MMB70-12GH50-1N-V1
MMB70-12GH50-1N-V1
    PEPPERL+FUCHS(倍加福)
    M12
    MAGNETIC FIELD SENSOR 70MM
MMB70-12GH50-1N-V1 数据手册
Magnetic field sensor MMB70-12GH50-1N-V1 < Comfort series < 70 mm flush Dimensions 60 41 17 49 4 M12 x 1 ø 10.5 8 LED (4x) Release date: 2021-10-20 Date of issue: 2021-10-21 Filename: 70108302_eng.pdf M12 x 1 Technical Data General specifications Switching function Normally open (NO) Output type Rated operating distance NAMUR sn 5 ... 70 mm Installation flush in non-magnetic metal Output type 2-wire Nominal ratings Nominal voltage Uo 8.2 V (Ri approx. 1 kΩ) Switching frequency f 0 ... 1000 Hz Current consumption Magnet detected ≥ 2.5 mA Magnet not detected ≤ 1 mA Switching state indicator LED, yellow Functional safety related parameters Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 1 Magnetic field sensor MMB70-12GH50-1N-V1 Technical Data MTTFd 3477 a Mission Time (TM) 20 a Diagnostic Coverage (DC) 0% Compliance with standards and directives Standard conformity NAMUR EN 60947-5-6:2000 Standards EN 60947-5-2:2007 EN 60947-5-2/A1:2012 Approvals and certificates IECEx approval Equipment protection level Ga IECEx TUN 20.0007 Equipment protection level Da IECEx TUN 20.0007 ATEX approval Equipment protection level Ga TÜV 20 ATEX 241336 Equipment protection level Da TÜV 20 ATEX 241336 Ambient conditions Ambient temperature -25 ... 70 °C (-13 ... 158 °F) Mechanical specifications Connection type Connector plug M12 x 1 , 4-pin Housing material Stainless steel 1.4404 / AISI 316L Sensing face Stainless steel 1.4404 / AISI 316L Degree of protection IP67 General information Use in the hazardous area see instruction manuals Connection 1 L+ 4 L- Release date: 2021-10-20 Date of issue: 2021-10-21 Filename: 70108302_eng.pdf Connection Assignment 1 4 2 3 Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 2 Magnetic field sensor MMB70-12GH50-1N-V1 Additional Information Magnet DM 60-31-15 Magnet DM 25-32-07 Release date: 2021-10-20 Date of issue: 2021-10-21 Filename: 70108302_eng.pdf Accessories BF 12 Mounting flange, 12 mm DM 60-31-15 Permanent magnet for magnetic field sensors DM 25-32-07 Permanent magnet for magnetic field sensors Refer to "General Notes Relating to Pepperl+Fuchs Product Information". Pepperl+Fuchs Group USA: +1 330 486 0001 Germany: +49 621 776 1111 fa-info@de.pepperl-fuchs.com www.pepperl-fuchs.com fa-info@us.pepperl-fuchs.com Singapore: +65 6779 9091 fa-info@sg.pepperl-fuchs.com 3
MMB70-12GH50-1N-V1 价格&库存
很抱歉,暂时无法提供与“MMB70-12GH50-1N-V1”相匹配的价格&库存,您可以联系我们找货
