BQ3060PW-BE
BQ3060PW-BE
    ROCHESTER(罗切斯特)
    TSSOP24
    IC BAT MFUNC LI-ION 2-4C 24TSSOP
BQ3060PW-BE 数据手册
Order Now Product Folder Support & Community Tools & Software Technical Documents bq3060 SLUS928B – MARCH 2009 – REVISED JULY 2016 bq3060 SBS 1.1-Compliant Gas Gauge and Protection With CEDV 1 Features 3 Description • The Texas Instruments bq3060 Battery Manager is a fully integrated, single-chip, pack-based solution that provides a rich array of features for gas gauging, protection, and authentication for 2, 3, or 4 series cell Li-Ion battery packs. With a footprint of merely 7.8 mm × 6.4 mm in a compact 24-pin TSSOP package, the bq3060 maximizes functionality and safety while dramatically cutting the solution cost and size for smart batteries. 1 • • • • • • • • • • Advanced CEDV (Compensated End-of-Discharge Voltage) Gauging Fully Integrated 2, 3, and 4 Series Li-Ion or LiPolymer Cell Battery Pack Manager 8-Bit RISC CPU With Ultra-Low Power Modes Full Array of Programmable Protection Features – Voltage, Current, and Temperature SHA-1 Authentication Flexible Memory Architecture With Integrated Flash Memory Supports Two-Wire SMBus v1.1 Interface With High-speed 400kHz Programming Option P-CH High Side Protection FET Drive Low Power Consumption Sleep Mode: < 69 μA High-Accuracy Analog Front End With Two Independent ADCs – High-Resolution, 15~22-bit Integrator for Coulomb Counting – 16-Bit Delta-Sigma ADC With a 16-Channel Multiplexer for Voltage, Current, and Temperature Ultra Compact Package: 24-Pin TSSOP PW Using its integrated high-performance analog peripherals, the bq3060 measures and maintains an accurate record of available capacity, voltage, current, temperature, and other critical parameters in Li-Ion or Li-Polymer batteries, and reports the information to the system host controller over an SMBus 1.1-compatible interface. The bq3060 provides software-first level and second level safety protection on overvoltage, undervoltage, overtemperature, and overcharge, as well as hardware-overcurrent in discharge, short circuit in charge, and discharge protection. Device Information(1) PART NUMBER bq3060 BODY SIZE (NOM) 4.4 mm × 7.8 mm (1) For all available packages, see the orderable addendum at the end of the data sheet. 2 Applications • • • PACKAGE TSSOP (24) Netbook and Notebook PCs Medical and Test Equipment Portable Instruments System Partitioning Diagram Pack + FUSE SMBD Fuse Blow & Detection Logic SMBD SMBC SMBC ZVCHG CHG DSG PACK BAT RBI Oscillator Pre Charge FET Drive P-Channel FET Drive Power Mode Control VSS SMB 1.1 System Control PRES PRES AFE HW Control Data Flash Memory Charging Algorithm SHA-1 Authentication Over Temperature Protection Temperature Measurement TS1 TS2 Watchdog Voltage Measurement Cell Voltage Mux & Translation Over- & UnderVoltage Protection CEDV Gas Gauging External Cell Balancing Driver Over Current Protection Coloumb Counter VC1 VC1 VDD VC2 VC2 OUT VC3 VC3 VC4 VC4 CD GND bq294xz SRN HW Over Current & Short Circuit Protection SRP Regulator REG27 bq3060 Pack RSNS 5mW –20mW typ. 1 An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. bq3060 SLUS928B – MARCH 2009 – REVISED JULY 2016 www.ti.com Table of Contents 1 2 3 4 5 6 Features .................................................................. Applications ........................................................... Description ............................................................. Revision History..................................................... Pin Configuration and Functions ......................... Specifications......................................................... 1 1 1 2 3 4 6.1 6.2 6.3 6.4 6.5 4 4 4 5 5 Absolute Maximum Ratings ...................................... ESD Ratings.............................................................. Recommended Operating Conditions....................... Thermal Information .................................................. Electrical Characteristics........................................... 7 Detailed Description ............................................ 11 7.1 Feature Description................................................. 11 7.2 Device Functional Modes........................................ 13 8 Device and Documentation Support.................. 14 8.1 8.2 8.3 8.4 8.5 8.6 9 Documentation Support ......................................... 14 Receiving Notification of Documentation Updates.. 14 Community Resources............................................ 14 Trademarks ............................................................. 14 Electrostatic Discharge Caution .............................. 14 Glossary .................................................................. 14 Mechanical, Packaging, and Orderable Information ........................................................... 14 4 Revision History NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Changes from Revision A (November 2009) to Revision B Page • Added ESD Ratings table, Feature Description section, Device Functional Modes, section, Device and Documentation Support section, and Mechanical, Packaging, and Orderable Information section....................................... 1 • Changed Device From: Production To: NRND....................................................................................................................... 1 Changes from Original (March 2009) to Revision A • 2 Page Changed Device From: Product Preview To: Production....................................................................................................... 1 Submit Documentation Feedback Copyright © 2009–2016, Texas Instruments Incorporated Product Folder Links: bq3060 bq3060 www.ti.com SLUS928B – MARCH 2009 – REVISED JULY 2016 5 Pin Configuration and Functions PW Package 24-Pin TSSOP Top View BAT DSG VC1 VC2 VC3 VC4 SRP SRN TS1 TS2 NC NC 1 2 3 4 5 6 7 8 9 10 11 12 24 23 22 21 20 19 18 17 16 15 14 13 PACK CHG ZVCHG FUSE REG27 VSS RBI PRES SMBC NC SMBD NC Pin Functions PIN NAME NO. I/O DESCRIPTION BAT 1 P Power input from battery DSG 2 O P-CH FET Drive controlling discharge VC1 3 IA Sense voltage input terminal and external cell balancing drive output for most positive cell, and battery stack measurement input. VC2 4 IA Sense voltage input terminal and external cell balancing drive output for second most positive cell. VC3 5 IA Sense voltage input terminal and external cell balancing drive output for third most positive cell. VC4 6 IA Sense voltage input terminal and external cell balancing drive output for least positive cell. SRP 7 IA Analog input pin connected to the internal coulomb-counter peripheral for integrating a small voltage between SRP and SRN where SRP is the top of the sense resistor. SRN 8 IA Analog input pin connected to the internal coulomb-counter peripheral for integrating a small voltage between SRP and SRN where SRN is the bottom of the sense resistor. TS1 9 I/O,IA Thermistor input TS1 TS2 10 I/O,IA Thermistor input TS2 NC 11 — Keep this pin floating NC 12 — Keep this pin floating NC 13 — Keep this pin floating SMBD 14 I/OD NC 15 — SMBC 16 I/OD SMBus clock pin PRES 17 I/OD Active low input to sense system insertion and typically requires additional ESD protection RBI 18 P RAM backup pin to provide backup potential to the internal DATA RAM if power is momentarily lost by using a capacitor attached between RBI and VSS VSS 19 P Device ground REG27 20 P Internal power supply 2.7V bias output FUSE 21 I/OD ZVCHG 22 O P-CH precharge FET Drive controlling pre-charge and zero-volt charge CHG 23 O P-CH FET Drive controlling charge PACK 24 P PACK positive terminal and alternative power source SMBus data pin Keep this pin floating Push-pull fuse drive and secondary protector activation input sensing Submit Documentation Feedback Copyright © 2009–2016, Texas Instruments Incorporated Product Folder Links: bq3060 3 bq3060 SLUS928B – MARCH 2009 – REVISED JULY 2016 www.ti.com 6 Specifications 6.1 Absolute Maximum Ratings Over operating free-air temperature range (unless otherwise noted) (1) VMAX Supply voltage range MIN MAX UNIT –0.3 34 V VVC2–0.3 VVC2+8.5 or 34, whichever is lower V VC2 VVC3–0.3 VVC3+8.5 V VC3 VVC4–0.3 VVC4+8.5 V VC4 VSRP–0.3 VSRP+8.5 V SRP, SRN –0.3 VREG27 V SMBD, SMBC –0.3 6 V TS1, TS2, /PRES –0.3 VREG27 + 0.3 V CHG, DSG, ZVCHG, FUSE –0.3 BAT V RBI, REG27 –0.3 2.75 V 50 mA PACK w.r.t. Vss VC1, BAT Input voltage range VIN VO Output voltage range ISS Maximum combined sink current for input pins TFUNC Functional temperature –40 110 °C TSTG Storage temperature –65 150 °C (1) Stresses beyond those listed under absolute maximum ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under recommended operating conditions is not implied. Exposure to absolute–maximum–rated conditions for extended periods may affect device reliability. 6.2 ESD Ratings VALUE Human-body model (HBM), per ANSI/ESDA/JEDEC JS-001 V(ESD) (1) (2) Electrostatic discharge (1) UNIT ±2000 Charged-device model (CDM), per JEDEC specification JESD22C101 (2) V ±500 JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. Manufacturing with less than 500-V HBM is possible with the necessary precautions. Pins listed as ±2000 V may actually have higher performance. JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Manufacturing with less than 250-V CDM is possible with the necessary precautions. Pins listed as ±500 V may actually have higher performance. 6.3 Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) MIN Supply voltage BAT VSTARTUP Start up voltage at PACK Vshutdown VPACK or VBAT, whichever is higher VIN Input voltage range 25 3.8 3 Operating temperature 4 V 5.5 V 3.2 3.3 V VC2 VVC3 VVC3+5 VC3 VVC4 VVC4+5 VC4 VSRP VSRP+5 0 5 V 25 –0.3 1 1 –40 Submit Documentation Feedback UNIT 5.2 VVC2+5 SRP to SRN TOPR VVC2+5 VVC2 PACK External 2.7V REG capacitor MAX VC1, BAT VCn – VC(n+1), (n=1, 2, 3, 4 ) CREG27 TYP PACK V μF 85 °C Copyright © 2009–2016, Texas Instruments Incorporated Product Folder Links: bq3060 bq3060 www.ti.com SLUS928B – MARCH 2009 – REVISED JULY 2016 6.4 Thermal Information bq3060 THERMAL METRIC (1) PW (TSSOP) UNIT 24 PINS RθJA Junction-to-ambient thermal resistance 83.6 °C/W RθJC(top) Junction-to-case (top) thermal resistance 16.5 °C/W RθJB Junction-to-board thermal resistance 39.4 °C/W ψJT Junction-to-top characterization parameter 0.4 °C/W ψJB Junction-to-board characterization parameter 38.8 °C/W RθJC(bot) Junction-to-case (bottom) thermal resistance – °C/W (1) For more information about traditional and new thermal metrics, see the Semiconductor and IC Package Thermal Metrics application report. 6.5 Electrical Characteristics Typical values stated where TA = 25°C and VBAT = VPACK = 14.4 V, Minimum/Maximum values stated where TA = –40°C to 85°C and VBAT = VPACK = 3.8 V to 25 V (unless otherwise noted) PARAMETER TEST CONDITION MIN TYP MAX UNIT GENERAL PURPOSE I/O VIH High-level input voltage /PRES, SMBD, SMBC, TS1, TS2 VIL Low-level input voltage /PRES, SMBD, SMBC, TS1, TS2 VOH Output voltage high /PRES, SMBD, SMBC, TS1, TS2, IL = –0.5 mA VOH(FUSE) High level fuse output tR(FUSE) FUSE output rise time ZO(FUSE) FUSE output impedance VFUSE_DET FUSE detect input voltage VOL Low-level output voltage CIN Input capacitance VBAT = 3.8 V to 9 V, CL = 1 nF VBAT = 9 V to 25 V, CL = 1nF 2 V 0.8 VREG27–0.5 V 3 VBAT–0.3 8.6 7.5 8 9 CL = 1 nF, VOH(FUSE) = 0 V to 5 V 0.8 μs 2 6 kΩ 2 3.2 V 0.4 V 5 Ilkg Input leakage current RPD(SMBx) SMBD and SMBC pull-down TA = –40°C to 100°C RPAD Pad resistance TS1, TS2 600 V 10 /PRES, SMBD, SMBC, TS1, TS2, IL = 7 mA /PRES, SMBD, SMBC, TS1, TS2 SMBD and SMBC pull-down disabled V pF 1 μA 950 1300 kΩ 87 110 Ω SUPPLY CURRENT ICC ISLEEP ISHUTDOWN Normal mode Sleep mode Shutdown mode Firmware running, no flash writes 441 μA Discharge FET ON, Charge FET ON ([NR]=1, [NRCHG]=1) 69 Discharge FET ON, Charge FET OFF ([NR]=1, [NRCHG]=0) 66 Discharge FET OFF, Charge FET OFF ([NR]=0, System not present) 61 TA = –40°C to 110°C 0.5 1 μA μA REG27 POWER ON RESET VREG27IT– Negative-going voltage input At REG27 2.22 2.35 2.34 V VREG27IT+ Positive-going voltage input At REG27 2.25 2.5 2.6 V 2.5 2.7 2.75 V INTERNAL LDO VREG Regulator output voltage IREG27 = 10 mA; TA = –40°C to 85°C ΔV(REGTEMP) Regulator output change with temperature IREG = 10 mA; TA = –40°C to 85°C ΔV(REGLINE) Line regulation IREG = 10 mA ΔV(REGLOAD) Load regulation IREG = 0.2 to 10 mA ±0.5% ±2 ±4 mV ±20 ±40 mV Submit Documentation Feedback Copyright © 2009–2016, Texas Instruments Incorporated Product Folder Links: bq3060 5 bq3060 SLUS928B – MARCH 2009 – REVISED JULY 2016 www.ti.com Electrical Characteristics (continued) Typical values stated where TA = 25°C and VBAT = VPACK = 14.4 V, Minimum/Maximum values stated where TA = –40°C to 85°C and VBAT = VPACK = 3.8 V to 25 V (unless otherwise noted) PARAMETER I(REGMAX) TEST CONDITION Current limit MIN TYP 25 MAX 50 UNIT mA SRx WAKE FROM SLEEP VWAKE = 1.2 mV 0.2 1.2 2 VWAKE = 2.4 mV 0.4 2.4 3.6 2 5 6.8 5.3 10 13 VWAKE_ACR Accuracy of VWAKE VWAKE_TCO Temperature drift of VWAKE accuracy 0.5 tWAKE Time from application of current and wake of bq3060 0.2 VWAKE = 5 mV VWAKE = 10 mV mV %/°C 1 ms COULOMB COUNTER Input voltage range –0.20 Conversion time Single conversion Effective resolution Single conversion Integral nonlinearity TA = –25°C to 85°C Offset error (1) Bits ±0.007 TA = –25°C to 85°C ±0.034 %FSR 0.3 0.5 μV/°C 0.2% 0.8% 10 –0.8% Full-scale error drift μV 150 Effective input resistance V ms 15 Offset error drift Full-scale error (2) 0.25 250 2.5 PPM/°C MΩ ADC Input voltage range 0.8×VRE –0.2 V G27 Conversion time 31.5 Resolution (no missing codes) 16 Effective resolution 14 Bits 15 Integral nonlinearity Offset error Bits ±0.020 (3) 70 Offset error drift Full-scale error ms 160 1 VIN = 1 V –0.8% ±0.2% Full –scale error drift M μV μV/°C 0.4% 150 Effective input resistance %FSR 8 PPM/°C MΩ EXTERNAL CELL BALANCE DRIVE Cell balance ON for VC1, VCi-VCi+1 = 4 V, where i = 1~4 RBAL_drive Cell balance ON for VC2, VCi-VCi+1 = 4 V, Internal pull-down resistance where = i = 1~4 for external cell balance Cell balance ON for VC3, VCi-VCi+1 = 4 V, where = i = 1~4 5.7 3.7 kΩ 1.75 Cell balance ON for VC4, VCi-VCi+1 = 4 V, where = i = 1~4 0.85 TA = –10°C to 60°C ±10 ±20 TA = –40°C to 85°C ±10 ±35 CELL VOLTAGE MONITOR CELL Voltage Measurement Accuracy (4) (1) (2) (3) (4) 6 mV Post Calibration Performance Uncalibrated performance. This gain error can be eliminated with external calibration. Channel to channel offset This is the performance expected for non-calibrated device. Submit Documentation Feedback Copyright © 2009–2016, Texas Instruments Incorporated Product Folder Links: bq3060 bq3060 www.ti.com SLUS928B – MARCH 2009 – REVISED JULY 2016 Electrical Characteristics (continued) Typical values stated where TA = 25°C and VBAT = VPACK = 14.4 V, Minimum/Maximum values stated where TA = –40°C to 85°C and VBAT = VPACK = 3.8 V to 25 V (unless otherwise noted) PARAMETER TEST CONDITION MIN TYP MAX UNIT INTERNAL TEMPERATURE SENSOR T(TEMP) Temperature sensor accuracy ±3% °C THERMISTOR MEASUREMENT SUPPORT RERR Internal resistor drift R Internal resistor –230 TS1, TS2 17 ppm/°C 20 kΩ 175 °C INTERNAL THERMAL SHUTDOWN (5) TMAX Maximum REG27 temperature TRECOVER Recovery hysteresis temperature 125 10 °C HIGH FREQUENCY OSCILLATOR f(OSC) Operating frequency of CPU clock f(EIO) Frequency error (6) t(SXO) Start-up time (7) 2.097 MHz TA = –20°C to 70°C –2% ±0.25% 2% TA = –40°C to 85°C –3% ±0.25% 3% 3 6 TA = –25°C to 85°C ms LOW FREQUENCY OSCILLATOR f(LOSC) f(LEIO) t(LSXO) Operating frequency Frequency error (6) Start-up time (8) 32.768 MHz TA = –20°C to 70°C –1.5% ±0.25% 1.5% TA = –40°C to 85°C –2.5% ±0.25% 2.5% TA = –25°C to 85°C 100 ms FLASH (9) Data retention Flash programming writecycles t(ROWPROG) Row programming time t(MASSERASE) Mass-erase time t(PAGEERASE) Page-erase time ICC(PROG) Flash-write supply current ICC(ERASE) Flash-erase supply current 10 Years 20k Cycles 2 ms 250 ms 25 ms 4 6 mA TA = –40°C to 0°C 8 22 TA = 0°C to 85°C 3 15 20 1500 mA RAM BACKUP I(RBI) V(RBI) RBI data-retention input current VRBI > V(RBI)MIN, VREG27 < VREG27IT-, TA = 70°C to 110°C nA VRBI > V(RBI)MIN, VREG27 < VREG27IT-, TA = –40°C to 70°C RBI data-retention voltage (9) 500 1 V CURRENT PROTECTION THRESHOLDS V(OCD) (5) (6) (7) (8) (9) OCD detection threshold voltage range, typical RSNS = 0; RSNS is set in STATE_CTL register 50 200 RSNS = 1; RSNS is set in STATE_CTL register 25 100 mV Parameters assured by design. Not production tested. The frequency drift is included and measured from the trimmed frequency at VBAT = VPACK = 14.4 V, TA = 25°C The startup time is defined as the time it takes for the oscillator output frequency to be ±3% when the device is already powered. The startup time is defined as the time it takes for the oscillator output frequency to be ±3%. Specified by design. Not production tested Submit Documentation Feedback Copyright © 2009–2016, Texas Instruments Incorporated Product Folder Links: bq3060 7 bq3060 SLUS928B – MARCH 2009 – REVISED JULY 2016 www.ti.com Electrical Characteristics (continued) Typical values stated where TA = 25°C and VBAT = VPACK = 14.4 V, Minimum/Maximum values stated where TA = –40°C to 85°C and VBAT = VPACK = 3.8 V to 25 V (unless otherwise noted) PARAMETER ΔV(OCDT) OCD detection threshold voltage program step SCC detection threshold voltage range, typical V(SCCT) ΔV(SCCT) SCC detection threshold voltage program step SCD detection threshold voltage range, typical V(SCDT) ΔV(SCDT) SCD detection threshold voltage program step TEST CONDITION MIN TYP RSNS = 0; RSNS is set in STATE_CTL register 10 RSNS = 1; RSNS is set in STATE_CTL register 5 MAX UNIT mV RSNS = 0; RSNS is set in STATE_CTL register –100 –300 RSNS = 1; RSNS is set in STATE_CTL register –50 –225 mV RSNS = 0; RSNS is set in STATE_CTL register –50 RSNS = 1; RSNS is set in STATE_CTL register –25 mV RSNS = 0; RSNS is set in STATE_CTL register 100 450 RSNS = 1; RSNS is set in STATE_CTL register 50 225 mV RSNS = 0; RSNS is set in STATE_CTL register 50 RSNS = 1; RSNS is set in STATE_CTL register 25 mV V(OFFSET) SCD, SCC and OCD offset –10 10 V(Scale_Err) SCD, SCC and OCD scale error –10% 10% 1 31 mV CURRENT PROTECTION TIMING t(OCDD) Overcurrent in discharge delay t(OCDD_STEP) OCDD step options t(SCDD) Short circuit in discharge delay t(SCDD_STEP) SCDD step options t(SCCD) Short circuit in charge delay t(SCCD_STEP) SCCD step options t(DETECT) Current fault detect time tACC Overcurrent and short circuit delay time accuracy 2 ms AFE.STATE_CNTL[SCDDx2] = 0 0 915 AFE.STATE_CNTL[SCDDx2] = 1 0 1830 AFE.STATE_CNTL[SCDDx2] = 0 61 AFE.STATE_CNTL[SCDDx2] = 1 122 0 915 35 µs µs 61 VSRP-SRN = VTHRESH + 12.5 mV, TA = –40°C to 85°C ms µs µs 160 Accuracy of typical delay time with WDI active –20% 20% Accuracy of typical delay time with no WDI input –50% 50% VO(FETONDSG) = V(BAT)–V(DSG), RGS = 1MΩ, TA = –40°C to 110°C, BAT = 20 V (10) 12 15 18 VO(FETONCHG) = V(PACK)–V(CHG), RGS =1MΩ, TA = –40°C to 110°C, PACK = 20 V (10) 12 15 18 µs P-CH FET DRIVE VO(FETON) VO(FETOFF) tr Output voltage, charge and discharge FETs on Output voltage, charge and discharge FETs off Rise time V VO(FETOFFDSG) = V(BAT)–V(DSG), TA = –40°C to 110°C, BAT = 16 V 0.2 VO(FETOFFCHG) = V(PACK)–V(CHG), TA = –40°C to 110°C, PACK = 16 V 0.2 V CL = 4700 pF; VDSG: 10% to 90% 70 200 CL = 4700 pF; VCHG: 10% to 90% 70 200 µs (10) For a VBAT or VPACK input range of 3.8 V to 25 V, MIN VO(FETON) voltage is 12 V or V(BAT)–1 V, whichever is less. 8 Submit Documentation Feedback Copyright © 2009–2016, Texas Instruments Incorporated Product Folder Links: bq3060 bq3060 www.ti.com SLUS928B – MARCH 2009 – REVISED JULY 2016 Electrical Characteristics (continued) Typical values stated where TA = 25°C and VBAT = VPACK = 14.4 V, Minimum/Maximum values stated where TA = –40°C to 85°C and VBAT = VPACK = 3.8 V to 25 V (unless otherwise noted) PARAMETER tf Fall time TYP MAX CL = 4700 pF; VDSG: 10% to 90% TEST CONDITION MIN 70 200 UNIT CL = 4700 pF; VCHG: 10% to 90% 70 200 15 18 V VBAT–0. 5 V 200 µs µs PRE-CHARGE/ZVCHG FET DRIVE V(PreCHGON) VO(PreCHGON) = V(PACK)–V(ZVCHG), pre-charge RGS =1 MΩ, TA = –40°C to 110°C FET on (11) V(PreCHGOFF) Output voltage, pre-charge FET off (11) RGS =1 MΩ, TA = –40°C to 110°C tr Rise time CL = 4700 pF, RG = 5.1 kΩ, VZVCHG: 10% to 90% 80 tf Fall time CL = 4700 pF, RG = 5.1 kΩ, VZVCHG : 90% to 10% 1.7 fSMB SMBus operating frequency Slave mode, SMBC 50% duty cycle fMAS SMBus master clock frequency Master mode, no clock low slave extend tBUF Bus free time between start and stop tHD:STA 12 ms SMBus 10 100 51.2 kHz kHz 4.7 µs Hold time after (repeated) start 4 µs tSU:STA Repeated start setup time 4.7 µs tSU:STO Stop setup time 4 µs tHD:DAT Data hold time tSU:DAT Data setup time tTIMEOUT Error signal/detect tLOW Clock low period tHIGH Receive mode 0 Transmit mode 300 ns 250 See (12) Clock high period See (13) tLOW:SEXT Cumulative clock low slave extend time See tLOW:MEXT tF 25 ns 35 4.7 µs 50 µs (14) 10 ms Cumulative clock low master See extend time (15) 300 ns Clock/data fall time See (16) 300 ns Clock/data rise time See (17) 1000 ns fSMBXL SMBus XL operating frequency Slave mode 400 kHz tBUF Bus free time between start and stop tHD:STA tR 4 ms SMBus XL 40 4.7 µs Hold time after (repeated) start 4 µs tSU:STA Repeated start setup time 4.7 µs tSU:STO Stop setup time 4 µs (11) For a VBAT or VPACK input range of 3.8 V to 25 V, MIN V(PreCHGON) voltage is 12 V or V(BAT)–1V, whichever is less. (12) The bq3060 times out when any clock low exceeds tTIMEOUT (13) tHIGH, Max, is the minimum bus idle time. SMBC = SMBD = 1 for t > 50 μs causes reset of any transaction involving bq3060 that is in progress. This specification is valid when the NC_SMB control bit remains in the default cleared state (CLK[0]=0). If NC_SMB is set then the timeout is disabled. (14) tLOW:SEXT is the cumulative time a slave device is allowed to extend the clock cycles in one message from initial start to the stop. (15) tLOW:MEXT is the cumulative time a master device is allowed to extend the clock cycles in one message from initial start to the stop. (16) Rise time tR = VILMAX – 0.15) to (VIHMIN + 0.15) (17) Fall time tF = 0.9VDD to (VILMAX – 0.15) Submit Documentation Feedback Copyright © 2009–2016, Texas Instruments Incorporated Product Folder Links: bq3060 9 bq3060 SLUS928B – MARCH 2009 – REVISED JULY 2016 www.ti.com Electrical Characteristics (continued) Typical values stated where TA = 25°C and VBAT = VPACK = 14.4 V, Minimum/Maximum values stated where TA = –40°C to 85°C and VBAT = VPACK = 3.8 V to 25 V (unless otherwise noted) PARAMETER TEST CONDITION tTIMEOUT Error signal/detect tLOW Clock low period tHIGH Clock high period See (12) See (13) MIN TYP MAX UNIT 25 35 ms 1 1 µs 1 2 µs Timing Measurement Intervals t LOW tR tF t HD:STA SCLK t SU:STA t HIGH t HD:STA t HD:DAT t SU:STO t SU:DAT SDATA t BUF P S S P t TIMEOUT Measurement Intervals Start Stop t LOW:SEXT SCLK ACK1 t LOW:MEXT SCLK ACK1 t LOW:MEXT t LOW:MEXT SCLK SDATA (1) 10 SCLKACK is the acknowledge-related clock pulse generated by the master. Submit Documentation Feedback Copyright © 2009–2016, Texas Instruments Incorporated Product Folder Links: bq3060 bq3060 www.ti.com SLUS928B – MARCH 2009 – REVISED JULY 2016 7 Detailed Description 7.1 Feature Description 7.1.1 Battery Parameter Measurements The bq3060 uses an integrating delta-sigma analog-to-digital converter (ADC) for current measurement, and a second delta-sigma ADC for individual cell and battery voltage, and temperature measurement. 7.1.1.1 Charge and Discharge Counting The integrating delta-sigma ADC measures the charge/discharge flow of the battery by measuring the voltage drop across a small-value sense resistor between the SR1 and SR2 pins. The integrating ADC measures bipolar signals from -0.20 V to 0.25 V. The bq3060 detects charge activity when VSR = V(SRP)- V(SRN)is positive, and discharge activity when VSR = V(SRP) - V(SRN) is negative. The bq3060 continuously integrates the signal over time, using an internal counter. The fundamental rate of the counter is 0.65 nVh. 7.1.1.2 Voltage The bq3060 updates the individual series cell voltages at one second intervals. The internal ADC of the bq3060 measures the voltage, scales, and offsets, and calibrates it appropriately. To ensure an accurate differential voltage sensing, the IC ground should be connected directly to the most negative terminal of the battery stack, not to the positive side of the sense resistor. This minimizes the voltage drop across the PCB trace. 7.1.1.3 Voltage Calibration and Accuracy The bq3060 is calibrated for voltage prior to shipping from TI. The bq3060 voltage measurement signal chain (ADC, high voltage translation, circuit interconnect) will be calibrated for each cell. The external filter resistors, connected from each cell to the VCx input of the bq3060, are required to be 1kΩ. The accuracy of the factorycalibrated devices is +/- 10mV per cell at room temperature at 4V cell voltage. Without any customer voltage calibration, this is the level of accuracy expected as long as the filter resistor value is 1kΩ. If better voltage accuracy is desired, customer voltage calibration is required. An application note on calibrating and programming the bq3060 is available in the product web folder. See Data Flash Programming and Calibrating the bq3060 Gas Gauge (SLUA502) for more details. 7.1.1.4 Current The bq3060 uses the SRP and SRN inputs to measure and calculate the battery charge and discharge current using a 5 mΩ to 20 mΩ typ. sense resistor. 7.1.1.5 Auto Calibration The bq3060 can automatically calibrate its offset between the A to D converter and the output of the high voltage translation circuit. Also, the bq3060 provides an auto-calibration for the coulomb counter to cancel the voltage offset error across SRN and SRP for maximum charge measurement accuracy. The bq3060 performs autocalibration when the SMBus lines stay low continuously for a minimum of 5 s. 7.1.1.6 Temperature The bq3060 has an internal temperature sensor and inputs for 2 external temperature sensor inputs TS1 and TS2 used in conjunction with two identical NTC thermistors (default is Semitec 103AT) to sense the battery cell temperature. The bq3060 can be configured to use internal or up to 2 external temperature sensors. 7.1.2 Primary (1st Level) Safety Features The bq3060 supports a wide range of battery and system protection features that can easily be configured. The primary safety features include: • Cell over/undervoltage protection • Charge and discharge overcurrent • Short circuit • Charge and discharge overtemperature • AFE Watchdog Submit Documentation Feedback Copyright © 2009–2016, Texas Instruments Incorporated Product Folder Links: bq3060 11 bq3060 SLUS928B – MARCH 2009 – REVISED JULY 2016 www.ti.com Feature Description (continued) 7.1.3 Secondary (2nd Level) Safety Features The secondary safety features of the bq3060 can be used to indicate more serious faults via the FUSE (pin 21). This pin can be used to blow an in-line fuse to permanently disable the battery pack from charging and discharging. This pin is also used as an input to sense the state of the fuse. The secondary safety protection features include: • Safety overvoltage • Safety overcurrent in charge and discharge • Safety overtemperature in charge and discharge • Charge FET and Zero-Volt Charge FET fault • Discharge FET fault • Cell imbalance detection • Fuse blow by a secondary voltage protection IC • AFE register integrity fault (AFE_P) • AFE communication fault (AFE_C) 7.1.4 Charge Control Features The bq3060 charge control features include: • Supports JEITA temperature ranges. Reports charging voltage and charging current according to the active temperature range. • Handles more complex charging profiles. Allows for splitting the standard temperature range into 2 subranges and allows for varying the charging current according to the cell voltage. • Reports the appropriate charging current needed for constant current charging and the appropriate charging voltage needed for constant voltage charging to a smart charger using SMBus broadcasts. • Reduce the charge difference of the battery cells in fully charged state of the battery pack gradually using a voltage-based cell balancing algorithm during charging. A voltage threshold can be set up for cell balancing to be active. This prevents fully charged cells from overcharging and causing excessive degradation and also increases the usable pack energy by preventing premature charge termination • Supports pre-charging/zero-volt charging • Supports charge inhibit and charge suspend if battery pack temperature is out of temperature range • Reports charging fault and also indicate charge status via charge and discharge alarms. 7.1.5 Gas Gauging The bq3060 uses advanced CEDV (Compensated End-of-Discharge Voltage) technology to measure and calculate the available capacity in battery cells. The bq3060 accumulates a measure of charge and discharge currents and compensates the charge current measurement for temperature and state-of-charge of the battery. The bq3060 estimates self-discharge of the battery and also adjusts the self-discharge estimation based on temperature. See bq3060 Technical Reference (SLUU319) for further details. 7.1.6 Lifetime Data Logging Features The bq3060 offers limited lifetime data logging for the following critical battery parameters for analysis purposes: • Lifetime maximum temperature • Lifetime minimum temperature • Lifetime maximum battery cell voltage • Lifetime minimum battery cell voltage 7.1.7 Authentication The bq3060 supports authentication by the host using SHA-1. 12 Submit Documentation Feedback Copyright © 2009–2016, Texas Instruments Incorporated Product Folder Links: bq3060 bq3060 www.ti.com SLUS928B – MARCH 2009 – REVISED JULY 2016 Feature Description (continued) 7.1.8 Configuration 7.1.8.1 System Present Operation The bq3060 checks the PRES pin periodically (1 second). If PRES input is pulled to ground by external system, the bq3060 detects the presence of the system. 7.1.8.2 2-, 3-, or 4-Cell Configuration In a 2-cell configuration, VC1 is shorted to VC2 and VC3. In a 3-cell configuration, VC1 is shorted to VC2. 7.1.8.3 Cell Balance Control If cell balancing is required, the bq3060 cell balance control allows a weak, internal pull-down for each VCx pin. The purpose of this weak pull-down is to enable an external FET for current bypass. Series resistors placed between the input VCx pins and the positive battery cell terminals control the VGS of the external FET. See bq3060 Cell balancing using external MOSFET (SLUA509) or bq3060 Gas Gauge Circuit Design (SLUA507) for more details. 7.1.9 Communications The bq3060 uses SMBus v1.1 with Master Mode and package error checking (PEC) options per the SBS specification. 7.1.9.1 SMBus On and Off State The bq3060 detects an SMBus off state when SMBC and SMBD are logic-low for ≥ 2 seconds. Clearing this state requires either SMBC or SMBD to transition high. Within 1 ms, the communication bus is available. 7.1.10 SBS Commands See bq3060 Technical Reference (SLUU319) for further details. 7.2 Device Functional Modes 7.2.1 Power Modes The bq3060 supports 3 different power modes to reduce power consumption: • In Normal Mode, the bq3060 performs measurements, calculations, protection decisions and data updates in 1 second intervals. Between these intervals, the bq3060 is in a reduced power stage. • In Sleep Mode, the bq3060 performs measurements, calculations, protection decisions and data update in adjustable time intervals. Between these intervals, the bq3060 is in a reduced power stage. The bq3060 has a wake function that enables exit from Sleep mode, when current flow or failure is detected. • In Shutdown Mode the bq3060 is completely disabled. Submit Documentation Feedback Copyright © 2009–2016, Texas Instruments Incorporated Product Folder Links: bq3060 13 bq3060 SLUS928B – MARCH 2009 – REVISED JULY 2016 www.ti.com 8 Device and Documentation Support 8.1 Documentation Support 8.1.1 Related Documentation • bq3060 Technical Reference (SLUU319) • bq3060 Cell balancing using external MOSFET (SLUA509) • bq3060 Gas Gauge Circuit Design (SLUA507) • Data Flash Programming and Calibrating the bq3060 Gas Gauge (SLUA502) 8.2 Receiving Notification of Documentation Updates To receive notification of documentation updates, navigate to the device product folder on ti.com. In the upper right corner, click on Alert me to register and receive a weekly digest of any product information that has changed. For change details, review the revision history included in any revised document. 8.3 Community Resources TI E2E™ support forums are an engineer's go-to source for fast, verified answers and design help — straight from the experts. Search existing answers or ask your own question to get the quick design help you need. Linked content is provided "AS IS" by the respective contributors. They do not constitute TI specifications and do not necessarily reflect TI's views; see TI's Terms of Use. 8.4 Trademarks E2E is a trademark of Texas Instruments. All other trademarks are the property of their respective owners. 8.5 Electrostatic Discharge Caution This integrated circuit can be damaged by ESD. Texas Instruments recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. 8.6 Glossary SLYZ022 — TI Glossary. This glossary lists and explains terms, acronyms, and definitions. 9 Mechanical, Packaging, and Orderable Information The following pages include mechanical, packaging, and orderable information. This information is the most current data available for the designated devices. This data is subject to change without notice and revision of this document. For browser-based versions of this data sheet, refer to the left-hand navigation. 14 Submit Documentation Feedback Copyright © 2009–2016, Texas Instruments Incorporated Product Folder Links: bq3060 PACKAGE OPTION ADDENDUM www.ti.com 6-Feb-2020 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Op Temp (°C) Device Marking (4/5) BQ3060PW ACTIVE TSSOP PW 24 60 Green (RoHS & no Sb/Br) NIPDAU Level-2-260C-1 YEAR -40 to 85 3060 BQ3060PWR ACTIVE TSSOP PW 24 2000 Green (RoHS & no Sb/Br) NIPDAU Level-2-260C-1 YEAR -40 to 85 3060 (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
BQ3060PW-BE 价格&库存
很抱歉,暂时无法提供与“BQ3060PW-BE”相匹配的价格&库存,您可以联系我们找货
