| MODEL HS35
INCREMENTAL OPTICAL ENCODER
Introduction
The HS35 combines the rugged, heavy-duty features usually associated with shafted encoders into a hollow shaft style. Its design includes dual
bearings and shaft seals for NEMA 4, 13 and IP65 environmental ratings, a rugged metal housing, and a sealed connector or cable gland. The HS35
accommodates shafts up to 1” in diameter. With optional insulating inserts, it can be mounted on smaller diameter shafts. It can be mounted on a
through shaft or a blind shaft with a closed cover to maintain its environmental rating. The HS35 is also available with a dual output option (inset) to
provide redundant encoder signals, dual resolutions, or to supply two separate controllers from a single encoder. Applications include motor feedback
and vector control, printing industries, robotic control, oil service industries, and web process control.
The HS35 Dual Output Encoder
SPECIFICATIONS
Mechanical
Shaft Bore
1.00”, 0.875”, 0.750”, 0.625”, 0.500”.
All are supplied with insulating sleeves.
Allowable Misalignments
0.005” T.I.R. on mating shaft 0.75” from shaft end
Bore Runout
0.001 T.I.R. maximum
Starting Torque at 25°C
Through shaft version (SS) = 7 in-oz (max);
Blind shaft version (BS) = 4 in-oz max
Bearings
52100 SAE High carbon steel
Shaft Material
416 stainless steel
Bearing Housing
Die cast aluminum with protective finish
Cover
Bearing Life
7.5 X 109 revs (50,000 hrs at 2500 RPM)
Maximum RPM
6,000 RPM (see frequency response above)
Moment of Inertia
0.019 oz-in-sec2
Weight
18 oz. typical
Page 1
Copyright © 2020 Sensata Technologies, Inc.
www.sensata.com
Electrical
Code
Incremental
Output Format
2 channels in quadrature, 1/2 cycle index gated with negative B channel
Cycles per Shaft Turn
1 to 80,000 (See Table A).
For resolutions above 5000 see interpolation options in Table A
Supply Voltage
5 to 28 VDC available (See Note 5)
Current Requirements
100 mA typical + output load, 250 mA (max)
Voltage / Output
15V/V: 5–15 VDC in, Vout = Vin
28V/V: Line Driver, 5–28 VDC in, Vout = Vin
28V/5: Line Driver, 5–28 VDC in, Vout = 5 VDC
28V/OC: Open Collector, 5–28 VDC in, OCout
(See Note 5)
Protection Level
Reverse, overvoltage and output short circuit protection
(See Note 5)
Frequency Response
150 kHz (Up to 5000 cpt resolution; 300 KHz above 5000 cpt, also see Note 7)
Output Termination
Pinouts
See Table 1
Notes: Consult factory for other electrical options.
Environmental
Enclosure Rating
NEMA 4 & 13 (IP65) when ordered with shaft seal (on units with an MS connector) or a cable gland (on units with cable
termination)
Temperature
Operating, 0º to 70º C; extended temperature testing up to 105º C available (see Note 8); Storage, -25º to 90º C
unless extended temperature option called out
Shock
50 g’s for 11 msec duration
Vibration
5 to 2000 Hz @ 20 g’s
Humidity
98% RH without condensation
Notes and Tables: All notes and tables referred to in the text can be found in the pages that follow.
Page 2
www.sensata.com
DIMENSIONS
Dimensions in mm
Page 3
www.sensata.com
TABLES
Table 1 —
Incremental Output Terminations
The connector style will determine pinouts.
For example, an encoder with ABC channels and an M18 connector uses the table below.
M18 Connector
M12 Connector
Channels Designated in
Model No.
M16 Connector
Pin
Channel
Pin
Channel
A
A
A
A
PIN
ABZ
ABC
B
B
B
B
A
A
A
C
Z
C
Z
B
B
B
D
+V
D
+V
C
Z
A
E
E
D
F
0V
F
0V
E
G
CG
G
CG
F
0V (Circuit Common)
H
A
H
A
G
Case Ground (CG) (Except H20)
I
B
J
B
J
Z
k
Z
Wire Color
DA 15P Connector
YEL
+V (Supply Voltage)
B
Channels Designated in Model No.
ABZ
ABC
ABZC
13
A
A
A
BLUE
14
B
B
B
ORN
15
Z
Z
W-Yel
10
A
A
W-Blu
11
B
B
W-Orn
12
Z
RED
6
+V (Supply Voltage)
BLK
1
0V (Circuit Common)
GRN
9
WHITE
Shield Drain (Shielded Cable Only)
Table A —
HS35 Disc Resolutions
32, 100, 250, 360, 420, 500, 512, 600, 635, 720, 1000, 1024, 1200, 1500, 1650, 1800, 2000, 2100, 2048, 2500, 2881, 2884, 3600, 3710, 4096, 5000
For interpolation please specify the multiplied output (up to 80,000 for the HS35) in the model number, i.e. 80,000-T16. Other resolutions available–consult factory.
NOTE: Dual resolutions available, consult factory.
Page 4
www.sensata.com
FIGURES
Figure 1 —
Output Waveform
NOTE: Index location is displaced 180° (mechanical) on
second output with dual output option.
Page 5
www.sensata.com
ORDERING OPTIONS
Encoder
X
HS35
F
100
Items highlighted in blue are standard Express Encoders and ship in one to three days.
R1
SS
2048
ABZ
C
28V/V
SM18
EX
S
X: Express Encoder
Type
HS: Hollow Shaft
35: 3.5” Encoder Diameter
Housing Configuration
F: Standard
Shaft Bore
100: 1.00”
87: 0.875”
75: 0.75”
62: 0.625”
50: 0.50” etc.
Metric bores available
Tether
R1: Tether Block and Pin
R2: Tether Arm
Shaft Seal Configuration
SS: Through Shaft, Rubber Seals
BS: Blind Shaft, Rubber Seal
FS: Through Shaft, Felt Seals
BFS: Blind Shaft Felt
(See Note 2)
Cycles per Turn
(Enter Cycles)
(See table A on the prior pages)
No. of Channels
ABZ
(See Note 3)
Compliments
C: Complimentary Outputs
(See Note 4)
Voltage / Output
15V/V: 5–15Vin/out
28V/V: 5-28Vin/out
28V/5: 5-28Vin/5Vout
28V/OC: 5-28Vin/OCout
(See Note 5)
Output Termination
SM12: MS3112E12-10P
M16: MS3102R16S-1P
SM18: MS3102R18-1P
(Indicate “S” for single or “D” for Dual (i.e. DM18 = Dual)
SCS: Shielded/Jacketed Cable with Cable Seal. Length of Cable is specified in inches. (i.e. SCS18 = 18 inches)
(See Table 1 & Note 9)
Hazardous Area Ratings
Blank: None
EX: Intrinsically Safe
NI: Non-Incendive
Contact Factory for Voltage Options
Special Features
S: Special Features specified on Purchase Order.
(See Note 3)
(Consult Factory for More Information)
Page 6
www.sensata.com
NOTES
1. The typical hollow shaft product is supported by, and clamped to, the driving shaft. A flexible tether is used to keep the housing from rotating.
2.The rubber shaft seal is recommended in virtually all installations. The most common exceptions are applications requiring a very low starting torque
or those requiring operation at both high temperature and high speed. For these exceptions, a felt shaft seal is recommended. Felt seals require very
low starting torque and can virtually eliminate frictional heat. Encoders ordered with felt shaft seals will have an enclosure rating of IP50 and will
have less than 1/10th the Starting Torque specified under Mechanical Configurations.
3. Non-standard index widths and multiple indices are available by special order. Consult factory.
4. Complementary outputs are recommended for use with line driver type (source/sink) outputs. When used with differential receivers, this combination
provides a high degree of noise immunity.
5. Output IC’s: Output IC’s are available as either Line Driver (LD) or NPN Open Collector (OC) types. Open Collectors require pull-up resistors, resulting
in higher output source impedance (sink impedance is similar to that of line drivers). In general, use of a Line Driver style output is recommended.
Line Drivers source or sink current and their lower impedance mean better noise immunity and faster switching times. Warning: Do not connect any
line driver outputs directly to circuit common/OV, which may damage the driver. Unused outputs should be isolated and left floating. Our applications
specialists would be pleased to discuss your system requirements and the compatibility of your receiving electronics with Line Driver type outputs.
28V/V: Multi-Voltage Line Driver (7272*): 100 mA source/sink. Input voltage 5 to 28 VDC ± 5% standard (Note: Vout = Vin). This driver is TTL
compatible when used with 5 volt supply. Supply lines are protected against overvoltage to 60 volts and reverse voltage. Outputs are short circuit
protected for one minute. Supply current is 120 mA typical (plus load current). This is the recommended replacement for 3904R and 7406R open
collector outputs with internal pullup resistors. It is also a direct replacement for any 4469, 88C30, 8830 or 26LS31 line driver
28V/5: Multi-voltage Line Driver (7272*): 100 mA source/sink. Input voltage 5 to 28 VDC +/- 5% standard, internally regulated with 5V (TTL compatible)
logic out. Supply lines are protected against overvoltage to 60 volts and reverse voltage. Outputs are short circuit protected for one minute. Supply
current is 90 mA typical (plus load current).
28V/OC: NPN Open Collector (3904*, 7273*). Current sink of 80 mA max. Current sourced by external pull- up resistor. Output can be pulled up to
voltage other than supply voltage (30 V max). Input voltage 5 to 28 VDC ± 5% standard. Supply current is 120 mA typical. This replaces prior IC’s with
designations of 3904, 7406, 3302, 681 and 689.
5V/OCR, 15V/OCR, 24V/OCR: Open Collector (3904R*, 7406R*, 7273R*): Current sink of 70 mA max. Includes internal pull-ups sized at approximately
100 ohms/volt. Max current source is 10 mA. Supply current is 100 mA typical, 120 mA with internal pull-ups. The 5V/OCR, 15V/OCR and 24V/OCR
are often replaced by the 28V/V in system upgrades.
Intrinsically Safe Voltage/Output options: 5V/V, 5V/OC, 5V/OCR, 9V/OC are the only output options available with the Intrinsically Safe “EX”
Hazardous Area Rating model option. They must be installed per Control Drawing 08292-001.
6. Special –S at the end of the model number is used to define a variety of non-standard features such as special shaft lengths, voltage options, or
special testing. Please consult the factory to discuss your special requirements.
7. Higher frequency response may be available. Please consult with the factory.
8. Extended temperature ratings are available in the following ranges: -40 to 70°C, -40 to 85°C, –20 to 105°C and –40 to 105°C depending on the
particular model. Some models can operate down to -55°C. Extended temperature ranges can affect other performance factors. Consult with factory
for more specific information.
9. Mating straight plug receptacles may be ordered from the factory:
For M12 use MS3116F12-10S
For M14 use MS3106F14S-6S
For M14/19 use MS3116J14-19S
For M16 use MS3106F16S-1S
For M18 use MS3106F18-1S
For M20 use MS3106F20-29S
Page 7
www.sensata.com
AGENCY APPROVALS & CERTIFICATIONS
Model HS35
Hazardous Area
Ratings
Agency
Blank
EX
Intrinsic Safety
NI
Non-Incendive
Ratings and Markings
File Number
CE
EN 55011: Electromagnetic Disturbance (EMI)
EN 61000-6-2: Electromagnetic Compatibility (EMC)
UL
Class I, Groups A, B, C, D
Class II, Groups E, F, G
20180302-E78446
DEMKO
II 1 G Ex ia IIC T4 Ga
(9V/OC is II 1 G Ex ia IIB T4 Ga)
DEMKO 06 ATEX 0614247X
IEC/IECEx
Ex ia IIC T4 Ga
(9V/OC is Ex ia IIB T4 Ga)
-40°C ≤ Ta ≤ +85°C
IECEx UL 12.0035X
UL
Class I, Div. 2, Groups A, B, C, D
Class II, Div. 2, Groups F, G
20170321-E78446
DEMKO
II 3 G Ex nA IIB T3 Gc
DEMKO 13 ATEX 1209038X
IEC/IECEx
Ex nA IIB T3 Gc
-40°C ≤ Ta ≤ +85°C
IECEx UL 13.0071X
Page 8
Sensata Technologies, Inc. (“Sensata”) data sheets are solely intended to assist designers (“Buyers”) who are developing systems that
incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible
for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets have
been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that
specifically described in the published documentation for a particular data sheet. Sensata may make corrections, enhancements,
improvements and other changes to its data sheets or components without notice.
Buyers are authorized to use Sensata data sheets with the Sensata component(s) identified in each particular data sheet. HOWEVER, NO
OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND
NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS
ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE
OF THE DATA SHEETS, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS
ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET
ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD
TO SENSATA DATA SHEETS OR USE THEREOF.
All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY
FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY
RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS,
AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION
OR SUPPORT THAT MAY BE PROVIDED BY SENSATA.
Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA.
Revised 08/18/2020
CONTACT US
Americas
+1 (800) 350 2727 – Option 1
sales.beisensors@sensata.com
Europe, Middle East & Africa
+33 (3) 88 20 8080
position-info.eu@sensata.com
Asia Pacific
sales.isasia@list.sensata.com
China +86 (21) 2306 1500
Japan +81 (45) 277 7117
Korea +82 (31) 601 2004
India +91 (80) 67920890
Rest of Asia +886 (2) 27602006
ext 2808
www.sensata.com
