NCT3941S/S-A
Nuvoton
4 Times Linear Fan Driver
NCT3941S/S-A
-I-
Publication Date: Aug, 2010
Revision A4
NCT3941S/S-A
Table of Content1.
GENERAL DESCRIPTION................................................................................. 1
2.
FEATURES ........................................................................................................ 1
3.
APPLICATION ................................................................................................... 1
4.
BLOCK DIAGRAM ............................................................................................. 2
5.
PIN CONFIGURATION AND TYPICAL APPLICATION CIRCUIT...................... 2
6.
PIN DESCRIPTION............................................................................................ 4
7.
FUNCTIONAL DESCRIPTION........................................................................... 4
8.
ELECTRICAL CHARACTERISTIC..................................................................... 7
9.
OPERATING CHARACTERISTICS ................................................................... 9
10.
PACKAGE DIMENSION .................................................................................. 15
11.
ORDERING INFORMATION............................................................................ 16
12.
TOP MARKING SPECIFICATION.................................................................... 16
13.
REVISION HISTORY ....................................................................................... 17
-II-
Revision A4
NCT3941S/S-A
1. GENERAL DESCRIPTION
The NCT3941S/S-A is a simply linear fan driver. It is designed for noise-sensitive or powersensitive applications that require system cooling. The NCT3941S/S-A is a low quiescent current,
low dropout linear regulator which is designed with a P-channel MOSFET to power a DC fan and
delivers output current up to 500mA. The output voltage follows the 4 times on the voltage of
VSET pin to dynamic adjust the DC fan speed. NCT3941S supports enable pin to control the
output voltage. NCT3941S-A supports fully turn-on function. NCT3941S/S-A is available in
SOP8-EP package.
2. FEATURES
z VOUT Follows 4 Times of VSET
z 0.5V Dropout @ 0.5A Output Current
z Continues current up to 500mA, current limit trip threshold 1.6A
z Enable Function (NCT3941S)
z Full Turn On Function (NCT3941S-A)
z Short Circuit and Over Temperature Protections
z Low External Component Count
z Low Cost and Easy to Use
z SOP8 150mil with Exposed Pad Package
z Green Package (Lead Free and Halogen Free)
3. APPLICATION
z Projectors
z Peripheral Add-in Cards
z Motherboards
z Battery Powered Systems
-1-
Revision A4
NCT3941S/S-A
4. BLOCK DIAGRAM
Internal
Regulator
ENABLE
(FON#)
GND
VIN
1
VOUT
Current Limit
3uA
3
Enable/FON#
Logic
VSET
2
Thermal Shutdown
4
R1
6
R1=3R2
R2
(FON#) ARE FOR NCT3941S-A
5. PIN CONFIGURATION AND TYPICAL APPLICATION CIRCUIT
VOUT
1
VIN
2
ENABLE (FON#)
3
VSET
Thermal
Pad
4
8
NC
7
NC
6
GND
5
NC
NCT3941S/ S-A
(Top View)
-2-
Revision A4
NCT3941S/S-A
VCC
ENABLE
(FON#)
VIN
CIN
2.2uF
Input Signal
VOUT
COUT
10uF
VSET
DC Voltage
GND
FAN
Typical Application Circuits
FAN_12V
ATX_12VCC
Cout
10U
Cin
2.2U
Vout
Vin
EN(FON#)
Vset
VEN
SIO_FANOUT(VOLTAGE MODE)
N.C
N.C
GND
N.C
NCT3941S/S-A
VOLTAGE MODE
FAN_12V
ATX_12VCC
Cout
10U
Cin
2.2U
Vout
Vin
EN(FON#)
Vset
VEN
N.C
N.C
GND
N.C
+3.3VC.C
R1
NCT3941S/S-A
1k
SIO_FANOUT(PWM MODE)
R2 100k
C1
1U
PWM MODE
-3-
Revision A4
NCT3941S/S-A
6. PIN DESCRIPTION
NO
PIN NAME
PIN TYPE
DESCRIPTION
1
AO
Voltage output pin. Connect a low ESR ceramic
capacitor (10uF, typically) to ground to assure
stability.
2
POWER
DC power supply input. Connect a bypass
capacitor (2.2uF, typically) is recommended.
I
Enable pin. Output voltage follows 4 times of
VSET pin voltage when ENABLE pin at high
level. Internal pull high is implemented.
NCT3941S
NCT3941S-A
VOUT
1
VIN
2
ENABLE
3
FON#
3
I
Full On mode selection pin. Output voltage
follows 4 times of VSET pin voltage when FON#
pin at high level. The internal power MOSFET full
turns on when FON# pin at low level. Internal pull
Output voltage setting pin. The inputs could be
DC voltage. The input voltage must be larger that
1V.
VSET
4
4
AIN
GND
6
6
GROUND
NC
5, 7, 8
5, 7, 8
PIN TYPE
Output pin (Analog)
AIN
Input pin (Analog)
I
Input pin (Digital)
GROUND
No internal connection.
PIN Attribute
AO
POWER
Power supply ground.
Positive power supply input
Power supply ground
7. FUNCTIONAL DESCRIPTION
7.1 VSET Setting
The output voltage is 4 times of VSET pin voltage. When the VSET voltage exceeds 1V, the output
voltage will follow 4 times of VSET voltage.
-4-
Revision A4
NCT3941S/S-A
7.2 Enable Function
This function is for NCT3941S only. The input voltage level of ENABLE pin can control the internal
regulator turn on or turn off. When pulling this pin below 0.3V, the regulator will be turned off. When
pulling this pin above 1V, the regulator will be turned on.
7.3 Full On Function
This function is for NCT3941S-A only. The input voltage level of FON# can control the internal
regulator fully turn on or following 4 times of VSET voltage. When pulling this pin below 0.3V, the
regulator will be fully turned on. When pulling this pin above 1.6V, the output voltage will follow 4
7.4 Short Circuit Current Limit
The NCT3941S/S-A provides a current limit circuitry for short circuit protection, which monitors the
output current and controls PMOS gate voltage to limit the output current at 200mA.
7.5 Thermal Consideration
The NCT3941S/S-A has a thermal shutdown circuitry to limit the junction temperature. When the
junction temperature exceeds 150°C, the thermal shutdown circuit disables the output, allowing the
device to cool down. The output circuitry is enabled again after the junction temperature cools down
by 30°C, resulting in a pulsed output during continuous thermal overload conditions. The thermal
protection is designed to protect the IC in the event of over temperature conditions. For reliabile
operation, the junction temperature cannot exceed 125°C.
The definition of power dissipation in chip is as following equation:
PD = (VIN - VOUT) x IOUT + VIN x IQ
PD represents the power dissipation.
The power dissipation depends on the thermal resistance of chip package, PCB layout, the airflow
and temperature difference between junction and ambient. Refers to JEDEC51-1, The power
dissipation can be calculated by following equation:
PD(MAX) = (TJ(MAX) - TA) / θJA
Where TJ(MAX) is the maximum operation junction temperature 125℃, TA is the ambient temperature
and theθJA is the junction to ambient thermal resistance. θJA for ESOP-8 package is 75℃/W on
JEDEC51-7 (4 layers, 2S2P) thermal test board with minimum copper area. The maximum power
dissipation at TA = 25℃ can be calculated as:
PD(MAX) = (125℃ - 25℃) / 75℃/W = 1.33W
-5-
Revision A4
NCT3941S/S-A
θ JA highly depends on IC package, PCB layout, the aireflow. Thermal resistance θ JA can be
improved by adding copper under the exposed pad of ESOP-8 while the IC package is fixed. The
copper under the exposed pad of ESOP-8 is an effective heatsink and is useful for improving thermal
conductivity. Figure show the relationship between thermal resistance θ JA vs. copper area on a
standard JEDEC 51-7 (4 layers, 2S2P) thermal test board at TA = 25℃, PCB copper thickness = 2oz.
The 70mm2 copper plane reduce θ JA from 75 ℃ /W to 45 ℃ /W and increases maximum power
disspation from 1.33W to 2.22W.
70mm2 copper area
30mm2 copper area
Minimum copper area
Figure01. Thermal Resistance θJA vs. Copper Area of
ESOP Packages
Figure02. Power dissipation vs. ambient temperature
7.6 VIN Decoupling
To achieve the best results when using the NCT3941S/S-A, decouple the power supply with a 2.2uF
capacitor. Use a high quality ceramic surface mount capacitor if possible. Surface mount components
minimize lead inductance, which improves performance, and ceramic capacitors tend to have
adequate high frequency response for decoupling applications.
7.7 VOUT Stability
To maintain circuit stability and improve transient response over temperature and current, the
NCT3941S/S-A needs a suitable output capacitor. In order to insure the circuit stability, the suitable
output capacitor should be larger than 10uF.
7.8 Layout Consideration
Consider the following points before starting the NCT3941S/S-A layout design.
-6-
Revision A4
NCT3941S/S-A
GND
Thermal pad
COU
T
VOUT
VSET
CIN
VIN VEN
8.
8.1
z
The input bypass capacitor for VIN should be placed as close as possible to the pin with short
and wide connections.
z
The output capacitor for VOUT should be placed close to the pin with short and wide connection
in order to avoid ESR and/or ESL trace inductance.
z
In order to effectively remove heat from the package, properly prepare the thermal land. Apply
solder directly to the package’s thermal pad. The wide traces of component and the side copper
connected to the thermal land pad help to dissipate heat. The thermal land connected to the
ground plane could also be used to help dissipation.
Absolute Maximum Ratings
PARAMETER
RATING
UNIT
Power Supply Voltage
-0.3 to 19V
V
Voltage on Other Pins
-0.3 to 7V
V
Storage Temperature
-50 to 150
°C
Soldering Temperature
Refer to IPC/JEDEC J-STD-020 Specification
ESD
Protection
Human Body Mode
2
kV
Machine Mode
200
V
Latch-up
100
mA
-7-
Revision A4
NCT3941S/S-A
Note: Exposure to conditions beyond those listed under Absolute Maximum Ratings may adversely affect the life and reliability of
the device.
8.2
Thermal Information
ITEM
RATING
UNIT
Internal Limited
W
75
℃/W
RATING
UNIT
Operating Temperature
-20 to 85
°C
Junction Temperature
-20 to 125
°C
Supply Voltage, VCC
8 to 17.6
V
Power Dissipation, PD @ TA=25℃
Package Thermal Resistance, SOP8-EP, θJA
8.3
Recommended Operating Conditions
PARAMETER
8.4
Electrical Characteristics
VIN=13V, VSET=2V, ENABLE=5V, CIN= 2.2uF, COUT=10uF, Ta= -20~85°C (Typical value are at Ta=25°C)
PARAMETER
SYM.
MIN.
VIN
8
TYP.
MAX.
UNIT
17.6
V
CONDITIONS
Supply Input Voltage
ENABLE / FON# Pin
ENABLE / FON# Voltage High
1
V
ENABLE / FON# Voltage Low
ENABLE
Current
FON#
Pin
0.3
Bias
3
V
uA
ENABLE / FON# = 0V
Supply Input Current
Quiescent Current
IQ
3
mA
ENABLE = 5V, VOUT
12V, No Load
Shutdown Current
ISD
100
uA
ENABLE = 0V
Output Voltage
VOUT Voltage / VSET Voltage
3.88
4
4.12
V/V
Load Regulation(NOTE1)
0.5
2
Line Regulation(NOTE1)
0.1
0.5
-8-
VIN = 12V
VSET = 1 ~ 3V
VSET = 3V
10mA≦IOUT≦500mA
Vin = 9V to 14V
Revision A4
NCT3941S/S-A
Output Resistance
0.7
Output Leakage(NOTE2)
Ω
uA
1
5.5
V
IOUT = 500mA
VSET = 4V
ENABLE = 0V
VSET Pin
VSET Voltage
VSET
VSET pin Current
100
nA
Short Circuit Current Limit Protection
Output Current Limit
ILIM
0.7
A
Current Limit Trigger Point
ITR
1.6
A
Short circuit protection
ISH
0.2
A
Thermal Shutdown Temperature
150
°C
Thermal Shutdown Hysteresis
30
°C
NOTE1 : Slew rate will effect transient response, use TR
