74LVT16244BEV/G:55
74LVT16244BEV/G:55
    NEXPERIA(安世)
    VFBGA56
    IC BUF NON-INVERT 3.6V 56VFBGA
74LVT16244BEV/G:55 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia 74LVT16244B; 74LVTH16244B 3.3 V 16-bit buffer/driver; 3-state Rev. 11 — 1 March 2012 Product data sheet 1. General description The 74LVT16244B; 74LVTH16244B is a high-performance BiCMOS product designed for VCC operation at 3.3 V. This device is a 16-bit buffer and line driver featuring non-inverting 3-state bus outputs. The device can be used as four 4-bit buffers, two 8-bit buffers, or one 16-bit buffer. 2. Features and benefits           16-bit bus interface 3-state buffers Output capability: +64 mA and 32 mA TTL input and output switching levels Input and output interface capability to systems at 5 V supply Bus hold data inputs eliminate need for external pull-up resistors to hold unused inputs Power-up 3-state Live insertion and extraction permitted No bus current loading when output is tied to 5 V bus Latch-up protection  JESD78B Class II exceeds 500 mA  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVT16244BDL 40 C to +85 C SSOP48 plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 40 C to +85 C TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 74LVT16244BEV 40 C to +85 C VFBGA56 plastic very thin fine-pitch ball grid array package; 56 balls; body 4.5  7  0.65 mm SOT702-1 74LVT16244BBX 40 C to +125 C HXQFN60 plastic compatible thermal enhanced extremely SOT1134-2 thin quad flat package; no leads; 60 terminals; body 4  6  0.5 mm 74LVTH16244BDL 74LVT16244BDGG 74LVTH16244BDGG 74LVTH16244BBX 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state 4. Functional diagram 47 46 44 43 1A0 1Y0 1A1 1Y1 1A2 1Y2 1A3 1Y3 2 36 3 35 5 33 6 32 3A0 3Y0 3A1 3Y1 3A2 3Y2 3A3 3Y3 1 1OE 48 2OE 25 3OE 24 4OE 13 14 16 1A0 1A1 17 1A2 1A3 1 1OE 25 3OE 2A0 2A1 41 2A0 2Y0 8 30 4A0 4Y0 2A2 19 2A3 40 2A1 2Y1 9 29 4A1 4Y1 3A0 20 3A1 38 37 48 2A2 2A3 2Y2 2Y3 2OE 11 12 27 26 24 4A2 4A3 4Y2 4Y3 3A2 22 3A3 4A0 23 4A1 4A2 4OE 4A3 EN1 EN2 EN3 EN4 47 46 Fig 1. Logic symbol 74LVT_LVTH16244B Product data sheet 1 2 3 44 5 43 6 41 40 1 2 8 9 38 11 37 12 36 35 1 3 13 14 33 16 32 17 30 29 1 4 19 20 27 22 26 23 001aae506 Pin numbers are shown for SSOP48 and TSSOP48 packages only. 1 1Y0 1Y1 1Y2 1Y3 2Y0 2Y1 2Y2 2Y3 3Y0 3Y1 3Y2 3Y3 4Y0 4Y1 4Y2 4Y3 001aae231 Pin numbers are shown for SSOP48 and TSSOP48 packages only. Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 2 of 18 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state 5. Pinning information 5.1 Pinning 74LVT16244B 74LVTH16244B 1OE 1 48 2OE 1Y0 2 47 1A0 1Y1 3 46 1A1 GND 4 45 GND 1Y2 5 44 1A2 1Y3 6 43 1A3 VCC 7 42 VCC 2Y0 8 41 2A0 2Y1 9 40 2A1 GND 10 39 GND 2Y2 11 38 2A2 2Y3 12 37 2A3 3Y0 13 36 3A0 3Y1 14 35 3A1 GND 15 34 GND 3Y2 16 33 3A2 3Y3 17 32 3A3 VCC 18 31 VCC 4Y0 19 30 4A0 4Y1 20 29 4A1 GND 21 28 GND 4Y2 22 27 4A2 4Y3 23 26 4A3 4OE 24 74LVT16244B ball A1 74LVTH16244B index area 1 2 3 4 5 6 A B C D E F G H J K 25 3OE 001aaj057 Transparent top view 001aae507 Fig 3. Pin configuration SOT370-1 (SSOP48) and SOT362-1 (TSSOP48) 74LVT_LVTH16244B Product data sheet Fig 4. Pin configuration SOT702-1 (VFBGA56) All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 3 of 18 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state terminal 1 index area D1 A32 A1 D5 A31 A30 B20 A29 B19 A28 B18 A27 D4 D8 A26 A2 A25 B1 B17 B2 B16 A3 A24 A4 A23 B15 B3 A5 A22 74LVT16244B 74LVTH16244B B4 B14 A6 A21 B5 B13 B6 B12 A20 A7 A8 A19 B7 B11 A9 A18 GND(1) A10 D6 D2 A11 B8 A12 B9 A13 B10 A14 A15 D7 A17 A16 D3 001aaj056 Transparent top view (1) This is not a supply pin, the substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad however if it is soldered the solder land should remain floating or be connected to GND. Fig 5. Pin configuration SOT1134-2 (HXQFN60) 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 4 of 18 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state 5.2 Pin description Table 2. Symbol Pin description Pin Description SOT370-1 and SOT362-1 SOT702-1 SOT1134-2 1, 48, 25, 24 A1, A6, K6, K1 A30, A29, A14, A13 output enable input (active LOW) 1Y0 to 1Y3 2, 3, 5, 6 B2, B1, C2, C1 B20, A31, D5, D1 data output 2Y0 to 2Y3 8, 9, 11, 12 D2, D1, E2, E1 A2, B2, B3, A5 data output 1OE, 2OE, 3OE, 4OE 3Y0 to 3Y3 13, 14, 16, 17 F1, F2, G1, G2 A6, B5, B6, A9 data output 4Y0 to 4Y3 19, 20, 22, 23 H1, H2, J1, J2 D2, D6, A12, B8 data output GND 4, 10, 15, 21, 28, 34, 39, 45 B3, B4, D3, D4, G3, G4, J3, J4 A32, A3, A8, A11, A16, A19, A24, A27 ground (0 V) VCC 7, 18, 31, 42 C3, C4, H3, H4 A1, A10, A17, A26 supply voltage 1A0 to 1A3 47, 46, 44, 43 B5, B6, C5, C6 B18, A28, D8, D4 data input 2A0 to 2A3 41, 40, 38, 37 D5, D6, E5, E6 A25, B16, B15, A22 data input 3A0 to 3A3 36, 35, 33, 32 F6, F5, G6, G5 A21, B13, B12, A18 data input 4A0 to 4A3 30, 29, 27, 26 H6, H5, J6, J5 D3, D7, A15, B10 data input n.c. A2, A3, A4, A5, K2, K3, K4, K5 A4, A7, A20, A23, B1, B4, B7, B9, B11, B14, B17, B19 not connected - 6. Functional description Table 3. Function table[1] Control Input Output nOE nAn nYn L L L L H H H X Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage VO output voltage output in OFF-state or HIGH-state IIK input clamping current IOK output clamping current 74LVT_LVTH16244B Product data sheet Conditions Min Max Unit 0.5 +4.6 V [1] 0.5 +7.0 V [1] 0.5 +7.0 V VI < 0 V 50 - mA VO < 0 V 50 - mA All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 5 of 18 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state Table 4. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit IO output current output in LOW-state - 128 mA output in HIGH-state 64 - mA Tstg storage temperature Tj junction temperature Ptot total power dissipation 65 +150 C [2] - 150 C (T)SSOP48 package [3] - 500 mW VFBGA56 package [4] - 1000 mW HXQFN60 package [4] - 1000 mW Tamb = 40 C to +85 C; [1] The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. [2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. [3] Above 60 C the value of Ptot derates linearly with 5.5 mW/K. [4] Above 70 C the value of Ptot derates linearly with 1.8 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC Conditions Min Typ Max Unit supply voltage 2.7 - 3.6 V VI input voltage 0 - 5.5 V VIH HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V IOH HIGH-level output current 32 - - mA IOL LOW-level output current none - - 32 mA current duty cycle  50 %; fi  1 kHz - - 64 mA in free-air 40 - +85 C - - 10 ns/V Tamb ambient temperature t/V input transition rise and fall rate outputs enabled 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 6 of 18 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 Conditions Min Typ Max Unit VCC = 2.7 V; IIK = 18 mA 1.2 0.85 C[1] VIK input clamping voltage VOH HIGH-level output voltage IOH = 100 A; VCC = 2.7 V to 3.6 V VOL - V VCC  0.2 VCC - V IOH = 8 mA; VCC = 2.7 V 2.4 2.5 - V IOH = 32 mA; VCC = 3.0 V 2.0 2.3 - V IOL = 100 A - 0.07 0.2 V IOL = 24 mA - 0.3 0.5 V IOL = 16 mA - 0.25 0.4 V IOL = 32 mA - 0.3 0.5 V IOL = 64 mA - 0.4 0.55 V - 0.1 10 A - 0.1 1.0 A VI = VCC - 0.1 1 A VI = 0 V 5 0.1 - A LOW-level output voltage VCC = 2.7 V VCC = 3.0 V II input leakage current all input pins; VCC = 0 V or 3.6 V; VI = 5.5 V control pins; VCC = 3.6 V; VI = VCC or GND data pins; VCC = 3.6 V [2] - 0.1 100 A 75 135 - A VCC = 3 V; VI = 2.0 V - 135 75 A bus hold LOW overdrive current nAn input; VCC = 0 V to 3.6 V; VI = 3.6 V 500 - - A IBHHO bus hold HIGH overdrive current nAn input; VCC = 0 V to 3.6 V; VI = 3.6 V - - 500 A ILO output leakage current output in HIGH-state when VO > VCC; VO = 5.5 V; VCC = 3.0 V - 50 125 A IO(pu/pd) power-up/power-down output current VCC  1.2 V; VO = 0.5 V to VCC; VI = GND or VCC; nOE = don’t care - 1 100 A IOZ OFF-state output current VCC = 3.6 V; VI = VIH or VIL IOFF power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V IBHL bus hold LOW current VCC = 3 V; VI = 0.8 V IBHH bus hold HIGH current IBHLO ICC supply current [3] [4] output HIGH: VO = 3.0 V - 0.5 5 A output LOW: VO = 0.5 V 5 +0.5 - A - 0.07 0.12 mA VCC = 3.6 V; VI = GND or VCC; IO = 0 A output HIGH output LOW outputs disabled ICC additional supply current 74LVT_LVTH16244B Product data sheet per input pin; VCC = 3.0 V to 3.6 V; one input at VCC  0.6 V other inputs at VCC or GND All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 - 4.0 6.0 mA [5] - 0.07 0.12 mA [6] - 0.1 0.2 mA © NXP B.V. 2012. All rights reserved. 7 of 18 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit CI input capacitance VI = 0 V or 3.0 V - 3 - pF CO output capacitance outputs disabled; VO = 0 V or 3.0 V - 9 - pF [1] Typical values are measured at VCC = 3.3 V and at Tamb = 25 C. [2] Unused pins at VCC or GND. [3] This is the bus hold overdrive current required to force the input to the opposite logic state. [4] This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to VCC = 3.3 V  0.3 V a transition time of 100 s is permitted. This parameter is valid for Tamb = 25 C only. [5] ICC is measured with outputs pulled to VCC or GND. [6] This is the increase in supply current for each input at the specified voltage level other than VCC or GND. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8. Symbol Parameter Conditions Min Typ Max Unit VCC = 2.7 V - - 4.0 ns VCC = 3.0 V to 3.6 V 0.5 1.8 3.2 ns VCC = 2.7 V - - 4.0 ns VCC = 3.0 V to 3.6 V 0.5 1.7 3.2 ns VCC = 2.7 V - - 5.0 ns VCC = 3.0 V to 3.6 V 1.0 2.3 4.0 ns VCC = 2.7 V - - 5.3 ns VCC = 3.0 V to 3.6 V 1.0 2.1 4.0 ns VCC = 2.7 V - - 5.0 ns VCC = 3.0 V to 3.6 V 1.0 3.2 4.5 ns VCC = 2.7 V - - 4.4 ns VCC = 3.0 V to 3.6 V 1.0 2.9 4.0 ns Tamb = 40 C to +85 C[1] tPLH tPHL nAn to nYn; see Figure 6 HIGH to LOW propagation delay nAn to nYn; see Figure 6 OFF-state to HIGH propagation delay tPZH OFF-state to LOW propagation delay tPZL tPHZ tPLZ [1] LOW to HIGH propagation delay nOE to nYn; see Figure 7 nOE to nYn; see Figure 7 HIGH to OFF-state propagation delay nOE to nYn; see Figure 7 LOW to OFF-state propagation delay nOE to nYn; see Figure 7 Typical values are measured at VCC = 3.3 V and Tamb = 25 C. 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 8 of 18 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state 11. Waveforms VI nAn input VM VM GND tPLH tPHL VOH VM nYn output VM VOL mna171 Measurements points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. Propagation delay input (nAn) to output (nYn) VI nOE input VM GND tPZL tPLZ 3.0 V VM nYn output VX VOL t PZH t PHZ VOH nYn output VY VM 0V 001aae464 Measurements points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 7. 3-state output enable and disable times Table 8. Measurement points Input Output VM VM VX VY 1.5 V 1.5 V VOL + 0.3 V VOH  0.3 V 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 9 of 18 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state VI tW 90 % negative pulse VM 0V VI tf tr tr tf 90 % positive pulse 0V VM 10 % VM VM 10 % tW VEXT VCC VI PULSE GENERATOR RL VO DUT RT CL RL 001aae235 Test data is given in Table 9. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 8. Test circuit for measuring switching times Table 9. Test data Input Load VEXT VI fi tW tr, tf CL RL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL 2.7 V  10 MHz 500 ns  2.5 ns 50 pF 500  GND 6V open 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 10 of 18 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state 12. Package outline SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 D E A X c y HE v M A Z 25 48 Q A2 A1 A (A 3) θ pin 1 index Lp L 24 1 detail X w M bp e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2.8 0.4 0.2 2.35 2.20 0.25 0.3 0.2 0.22 0.13 16.00 15.75 7.6 7.4 0.635 10.4 10.1 1.4 1.0 0.6 1.2 1.0 0.25 0.18 0.1 0.85 0.40 8o o 0 Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT370-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-118 Fig 9. Package outline SOT370-1 (SSOP48) 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 11 of 18 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 E D A X c HE y v M A Z 48 25 Q A2 (A 3) A1 pin 1 index A θ Lp L 1 detail X 24 w M bp e 2.5 0 5 mm scale DIMENSIONS (mm are the original dimensions). UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z θ mm 1.2 0.15 0.05 1.05 0.85 0.25 0.28 0.17 0.2 0.1 12.6 12.4 6.2 6.0 0.5 8.3 7.9 1 0.8 0.4 0.50 0.35 0.25 0.08 0.1 0.8 0.4 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT362-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig 10. Package outline SOT362-1 (TSSOP48) 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 12 of 18 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state VFBGA56: plastic very thin fine-pitch ball grid array package; 56 balls; body 4.5 x 7 x 0.65 mm B D SOT702-1 A ball A1 index area A E A2 A1 detail X e1 1/2 C ∅v M C A B ∅w M C b e y1 C e y K J H e G F e2 E D 1/2 e C X B A ball A1 index area 1 2 3 4 5 6 DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 b D E e e1 e2 v w y y1 mm 1 0.3 0.2 0.7 0.6 0.45 0.35 4.6 4.4 7.1 6.9 0.65 3.25 5.85 0.15 0.08 0.08 0.1 OUTLINE VERSION SOT702-1 REFERENCES IEC JEDEC JEITA 0 2.5 5 mm scale EUROPEAN PROJECTION ISSUE DATE 02-08-08 03-07-01 MO-225 Fig 11. Package outline SOT702-1 (VFBGA56) 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 13 of 18 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state HXQFN60: plastic compatible thermal enhanced extremely thin quad flat package; no leads; 60 terminals; body 4 x 6 x 0.5 mm A B D SOT1134-2 terminal 1 index area A A2 E A1 detail X e2 b e1 L1 L A11 B10 A17 A10 eR eT y y1 C D3 D7 A16 B8 C eT 1/2 e D2 D6 C A B C eR e C A B C v w v w e B11 B7 Eh e3 e4 1/2 e B17 B1 A1 terminal 1 index area A26 D5 D1 A32 B20 B18 A27 Dh D8 D4 eT eR X K eT eR 0 5 mm Dimensions Unit mm A A1 A2 b max 0.50 0.08 0.42 0.28 nom 0.05 0.40 0.23 min 0.02 0.38 0.18 D Dh E Eh e e1 e2 e3 e4 eR 4.1 4.0 3.9 1.95 1.85 1.75 6.1 6.0 5.9 3.95 3.85 3.75 0.5 1.0 2.5 3.0 4.5 0.5 eT K L L1 v w 0.25 0.28 0.195 0.49 0.20 0.23 0.145 0.1 0.15 0.18 0.095 y 0.05 0.08 y1 0.1 sot1134-2_po References Outline version IEC JEDEC JEITA SOT1134-2 --- --- --- European projection Issue date 11-08-15 Fig 12. Package outline SOT1134-2 (HXQFN60) 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 14 of 18 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date 74LVT_LVTH16244B v.11 20120301 Modifications: • • Change notice Supersedes Product data sheet - 74LVT_LVTH16244B v.10 For type number 74LVT16244BBX and 74LVTH16244BBX the sot code has changed to SOT1134-2. 74LVT_LVTH16244B v.10 20111122 Modifications: Data sheet status Product data sheet - 74LVT_LVTH16244B v.9 Legal pages updated. 74LVT_LVTH16244B v.9 20110620 Product data sheet - 74LVT_LVTH16244B v.8 74LVT_LVTH16244B v.8 20100322 Product data sheet - 74LVT_LVTH16244B v.7 74LVT_LVTH16244B v.7 20090326 Product data sheet - 74LVT_LVTH16244B v.6 74LVT_LVTH16244B v.6 20081113 Product data sheet - 74LVT_LVTH16244B v.5 74LVT_LVTH16244B v.5 20060321 Product data sheet - 74LVT16244B v.4 74LVT16244B v.4 20021031 Product specification - 74LVT16244B v.3 74LVT16244B v.3 19981007 Product specification - 74LVT16244B v.2 74LVT16244B v.2 19980219 Product specification - - 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 15 of 18 74LVT16244B; 74LVTH16244B NXP Semiconductors 3.3 V 16-bit buffer/driver; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74LVT_LVTH16244B Product data sheet Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 16 of 18 NXP Semiconductors 74LVT16244B; 74LVTH16244B 3.3 V 16-bit buffer/driver; 3-state Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com 74LVT_LVTH16244B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 1 March 2012 © NXP B.V. 2012. All rights reserved. 17 of 18 NXP Semiconductors 74LVT16244B; 74LVTH16244B 3.3 V 16-bit buffer/driver; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15 Legal information. . . . . . . . . . . . . . . . . . . . . . . 16 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Contact information. . . . . . . . . . . . . . . . . . . . . 17 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2012. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 1 March 2012 Document identifier: 74LVT_LVTH16244B
74LVT16244BEV/G:55 价格&库存
很抱歉,暂时无法提供与“74LVT16244BEV/G:55”相匹配的价格&库存,您可以联系我们找货
