TMR1383S
TMR1383S
    MDT(多维)
    TO236-3
    TMR SENSOR OMNI 26G 3-40V 0.6MA
TMR1383S 数据手册
Datasheet V1.1 TMR1383 High-Voltage TMR Omnipolar Switch General Description TMR1383 is a digital omnipolar magnetic switch that integrates TMR and CMOS technology in order to provide a magnetically triggered digital switch with high sensitivity, high speed, and low power consumption. It is designed for use in applications that are both power-critical and performance-demanding. It contains a push-pull TMR sensor bridge and CMOS signal processing circuitry within the same package, including an on-chip TMR voltage generator for precise magnetic sensing, a TMR voltage amplifier and comparator plus a Schmitt trigger to provide switching hysteresis for noise rejection, and an open-drain output. An internal band gap regulator is used to provide a temperature compensated supply voltage for internal circuits, permitting a wide range of supply voltages from 3V up to 40V. The TMR1383 draws only 0.6mA resulting in low-power operation. It has fast response, accurate switching points, excellent thermal stability, and immunity to stray field interference. It is available in an SOT23-3 package (P/N TMR1383S). Features and Benefits  Tunneling Magnetoresistance (TMR) Technology  Low Power Consumption < 0.6mA  High Frequency Response ≥ 100KHz  Omnipolar Operation  In-plane X-Axis sensing  High Supply Voltages of 40V and 30V Reverse Voltage  Open-Drain Output  Excellent Thermal Stability  High Tolerance to External Magnetic Field Interference Applications  Utility Meters including Water, Gas, and Heat Meters  Proximity Switches TMR1383S  Position and Speed Sensing  Motor and Fan Control  Power Window 1/5 Datasheet V1.1 Block Diagram Pin Configuration Pin No. Pin Name SOT23-3 Pin Function VCC 1 Supply Voltage GND 3 Ground VOUT 2 Output SOT23-3 Absolute Maximum Ratings Parameter Symbol Limit Unit Supply Voltage VCC 40 V Reverse Supply Voltage VRCC 30 V Output Current IOUTSINK 25 mA Magnetic Flux Density B 4000 G ESD level(HBM) VESD 4 kV Operating Temperature TA -40 ~125 °C Storage Temperature Tstg -50 ~ 150 °C Electrical Characteristics (VCC=24V, TA=25°C) Parameter Symbol Conditions Min Typ. Max Unit Supply Voltage VCC Operating 3 24 40 V Output Stress Voltage Vstress 40 V Output Leakage Current Ileak Output Turn-off Resistance Roff Output Low Voltage Vol OUT=High, Vcc=24V, Vout=24V OUT=High 3 μA 10 MΩ OUT=Low, Vcc=24V, Isink=25mV Output Turn-on Resistance Ron OUT=Low Supply Current ICC Output Open Response Frequency F 0.4 0.5 0.3 V 10 Ω 0.6 mA 100 kHz Note: A 1kOhm pull-up resistor is connected between VCC and VOUT, and a 0.1μF capacitor is connected between VCC and GND during all tests in the table above. 2/5 Datasheet V1.1 Magnetic Characteristics (VCC=24V, TA=25°C) Parameters Symbol Operate Point Release Point Hysteresis Min Typ. Max Units BOPS 26 G BOPN -26 G BRPS 19 G BRPN -19 G BH 7 G Voltage and Temperature Characteristics Temperature Performance (VCC=24V) 40 VCC(V) -40 RPN BH-N(G) Temperature 125℃ 20 OPN 105℃ -40 0 -20 85℃ RP-N(G) RPS 65℃ OP-N(G) -20 0 45℃ BH-S(G) OPS 25℃ 0 20 0℃ RP-S(G) -20℃ 20 40 -40℃ OP-S(G) Switching Points (G) Switching Points (G) Voltage Performance (TA=25°C) 40 Output Behavior vs. Magnetic Polarity Magnetic Polarity South North Test Conditions Output B > BOPS Low (On) 0< B < BRPS High (Off) B < BOPN Low (On) 0 > B > BRPN High (Off) Note: when power is turned on under zero magnetic field, the output is “High”. Sensing Direction of Magnetic Field Magnetic Flux Application Information The output of the TMR1383 switches low (turns on) when a magnetic field parallel to the TMR sensor exceeds the operate point threshold |BOPS| or |BOPN|. When the magnetic field is reduced below the release point |BRPS| or |BRPN|, the device output goes high (turns off). The difference between the magnetic operate point and release point is the hysteresis BH of the device. It is strongly recommended that an external bypass capacitor be connected in close proximity to the device between the supply and ground to reduce noise. The typical value of the external capacitor is 0.1μF. 3/5 Datasheet V1.1 Package Information SOT23-3 package drawing TMR Sensor Position Top view and side view (unit: mm) 4/5 Datasheet V1.1 MultiDimension Technology Co., Ltd. Address:No.7 Guangdong Road, Zhangjiagang Free Trade Zone, Jiangsu, 215634, China Web: www.dowaytech.com/en Email: info@dowaytech.com The information provided herein by MultiDimension Technology Co., Ltd. (hereinafter MultiDimension) is believed to be accurate and reliable. Publication neither conveys nor implies any license under patent or other industrial or intellectual property rights. MultiDimension reserves the right to make changes to product specifications for the purpose of improving product quality, reliability, and functionality. MultiDimension does not assume any liability arising out of the application and use of its products. MultiDimension’s customers using or selling this product for use in appliances, devices, or systems where malfunction can reasonably be expected to result in personal injury do so at their own risk and agree to fully indemnify MultiDimension for any damages resulting from such applications. 5/5
TMR1383S 价格&库存
很抱歉,暂时无法提供与“TMR1383S”相匹配的价格&库存,您可以联系我们找货
