THIS DOCUMENT IS FOR MAINTENANCE
PURPOSES ONLY AND IS NOT
RECOMMENDED FOR NEW DESIGNS
NJ88C25
NJ88C25 IS FOR MAINTENANCE PURPOSES ONLY AND IS NOT RECOMMENDED FOR NEW DESIGNS
DS3280-1.3
NJ88C25
FREQUENCY SYNTHESISER (MICROPROCESSOR SERIAL INTERFACE)
The NJ88C25 is a synthesiser circuit fabricated on the GPS
CMOS process and is capable of achieving high sideband
attenuation and low noise performance. It contains a reference
oscillator, 11-bit programmable reference divider, digital and
sample-and-hold comparators, 10-bit programmable ‘M’ counter,
7-bit programmable ‘A’ counter, latched and buffered Band 0 and
Band 1 outputs and the necessary control and latch circuitry for
accepting and latching the input data.
Data is presented serially under external control from a suitable
microprocessor. Although 30 bits of data are initially required to
program all counters, subsequent updating can be abbreviated to
19 bits, when only the ‘A’, ‘M’ and ‘B’ counters require changing.
The NJ88C25 is intended to be used in conjunction with a twomodulus prescaler such as the SP8710 series to produce a
universal binary coded synthesiser.
PDA
1
18
CH
PDB
2
17
RB
FV
3
16
MC
LD
4
15
CAP
FIN
5 NJ88C25 14
VSS
6
13
CLOCK
VDD
7
12
DATA
BAND 0
8
11
BAND 1
OSC IN
9
10
OSC OUT
DG18, DP18, MP18
FEATURES
■ Low Power Consumption
Fig.1 Pin connections - top view
■ High Performance Sample and Hold Phase Detector
■ Serial Input with Fast Update Feature
ORDERING INFORMATION
NJ88C25 KA DG Ceramic DIL Package
NJ88C25 KA DP Plastic DIL Package
NJ88C25 KA MP Miniature Plastic DIL Package
ABSOLUTE MAXIMUM RATINGS
Supply voltage, VDD2VSS:
20·5V to 7V
Input voltage
Open drain output, pins 3 and 4:
7V
All other pins:
VSS20·3V to VDD10·3V
Storage temperature:
265°C to 1150°C (DG package)
255°C to 1125°C
(DP and MP packages)
RB
17
OSC IN
OSC OUT
9
ENABLE
REFERENCE COUNTER
(11BITS)
fr
42
10
CAP
CH
15
18
SAMPLE/HOLD
PHASE
DETECTOR
1
FREQUENCY/
PHASE
DETECTOR
2
PDA
LATCH 6 LATCH 7 LATCH 8
12
DATA 14
ENABLE
CLOCK
13
‘B’ REGISTER
LATCH 6
BAND 0
BAND 1
FIN
fV
‘R’ REGISTER
‘M’ REGISTER
‘A’ REGISTER
LATCH 1 LATCH 2 LATCH 3
LATCH 4 LATCH 5
11
3
‘M’ COUNTER
(10 BITS)
‘A’ COUNTER
(7 BITS)
VSS
LOCK DETECT (LD)
VSS
8
FV
VSS
5
CONTROL LOGIC
VDD
4
PDB
7
6
Fig.2 Block diagram
16
MODULUS
CONTROL
OUTPUT (MC)
NJ88C25
ELECTRICAL CHARACTERISTICS AT VDD = 5V
Test conditions unless otherwise stated:
VDD–VSS=2·7V to 5·5V. Temperature range = –30°C to +70°C
DC Characteristics
Value
Characteristic
Units
Supply current
OUTPUTS
Modulus Control (MC), BAND 1 and BAND 2
High level
Low level
Lock Detect (LD) and FV
Low level
Open drain pull-up voltage
PDB
High level
Low level
3-state leakage current
Typ.
Conditions
Max.
5·5
0·7
3·7
mA
mA
mA
fosc, fFIN = 20MHz
fosc, fFIN = 1MHz
fosc, fFIN = 10MHz
0·4
V
V
ISOURCE = 1mA
ISINK = 1mA
0·4
7·0
V
V
ISINK = 4mA
0·4
±0·1
V
V
µA
ISOURCE = 4mA
ISINK = 4mA
VDD20·4
4·6
Min.
0 to 5V
square
wave
AC Characteristics
Value
Characteristic
Units
200
0·5
0·5
0·2
0·2
0·2
0·2
0·2
3
Conditions
Max.
50
tCH
2
500
5
1
1
5
mV RMS 10MHz AC-coupled sinewave
MHz
Input squarewave VDD to VSS,
ns
See note 2
µs
µs
µs
µs
µs
µs
µs
V
V
ns
kΩ
nF
nF
kΩ
FIN and OSC IN input level
Max. operating frequency, fFIN and fosc
Propagation delay, clock to modulus control MC
Programming Inputs
Clock high time, tCH
Clock low time, tCL
Enable set-up time, tES (see note 5)
Enable hold time, tEH
Data set-up time, tDS
Data hold time, tDH
Clock rise and fall times
Positive threshold
Negative threshold
Phase Detector
Digital phase detector propagation delay
Gain programming resistor, RB
Hold capacitor, CH
Programming capacitor, CAP
Output resistance, PDA
Typ.
Min.
All timing periods
are referenced to
the negative
transition of the
clock waveform.
See note 5
TTL compatible, see note 1
See note 3
NOTES
1. Data inputs have internal pull-up resistors to enable them to be driven from TTL outputs.
2. All counters have outputs directly synchronous with their respective clock rising edges.
3. The finite output resistance of the internal voltage follower and ‘on’ resistance of the sample switch driving this pin will add a finite time constant
to the loop. An external 1nF hold capacitor will give a maximum time constant of 5µs.
4. The inputs to the device should be at logic ‘0’ when power is applied if latch-up conditions are to be avoided. This includes the OSC IN and
FIN inputs.
5. Clock to enable set-up time (tES) is variable, dependent on fOSC. It needs to be specified in terms of fOSC, clock high time (tCH) and clock low time
(tCL) and must meet the following conditions: 431/fOSCA. Where every possible channel is required, the minimum total division
ratio N should be: N>P 22P.
17
RB
An external sample and hold phase comparator gain programming resistor should be connected
between this pin and VSS.
18
CH
An external hold capacitor should be connected between this pin and VSS.
Two latch outputs, providing an output of the data from the ‘B’ register.
3
NJ88C25
8
2·0
VDD = 5V
FIN = LOW FREQUENCY
0V TO 5V SQUARE WAVE
7
1·5
SUPPLY CURRENT (mA)
SUPPLY CURRENT (mA)
VDD = 5V
OSC IN, FIN = 0V TO 5V SQUARE WAVE
OSC IN
1·0
FIN
6
5
10MHz
4
3
1MHz
2
0·5
TOTAL SUPPLY CURRENT IS
THE SUM OF THAT DUE TO FIN
AND OSC IN
1
2
3
4
5
6
7
INPUT FREQUENCY (MHz)
8
1
9
0·2
10
Fig. 3 Typical supply current v. input frequency
0·4
0·6
0·8
1·0
1·2
INPUT LEVEL (V RMS)
1·4
1·6
Fig. 4 Typical supply current v. input level, OSC IN
PROGRAMMING
Reference Divider Chain
The comparison frequency depends upon the crystal
oscillator frequency and the division ratio of th ‘R’ counter,
which can be programmed in the range 3 to 2047, and a fixed
divide by two stage.
fosc
R=
23fcomp
where fosc = oscillator frequency,
fcomp = comparison frequency,
R = ‘R’ counter ratio
For example, where the crystal frequency = 10MHz and a
channel spacing comparison frequency of 12·5kHz is required,
R=
107
= 400
2312·53103
Thus, the ‘R’ register would be programmed to 400 expressed
in binary. The total division ratio would then be 23400 = 800
since the total division ratio of the ‘R’ counter plus the 42 stage
is from 6 to 4094 in steps of 2.
VCO Divider Chain
The synthesised frequency of the voltage controlled oscillator
(VCO) will depend on the division ratios of the ‘M’ and ‘A’
counters, the ratio of the external two-modulus prescaler
(P/P11)and the comparison frequency .
For example, if the desired VCO frequency = 275MHz, the
comparison frequency is 12·5kHz and a two-modulus prescaler
of 464/65 is being used, then
6
N = 275310 3 = 223103
12·5310
Now, N = MP1A, which can be rearranged as N/P = M1A/P.
In our example we have P = 64, therefore
A
223103
= M1
64
64
such that M = 343 and A /64 = 0·75.
Now, M is programmed to the integer part = 343 and A is
programmed to the fractional part364 i.e., A = 0·75364 = 48.
NB The minimum ratio N that can be used is P 22P (=4032 in
our example) for all contiguous channels to be available.
To check: N = 343364148 = 22000, which is the required
division ratio and is greater than 4032 ( = P 22P ).
tCL
tCH
CLOCK
ENABLE
The division ratio N = MP1A,
where M is the ratio of the ‘M’ counter in the range 8 to 1023
and A is the ratio of the ‘A’ counter in the range 0 to 127.
Note that M>A and
N = fVCO
fcomp
tEH
tES
tEH
tDS
tDH
DATA
Fig. 5 Timing diagram showing timing periods required for correct operation
4
tES
NJ88C25
1
2
3
4
5
(17)28
(18)29
(19)30
CLOCK
ENABLE
DATA
A6
A5
A4
A3
A2
(M2)R2
(B1)R1
(B0)R0
Fig.6 Timing diagram showing programming details
PHASE COMPARATORS
Noise output from a synthesiser loop is related to loop gain:
KPD KVCO
N
where KPD is the phase detector constant (volts/rad), KVCO is
the VCO constant (rad/sec/volt) and N is the overall loop division
ratio. When N is large and the loop gain is low, noise may be
reduced by employing a phase comparator with a high gain.
The sample and hold phase comparator in the NJ88C25 has
a high gain and uses a double sampling technique to reduce
spurious outputs to a low level.
A standard digital phase/frequency detector driving a threestate output,PDB, provides a ‘coarse’ error signal to enable
fast switching between channels.
The PDB output is active until the phase error is within the
sample and hold phase detector window, when PDB becomes
high impedance. Phase-lock is indicated at this point by a low
level on LD. The sample and hold phase detector provides a
‘fine’ error signal to give further phase adjustment and to hold
the loop in lock. An internally generated ramp, controlled by the
digital output from both the reference and main divider chains,
is sampled at the reference frequency to give the ‘fine’ error
signal, PDA. When in phase lock, this output would be typically
at (VDD2VSS)/2 and any offset from this would be proportional
to phase error.
The relationship between this offset and the phase error is
the phase comparator gain, KPDA, which is programmable with
an external resistor, RB, and a capacitor, CAP. An internal
50pF capacitor is used in the sample and hold comparator.
5
NJ88C25
HEADQUARTERS OPERATIONS
GEC PLESSEY SEMICONDUCTORS
Cheney Manor, Swindon,
Wiltshire SN2 2QW, United Kingdom.
Tel: (0793) 518000
Fax: (0793) 518411
P.O. Box 660017
1500 Green Hills Road,
Scotts Valley, California 95067-0017,
United States of America.
Tel: (408) 438 2900
Fax: (408) 438 5576
CUSTOMER SERVICE CENTRES
• FRANCE & BENELUX Les Ulis Cedex Tel: (1) 64 46 23 45 Tx: 602858F
Fax : (1) 64 46 06 07
• GERMANY Munich Tel: (089) 3609 06-0 Tx: 523980 Fax : (089) 3609 06-55
• ITALY Milan Tel: (02) 66040867 Fax: (02) 66040993
• JAPAN Tokyo Tel: (03) 3296-0281 Fax: (03) 3296-0228
• NORTH AMERICA Integrated Circuits and Microwave Products Scotts Valley, USA
Tel (408) 438 2900 Fax: (408) 438 7023.
Hybrid Products, Farmingdale, USA Tel (516) 293 8686
Fax: (516) 293 0061.
• SOUTH EAST ASIA Singapore Tel: (65) 3827708 Fax: (65) 3828872
• SWEDEN Stockholm, Tel: 46 8 702 97 70 Fax: 46 8 640 47 36
• UNITED KINGDOM & SCANDINAVIA
Swindon Tel: (0793) 518510 Tx: 444410 Fax : (0793) 518582
These are supported by Agents and Distributors in major countries world-wide.
GEC Plessey Semiconductors 1992 Publication No. DS3280 Issue No. 1.3 May 1992
This publication is issued to provide information only which (unless agreed by the Company in writing) may not be used, applied or reproduced for any purpose nor form part of any order or contract nor to be regarded
as a representation relating to the products or services concerned. No warranty or guarantee express or implied is made regarding the capability, performance or suitability of any product or service. The Company
reserves the right to alter without prior knowledge the specification, design or price of any product or service. Information concerning possible methods of use is provided as a guide only and does not constitute
any guarantee that such methods of use will be satisfactory in a specific piece of equipment. It is the user's responsibility to fully determine the performance and suitability of any equipment using such information
and to ensure that any publication or data used is up to date and has not been superseded. These products are not suitable for use in any medical products whose failure to perform may result in significant injury
or death to the user. All products and materials are sold and services provided subject to the Company's conditions of sale, which are available on request.
For more information about all Zarlink products
visit our Web Site at
www.zarlink.com
Information relating to products and services furnished herein by Zarlink Semiconductor Inc. or its subsidiaries (collectively “Zarlink”) is believed to be reliable.
However, Zarlink assumes no liability for errors that may appear in this publication, or for liability otherwise arising from the application or use of any such
information, product or service or for any infringement of patents or other intellectual property rights owned by third parties which may result from such application or
use. Neither the supply of such information or purchase of product or service conveys any license, either express or implied, under patents or other intellectual
property rights owned by Zarlink or licensed from third parties by Zarlink, whatsoever. Purchasers of products are also hereby notified that the use of product in
certain ways or in combination with Zarlink, or non-Zarlink furnished goods or services may infringe patents or other intellectual property rights owned by Zarlink.
This publication is issued to provide information only and (unless agreed by Zarlink in writing) may not be used, applied or reproduced for any purpose nor form part
of any order or contract nor to be regarded as a representation relating to the products or services concerned. The products, their specifications, services and other
information appearing in this publication are subject to change by Zarlink without notice. No warranty or guarantee express or implied is made regarding the
capability, performance or suitability of any product or service. Information concerning possible methods of use is provided as a guide only and does not constitute
any guarantee that such methods of use will be satisfactory in a specific piece of equipment. It is the user’s responsibility to fully determine the performance and
suitability of any equipment using such information and to ensure that any publication or data used is up to date and has not been superseded. Manufacturing does
not necessarily include testing of all functions or parameters. These products are not suitable for use in any medical products whose failure to perform may result in
significant injury or death to the user. All products and materials are sold and services provided subject to Zarlink’s conditions of sale which are available on request.
Purchase of Zarlink’s I2C components conveys a licence under the Philips I2C Patent rights to use these components in and I2C System, provided that the system
conforms to the I2C Standard Specification as defined by Philips.
Zarlink, ZL and the Zarlink Semiconductor logo are trademarks of Zarlink Semiconductor Inc.
Copyright Zarlink Semiconductor Inc. All Rights Reserved.
TECHNICAL DOCUMENTATION - NOT FOR RESALE
