74HCT365DB/DG,118
74HCT365DB/DG,118
    NEXPERIA(安世)
    SSOP16
    IC BUFFER INVERT 5.5V 16SSOP
74HCT365DB/DG,118 数据手册
74HC365; 74HCT365 Hex buffer/line driver; 3-state Rev. 6 — 28 July 2021 Product data sheet 1. General description The 74HC365; 74HCT365 is a hex buffer/line driver with 3-state outputs controlled by the output enable inputs (OEn). A HIGH on OEn causes the outputs to assume a high impedance OFF-state. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • • • • • • • Wide supply voltage range from 2.0 V to 6.0 V CMOS low power dissipation High noise immunity Latch-up performance exceeds 100 mA per JESD 78 Class II Level B Complies with JEDEC standards: • JESD8C (2.7 V to 3.6 V) • JESD7A (2.0 V to 6.0 V) Non-inverting outputs Input levels: • For 74HC365: CMOS level • For 74HCT365: TTL level ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package 74HC365D Temperature range Name Description -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 Version -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm 74HCT365D 74HC365PW 74HCT365PW SOT403-1 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state 4. Functional diagram 2 4 6 10 12 14 1 15 1A 1Y 2A 2Y 3A 3Y 4A 4Y 5A 5Y 6A 6Y 3 5 7 9 11 13 1Y 2A 2Y 3A 3Y 4A 4Y 5A 5Y 6A 1 15 6Y OE1 OE1 OE2 OE2 aaa-004274 Fig. 1. 1A Functional diagram Fig. 2. 3 4 5 6 7 10 9 12 11 14 13 aaa-004276 Fig. 3. buffer/line driver 1 EN 2 aaa-004275 Logic symbol & IEC logic symbol VCC 1A 1Y OE1 OE2 GND 2A 3A 4A 5A 6A buffer/line driver 2 2Y buffer/line driver 3 3Y buffer/line driver 4 4Y buffer/line driver 5 5Y buffer/line driver 6 6Y aaa-004277 Fig. 4. Logic diagram 74HC_HCT365 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 © Nexperia B.V. 2021. All rights reserved 2 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state 5. Pinning information 5.1. Pinning 74HC365 74HCT365 OE1 1 16 VCC 1A 2 15 OE2 1Y 3 14 6A 2A 4 13 6Y 2Y 5 12 5A 3A 6 11 5Y 3Y 7 10 4A GND 8 9 4Y aaa-004278 Fig. 5. Pin configuration for SOT109-1 (SO16) and SOT403-1 (TSSOP16) 5.2. Pin description Table 2. Pin description Symbol Pin Description OE1 1 output enable input 1 (active LOW) 1A 2 data input 1 1Y 3 data output 1 2A 4 data input 2 2Y 5 data output 2 3A 6 data input 3 3Y 7 data output 3 GND 8 ground (0 V) 4Y 9 data output 4 4A 10 data input 4 5Y 11 data output 5 5A 12 data input 5 6Y 13 data output 6 6A 14 data input 6 OE2 15 output enable input 2 (active LOW) VCC 16 supply voltage 74HC_HCT365 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 © Nexperia B.V. 2021. All rights reserved 3 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Control Input Output OE1 OE2 nA nY L L L L L L H H X H X Z H X X Z 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max -0.5 +7 V [1] - ±20 mA [1] - ±20 mA - ±35 mA supply current - 70 mA ground current -70 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V IO output current VO = -0.5 V to (VCC + 0.5 V) ICC IGND [1] [2] [2] Unit The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC365 74HCT365 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 74HC_HCT365 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 © Nexperia B.V. 2021. All rights reserved 4 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state 9. Static characteristics Table 6. Static characteristics 74HC365 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V 1.5 1.2 - V VCC = 4.5 V 3.15 2.4 - V VCC = 6.0 V 4.2 3.2 - V VCC = 2.0 V - 0.8 0.5 V VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.8 Tamb = 25 °C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VI = VIH or VIL V - - - IO = -20 μA; VCC = 2.0 V 1.9 2.0 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - V IO = -6.0 mA; VCC = 4.5 V 3.98 4.32 - V IO = -7.8 mA; VCC = 6.0 V 5.48 5.81 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 V LOW-level output voltage VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 μA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - ±0.5 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 μA CI input capacitance - 3.5 - pF VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = -20 μA; VCC = 2.0 V 1.9 - - V IO = -20 μA; VCC = 4.5 V 4.4 - - V IO = -20 μA; VCC = 6.0 V 5.9 - - V IO = -6.0 mA; VCC = 4.5 V 3.84 - - V IO = -7.8 mA; VCC = 6.0 V 5.34 - - V Tamb = -40 °C to +85 °C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VI = VIH or VIL 74HC_HCT365 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 © Nexperia B.V. 2021. All rights reserved 5 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state Symbol Parameter VOL Min Typ IO = 20 μA; VCC = 2.0 V - - 0.1 V IO = 20 μA; VCC = 4.5 V - - 0.1 V IO = 20 μA; VCC = 6.0 V - - 0.1 V IO = 6.0 mA; VCC = 4.5 V - - 0.33 V IO = 7.8 mA; VCC = 6.0 V - - 0.33 V Conditions Max Unit LOW-level output voltage VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±1.0 μA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - ±5.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 80 μA VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = -20 μA; VCC = 2.0 V 1.9 - - V IO = -20 μA; VCC = 4.5 V 4.4 - - V IO = -20 μA; VCC = 6.0 V 5.9 - - V IO = -6.0 mA; VCC = 4.5 V 3.7 - - V IO = -7.8 mA; VCC = 6.0 V 5.2 - - V IO = 20 μA; VCC = 2.0 V - - 0.1 V IO = 20 μA; VCC = 4.5 V - - 0.1 V IO = 20 μA; VCC = 6.0 V - - 0.1 V IO = 6.0 mA; VCC = 4.5 V - - 0.4 V IO = 7.8 mA; VCC = 6.0 V V Tamb = -40 °C to +125 °C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage VI = VIH or VIL LOW-level output voltage VI = VIH or VIL - - 0.4 II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±1.0 μA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - ±10.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 74HC_HCT365 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 © 160 μA Nexperia B.V. 2021. All rights reserved 6 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state Table 7. Static characteristics 74HCT365 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Min Typ 2.0 1.6 - V - 1.2 0.8 V IO = -20 μA 4.4 4.5 - V IO = -6.0 mA 3.98 4.32 - V IO = 20 μA - 0 0.1 V IO = 6.0 mA - 0.16 0.26 V - - ±0.1 μA Conditions Max Unit Tamb = 25 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V VOL II input leakage current IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - ±0.5 μA ICC supply current - - 8.0 μA ΔICC additional supply current VI = VCC - 2.1 V; other inputs at VCC or GND; IO = 0 A pins nA - 100 360 μA pin OE1 - 100 360 μA pin OE2 - 90 324 μA - 3.5 - pF 2.0 - - V - - 0.8 V IO = -20 μA 4.4 - - V IO = -6.0 mA 3.84 - - V IO = 20 μA - - 0.1 V IO = 6.0 mA - - 0.33 V - - ±1.0 μA CI VI = VCC or GND; VCC = 5.5 V VI = VCC or GND; IO = 0 A; VCC = 5.5 V input capacitance Tamb = -40 °C to +85 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V ICC supply current ΔICC additional supply current VI = VCC - 2.1 V; other inputs at VCC or GND; IO = 0 A VOL 74HC_HCT365 Product data sheet VI = VCC or GND; IO = 0 A; VCC = 5.5 V ±5.0 μA - - 80 μA pins nA - - 450 μA pin OE1 - - 450 μA pin OE2 - - 405 μA All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 © Nexperia B.V. 2021. All rights reserved 7 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state Symbol Parameter Min Typ 2.0 - - V - - 0.8 V IO = -20 μA 4.4 - - V IO = -6.0 mA 3.7 - - V IO = 20 μA - - 0.1 V IO = 6.0 mA - - 0.4 V - - ±1.0 μA ±10.0 μA Conditions Max Unit Tamb = -40 °C to +125 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V VOL LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V II input leakage current VI = VCC or GND; VCC = 5.5 V IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - ICC supply current - - 160 μA ΔICC additional supply current VI = VCC - 2.1 V; other inputs at VCC or GND; IO = 0 A pins nA - - 490 μA pin OE1 - - 490 μA pin OE2 - - 441 μA VI = VCC or GND; IO = 0 A; VCC = 5.5 V 10. Dynamic characteristics Table 8. Dynamic characteristics 74HC365 Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; see test circuit Fig. 8. Symbol Parameter Min Typ VCC = 2.0 V - 30 95 ns VCC = 4.5 V - 11 19 ns VCC = 5 V; CL = 15 pF - 9 - ns VCC = 6.0 V - 9 16 ns VCC = 2.0 V - 47 150 ns VCC = 4.5 V - 17 30 ns VCC = 6.0 V - 14 26 ns VCC = 2.0 V - 61 150 ns VCC = 4.5 V - 22 30 ns - 18 26 ns VCC = 2.0 V - 14 60 ns VCC = 4.5 V - 5 12 ns VCC = 6.0 V - 4 10 ns - 40 - pF Conditions Max Unit Tamb = 25 °C tpd ten tdis propagation delay enable time disable time nA to nY; see Fig. 6 OEn to nY; see Fig. 7 OEn to nY; see Fig. 7 [1] [2] [3] VCC = 6.0 V tt CPD transition time power dissipation capacitance 74HC_HCT365 Product data sheet see Fig. 6 [4] per buffer; VI = GND to VCC All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 [5] © Nexperia B.V. 2021. All rights reserved 8 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state Symbol Parameter Min Typ VCC = 2.0 V - - 120 ns VCC = 4.5 V - - 24 ns VCC = 6.0 V - - 20 ns VCC = 2.0 V - - 190 ns VCC = 4.5 V - - 38 ns VCC = 6.0 V - - 33 ns VCC = 2.0 V - - 190 ns VCC = 4.5 V - - 38 ns - - 33 ns VCC = 2.0 V - - 75 ns VCC = 4.5 V - - 15 ns VCC = 6.0 V - - 13 ns VCC = 2.0 V - - 145 ns VCC = 4.5 V - - 29 ns VCC = 6.0 V - - 25 ns VCC = 2.0 V - - 225 ns VCC = 4.5 V - - 45 ns VCC = 6.0 V - - 38 ns VCC = 2.0 V - - 225 ns VCC = 4.5 V - - 45 ns VCC = 6.0 V - - 38 ns VCC = 2.0 V - - 90 ns VCC = 4.5 V - - 18 ns VCC = 6.0 V - - 15 ns Conditions Max Unit Tamb = -40 °C to +85 °C tpd propagation delay ten enable time tdis disable time nA to nY; see Fig. 6 OEn to nY; see Fig. 7 OEn to nY; see Fig. 7 [1] [2] [3] VCC = 6.0 V tt transition time see Fig. 6 [4] Tamb = -40 °C to +125 °C tpd propagation delay ten enable time tdis disable time tt [1] [2] [3] [4] [5] transition time nA to nY; see Fig. 6 OEn to nY; see Fig. 7 OEn to nY; see Fig. 7 see Fig. 6 [1] [2] [3] [4] tpd is the same as tPHL and tPLH. ten is the same as tPZH and tPZL. tdis is the same as tPHZ and tPLZ. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL x VCC x fo) = sum of outputs. 74HC_HCT365 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 © Nexperia B.V. 2021. All rights reserved 9 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state Table 9. Dynamic characteristics 74HCT365 Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; see test circuit Fig. 8. Symbol Parameter Min Typ VCC = 4.5 V - 14 25 ns VCC = 5 V; CL = 15 pF - 11 - ns Conditions Max Unit Tamb = 25 °C tpd propagation delay nA to nY; see Fig. 6 [1] ten enable time OEn to nY; VCC = 4.5 V; see Fig. 7 [2] - 18 35 ns tdis disable time OEn to nY; VCC = 4.5 V; see Fig. 7 [3] - 23 35 ns tt transition time VCC = 4.5 V; see Fig. 6 [4] - 5 12 ns CPD power dissipation capacitance per buffer; VI = GND to (VCC - 1.5 V) [5] - 40 - pF Tamb = -40 °C to +85 °C tpd propagation delay nA to nY; VCC = 4.5 V; see Fig. 6 [1] - - 31 ns ten enable time OEn to nY; VCC = 4.5 V; see Fig. 7 [2] - - 44 ns tdis disable time OEn to nY; VCC = 4.5 V; see Fig. 7 [3] - - 44 ns tt transition time VCC = 4.5 V; see Fig. 6 [4] - - 15 ns Tamb = -40 °C to +125 °C tpd propagation delay nA to nY; VCC = 4.5 V; see Fig. 6 [1] - - 38 ns ten enable time OEn to nY; VCC = 4.5 V; see Fig. 7 [2] - - 53 ns tdis disable time OEn to nY; VCC = 4.5 V; see Fig. 7 [3] - - 53 ns tt transition time VCC = 4.5 V; see Fig. 6 [4] - - 18 ns [1] [2] [3] [4] [5] tpd is the same as tPHL and tPLH. ten is the same as tPZH and tPZL. tdis is the same as tPHZ and tPLZ. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL x VCC x fo) = sum of outputs. 74HC_HCT365 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 © Nexperia B.V. 2021. All rights reserved 10 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state 10.1. Waveforms and test circuit VI nA input VM VM GND tPHL tPHL VOH nY output VM VOL VM tTHL tTHL aaa-004279 Measurement points are given in Table 10. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. Propagation delay data input (nA) to output (nY) and output transition time VI VM OEn input VM GND tPLZ nY output LOW-to-OFF OFF-to-LOW tPZL VCC VM VX VOL tPHZ nY output HIGH-to-OFF OFF-to-HIGH VOH tPZH VY VM GND outputs enabled outputs disabled outputs enabled 001aaf586 Measurement points are given in Table 10. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 7. 3-state enable and disable times Table 10. Measurement points Input Type Output VM VM VX VY 74HC365 0.5VCC 0.5VCC 0.1 × VCC 0.9 × VCC 74HCT365 1.3 V 1.3 V 0.1 × VCC 0.9 × VCC 74HC_HCT365 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 © Nexperia B.V. 2021. All rights reserved 11 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VCC VO RT RL S1 open CL 001aad983 Test data is given in Table 11. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistance S1 = Test selection switch Fig. 8. Test circuit for measuring switching times Table 11. Test data Type Input Load VI tr, tf CL 74HC365 VCC 6 ns 74HCT365 3V 6 ns 74HC_HCT365 Product data sheet S1 position RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 15 pF, 50 pF 1 kΩ open GND VCC 15 pF, 50 pF 1 kΩ open GND VCC All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 © Nexperia B.V. 2021. All rights reserved 12 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state 11. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT109-1 (SO16) 74HC_HCT365 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 © Nexperia B.V. 2021. All rights reserved 13 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 10. Package outline SOT403-1 (TSSOP16) 74HC_HCT365 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 © Nexperia B.V. 2021. All rights reserved 14 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state 12. Abbreviations Table 12. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 13. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT365 v.6 20210728 Product data sheet - 74HC_HCT365 v.5 Modifications: • 74HC_HCT365 v.5 20210212 Modifications: • • • • • Type number 74HCT365DB (SOT338-1/SSOP16) removed. 20160127 Modifications: • 74HC_HCT365 v.3 20120905 Modifications: • 74HC_HCT365_CNV v.2 74HC_HCT365 Product data sheet - 74HC_HCT365 v.4 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Section 1 and Section 2 updated. Type number 74HC365DB (SOT338-1/SSOP16) removed. Section 7: Derating values for Ptot total power dissipation updated. 74HC_HCT365 v.4 • Product data sheet Product data sheet - 74HC_HCT365 v.3 Type numbers 74HC365N and 74HCT365N (SOT38-4) removed. Product data sheet - 74HC_HCT365_CNV v.2 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. 19970829 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 - © Nexperia B.V. 2021. All rights reserved 15 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT365 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 © Nexperia B.V. 2021. All rights reserved 16 / 17 74HC365; 74HCT365 Nexperia Hex buffer/line driver; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 4 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 8 10.1. Waveforms and test circuit...................................... 11 11. Package outline........................................................ 13 12. Abbreviations............................................................ 15 13. Revision history........................................................15 14. Legal information......................................................16 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 28 July 2021 74HC_HCT365 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 July 2021 © Nexperia B.V. 2021. All rights reserved 17 / 17
74HCT365DB/DG,118 价格&库存
很抱歉,暂时无法提供与“74HCT365DB/DG,118”相匹配的价格&库存,您可以联系我们找货
