S-57GD S Series
www.ablic.com
AUTOMOTIVE, 150°C OPERATION,
HIGH-WITHSTAND VOLTAGE, HIGH-SPEED,
OMNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC
Rev.1.3_00
© ABLIC Inc., 2019-2021
This IC, developed by CMOS technology, is a high-accuracy Hall effect switch IC that operates with high temperature and
high-withstand voltage.
The output voltage level changes when this IC detects the intensity level of magnetic flux density. Using this IC with a
magnet makes it possible to detect the open / close in various devices.
ABLIC Inc. offers a "magnetic simulation service" that provides the ideal combination of magnets and our Hall effect ICs
for customer systems. Our magnetic simulation service will reduce prototype production, development period and
development costs. In addition, it will contribute to optimization of parts to realize high cost performance.
For more information regarding our magnetic simulation service, contact our sales representatives.
ABLIC Inc. offers FIT rate calculated based on actual customer usage conditions in order to support customer functional
safety design.
For more information regarding our FIT rate calculation, contact our sales representatives.
Caution
This product can be used in vehicle equipment and in-vehicle equipment. Before using the product for
these purposes, it is imperative to contact our sales representatives.
Features
• Uses a thin (t0.80 mm max.) TSOT-23-3S or ultra-thin (t0.50 mm max.) HSNT-6(2025) package, contributing to the
enhancement of the designs of devices
• Contributes to accurate mechanism operation with high-accuracy magnetic characteristics (Refer to " Magnetic
Characteristics" for details.)
• Suitable for devices which require high quality due to the production system of this IC which certifies automotive
application quality
• Contributes to device safe design with a built-in reverse voltage protection circuit and output current limit circuit
Specifications
• Pole detection:
• Output logic*1:
• Output form*1:
• Magnetic sensitivity*1:
Applications
Omnipolar detection
Active "L"
Active "H"
Nch open-drain output
Nch driver + built-in pull-up resistor (1.2 kΩ typ.)
BOP = 3.0 mT typ.
BOP = 6.0 mT typ.
BOP = 10.0 mT typ.
BOP = 15.0 mT typ.
fC = 500 kHz typ.
tD = 16.0 μs typ.
VDD = 2.7 V to 26.0 V
• Chopping frequency:
• Output delay time:
• Power supply voltage range*2:
• Built-in regulator
• Built-in reverse voltage protection circuit
• Built-in output current limit circuit
• Operation temperature range:
Ta = −40°C to +150°C
• Lead-free (Sn 100%), halogen-free
• AEC-Q100 qualified*3
• Automobile equipment
• Housing equipment
• Industrial equipment
Packages
• TSOT-23-3S
• HSNT-6(2025)
*1. The option can be selected.
*2. VDD = 2.7 V to 5.5 V when output form is Nch driver + built-in pull-up resistor (1.2 kΩ typ.)
*3. Contact our sales representatives for details.
1
AUTOMOTIVE, 150°C OPERATION, HIGH-WITHSTAND VOLTAGE, HIGH-SPEED, OMNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC
S-57GD S Series
Rev.1.3_00
Block Diagrams
1.
Nch open-drain output product
VDD
Reverse voltage
protection circuit
Regulator
OUT
Chopper
stabilized
amplifier
*1
Output current limit circuit
VSS
*1.
Parasitic diode
Figure 1
2.
Nch driver + built-in pull-up resistor product
VDD
Reverse voltage
protection circuit
Regulator
Chopper
stabilized
amplifier
*1
VSS
*1.
Parasitic diode
Figure 2
2
OUT
Rev.1.3_00
S-57GD S Series
AEC-Q100 Qualified
This IC supports AEC-Q100 for operation temperature grade 0.
Contact our sales representatives for details of AEC-Q100 reliability specification.
Product Name Structure
1.
Product name
S-57GD
x
x x S
xxxx
U
Environmental code
U: Lead-free (Sn 100%), halogen-free
Package abbreviation and IC packing specifications*1
L3T2: TSOT-23-3S, Tape
A6T8: HSNT-6(2025), Tape
S: Ta = −40°C to +150°C
1: BOP = 3.0 mT typ.
3: BOP = 6.0 mT typ.
4: BOP = 10.0 mT typ.
5: BOP = 15.0 mT typ.
Output logic
L: Active "L"
H: Active "H"
Output form
N: Nch open-drain output
1: Nch driver + built-in pull-up resistor (1.2 kΩ typ.)
*1.
2.
Refer to the tape drawing.
Packages
Table 1
Package Name
TSOT-23-3S
HSNT-6(2025)
Package Drawing Codes
Dimension
Tape
Reel
MP003-E-P-SD
PJ006-B-P-SD
MP003-E-C-SD
PJ006-B-C-SD
MP003-E-R-SD
PJ006-B-R-SD
Land
PJ006-B-LM-SD
Stencil Opening
PJ006-B-LM-SD
3
S-57GD S Series
Rev.1.3_00
3.
Product name list
3. 1
TSOT-23-3S
Table 2
Product Name
Output Form
Power Supply
Voltage Range
Output Logic
S-57GDNL1S-L3T2U Nch open-drain output
VDD = 2.7 V to 26.0 V Active "L"
S-57GDNL3S-L3T2U Nch open-drain output
S-57GDNL5S-L3T2U Nch open-drain output
Remark Please contact our sales representatives for products other than the above.
3. 2
Magnetic
Sensitivity (BOP)
3.0 mT typ.
6.0 mT typ.
15.0 mT typ.
HSNT-6(2025)
Table 3
Product Name
Output Form
Power Supply
Voltage Range
Output Logic
S-57GDNL1S-A6T8U Nch open-drain output
S-57GDNL3S-A6T8U Nch open-drain output
S-57GDNL5S-A6T8U Nch open-drain output
4
Magnetic
Sensitivity (BOP)
3.0 mT typ.
6.0 mT typ.
15.0 mT typ.
Rev.1.3_00
S-57GD S Series
Pin Configurations
1.
TSOT-23-3S
Top view
Table 4
1
Pin No.
1
2
3
2
Symbol
Description
GND pin
Power supply pin
Output pin
VSS
VDD
OUT
3
Figure 3
2.
HSNT-6(2025)
Top view
1
2
3
Table5
6
5
4
Bottom view
6
5
4
1
2
3
Pin No.
1
2
3
4
5
6
Symbol
VDD
NC*2
OUT
NC*2
VSS
NC*2
Description
Power supply pin
No connection
Output pin
No connection
GND pin
No connection
*1
Figure 4
*1. Connect the heatsink of backside at shadowed area to the board, and set electric potential open or GND.
However, do not use it as the function of electrode.
*2. The NC pin is electrically open.
The NC pin can be connected to the VDD pin or the VSS pin.
5
S-57GD S Series
Rev.1.3_00
Absolute Maximum Ratings
Table 6
Item
Symbol
(1.2 kΩ typ.) product
VDD
Power supply current
Output current
IDD
IOUT
Output voltage
VOUT
Junction temperature
Operation ambient temperature
Storage temperature
Caution
Tj
Topr
Tstg
VSS − 28.0 to VSS + 28.0
Unit
VSS − 9.0 to VSS + 9.0
V
±10
±10
VSS − 0.3 to VSS + 28.0
mA
mA
V
VSS − 0.3 to VDD + 0.3
V
−40 to +170
−40 to +150
−40 to +170
°C
°C
°C
V
The absolute maximum ratings are rated values exceeding which the product could suffer
physical damage. These values must therefore not be exceeded under any conditions.
Thermal Resistance Value
Table 7
Item
Symbol
Condition
TSOT-23-3S
Junction-to-ambient thermal resistance*1 θJA
HSNT-6(2025)
*1. Test environment: compliance with JEDEC STANDARD JESD51-2A
Remark
6
Refer to " Power Dissipation" and "Test Board" for details.
Board A
Board B
Board C
Board D
Board E
Board A
Board B
Board C
Board D
Board E
Min.
Typ.
225
190
180
128
43
44
36
Max.
Unit
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
Rev.1.3_00
S-57GD S Series
Electrical Characteristics
1.
Table 8
(Ta = −40°C to +150°C, VDD = 2.7 V to 26.0 V, VSS = 0 V unless otherwise specified)
Item
Current consumption
Current consumption
during reverse connection
Low level output voltage
Leakage current
Output limit current
Output delay time*2
Chopping frequency*2
Start up time*2
Output rise time*2
Output fall time*2
*1.
*2.
2.
Symbol
Condition
Min.
Typ.*1
Max.
Unit
2.7
12.0
4.0
26.0
4.5
V
mA
Test
Circuit
1
−0.1
mA
1
11
250
16
500
25
0.4
10
35
32
40
1.0
1.0
V
μA
mA
μs
kHz
μs
μs
μs
2
3
3
4
5
5
VDD
IDD
VDD = −26.0 V
IDDREV
VOL
IOUT = 5 mA, VOUT = "L"
ILEAK
VOUT = "H"
IOM
VOUT = 12.0 V
tD
fC
tPON
C = 20 pF, R = 820 Ω
tR
tF
Typ. value when Ta = +25°C, VDD = 12.0 V.
This item is guaranteed by design.
Nch driver + built-in pull-up resistor (1.2 kΩ typ.) product
Table 9
(Ta = −40°C to +150°C, VDD = 2.7 V to 5.5 V, VSS = 0 V unless otherwise specified)
Item
Symbol
Condition
VDD
Current consumption
IDD
VOUT = "H"
VOL
IOUT = 0 mA, VOUT = "L"
High level output voltage
VOH
IOUT = 0 mA, VOUT = "H"
IOM
VDD = VOUT = 5.0 V
Output delay time*2
tD
fC
Start up time*2
tPON
Output rise time*2
tR
C = 20 pF
Output fall time*2
tF
C = 20 pF
Pull-up resistor
RL
*1. Typ. value when Ta = +25°C, VDD = 5.0 V.
*2. This item is guaranteed by design.
Caution
Min.
Typ.*1
Max.
Unit
2.7
VDD × 0.9
11
250
0.9
5.0
4.0
16
500
25
1.2
5.5
4.5
0.4
35
32
40
1.0
1.0
1.5
V
mA
V
V
mA
μs
kHz
μs
μs
μs
kΩ
Test
Circuit
1
2
2
3
4
5
5
Due to limitation of the power dissipation, these values may not be satisfied. Attention should be paid
to the power dissipation when using in high temperature operation environments.
7
S-57GD S Series
Rev.1.3_00
S pole
Magnetic flux
density applied
to this IC (B)
BOPS
BRPS
BRPN
BOPN
N pole
tD
tD
tD
tF
tD
tF
tR
tR
90%
Output voltage (VOUT)
(Active "L" product)
10%
tD
tD
tR
90%
(Active "H" product)
10%
Figure 5 Operation Timing
8
tD
tD
tF
tR
tF
Rev.1.3_00
S-57GD S Series
Magnetic Characteristics
1.
TSOT-23-3S
1. 1
Product with BOP = 3.0 mT typ.
1. 1. 1
Ta = +25°C
Table 10
Item
Operation point*1
Release point*2
Hysteresis width*3
1. 1. 2
S pole
N pole
S pole
N pole
S pole
N pole
Symbol
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Condition
BHYSS = BOPS − BRPS
BHYSN = |BOPN − BRPN|
(VDD = 5.0 V, VSS = 0 V unless otherwise specified)
Min.
Typ.
Max.
Unit
Test Circuit
2.0
3.0
4.3
mT
4
−4.3
−3.0
−2.0
mT
4
1.2
2.2
3.2
mT
4
−3.2
−2.2
−1.2
mT
4
0.8
mT
4
0.8
mT
4
Ta = −40°C to +150°C*4
Table 11
(VDD = 2.7 V to 26.0 V, VSS = 0 V unless otherwise specified)
Item
Operation point*1
Release point*2
Hysteresis width*3
1. 2
S pole
N pole
S pole
N pole
S pole
N pole
Symbol
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Condition
BHYSS = BOPS − BRPS
Min.
1.5
−6.0
0.5
−4.5
Typ.
3.0
−3.0
2.2
−2.2
0.8
0.8
Max.
6.0
−1.5
4.5
−0.5
Unit
mT
mT
mT
mT
mT
mT
Test Circuit
4
4
4
4
4
4
Product with BOP = 6.0 mT typ.
1. 2. 1
Ta = +25°C
Table 12
Item
Operation point*1
Release point*2
Hysteresis width*3
1. 2. 2
S pole
N pole
S pole
N pole
S pole
N pole
Symbol
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Condition
BHYSS = BOPS − BRPS
Min.
Typ.
Max.
Unit
Test Circuit
4.0
6.0
8.0
mT
4
−8.0
−6.0
−4.0
mT
4
3.0
4.5
6.0
mT
4
−6.0
−4.5
−3.0
mT
4
1.5
mT
4
1.5
mT
4
Item
Operation point*1
Release point*2
Hysteresis width*3
S pole
N pole
S pole
N pole
S pole
N pole
Symbol
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Table 13
Condition
Min.
Typ.
Max.
Unit
Test Circuit
3.0
6.0
9.0
mT
4
−9.0
−6.0
−3.0
mT
4
2.0
4.5
7.0
mT
4
−7.0
−4.5
−2.0
mT
4
BHYSS = BOPS − BRPS
1.5
mT
4
1.5
mT
4
9
S-57GD S Series
Rev.1.3_00
1. 3
Product with BOP = 10.0 mT typ.
1. 3. 1
Ta = +25°C
Table 14
Item
Operation point*1
Release point*2
Hysteresis width*3
1. 3. 2
Symbol
S pole
N pole
S pole
N pole
S pole
N pole
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Condition
BHYSS = BOPS − BRPS
Min.
Typ.
Max.
Unit
Test Circuit
7.2
10.0
12.6
mT
4
−12.6
−10.0
−7.2
mT
4
5.2
7.5
9.8
mT
4
−9.8
−7.5
−5.2
mT
4
2.5
mT
4
2.5
mT
4
Table 15
Item
Operation point*1
Release point*2
Hysteresis width*3
1. 4
S pole
N pole
S pole
N pole
S pole
N pole
Symbol
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Condition
BHYSS = BOPS − BRPS
Min.
5.6
−13.8
4.0
−10.8
Typ.
10.0
−10.0
7.5
−7.5
2.5
2.5
Max.
13.8
−5.6
10.8
−4.0
Unit
mT
mT
mT
mT
mT
mT
Test Circuit
4
4
4
4
4
4
Product with BOP = 15.0 mT typ.
1. 4. 1
Ta = +25°C
Table 16
Item
Operation point*1
Release point*2
Hysteresis width*3
1. 4. 2
Symbol
S pole
N pole
S pole
N pole
S pole
N pole
Condition
BHYSS = BOPS − BRPS
Item
Operation point*1
Release point*2
Hysteresis width*3
10
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Min.
Typ.
Max.
Unit
Test Circuit
11.2
15.0
19.2
mT
4
−19.2
−15.0
−11.2
mT
4
8.4
12.0
15.0
mT
4
−15.0
−12.0
−8.4
mT
4
3.0
mT
4
3.0
mT
4
S pole
N pole
S pole
N pole
S pole
N pole
Symbol
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Table 17
Condition
Min.
Typ.
Max.
Unit
Test Circuit
8.8
15.0
21.4
mT
4
−21.4
−15.0
−8.8
mT
4
6.8
12.0
16.8
mT
4
−16.8
−12.0
−6.8
mT
4
BHYSS = BOPS − BRPS
3.0
mT
4
3.0
mT
4
Rev.1.3_00
S-57GD S Series
2.
HSNT-6(2025)
2. 1
2. 1. 1
Ta = +25°C
Table 18
Item
Operation point*1
Release point*2
Hysteresis width*3
2. 1. 2
Symbol
S pole
N pole
S pole
N pole
S pole
N pole
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Condition
BHYSS = BOPS − BRPS
Min.
Typ.
Max.
Unit
Test Circuit
1.7
3.0
4.7
mT
4
−4.7
−3.0
−1.7
mT
4
0.7
2.2
3.6
mT
4
−3.6
−2.2
−0.7
mT
4
0.8
mT
4
0.8
mT
4
Table 19
Item
Operation point*1
Release point*2
Hysteresis width*3
2. 2
S pole
N pole
S pole
N pole
S pole
N pole
Symbol
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Condition
BHYSS = BOPS − BRPS
Min.
1.0
−6.2
0.2
−5.0
Typ.
3.0
−3.0
2.2
−2.2
0.8
0.8
Max.
6.2
−1.0
5.0
−0.2
Unit
mT
mT
mT
mT
mT
mT
Test Circuit
4
4
4
4
4
4
2. 2. 1
Ta = +25°C
Table 20
Item
Operation point*1
Release point*2
Hysteresis width*3
2. 2. 2
Symbol
S pole
N pole
S pole
N pole
S pole
N pole
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Condition
BHYSS = BOPS − BRPS
Min.
Typ.
Max.
Unit
Test Circuit
3.7
6.0
8.3
mT
4
−8.3
−6.0
−3.7
mT
4
2.5
4.5
6.5
mT
4
−6.5
−4.5
−2.5
mT
4
1.5
mT
4
1.5
mT
4
Item
Operation point*1
Release point*2
Hysteresis width*3
S pole
N pole
S pole
N pole
S pole
N pole
Symbol
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Table 21
Condition
Min.
Typ.
Max.
Unit
Test Circuit
2.9
6.0
9.1
mT
4
−9.1
−6.0
−2.9
mT
4
1.7
4.5
7.3
mT
4
−7.3
−4.5
−1.7
mT
4
BHYSS = BOPS − BRPS
1.5
mT
4
1.5
mT
4
11
S-57GD S Series
Rev.1.3_00
2. 3
2. 3. 1
Ta = +25°C
Table 22
Item
Operation point*1
Release point*2
Hysteresis width*3
2. 3. 2
Symbol
S pole
N pole
S pole
N pole
S pole
N pole
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Condition
BHYSS = BOPS − BRPS
Min.
Typ.
Max.
Unit
Test Circuit
7.4
10.0
13.1
mT
4
−13.1
−10.0
−7.4
mT
4
5.1
7.5
10.1
mT
4
−10.1
−7.5
−5.1
mT
4
2.5
mT
4
2.5
mT
4
Table 23
Item
Operation point*1
Release point*2
Hysteresis width*3
2. 4
S pole
N pole
S pole
N pole
S pole
N pole
Symbol
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Condition
BHYSS = BOPS − BRPS
Min.
3.8
−16.1
2.7
−12.5
Typ.
10.0
−10.0
7.5
−7.5
2.5
2.5
Max.
16.1
−3.8
12.5
−2.7
Unit
mT
mT
mT
mT
mT
mT
Test Circuit
4
4
4
4
4
4
2. 4. 1
Ta = +25°C
Table 24
Item
Operation point*1
Release point*2
Hysteresis width*3
2. 4. 2
Symbol
S pole
N pole
S pole
N pole
S pole
N pole
Condition
BHYSS = BOPS − BRPS
Item
Operation point*1
Release point*2
Hysteresis width*3
12
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Min.
Typ.
Max.
Unit
Test Circuit
10.6
15.0
19.9
mT
4
−19.9
−15.0
−10.6
mT
4
8.1
12.0
15.8
mT
4
−15.8
−12.0
−8.1
mT
4
3.0
mT
4
3.0
mT
4
S pole
N pole
S pole
N pole
S pole
N pole
Symbol
BOPS
BOPN
BRPS
BRPN
BHYSS
BHYSN
Table 25
Condition
Min.
Typ.
Max.
Unit
Test Circuit
6.4
15.0
23.5
mT
4
−23.5
−15.0
−6.4
mT
4
4.6
12.0
19.6
mT
4
−19.6
−12.0
−4.6
mT
4
BHYSS = BOPS − BRPS
3.0
mT
4
3.0
mT
4
Rev.1.3_00
S-57GD S Series
*1.
*2.
*3.
*4.
BOPN, BOPS: Operation points
BOPN and BOPS are the values of magnetic flux density when the output voltage (VOUT) changes after the magnetic
flux density applied to this IC by the magnet (N pole or S pole) is increased (by moving the magnet closer).
Even when the magnetic flux density exceeds BOPN or BOPS, VOUT retains the status.
BRPN, BRPS: Release points
BRPN and BRPS are the values of magnetic flux density when the output voltage (VOUT) changes after the magnetic
flux density applied to this IC by the magnet (N pole or S pole) is decreased (the magnet is moved further away).
Even when the magnetic flux density falls below BRPN or BRPS, VOUT retains the status.
BHYSN, BHYSS: Hysteresis widths
BHYSN and BHYSS are the difference between BOPN and BRPN, and BOPS and BRPS, respectively.
Caution Due to limitation of the power dissipation, these values may not be satisfied. Attention should be paid
Remark
The unit of magnetic density mT can be converted by using the formula 1 mT = 10 Gauss.
13
S-57GD S Series
Rev.1.3_00
Test Circuits
A
R*1
820 Ω
VDD
VDD
OUT
OUT
VSS
V
VSS
*1.
Resistor (R) is unnecessary for Nch driver +
built-in pull-up resistor product.
Figure 6
Figure 7
Test Circuit 1
VSS
VSS
V
*1.
Test Circuit 3
OUT
VSS
V
Figure 10
14
C
20 pF
Test Circuit 5
V
Figure 9
R*1
820 Ω
VDD
R*1
820 Ω
OUT
A
OUT
Figure 8
Test Circuit 2
VDD
VDD
*1.
A
Test Circuit 4
Rev.1.3_00
S-57GD S Series
Standard Circuit
VDD
CIN
0.1 μF
*1.
R*1
820 Ω
OUT
VSS
Resistor (R) is unnecessary for Nch driver + built-in pull-up resistor product.
Figure 11
Caution The above connection diagram and constants will not guarantee successful operation. Perform
thorough evaluation using the actual application to set the constants.
15
S-57GD S Series
Rev.1.3_00
Operation
1.
Direction of applied magnetic flux
This IC detects the magnetic flux density which is perpendicular to the package marking surface. A magnetic field is
defined as positive when marking side of the package is the S pole, and negative when it is the N pole.
Figure 12 and Figure 13 show polarity in a magnetic field and direction in which magnetic flux is being applied.
1. 1
TSOT-23-3S
1. 2
HSNT-6(2025)
N
S
N
S
Marking surface
Marking surface
Figure 12
2.
Figure 13
Position of Hall sensor
Figure 14 and Figure 15 show the position of Hall sensor.
The center of this Hall sensor is located in the area indicated by a circle, which is in the center of a package as
described below.
The following also shows the distance (typ. value) between the marking surface and the chip surface of a package.
2. 1
TSOT-23-3S
2. 2
HSNT-6(2025)
Top view
2
The center of Hall
sensor, in this φ0.3 mm
1
6
2
5
3
4
3
0.22 mm (typ.)
Figure 14
16
Top view
The center of Hall sensor,
in this φ0.3 mm
1
0.16 mm (typ.)
Figure 15
Rev.1.3_00
S-57GD S Series
3.
Basic operation
This IC changes the output voltage (VOUT) according to the level of the magnetic flux density (N pole or S pole)
applied by a magnet.
3. 1
Active "L" product
When the magnetic flux density perpendicular to the marking surface exceeds the operation point (BOPN or BOPS)
after the S pole or N pole of a magnet is moved closer to the marking surface of this IC, VOUT changes from "H" to
"L". When the S pole or N pole of a magnet is moved further away from the marking surface of this IC and the
magnetic flux density is lower than the release point (BRPN or BRPS), VOUT changes from "L" to "H".
Figure 16 shows the relationship between the magnetic flux density and VOUT.
VOUT
BHYSN
BHYSS
H
L
N pole
BOPN
BRPN
BRPS
BOPS
S pole
Magnetic flux density (B)
Figure 16
3. 2
Active "H" product
after the S pole or N pole of a magnet is moved closer to the marking surface of this IC, VOUT changes from "L" to
"H". When the S pole or N pole of a magnet is moved further away from the marking surface of this IC and the
magnetic flux density is lower than the release point (BRPN or BRPS), VOUT changes from "H" to "L".
Figure 17 shows the relationship between the magnetic flux density and VOUT.
VOUT
BHYSN
BHYSS
H
L
N pole
BOPN
BRPN
BRPS
BOPS
S pole
Figure 17
17
S-57GD S Series
Rev.1.3_00
4.
Power-on operation
The output voltage (VOUT) of this IC immediately after power-on is "H". After the start up time (tPON) is passed, the IC
changes VOUT according to the level of the magnetic flux density (N pole or S pole) applied by a magnet.
4. 1
Active "L" product
Figure 18 shows the timing chart at power-on for active "L" product.
The initial output voltage at rising of power supply voltage (VDD) is "H".
In case of B > BOPS or B < BOPN at the time when tPON is passed after rising of VDD, VOUT changes from "H" to "L".
In case of BOPN < B < BOPS at the time when tPON is passed after rising of VDD, VOUT retains "H".
(VDD)
tPON
(B > BOPS or B < BOPN)
"H"
(BOPN < B < BOPS)
"H"
"L"
Latching
Figure 18
4. 2
Active "H" product
Figure 19 shows the timing chart at power-on for active "H" product.
In case of B > BOPS or B < BOPN at the time when tPON is passed after rising of VDD, VOUT retains "H".
In case of BOPN < B < BOPS at the time when tPON is passed after rising of VDD, VOUT changes from "H" to "L".
(VDD)
tPON
"H"
(BOPN < B < BOPS)
"H"
Figure 19
18
Latching
"L"
Rev.1.3_00
S-57GD S Series
Precautions
• If the impedance of the power supply is high, the IC may malfunction due to a supply voltage drop caused by
feed-through current. Take care with the pattern wiring to ensure that the impedance of the power supply is low.
• Note that the IC may malfunction if the power supply voltage rapidly changes. When the IC is used under the
environment where the power supply voltage rapidly changes, it is recommended to judge the output voltage of
the IC by reading it multiple times.
• Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic
protection circuit.
• Note that the output voltage may rarely change if the magnetic flux density between the operation point and the
release point is applied to this IC continuously for a long time.
• Although this IC has a built-in output current limit circuit, it may suffer physical damage such as product
deterioration under the environment where the absolute maximum ratings are exceeded.
• Although this IC has a built-in reverse voltage protection circuit, it may suffer physical damage such as product
• The application conditions for the power supply voltage, the pull-up voltage, and the pull-up resistor should not
exceed the power dissipation.
• Large stress on this IC may affect the magnetic characteristics. Avoid large stress which is caused by the
handling during or after mounting the IC on a board.
• Since the package heat radiation differs according to the conditions of the application, perform thorough
evaluation with actual applications to confirm no problems occur.
• ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by
products including this IC of patents owned by a third party.
19
S-57GD S Series
Rev.1.3_00
Characteristics (Typical Data)
1. 1
S-57GDxxxS
1. 1. 1
Current consumption (IDD)
vs. Temperature (Ta)
VOUT = "H"
6.0
5.0
IDD [mA]
1. 1. 2
VDD = 5.5 V
3.0
2.0
VDD = 2.7 V
VDD = 12.0 V
1.0
0.0
−40 −25
1. 1. 3
2.0
1. 1. 4
VDD = 26.0 V
Ta = +150°C
10
15
VDD [V]
25
30
Output delay time (tD)
vs. Power supply voltage (VDD)
VDD = 5.5 V
tD [μs]
tD [μs]
3.0
40
10
Caution
VDD = 12.0 V
Ta = −40°C
VDD = 2.7 V
−40 −25
50 75 100 125 150
Ta [°C]
Ta = +150°C
Ta = +25°C
10
15
VDD [V]
25
30
VDD = 2.7 V to 5.5 V when output form is Nch driver + built-in pull-up resistor (1.2 kΩ typ.).
Comply with power supply voltage range and do not exceed absolute maximum ratings.
S-57GDNxxS
1. 2. 1
Low level output voltage (VOL)
1. 2. 2
IOUT = 5 mA
0.6
IOUT = 5 mA
VDD = 12.0 V
VDD = 5.5 V
0.2
0.1
0.0
−40 −25
VDD = 2.7 V
VOL [V]
0.5
VDD = 26.0 V
0.4
0.3
0.6
0.5
VOL [V]
4.0
0.0
50 75 100 125 150
Ta [°C]
30
Ta = −40°C
Ta = +25°C
1.0
40
1. 2
VOUT = "H"
5.0
VDD = 26.0 V
4.0
6.0
IDD [mA]
1.
0.4
Ta = +25°C
0.3
0.2
0.1
Ta = −40°C
0.0
50 75 100 125 150
Ta [°C]
Ta = +150°C
10
15
VDD [V]
25
30
Rev.1.3_00
S-57GD S Series
1. 3
S-57GD1xxS
1. 3. 1
1. 3. 2
IOUT = 0 mA
0.6
0.5
0.2
VDD = 5.5 V
VDD = 5.0 V
VDD = 2.7 V
VOL [V]
VOL [V]
0.3
0.0
−40 −25
Ta = +150°C
Ta = +25°C
Ta = −40°C
0.3
0.2
0.0
50 75 100 125 150
Ta [°C]
High level output voltage (VOH)
2
1. 3. 4
IOUT = 0 mA
6.0
VDD = 5.0 V VDD = 5.5 V
3.0
2.0
1.0
0.0
−40 −25
VDD = 2.7 V
4
VDD [V]
5
6
IOUT = 0 mA
5.0
VOH [V]
4.0
3
6.0
5.0
VOH [V]
0.4
0.1
0.1
1. 3. 3
IOUT = 0 mA
0.6
0.5
0.4
Ta = +150°C
4.0
3.0
Ta = +25°C
Ta = −40°C
2.0
1.0
0.0
50 75 100 125 150
Ta [°C]
2
3
4
VDD [V]
5
6
21
S-57GD S Series
Rev.1.3_00
S-57GDxx1S-L3T2U
2. 1. 1
Operation point, release point (BOP, BRP)
BOP, BRP [mT]
6.0
4.0
2.0
0.0
−2.0
−4.0
BOPS
BRPS
BRPN
BOP, BRP [mT]
5.5 V
VDD = 12.0 V
12.0 V
12.0 V
5.5 V
Ta = +25°C
6.0
12.0 V
2.0
BRPS
BRPN
0.0
−2.0
−4.0
−6.0
50 75 100 125 150
Ta [°C]
BOPS
4.0
BOPN
10
15
VDD [V]
25
30
S-57GDxx3S-L3T2U
2. 2. 1
10.0
VDD = 12.0 V
7.5 BOPS VDD = 5.5 V
5.0
2.5 BRPS
12.0 V
5.5 V
0.0 BRPN
12.0 V
5.5
V
−2.5
−5.0
−7.5 BOPN
5.5 V
12.0 V
−10.0
−40 −25 0
25 50 75 100 125 150
Ta [°C]
Caution
22
5.5 V
BOPN
−6.0
−40 −25
2. 2
VDD = 5.5 V
2. 1. 2 Operation point, release point (BOP, BRP)
BOP, BRP [mT]
2. 1
2. 2. 2 Operation point, release point (BOP, BRP)
BOP, BRP [mT]
2.
10.0
7.5
5.0
2.5
0.0
−2.5
−5.0
−7.5
−10.0
Ta = +25°C
BOPS
BRPS
BRPN
BOPN
10
15
VDD [V]
25
30
Rev.1.3_00
S-57GD S Series
S-57GDxx4S-L3T2U
BOP, BRP [mT]
13.5
9.0
4.5
0.0
−4.5
BOPS
BRPS
12.0 V
VDD = 12.0 V
5.5 V
VDD = 5.5 V
5.5 V
5.5 V
12.0 V
12.0 V
BRPN
−9.0
25
BRPS
4.5
0.0
−4.5
BRPN
−9.0
−13.5
50 75 100 125 150
Ta [°C]
BOPS
9.0
BOPN
10
15
VDD [V]
25
30
S-57GDxx5S-L3T2U
2. 4. 1
21.0
BOP, BRP [mT]
Ta = +25°C
13.5
B OPN
−13.5
−40 −25 0
2. 4
2. 3. 2 Operation point, release point (BOP, BRP)
BOP, BRP [mT]
2. 3. 1
14.0
7.0
BRPS
BRPN
VDD = 12.0 V
VDD = 5.5 V
5.5 V
12.0 V
12.0 V
5.5 V
5.5 V
12.0 V
−14.0
B OPN
−21.0
−40 −25 0
Caution
Ta = +25°C
21.0
BOPS
0.0
−7.0
2. 4. 2 Operation point, release point (BOP, BRP)
25
50 75 100 125 150
Ta [°C]
BOP, BRP [mT]
2. 3
BOPS
14.0
BRPS
7.0
0.0
−7.0
BRPN
−14.0
−21.0
BOPN
10
15
VDD [V]
25
30
23
S-57GD S Series
Rev.1.3_00
S-57GDxx1S-A6T8U
BOP, BRP [mT]
6.0
4.0
2.0
0.0
−2.0
−4.0
VDD = 26.0 V
BOPS
BRPS
BRPN
B OPN
−6.0
−40 −25
2. 6
BOP, BRP [mT]
VDD = 5.5 V
VDD = 12.0 V
VDD = 2.7 V
26.0 V 12.0 V 5.5 V 2.7 V
Ta = +25°C
6.0
4.0
2.0
BRPS
0.0
BRPN
−2.0
BOPN
−4.0
−6.0
50 75 100 125 150
Ta [°C]
BOPS
10
15
VDD [V]
25
30
S-57GDxx3S-A6T8U
2. 6. 1
10.0
VDD = 26.0 V VDD = 5.5 V
7.5 BOPS
5.0
2.5 BRPS
VDD = 2.7 V
VDD = 12.0 V
0.0
−2.5 BRPN
−5.0
−7.5 BOPN 26.0 V
12.0 V 5.5 V 2.7 V
−10.0
−40 −25 0
Ta [°C]
Caution
24
2. 5. 2 Operation point, release point (BOP, BRP)
BOP, BRP [mT]
2. 5. 1
2. 6. 2 Operation point, release point (BOP, BRP)
BOP, BRP [mT]
2. 5
10.0
7.5
5.0
2.5
0.0
−2.5
−5.0
−7.5
−10.0
Ta = +25°C
BOPS
BRPS
BRPN
BOPN
10
15
VDD [V]
25
30
Rev.1.3_00
S-57GD S Series
S-57GDxx4S-A6T8U
BOP, BRP [mT]
13.5
9.0
4.5
0.0
−4.5
BOPS
BRPS
VDD = 12.0 V
VDD = 26.0 V VDD =
BRPN
VDD = 2.7 V
26.0 V 12.0 V 5.5 V
2.7 V
−9.0
25
BRPS
4.5
0.0
−4.5
BRPN
−9.0
−13.5
50 75 100 125 150
Ta [°C]
BOPS
9.0
BOPN
10
15
VDD [V]
25
30
S-57GDxx5S-A6T8U
2. 8. 1
21.0
BOP, BRP [mT]
Ta = +25°C
13.5
BOPN
−13.5
−40 −25 0
2. 8
2. 7. 2 Operation point, release point (BOP, BRP)
BOP, BRP [mT]
2. 7. 1
14.0
7.0
BOPS
BRPS
0.0
−7.0
BRPN
Ta = +25°C
21.0
VDD = 2.7 V
VDD = 12.0 V
VDD = 5.5 V
VDD = 26.0 V
−14.0
BOPN
−21.0
-40 -25 0
Caution
2. 8. 2 Operation point, release point (BOP, BRP)
25
50 75 100 125 150
Ta [°C]
BOP, BRP [mT]
2. 7
BOPS
14.0
BRPS
7.0
0.0
−7.0
BRPN
−14.0
−21.0
BOPN
10
15
VDD [V]
25
30
25
S-57GD S Series
Rev.1.3_00
Power Dissipation
HSNT-6(2025)
TSOT-23-3S
Tj = +170°C max.
4
3
2
1 B
Tj = +170°C max.
5
Power dissipation (PD) [W]
5
E
4
C
3 D
2
B
1
A
A
50
75
100
125
150
175
Ambient temperature (Ta) [°C]
Board
A
B
C
D
E
26
Power Dissipation (PD)
0.64 W
0.76 W
50
75
100
125
150
175
Board
A
B
C
D
E
0.81 W
1.13 W
3.37 W
3.30 W
4.03 W
TSOT-23-3S Test Board
IC Mount Area
(1) Board A
Item
Size [mm]
Material
Number of copper foil layer
Copper foil layer [mm]
1
2
3
4
Thermal via
Specification
114.3 x 76.2 x t1.6
FR-4
2
Land pattern and wiring for testing: t0.070
74.2 x 74.2 x t0.070
(2) Board B
Item
Size [mm]
Material
Thermal via
1
2
3
4
Specification
114.3 x 76.2 x t1.6
FR-4
4
74.2 x 74.2 x t0.035
No. TSOT23x-A-Board-SD-1.0
ABLIC Inc.
HSNT-6(2025) Test Board
IC Mount Area
(1) Board A
Item
Size [mm]
Material
1
2
3
4
Thermal via
Specification
114.3 x 76.2 x t1.6
FR-4
2
(2) Board B
Item
Size [mm]
Material
1
2
3
4
Thermal via
Specification
114.3 x 76.2 x t1.6
FR-4
4
(3) Board C
Item
Size [mm]
Material
Thermal via
1
2
3
4
Specification
114.3 x 76.2 x t1.6
FR-4
4
Number: 4
Diameter: 0.3 mm
No. HSNT6-B-Board-SD-1.0
enlarged view
ABLIC Inc.
IC Mount Area
(4) Board D
Item
Size [mm]
Material
1
2
3
4
Thermal via
Specification
114.3 x 76.2 x t1.6
FR-4
4
2
Pattern for heat radiation: 2000mm t0.070
enlarged view
(5) Board E
Item
Size [mm]
Material
Thermal via
1
2
3
4
Specification
114.3 x 76.2 x t1.6
FR-4
4
2
Number: 4
Diameter: 0.3 mm
enlarged view
ABLIC Inc.
2.9±0.2
1
2
3
0.16
0.95±0.1
+0.1
-0.06
1.9±0.2
0.42±0.1
No. MP003-E-P-SD-1.0
TITLE
TSOT233S-A-PKG Dimensions
No.
MP003-E-P-SD-1.0
ANGLE
UNIT
mm
ABLIC Inc.
ø1.5
+0.1
-0
4.0±0.1
2.0±0.05
ø1.0
+0.1
-0
0.25±0.1
(0.4)
4.0±0.1
0.95±0.2
3.23±0.2
(1.0)
1
2
3
Feed direction
No. MP003-E-C-SD-1.0
TITLE
TSOT233S-A-Carrier Tape
No.
MP003-E-C-SD-1.0
ANGLE
UNIT
mm
ABLIC Inc.
9.0
+1.0
- 0.0
11.4±1.0
Enlarged drawing in the central part
ø13±0.2
(60°)
(60°)
No. MP003-E-R-SD-1.0
TITLE
TSOT233S-A-Reel
No.
MP003-E-R-SD-1.0
ANGLE
QTY.
UNIT
mm
ABLIC Inc.
3,000
1.96±0.05
1.78±0.1
6
5
0.5
1
4
2
3
0.5
0.5
0.12±0.04
0.48±0.02
0.22±0.05
The heat sink of back side has different electric
potential depending on the product.
Confirm specifications of each product.
Do not use it as the function of electrode.
No. PJ006-B-P-SD-1.0
TITLE
HSNT-6-C-PKG Dimensions
No.
PJ006-B-P-SD-1.0
ANGLE
UNIT
mm
ABLIC Inc.
ø1.5
+0.1
-0
2.0±0.05
4.0±0.1
ø0.5±0.1
0.25±0.05
0.65±0.05
4.0±0.1
2.25±0.05
3 21
0.5
0.5
0.5
0.5
0.5
0.5
4 5 6
Feed direction
No. PJ006-B-C-SD-1.0
TITLE
HSNT-6-C-Carrier Tape
No.
PJ006-B-C-SD-1.0
ANGLE
UNIT
mm
ABLIC Inc.
9.0
+1.0
- 0.0
11.4±1.0
ø13±0.2
(60°)
(60°)
No. PJ006-B-R-SD-1.0
TITLE
HSNT-6-C-Reel
No.
PJ006-B-R-SD-1.0
QTY.
ANGLE
UNIT
mm
ABLIC Inc.
5,000
Land Recommendation
0.50
0.35
0.50
1.44
1.78
2.10
Caution It is recommended to solder the heat sink to a board in order to ensure the heat radiation.
PKG
Stencil Opening
1.40
0.50
0.50
No. PJ006-B-LM-SD-1.0
0.35
Caution
Mask aperture ratio of the lead mounting part is 100~120%.
Mask aperture ratio of the heat sink mounting part is 30%.
Mask thickness: t0.12 mm
Reflow atmosphere: Nitrogen atmosphere is recommended.
(Oxygen concentration: 1000ppm or less)
100~120%
30%
t0.12 mm
TITLE
HSNT-6-C
-Land &Stencil Opening
PJ006-B-LM-SD-1.0
No.
ANGLE
UNIT
mm
1000ppm
ABLIC Inc.
Disclaimers (Handling Precautions)
1.
All the information described herein (product data, specifications, figures, tables, programs, algorithms and
application circuit examples, etc.) is current as of publishing date of this document and is subject to change without
notice.
2.
The circuit examples and the usages described herein are for reference only, and do not guarantee the success of
any specific mass-production design.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products
described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other
right due to the use of the information described herein.
3.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described
herein.
4.
Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute
maximum ratings, operation voltage range and electrical characteristics, etc.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to
the use of the products outside their specified ranges.
5.
Before using the products, confirm their applications, and the laws and regulations of the region or country where they
are used and verify suitability, safety and other factors for the intended use.
6.
When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related
laws, and follow the required procedures.
7.
The products are strictly prohibited from using, providing or exporting for the purposes of the development of
weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands
caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear,
biological or chemical weapons or missiles, or use any other military purposes.
8.
The products are not designed to be used as part of any device or equipment that may affect the human body, human
life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control
systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment,
aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by
ABLIC, Inc. Do not apply the products to the above listed devices and equipments.
ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of
the products.
9.
In general, semiconductor products may fail or malfunction with some probability. The user of the products should
therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread
prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social
damage, etc. that may ensue from the products' failure or malfunction.
The entire system in which the products are used must be sufficiently evaluated and judged whether the products are
allowed to apply for the system on customer's own responsibility.
10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the
product design by the customer depending on the intended use.
11. The products do not affect human health under normal use. However, they contain chemical substances and heavy
metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be
careful when handling these with the bare hands to prevent injuries, etc.
12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used.
13. The information described herein contains copyright information and know-how of ABLIC Inc. The information
described herein does not convey any license under any intellectual property rights or any other rights belonging to
ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this
document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express
permission of ABLIC Inc.
14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales
representative.
15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into
the English language and the Chinese language, shall be controlling.
2.4-2019.07
www.ablic.com
