TR4-SFM01C
TR4-SFM01C
    SICK
    SENSOR REED SWITCH M12-8
TR4-SFM01C 数据手册
Product data sheet TR4-SFM01C TR4 Direct NON-CONTACT SAFETY SWITCHES TR4-SFM01C | TR4 Direct NON-CONTACT SAFETY SWITCHES A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. TR4-SFM01C 6044650 Other models and accessories www.sick.com/TR4_Direct Detailed technical data Features System part Sensor and actuator Sensor principle Transponder Number of safe outputs 2 Safe switch on distance Sao 15 mm Safe switch off distance Sar 35 mm Active sensor surfaces 2 Actuation directions 5 Retaining force ≤ 10 N Boundary area indication ✔ Coding Universally coded Safety-related parameters Safety integrity level SIL3 (IEC 61508) SILCL3 (EN 62061) Category Category 4 (EN ISO 13849) Performance level PL e (EN ISO 13849) PFHD (mean probability of a dangerous failure per hour) 1.119 x 10-9 (EN ISO 13849) TM (mission time) 20 years (EN ISO 13849) Type Type 4 (EN ISO 14119) Actuator coding level Low coding level (EN ISO 14119) Classification in compliance with IEC/ EN 60947-5-3 PDF-M Safe state in the event of a fault At least one safety-related semiconductor output (OSSD) is in the OFF state. Functions Safe series connection With Flexi Loop (with diagnostics) With T-connector (without diagnostics) Interfaces Connection type Cable with plug M12, 8-pin Length of cable 0.2 m Cable material PVC 2 SAFETY SWITCHES | SICK Product data sheet | 2021-05-18 12:26:14 Subject to change without notice TR4-SFM01C | TR4 Direct NON-CONTACT SAFETY SWITCHES Long connecting cable ≤ 200 m Status display ✔ Electrical data Protection class III (EN 50178) Classification according to cULus Class 2 Supply voltage Vs 24 V DC (20.4 V DC ... 26.4 V DC) Power consumption 50 mA Type of output Self-monitoring semiconductor outputs (OSSDs) Output current ≤ 200 mA Response time 60 ms 1) Enable time 360 ms 2) Risk time 60 s 3) Switch-on time 2.5 s 4) Electrical life 10 x 106 switching cycles 1) 2) 3) 4)  In a safe series connection, each downstream safety switch increases the system response time. More response times can be found in the operating instructions.  Response time on approach to the enable zone.  Detection time for external faults (e.g., short-circuit or cross-circuit of output signal switching devices). Follow the detailed information in the operating instructions.  After application of the supply voltage to the safety switch. Mechanical data Design Rectangular Dimensions (W x H x D) 25 mm x 88 mm x 20 mm Weight + 112 g Housing material Valox® DR48 Ambient data Enclosure rating IP69K (IEC 60529) Ambient operating temperature –10 °C ... +55 °C Vibration resistance 10 Hz ... 55 Hz, 3.5 mm (IEC 60068-2-6) Shock resistance 30 g, 11 ms (EN 60068-2-27) Classifications ECl@ss 5.0 27272403 ECl@ss 5.1.4 27272403 ECl@ss 6.0 27272403 ECl@ss 6.2 27272403 ECl@ss 7.0 27272403 ECl@ss 8.0 27272403 ECl@ss 8.1 27272403 ECl@ss 9.0 27272403 ECl@ss 10.0 27272403 ECl@ss 11.0 27272403 ETIM 5.0 EC001829 2021-05-18 12:26:14 | Product data sheet  Subject to change without notice SAFETY SWITCHES | SICK 3 TR4-SFM01C | TR4 Direct NON-CONTACT SAFETY SWITCHES EC001829 ETIM 7.0 EC001829 UNSPSC 16.0901 39122205 Dimensional drawing (Dimensions in mm (inch)) 18.5 5.1 4.6 4.6 20.7 68.3 10.7 7.1 6.8 4.6 72.9 78.0 18.5 88.1 78.0 58.0 62.5 88.1 25.0 82.6 20.7 25.0 10.7 4.6 5.1 4.6 13.4 H I J K L M N O P Q R S T ETIM 6.0 Plug version 10.0 M12 x 1 9.7 Response range Side approaches Safe switch-on distance Sao 15 mm Alignment offset [mm] A B C D E F Area for the boundary area indication Switch-on distance [mm] If the actuator moves laterally in relation to the surface of the sensor, a minimum distance of 9 mm must be maintained. This distance will prevent premature triggering due to the side approach areas. 4 SAFETY SWITCHES | SICK Product data sheet | 2021-05-18 12:26:14 Subject to change without notice TR4-SFM01C | TR4 Direct NON-CONTACT SAFETY SWITCHES Connection diagram 2 1 8 3 7 4 6 5 1 Aux output (not safe) 2 Voltage supply 24 V DC 3 Not connected 4 Enable input for OSSD 2 5 OSSD 1 6 OSSD 2 7 Voltage supply 0 V DC 8 Enable input for OSSD 1 Connection single sensor 1 2 3 ①  Safe evaluation unit ②  Connecting cable with M12 female connector, 8-pin and flying leads (e.g. YF2A18-xxxUA5LEAX) ③  TR4 Direct transponder safety switch (e.g., TR4-Sxx01C) 2021-05-18 12:26:14 | Product data sheet  Subject to change without notice SAFETY SWITCHES | SICK 5 TR4-SFM01C | TR4 Direct NON-CONTACT SAFETY SWITCHES A B C D E F H I J K L M N O P Q R S T Series connection Series connection with T-piece (without diagnostics) 1 2 7 7 7 6 6 6 3 4 3 4 3 5 ①  Safe evaluation unit ②  Connecting cable with M12 female connector, 4-pin and flying leads (e.g. YF2A14-xxxVB3XLEAX) ③  STR1-XXA T-connector ④  Connection cable with 4-pin, M12 male connector and 4-pin, M12 female connector (e.g., YF2A14-xxxVB3M2A14) ⑤  MLP1-XXT end connector ⑥  Connection cable with 8-pin, M12 male connector and 8-pin, M12 female connector (e.g., YF2A18-xxxUA5M2A18) ⑦  TR4 Direct transponder safety switch (e.g., TR4-Sxx01C) Recommended accessories Other models and accessories www.sick.com/TR4_Direct Brief description Type Part no. Head A: female connector, M12, 8-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 2 m YF2A18-020UA5XLEAX 2095652 Head A: female connector, M12, 8-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 5 m YF2A18-050UA5XLEAX 2095653 Head A: female connector, M12, 8-pin, straight, A-coded Head B: Flying leads Cable: Sensor/actuator cable, PUR, halogen-free, unshielded, 10 m YF2A18-100UA5XLEAX 2095654 Plug connectors and cables 6 SAFETY SWITCHES | SICK Product data sheet | 2021-05-18 12:26:14 Subject to change without notice Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
TR4-SFM01C 价格&库存
很抱歉,暂时无法提供与“TR4-SFM01C”相匹配的价格&库存,您可以联系我们找货
