S-57TZNL1S-A6T8U
S-57TZNL1S-A6T8U
    ABLIC(艾普凌科)
    HSNT-6
    MAGNETIC SWITCH LATCH HSNT-6
S-57TZNL1S-A6T8U 数据手册
S-57TZ S Series www.ablic.com AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC Rev.1.2_00 © ABLIC Inc., 2019-2021 This IC, developed by CMOS technology, is a high-accuracy Hall effect IC that operates with high temperature and high-withstand voltage. The IC switches output voltage level when the IC detects magnetic flux density (magnetic field) polarity changes. The Zero Crossing Latch detection method realizes polarity changes detection with the higher accuracy than the conventional bipolar latch method. Using this IC with a magnet makes it possible to detect the rotation status in various devices. ABLIC Inc. offers a "magnetic simulation service" that provides the ideal combination of magnets and our Hall effect ICs for customer systems. Our magnetic simulation service will reduce prototype production, development period and development costs. In addition, it will contribute to optimization of parts to realize high cost performance. For more information regarding our magnetic simulation service, contact our sales representatives. Caution This product can be used in vehicle equipment and in-vehicle equipment. Before using the product for these purposes, it is imperative to contact our sales representatives.  Features • Uses a thin (t0.80 mm max.) TSOT-23-3S or ultra-thin (t0.50 mm max.) HSNT-6(2025) package, allowing for device miniaturization • Contributes to reduction of mechanism operation dispersion through high accuracy detection of magnetic flux density (magnetic field) polarity changes • Suitable for devices which require high quality due to the production system of this IC which certifies automotive application quality • Contributes to device safe design with a built-in reverse voltage protection circuit and output current limit circuit  Specifications • Pole detection: • Output logic*1: • Output form*1: • Zero crossing latch point: • Release point (S pole)*1:  Applications Zero Crossing Latch detection VOUT = "L" at S pole detection VOUT = "H" at S pole detection Nch open-drain output Nch driver + built-in pull-up resistor (1.2 kΩ typ.) BZ = 0.0 mT typ. BRS = 3.0 mT typ. BRS = 6.0 mT typ. fC = 500 kHz typ. tD = 8.0 μs typ. VDD = 2.7 V to 26.0 V • Chopping frequency: • Output delay time: • Power supply voltage range*2: • Built-in regulator • Built-in reverse voltage protection circuit • Built-in output current limit circuit • Operation temperature range: Ta = −40°C to +150°C • Lead-free (Sn 100%), halogen-free • AEC-Q100 qualified*3 • DC brushless motor for automotive applications • Automobile equipment • Housing equipment • Industrial equipment  Packages • TSOT-23-3S • HSNT-6(2025) *1. The option can be selected. *2. VDD = 2.7 V to 5.5 V when output form is Nch driver + built-in pull-up resistor (1.2 kΩ typ.) *3. Contact our sales representatives for details. 1 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC S-57TZ S Series Rev.1.2_00  Block Diagrams 1. Nch open-drain output product VDD Reverse voltage protection circuit Regulator OUT Chopper stabilized amplifier *1 Output current limit circuit VSS *1. Parasitic diode Figure 1 2. Nch driver + built-in pull-up resistor product VDD Reverse voltage protection circuit Regulator Chopper stabilized amplifier *1 Output current limit circuit VSS *1. Parasitic diode Figure 2 2 OUT AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC Rev.1.2_00 S-57TZ S Series  AEC-Q100 Qualified This IC supports AEC-Q100 for operation temperature grade 0. Contact our sales representatives for details of AEC-Q100 reliability specification.  Product Name Structure 1. Product name S-57TZ x x x S - xxxx U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 L3T2: TSOT-23-3S, Tape A6T8: HSNT-6(2025), Tape Operation temperature S: Ta = −40°C to +150°C Release point (S pole) 1: BRS = 3.0 mT typ. 2: BRS = 6.0 mT typ. Output logic L: VOUT = "L" at S pole detection H: VOUT = "H" at S pole detection Output form N: Nch open-drain output 1: Nch driver + built-in pull-up resistor (1.2 kΩ typ.) *1. Refer to the tape drawing. 2. Packages Table 1 Package Name TSOT-23-3S HSNT-6(2025) Dimension MP003-E-P-SD PJ006-B-P-SD Package Drawing Codes Tape MP003-E-C-SD PJ006-B-C-SD Reel MP003-E-R-SD PJ006-B-R-SD Land − PJ006-B-LM-SD Stencil Opening − PJ006-B-LM-SD 3 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC S-57TZ S Series Rev.1.2_00 3. Product name list 3. 1 TSOT-23-3S Table 2 Output Form Product Name S-57TZNL1S-L3T2U Nch open-drain output S-57TZ1L1S-L3T2U Remark 3. 2 Power Supply Voltage Range VDD = 2.7 V to 26.0 V Nch driver + built-in pull-up resistor VDD = 2.7 V to 5.5 V (1.2 kΩ typ.) Output Logic VOUT = "L" at S pole detection VOUT = "L" at S pole detection Release Point (S pole) (BRS) 3.0 mT typ. 3.0 mT typ. Please contact our sales representatives for products other than the above. HSNT-6(2025) Table 3 Product Name Output Form S-57TZNL1S-A6T8U Nch open-drain output S-57TZ1L1S-A6T8U Remark 4 Power Supply Voltage Range VDD = 2.7 V to 26.0 V Nch driver + built-in pull-up resistor VDD = 2.7 V to 5.5 V (1.2 kΩ typ.) Output Logic VOUT = "L" at S pole detection VOUT = "L" at S pole detection Please contact our sales representatives for products other than the above. Release Point (S pole) (BRS) 3.0 mT typ. 3.0 mT typ. AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC Rev.1.2_00 S-57TZ S Series  Pin Configurations 1. TSOT-23-3S Top view Table 4 1 Pin No. 1 2 3 2 Symbol Description GND pin Power supply pin Output pin VSS VDD OUT 3 Figure 3 2. HSNT-6(2025) Top view 1 2 3 Table 5 6 5 4 Bottom view 6 5 4 1 2 3 Pin No. 1 2 3 4 5 6 Symbol VDD NC*2 OUT NC*2 VSS NC*2 Description Power supply pin No connection Output pin No connection GND pin No connection *1 Figure 4 *1. Connect the heatsink of backside at shadowed area to the board, and set electric potential open or GND. However, do not use it as the function of electrode. *2. The NC pin is electrically open. The NC pin can be connected to the VDD pin or the VSS pin. 5 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC S-57TZ S Series Rev.1.2_00  Absolute Maximum Ratings Table 6 Item Power supply voltage Symbol Nch open-drain output product Nch driver + built-in pull-up resistor (1.2 kΩ typ.) product VDD Power supply current Output current IDD IOUT Nch open-drain output product Nch driver + built-in pull-up resistor (1.2 kΩ typ.) product Output voltage VOUT Junction temperature Operation ambient temperature Storage temperature Caution Tj Topr Tstg Absolute Maximum Rating VSS − 28.0 to VSS + 28.0 Unit VSS − 9.0 to VSS + 9.0 V ±10 ±10 VSS − 0.3 to VSS + 28.0 mA mA V VSS − 0.3 to VDD + 0.3 V −40 to +170 −40 to +150 −40 to +170 °C °C °C V The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Table 7 Item Symbol Condition TSOT-23-3S Junction-to-ambient thermal resistance*1 θJA HSNT-6(2025) *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Remark 6 Refer to " Power Dissipation" and "Test Board" for details. Board A Board B Board C Board D Board E Board A Board B Board C Board D Board E Min. − − − − − − − − − − Typ. 225 190 − − − 180 128 43 44 36 Max. − − − − − − − − − − Unit °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC Rev.1.2_00 S-57TZ S Series  Electrical Characteristics 1. Nch open-drain output product Table 8 (Ta = −40°C to +150°C, VDD = 2.7 V to 26.0 V, VSS = 0 V unless otherwise specified) Item Power supply voltage Current consumption Current consumption during reverse connection Low level output voltage Leakage current Output limit current Output delay time*2 Chopping frequency*2 Start up time*2 Output rise time*2 Output fall time*2 *1. *2. 2. Symbol Condition Min. Typ.*1 Max. Unit − − 2.7 − 12.0 4.0 26.0 4.5 V mA Test Circuit − 1 −0.1 − − mA 1 − − 11 − 250 − − − − − − 8 500 25 − − 0.4 10 35 16 − 40 1.0 1.0 V μA mA μs kHz μs μs μs 2 3 3 − − 4 5 5 VDD IDD VDD = −26.0 V IDDREV VOL IOUT = 5 mA, VOUT = "L" ILEAK VOUT = "H" IOM VOUT = 12.0 V tD − fC − − tPON C = 20 pF, R = 820 Ω tR C = 20 pF, R = 820 Ω tF Typ. value when Ta = +25°C, VDD = 12.0 V. This item is guaranteed by design. Nch driver + built-in pull-up resistor (1.2 kΩ typ.) product Table 9 (Ta = −40°C to +150°C, VDD = 2.7 V to 5.5 V, VSS = 0 V unless otherwise specified) Item Symbol Condition − Power supply voltage VDD Current consumption IDD VOUT = "H" Low level output voltage VOL IOUT = 0 mA, VOUT = "L" High level output voltage VOH IOUT = 0 mA, VOUT = "H" Output limit current IOM VDD = VOUT = 5.0 V − Output delay time*2 tD Chopping frequency*2 fC − − Start up time*2 tPON Output rise time*2 tR C = 20 pF Output fall time*2 tF C = 20 pF − Pull-up resistor RL *1. Typ. value when Ta = +25°C, VDD = 5.0 V. *2. This item is guaranteed by design. Caution Min. Typ.*1 Max. Unit 2.7 − − VDD × 0.9 11 − 250 − − − 0.9 5.0 4.0 − − − 8 500 25 − − 1.2 5.5 4.5 0.4 − 35 16 − 40 1.0 1.0 1.5 V mA V V mA μs kHz μs μs μs kΩ Test Circuit − 1 2 2 3 − − 4 5 5 − Due to limitation of the power dissipation, these values may not be satisfied. Attention should be paid to the power dissipation when using this IC in high temperature operation environments. 7 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC S-57TZ S Series Rev.1.2_00 S pole Magnetic flux density applied to this IC (B) BRS BZ (0) BRN N pole tD tD tF Output voltage (VOUT) (Product with VOUT = "L" at S pole detection) 90% 10% tD tD tR Output voltage (VOUT) (Product with VOUT = "H" at S pole detection) 90% 10% Figure 5 Operation Timing 8 tR tF AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC Rev.1.2_00 S-57TZ S Series  Magnetic Characteristics 1. TSOT-23-3S 1. 1 Product with BRS = 3.0 mT typ. Table 10 (Ta = +25°C, VDD = 5.0 V, VSS = 0 V unless otherwise specified) Item Zero crossing latch point S pole Release point N pole 1. 2 Symbol BZ*1 BRS*2 BRN*3 Condition − − − Min. −1.15 1.9 −4.1 Typ. 0.0 3.0 −3.0 Max. 1.15 4.1 −1.9 Unit mT mT mT Test Circuit 4 4 4 Product with BRS = 6.0 mT typ. Table 11 (Ta = +25°C, VDD = 5.0 V, VSS = 0 V unless otherwise specified) Item Zero crossing latch point S pole Release point N pole 2. Symbol BZ*1 BRS*2 BRN*3 Condition − − − Min. −1.35 4.0 −8.0 Typ. 0.0 6.0 −6.0 Max. 1.35 8.0 −4.0 Unit mT mT mT Test Circuit 4 4 4 HSNT-6(2025) 2. 1 Product with BRS = 3.0 mT typ. Table 12 (Ta = +25°C, VDD = 5.0 V, VSS = 0 V unless otherwise specified) Item Zero crossing latch point S pole Release point N pole 2. 2 Symbol BZ*1 BRS*2 BRN*3 Condition − − − Min. −1.65 1.0 −5.0 Typ. 0.0 3.0 −3.0 Max. 1.65 5.0 −1.0 Unit mT mT mT Test Circuit 4 4 4 Product with BRS = 6.0 mT typ. Table 13 (Ta = +25°C, VDD = 5.0 V, VSS = 0 V unless otherwise specified) Item Zero crossing latch point S pole Release point N pole Symbol BZ*1 BRS*2 BRN*3 Condition − − − Min. −1.75 3.5 −8.5 Typ. 0.0 6.0 −6.0 Max. 1.75 8.5 −3.5 Unit mT mT mT Test Circuit 4 4 4 *1. BZ : Zero crossing latch point BZ is the value of magnetic flux density at which polarity changes are detected according to the magnetic flux density applied to this IC. *2. BRS : Release point (S pole) BRS is the value of magnetic flux density of release point (S pole). This IC releases the Hold status of the output voltage (VOUT) when the magnetic flux density applied to this IC exceeds BRS (by moving the magnet (S pole) closer). *3. BRN : Release point (N pole) BRN is the value of magnetic flux density of release point (N pole). This IC releases the Hold status of the output voltage (VOUT) when the magnetic flux density applied to this IC exceeds BRN (by moving the magnet (N pole) closer). Remark The unit of magnetic density mT can be converted by using the formula 1 mT = 10 Gauss. 9 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC S-57TZ S Series Rev.1.2_00  Test Circuits A R*1 820 Ω VDD VDD OUT OUT VSS V VSS *1. Resistor (R) is unnecessary for Nch driver + built-in pull-up resistor product. Figure 6 Figure 7 Test Circuit 1 VSS VSS V *1. Test Circuit 3 OUT VSS V Resistor (R) is unnecessary for Nch driver + built-in pull-up resistor product. Figure 10 10 C 20 pF Test Circuit 5 V Resistor (R) is unnecessary for Nch driver + built-in pull-up resistor product. Figure 9 R*1 820 Ω VDD R*1 820 Ω OUT A OUT Figure 8 Test Circuit 2 VDD VDD *1. A Test Circuit 4 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC Rev.1.2_00 S-57TZ S Series  Standard Circuit VDD CIN 0.1 μF *1. R*1 820 Ω OUT VSS Resistor (R) is unnecessary for Nch driver + built-in pull-up resistor product. Figure 11 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constants. 11 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC S-57TZ S Series Rev.1.2_00  Operation 1. Direction of applied magnetic flux This IC detects the magnetic flux density which is perpendicular to the package marking surface. A magnetic field is defined as positive when marking side of the package is the S pole, and negative when it is the N pole. Figure 12 and Figure 13 show polarity in a magnetic field and direction in which magnetic flux is being applied. 1. 1 TSOT-23-3S 1. 2 HSNT-6(2025) N S N S Marking surface Marking surface Figure 12 2. Figure 13 Position of Hall sensor Figure 14 and Figure 15 show the position of Hall sensor. The center of this Hall sensor is located in the area indicated by a circle, which is in the center of a package as described below. The following also shows the distance (typ. value) between the marking surface and the chip surface of a package. 2. 1 TSOT-23-3S 2. 2 HSNT-6(2025) Top view 2 The center of Hall sensor, in this φ0.3 mm 1 6 2 5 3 4 3 0.22 mm (typ.) Figure 14 12 Top view The center of Hall sensor, in this φ0.3 mm 1 0.16 mm (typ.) Figure 15 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC Rev.1.2_00 S-57TZ S Series 3. Basic operation This IC switches output voltage level (VOUT) when the IC detects magnetic flux density (magnetic field) polarity changes by using Zero Crossing Latch technology. Zero Crossing Latch technology realizes polarity changes detection and hold operation (Hold status) of VOUT. This is different from the conventional bipolar latch method. Zero Crossing Latch detection method has no hysteresis width of the magnetic sensitivity to switch VOUT. Instead, the Zero Crossing Latch detection method can switch VOUT without chattering by using the Hold status. 3. 1 Zero Crossing Latch basic operation This IC switches VOUT after the output delay time (tD) from when the magnetic flux density applied to this IC crosses BZ (from B > BRS to B < BZ or from B < BRN to B > BZ). When VOUT is switched, this IC starts the Hold status. In the Hold status of VOUT, when the magnetic flux density applied to this IC exceeds BRS or BRN, this IC releases the Hold status (from B<BZ to B < BRN or from B > BZ to B > BRS). Figure 16 and Figure 17 show the VOUT operation timing when sine wave magnetic flux density is applied to this IC. (1) (2) (3) (4) B > BRS → B < BZ, and after tD, VOUT = "L" → "H", and Hold status starts B < BZ → B < BRN, and after tD, Hold status is released, and VOUT = "H" continues B < BRN → B > BZ, and after tD, VOUT = "H" → "L", and Hold status starts B > BZ → B > BRS, and after tD, Hold status is released, and VOUT = "L" continues (1) Magnetic flux density applied to this IC (B) (2) (4) (3) S pole BRS BZ (0) ) BRN N pole tD tD Hold status Output voltage (VOUT) tD tD Hold status H L t Figure 16 Product with VOUT = "L" at S pole detection 13 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC S-57TZ S Series Rev.1.2_00 (1) (2) (3) (4) B > BRS → B < BZ, and after tD, VOUT = "H" → "L", and Hold status starts B < BZ → B < BRN, and after tD, Hold status is released, and VOUT = "L" continues B < BRN → B > BZ, and after tD, VOUT = "L" → "H", and Hold status starts B > BZ → B > BRS, and after tD, Hold status is released, and VOUT = "H" continues (1) Magnetic flux density applied to this IC (B) (2) (3) (4) S pole BRS BZ (0) ) BRN N pole tD tD Hold status Output voltage (VOUT) tD tD Hold status H L t Figure 17 14 Product with VOUT = "H" at S pole detection AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC Rev.1.2_00 S-57TZ S Series 3. 2 Prevention of VOUT chattering by Hold status By the Hold status, this IC can switch VOUT without chattering even under an influence of external mechanical vibrations, electrical noise, or magnetic noise. Figure 18 and Figure 19 show the VOUT operation when the magnetic flux density applied to this IC changes near the zero crossing latch point (BZ) and BZ is crossed multiple times. (1) In the Hold status, the IC retains VOUT when the magnetic flux density applied to this IC crosses BZ. (1) (1) S pole BRS Magnetic flux density applied to this IC (B) BZ (0) ) BRN N pole tD tD tD tD H Hold status Hold status Output voltage (VOUT) L t Figure 18 Product with VOUT = "L" at S pole detection (1) (1) S pole BRS Magnetic flux density applied to this IC (B) BZ (0) ) BRN N pole tD tD tD tD H Hold status Output voltage (VOUT) Hold status L t Figure 19 Product with VOUT = "H" at S pole detection 15 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC S-57TZ S Series Rev.1.2_00 3. 3 Operation when polarity changes direction is inverted in the Hold status In the Hold status, when the polarity changes direction is inverted, this IC release the Hold status at the opposite release point and switches VOUT. Figure 20 and Figure 21 show the VOUT operation timing when the polarity change direction is inverted. (1) (2) (3) (4) (5) (6) B > BZ → B < BZ, and after tD, VOUT = "L" → "H", and Hold status starts During Hold status, even after B < BZ → B > BZ, VOUT = "H" is retained B > BZ → B > BRS, and after tD, Hold status is released, and VOUT = "H" → "L" B < BZ → B > BZ, and after tD, VOUT = "H" → "L", and Hold status starts During Hold status, even after B > BZ → B < BZ, VOUT = "L" is retained B < BZ → B < BRN, and after tD, Hold status is released, and VOUT = "L" → "H" (1) (2) (3) (4) (5) (6) S pole BRS Magnetic flux density applied to this IC (B) ・・・ ・・・ BZ (0) ) BRN N pole tD tD tD tD H Output voltage (VOUT) Hold status Hold status L t Figure 20 Product with VOUT = "L" at S pole detection 16 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC Rev.1.2_00 S-57TZ S Series (1) (2) (3) (4) (5) (6) B > BZ → B < BZ, and after tD, VOUT = "H" → "L", and Hold status starts During Hold status, even after B < BZ → B > BZ, VOUT = "L" is retained B > BZ → B > BRS, and after tD, Hold status is released, and VOUT = "L" → "H" B < BZ → B > BZ, and after tD, VOUT = "L" → "H", and Hold status starts During Hold status, even after B > BZ → B < BZ, VOUT = "H" is retained B < BZ → B < BRN, and after tD, Hold status is released, and VOUT = "H" → "L" (1) (2) (3) (4) (5) (6) S pole BRS Magnetic flux density applied to this IC (B) BZ (0) ・・・ ・・・ ) BRN N pole tD tD tD tD H Output voltage (VOUT) Hold status Hold status L t Figure 21 Product with VOUT = "H" at S pole detection 17 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC S-57TZ S Series Rev.1.2_00 4. Power-on operation This IC requires start up time (tPON) during the time immediately after power-on until VOUT switches. During the tPON period, VOUT is "H". After tPON, when B > BRS or B < BRN is detected, polarity changes can be detected. 4. 1 B > BRS or B < BRN When the magnetic flux density applied to this IC at power-on is B > BRS or B < BRN, after tPON, VOUT switches according to the output logic at the S pole detection, and polarity changes can be detected. Figure 22 and Figure 23 show VOUT operation immediately after power-on when B > BRS or B < BRN. S pole Magnetic flux density applied to this IC (B) B > BRS BRS Bz (0) BRN B < BRN N pole Power supply voltage (VDD) tPON Output voltage (VOUT) when B > BRS "H" Output voltage (VOUT) when B < BRN "H" "L" "L" t Figure 22 Product with VOUT = "L" at S pole detection S pole Magnetic flux density applied to this IC (B) B > BRS BRS Bz (0) BRN B < BRN N pole Power supply voltage (VDD) tPON Output voltage (VOUT) when B > BRS "H" Output voltage (VOUT) when B < BRN "H" "L" "L" t Figure 23 Product with VOUT = "H" at S pole detection 18 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC Rev.1.2_00 S-57TZ S Series 4. 2 BRN < B < BRS When the magnetic flux density applied to this IC at power-on is BRN < B < BRS, after tPON, VOUT continues "H". Thereafter, when the magnetic flux density changes to B > BRS or B < BRN, after tD, VOUT switches according to the output logic at the S pole detection and magnetic flux density, and polarity changes can be detected. Figure 24 and Figure 25 show VOUT operation when change of BRN < B < BRS → B > BRS or B < BRN occurs after tPON. S pole Magnetic flux density applied to this IC (B) BRS B < BRS → B > BRS 0 (BZ) B > BRN → B < BRN BRN N pole Power supply voltage (VDD) tPON tD Output voltage (VOUT) when B < BRS → B > BRS "H" Output voltage (VOUT) when B > BRN → B < BRN "H" "L" "L" t Figure 24 Product with VOUT = "L" at S pole detection S pole Magnetic flux density applied to this IC (B) BRS B < BRS → B > BRS 0 (BZ) B > BRN → B < BRN BRN N pole Power supply voltage (VDD) tPON tD Output voltage (VOUT) when B < BRS → B > BRS "H" Output voltage (VOUT) when B > BRN → B < BRN "H" "L" "L" t Figure 25 Product with VOUT = "H" at S pole detection 19 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC S-57TZ S Series Rev.1.2_00  Precautions • If the impedance of the power supply is high, the IC may malfunction due to a supply voltage drop caused by feed-through current. Take care with the pattern wiring to ensure that the impedance of the power supply is low. • Note that the IC may malfunction if the power supply voltage rapidly changes. When the IC is used under the environment where the power supply voltage rapidly changes, it is recommended to judge the output voltage of the IC by reading it multiple times. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • Although this IC has a built-in output current limit circuit, it may suffer physical damage such as product deterioration under the environment where the absolute maximum ratings are exceeded. • Although this IC has a built-in reverse voltage protection circuit, it may suffer physical damage such as product deterioration under the environment where the absolute maximum ratings are exceeded. • The application conditions for the power supply voltage, the pull-up voltage, and the pull-up resistor should not exceed the power dissipation. • Large stress on this IC may affect the magnetic characteristics. Avoid large stress which is caused by the handling during or after mounting the IC on a board. • Since the package heat radiation differs according to the conditions of the application, perform thorough evaluation with actual applications to confirm no problems occur. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 20 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC Rev.1.2_00 S-57TZ S Series  Characteristics (Typical Data) Electrical Characteristics 1. 1 S-57TZxxxS 1. 1. 1 Current consumption (IDD) vs. Temperature (Ta) VOUT = "H" 6.0 5.0 IDD [mA] 1. 1. 2 VDD = 5.5 V 3.0 2.0 VDD = 2.7 V VDD = 12.0 V 1.0 0.0 −40 −25 2.0 1. 1. 4 VDD = 26.0 V Ta = +150°C 15 20 25 VDD [V] Output delay time (tD) vs. Power supply voltage (VDD) 0 10 5 15 VDD = 5.5 V tD [μs] tD [μs] 3.0 5 10 30 20 15 5 Caution VDD = 12.0 V 0 25 Ta = −40°C 10 VDD = 2.7 V 0 −40 −25 Ta = +150°C Ta = +25°C 0 50 75 100 125 150 Ta [°C] 0 5 10 15 20 VDD [V] 25 30 VDD = 2.7 V to 5.5 V when output form is Nch driver + built-in pull-up resistor (1.2 kΩ typ.). Comply with power supply voltage range and do not exceed absolute maximum ratings. S-57TZNxxS 1. 2. 1 Low level output voltage (VOL) vs. Temperature (Ta) 1. 2. 2 IOUT = 5 mA 0.6 IOUT = 5 mA 0.5 VDD = 12.0 V VDD = 5.5 V 0.2 0.1 0.0 −40 −25 VDD = 2.7 V VOL [V] VDD = 26.0 V 0.4 0.3 Low level output voltage (VOL) vs. Power supply voltage (VDD) 0.6 0.5 VOL [V] 4.0 0.0 25 20 1. 2 Ta = −40°C Ta = +25°C 1.0 50 75 100 125 150 Ta [°C] Output delay time (tD) vs. Temperature (Ta) 1. 1. 3 0 VOUT = "H" 5.0 VDD = 26.0 V 4.0 Current consumption (IDD) vs. Power supply voltage (VDD) 6.0 IDD [mA] 1. 0.4 Ta = +25°C 0.3 0.2 0.1 Ta = −40°C 0.0 0 25 50 75 100 125 150 Ta [°C] Ta = +150°C 0 5 10 15 20 VDD [V] 25 30 21 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC S-57TZ S Series Rev.1.2_00 1. 3 S-57TZ1xxS 1. 3. 1 Low level output voltage (VOL) vs. Temperature (Ta) 1. 3. 2 IOUT = 0 mA 0.6 0.5 0.2 VDD = 5.5 V VDD = 5.0 V VDD = 2.7 V VOL [V] VOL [V] 0.3 0.0 −40 −25 25 0.2 50 75 100 125 150 Ta [°C] High level output voltage (VOH) vs. Temperature (Ta) 2 1. 3. 4 IOUT = 0 mA VDD = 5.0 V VDD = 5.5 V 3.0 2.0 1.0 0.0 −40 −25 VDD = 2.7 V 4 VDD [V] 5 6 High level output voltage (VOH) vs. Power supply voltage (VDD) IOUT = 0 mA 5.0 VOH [V] 4.0 3 6.0 5.0 VOH [V] Ta = +150°C Ta = +25°C Ta = −40°C 0.3 0.0 0 6.0 22 0.4 0.1 0.1 1. 3. 3 IOUT = 0 mA 0.6 0.5 0.4 Low level output voltage (VOL) vs. Power supply voltage (VDD) Ta = +150°C 4.0 3.0 Ta = +25°C Ta = −40°C 2.0 1.0 0.0 0 25 50 75 100 125 150 Ta [°C] 2 3 4 VDD [V] 5 6 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC Rev.1.2_00 S-57TZ S Series Magnetic Characteristics S-57TZxx1S-L3T2U S pole → N pole 8.0 6.0 VDD = 26.0 V VDD = 12.0 V 4.0 2.0 0.0 −2.0 VDD = 2.7 V −4.0 VDD = 5.5 V −6.0 −8.0 −40 −25 0 25 50 75 100 125 150 Ta [°C] BZ [mT] 2. 1. 3 Zero crossing latch point (BZ) vs. Temperature (Ta) N pole → S pole 8.0 6.0 VDD = 26.0 V VDD = 12.0 V 4.0 2.0 0.0 −2.0 VDD = 2.7 V −4.0 VDD = 5.5 V −6.0 −8.0 −40 −25 0 25 50 75 100 125 150 Ta [°C] 2. 1. 5 BRS, BRN [mT] Zero crossing latch point (BZ) vs. Temperature (Ta) Release point (BRS, BRN) vs. Temperature (Ta) 8.0 BRS VDD = 26.0 V 6.0 VDD = 5.5 V VDD = 12.0 V 4.0 2.0 VDD = 26.0 V 0.0 VDD = 2.7 V −2.0 −4.0 VDD = 2.7 V VDD = 5.5 V −6.0 BRN VDD = 12.0 V −8.0 −40 −25 0 25 50 75 100 125 150 Ta [°C] Caution 2. 1. 2 Zero crossing latch point (BZ) vs. Power supply voltage (VDD) S pole → N pole BZ [mT] BZ [mT] 2. 1. 1 8.0 6.0 4.0 2.0 0.0 −2.0 −4.0 −6.0 −8.0 Ta = +150°C Ta = +25°C Ta = −40°C 0 5 10 15 20 VDD [V] 25 30 2. 1. 4 Zero crossing latch point (BZ) vs. Power supply voltage (VDD) N pole → S pole BZ [mT] 2. 1 8.0 6.0 4.0 2.0 0.0 −2.0 −4.0 −6.0 −8.0 Ta = −40°C Ta = +25°C Ta = +150°C 0 5 10 15 20 VDD [V] 25 30 2. 1. 6 Release point (BRS, BRN) vs. Power supply voltage (VDD) 8.0 Ta = −40°C 6.0 BRS Ta = +25°C 4.0 2.0 Ta = +150°C 0.0 Ta = +150°C −2.0 −4.0 Ta = −40°C −6.0 BRN Ta = +25°C −8.0 0 30 5 10 15 20 25 VDD [V] BRS, BRN [mT] 2. VDD = 2.7 V to 5.5 V when output form is Nch driver + built-in pull-up resistor (1.2 kΩ typ.). Comply with power supply voltage range and do not exceed absolute maximum ratings. 23 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC S-57TZ S Series Rev.1.2_00 S-57TZxx2S-L3T2U BZ [mT] N pole → S pole 8.0 6.0 VDD = 26.0 V VDD = 12.0 V 4.0 2.0 0.0 −2.0 −4.0 VDD = 2.7 V VDD = 5.5 V −6.0 −8.0 −40 −25 0 25 50 75 100 125 150 Ta [°C] 2. 2. 5 BRS, BRN [mT] Zero crossing latch point (BZ) vs. Temperature (Ta) Release point (BRS, BRN) vs. Temperature (Ta) 8.0 BRS 6.0 4.0 VDD = 26.0 V VDD = 5.5 V 2.0 VDD = 2.7 V VDD = 12.0 V 0.0 VDD = 26.0 V VDD = 5.5 V −2.0 VDD = 12.0 V V DD = 2.7 V −4.0 −6.0 BRN −8.0 −40 −25 0 25 50 75 100 125 150 Ta [°C] Caution 2. 2. 2 Zero crossing latch point (BZ) vs. Power supply voltage (VDD) S pole → N pole BZ [mT] S pole → N pole 8.0 6.0 VDD = 26.0 V VDD = 12.0 V 4.0 2.0 0.0 −2.0 VDD = 2.7 V −4.0 VDD = 5.5 V −6.0 −8.0 −40 −25 0 25 50 75 100 125 150 Ta [°C] 2. 2. 3 24 Zero crossing latch point (BZ) vs. Temperature (Ta) 8.0 6.0 4.0 2.0 0.0 −2.0 −4.0 −6.0 −8.0 Ta = +150°C Ta = +25°C Ta = −40°C 0 5 10 15 20 VDD [V] 25 30 2. 2. 4 Zero crossing latch point (BZ) vs. Power supply voltage (VDD) N pole → S pole BZ [mT] BZ [mT] 2. 2. 1 8.0 6.0 4.0 2.0 0.0 −2.0 −4.0 −6.0 −8.0 Ta = −40°C Ta = +25°C Ta = +150°C 0 5 10 15 20 VDD [V] 25 30 2. 2. 6 Release point (BRS, BRN) vs. Power supply voltage (VDD) 8.0 BRS 6.0 4.0 Ta = −40°C Ta = +25°C 2.0 Ta = +150°C 0.0 Ta = −40°C −2.0 Ta = +25°C −4.0 Ta = +150°C −6.0 BRN −8.0 5 10 15 20 25 0 30 VDD [V] BRS, BRN [mT] 2. 2 VDD = 2.7 V to 5.5 V when output form is Nch driver + built-in pull-up resistor (1.2 kΩ typ.). Comply with power supply voltage range and do not exceed absolute maximum ratings. AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC Rev.1.2_00 S-57TZ S Series S-57TZxx1S-A6T8U BZ [mT] Zero crossing latch point (BZ) vs. Temperature (Ta) N pole → S pole 8.0 6.0 VDD = 26.0 V VDD = 12.0 V 4.0 2.0 0.0 −2.0 VDD = 2.7 V −4.0 VDD = 5.5 V −6.0 −8.0 −40 −25 0 25 50 75 100 125 150 Ta [°C] 2. 3. 5 Release point (BRS, BRN) vs. Temperature (Ta) 8.0 BRS VDD = 26.0 V 6.0 VDD = 5.5 V VDD = 12.0 V 4.0 2.0 VDD = 26.0 V 0.0 VDD = 2.7 V −2.0 −4.0 VDD = 2.7 V VDD = 5.5 V −6.0 BRN VDD = 12.0 V −8.0 −40 −25 0 25 50 75 100 125 150 Ta [°C] Caution 2. 3. 2 Zero crossing latch point (BZ) vs. Power supply voltage (VDD) S pole → N pole BZ [mT] S pole → N pole 8.0 6.0 VDD = 26.0 V VDD = 12.0 V 4.0 2.0 0.0 −2.0 VDD = 2.7 V −4.0 VDD = 5.5 V −6.0 −8.0 −40 −25 0 25 50 75 100 125 150 Ta [°C] 2. 3. 3 BRS, BRN [mT] Zero crossing latch point (BZ) vs. Temperature (Ta) 8.0 6.0 4.0 2.0 0.0 −2.0 −4.0 −6.0 −8.0 Ta = +150°C Ta = +25°C Ta = −40°C 0 5 10 15 20 VDD [V] 25 30 2. 3. 4 Zero crossing latch point (BZ) vs. Power supply voltage (VDD) N pole → S pole BZ [mT] BZ [mT] 2. 3. 1 8.0 6.0 4.0 2.0 0.0 −2.0 −4.0 −6.0 −8.0 Ta = −40°C Ta = +25°C Ta = +150°C 0 5 10 15 20 VDD [V] 25 30 2. 3. 6 Release point (BRS, BRN) vs. Power supply voltage (VDD) 8.0 Ta = +150°C 6.0 BRS Ta = +25°C 4.0 2.0 Ta = +150°C 0.0 Ta = −40°C −2.0 −4.0 Ta = −40°C −6.0 BRN Ta = +25°C −8.0 5 10 15 20 25 0 30 VDD [V] BRS, BRN [mT] 2. 3 VDD = 2.7 V to 5.5 V when output form is Nch driver + built-in pull-up resistor (1.2 kΩ typ.). Comply with power supply voltage range and do not exceed absolute maximum ratings. 25 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC S-57TZ S Series Rev.1.2_00 S-57TZxx2S-A6T8U BZ [mT] N pole → S pole 8.0 6.0 VDD = 26.0 V 4.0 VDD = 12.0 V 2.0 0.0 −2.0 −4.0 VDD = 2.7 V VDD = 5.5 V −6.0 −8.0 −40 −25 0 25 50 75 100 125 150 Ta [°C] 2. 4. 5 BRS, BRN [mT] Zero crossing latch point (BZ) vs. Temperature (Ta) Release point (BRS, BRN) vs. Temperature (Ta) 8.0 BRS 6.0 4.0 VDD = 26.0 V VDD = 5.5 V 2.0 VDD = 2.7 V VDD = 12.0 V 0.0 VDD = 26.0 V VDD = 5.5 V −2.0 VDD = 12.0 V V DD = 2.7 V −4.0 −6.0 BRN −8.0 −40 −25 0 25 50 75 100 125 150 Ta [°C] Caution 2. 4. 2 Zero crossing latch point (BZ) vs. Power supply voltage (VDD) S pole → N pole BZ [mT] S pole → N pole 8.0 6.0 VDD = 26.0 V VDD = 12.0 V 4.0 2.0 0.0 −2.0 VDD = 2.7 V −4.0 V DD = 5.5 V −6.0 −8.0 −40 −25 0 25 50 75 100 125 150 Ta [°C] 2. 4. 3 26 Zero crossing latch point (BZ) vs. Temperature (Ta) 8.0 6.0 4.0 2.0 0.0 −2.0 −4.0 −6.0 −8.0 Ta = +150°C Ta = +25°C Ta = −40°C 5 0 10 15 20 VDD [V] 25 30 2. 4. 4 Zero crossing latch point (BZ) vs. Power supply voltage (VDD) N pole → S pole BZ [mT] BZ [mT] 2. 4. 1 8.0 6.0 4.0 2.0 0.0 −2.0 −4.0 −6.0 −8.0 Ta = −40°C Ta = +25°C Ta = +150°C 5 0 10 15 20 VDD [V] 25 30 2. 4. 6 Release point (BRS, BRN) vs. Power supply voltage (VDD) 8.0 BRS 6.0 4.0 Ta = −40°C Ta = +25°C 2.0 Ta = +150°C 0.0 Ta = +150°C −2.0 Ta = +25°C −4.0 Ta = −40°C BRS, BRN [mT] 2. 4 −6.0 −8.0 BRN 0 5 10 15 20 VDD [V] 25 VDD = 2.7 V to 5.5 V when output form is Nch driver + built-in pull-up resistor (1.2 kΩ typ.). Comply with power supply voltage range and do not exceed absolute maximum ratings. 30 AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, ZERO CROSSING LATCH HALL EFFECT IC Rev.1.2_00 S-57TZ S Series  Power Dissipation HSNT-6(2025) TSOT-23-3S Tj = +170°C max. 4 3 2 1 B Tj = +170°C max. 5 Power dissipation (PD) [W] Power dissipation (PD) [W] 5 E 4 C 3 D 2 B 1 A A 0 0 25 50 75 100 125 150 175 0 0 25 Ambient temperature (Ta) [°C] Board A B C D E Power Dissipation (PD) 0.64 W 0.76 W − − − 50 75 100 125 150 175 Ambient temperature (Ta) [°C] Board A B C D E Power Dissipation (PD) 0.81 W 1.13 W 3.37 W 3.30 W 4.03 W 27 TSOT-23-3S Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. TSOT23x-A-Board-SD-1.0 ABLIC Inc. HSNT-6(2025) Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (3) Board C Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm No. HSNT6-B-Board-SD-1.0 enlarged view ABLIC Inc. HSNT-6(2025) Test Board IC Mount Area (4) Board D Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - enlarged view (5) Board E Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm enlarged view No. HSNT6-B-Board-SD-1.0 ABLIC Inc. 2.9±0.2 1 2 3 0.16 0.95±0.1 +0.1 -0.06 1.9±0.2 0.42±0.1 No. MP003-E-P-SD-1.0 TITLE TSOT233S-A-PKG Dimensions No. MP003-E-P-SD-1.0 ANGLE UNIT mm ABLIC Inc. ø1.5 +0.1 -0 4.0±0.1 2.0±0.05 ø1.0 +0.1 -0 0.25±0.1 (0.4) 4.0±0.1 0.95±0.2 3.23±0.2 (1.0) 1 2 3 Feed direction No. MP003-E-C-SD-1.0 TITLE TSOT233S-A-Carrier Tape No. MP003-E-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 9.0 +1.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP003-E-R-SD-1.0 TITLE TSOT233S-A-Reel No. MP003-E-R-SD-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 1.96±0.05 1.78±0.1 6 5 0.5 1 4 2 3 0.5 0.5 0.12±0.04 0.48±0.02 0.22±0.05 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PJ006-B-P-SD-1.0 TITLE HSNT-6-C-PKG Dimensions No. PJ006-B-P-SD-1.0 ANGLE UNIT mm ABLIC Inc. ø1.5 +0.1 -0 2.0±0.05 4.0±0.1 ø0.5±0.1 0.25±0.05 0.65±0.05 4.0±0.1 2.25±0.05 3 21 0.5 0.5 0.5 0.5 0.5 0.5 4 5 6 Feed direction No. PJ006-B-C-SD-1.0 TITLE HSNT-6-C-Carrier Tape No. PJ006-B-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 9.0 +1.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PJ006-B-R-SD-1.0 TITLE HSNT-6-C-Reel No. PJ006-B-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 Land Recommendation 0.50 0.35 0.50 1.44 1.78 2.10 Caution It is recommended to solder the heat sink to a board in order to ensure the heat radiation. PKG Stencil Opening 1.40 0.50 0.50 No. PJ006-B-LM-SD-1.0 0.35 Caution Mask aperture ratio of the lead mounting part is 100~120%. Mask aperture ratio of the heat sink mounting part is 30%. Mask thickness: t0.12 mm Reflow atmosphere: Nitrogen atmosphere is recommended. (Oxygen concentration: 1000ppm or less) 100~120% 30% t0.12 mm TITLE HSNT-6-C -Land &Stencil Opening PJ006-B-LM-SD-1.0 No. ANGLE UNIT mm 1000ppm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-57TZNL1S-A6T8U 价格&库存
很抱歉,暂时无法提供与“S-57TZNL1S-A6T8U”相匹配的价格&库存,您可以联系我们找货
