SRA-SP-001
SRA-SP-001
    COMUS(康姆斯)
SRA-SP-001 数据手册
Compact Ferrous Metal Sensor - Non powered Part Number : SRA-SP-001 Product Data Sheet PICTURE DIMENSIONS SENSING FACE Drawings not to scale All dimensions in mm nominal SPECIFICATION Contact Form / Style Activation distance Switching Voltage Switching Current Switching Power Carry Current Breakdown Voltage Contact Resistance Operating Frequency Operating Temperature Case Material Cable Normally Open, closes in presence of ferrous metal mm 6 Max Volts AC/DC 140 / 200 Max Amps 0.5 Max Watts 10 Max Amps 2.75 Min Volts DC 225 Max mOhms 100 Max Hz 100 Celsius - 40° to 85° ABS Plastic 2 x 0.14mm² Grey PVC insulated, Brown/ White Applications Include Options Gate closed detection. Robotics sensing. Automated production lines. Safety guards. Top, front or base sensing direction. 105° G/F Nylon version available. Did you know we also sell? Float Switches Pressure Switches Magnets Proximity Switches Reed Switches Reed Relays Solid State Relays Custom cable types, cable lengths, connectors or crimp terminals available. If you do not see what you need, just ask, as there is a strong possibility we can do it ! Rev. No. Revision Note Date Signature 1 Datasheet 01-10-14 ML As part of the company policy of continued product improvement, specifications may change without notice. Our sales office will be pleased to help you with the latest information on this product range and the details of our full design and manufacturing service. All products are supplied to our standard conditions of sale unless otherwise agreed in writing. Phone : +44 (0)1255 862236 www.comus-group.com Fax: +44 (0)1255 862014 ©2014 Copyright Comus Europe Ltd, Unit 7, Rice Bridge Industrial Estate, Thorpe - Le - Soken, Essex, CO16 0HL, ENGLAND. USA: Comus International:+1 973 777 6900, Belgium: Comus Belgium BVBA: +32 (0)12 390400
SRA-SP-001 价格&库存
很抱歉,暂时无法提供与“SRA-SP-001”相匹配的价格&库存,您可以联系我们找货
