S-11L10D30-M5T1U
S-11L10D30-M5T1U
    ABLIC(艾普凌科)
    SOT23-5
    IC REG LINEAR 3V 150MA SOT23-5
S-11L10D30-M5T1U 数据手册
S-11L10 Series 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR N www.ablic.com Rev.2.3_02 DE SI G © ABLIC Inc., 2009-2018 W The S-11L10 Series, developed by using the CMOS technology, is a positive voltage regulator IC which has low output voltage, high-accuracy output voltage and low current consumption (150 mA output current). A 1.0 μF small ceramic capacitor can be used. It operates with low current consumption of 9 μA typ. The overcurrent protection circuit prevents the load current from exceeding the current capacity of the output transistor. The ON / OFF circuit ensures longer battery life. Various capacitors, also small ceramic capacitors, can be used for this IC more than for the conventional regulator ICs which have CMOS technology. Furthermore, small SOT-23-5 and SNT-6A(H) packages realize high-density mounting. NE  Features 0.8 V to 3.3 V, selectable in 0.05 V step 1.2 V to 3.65 V ±1.0% (0.8 V to 1.45 V output product : ±15 mV) 210 mV typ. (1.5 V output product, IOUT = 100 mA) During operation: 9 μA typ., 16 μA max. During power-off: 0.1 μA typ., 0.9 μA max. Possible to output 150 mA (VIN ≥ VOUT(S) + 1.0 V)*1 A ceramic capacitor of 1.0 μF or more can be used. 60 dB typ. (1.25 V output product, f = 1.0 kHz) Limits overcurrent of output transistor. Ensures long battery life. Discharge shunt function is available. Pull-down function “available” / “unavailable” is selectable. Ta = −40°C to +85°C D MM EN • Operation temperature range: • Lead-free (Sn 100%), halogen-free DE • Output current: • Input and output capacitors: • Ripple rejection: • Built-in overcurrent protection circuit: • Built-in ON / OFF circuit: FO R • Output voltage: • Input voltage: • Output voltage accuracy: • Dropout voltage: • Current consumption: *1. Attention should be paid to the power dissipation of the package when the output current is large.  Applications RE  Packages CO • Power supply for battery-powered device • Power supply for mobile phone • Power supply for portable equipment NO T • SOT-23-5 • SNT-6A(H) 1 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series  Block Diagrams N S-11L10 Series B type *1 VIN VOUT Overcurrent protection circuit ON / OFF circuit Reference voltage circuit R *1 FO VSS *1. Available W + − Status Active “H” NE ON / OFF Function ON / OFF logic Constant current source pull-down DE SI G 1. Parasitic diode S-11L10 Series D type DE 2. D Figure 1 *1 VOUT MM EN VIN Overcurrent protection circuit ON / OFF circuit NO T VSS RE CO ON / OFF *1. 2 + − Reference voltage circuit *1 Parasitic diode Figure 2 Function ON / OFF logic Constant current source pull-down Status Active “H” Unavailble 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series  Product Name Structure 1. DE SI G N Users can select the product type, output voltage, and package type for the S-11L10 Series. Refer to “1. Product name” regarding the contents of product name, “2. Function list of product type” regarding the product type, “3. Package” regarding the package drawings, “4. Product name list” regarding details of the product name. Product name S-11L10 x xx - xxxx U W Environmental code U: Lead-free (Sn 100%), halogen-free NE Package abbreviation and IC packing specifications*1 M5T1: SOT-23-5, Tape I6T2: SNT-6A(H), Tape FO R Output voltage*2 08 to 33 (e.g., when the output voltage is 1.0 V, it is expressed as 10.) Function list of product type MM EN 2. Refer to the tape drawing. If you request the product which has 0.05 V step, contact our sales office. Refer to “2. Function list of product type”. DE *1. *2. *3. D Product type*3 B or D Product Type Packages Constant Current Source Pull-down Active “H” Available D Active “H” Unavailble Package MP005-A-P-SD PI006-A-P-SD Drawing Code Tape Reel MP005-A-C-SD MP005-A-R-SD PI006-A-C-SD PI006-A-R-SD Land ⎯ PI006-A-L-SD NO T SOT-23-5 SNT-6A(H) RE Package Name ON / OFF Logic B CO 3. Table 1 3 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series Product name list S-11L10 Series B type ON / OFF logic: Constant current source pull-down: Active “H” Table 2 Output voltage 0.8 V±15 mV N 4. 1 Available DE SI G 4. SOT-23-5 SNT-6A(H) S-11L10B08-M5T1U S-11L10B08-I6T2U NO T RE CO MM EN DE D FO R NE W S-11L10B09-M5T1U S-11L10B09-I6T2U 0.9 V±15 mV 1.0 V±15 mV S-11L10B10-M5T1U S-11L10B10-I6T2U 1.1 V±15 mV S-11L10B11-M5T1U S-11L10B11-I6T2U 1.2 V±15 mV S-11L10B12-M5T1U S-11L10B12-I6T2U 1.3 V±15 mV S-11L10B13-M5T1U S-11L10B13-I6T2U 1.4 V±15 mV S-11L10B14-M5T1U S-11L10B14-I6T2U 1.5 V±1.0% S-11L10B15-M5T1U S-11L10B15-I6T2U 1.6 V±1.0% S-11L10B16-M5T1U S-11L10B16-I6T2U 1.7 V±1.0% S-11L10B17-M5T1U S-11L10B17-I6T2U 1.8 V±1.0% S-11L10B18-M5T1U S-11L10B18-I6T2U 1.9 V±1.0% S-11L10B19-M5T1U S-11L10B19-I6T2U 2.0 V±1.0% S-11L10B20-M5T1U S-11L10B20-I6T2U 2.1 V±1.0% S-11L10B21-M5T1U S-11L10B21-I6T2U 2.2 V±1.0% S-11L10B22-M5T1U S-11L10B22-I6T2U 2.3 V±1.0% S-11L10B23-M5T1U S-11L10B23-I6T2U 2.4 V±1.0% S-11L10B24-M5T1U S-11L10B24-I6T2U 2.5 V±1.0% S-11L10B25-M5T1U S-11L10B25-I6T2U 2.6 V±1.0% S-11L10B26-M5T1U S-11L10B26-I6T2U 2.7 V±1.0% S-11L10B27-M5T1U S-11L10B27-I6T2U 2.8 V±1.0% S-11L10B28-M5T1U S-11L10B28-I6T2U 2.9 V±1.0% S-11L10B29-M5T1U S-11L10B29-I6T2U 3.0 V±1.0% S-11L10B30-M5T1U S-11L10B30-I6T2U 3.1 V±1.0% S-11L10B31-M5T1U S-11L10B31-I6T2U 3.2 V±1.0% S-11L10B32-M5T1U S-11L10B32-I6T2U 3.3 V±1.0% S-11L10B33-M5T1U S-11L10B33-I6T2U Remark Please contact our sales office for products with specifications other than the above. 4 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series S-11L10 Series D type ON / OFF logic: Constant current source pull-down: Active “H” 0.8 V±15 mV DE SI G Table 3 Output voltage Unavailable N 4. 2 SOT-23-5 SNT-6A(H) S-11L10D08-M5T1U S-11L10D08-I6T2U NO T RE CO MM EN DE D FO R NE W S-11L10D09-M5T1U S-11L10D09-I6T2U 0.9 V±15 mV 1.0 V±15 mV S-11L10D10-M5T1U S-11L10D10-I6T2U 1.1 V±15 mV S-11L10D11-M5T1U S-11L10D11-I6T2U 1.2 V±15 mV S-11L10D12-M5T1U S-11L10D12-I6T2U 1.3 V±15 mV S-11L10D13-M5T1U S-11L10D13-I6T2U 1.4 V±15 mV S-11L10D14-M5T1U S-11L10D14-I6T2U 1.5 V±1.0% S-11L10D15-M5T1U S-11L10D15-I6T2U 1.6 V±1.0% S-11L10D16-M5T1U S-11L10D16-I6T2U 1.7 V±1.0% S-11L10D17-M5T1U S-11L10D17-I6T2U 1.8 V±1.0% S-11L10D18-M5T1U S-11L10D18-I6T2U 1.9 V±1.0% S-11L10D19-M5T1U S-11L10D19-I6T2U 2.0 V±1.0% S-11L10D20-M5T1U S-11L10D20-I6T2U 2.1 V±1.0% S-11L10D21-M5T1U S-11L10D21-I6T2U 2.2 V±1.0% S-11L10D22-M5T1U S-11L10D22-I6T2U 2.3 V±1.0% S-11L10D23-M5T1U S-11L10D23-I6T2U 2.4 V±1.0% S-11L10D24-M5T1U S-11L10D24-I6T2U 2.5 V±1.0% S-11L10D25-M5T1U S-11L10D25-I6T2U 2.6 V±1.0% S-11L10D26-M5T1U S-11L10D26-I6T2U 2.7 V±1.0% S-11L10D27-M5T1U S-11L10D27-I6T2U 2.8 V±1.0% S-11L10D28-M5T1U S-11L10D28-I6T2U 2.9 V±1.0% S-11L10D29-M5T1U S-11L10D29-I6T2U 3.0 V±1.0% S-11L10D30-M5T1U S-11L10D30-I6T2U 3.1 V±1.0% S-11L10D31-M5T1U S-11L10D31-I6T2U 3.2 V±1.0% S-11L10D32-M5T1U S-11L10D32-I6T2U 3.3 V±1.0% S-11L10D33-M5T1U S-11L10D33-I6T2U Remark Please contact our sales office for products with specifications other than the above. 5 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series  Pin Configuration SOT-23-5 N 1. Top view DE SI G 5 Table 4 Symbol Description VIN Input voltage pin VSS GND pin ON / OFF ON / OFF pin No connection NC*1 VOUT Output voltage pin Pin No. 1 2 3 4 5 4 1 2 3 SNT-6A(H) Top view The NC pin is electrically open. The NC pin can be connected to VIN pin or VSS pin. NO T RE CO MM EN *1. DE Figure 4 6 Table 5 Symbol Description VOUT Output voltage pin VSS GND pin No connection NC*1 ON / OFF ON / OFF pin VSS GND pin VIN Input voltage pin FO 6 5 4 D 1 2 3 Pin No. 1 2 3 4 5 6 R 2. The NC pin is electrically open. The NC pin can be connected to VIN pin or VSS pin. NE *1. W Figure 3 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series  Absolute Maximum Ratings Table 6 Input voltage Output voltage VSS − 0.3 to VSS + 4.0 VSS − 0.3 to VIN + 0.3 VSS − 0.3 to VIN + 0.3 600*1 500*1 −40 to +85 −40 to +125 SOT-23-5 PD SNT-6A(H) Operation ambient temperature Topr Storage temperature Tstg *1. When mounted on board [Mounted board] (1) Board size: 114.3 mm × 76.2 mm × t1.6 mm (2) Name: JEDEC STANDARD51-7 V V V mW mW °C °C NE W Power dissipation The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. FO R Caution N Symbol VIN VON / OFF VOUT DE SI G Item (Ta = +25°C unless otherwise specified) Absolute Maximum Rating Unit D SNT-6A(H) DE 400 200 MM EN Power Dissiaption (PD) [mW] SOT-23-5 600 0 0 150 100 50 Ambient Temperature (Ta) [°C] NO T RE CO Figure 5 Power Dissipation of Package (When Mounted on Board) 7 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series  Electrical Characteristics Output voltage temperature coefficient*4 Current consumption during operation ΔVIN • VOUT ΔVOUT2 ΔVOUT ΔTa • VOUT ISS1 ISS2 NO T Current consumption during power-off ΔVOUT1 8 VOUT(S) + 0.5 V ≤ VIN ≤ 3.65 V, IOUT = 30 mA 3.4 V ≤ VIN ≤ 3.65 V, IOUT = 30 mA VIN = VOUT(S) + 1.0 V, 10 μA ≤ IOUT ≤ 100 mA VIN = 3.65 V, 10 μA ≤ IOUT ≤ 100 mA VIN = VOUT(S) + 1.0 V, IOUT = 30 mA, −40°C ≤ Ta ≤ +85°C VIN = 3.65 V, IOUT = 30 mA, −40°C ≤ Ta ≤ +85°C VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, no load VIN = 3.65 V, ON / OFF pin = ON, no load VIN = VOUT(S) + 1.0 V, ON / OFF pin = OFF, no load VIN = 3.65 V, ON / OFF pin = OFF, no load CO Load regulation DE SI G W 0.8 V ≤ VOUT(S) ≤ 2.65 V 2.65 V < VOUT(S) ≤ 3.3 V 0.8 V ≤ VOUT(S) < 1.1 V 1.1 V ≤ VOUT(S) < 1.3 V 1.3 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) < 1.7 V 1.7 V ≤ VOUT(S) ≤ 3.3 V IOUT = 100 mA RE Line regulation 2.65 V < VOUT(S) ≤ 3.3 V VOUT(S) − 0.015 VOUT(S) × 0.99 VOUT(S) × 0.99 150*5 150*5 0.40 ⎯ ⎯ ⎯ ⎯ NE Vdrop VIN = 3.65 V, IOUT = 30 mA VIN ≥ VOUT(S) + 1.0 V VIN = 3.65 V R Dropout voltage*3 1.5 V ≤ VOUT(S) ≤ 2.65 V ⎯ ⎯ 0.44 0.28 0.24 0.21 0.19 VOUT(S) + 0.015 VOUT(S) × 1.01 VOUT(S) × 1.01 ⎯ ⎯ 0.48 0.42 0.36 0.32 0.29 VOUT(S) VOUT(S) VOUT(S) V 1 V 1 V 1 mA mA V V V V V 3 3 1 1 1 1 1 0.8 V ≤ VOUT(S) < 2.9 V ⎯ 0.05 0.2 %/V 1 2.9 V ≤ VOUT(S) ≤ 3.3 V ⎯ 0.05 0.2 %/V 1 0.8 V ≤ VOUT(S) ≤ 2.65 V ⎯ 20 40 mV 1 2.65 V < VOUT(S) ≤ 3.3 V ⎯ 20 40 mV 1 0.8 V ≤ VOUT(S) ≤ 2.65 V ⎯ ±150 ⎯ ppm/°C 1 2.65 V < VOUT(S) ≤ 3.3 V ⎯ ±150 ⎯ ppm/°C 1 0.8 V ≤ VOUT(S) ≤ 2.65 V ⎯ 9 16 μA 2 2.65 V < VOUT(S) ≤ 3.3 V ⎯ 9 16 μA 2 0.8 V ≤ VOUT(S) ≤ 2.65 V ⎯ 0.1 0.9 μA 2 2.65 V < VOUT(S) ≤ 3.3 V ⎯ 0.1 0.9 μA 2 FO IOUT 0.8 V ≤ VOUT(S) < 1.5 V D Output current*2 Conditions VIN = VOUT(S) + 1.0 V, IOUT = 30 mA VOUT(E) (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit DE Output voltage*1 Symbol MM EN Item N Table 7 (1 / 2) 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series Table 7 (2 / 2) Ripple rejection Short-circuit current Discharge shunt resistance during power-off ISL RR Ishort RLOW VOUT = 0.1 V, VIN = 3.65 V N DE SI G ⎯ V 4 2.65 V < VOUT(S) ≤ 3.3 V 0.9 ⎯ ⎯ V 4 0.8 V ≤ VOUT(S) ≤ 2.65 V ⎯ ⎯ 0.2 V 4 ⎯ ⎯ 0.2 V 4 0.05 −0.1 ⎯ ⎯ 0.55 0.1 μA μA 4 4 −0.1 ⎯ 0.1 μA 4 0.8 V ≤ VOUT(S) ≤ 1.25 V ⎯ 60 ⎯ dB 5 1.25 V < VOUT(S) ≤ 2.65 V ⎯ 55 ⎯ dB 5 2.65 V < VOUT(S) ≤ 3.3 V ⎯ 55 ⎯ dB 5 0.8 V ≤ VOUT(S) ≤ 2.65 V ⎯ 150 ⎯ mA 3 2.65 V < VOUT(S) ≤ 3.3 V ⎯ 150 ⎯ mA 3 ⎯ 100 ⎯ Ω 3 W ⎯ 2.65 V < VOUT(S) ≤ 3.3 V B type D type VIN = 3.65 V, VON / OFF = 0 V VIN = VOUT(S) + 1.0 V, f = 1.0 kHz, ΔVrip = 0.5 Vrms, IOUT = 30 mA VIN = 3.65 V, f = 1.0 kHz, ΔVrip = 0.5 Vrms, IOUT = 30 mA VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, VOUT = 0 V VIN = 3.65 V, ON / OFF pin = ON, VOUT = 0 V V ⎯ NE ISH 3.65 0.9 R VSL ⎯ 0.8 V ≤ VOUT(S) ≤ 2.65 V FO ON / OFF pin input current “H” ON / OFF pin input current “L” VSH 1.2 D ON / OFF pin input voltage “L” ⎯ VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ, determined by VOUT output level VIN = 3.65 V, RL = 1.0 kΩ, determined by VOUT output level VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ, determined by VOUT output level VIN = 3.65 V, RL = 1.0 kΩ, determined by VOUT output level VIN = 3.65 V, VON / OFF = 3.65 V VIN MM EN ON / OFF pin input voltage “H” Conditions CO Input voltage Symbol DE Item (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit NO T RE *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT(= 30 mA) and inputting VOUT(S) +1.0 V or 3.65 V *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V or 3.65 V and IOUT = 100 mA. VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. *4. A change in temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S)[V]*2 × ΔTa•V [ppm/°C]*3 ÷ 1000 ΔTa OUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. The output current can be at least this value. Due to restrictions on the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation of the package when the output current is large. This specification is guaranteed by design. 9 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series  Test Circuits ON / OFF V VSS A N + VOUT VIN + DE SI G 1. Set to ON Figure 6 + A VOUT VIN W 2. ON / OFF NE VSS Set to VIN or GND A FO 3. VOUT VIN ON / OFF V VOUT A MM EN VIN + DE Set to VIN or GND 4. + D VSS Figure 8 R Figure 7 ON / OFF VSS V + RL 5. CO Figure 9 VIN VOUT RE ON / OFF VSS NO T Set to ON 10 Figure 10 V + RL 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series  Standard Circuit Input Output *1 ON / OFF VSS CL Single GND W GND CIN is a capacitor for stabilizing the input. A ceramic capacitor of 1.0 μF or more can be used as CL. Figure 11 The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. FO R Caution NE *1. *2. *2 DE SI G CIN N VOUT VIN Input capacitor (CIN): Output capacitor (CL): 1.0 μF or more 1.0 μF or more D  Condition of Application MM EN DE Caution Generally a series regulator may cause oscillation, depending on the selection of external parts. Confirm that no oscillation occurs in the application for which the above capacitors are used.  Selection of Input and Output Capacitors (CIN, CL) NO T RE CO The S-11L10 Series requires an output capacitor between the VOUT pin and VSS pin for phase compensation. Operation is stabilized by a ceramic capacitor with an output capacitance of 1.0 μF or more over the entire temperature range. When using an OS capacitor, a tantalum capacitor, or an aluminum electrolytic capacitor, the capacitance must be 1.0 μF or more. The value of the output overshoot or undershoot transient response varies depending on the value of the output capacitor. The required capacitance of the input capacitor differs depending on the application. The recommended capacitance for an application is CIN ≥ 1.0 μF, CL ≥ 1.0 μF; however, when selecting the output capacitor, perform sufficient evaluation, including evaluation of temperature characteristics, on the actual device. 11 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series  Explanation of Terms Low dropout voltage regulator N 1. 2. DE SI G This voltage regulator has the low dropout voltage due to its built-in low on-resistance transistor. Output voltage (VOUT) The accuracy of the output voltage is ensured at ±1.0% or ±15 mV*1 under the specified conditions of fixed input voltage*2, fixed output current, and fixed temperature. When VOUT < 1.5 V: ±15 mV, when 1.5 V ≤ VOUT: ±1.0% Differs depending on the product. ΔVOUT1  Line regulation  ΔVIN•VOUT  R 3. If the above conditions change, the output voltage value may vary and exceed the accuracy range of the output voltage. Refer to “ Electrical Characteristics” and “ Characteristics (Typical Data)” for details. W Caution NE *1. *2. 4. FO Indicates the dependency of the output voltage on the input voltage. That is, the values show how much the output voltage changes due to a change in the input voltage with the output current remaining unchanged. Load regulation (ΔVOUT2) Dropout voltage (Vdrop) DE 5. D Indicates the dependency of the output voltage on the output current. That is, the values show how much the output voltage changes due to a change in the output current with the input voltage remaining unchanged. MM EN Indicates the difference between input voltage (VIN1) and the output voltage when; decreasing input voltage (VIN) gradually until the output voltage has dropped out to the value of 98% of output voltage (VOUT3), which is at VIN = VOUT(S) + 1.0 V. NO T RE CO Vdrop = VIN1 − (VOUT3 × 0.98) 12 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series 6. Output voltage temperature coefficient  ΔVOUT  ΔTa•VOUT  Example of S-11L10B10 typ. product VOUT [V] DE SI G N The shaded area in Figure 12 is the range where VOUT varies in the operation temperature range when the output voltage temperature coefficient is ±150 ppm/°C. +0.15 mV/°C W *1 NE VOUT(E) −0.15 mV/°C +85 Ta [°C] VOUT(E) is the value of the output voltage measured at Ta = +25°C. FO *1. +25 R −40 Figure 12 NO T RE CO MM EN DE D A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔV [mV/°C]*1 = VOUT(S)[V]*2 × ΔTa•OUT [ppm/°C]*3 ÷ 1000 ΔTa VOUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient 13 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series  Operation Basic operation N 1. DE SI G Figure 13 shows the block diagram of the S-11L10 Series. The error amplifier compares the reference voltage (Vref) with feedback voltage (Vfb), which is the output voltage resistance-divided by feedback resistors (Rs and Rf). It supplies the gate voltage necessary to maintain the constant output voltage which is not influenced by the input voltage and temperature change, to the output transistor. VIN *1 W Current supply Vref NE Error amplifier − Rf FO R + Reference voltage circuit D Parasitic diode Output transistor Rs MM EN 2. Vfb DE VSS *1. VOUT Figure 13 NO T RE CO In the S-11L10 Series, a low on-resistance P-channel MOS FET is used as the output transistor. Be sure that VOUT does not exceed VIN + 0.3 V to prevent the voltage regulator from being damaged due to reverse current flowing from the VOUT pin through a parasitic diode to the VIN pin, when the potential of VOUT became higher than VIN. 14 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series 3. ON / OFF pin This pin starts and stops the regulator. DE SI G N When the ON / OFF pin is set to OFF level, the entire internal circuit stops operating, and the built-in P-channel MOS FET output transistor between the VIN pin and the VOUT pin is turned off, reducing current consumption significantly. Since the S-11L10 Series has a built-in discharge shunt circuit to discharge the output capacitance, the VOUT pin is forcibly set to the VSS level. The ON / OFF pin is configured as shown in Figure 14 and Figure 15. 3. 1 S-11L10 Series B type 3. 2 W The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. For the ON / OFF pin current, refer to the B type of ON / OFF pin input current “H” in “ Electrical Characteristics”. S-11L10 Series D type Under high temperature in the S-11L10 Series, this IC’s current consumption may increase if applying voltage of 0.2 V to 0.9 V to the ON / OFF pin. FO R Caution NE The ON / OFF pin is internally not pulled up or pulled down, so do not use this pin in the floating status. When not using the ON / OFF pin, connect it to the VIN pin. Table 8 VOUT Pin Voltage “L”: OFF ON / OFF Pin Stop VSS level ISS2 B/D “H”: ON Operate Set value ISS1 D Internal Circuit B/D Current Consumption MM EN DE Product Type VIN ON / OFF RE CO ON / OFF VIN S-11L10 Series B Type VSS Figure 15 S-11L10 Series D Type NO T Figure 14 VSS 15 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series 4. Discharge shunt function DE SI G N The S-11L10 Series has a built-in discharge shunt circuit to discharge the output capacitance. When the ON / OFF pin is set to OFF level, turns the output transistor off, and turns the discharge shunt function on so that the output capacitor discharges. The VOUT pin is set to the VSS level faster, compared to the product which does not have a discharge shunt circuit. S-11L10 Series Output transistor: OFF *1 VOUT NE W VIN ON / OFF DE ON / OFF pin: OFF D ON / OFF circuit FO R Discharge shunt circuit : ON MM EN VSS Current flow NO T RE CO *1. Parasitic diode 16 *1 Output capacitor (CL) Figure 16 GND 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series 5. Overcurrent protection circuit DE SI G N The S-11L10 Series includes an overcurrent protection circuit having the characteristics shown in “1. Output Voltage vs. Output Current (When Load Current Increases) (Ta = +25°C)” in “ Characteristics (Typical Data)”, in order to protect the output transistor against an excessive output current and short circuiting between the VOUT pin and VSS pin. The current when the output pin is short-circuited (Ishort) is internally set at approx. 150 mA typ., and the normal value is restored for the output voltage, if releasing a short circuit once. 6. Constant current source pull-down (S-11L10 Series B type) W Caution This overcurrent protection circuit does not work as for thermal protection. If this IC long keeps short circuiting inside, pay attention to the conditions of input voltage and load current so that, under the usage conditions including short circuit, the loss of the IC will not exceed power dissipation of the package. NE The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. NO T RE CO MM EN DE D FO R Note that the IC’s current consumption increases as much as the constant current flows when the ON / OFF pin is connected to the VIN pin and the S-11L10 Series B type is operating. 17 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series  Precautions DE SI G N • Wiring patterns for the VIN pin, the VOUT pin and GND should be designed so that the impedance is low. When mounting an output capacitor between the VOUT pin and the VSS pin (CL) and a capacitor for stabilizing the input between the VIN pin and the VSS pin (CIN), the distance from the capacitors to these pins should be as short as possible. • Note that generally the output voltage may increase when a series regulator is used at low load current (100 μA or less). • Note that generally the output voltage may increase due to the leakage current from an output driver when a series regulator is used at high temperature. W • At high temperature, the current consumption of the S-11L10 Series may increase if applying voltage of 0.2 V to 0.9 V to the ON / OFF pin. NE • The S-11L10 Series may oscillate if power supply’s inductance is high. Select an input capacitor after performing sufficient evaluation under the actual usage conditions including evaluation of temperature characteristics. 1.0 μF or more 1.0 μF or more FO Input capacitor (CIN): Output capacitor (CL): R • Generally a series regulator may cause oscillation, depending on the selection of external parts. The following conditions are recommended for the S-11L10 Series. However, be sure to perform sufficient evaluation under the actual usage conditions for selection, including evaluation of temperature characteristics. Refer to “5. Example of Equivalent Series Resistance vs. Output Current Characteristics (Ta = +25°C)” in “ Reference Data” for the equivalent series resistance (RESR) of the output capacitor. D • The voltage regulator may oscillate when the impedance of the power supply is high and the input capacitance is small or an input capacitor is not connected. DE • If the output capacitance is small, power supply’s fluctuation and the characteristics of load fluctuation become worse. Sufficiently evaluate the output voltage’s fluctuation with the actual device. MM EN • Overshoot may occur in the output voltage momentarily if the voltage is rapidly raised at power-on or when the power supply fluctuates. Sufficiently evaluate the output voltage at power-on with the actual device. • The application conditions for the input voltage, the output voltage, and the load current should not exceed the package power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. CO • In determining the output current, attention should be paid to the output current value specified in Table 7 in “ Electrical Characteristics” and footnote *5 of the table. NO T RE • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 18 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series VOUT = 0.8 V 1.2 1. 2 1.5 0.8 VOUT [V] VOUT [V] 1.0 VIN = 1.3 V 1.8 V 3.65 V 0.6 0.4 0 0 50 0 100 150 200 250 300 350 IOUT [mA] VIN = 3.65 V 2.0 1.0 0 In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *5 in Table 7 in “ Electrical Characteristics” 2. The package power dissipation D 100 150 200 250 300 350 IOUT [mA] DE 50 0 100 150 200 250 300 350 IOUT [mA] R Remark 50 FO VOUT [V] 0 VOUT = 3.3 V 4.0 3.0 MM EN VOUT = 3.3 V 3.4 3.3 3.2 CO 2. 3 VOUT = 0.8 V 1.0 IOUT = 1 mA 0.9 0.8 0.7 30 mA 0.6 100 mA 0.5 0.4 0.3 0 0.5 1.0 1.5 2.0 VIN [V] 2.5 3.0 3.5 2. 2 VOUT = 1.5 V 1.6 IOUT = 1 mA 1.5 1.4 30 mA 1.3 100 mA 1.2 1.1 1.0 1.0 1.5 2.0 2.5 VIN [V] 3.0 3.5 RE VOUT [V] 2. 1 VOUT [V] Output Voltage vs. Input Voltage (Ta = +25°C) IOUT = 1 mA 30 mA 3.1 NO T VOUT [V] 2. VIN = 2.0 V 2.5 V 3.65 V 1.0 0.5 0.2 1. 3 VOUT = 1.5 V 2.0 W 1. 1 DE SI G Output Voltage vs. Output Current (When Load Current Increases) (Ta = +25°C) NE 1. N  Characteristics (Typical Data) 100 mA 3.0 2.9 2.8 2.8 3.0 3.2 VIN [V] 3.4 3.6 19 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series Dropout Voltage vs. Output Current Ta = 85°C 0.3 25°C 0.2 −40°C 0.1 50 125 150 −40°C NE VOUT = 3.3 V 0.20 Ta = 85°C 0.10 R 25°C −40°C 0 25 50 100 75 IOUT [mA] 125 DE Dropout Voltage vs. Set Output Voltage 150 D 0 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 1.0 1.5 2.0 2.5 VOUT(S) [V] NO T RE CO 0.5 MM EN IOUT = 150 mA 100 mA 50 mA 30 mA 10 mA 0 25 0 FO Vdrop [V] 75 100 IOUT [mA] 0.05 Vdrop [V] 25°C 0.10 50 W 25 0.15 20 0.15 0 0 4. Ta = 85°C 0.20 0.05 0 3. 3 VOUT = 1.5 V 0.30 0.25 0.4 Vdrop [V] 3. 2 N VOUT = 0.8 V 0.5 DE SI G 3. 1 Vdrop [V] 3. 3.0 3.5 75 100 IOUT [mA] 125 150 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series Output Voltage vs. Ambient Temperature VOUT = 0.8 V 0.84 5. 2 1.55 VOUT [V] VOUT [V] 0.82 0.80 0.78 1.45 1.40 −40 −25 0 25 Ta [°C] 50 75 85 0 25 Ta [°C] 50 75 85 VOUT = 3.3 V 3.5 3.3 8 6 DE −40°C 4 2 25°C 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 VIN [V] VOUT = 3.3 V 12 CO 0 75 85 6. 2 VOUT = 1.5 V 12 Ta = 85°C 10 8 6 −40°C 4 25°C 2 0 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 VIN [V] Ta = 85°C RE 10 8 6 4 NO T ISS1 [μA] MM EN ISS1 [μA] VOUT = 0.8 V 12 Ta = 85°C 10 0 6. 3 50 FO −40 −25 Current Consumption vs. Input Voltage 6. 1 25 Ta [°C] D 3.1 6. 0 R 3.2 ISS1 [μA] VOUT [V] 3.4 3.0 −40 −25 NE 5. 3 1.50 W 0.76 VOUT = 1.5 V 1.60 N 5. 1 DE SI G 5. −40°C 25°C 2 0 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 VIN [V] 21 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series 7. Ripple Rejection (Ta = +25°C) 7. 1 VOUT = 0.8 V 7. 2 VOUT = 1.5 V 30 mA 100 mA 60 40 20 0 1k 10k 100k Frequency [Hz] 0 FO 40 20 0 1k 10k 100k Frequency [Hz] 1M NO T RE CO MM EN DE 100 100 R 30 mA 100 mA 10 N 20 NE IOUT = 1 mA D Ripple Rejection [dB] VIN = 3.5 V, CL = 1.0 μF 22 40 10 100 60 30 mA 100 mA 60 1M VOUT = 2.5 V 80 IOUT = 1 mA 80 1k 10k 100k Frequency [Hz] W 100 100 DE SI G IOUT = 1 mA 80 10 7. 3 VIN = 2.5 V, CL = 1.0 μF 100 Ripple Rejection [dB] Ripple Rejection [dB] VIN = 1.8 V, CL = 1.0 μF 1M 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series  Reference Data Transient Response Characteristics when Input (Ta = +25°C) 3.0 2.0 2.5 1.0 VOUT 0 0.5 0 −100 −50 0 50 100 150 200 250 300 t [μs] 2.0 −1.0 1.0 −2.0 0.5 −100 −50 2.0 1.5 50 100 150 200 250 300 t [μs] 0 −1.0 1.0 DE Transient Response Characteristics of Load (Ta = +25°C) IOUT [mA] NO T VOUT [V] RE 2. 3 VOUT = 3.3 V VIN = 3.65 V, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA 3.45 150 100 3.40 IOUT 50 3.35 0 VOUT 3.30 −50 3.25 −100 3.20 −150 3.15 −200 −100 −50 0 50 100 150 200 250 300 t [μs] 2. 2 VOUT = 1.5 V VIN = 2.5 V, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA 1.70 150 1.65 100 IOUT 1.60 50 VOUT 1.55 0 1.50 −50 1.45 −100 1.40 −150 1.35 −200 −100 −50 0 50 100 150 200 250 300 t [μs] IOUT [mA] IOUT [mA] CO VOUT [V] MM EN 2. 1 VOUT = 0.8 V VIN = 1.8 V, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 50 mA ↔ 100 mA 1.00 150 0.95 100 IOUT 0.90 50 0.85 0 VOUT 0.80 −50 0.75 −100 0.70 −150 0.65 −200 −100 −50 0 50 100 150 200 250 300 t [μs] VOUT [V] 2. 0 1.0 NE 1.5 1.0 −100 −50 2.0 R 2.5 VOUT 50 100 150 200 250 300 t [μs] 3.0 FO 2.0 3.0 0 4.0 D 2.5 VIN [V] VOUT [V] 3.0 3.5 VIN VOUT 1.5 1. 3 VOUT = 2.0 V IOUT = 30 mA, tr = tf = 5.0 μs, CL = 1.0 μF, CIN = 1.0 μF 4.0 4.0 3.5 VIN VIN [V] 1.5 1.0 3.0 DE SI G VIN W 2.0 VIN [V] VOUT [V] 2.5 1. 2 VOUT = 1.5 V IOUT = 30 mA, tr = tf = 5.0 μs, CL = 1.0 μF, CIN = 1.0 μF 3.5 5.0 N 1. 1 VOUT = 0.8 V IOUT = 30 mA, tr = tf = 5.0 μs, CL = 1.0 μF, CIN = 1.0 μF 3.0 4.0 VOUT [V] 1. 23 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series Transient Response Characteristics of ON / OFF Pin (Ta = +25°C) 1.0 0 0.5 −1 VOUT 3.0 VOUT [V] VON / OFF [V] 1 2.0 1.0 −2 0 −3 −1.0 50 100 t [μs] 150 200 3. 3 VOUT = 3.3 V VIN = 3.65 V, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 100 mA 10.0 8.0 0 −3 VOUT 0 −6 0 50 100 t [μs] 150 200 150 200 −6 −9 VOUT(S) = 3.3 V 1.5 V 0.8 V 2.0 1.5 1.0 0.5 0 2 4 6 CL [μF] 8 10 NO T Figure 17 1 μs VON / OFF VSS tDSC VOUT 12 VOUT × 10% RE 0 CO tDSC [ms] 2.5 MM EN 3.0 DE Output Capacitance vs. Characteristics of Discharge Time (Ta = +25°C) VIN = VOUT + 1.0 V (max.: 3.65 V), IOUT = no load VON / OFF = VOUT + 1.0 V → VSS, tf = 1 μs 24 100 t [μs] −4 D −50 50 −2 R 2.0 0 0 FO VOUT [V] 3 VON /OFF 4.0 −2.0 9 6 6.0 −50 2 NE 0 VOUT 4 W 0 −0.5 −50 VON /OFF 6 VON / OFF [V] 4.0 2 VON /OFF 1.5 VOUT [V] N 3 2.0 4. 3. 2 VOUT = 1.5 V VIN = 2.5 V, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 100 mA 5.0 DE SI G 3. 1 VOUT = 0.8 V VIN = 1.8 V, CL = 1.0 μF, CIN = 1.0 μF, IOUT = 100 mA 2.5 VON / OFF [V] 3. VIN = VOUT + 1.0 V VON / OFF = VOUT + 1.0 V → VSS Figure 18 Measurement Condition of Discharge Time 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series Example of Equivalent Series Resistance vs. Output Current Characteristics (Ta = +25°C) 100 CIN Stable S-11L10 Series ON / OFF 0 0.1 150 IOUT [mA] VOUT CL VSS *1 RESR CL: TDK Corporation C3216X8R1E105K (1.0 μF) W *1. DE SI G VIN N CIN = CL = 1.0 μF RESR [Ω] Figure 20 RE CO MM EN DE D FO R NE Figure 19 NO T 5. 25 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series  Marking Specifications SOT-23-5 N 1. Top view : Product code (Refer to Product name vs. Product code) : Lot number (1) to (3) (4) 4 DE SI G 5 2 3 NE 1 W (1) (2) (3) (4) Product name vs. Product code NO T RE CO 26 S-11L10 Series D type FO Product code (2) (3) V A V B V C V D V E V F V G V H V I V J V K V L V M V N V O V P V Q V R V S V T V U V V V W V X V Y V Z D S-11L10B08-M5T1U S-11L10B09-M5T1U S-11L10B10-M5T1U S-11L10B11-M5T1U S-11L10B12-M5T1U S-11L10B13-M5T1U S-11L10B14-M5T1U S-11L10B15-M5T1U S-11L10B16-M5T1U S-11L10B17-M5T1U S-11L10B18-M5T1U S-11L10B19-M5T1U S-11L10B20-M5T1U S-11L10B21-M5T1U S-11L10B22-M5T1U S-11L10B23-M5T1U S-11L10B24-M5T1U S-11L10B25-M5T1U S-11L10B26-M5T1U S-11L10B27-M5T1U S-11L10B28-M5T1U S-11L10B29-M5T1U S-11L10B30-M5T1U S-11L10B31-M5T1U S-11L10B32-M5T1U S-11L10B33-M5T1U (1) T T T T T T T T T T T T T T T T T T T T T T T T T T MM EN Product Name 1. 2 R S-11L10 Series B type DE 1. 1 Product Name S-11L10D08-M5T1U S-11L10D09-M5T1U S-11L10D10-M5T1U S-11L10D11-M5T1U S-11L10D12-M5T1U S-11L10D13-M5T1U S-11L10D14-M5T1U S-11L10D15-M5T1U S-11L10D16-M5T1U S-11L10D17-M5T1U S-11L10D18-M5T1U S-11L10D19-M5T1U S-11L10D20-M5T1U S-11L10D21-M5T1U S-11L10D22-M5T1U S-11L10D23-M5T1U S-11L10D24-M5T1U S-11L10D25-M5T1U S-11L10D26-M5T1U S-11L10D27-M5T1U S-11L10D28-M5T1U S-11L10D29-M5T1U S-11L10D30-M5T1U S-11L10D31-M5T1U S-11L10D32-M5T1U S-11L10D33-M5T1U (1) T T T T T T T T T T T T T T T T T T T T T T T T T T Product code (2) (3) X A X B X C X D X E X F X G X H X I X J X K X L X M X N X O X P X Q X R X S X T X U X V X W X X X Y X Z 3.65 V INPUT, 150 mA, LOW OUTPUT VOLTAGE (0.8 V) VOLTAGE REGULATOR Rev.2.3_02 S-11L10 Series SNT-6A(H) Top view : Product code (Refer to Product name vs. Product code) : Lot number N 5 (1) to (3) (4) to (6) 4 DE SI G 6 (1) (2) (3) (4) (5) (6) 2 3 W 1 S-11L10 Series B type RE CO S-11L10 Series D type Product Name R S-11L10D08-I6T2U S-11L10D09-I6T2U S-11L10D10-I6T2U S-11L10D11-I6T2U S-11L10D12-I6T2U S-11L10D13-I6T2U S-11L10D14-I6T2U S-11L10D15-I6T2U S-11L10D16-I6T2U S-11L10D17-I6T2U S-11L10D18-I6T2U S-11L10D19-I6T2U S-11L10D20-I6T2U S-11L10D21-I6T2U S-11L10D22-I6T2U S-11L10D23-I6T2U S-11L10D24-I6T2U S-11L10D25-I6T2U S-11L10D26-I6T2U S-11L10D27-I6T2U S-11L10D28-I6T2U S-11L10D29-I6T2U S-11L10D30-I6T2U S-11L10D31-I6T2U S-11L10D32-I6T2U S-11L10D33-I6T2U FO Product code (2) (3) V A V B V C V D V E V F V G V H V I V J V K V L V M V N V O V P V Q V R V S V T V U V V V W V X V Y V Z D S-11L10B08-I6T2U S-11L10B09-I6T2U S-11L10B10-I6T2U S-11L10B11-I6T2U S-11L10B12-I6T2U S-11L10B13-I6T2U S-11L10B14-I6T2U S-11L10B15-I6T2U S-11L10B16-I6T2U S-11L10B17-I6T2U S-11L10B18-I6T2U S-11L10B19-I6T2U S-11L10B20-I6T2U S-11L10B21-I6T2U S-11L10B22-I6T2U S-11L10B23-I6T2U S-11L10B24-I6T2U S-11L10B25-I6T2U S-11L10B26-I6T2U S-11L10B27-I6T2U S-11L10B28-I6T2U S-11L10B29-I6T2U S-11L10B30-I6T2U S-11L10B31-I6T2U S-11L10B32-I6T2U S-11L10B33-I6T2U (1) T T T T T T T T T T T T T T T T T T T T T T T T T T MM EN Product Name 2. 2 DE 2. 1 NE Product name vs. Product code NO T 2. (1) T T T T T T T T T T T T T T T T T T T T T T T T T T Product code (2) (3) X A X B X C X D X E X F X G X H X I X J X K X L X M X N X O X P X Q X R X S X T X U X V X W X X X Y X Z 27 N 2.9±0.2 DE SI G 1.9±0.2 4 2 3 +0.1 0.16 -0.06 D 0.95±0.1 FO R NE 1 W 5 MM EN DE 0.4±0.1 NO T RE CO No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 2.0±0.05 0.25±0.1 +0.2 W DE SI G N ø1.5 -0 4.0±0.1 1.4±0.2 R NE ø1.0 -0 5 Feed direction CO 4 MM EN 3 2 1 DE D FO 3.2±0.2 NO T RE No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. D FO R NE W DE SI G N 12.5max. 9.0±0.3 DE MM EN Enlarged drawing in the central part (60°) CO (60°) ø13±0.2 NO T RE No. MP005-A-R-SD-1.1 SOT235-A-Reel TITLE No. MP005-A-R-SD-1.1 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 6 4 2 +0.05 0.08 -0.02 3 NE 1 W DE SI G 5 N 1.57±0.03 0.5 DE D FO R 0.48±0.02 MM EN 0.2±0.05 NO T RE CO No. PI006-A-P-SD-2.1 TITLE SNT-6A(H)-A-PKG Dimensions No. PI006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. N 4.0±0.1 0.25±0.05 +0.1 4.0±0.1 0.65±0.05 4 MM EN 3 2 1 DE D FO R 1.85±0.05 ø0.5 -0 NE W 2.0±0.05 DE SI G +0.1 ø1.5 -0 5 6 CO Feed direction NO T RE No. PI006-A-C-SD-2.0 TITLE SNT-6A(H)-A-Carrier Tape No. PI006-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. FO R NE W DE SI G N 12.5max. D 9.0±0.3 DE Enlarged drawing in the central part MM EN ø13±0.2 (60°) No. PI006-A-R-SD-1.0 NO T RE CO (60°) TITLE SNT-6A(H)-A-Reel No. PI006-A-R-SD-1.0 ANGLE UNIT QTY. mm ABLIC Inc. 5,000 NE W 0.52 2 DE SI G 1.36 N 0.52 1 R 0.2 0.3 (0.25 mm min. / 0.30 mm typ.) (1.30 mm ~ 1.40 mm) FO 1. 2. 3. 4. 0.03 mm D 1. 2. DE SNT 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package (1.30 mm to 1.40 mm). MM EN Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. (0.25 mm min. / 0.30 mm typ.) (1.30 mm ~ 1.40 mm) NO T RE CO 1. 2. No. PI006-A-L-SD-4.1 TITLE SNT-6A(H)-A -Land Recommendation No. PI006-A-L-SD-4.1 ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not responsible for damages caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not responsible for damages caused by the incorrect information described herein. 4. Be careful to use the products within their specified ranges. Pay special attention to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not responsible for damages caused by failures and / or accidents, etc. that occur due to the use of the products outside their specified ranges. 5. When using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products must not be used or provided (exported) for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not responsible for any provision (export) to those whose purpose is to develop, manufacture, use or store nuclear, biological or chemical weapons, missiles, or other military use. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses. Do not apply the products to the above listed devices and equipments without prior written permission by ABLIC Inc. Especially, the products cannot be used for life support devices, devices implanted in the human body and devices that directly affect human life, etc. Prior consultation with our sales office is required when considering the above uses. ABLIC Inc. is not responsible for damages caused by unauthorized or unspecified use of our products. 9. Semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system must be sufficiently evaluated and applied on customer's own responsibility. MM EN DE D FO R NE W DE SI G N 1. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. CO 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. RE 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party without the express permission of ABLIC Inc. is strictly prohibited. NO T 14. For more details on the information described herein, contact our sales office. 2.2-2018.06 www.ablic.com
S-11L10D30-M5T1U
物料型号:S-11L10系列
器件简介: - 由ABLIC公司开发,使用CMOS技术制造的正电压调节器集成电路。 - 具有低输出电压、高精度输出电压和低电流消耗(典型值为9μA)。
引脚分配: - SOT-23-5封装:VIN(1脚,输入电压引脚)、VSS(2脚,地线)、ON/OFF(3脚,控制开关)、NC(4脚,无连接)、VOUT(5脚,输出电压引脚)。 - SNT-6A(H)封装:VOUT(1脚)、VSS(2和5脚,地线)、NC(3脚,无连接)、ON/OFF(4脚,控制开关)、VIN(6脚)。
参数特性: - 输出电压:0.8V至3.3V,以0.05V步进可调。 - 输入电压:1.2V至3.65V。 - 输出电压精度:±1.0%(0.8V至1.45V输出产品)或±15mV。 - 工作电流:典型值9μA,最大16μA。 - 关闭时电流:典型值0.1μA,最大0.9μA。 - 输出电流:可达150mA。 - 过流保护:内置过流保护电路,防止输出晶体管电流超出容量。 - ON/OFF电路:确保更长的电池寿命,具有放电分流功能。
功能详解: - 设计用于电池供电设备、移动电话和便携设备的电源供应。 - 提供了两种产品类型(B型和D型),具有不同的ON/OFF逻辑和恒流源下拉功能。
应用信息: - 适用于需要低电压和高电流稳定性的应用场合。
封装信息: - 提供SOT-23-5和SNT-6A(H)两种封装类型。
注意事项: - 当输出电流较大时,需要注意封装的功率耗散。 - 绝对最大额定值不应超过,否则产品可能会受到物理损坏。
S-11L10D30-M5T1U 价格&库存
很抱歉,暂时无法提供与“S-11L10D30-M5T1U”相匹配的价格&库存,您可以联系我们找货
