5962-8778501CA
5962-8778501CA
    L3HARRIS
    CDIP14
    OPERATIONAL AMPLIFIER
5962-8778501CA 数据手册
REVISIONS LTR DESCRIPTION DATE (YR-MO-DA) APPROVED A Add generic part number HA-2841 as device type 03. Add case outline C to device type 01. Make changes to 1.2.1, 1.3, TABLE I, and FIGURE 2. 94-05-16 M. A. FRYE B Drawing updated to reflect current requirements. - ro 00-05-24 R. MONNIN THE ORIGINAL FIRST SHEET OF THIS DRAWING HAS BEEN REPLACED. REV SHEET REV SHEET REV STATUS REV B B B B B B B B B B B B B B OF SHEETS SHEET 1 2 3 4 5 6 7 8 9 10 11 12 13 14 PMIC N/A PREPARED BY RICK C. OFFICER STANDARD MICROCIRCUIT DRAWING THIS DRAWING IS AVAILABLE FOR USE BY ALL DEPARTMENTS AND AGENCIES OF THE DEPARTMENT OF DEFENSE AMSC N/A DEFENSE SUPPLY CENTER COLUMBUS COLUMBUS, OHIO 43216 CHECKED BY RAJESH R. PITHADIA APPROVED BY MICHAEL A. FRYE DRAWING APPROVAL DATE 90-06-28 REVISION LEVEL B MICROCIRCUIT, LINEAR, WIDEBAND, FAST SETTLING, OPERATIONAL AMPLIFIER, MONOLITHIC SILICON SIZE CAGE CODE A 67268 SHEET DSCC FORM 2233 APR 97 DISTRIBUTION STATEMENT A. Approved for public release; distribution is unlimited. 1 OF 5962-87785 14 5962-E273-00 1. SCOPE 1.1 Scope. This drawing describes device requirements for MIL-STD-883 compliant, non-JAN class level B microcircuits in accordance with MIL-PRF-38535, appendix A. 1.2 Part or Identifying Number (PIN). The complete PIN is as shown in the following example: 5962-87785 01 ~ ~ ~ ~ C ~ ~ ~ ~ Drawing number X ~ ~ ~ ~ Device type (see 1.2.1) ~ ~ ~ ~ Case outline (see 1.2.2) Lead finish (see 1.2.3) 1.2.1 Device type(s). The device type(s) identify the circuit function as follows: Device type Generic number 01 HA-2541 02 EL-2041 03 HA-2841 Circuit function Fast settling, unity gain stable, wideband operational amplifier Fast settling, unity gain stable, wideband operational amplifier Fast settling, unity gain stable, video operational amplifier 1.2.2 Case outline(s). The case outline(s) are as designated in MIL-STD-1835 and as follows: Outline letter C P X 2 Descriptive designator Terminals GDIP1-T14 or CDIP2-T14 GDIP1-T8 or CDIP2-T8 See figure 1 CQCC1-N20 14 8 12 20 Package style Dual-in-line package Dual-in-line package Can Square leadless chip carrier 1.2.3 Lead finish. The lead finish is as specified in MIL-PRF-38535, appendix A. 1.3 Absolute maximum ratings. Voltage between +V and -V terminals ..............................................35 V dc Differential input voltage (VIN) .......................................................... 6.0 V dc Voltage at either input terminal .........................................................V+ to VPeak output current (< 10% duty cycle) ............................................50 mA Maximum power dissipation (PD) .....................................................2.0 W 1/ Storage temperature range ...............................................................-65 C to +150 C Lead temperature (soldering, 10 seconds) : Device types 01 and 02 .................................................................+275 C Device type 03 ..............................................................................+300 C Junction temperature (TJ) .................................................................+175 C r q q q q q T Thermal resistance, junction-to-case ( JC) : Cases C, P, and 2 .........................................................................See MIL-STD-1835 Case X ..........................................................................................82 C/W Thermal resistance, junction-to-ambient ( JA): .................................50 C/W q q T 1/ q q Derate linearly above TA = +75 C at 20 mW/ C. STANDARD MICROCIRCUIT DRAWING DEFENSE SUPPLY CENTER COLUMBUS COLUMBUS, OHIO 43216-5000 DSCC FORM 2234 APR 97 SIZE 5962-87785 A REVISION LEVEL B SHEET 2 1.4 Recommended operating conditions. Positive supply voltage range (+V) ...................................................+12 V dc to +15 V dc Negative supply voltage range (-V) ..................................................-12 V dc to -15 V dc Common mode input voltage (VCM) ................................................. (+V – (-V)) / 2 d Load resistance (RL) .........................................................................1.0 k q : q Ambient operating temperature range (T A) ......................................-55 C to +125 C 2. APPLICABLE DOCUMENTS 2.1 Government specification, standards, and handbooks. The following specification, standards, and handbooks form a part of this drawing to the extent specified herein. Unless otherwise specified, the issues of these documents are those listed in the issue of the Department of Defense Index of Specifications and Standards (DoDISS) and supplement thereto, cited in the solicitation. SPECIFICATION DEPARTMENT OF DEFENSE MIL-PRF-38535 - Integrated Circuits, Manufacturing, General Specification for. STANDARDS DEPARTMENT OF DEFENSE MIL-STD-883 MIL-STD-973 MIL-STD-1835 - Test Method Standard Microcircuits. Configuration Management. Interface Standard For Microcircuit Case Outlines. HANDBOOKS DEPARTMENT OF DEFENSE MIL-HDBK-103 MIL-HDBK-780 - List of Standard Microcircuit Drawings (SMD's). Standard Microcircuit Drawings. (Unless otherwise indicated, copies of the specification, standards, and handbooks are available from the Standardization Document Order Desk, 700 Robbins Avenue, Building 4D, Philadelphia, PA 19111-5094.) 2.2 Order of precedence. In the event of a conflict between the text of this drawing and the references cited herein, the text of this drawing takes precedence. Nothing in this document, however, supersedes applicable laws and regulations unless a specific exemption has been obtained. 3. REQUIREMENTS 3.1 Item requirements. The individual item requirements shall be in accordance with MIL-PRF-38535, appendix A for nonJAN class level B devices and as specified herein. Product built to this drawing that is produced by a Qualified Manufacturer Listing (QML) certified and qualified manufacturer or a manufacturer who has been granted transitional certification to MILPRF-38535 may be processed as QML product in accordance with the manufacturers approved program plan and qualifying activity approval in accordance with MIL-PRF-38535. This QML flow as documented in the Quality Management (QM) plan may make modifications to the requirements herein. These modifications shall not affect form, fit, or function of the device. These modifications shall not affect the PIN as described herein. A "Q" or "QML" certification mark in accordance with MILPRF-38535 is required to identify when the QML flow option is used. STANDARD MICROCIRCUIT DRAWING DEFENSE SUPPLY CENTER COLUMBUS COLUMBUS, OHIO 43216-5000 DSCC FORM 2234 APR 97 SIZE 5962-87785 A REVISION LEVEL B SHEET 3 3.2 Design, construction, and physical dimensions. The design, construction, and physical dimensions shall be as specified in MIL-PRF-38535, appendix A and herein. 3.2.1 Case outline(s). The case outline(s) shall be in accordance with 1.2.2 herein and figure 1. 3.2.2 Terminal connections. The terminal connections shall be as specified on figure 2. 3.3 Electrical performance characteristics. Unless otherwise specified herein, the electrical performance characteristics are as specified in table I and shall apply over the full ambient operating temperature range. 3.4 Electrical test requirements. The electrical test requirements shall be the subgroups specified in table II. The electrical tests for each subgroup are described in table I. 3.5 Marking. Marking shall be in accordance with MIL-PRF-38535, appendix A. The part shall be marked with the PIN listed in 1.2 herein. In addition, the manufacturer's PIN may also be marked as listed in MIL-HDBK-103 (see 6.6 herein). For packages where marking of the entire SMD PIN number is not feasible due to space limitations, the manufacturer has the option of not marking the "5962-" on the device. 3.6 Certificate of compliance. A certificate of compliance shall be required from a manufacturer in order to be listed as an approved source of supply in MIL-HDBK-103 (see 6.6 herein). The certificate of compliance submitted to DSCC-VA prior to listing as an approved source of supply shall affirm that the manufacturer's product meets the requirements of MIL-PRF38535, appendix A and the requirements herein. 3.7 Certificate of conformance. A certificate of conformance as required in MIL-PRF-38535, appendix A shall be provided with each lot of microcircuits delivered to this drawing. 3.8 Notification of change. Notification of change to DSCC-VA shall be required in accordance with MIL-PRF-38535, appendix A. 3.9 Verification and review. DSCC, DSCC's agent, and the acquiring activity retain the option to review the manufacturer's facility and applicable required documentation. Offshore documentation shall be made available onshore at the option of the reviewer. STANDARD MICROCIRCUIT DRAWING DEFENSE SUPPLY CENTER COLUMBUS COLUMBUS, OHIO 43216-5000 DSCC FORM 2234 APR 97 SIZE 5962-87785 A REVISION LEVEL B SHEET 4 TABLE I. Electrical performance characteristics. Test Input offset voltage Symbol Conditions 1/ -55 C TA +125 C unless otherwise specified VIO VCM = 0 V q d d q Group A subgroups Device type 1 01,02 Min -2.0 Max +2.0 03 -4.0 +4.0 01 -6.0 +6.0 02 -10.0 +10.0 03 -8.0 +8.0 01 -35 +35 -50 +50 -15 +15 -20 +20 -10 +10 -20 +20 -35 +35 -50 +50 -15 +15 -20 +20 -10 +10 -20 +20 -7.0 +7.0 -9.0 +9.0 -4.0 +4.0 -6.0 +6.0 -1.0 +1.0 -2.0 +2.0 2,3 Input bias current +IIB : 1 VCM = 0 V, +RS = 1.1 k , -RS = 100 : 2,3 1 02 2,3 1 03 2,3 -IIB VCM = 0 V, +RS = 100 -RS = 1.1 k :, 1 : 01 2,3 1 02 2,3 1 03 2,3 Input offset current IIO : 1 VCM = 0 V, +RS = 1.1 k , -RS = 1.1 k : 01 2,3 1 02 2,3 1 03 2,3 Limits Unit mV PA PA See footnotes at end of table. STANDARD MICROCIRCUIT DRAWING DEFENSE SUPPLY CENTER COLUMBUS COLUMBUS, OHIO 43216-5000 DSCC FORM 2234 APR 97 SIZE 5962-87785 A REVISION LEVEL B SHEET 5 TABLE I. Electrical performance characteristics – Continued. Test Common mode input range Symbol Conditions 1/ -55 C TA +125 C unless otherwise specified +VCM +V = 5.0 V, -V = -25 V -VCM Large signal voltage range +AVOL q d Device type 1,2,3 01,03 Min 10 02 8 01,03 -10 02 -8 01,03 10 02 7 5,6 All 5 4 01,03 10 02 7 5,6 All 5 'VCM = 10 V, -V = -25 V, 1,2,3 01,02 70 +V = 5.0 V, VOUT = -10 V 1 03 86 +V = 25 V, -V = -5.0 V +CMRR 4 VOUT = 0 V and 10 V, : VOUT = 0 V and -10 V, RL = 1.0 k Common mode rejection ratio q Group A subgroups RL = 1.0 k -AVOL d : 2,3 -CMRR +IOUT 'VCM = -10 V, +V = 25 V, 1,2,3 01,02 70 -V = -5.0 V, VOUT = 10 V 1 03 86 1 VOUT = -10 V 1 VOUT = -5 V 2/ 1 VOUT = 10 V 1 VOUT = +5 V 2/ Max V kV/V dB 80 01 10 02 25 03 25 2,3 -IOUT Unit 80 2,3 Output current Limits mA 15 01 -10 02 -25 03 -25 2,3 -15 See footnotes at end of table. STANDARD MICROCIRCUIT DRAWING DEFENSE SUPPLY CENTER COLUMBUS COLUMBUS, OHIO 43216-5000 DSCC FORM 2234 APR 97 SIZE 5962-87785 A REVISION LEVEL B SHEET 6 TABLE I. Electrical performance characteristics – Continued. Test Output voltage swing Symbol Conditions 1/ -55 C TA +125 C unless otherwise specified +VOUT RL = 1.0 k -VOUT Quiescent power supply current +ICC -ICC Power supply rejection ratio +PSRR q d d q Group A subgroups Device type 1,2,3 01,03 Min 10 02 11 01,03 -10 02 -11 : RL = 1.0 k : 1,2,3 1,2,3 VOUT = 0 V, IOUT = 0 mA 1,2,3 VOUT = 0 V, IOUT = 0 mA +V = 5.0 and 15 V, -V = -15 V 1,2,3 +V = 10 and 20 V, -V = -15 V -PSRR -V = -5.0 V and -15 V, +V = +15 V 1,2,3 -V = -10 and -20 V, +V = +15 V Offset voltage adjustment +VIO q 1 TA = +25 C 3/ Unit Max V 01 39 02 17 03 11 01 -39 02 -17 03 -11 01 70 02 60 03 70 01 70 02 60 03 70 All VIO (adj) -VIO Limits mA dB mV -1.0 q 1 TA = +25 C 3/ All VIO (adj) +1.0 See footnotes at end of table. STANDARD MICROCIRCUIT DRAWING DEFENSE SUPPLY CENTER COLUMBUS COLUMBUS, OHIO 43216-5000 DSCC FORM 2234 APR 97 SIZE 5962-87785 A REVISION LEVEL B SHEET 7 TABLE I. Electrical performance characteristics – Continued. Symbol Conditions 1/ -55 C TA +125 C unless otherwise specified Differential input 4/ resistance RIN Slew rate 4/ +SR Test q d d q Group A subgroups Device type VCM = 0 V, TA = +25 C 4 01,02 Min 40 VOUT = -3.0 V to 3.0 V, 7 01 200 q : -SR RL = 1 k , AV = 1 V/V 8 150 VOUT = 3.0 V to -3.0 V, 7 200 RL = 1 k , AV = 1 V/V 8 150 VOUT = -3.0 V to 3.0 V, 7 : +SR : -SR 130 VOUT = 3.0 V to -3.0 V, 7 180 RL = 1 k , AV = 1 V/V 8 130 VOUT = -3.0 V to 3.0 V, 7 Gain bandwidth 4/ product Full power bandwidth 4/ 5/ GBWP FPBW 03 8 187 VOUT = 3.0 V to -3.0 V, 7 200 8 187 : VOUT = r100 mV, RL = 1 k:, f1 = 100 kHz, f2 = 10 MHz, TA = +25qC VOUT = r200 mV, RL = 1 k:, fO = 100 kHz, TA = +25qC VOUT = r200 mV, RL = 1 k:, fO = 10 MHz, TA = +25qC VPK = 10 V, RL = 1 k: 4 Max k : P V/ s 200 RL = 1 k , AV = 1 V/V RL = 1 k , AV = 1 V/V Unit 180 8 : -SR 02 RL = 1 k , AV = 1 V/V : +SR Limits All 38 03 42 MHz 44 4 01 3.0 5,6 4 MHz 2.4 02 2.8 5,6 2.0 See footnotes at end of table. STANDARD MICROCIRCUIT DRAWING DEFENSE SUPPLY CENTER COLUMBUS COLUMBUS, OHIO 43216-5000 DSCC FORM 2234 APR 97 SIZE 5962-87785 A REVISION LEVEL B SHEET 8 TABLE I. Electrical performance characteristics – Continued. Test Full power bandwidth 4/ 5/ Symbol Conditions 1/ -55 C TA +125 C unless otherwise specified FPBW VPK = 10 V, RL = 1 k q d d q Group A subgroups Device type 4 03 : Min 3.1 5,6 : d 10 pF Closed loop stable 4/ gain CLSG RL = 1 k , CL Rise time 4/ 6/ tr VOUT = 0 V to +200 mV Fall time 4/ 6/ tf VOUT = 0 V to –200 mV ts Max MHz 4,5,6 All 9,10,11 01,02 10 03 6 9,10,11 01,02 10 9 03 5 1.0 V/V ns ns 6 9 AV = -1 V/V, 10 V step to Unit 3.0 10,11 Settling time 4/ Limits 01 150 ns q 0.1 %, TA = +25 C 300 AV = -1 V/V, 10 V step to q 0.01 %, TA = +25 C AV = -1 V/V, 10 V step to 9 02 350 9,10,11 01,02 40 9 03 60 q 0.05 %, TA = +25 C Overshoot 4/ +OS VOUT = 0 V to +200 mV 10,11 -OS VOUT = 0 V to –200 mV 65 9,10,11 01,02 40 9 03 60 10,11 q Output resistance 4/ ROUT Open loop, TA = +25 C Quiescent power 7/ consumption PC VOUT = 0 V, IOUT = 0 mA  70 4 01,02 25 : 1,2,3 01 1.17 W 02 .51 See footnotes at end of table. STANDARD MICROCIRCUIT DRAWING DEFENSE SUPPLY CENTER COLUMBUS COLUMBUS, OHIO 43216-5000 DSCC FORM 2234 APR 97 SIZE 5962-87785 A REVISION LEVEL B SHEET 9 TABLE I. Electrical performance characteristics – Continued. 1/ Unless otherwise specified, for dc tests, RS = 100 r : :, RL = 100 k:, VOUT = 0 V. Unless otherwise specified, for ac tests, AV = 1 V/V and RL = 1 k . q Device type 03 is designed to handle IOUT = 10 mA at a 50 % duty cycle for TJ = +175 C. For IOUT = 15 mA and 2/ q TJ = +175 C, a duty cycle of less than or equal to 33 % is required. r 3/ Offset adjustment range is VIO (measured) 1.0 mV minimum referred to output. This test is for functionality only to assure adjustment through 0 V. 4/ If not tested, shall be guaranteed to the limits specified in table I herein. 5/ Full power bandwidth = SR / ( 2 x S x VPK). 6/ Rise and fall times measured between 10 percent and 90 percent point. 7/ Quiescent power consumption is based on quiescent supply current test maximum (no load outputs). 4. QUALITY ASSURANCE PROVISIONS 4.1 Sampling and inspection. Sampling and inspection procedures shall be in accordance with MIL-PRF-38535, appendix A. 4.2 Screening. Screening shall be in accordance with method 5004 of MIL-STD-883, and shall be conducted on all devices prior to quality conformance inspection. The following additional criteria shall apply: a. Burn-in test, method 1015 of MIL-STD-883. (1) Test condition A, B, C, or D. The test circuit shall be maintained by the manufacturer under document revision level control and shall be made available to the preparing or acquiring activity upon request. The test circuit shall specify the inputs, outputs, biases, and power dissipation, as applicable, in accordance with the intent specified in test method 1015 of MIL-STD-883. q (2) TA = +125 C, minimum. b. Interim and final electrical test parameters shall be as specified in table II herein, except interim electrical parameter tests prior to burn-in are optional at the discretion of the manufacturer. 4.3 Quality conformance inspection. Quality conformance inspection shall be in accordance with method 5005 of MIL-STD-883 including groups A, B, C, and D inspections. The following additional criteria shall apply. 4.3.1 Group A inspection. a. Tests shall be as specified in table II herein. STANDARD MICROCIRCUIT DRAWING DEFENSE SUPPLY CENTER COLUMBUS COLUMBUS, OHIO 43216-5000 DSCC FORM 2234 APR 97 SIZE 5962-87785 A REVISION LEVEL B SHEET 10 Case X Letter A Ib ID ID1 e e1 F k k1 L Inches Min .130 .016 .585 .545 Millimeters Min Max 3.30 3.81 0.41 0.53 14.86 15.62 13.84 14.10 10.16 BSC 2.54 BSC 0.51 1.02 0.69 0.86 0.69 1.14 12.83 14.27 Max .150 .021 .615 .555 .400 BSC .100 BSC .020 .027 .027 .505 .040 .034 .045 .562 NOTES: 1. The US government preferred system of measurement is the metric SI system. However, since this item was originally designed using inch-pound units of measurement, in the event of conflict between the metric and inch-pound units, the inch-pound units shall take precedence. 2. Pin numbers are for reference only and do not appear on package. FIGURE 1. Case outline. STANDARD MICROCIRCUIT DRAWING DEFENSE SUPPLY CENTER COLUMBUS COLUMBUS, OHIO 43216-5000 DSCC FORM 2234 APR 97 SIZE 5962-87785 A REVISION LEVEL B SHEET 11 Device types 01 and 02 01, 02, and 03 02 03 Case outlines X C 2 P Terminal number 1 Terminal symbol NC NC NC BAL 2 NC NC BAL -IN 3 BAL BAL NC +IN 4 BAL -IN NC -V 5 -IN +IN -IN NC 6 +IN -V NC OUT 7 NC NC +IN +V 8 NC NC NC BAL 9 NC NC NC --- 10 -V OUTPUT -V --- 11 OUTPUT +V NC --- 12 +V BAL NC --- 13 --- NC NC --- 14 --- NC NC --- 15 --- --- OUT --- 16 --- --- NC --- 17 --- --- +V --- 18 --- --- NC --- 19 --- --- NC --- 20 --- --- BAL --- NC = No connection FIGURE 1. Terminal connections. STANDARD MICROCIRCUIT DRAWING DEFENSE SUPPLY CENTER COLUMBUS COLUMBUS, OHIO 43216-5000 DSCC FORM 2234 APR 97 SIZE 5962-87785 A REVISION LEVEL B SHEET 12 TABLE II. Electrical test requirements. MIL-STD-883 test requirements Subgroups (in accordance with MIL-STD-883, method 5005, table I) Interim electrical parameters (method 5004) --- Final electrical test parameters (method 5004) 1*, 2,3,4,5,6 Group A test requirements (method 5005) 1,2,3,4,5,6,7**,8**,9**10**,11** Groups C and D end-point electrical parameters (method 5005) 1 * PDA applies to subgroup 1. ** Subgroups 7, 8, 9, 10, and 11, if not tested, shall be guaranteed to the limits specified in table I herein. 4.3.2 Groups C and D inspections. a. End-point electrical parameters shall be as specified in table II herein. b. Steady-state life test conditions, method 1005 of MIL-STD-883. (1) Test condition A, B, C, or D. The test circuit shall be maintained by the manufacturer under document revision level control and shall be made available to the preparing or acquiring activity upon request. The test circuit shall specify the inputs, outputs, biases, and power dissipation, as applicable, in accordance with the intent specified in test method 1005 of MIL-STD-883. (2) TA = +125 C, minimum. (3) Test duration: 1,000 hours, except as permitted by method 1005 of MIL-STD-883. q 5. PACKAGING 5.1 Packaging requirements. The requirements for packaging shall be in accordance with MIL-PRF-38535, appendix A. 6. NOTES 6.1 Intended use. Microcircuits conforming to this drawing are intended for use for Government microcircuit applications (original equipment), design applications, and logistics purposes. 6.2 Replaceability. Microcircuits covered by this drawing will replace the same generic device covered by a contractor-prepared specification or drawing. STANDARD MICROCIRCUIT DRAWING DEFENSE SUPPLY CENTER COLUMBUS COLUMBUS, OHIO 43216-5000 DSCC FORM 2234 APR 97 SIZE 5962-87785 A REVISION LEVEL B SHEET 13 6.3 Configuration control of SMD's. All proposed changes to existing SMD's will be coordinated with the users of record for the individual documents. This coordination will be accomplished in accordance with MIL-STD-973 using DD Form 1692, Engineering Change Proposal. 6.4 Record of users. Military and industrial users shall inform Defense Supply Center Columbus when a system application requires configuration control and the applicable SMD. DSCC will maintain a record of users and this list will be used for coordination and distribution of changes to the drawings. Users of drawings covering microelectronics devices (FSC 5962) should contact DSCC-VA, telephone (614) 692-0525. 6.5 Comments. Comments on this drawing should be directed to DSCC-VA, Columbus, Ohio 43216-5000, or telephone (614) 692-0674. 6.6 Approved sources of supply. Approved sources of supply are listed in MIL-HDBK-103. The vendors listed in MILHDBK-103 have agreed to this drawing and a certificate of compliance (see 3.6 herein) has been submitted to and accepted by DSCC-VA. STANDARD MICROCIRCUIT DRAWING DEFENSE SUPPLY CENTER COLUMBUS COLUMBUS, OHIO 43216-5000 DSCC FORM 2234 APR 97 SIZE 5962-87785 A REVISION LEVEL B SHEET 14 STANDARD MICROCIRCUIT DRAWING BULLETIN DATE: 00-05-24 Approved sources of supply for SMD 5962-87785 are listed below for immediate acquisition information only and shall be added to MIL-HDBK-103 and QML-38535 during the next revision. MIL-HDBK-103 and QML-383535 will be revised to include the addition or deletion of sources. The vendors listed below have agreed to this drawing and a certificate of compliance has been submitted to and accepted by DSCC-VA. This bulletin is superseded by the next dated revision of MIL-HDBK-103 and QML-38535. Standard microcircuit drawing PIN 1/ Vendor CAGE number Vendor similar PIN 2/ 5962-8778501CA 34371 HA1-2541/883 5962-8778501XA 3/ HA2-2541/883 5962-8778501XC 34371 HA2-2541/883 5962-8778502CA 3/ EL2041J/883B 5962-8778502XA 3/ EL2041G/883B 5962-87785022A 3/ EL2041L/883B 5962-8778503CA 34371 HA1-2841/883 5962-8778503PA 3/ HA7-2841/883 1/ The lead finish shown for each PIN representing a hermetic package is the most readily available from the manufacturer listed for that part. If the desired lead finish is not listed contact the vendor to determine its availability. 2/ Caution. Do not use this number for item acquisition. Items acquired to this number may not satisfy the performance requirements of this drawing. 3/ Not available from approved source of supply. Vendor CAGE number 34371 Vendor name and address Intersil Corporation P.O. Box 883 Melbourne, FL 32902-0883 The information contained herein is disseminated for convenience only and the Government assumes no liability whatsoever for any inaccuracies in the information bulletin.
5962-8778501CA 价格&库存
很抱歉,暂时无法提供与“5962-8778501CA”相匹配的价格&库存,您可以联系我们找货
