MZC1-2V2PS-KU0
MZC1-2V2PS-KU0
    SICK
    Cylinder
MZC1-2V2PS-KU0 数据手册
Product data sheet MZC1-2V2PS-KU0 MZC1 SENSORS FOR C-SLOT CYLINDERS MZC1-2V2PS-KU0 | MZC1 SENSORS FOR C-SLOT CYLINDERS A B C D E F Ordering information Type Part no. MZC1-2V2PS-KU0 1059738 Other models and accessories www.sick.com/MZC1 Detailed technical data Features H I J K L M N O P Q R S T Cylinder type C-slot Cylinder types with adapter SMC rail CDQ2 SMC rail ECDQ2 Round body cylinder Profile cylinders and tie-rod cylinders Housing length 23.7 mm Switching output PNP Switching frequency 1,000 Hz Output function NO Electrical wiring DC 3-wire Enclosure rating IP68, IP69K 1) 2) 1) 2)  According to EN 60529 (IP 67 / IP 68).  According to DIN 40050 (IP 69K). Mechanics/electronics Supply voltage 10 V DC ... 30 V DC Power consumption 8 mA 1) Voltage drop ≤ 2.5 V Continuous current Ia ≤ 100 mA Protection class III Response sensitivity, typ. 2.2 mT Overrun distance, typ. 4 mm Hysteresis, typ. ≤ 0.8 mT Reproducibility ≤ 0.1 mT 2) Reverse polarity protection ✔ Short-circuit protection ✔ 1) 2) 2  Without load.  Ub and Ta constant. MAGNETIC CYLINDER SENSORS | SICK Product data sheet | 2021-11-27 10:37:30 Subject to change without notice MZC1-2V2PS-KU0 | MZC1 SENSORS FOR C-SLOT CYLINDERS Power-up pulse protection ✔ Ambient operating temperature –30 °C ... +80 °C Shock and vibration resistance 30 g, 11 ms / 10 ... 55 Hz, 1 mm EMC According to EN 60947-5-2 Connection type Cable, 3-wire, 2 m Connection type Detail Conductor cross-section 0.09 mm² Cable diameter Ø 2.2 mm Bending radius With fixed installation > 2 x cable diameter For flexible use > 5 x cable diameter Cable outlet Axial Material Housing Plastic Cable PUR UL File No. 1) 2) NRKH.E181493 & NRKH7.E181493  Without load.  Ub and Ta constant. Safety-related parameters MTTFD 2,461 years DCavg 0 % TM (mission time) 20 years Classifications ECl@ss 5.0 27270104 ECl@ss 5.1.4 27270104 ECl@ss 6.0 27270104 ECl@ss 6.2 27270104 ECl@ss 7.0 27270104 ECl@ss 8.0 27270104 ECl@ss 8.1 27270104 ECl@ss 9.0 27270104 ECl@ss 10.0 27270104 ECl@ss 11.0 27270104 ETIM 5.0 EC002544 ETIM 6.0 EC002544 ETIM 7.0 EC002544 ETIM 8.0 EC002544 UNSPSC 16.0901 39122230 2021-11-27 10:37:30 | Product data sheet  Subject to change without notice MAGNETIC CYLINDER SENSORS | SICK 3 MZC1-2V2PS-KU0 | MZC1 SENSORS FOR C-SLOT CYLINDERS A B C D E F Installation note Insert sensor Torque typical 0.5 Nm LED AF 1.5 Connection diagram Cd-001 BN BK BU + (L+) NO - (M) Dimensional drawing (Dimensions in mm (inch)) Cable 4.7 (0.19) H I J K L M N O P Q R S T Tighten screw 2.9 (0.11) 3 2 2.55 (0.1) Sensor element 23.7 (0.93) L 1 A ①  Connection ②  Fixing screw SW 1.5 ③  Display LED 4 L A 1059738 MZC1-2V2PS-KU0 2 m 31.5 3 1059740 MZC1-2V2PS-KW0 2 m 31.5 3 1059743 MZC1-2V2NS-KU0 2 m 31.5 3 1059755 MZC1-4V3PS-KU0 2 m 31.5 3 1059756 MZC1-4V3NS-KU0 2 m 31.5 3 1063549 MZC1-4V3PO-KU0 2 m 31.5 3 1086137 MZC1-2V2DS-KUA 3 m 31.5 2 MAGNETIC CYLINDER SENSORS | SICK Product data sheet | 2021-11-27 10:37:30 Subject to change without notice MZC1-2V2PS-KU0 | MZC1 SENSORS FOR C-SLOT CYLINDERS L A 1059739 MZC1-2V2PS-KUB 5 m 31.5 3 1059741 MZC1-2V2PS-KWB 5 m 31.5 3 1068831 MZC1-2Z2PS-KUB 5 m 31.5 3 1087248 MZC1-2V2DS-KUB 5 m 31.5 2 Recommended accessories Other models and accessories www.sick.com/MZC1 Brief description Type Part no. Mounting bracket for integrated profile cylinder/tie-rod cylinder, zinc diecast, mounting hardware included BEF-KHZ-PC1 2076170 1 piece, Mounting bracket on round body cylinder with piston diameter of 12 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum BEF-KHZ-RC-12 2077673 1 piece, Mounting bracket on round body cylinder with piston diameter of 16 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum BEF-KHZ-RC-16 2077672 1 piece, Mounting bracket on round body cylinder with piston diameter of 20 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum BEF-KHZ-RC-20 2077671 1 piece, Mounting bracket on round body cylinder with piston diameter of 25 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum BEF-KHZ-RC-25 2077670 1 piece, Mounting bracket on round body cylinder with piston diameter of 32 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum BEF-KHZ-RC-32 2077669 1 piece, Mounting bracket on round body cylinder with piston diameter of 40 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum BEF-KHZ-RC-40 2077668 1 piece, Mounting bracket on round body cylinder with piston diameter of 50 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum BEF-KHZ-RC-50 2077667 1 piece, Mounting bracket on round body cylinder with piston diameter of 63 mm, ambient temperature min 0 °C max 50 °C, plastic, Aluminum BEF-KHZ-RC-63 2077666 1 piece, Mounting bracket on round body cylinder with piston diameter of 1 mm ... 130 mm, ambient temperature min –30 °C max 80 °C, stainless steel, Aluminum BEF-KHZ-RC1-130 2077686 1 piece, Mounting bracket on round body cylinder with piston diameter of 1 mm ... 25 mm, ambient temperature min –30 °C max 80 °C, stainless steel, Aluminum BEF-KHZ-RC1-25 2077685 YM08U130002K1823A 2122277 Brackets for cylinder sensors Plug connectors and cables Head A: male connector, M8, 3-pin, straight, A-coded Cable: Sensor/actuator cable 2021-11-27 10:37:30 | Product data sheet  Subject to change without notice MAGNETIC CYLINDER SENSORS | SICK 5 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
MZC1-2V2PS-KU0 价格&库存
很抱歉,暂时无法提供与“MZC1-2V2PS-KU0”相匹配的价格&库存,您可以联系我们找货
