TCW400-1213-001
TCW400-1213-001
    SENSATA(森萨塔)
    TCW4 MOD MULTITURN 5-30V SSI NO
TCW400-1213-001 数据手册
| TCW4 SSI SSI MULTI-TURN MODULAR SENSOR Sensata-BEI Sensors' TCW4 sensors provide absolute multi-turn measurement with an SSI output in an over-molded, modular package that offers design flexibility and protection from the environment. Features •  With its two-part design, the TCW4 absolute multi-turn offers maximum flexibility for installation •  Rugged and excellent resistance to shock and vibration •  Robust, proven magnetic technology •  Environmentally resistant, IP 67 standard (IP69K option) •  Extended operating range from -20° C to 85° C •  Uses universal supply 5 to 30 VDC – SSI Output •  Available resolution 12 bits per turn and up to 13 bits of turns counting. •  Variety of magnet holders available Applications •  Factory Automation •  Process Automation SPECIFICATIONS Mechanical Terminations PUR cable Housing Macromelt PA638 Weight 0,150 kg Electrical Electrical Angle 360° Output Function SSI, 10% to 90% Duty Cycle Minimal Cycle Time 1ms Resolution Resolution 12 bits per turn and up to 13 bits of turns counting Accuracy +/-0.3% on 360° Repeatability +/-0.1% on 360° Supply Voltage 5V to 30 Vdc Start-up < 1s Response time < 10 ms Recommended Load > 10 kOhms Isolation 500 Veff Current Requirements < 40mA Protection Overvoltage Protection: Yes Reverse Polarity Protection: Yes Short Circuit Protection: Yes EMC IEC 61000-4-2 Electrostatic discharge (ESD) 4 kV, 8 kV IEC 61000-4-3 Electromagnetic fields 10 V/m (80MHz - 1GHz), 3V/m (1.4GHz - 2GHz), 1V/m (2GHz - 2.7GHz) IEC 61000-4-4 Electrical fast transients (burst) 1 kV IEC 61000-4-6 Conducted disturbances, induced by RF-fields 10 Veff. Page 1 Copyright © 2020 Sensata Technologies, Inc. www.sensata.com SSI Transmission Transmission Transmission up to 400m* at 100kHz as a function of the cable characteristics. Cable High security of transmission by using shielded cable and twisted pairs. * Consult us for length > 100m. Note: Connect DIRECTION and RAZ/RAX to a potential (RAZ at 0V if not used) DIMENSIONS All Dimensions are in millimeters. Shaft system with magnet to be ordered separately (see Accessories). 24 52 38 R2 26 4 H10 1° Advised mounting condition (magnet sold separately) 11,2 8 27,5 2x A 1 A 30° Clockwise direction 0.5 to 3.5mm Advised mounting condition Page 2 Copyright © 2020 Sensata Technologies, Inc. www.sensata.com CONNECTIONS Ref. Type + Vcc 0V Clk+ Data+ RAZ Data- Clk- Direction Ground S5 SSI cable PUR 8230/050 BN/GN Brown/ Green WH/GN White/Green GN Green GY Gray BU Blue PK Pink BN Brown WH White General shielding NOTES Stray magnetic fields can interfere with accuracy and repeatability of the signal. Example : TCW4_00//PSSB//12B13D5//S5D020 ORDERING OPTIONS TCW4 _ 00 // (Contact the factory for special versions, ex : dimensions, connections... ) P SS B // 12B13D5 // S5D 020 Family TCW4: Absolute Multi-turn Sensor Shaft Ø 00: Modular Supply P: 5 to 30 Vdc Output Stage SS: SSI Without Parity Code B: Binary G: Gray Resolution 12B13D5: 12 bits per turn by 13 bits of turns counting Connection S5D: SSI PUR Cable Cable Length 020: 2 meters of cable Page 3 Copyright © 2020 Sensata Technologies, Inc. www.sensata.com ACCESSORIES KXX: Where XX is the shaft mounting diameter in mm. Standards are 06, 08, 10, 11, and 14 mm. i.e M9105/K10 mounts to a 10 mm shaft. A W Z 0 V -0,5 X H7 Y SECTION A-A A M9105/K06 M9105/K08 M9105/K10 M9105/K11 M9105/K14 X 06 H7 08 H7 10 H7 11 H7 14 H7 V 20 20 26 26 29 W 9,3 9,3 10 10 10 Y 12,5 12,5 14 14 14 Z 15 15 15 15 18 10 12,5 Index Magnet 36 h7 26 3 H10 2x CHc M4x12 Screws Page 4 Copyright © 2020 Sensata Technologies, Inc. www.sensata.com 12 25 50% of output signal visual mark 10 g7 20 10±0.10 2.50±0.10 Page 5 Sensata Technologies, Inc. (“Sensata”) data sheets are solely intended to assist designers (“Buyers”) who are developing systems that incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets have been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that specifically described in the published documentation for a particular data sheet. Sensata may make corrections, enhancements, improvements and other changes to its data sheets or components without notice. Buyers are authorized to use Sensata data sheets with the Sensata component(s) identified in each particular data sheet. HOWEVER, NO OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE OF THE DATA SHEETS, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD TO SENSATA DATA SHEETS OR USE THEREOF. All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS, AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION OR SUPPORT THAT MAY BE PROVIDED BY SENSATA. Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA. Copyright © 20 Sensata Technologies, Inc. No.02320-001 Rev.04/09/20 CONTACT US Americas +1 (800) 350 2727 sales.beisensors@sensata.com EMEA position-info.eu@sensata.com +33 (3) 88 20 8080 Asia Pacific sales.isasia@list.sensata.com China +86 (21) 2306 1500 Japan +81 (45) 277 7117 Korea +82 (31) 601 2004 India +91 (80) 67920890 Rest of Asia +886 (2) 27602006 ext 2808 www.sensata.com
TCW400-1213-001
物料型号:TCW4 SSI 器件简介:Sensata-BEI Sensors的TCW4传感器提供绝对多圈测量,具有SSI输出,采用注塑成型的模块化封装,设计灵活,能够抵御环境影响。
引脚分配:+Vcc, OV, Clk+, Data+, RAZ, Data-, Clk-, Direction, Ground 参数特性: - 电气角度:360° - 输出功能:SSI, 10%至90%占空比 - 最小周期时间:1ms - 分辨率:每圈12位,最多13位圈数计数 - 精度:±0.3% on 360° - 重复性:±0.1% on 360° - 供电电压:5V至30Vdc - 启动时间:<1s - 响应时间:<10ms - 推荐负载:>10kΩ - 隔离:500V有效值 - 电流需求:<40mA - 保护:过压保护、反极性保护、短路保护 - EMC:符合IEC 61000-4-2、IEC 61000-4-3、IEC 61000-4-4、IEC 61000-4-6标准 功能详解:TCW4绝对多圈传感器,具有二部分设计,安装灵活,抗冲击和振动性能优越,使用经过验证的磁性技术,环境适应性强,工作温度范围宽,使用通用供电,多种磁铁支架可选。
应用信息:工厂自动化、过程自动化 封装信息:采用注塑成型的模块化封装,重量为0.150kg,电缆为PUR电缆。
TCW400-1213-001 价格&库存
很抱歉,暂时无法提供与“TCW400-1213-001”相匹配的价格&库存,您可以联系我们找货
