CM30-16BAP-KW1
CM30-16BAP-KW1
    SICK
    Cylinder,Threaded
CM30-16BAP-KW1 数据手册
Product data sheet CM30-16BAP-KW1 CM CAPACITIVE PROXIMITY SENSORS CM30-16BAP-KW1 | CM CAPACITIVE PROXIMITY SENSORS A B C D E F H I J K L M N O P Q R S T Ordering information Type Part no. CM30-16BAP-KW1 6028411 Other models and accessories www.sick.com/CM Illustration may differ Detailed technical data Features Housing Cylindrical thread design Thread size M30 x 1.5 Diameter Ø 30 mm Sensing range Sn 2 mm ... 16 mm Safe sensing range Sa 11.52 mm Installation type Flush Switching frequency 10 Hz Connection type Cable, 2-wire, 2 m 1) Output function NC or NO Electrical wiring AC 2-wire Adjustment Potentiometer (Sensitivity) Enclosure rating IP67 2) 1) 2)  Do not bend below 0 °C.  According to EN 60529. Mechanics/electronics Supply voltage 20 V AC ... 250 V AC Ripple ≤ 10 % 1) Voltage drop ≤ 10 V DC 2) Current consumption 10 mA 3) Time delay before availability ≤ 100 ms Hysteresis 4 % ... 20 % 1) 2) 3) 4) 5) 6)  Of Ub.  At Ia max.  Without load.  Of Sr.  Ub and Ta constant.  In EMC critical applications, conducted interference levels may lie within the frequency range of the oscillator. This can cause changes to the output signal. (See operating instructions.). 2 PROXIMITY SENSORS | SICK Product data sheet | 2021-09-01 09:25:52 Subject to change without notice CM30-16BAP-KW1 | CM CAPACITIVE PROXIMITY SENSORS Reproducibility ≤ 5 % 4) 5) Temperature drift (of Sr) ± 10 % EMC According to EN 60947-5-2 6) Continuous current Ia ≤ 500 mA Cable material PVC Conductor size 0.5 mm² Reverse polarity protection ✔ Power-up pulse protection ✔ Shock and vibration resistance 30 g, 11 ms / 10 ... 55 Hz, 1 mm Ambient operating temperature –25 °C ... +80 °C Housing material Plastic, PBT Housing length 63.6 mm Thread length 50 mm Tightening torque, max. ≤ 7.5 Nm Items supplied Mounting nut, PA12 plastic (2x) Screwdriver for potentiometer adjustment (1 x) 1) 2) 3) 4) 5) 6)  Of Ub.  At Ia max.  Without load.  Of Sr.  Ub and Ta constant.  In EMC critical applications, conducted interference levels may lie within the frequency range of the oscillator. This can cause changes to the output signal. (See operating instructions.). Safety-related parameters MTTFD 815 years DCavg 0 % TM (mission time) 20 years Reduction factors Note The values are reference values which may vary Metal 1 Water 1 PVC Approx. 0.4 Oil Approx. 0.25 Glass 0.6 Ceramics 0.5 Alcohol 0.7 Wood 0.2 ... 0.7 Installation note Remark Associated graphic see "Installation" B 30 mm C 30 mm D 48 mm 2021-09-01 09:25:52 | Product data sheet  Subject to change without notice PROXIMITY SENSORS | SICK 3 CM30-16BAP-KW1 | CM CAPACITIVE PROXIMITY SENSORS A B C D E F H I J K L M N O P Q R S T Classifications ECl@ss 5.0 27270102 ECl@ss 5.1.4 27270102 ECl@ss 6.0 27270102 ECl@ss 6.2 27270102 ECl@ss 7.0 27270102 ECl@ss 8.0 27270102 ECl@ss 8.1 27270102 ECl@ss 9.0 27270102 ECl@ss 10.0 27270102 ECl@ss 11.0 27270102 ETIM 5.0 EC002715 ETIM 6.0 EC002715 ETIM 7.0 EC002715 ETIM 8.0 EC002715 UNSPSC 16.0901 39122230 Installation note Flush installation F B C D Connection diagram Cd-013 BN BU 4 L1 N PROXIMITY SENSORS | SICK Product data sheet | 2021-09-01 09:25:52 Subject to change without notice CM30-16BAP-KW1 | CM CAPACITIVE PROXIMITY SENSORS Characteristic curve CM30, Flush installation mm (inch) 20 (0.79) 10 (0.39) 0 –10 (–0.39) –20 (–0.79) 0 5 (0.2) 10 15 20 25 30 (0.39) (0.59) (0.79) (0.98) (1.18) Distance in mm (inch) Dimensional drawing (Dimensions in mm (inch)) CM30, flush, cable 4 3 M30 x 1.5 2 1 50 (1.97) 15.4 63.6 (2.50) (0.61) ①  Connection ②  Display LED ③  Potentiometer ④  Fastening nuts (2 x); 34 mm hex, plastic Recommended accessories Other models and accessories www.sick.com/CM Brief description Type Part no. Mounting plate for M30 sensors, steel, zinc coated, without mounting hardware BEF-WG-M30 5321871 Mounting bracket for M30 sensors, steel, zinc coated, without mounting hardware BEF-WN-M30 5308445 Mounting brackets and plates 2021-09-01 09:25:52 | Product data sheet  Subject to change without notice PROXIMITY SENSORS | SICK 5 Online data sheet SICK at a glance SICK is one of the leading manufacturers of intelligent sensors and sensor solutions for industrial applications. A unique range of products and services creates the perfect basis for controlling processes securely and efficiently, protecting individuals from accidents and preventing damage to the environment. We have extensive experience in a wide range of industries and understand their processes and requirements. With intelligent sensors, we can deliver exactly what our customers need. In application centers in Europe, Asia and North America, system solutions are tested and optimized in accordance with customer specifications. All this makes us a reliable supplier and development partner. Comprehensive services complete our offering: SICK LifeTime Services provide support throughout the machine life cycle and ensure safety and productivity. For us, that is “Sensor Intelligence.” Worldwide presence: Contacts and other locations – www.sick.com SICK AG | Waldkirch | Germany | www.sick.com
CM30-16BAP-KW1 价格&库存
很抱歉,暂时无法提供与“CM30-16BAP-KW1”相匹配的价格&库存,您可以联系我们找货
