bq2018
Power Minder™ IC
Features
General Description
➤ Multifunction charge/discharge
counter
The bq2018 is a low-cost charge/discharge counter peripheral packaged in
an 8-pin TSSOP or SOIC. It works
with an intelligent host controller, providing state-of-charge information for
rechargeable batteries.
➤ Resolves signals less than 12.5µV
➤ Internal offset calibration improves accuracy
➤ 1024 bits of NVRAM configured as
128 x 8
➤ Internal temperature sensor for
self-discharge estimation
➤ Single-wire serial interface
➤ Dual operating modes:
Operating: VSR2 (Max. = +200mV) 12.5µVh increments
16-bit
SCR
Self-discharge count register
1 count/hour @ 25°C
16-bit
DTC
Discharge time counter
1 count/0.8789s default
1 count/225s if STD is set
16-bit
CTC
Charge time counter
1 count/225s if STC is set
16-bit
MODE/
WOE
MODE/
Wake output enable
8-bit
4
bq2018
7f
7f
Discharge count high byte
7e Discharge count low byte
7d Charge count high byte
7c Charge count low byte
7b Self-discharge high byte
7a Self-discharge low byte
73
72
79 Discharge time high byte
78 Discharge time low byte
User
RAM
77 Charge time high byte
76 Charge time low byte
75 Mode/wake output enable
74 Temperature/clear
73 Offset register
00
FG201801.eps
Figure 3. Address Map
useful in determining an estimation of the battery selfdischarge based on capacity and storage temperature
conditions.
During charge, the CCR and the Charge Time Counter
(CTC) are active. If VSR1 is greater than VSR2, indicating
a charge, the CCR counts at a rate equivalent to 12.5µV
every hour, and the CTC counts at a rate of 1
count/0.8789 seconds. For example, a +100mV signal produces 8000 CCR counts and 4096 CTC counts each hour.
The amount of charge added to the battery can easily be
calculated.
The bq2018 may be programmed to measure the voltage
offset between SR1 and SR2 during pack assembly or at
any time by invoking the Calibration mode. The Offset
Register (OFR) is used to store the bq2018 offset. The 8bit 2’s complement value stored in the OFR is scaled to
the same units as the DCR and CCR, representing the
amount of positive or negative offset in the bq2018. The
maximum offset for the bq2018 is specified as ± 500µV.
Care should be taken to ensure proper PCB layout. Using OFR, the system host can cancel most of the effects of
bq2018 offset for greater resolution and accuracy.
The DTC and the CTC are 16-bit registers, and roll over
beyond ffffh. If a rollover occurs, the corresponding bit in
the MODE/WOE register is set, and the counter will subsequently increment at 1/256 of the normal rate (16
counts/hr.).
Whenever the signal between SR1 and SR2 is above the
Wakeup Output Enable (WOE) threshold and the HDQ
pin is high, the bq2018 is in its full operating state. In
this state, the DCR, CCR, DTC, CTC, and SCR are fully
operational, and the WAKE output is low. During this
mode, the internal RAM registers of the bq2018 may be
accessed over the HDQ pin, as described in the section
“Communicating With the 2018.”
Figure 3 shows the bq2018 register address map. The
bq2018 uses the upper 13 locations. The remaining
memory can store user-specific information such as
chemistry, serial number, and manufacturing date.
WAKE Output
This output is used to inform the system that the voltage
difference between SR1 and SR2 is above or below the
Wake Output Enable (WOE) threshold programmed in
the MODE/WOE register. When the voltage difference
between SR1 and SR2 is below VWOE, the WAKE output
goes into High Z and remains in this state until the discharge or charge current increases above the specified
value. The MODE/WOE resets to 0eh after a power-on
reset. VWOE is set by dividing 3.84mV by a value between 1 and 7 (1–7h) according to Table 3.
If the signal between SR1 and SR2 is below the WOE
threshold (refer to the WAKE section for details) and
HDQ remains low for greater than 10 seconds, the
bq2018 enters a sleep mode where all register counting is
suspended. The bq2018 remains in this mode until HDQ
returns high.
For self-discharge calculation, the self-discharge count
register (SCR) counts at a rate equivalent to 1 count
every hour at a nominal 25°C and doubles approximately
every 10°C up to 60°C. The SCR count rate is halved
every 10 °C below 25°C down to 0°C. The value in SCR is
5
bq2018
Table 3. WOE Thresholds
Table 4. Temperature Steps
WOE3–1 (hex)
VWOE (mV)
0h
n/a
1h
3.840
2h
1.920
10–20°
2h
× 1/2
3h
1.280
20–30°
3h
1 count/hr.
4h
0.960
30–40°
4h
×2
5h
0.768
40–50°
5h
×4
6h
0.640
50–60°
6h
×8
7h*
0.549
>60°
7h
× 16
Temp
Value (hex)
SDR Count Rate
VWOE, then the calibration cycle is reset.
The bq2018 then postpones the calibration cycle until the
conditions are met. The calibration bit does not reset to
zero until a valid calibration cycle is completed. The requirement for HDQ to remain low for the calibration cycle can be disabled by setting the OVRDQ bit to 1. In this
case, calibration continues as long as |VSR| < VWOE. The
OVRDQ bit is reset to zero at the end of a valid calibration cycle.
Communication with the bq2018 always occurs with the
least-significant bit being transmitted first. Figure 4 shows
an example of a communication sequence to read the
bq2018 OFR register.
Communicating with the bq2018
bq2018 Registers
The bq2018 includes a simple single-pin (referenced to
VSS) serial data interface. A host processor uses the interface to access various bq2018 registers. Battery activity may be easily monitored by adding a single contact to
the battery pack. Note: The HDQ pin requires an external pull-up or pull-down resistor.
The bq2018 command and status registers are listed in
Table 5 and described below.
Command (CMDR)
The write-only command register is accessed when the
bq2018 has received eight contiguous valid command
bits. The command register contains two fields:
The interface uses a command-based protocol, where the
host processor sends a command byte to the bq2018. The
command directs the bq2018 either to store the next
eight bits of data received to a register specified by the
command byte or to output the eight bits of data from a
register specified by the command byte.
n
W/R
n
Command address
The W/R bit of the command register is used to select
whether the received command is for a read or a write
function. The W/R values are
The communication protocol is asynchronous return-toone. Command and data bytes consist of a stream of
eight bits that have a maximum transmission rate of 5K
bits/sec. The least-significant bit of a command or data
byte is transmitted first. The protocol is simple enough
that it can be implemented by most host processors using
either polled or interrupt processing. Data input from the
bq2018 may be sampled using the pulse-width capture
timers available on some microcontrollers. A UART may
also be used to communicate through the HDQ pin.
CMDR Bits
7
6
5
4
3
2
1
W/R
Where W/R is
If a communication time-out occurs, e.g., the host waits
longer than tCYCB for the bq2018 to respond or if this is
the first access command, then a BREAK should be sent
by the host. The host may then resend the command. The
bq2018 detects a BREAK when the HDQ pin is driven to
a logic-low state for a time, tB or greater. The HDQ pin
then returns to its normal ready-high logic state for a
time, tBR. The bq2018 is then ready to receive a command from the host processor.
The bq2018 outputs the requested register
contents specified by the address portion of
the CMDR
1
The following eight bits should be written
to the register specified by the address portion of the CMDR
The lower seven-bit field of CMDR contains the address
portion of the register to be accessed.
The return-to-one data bit frame consists of three distinct
sections. The first section is used to start the transmission by either the host or the bq2018 taking the HDQ pin
to a logic-low state for a period, tSTRH,B. The next section
is the actual data transmission, where the data should be
valid by a period, tDSU,B, after the negative edge used to
start communication. The data should be held for a period, tDV/tDH, to allow the host or bq2018 to sample the
data bit.
CMDR Bits
7
6
5
AD6 AD5
4
3
2
1
AD4
AD3
AD2
AD1
AD0
Discharge Count Registers (DCRH/DCRL)
The DCRH high-byte register (address = 7fh) and the
DCRL low-byte register (address = 7eh) contain the count
8
bq2018
DTCH and DTCL increment at a rate of 16 counts per
hour. Note: If a second rollover occurs, STC is
cleared. Access to the bq2018 should be timed to
clear CTCH/CTCL more often than every 170 days.
The TMP/CLR register is used to force the reset of both
the CTCH and CTCL to zero.
of the discharge, and are incremented whenever VSR1 <
VSR2. These registers continue to count beyond ffffh, so
proper register maintenance should be done by the host
system. The TMP/CLR register is used to force the reset
of both the DCRH and DCRL to zero.
Charge Count Registers (CCRH/CCRL)
Mode/Wake-up Enable Register
The CCRH high-byte register (address = 7dh) and the
CCRL low-byte register (address = 7ch) contain the count
of the charge, and are incremented whenever VSR1 >
of both the CCRH and CCRL to zero.
The Mode/WOE register (address = 75h) contains the
calibration, wakeup enable information, and the STC and
STD bits as described below.
The Override DQ(OVRDQ) bit (bit 7) is used to override
the requirement for HDQ to be low prior to initiating VOS
calibration. This bit is normally set to zero. If OVRDQ is
written to one, the bq2018 begins offset calibration when
|VSR|
