RV3500
RV3500
    IFM(易福门)
    SOLID SHAFT ENCODER; SHAFT DIAME
RV3500 数据手册
RV3500 Incremental encoder with solid shaft INCREMENTAL ENCODER BASIC LINE 1 2 M4 x 0.7 Depth 6 mm M3 x 0.5 Depth 6 mm Product characteristics Resolution 1...10000; (parameterisable; Factory setting: 1024) resolution Communication interface IO-Link Shaft design Shaft diameter solid shaft [mm] 10 Application Function principle incremental Detection system magnetic Electrical data Operating voltage Current consumption [V] [mA] Protection class Max. revolution electrical < 150 III Reverse polarity protection Power-on delay time 4.75...30 DC yes [s] [U/min] 0.5 12000 Outputs Electrical design HTL/TTL Max. current load per output [mA] Switching frequency [kHz] Factory setting 1000 Output function: HTL (50 mA) Short-circuit protection Phase difference A and B 50 yes [°] 90 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — RV3500-01 — 04.03.2016 — RV3500 Incremental encoder with solid shaft INCREMENTAL ENCODER BASIC LINE Measuring/setting range Resolution 1...10000; (parameterisable; Factory setting: 1024) resolution Accuracy / deviations Accuracy [°] 0.1 Software / programming Parameter setting options Resolution; direction of rotation; HTL; TTL Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SIO mode yes Min. process cycle time [ms] 2.3 [°C] -40...80 Operating conditions Ambient temperature Note on ambient temperature for flexibly laid cable: -25 °C Storage temperature [°C] -40...80 Max. relative air humidity [%] 95; (condensation not permissible) Protection IP 65; IP 66; (on the housing: IP 67; on the shaft: IP 64) Tests / approvals Shock resistance 100 g Vibration resistance 20 g MTTF [years] 292 [g] 441 Mechanical data Weight Dimensions [mm] Materials flange: aluminium; housing: stainless steel (1.4521 / 444); cable plug: PA Max. revolution, mechanical [U/min] Max. starting torque Reference temperature torque 12000 [Nm] 1 [°C] 20 Shaft design Shaft diameter Ø 58 / L = 79.5 solid shaft [mm] Shaft material 10 stainless steel Max. shaft load axial (at the shaft end) [N] 40 Max. shaft load radial (at the shaft end) [N] 60 Fixing flange clamping flange ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — RV3500-01 — 04.03.2016 — RV3500 Incremental encoder with solid shaft INCREMENTAL ENCODER BASIC LINE Electrical connection Cable: 2 m, Ø 4.9 mm; radial, can also be used axially; 5 x 0.14 mm² IO-Link brown L+ white not to be used blue L- grey not to be used black IO-Link Screen housing encoder brown UB white A blue GND grey B black Z/0-Pulse (90 deg) Screen housing Diagrams and graphs Pulse diagram direction of rotation clockwise (looking at the shaft) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — RV3500-01 — 04.03.2016 —
RV3500 价格&库存
很抱歉,暂时无法提供与“RV3500”相匹配的价格&库存,您可以联系我们找货
RV3500
    • 1+2089.94255
    库存:3
