
T1OUT
High Data Rates
The ICL32xxE maintain the RS-232 ±5V minimum
transmitter output voltages even at high data rates.
Figure 10 details a transmitter loopback test circuit, and
Figure 11 illustrates the loopback test result at 120kbps. For
this test, all transmitters were simultaneously driving RS-232
loads in parallel with 1000pF, at 120kbps. Figure 12 shows
the loopback results for a single transmitter driving 1000pF
and an RS-232 load at 250kbps. The static transmitters were
also loaded with an RS-232 receiver.
15
R1OUT
VCC = +3.3V
C1 - C4 = 0.1µF
2µs/DIV
FIGURE 12. LOOPBACK TEST AT 250kbps
FN4910.20
September 15, 2008
Interconnection with 3V and 5V Logic
The ICL32XX directly interface with 5V CMOS and TTL logic
families. Nevertheless, with the ICL32XX at 3.3V, and the logic
supply at 5V, AC, HC, and CD4000 outputs can drive ICL32XX
inputs, but ICL32XX outputs do not reach the minimum VIH for
these logic families. See Table 4 for more information.
TABLE 4. LOGIC FAMILY COMPATIBILITY WITH VARIOUS
SUPPLY VOLTAGES
SYSTEM
POWER-SUPPLY VCC SUPPLY
VOLTAGE (V)
VOLTAGE (V)
3.3
3.3
5
5
5
3.3
delivers the charge through a 1.5kΩ current limiting resistor,
making the test less severe than the IEC61000 test which
utilizes a 330Ω limiting resistor. The HBM method
determines an IC’s ability to withstand the ESD transients
typically present during handling and manufacturing. Due to
the random nature of these events, each pin is tested with
respect to all other pins. The RS-232 pins on “E” family
devices can withstand HBM ESD events to ±15kV.
IEC61000-4-2 Testing
COMPATIBILITY
Compatible with all CMOS
families.
Compatible with all TTL and
CMOS logic families.
Compatible with ACT and HCT
CMOS, and with TTL. ICL32XX
outputs are incompatible with
AC, HC, and CD4000 CMOS
inputs.
±15kV ESD Protection
All pins on ICL32XX devices include ESD protection
structures, but the ICL32xxE family incorporates advanced
structures which allow the RS-232 pins (transmitter outputs
and receiver inputs) to survive ESD events up to ±15kV. The
RS-232 pins are particularly vulnerable to ESD damage
because they typically connect to an exposed port on the
exterior of the finished product. Simply touching the port
pins, or connecting a cable, can cause an ESD event that
might destroy unprotected ICs. These new ESD structures
protect the device whether or not it is powered up, protect
without allowing any latch-up mechanism to activate, and
don’t interfere with RS-232 signals as large as ±25V.
Human Body Model (HBM) Testing
As the name implies, this test method emulates the ESD
event delivered to an IC during human handling. The tester
Typical Performance Curves
The IEC61000 test method applies to finished equipment,
rather than to an individual IC. Therefore, the pins most likely
to suffer an ESD event are those that are exposed to the
outside world (the RS-232 pins in this case), and the IC is
tested in its typical application configuration (power applied)
rather than testing each pin-to-pin combination. The lower
current limiting resistor coupled with the larger charge
storage capacitor yields a test that is much more severe than
the HBM test. The extra ESD protection built into this
device’s RS-232 pins allows the design of equipment
meeting level 4 criteria without the need for additional board
level protection on the RS-232 port.
AIR-GAP DISCHARGE TEST METHOD
For this test method, a charged probe tip moves toward the
IC pin until the voltage arcs to it. The current waveform
delivered to the IC pin depends on approach speed,
humidity, temperature, etc., so it is difficult to obtain
repeatable results. The “E” device RS-232 pins withstand
±15kV air-gap discharges.
CONTACT DISCHARGE TEST METHOD
During the contact discharge test, the probe contacts the
tested pin before the probe tip is energized, thereby
eliminating the variables associated with the air-gap
discharge. The result is a more repeatable and predictable
test, but equipment limits prevent testing devices at voltages
higher than ±8kV. All “E” family devices survive ±8kV contact
discharges on the RS-232 pins.
VCC = 3.3V, TA = +25°C.
25
VOUT+
4
SLEW RATE (V/μs)
6
2
1 TRANSMITTER AT 250kbps
1 OR 2 TRANSMITTERS AT 30kbps
15
-SLEW
+SLEW
10
VOUT -
-4
-6
2000
3000
4000
5000
LOAD CAPACITANCE (pF)
FIGURE 13. TRANSMITTER OUTPUT VOLTAGE vs LOAD
CAPACITANCE
16
5
2000
3000
4000
5000
FIGURE 14. SLEW RATE vs LOAD CAPACITANCE
FN4910.20
September 15, 2008
VCC = 3.3V, TA = +25°C. (Continued)
45
45
ICL3221E
40
40
SUPPLY CURRENT (mA)
SUPPLY CURRENT (mA)
250kbps
35
250kbps
30
25
120kbps
15
10
20kbps
35
30
25
120kbps
20kbps
10
5
5
2000
3000
4000
1000
2000
3000
5000
FIGURE 16. SUPPLY CURRENT vs LOAD CAPACITANCE
WHEN TRANSMITTING DATA
FIGURE 15. SUPPLY CURRENT vs LOAD CAPACITANCE
45
3.5
NO LOAD
ALL OUTPUTS STATIC
ICL324XE
40
3.0
250kbps
35
SUPPLY CURRENT (mA)
SUPPLY CURRENT (mA)
4000
30
120kbps
25
20kbps
15
2.5
2.0
1.5
1.0
ICL324XE
0.5
ICL324XE
10
1000
3000
4000
FIGURE 17. SUPPLY CURRENT vs LOAD CAPACITANCE
5000
3.0
3.5
4.0
4.5
5.0
5.5
6.0
SUPPLY VOLTAGE (V)
FIGURE 18. SUPPLY CURRENT vs SUPPLY VOLTAGE
Die Characteristics
SUBSTRATE POTENTIAL (POWERED UP):
GND
TRANSISTOR COUNT:
ICL3221E: 286
ICL3222E: 338
ICL3223E: 357
ICL3232E: 296
ICL324XE: 464
PROCESS:
Si Gate CMOS
17
FN4910.20
September 15, 2008
Dual-In-Line Plastic Packages (PDIP)
N
E18.3 (JEDEC MS-001-BC ISSUE D)
E1
INDEX
AREA
1 2 3
18 LEAD DUAL-IN-LINE PLASTIC PACKAGE
N/2
INCHES
-B-
SYMBOL
-AD
E
BASE
PLANE
-C-
SEATING
PLANE
A2
A
L
D1
e
B1
D1
eA
A1
eC
B
0.010 (0.25) M
C
L
C A B S
C
eB
NOTES:
1. Controlling Dimensions: INCH. In case of conflict between English and
Metric dimensions, the inch dimensions control.
2. Dimensioning and tolerancing per ANSI Y14.5M-1982.
3. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of
Publication No. 95.
4. Dimensions A, A1 and L are measured with the package seated in
JEDEC seating plane gauge GS-3.
5. D, D1, and E1 dimensions do not include mold flash or protrusions.
Mold flash or protrusions shall not exceed 0.010 inch (0.25mm).
6. E and eA are measured with the leads constrained to be perpendicular to datum -C- .
MILLIMETERS
MIN
MAX
MIN
MAX
NOTES
A
0.210
5.33
4
A1
0.015
0.39
4
A2
0.115
0.195
2.93
4.95
B
0.014
0.022
0.356
0.558
B1
0.045
0.070
1.15
1.77
8, 10
C
0.008
0.014
0.204
0.355
D
0.845
0.880
21.47
D1
0.005
0.13
5
22.35
5
E
0.300
0.325
7.62
8.25
6
E1
0.240
0.280
6.10
7.11
5
e
0.100 BSC
2.54 BSC
eA
0.300 BSC
7.62 BSC
6
eB
0.430
10.92
7
L
0.115
0.150
2.93
3.81
4
N
18
18
9
Rev. 2 11/03
7. eB and eC are measured at the lead tips with the leads unconstrained.
eC must be zero or greater.
8. B1 maximum dimensions do not include dambar protrusions. Dambar
9. N is the maximum number of terminal positions.
10. Corner leads (1, N, N/2 and N/2 + 1) for E8.3, E16.3, E18.3, E28.3
may have a B1 dimension of 0.030 - 0.045 inch (0.76 - 1.14mm).
18
FN4910.20
September 15, 2008
Small Outline Plastic Packages (SOIC)
M16.15 (JEDEC MS-012-AC ISSUE C)
N
INDEX
AREA
H
0.25(0.010) M
16 LEAD NARROW BODY SMALL OUTLINE PLASTIC PACKAGE
B M
INCHES
E
-B1
2
3
L
SEATING PLANE
-A-
A
D
h x 45°
-C-
e
A1
B
0.25(0.010) M
C
0.10(0.004)
C A M
SYMBOL
MIN
MAX
MIN
MAX
NOTES
A
0.0532
0.0688
1.35
1.75
A1
0.0040
0.0098
0.10
0.25
B
0.013
0.020
0.33
0.51
9
C
0.0075
0.0098
0.19
0.25
D
0.3859
0.3937
9.80
10.00
3
E
0.1497
0.1574
3.80
4.00
4
e
α
B S
0.050 BSC
0.2284
0.2440
5.80
6.20
h
0.0099
0.0196
0.25
0.50
5
L
0.016
0.050
0.40
1.27
6
α
1. Symbols are defined in the “MO Series Symbol List” in Section 2.2 of
Publication Number 95.
1.27 BSC
H
N
NOTES:
MILLIMETERS
16
0°
16
8°
0°
7
8°
Rev. 1 6/05
3. Dimension “D” does not include mold flash, protrusions or gate burrs.
Mold flash, protrusion and gate burrs shall not exceed 0.15mm (0.006
inch) per side.
4. Dimension “E” does not include interlead flash or protrusions. Interlead
flash and protrusions shall not exceed 0.25mm (0.010 inch) per side.
5. The chamfer on the body is optional. If it is not present, a visual index
feature must be located within the crosshatched area.
6. “L” is the length of terminal for soldering to a substrate.
7. “N” is the number of terminal positions.
8. Terminal numbers are shown for reference only.
9. The lead width “B”, as measured 0.36mm (0.014 inch) or greater above
the seating plane, shall not exceed a maximum value of 0.61mm
(0.024 inch).
10. Controlling dimension: MILLIMETER. Converted inch dimensions are
not necessarily exact.
19
FN4910.20
September 15, 2008
Thin Shrink Small Outline Plastic Packages (TSSOP)
M16.173
N
16 LEAD THIN SHRINK SMALL OUTLINE PLASTIC PACKAGE
INDEX
AREA
E
0.25(0.010) M
2
INCHES
E1
GAUGE
PLANE
-B1
B M
L
0.05(0.002)
-A-
SYMBOL
MIN
MAX
MIN
MAX
NOTES
A
0.043
1.10
0.05
0.15
A2
0.033
0.037
0.85
0.95
b
0.0075
0.012
0.19
0.30
9
c
0.0035
0.008
0.09
0.20
D
0.193
0.201
4.90
5.10
3
E1
0.169
0.177
4.30
4.50
4
A1
3
A
D
-C-
e
α
e
A2
A1
b
0.10(0.004) M
0.25
0.010
SEATING PLANE
c
0.10(0.004)
C A M
B S
0.002
0.246
L
0.020
α
1. These package dimensions are within allowable dimensions of
JEDEC MO-153-AB, Issue E.
0.006
0.026 BSC
E
N
NOTES:
MILLIMETERS
0.65 BSC
0.256
6.25
0.028
0.50
16
0o
6.50
0.70
16
8o
0o
6
7
8o
Rev. 1 2/02
burrs. Mold flash, protrusion and gate burrs shall not exceed
0.15mm (0.006 inch) per side.
4. Dimension “E1” does not include interlead flash or protrusions.
Interlead flash and protrusions shall not exceed 0.15mm (0.006
inch) per side.
index feature must be located within the crosshatched area.
9. Dimension “b” does not include dambar protrusion. Allowable
dambar protrusion shall be 0.08mm (0.003 inch) total in excess
of “b” dimension at maximum material condition. Minimum space
between protrusion and adjacent lead is 0.07mm (0.0027 inch).
10. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact. (Angles in degrees)
FN4910.20
September 15, 2008
Small Outline Plastic Packages (SSOP)
M16.209 (JEDEC MO-150-AC ISSUE B)
N
16 LEAD SHRINK SMALL OUTLINE PLASTIC PACKAGE
INDEX
AREA
H
0.25(0.010) M
B M
INCHES
E
GAUGE
PLANE
-B1
2
3
L
0.25
0.010
SEATING PLANE
-A-
A
D
-C-
α
e
B
0.25(0.010) M
C
0.10(0.004)
C A M
SYMBOL
MIN
MAX
MIN
MAX
NOTES
A
0.078
2.00
A1
0.002
0.05
A2
0.065
0.072
1.65
1.85
B
0.009
0.014
0.22
0.38
9
C
0.004
0.009
0.09
0.25
D
0.233
0.255
5.90
6.50
3
E
0.197
0.220
5.00
5.60
4
e
A2
A1
B S
0.026 BSC
H
0.292
L
0.022
N
α
NOTES:
MILLIMETERS
0.65 BSC
0.322
7.40
0.037
0.55
16
0°
8.20
0.95
6
16
8°
0°
7
8°
Rev. 3
6/05
Mold flash, protrusion and gate burrs shall not exceed 0.20mm (0.0078
inch) per side.
flash and protrusions shall not exceed 0.20mm (0.0078 inch) per side.
9. Dimension “B” does not include dambar protrusion. Allowable dambar
protrusion shall be 0.13mm (0.005 inch) total in excess of “B” dimension at maximum material condition.
21
FN4910.20
September 15, 2008
M16.3 (JEDEC MS-013-AA ISSUE C)
N
16 LEAD WIDE BODY SMALL OUTLINE PLASTIC PACKAGE
INDEX
AREA
H
0.25(0.010) M
B M
INCHES
E
-B1
2
3
L
SEATING PLANE
-A-
A
D
h x 45°
-C-
e
A1
B
0.25(0.010) M
C
0.10(0.004)
C A M
SYMBOL
MIN
MAX
MIN
MAX
NOTES
A
0.0926
0.1043
2.35
2.65
A1
0.0040
0.0118
0.10
0.30
B
0.013
0.0200
0.33
0.51
9
C
0.0091
0.0125
0.23
0.32
D
0.3977
0.4133
10.10
10.50
3
E
0.2914
0.2992
7.40
7.60
4
e
α
B S
0.050 BSC
1.27 BSC
H
0.394
0.419
10.00
10.65
h
0.010
0.029
0.25
0.75
5
L
0.016
0.050
0.40
1.27
6
N
α
NOTES:
MILLIMETERS
16
0°
16
8°
0°
7
8°
Rev. 1 6/05
inch) per side.
the seating plane, shall not exceed a maximum value of 0.61mm (0.024
inch)
22
FN4910.20
September 15, 2008
M18.3 (JEDEC MS-013-AB ISSUE C)
N
18 LEAD WIDE BODY SMALL OUTLINE PLASTIC PACKAGE
INDEX
AREA
H
0.25(0.010) M
B M
INCHES
E
-B1
2
3
L
SEATING PLANE
-A-
A
D
h x 45°
-C-
e
A1
B
0.25(0.010) M
C
0.10(0.004)
C A M
SYMBOL
MIN
MAX
MIN
MAX
NOTES
A
0.0926
0.1043
2.35
2.65
A1
0.0040
0.0118
0.10
0.30
B
0.013
0.0200
0.33
0.51
9
C
0.0091
0.0125
0.23
0.32
D
0.4469
0.4625
11.35
11.75
3
E
0.2914
0.2992
7.40
7.60
4
e
α
B S
0.050 BSC
1.27 BSC
H
0.394
0.419
10.00
10.65
h
0.010
0.029
0.25
0.75
5
L
0.016
0.050
0.40
1.27
6
N
α
NOTES:
MILLIMETERS
18
0°
18
8°
0°
7
8°
Rev. 1 6/05
inch) per side.
(0.024 inch)
23
FN4910.20
September 15, 2008
M20.173
N
INDEX
AREA
E
0.25(0.010) M
E1
2
INCHES
GAUGE
PLANE
-B1
20 LEAD THIN SHRINK SMALL OUTLINE PLASTIC
PACKAGE
B M
3
L
0.05(0.002)
-A-
A
D
-C-
α
e
A2
A1
b
0.10(0.004) M
0.25
0.010
SEATING PLANE
c
0.10(0.004)
C A M
B S
SYMBOL
MIN
MAX
MIN
MAX
NOTES
A
0.047
1.20
A1
0.002
0.006
0.05
0.15
A2
0.031
0.051
0.80
1.05
b
0.0075
0.0118
0.19
0.30
9
c
0.0035
0.0079
0.09
0.20
D
0.252
0.260
6.40
6.60
3
E1
0.169
0.177
4.30
4.50
4
e
0.026 BSC
E
0.246
L
0.0177
N
NOTES:
JEDEC MO-153-AC, Issue E.
MILLIMETERS
α
0.65 BSC
0.256
6.25
0.0295
0.45
0o
6.50
0.75
8o
0o
6
7
8o
Rev. 1 6/98
4. Dimension “E1” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.15mm (0.006 inch) per
side.
9. Dimension “b” does not include dambar protrusion. Allowable dambar
protrusion shall be 0.08mm (0.003 inch) total in excess of “b” dimension at maximum material condition. Minimum space between protrusion and adjacent lead is 0.07mm (0.0027 inch).
24
FN4910.20
September 15, 2008
Shrink Small Outline Plastic Packages (SSOP)
M20.209 (JEDEC MO-150-AE ISSUE B)
N
20 LEAD SHRINK SMALL OUTLINE PLASTIC PACKAGE
INDEX
AREA
H
0.25(0.010) M
B M
INCHES
E
GAUGE
PLANE
-B1
2
3
0.25
0.010
SEATING PLANE
-A-
A
D
-C-
α
e
C
0.10(0.004)
C A M
MIN
MAX
B S
MAX
NOTES
A
0.068
0.078
1.73
1.99
0.002
0.008’
0.05
0.21
A2
0.066
0.070’
1.68
1.78
B
0.010’
0.015
0.25
0.38
C
0.004
0.008
0.09
0.20’
D
0.278
0.289
7.07
7.33
3
E
0.205
0.212
5.20’
5.38
4
0.026 BSC
0.301
0.311
7.65
7.90’
L
0.025
0.037
0.63
0.95
8 deg.
0 deg.
N
0 deg.
9
0.65 BSC
H
α
NOTES:
MILLIMETERS
MIN
A1
e
A2
A1
B
0.25(0.010) M
L
SYMBOL
6
8 deg.
Rev. 3 11/02
2.2 of Publication Number 95.
4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.20mm (0.0078
inch) per side.
dambar protrusion shall be 0.13mm (0.005 inch) total in excess
25
FN4910.20
September 15, 2008
M28.173
N
INDEX
AREA
E
0.25(0.010) M
E1
2
INCHES
GAUGE
PLANE
-B1
28 LEAD THIN SHRINK SMALL OUTLINE PLASTIC
PACKAGE
B M
SYMBOL
3
L
0.05(0.002)
-A-
SEATING PLANE
A
D
-C-
α
e
A2
A1
b
0.10(0.004) M
0.25
0.010
c
0.10(0.004)
C A M
B S
MIN
JEDEC MO-153-AE, Issue E.
MILLIMETERS
MIN
MAX
NOTES
A
0.047
1.20
A1
0.002
0.006
0.05
0.15
A2
0.031
0.051
0.80
1.05
b
0.0075
0.0118
0.19
0.30
9
c
0.0035
0.0079
0.09
0.20
D
0.378
0.386
9.60
9.80
3
E1
0.169
0.177
4.30
4.50
4
e
0.026 BSC
0.65 BSC
E
0.246
0.256
6.25
6.50
L
0.0177
0.0295
0.45
0.75
6
8o
0o
N
NOTES:
MAX
α
28
0o
28
7
8o
Rev. 0 6/98
side.
26
FN4910.20
September 15, 2008
M28.209 (JEDEC MO-150-AH ISSUE B)
N
28 LEAD SHRINK SMALL OUTLINE PLASTIC PACKAGE
INDEX
AREA
H
0.25(0.010) M
B M
INCHES
E
GAUGE
PLANE
-B1
2
3
L
0.25
0.010
SEATING PLANE
-A-
A
D
-C-
α
e
B
0.25(0.010) M
C
0.10(0.004)
C A M
SYMBOL
MIN
MAX
MIN
MAX
NOTES
A
0.078
2.00
A1
0.002
0.05
A2
0.065
0.072
1.65
1.85
B
0.009
0.014
0.22
0.38
9
C
0.004
0.009
0.09
0.25
D
0.390
0.413
9.90
10.50
3
E
0.197
0.220
5.00
5.60
4
e
A2
A1
B S
0.026 BSC
H
0.292
L
0.022
N
α
NOTES:
MILLIMETERS
0.65 BSC
0.322
7.40
0.037
0.55
28
0°
8.20
0.95
6
28
8°
0°
7
8°
Rev. 2 6/05
inch) per side.
dambar protrusion shall be 0.13mm (0.005 inch) total in excess of
27
FN4910.20
September 15, 2008
M28.3 (JEDEC MS-013-AE ISSUE C)
N
28 LEAD WIDE BODY SMALL OUTLINE PLASTIC PACKAGE
INDEX
AREA
0.25(0.010) M
H
B M
INCHES
E
SYMBOL
-B-
1
2
3
L
SEATING PLANE
-A-
h x 45o
A
D
-C-
e
A1
B
C
0.10(0.004)
0.25(0.010) M
C A M
B S
MILLIMETERS
MIN
MAX
NOTES
A
0.0926
0.1043
2.35
2.65
0.0040
0.0118
0.10
0.30
B
0.013
0.0200
0.33
0.51
9
C
0.0091
0.0125
0.23
0.32
D
0.6969
0.7125
17.70
18.10
3
E
0.2914
0.2992
7.40
7.60
4
0.05 BSC
0.394
h
0.01
0.029
L
0.016
0.050
8o
0o
N
0.419
1.27 BSC
H
α
NOTES:
MAX
A1
e
µα
MIN
10.00
0.25
0.75
5
0.40
1.27
6
28
0o
10.65
28
7
8o
Rev. 0 12/93
4. Dimension “E” does not include interlead flash or protrusions. Interlead flash and protrusions shall not exceed 0.25mm (0.010
inch) per side.
above the seating plane, shall not exceed a maximum value of
0.61mm (0.024 inch)
All Intersil U.S. products are manufactured, assembled and tested utilizing ISO9000 quality systems.
Intersil Corporation’s quality certifications can be viewed at www.intersil.com/design/quality
Intersil products are sold by description only. Intersil Corporation reserves the right to make changes in circuit design, software and/or specifications at any time without
notice. Accordingly, the reader is cautioned to verify that data sheets are current before placing orders. Information furnished by Intersil is believed to be accurate and
reliable. However, no responsibility is assumed by Intersil or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result
from its use. No license is granted by implication or otherwise under any patent or patent rights of Intersil or its subsidiaries.
For information regarding Intersil Corporation and its products, see www.intersil.com
28
FN4910.20
September 15, 2008
