IH5140CPE
IH5140CPE
    L3HARRIS
    DIP-16
    HIGH-LEVEL CMOS ANALOG SWITCH
IH5140CPE 数据手册
Datasheet IH5143 High-Level CMOS Analog Switches The IH5140 Family of CMOS switches utilizes Harris’ latch­free Junction isolated processing to build the fastest switches currently available. These switches can be toggled at a rate of greater than 1MHz with fast tON times (80ns typical) and faster tOFF times (50ns typical), guaranteeing break before make switching. This family of switches combines the speed of the hybrid FET DG180 family with the reliability and low power consumption of a monolithic CMOS construction. Very low quiescent power is dissipated in either the ON or the OFF state of the switch. Maximum power supply current is 10µA (at 25°C) from any supply and typical quiescent cur­rents are in the 10nA which makes these devices ideal for portable equipment and military applications. The IH5140 Family is completely compatible with TTL (5V) logic, TTL open collector logic and CMOS logic. It is pin compatible with Harris’ IH5040 family and part of the DG180/DG 190 family as shown in the switching state diagrams. Rochester Electronics Manufactured Components Rochester branded components are manufactured using either die/wafers purchased from the original suppliers or Rochester wafers recreated from the original IP. All re-creations are done with the approval of the Original Component Manufacturer (OCM). Parts are tested using original factory test programs or Rochester developed test solutions to guarantee product meets or exceeds the OCM data sheet. Quality Overview • ISO-9001 • AS9120 certification • Qualified Manufacturers List (QML) MIL-PRF-35835 • Class Q Military • Class V Space Level • Qualified Suppliers List of Distributors (QSLD) • Rochester is a critical supplier to DLA and meets all industry and DLA standards. Rochester Electronics, LLC is committed to supplying products that satisfy customer expectations for quality and are equal to those originally supplied by industry manufacturers. The original manufacturer’s datasheet accompanying this document reflects the performance and specifications of the Rochester manufactured version of this device. Rochester Electronics guarantees the performance of its semiconductor products to the original OCM specifications. ‘Typical’ values are for reference purposes only. Certain minimum or maximum ratings may be based on product characterization, design, simulation, or sample testing. FOR REFERENCE ONLY © 2019 Rochester Electronics, LLC. All Rights Reserved 04112019 To learn more, please visit www.rocelec.com
IH5140CPE 价格&库存
很抱歉,暂时无法提供与“IH5140CPE”相匹配的价格&库存,您可以联系我们找货
