MANUAL SETTING TYPE OPTICAL ENCODERS
REC/RES
■ FEATURES
RoHS compliant
OContactless, manual adjustment only
OCompact, light weight
OWith click (REC20, REC20C, REC20D, RECW20D)
OPanel seal type (RESW20D, RECW20D)
ORoHS compliant
■ PART NUMBER DESIGNATION
RE C W 20 D - 50 - 201 - 1
Series name
Output connection
1:Cable wire
Click
Output phase
C:With click
S:Without click
2:“A” & “B”
Panel seal
Resolution (P/R)
W:Panel seal (With O ring)
25, 50
Blank:Non Panel seal
Model
Size
φ 20 mm
■ LIST OF PART NUMBERS
ltem
Output wave form
Output terminal
Click
Panel seal
Part number
Resolution
50 (P/R)
100 (P/R)
50 (P/R)
100 (P/R)
Saturated wave
Pin terminal
Without click
Pseudosquare wave
Without click
Non Panel seal
25 (P/R)
With click
REC20-25-201-1
REC20D-25-201-1
Without click
RES20D-50-201-1
With click
REC20C-50-201-1
REC20D-50-201-1
50 (P/R)
Square wave
RES20-50-200
RES20-100-200
RES20-50-200-Z
RES20-100-200-Z
RES20B-25-201-1
RES20D-25-201-1
Cable wire
RESW20D-25-201-1
Without click
25 (P/R)
RECW20D-25-201-1
With click
Panel seal
Without click
RESW20D-50-201-1
With click
RECW20D-50-201-1
50 (P/R)
※ Verify the above part numbers when placing orders.
The knob is available.
REC/RES
OPTICAL ENCODERS
■ STANDARD SPECIFICATIONS
OElectrical characteristics
Item
Part number
RES20
RES20-Z
REC20
RES20B
Input voltage
REC20C
RES20D
REC20D
RESW20D
RECW20D
DC5 V ± 5 %
mA
maximum
Input current
Output wave form
40
50
70
50
Square wave
Saturated wave Pseudosquare wave
Output phases
A, B
(P/R)
50
Resolution
100
50
100
25
50
90° ± 45°
Phase difference of outputs A & B
Maximum frequency response Hz
“1 (High)”
Output signal
“0 (Low)”
25, 50
500
100
2 Vp-p 1 Vp-p
minimum minimum
+ 4.0 V
minimum
+ 1.0 V
maximum
500
200
+ 4.5 V minimum
+ 0.5 V maximum
LED
Light source
OMechanical characteristics
Item
Part number
RES20
2.94
mN·m
{gf·cm} {30} maximum
mN·m
{gf·cm}
Starting torque
Click torque
Click number
Shaft loading
(When mounting)
RES20-Z
REC20
RES20B
REC20C
RES20D
REC20D
RESW20D
RECW20D
4.90
{50} maximum
2.94
{30} maximum
1.18 ± 0.78
{12 ± 8}
2.94 ± 1.96
{30 ± 20}
19.6
{200} maximum
19.6
{200} maximum
9.81 ± 4.9
{100 ± 50}
11.8 ± 4.9
{120 ± 50}
25
50
25, 50
25, 50
Radial
9.81 N {1 kgf} maximum
4.90 N {500 gf} maximum
Axial
4.9 N {500 gf} maximum
2.94 N {300 gf} maximum
Net weight
Approx. 20 g Approx. 20 g
Strength of tighten screw
Approx. 10 g
Approx. 25 g
0.98 N·m {10 kgf·cm} maximum
0.49 N·m {5 kgf·cm} maximum
OEnvironmental characteristics
Item
Part number
Operating temp. range
Storage temp. range
Protection grade
RES20
RES20-Z
REC20
RES20B
REC20C
RES20D
REC20D
RESW20D
0 ~ 50 °C
– 20 ~ 80 °C
IP40
Note) Manual setting only.
RECW20D
REC/RES
OPTICAL ENCODERS
■ RELIABILITY TEST
The output shall satisfy the criteria below after the following tests.
Test item
Test conditions
Vibration
Power OFF
Amplitude : 1.52 mm or 98.1 m/s2 (10 G) whichever is smaller.
10 ~ 500 Hz excursion 15 min/cycle, 8 cycles each for X, Z, directions.
Shock
Power OFF
3 times each in directions (X, Z) at 490 m/s2 (50 G), 11 ms.
High temperature
exposure
Power OFF
80 °C 96 h
Power ON
50 °C 96 h
Low temperature
exposure
Power OFF
− 20 °C 96 h
Power ON
0 °C 96 h
Humidity
Power OFF
40 °C Relative humidity 90 ∼ 95 % 96 h
(To be measured after wiping out moisture and leaving samples for 1 h at normal temperature and humidity after the test.)
Thermal shock
Power OFF
To be done 10 cycles with the following condition
(To be measured after leaving samples for 1 h at normal temperature and humidity after the test.)
80 °C ± 2 °C 0.5 h、− 20 °C ± 2 °C 0.5 h
■ OUTLINE DIMENSIONS
ORES20D/RESW20D
AWG26
(Without click / Without click, With panel seal)
Lead wire
80 min.
Unless otherwise specified, tolerance: ± 0.4 (Unit: mm)
6.5
9
11
< Option (Stopper) >
< Attachment >
ORES20D / REC20D /
RESW20D / RECW20D
2.5
2.8
2
φ 12.9
1. Nut
2
1
2. Washer
5
R0.
7.25
12
2
0.
–R
6.8
P = 0.75
0.5
4.7
M9
φ 9.4
※Water resistant washer will be provided for panel seal type.
Position stopper (metal piece) is available.
φ 10.4
0.5±0.1
φ 20
The stopper can be provided upon request.
φ 20
4.7
(With click / With click, With panel seal)
φ8
φ 6 –0.05
OREC20D/RECW20D
φ 10.3 –0.06
M 9 P = 0.75
REC/RES
OPTICAL ENCODERS
ORES20/RES20-Z
Connector B4P・SHF・1AA
(Without click)
6
11
3.5
φ 20
φ 10.3 –0.05
0.8
φ 6 –0.02
M 9 P = 0.75
V B A O
1.2
15
6.5
1.5
15 max.
23
2.5
1
9 max.
(38)
7
(With click)
(100)
OREC20
AWG26
W 0.8 = D 1.2
15
6.5
q 10.3 –0.05
(Without click)
q 6 –0.02
23 max.
M9 P = 0.75
q
1.5
(23)
18 max.
7
10
AWG26
2
(With click)
6.5
q 10.3 –0.05
q 6 –0.02
25 max.
M9 P = 0.75
15
q
1.5
(23)
23 max.
< Accessories >
0.5
M9
P = 0.75
12
2
φ 9.4
φ 12.9
1. Nut
0.5
1
6.8
7.5
q
(100)
OREC20C
3
0.
q 1
2.8
2.5
2. Washer
3. Stopper
REC/RES
OPTICAL ENCODERS
OKNOB FOR SETTING ENCODERS
(Unit: mm)
10
The knobs are sold separately as an optional item.
8.5
4.5
φ 33
φ 6 +0.10
+0.05
φ 15
R10
φ 11
9.5
2.5
2–M3
7.5
※ Use a hexagon wrench for
1.5 fastening.
Knurl (All surronding area)
■ OUTPUT
ORES20D/REC20D/RESW20D/RECW20D
Square wave
T
Click spot
CW
Output “A”
CW
Output “A”
Output “B”
Click spot
Output “B”
a
b
c
d
Click spot
a, b, c, d ≧ 1/10T
ORES20
ORES20 *** Z
CW
Saturated Wave
T
CCW
Output “A”
2.5 V
Output “B”
2.5 V
Output “A”
1/2T
1/4T±1/8T
a
Output “B”
c
a, b, c, d ≧ 100 μs
1/2T
OREC20/RES20B/REC20C
Square Wave
T
CCW
CW
1
Output “A”
b
1/4T±1/8T
1
Output “B”
Click range
(REC20,REC20C)
d
CW
REC/RES
OPTICAL ENCODERS
■ OUTPUT CIRCUIT
ORES20
ORES20-Z
Vcc 5 V
Vcc 5 V
Output “A”
A
Output “B”
B
120 Ω
15 kΩ
15 kΩ
85 Ω min.
GND
Vcc 5 V (Red)
Vcc 5 V (Red)
4.7 kΩ
1 kΩ
Output “A” (White)
“B” (Green)
Output “A” (White)
“B” (Green)
IC
0 V (Black)
0 V (Black)
■ EXTERNAL SCHEMATICS
ORES20
V
+5 V
10 kΩ
Comp.
A
5 kΩ
G
R
Comp.
B
85 Ω min.
10 kΩ
5 kΩ
Output “A”
R
Output “B”
0V
很抱歉,暂时无法提供与“RESW20D-25-201-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+146.57476
- 2+140.65970
- 5+136.06720
- 国内价格 香港价格
- 1+219.668001+28.35480
- 5+188.595265+24.34393
- 10+176.5731110+22.79210
- 40+154.6905540+19.96750
- 80+144.7245180+18.68108
- 120+144.56975120+18.66110
