CD74AC74M
CD74AC74M
    L3HARRIS
    SOIC-14
    IC FF D-TYPE DUAL 1BIT 14SOIC
CD74AC74M 数据手册
CD54AC74, CD74AC74 DUAL POSITIVE-EDGE-TRIGGERED D-TYPE FLIP-FLOPS WITH CLEAR AND PRESET SCHS231D – SEPTEMBER 1998 – REVISED DECEMBER 2002 D D D D D D CD54AC74 . . . F PACKAGE CD74AC74 . . . E OR M PACKAGE (TOP VIEW) AC Types Feature 1.5-V to 5.5-V Operation and Balanced Noise Immunity at 30% of the Supply Speed of Bipolar F, AS, and S, With Significantly Reduced Power Consumption Balanced Propagation Delays ±24-mA Output Drive Current – Fanout to 15 F Devices SCR-Latchup-Resistant CMOS Process and Circuit Design Exceeds 2-kV ESD Protection Per MIL-STD-883, Method 3015 1CLR 1D 1CLK 1PRE 1Q 1Q GND 1 14 2 13 3 12 4 11 5 10 6 9 7 8 VCC 2CLR 2D 2CLK 2PRE 2Q 2Q description/ordering information The ’AC74 dual positive-edge-triggered devices are D-type flip-flops. A low level at the preset (PRE) or clear (CLR) inputs sets or resets the outputs, regardless of the levels of the other inputs. When PRE and CLR are inactive (high), data at the data (D) input meeting the setup time requirements is transferred to the outputs on the positive-going edge of the clock pulse. Clock triggering occurs at a voltage level and is not related directly to the rise time of the clock pulse. Following the hold-time interval, data at the D input can be changed without affecting the levels at the outputs. ORDERING INFORMATION PDIP – E 55°C to 125°C –55°C ORDERABLE PART NUMBER PACKAGE† TA SOIC – M Tube CD74AC74E Tube CD74AC74M Tape and reel CD74AC74M96 TOP-SIDE MARKING CD74AC74E AC74M CDIP – F Tube CD54AC74F3A CD54AC74F3A † Package drawings, standard packing quantities, thermal data, symbolization, and PCB design guidelines are available at www.ti.com/sc/package. FUNCTION TABLE (each flip-flop) INPUTS OUTPUTS PRE CLR CLK D Q Q L H X X H L H L X X L H L L X X H‡ H‡ H H ↑ H H L H H ↑ L L H H H L X Q0 Q0 ‡ This configuration is nonstable; that is, it does not persist when PRE or CLR returns to its inactive (high) level. Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. Copyright  2002, Texas Instruments Incorporated PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. On products compliant to MIL-PRF-38535, all parameters are tested unless otherwise noted. On all other products, production processing does not necessarily include testing of all parameters. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 1 CD54AC74, CD74AC74 DUAL POSITIVE-EDGE-TRIGGERED D-TYPE FLIP-FLOPS WITH CLEAR AND PRESET SCHS231D – SEPTEMBER 1998 – REVISED DECEMBER 2002 logic diagram, each flip-flop (positive logic) PRE CLK C C C Q TG C C C C D TG TG TG C C C Q CLR absolute maximum ratings over operating free-air temperature range (unless otherwise noted)† Supply voltage range, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . – 0.5 V to 6 V Input clamp current, IIK (VI < 0 or VI > VCC) (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±20 mA Output clamp current, IOK (VO < 0 or VO > VCC) (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±50 mA Continuous output current, IO (VO = 0 to VCC) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±50 mA Continuous current through VCC or GND . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±100 mA Package thermal impedance, θJA (see Note 2): E package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80°C/W M package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86°C/W Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . – 65°C to 150°C † Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTES: 1. The input and output voltage ratings may be exceeded if the input and output current ratings are observed. 2. The package thermal impedance is calculated in accordance with JESD 51-7. 2 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 CD54AC74, CD74AC74 DUAL POSITIVE-EDGE-TRIGGERED D-TYPE FLIP-FLOPS WITH CLEAR AND PRESET SCHS231D – SEPTEMBER 1998 – REVISED DECEMBER 2002 recommended operating conditions (see Note 3) –55°C to 125°C TA = 25°C VCC Supply voltage VIH High-level input voltage UNIT MIN MAX MIN MAX MIN MAX 1.5 5.5 1.5 5.5 1.5 5.5 VCC = 1.5 V VCC = 3 V 1.2 1.2 1.2 2.1 2.1 2.1 VCC = 5.5 V VCC = 1.5 V 3.85 VIL Low-level input voltage VI VO Input voltage 0 Output voltage 0 IOH IOL High-level output current ∆t/∆v Input transition rise or fall rate 3.85 VCC = 3 V VCC = 5.5 V Low-level output current –40°C to 85°C V 3.85 0.3 0.3 0.3 0.9 0.9 0.9 1.65 VCC VCC 1.65 0 0 V VCC VCC V 1.65 0 0 VCC VCC V V VCC = 4.5 V to 5.5 V VCC = 4.5 V to 5.5 V –24 –24 –24 mA 24 24 24 mA VCC = 1.5 V to 3 V VCC = 3.6 V to 5.5 V 50 50 50 20 20 20 ns/V NOTE 3: All unused inputs of the device must be held at VCC or GND to ensure proper device operation. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs, literature number SCBA004. electrical characteristics over recommended operating free-air temperature range (unless otherwise noted) PARAMETER TEST CONDITIONS VCC MIN IOH = –50 µA VOH VI = VIH or VIL IOH = –4 mA IOH = –24 mA IOH = –50 mA† IOH = –75 mA† IOL = 50 µA VOL II ICC VI = VIH or VIL VI = VCC or GND VI = VCC or GND, –55°C to 125°C TA = 25°C MAX MIN –40°C to 85°C MAX MIN 1.5 V 1.4 1.4 1.4 3V 2.9 2.9 2.9 4.5 V 4.4 4.4 4.4 3V 2.58 2.4 2.48 4.5 V 3.94 3.7 3.8 5.5 V UNIT MAX V 3.85 5.5 V 3.85 1.5 V 0.1 0.1 0.1 3V 0.1 0.1 0.1 4.5 V 0.1 0.1 0.1 IOL = 12 mA IOL = 24 mA IOL = 50 mA† 3V 0.36 0.5 0.44 4.5 V 0.36 0.5 0.44 IOL = 75 mA† 5.5 V 5.5 V 5.5 V IO = 0 5.5 V Ci V 1.65 1.65 ±0.1 ±1 ±1 µA 4 80 40 µA 10 10 10 pF † Test one output at a time, not exceeding 1-second duration. Measurement is made by forcing indicated current and measuring voltage to minimize power dissipation. Test verifies a minimum 50-Ω transmission-line drive capability at 85°C and 75-Ω transmission-line drive capability at 125°C. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 3 CD54AC74, CD74AC74 DUAL POSITIVE-EDGE-TRIGGERED D-TYPE FLIP-FLOPS WITH CLEAR AND PRESET SCHS231D – SEPTEMBER 1998 – REVISED DECEMBER 2002 timing requirements over recommended operating free-air temperature range, VCC = 1.5 V (unless otherwise noted) –55°C to 125°C MIN fclock Clock frequency tw Pulse duration tsu Setup time th trec Hold time Recovery time, before CLK↑ –40°C to 85°C MAX MIN UNIT MAX 9 10 MHz PRE or CLR low 50 44 CLK 56 49 Data 44 39 Data after CLK↑ 0 0 ns CLR↑ or PRE↑ 34 30 ns ns ns PRE or CLR inactive ns timing requirements over recommended operating free-air temperature range, VCC = 3.3 V ± 0.3 V (unless otherwise noted) (see Figure 1) –55°C to 125°C MIN fclock –40°C to 85°C MAX Clock frequency MIN 79 90 PRE or CLR low 5.6 4.9 CLK 6.3 5.5 Data 4.9 4.3 tw Pulse duration tsu Setup time th trec Hold time Data after CLK↑ Recovery time, before CLK↑ CLR↑ or PRE↑ UNIT MAX MHz ns ns PRE or CLR inactive ns 0 0 ns 4.7 4.1 ns timing requirements over recommended operating free-air temperature range, VCC = 5 V ± 0.5 V (unless otherwise noted) (see Figure 1) –55°C to 125°C MIN 4 fclock Clock frequency tw Pulse duration tsu Setup time th trec Hold time Data after CLK↑ Recovery time, before CLK↑ CLR↑ or PRE↑ MAX –40°C to 85°C MIN 110 PRE or CLR low 125 MHz 4 3.5 CLK 4.5 3.9 Data 3.5 3.1 0 0 ns 2.7 2.4 ns PRE or CLR inactive POST OFFICE BOX 655303 UNIT MAX • DALLAS, TEXAS 75265 ns ns ns CD54AC74, CD74AC74 DUAL POSITIVE-EDGE-TRIGGERED D-TYPE FLIP-FLOPS WITH CLEAR AND PRESET SCHS231D – SEPTEMBER 1998 – REVISED DECEMBER 2002 switching characteristics over recommended operating free-air temperature range, VCC = 1.5 V, CL = 50 pF (unless otherwise noted) (see Figure 1) PARAMETER fmax tPLH tPHL tPLH tPHL FROM (INPUT) TO (OUTPUT) –55°C to 125°C MIN –40°C to 85°C MAX 9 CLK Q or Q PRE or CLR Q or Q MIN UNIT MAX 10 MHz 125 114 125 114 132 120 144 131 ns ns switching characteristics over recommended operating free-air temperature range, VCC = 3.3 V ± 0.3 V (unless otherwise noted) (see Figure 1) PARAMETER fmax tPLH tPHL tPLH tPHL FROM (INPUT) TO (OUTPUT) –55°C to 125°C MIN –40°C to 85°C MIN 3.5 14 3.6 12.7 3.5 14 3.6 12.7 3.7 14.7 3.8 13.4 4 16.1 4.1 14.6 79 CLK Q or Q PRE or CLR Q or Q UNIT MAX MAX 90 MHz ns ns switching characteristics over recommended operating free-air temperature range, VCC = 5 V ± 0.5 V (unless otherwise noted) (see Figure 1) PARAMETER fmax tPLH tPHL tPLH tPHL FROM (INPUT) TO (OUTPUT) –55°C to 125°C MIN –40°C to 85°C MAX 110 CLK Q or Q PRE or CLR Q or Q MIN UNIT MAX 125 MHz 2.5 10 2.6 9.1 2.5 10 2.6 9.1 2.6 10.5 2.7 9.5 2.9 11.5 3 10.4 ns ns operating characteristics, TA = 25°C PARAMETER Cpd TYP Power dissipation capacitance 55 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 UNIT pF 5 CD54AC74, CD74AC74 DUAL POSITIVE-EDGE-TRIGGERED D-TYPE FLIP-FLOPS WITH CLEAR AND PRESET SCHS231D – SEPTEMBER 1998 – REVISED DECEMBER 2002 PARAMETER MEASUREMENT INFORMATION S1 R1 = 500 Ω† From Output Under Test 2 × VCC Open GND CL = 50 pF (see Note A) R2 = 500 Ω† TEST S1 tPLH/tPHL tPLZ/tPZL tPHZ/tPZH Open 2 × VCC GND tw VCC † When VCC = 1.5 V, R1 = R2 = 1 kΩ Input 50% VCC 50% VCC 0V LOAD CIRCUIT VOLTAGE WAVEFORMS PULSE DURATION CLR Input VCC Reference Input VCC 50% VCC 50% VCC 0V 0V tsu trec Data 50% Input 10% VCC 50% VCC CLK 90% VOLTAGE WAVEFORMS RECOVERY TIME tf VCC 50% VCC 50% VCC tPLH tPHL 50% 10% 90% 90% tr tPHL Out-of-Phase Output VCC 50% VCC 10% 0 V VOLTAGE WAVEFORMS SETUP AND HOLD AND INPUT RISE AND FALL TIMES 0V In-Phase Output 90% tr 0V Input th 90% VOH 50% VCC 10% VOL tf Output Waveform 1 S1 at 2 × VCC (see Note B) tPLH 50% VCC 10% tf 50% 10% 90% tr VOH VOL VOLTAGE WAVEFORMS PROPAGATION DELAY AND OUTPUT TRANSITION TIMES VCC Output Control 50% VCC 50% VCC 0V tPLZ tPZL 50% VCC tPHZ tPZH Output Waveform 2 S1 at GND (see Note B) ≈VCC 20% VCC VOL 50% VCC VOH 80% VCC ≈0 V VOLTAGE WAVEFORMS OUTPUT ENABLE AND DISABLE TIMES NOTES: A. CL includes probe and test-fixture capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control. C. All input pulses are supplied by generators having the following characteristics: PRR ≤ 1 MHz, ZO = 50 Ω, tr = 3 ns, tf = 3 ns. Phase relationships between waveforms are arbitrary. D. For clock inputs, fmax is measured with the input duty cycle at 50%. E. The outputs are measured one at a time with one input transition per measurement. F. tPLH and tPHL are the same as tpd. G. tPZL and tPZH are the same as ten. H. tPLZ and tPHZ are the same as tdis. Figure 1. Load Circuit and Voltage Waveforms 6 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 PACKAGE OPTION ADDENDUM www.ti.com 6-Feb-2020 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Op Temp (°C) Device Marking (4/5) CD54AC74F3A ACTIVE CDIP J 14 1 TBD Call TI N / A for Pkg Type -55 to 125 CD54AC74F3A CD74AC74E ACTIVE PDIP N 14 25 Green (RoHS & no Sb/Br) NIPDAU N / A for Pkg Type -55 to 125 CD74AC74E CD74AC74M ACTIVE SOIC D 14 50 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 AC74M CD74AC74M96 ACTIVE SOIC D 14 2500 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 AC74M CD74AC74M96E4 ACTIVE SOIC D 14 2500 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 AC74M CD74AC74M96G4 ACTIVE SOIC D 14 2500 Green (RoHS & no Sb/Br) NIPDAU Level-1-260C-UNLIM -55 to 125 AC74M (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
CD74AC74M 价格&库存
很抱歉,暂时无法提供与“CD74AC74M”相匹配的价格&库存,您可以联系我们找货
