MSS Standard
Series Product Sheet
Security Contacts have been made with a
decades-old technology called the Reed switch.
Reed switches have three inherent weaknesses
when used in security contacts. They are (1)
Easily defeated with magnets, (2) Prone to
permanent contact weld failure (from lightning
and power surges), and (3) fragile (made mostly
of glass, they are subject to damage even when
packaged as security contacts).
Concealed/Recessed
Surface Mount
The MAGNASPHERE line of security sensors
provides a solution to all of these issues.
Utilizing the the patented, revolutionary
MAGNASPHERE® BMS switch renders the MSS
products virtually unbreakable, and highly
resistant to permanent contact welding and
outsider magnet defeat, allowing
MAGNASPHERE to offer a lifetime replacement
warranty.
MSS contacts are available in both the
traditional Closed Loop (contact closed when
magnet is present) as well as the more Secure
Open Loop (contact open when magnet is
present) electrical configuration. This is the
same configuration required for other life safety
devices such as smoke and fire alarms, and has
long been the recommend configuration by
most knowledgeable security professionals.
Overhead Door
FEATURES
• Made with MAGNASPHERE® BMS switch
technology
• Won't break
• Resistant to contact welding
• Resistant to outside defeat
• Security industry's BEST warranty
• Universal mounting
• Cost competitive
• Increases RMR
Wireless
PATENTED DESIGN
#5977873, #RE39731, #6506987, #6303845, #6603378, and Patents Pending
MAGNASPHERE CORP. | 23777 Stone Ridge Dr., Suite 160, Waukesha, WI 53188
tel. 262.347.0711 | fax 262.347.0710 | www.MAGNASPHERE.com
Reed vs. MAGNASPHERE
Security contacts are made with a decades-old technology called the Reed switch.
Reed switches have three inherent weaknesses when used in security contacts: (1) Easily defeated with magnets,
(2) Prone to permanent contact weld failure (from lightning and power surges), and (3) fragile (made mostly of glass,
they are subject to damage even when packaged as security contacts).
CLOSED
Door Frame
FAILED: NO ALARM
Defeat
Magnet
SECURE: NO ALARM
CLOSED
Door Frame
Door
Door Opened
Magnet
Reed contacts operate on magnetic fields.
Most contacts are Closed in the secure
position (Closed Loop) when the door is
closed and the magnet is near the switch.
NO ALARM
Reed switch contacts are globally magnetic:
they will respond to the strongest magnetic
field anywhere around the contact –– not
solely to the door magnet. When compromised,
reed contacts will still send secure signals.
FAILED: NO ALARM
WELDED
CLOSED
CLOSED
Door Frame
Door
Door Frame
Magnet
When closed reed contacts are exposed to
power surges such as lightning strikes, they
are prone to permanent contact welding.
© MAGNASPHERE CORP.
Introducing a defeat
magnet OUTSIDE
the door will keep
the reed contacts
closed, allowing
an intruder to enter
without alerting
the security system.
They FAIL SECURE.
Once contacts have
welded closed, they
remain in that state
though the door is open.
They FAIL SECURE.
Door Opened
Reed contacts operate by magnetic induction,
so they are not attracted to the door magnet.
www.MAGNASPHERE.com
The patented, award-winning MAGNASPHERE switch technology was designed as
a security device which over comes the deficiencies of reed contacts. The MAGNASPHERE
switch is (1) Resistant to magnetic defeat and tamper, (2) Resistant to permanent contact welding from lightning
and power surges, and (3) Robust, all metal welded construction is virtually unbreakable.
SECURE: NO ALARM
Defeat
Magnet
ALARM
CLOSED
OPEN
The Door is Closed
MAGNASPHERE security sensors' magnet
ball contact is open in the secure position
(Open Loop) when the door is closed and
the door magnet is near the switch.
The Door is Open
MAGNASPHERE’s contact is a spherical
magnet and operates in a defined activation
zone directed toward the door magnet.
NO ALARM
ALARM
CLOSED
OPEN
The Door is Closed
A defeat magnet
introduced OUTSIDE
the door will have no
effect on the ball
contact. When the
door is opened, the
contact will close,
and the SYSTEM
WILL ALARM.
The Door is Open
Because the magnet
ball contact will not
weld, when the door
is opened the
contact will close
and the SYSTEM
WILL ALARM.
MAGNASPHERE Security Sensors are Open
Loop and highly resistant to contact welding
from power surges and lightning strikes.
© MAGNASPHERE CORP.
www.MAGNASPHERE.com
很抱歉,暂时无法提供与“MSS-63S-W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1184.379951+153.05991
- 10+981.6882410+126.86564
- 30+904.9250130+116.94536
- 100+835.59712100+107.98597
