MC60-12GM50-1N-V1
MC60-12GM50-1N-V1
    PEPPERL+FUCHS(倍加福)
    M12
    MAGNETIC SEN 60MM NAMUR
MC60-12GM50-1N-V1 数据手册
Magnetic field sensor MC60-12GM50-1N-V1 < 60 mm flush with permanent magnet DM 60-31-15 Dimensions 17 63 40 4 M12x1 LED Release date: 2020-10-19 Date of issue: 2020-10-19 Filename: 183132_eng.pdf M12x1 Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance NAMUR sn Installation Assured operating distance 60 mm flush in non-magnetic metal sa Output type 10 ... 48.6 mm 2-wire Nominal ratings Nominal voltage Uo 8.2 V (Ri approx. 1 kΩ) Switching frequency f 0 ... 5000 Hz Current consumption Magnet detected ≥ 2.5 mA Magnet not detected ≤ 1 mA Switching state indicator LED, yellow Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Magnetic field sensor MC60-12GM50-1N-V1 Technical Data Functional safety related parameters MTTFd 4382 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity NAMUR EN 60947-5-6:2000 Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 IEC 60947-5-2:2007 IEC 60947-5-2 AMD 1:2012 Approvals and certificates ATEX approval Equipment protection level Gb TÜV 01 ATEX 1718 FM approval Control drawing 116-0165 Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector plug M12 x 1 , 4-pin Housing material stainless steel 1.4404 / AISI 316L Sensing face stainless steel 1.4404 / AISI 316L Degree of protection IP67 General information Use in the hazardous area see instruction manuals Connection 1 L+ 2,3,4 L- Release date: 2020-10-19 Date of issue: 2020-10-19 Filename: 183132_eng.pdf Connection Assignment 1 4 2 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Magnetic field sensor MC60-12GM50-1N-V1 Additional Information Magnet DM 60-31-15 Magnet DM 25-32-07 Release date: 2020-10-19 Date of issue: 2020-10-19 Filename: 183132_eng.pdf Accessories BF 12 Mounting flange, 12 mm EXG-12 Quick mounting bracket with dead stop DM 60-31-15 Permanent magnet for magnetic field sensors DM 25-32-07 Permanent magnet for magnetic field sensors V1-G-N-2M-PUR Female cordset single-ended M12 straight A-coded, 2-pin, PUR cable blue, NAMUR V1-W-N-2M-PUR Female cordset single-ended M12 angled A-coded, 2-pin, PUR cable blue, NAMUR Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
MC60-12GM50-1N-V1 价格&库存
很抱歉,暂时无法提供与“MC60-12GM50-1N-V1”相匹配的价格&库存,您可以联系我们找货
