MANUAL SETTING TYPE MAGNETIC ENCODERS
RMS20
■ FEATURES
OHigh resolution of 256 P/R and fine setting
OLower consumption of electric power (15 mA maximum) due to magnetic method
5
OLong life for 10 times continuous run due to contactless & magnetic method
OSquare wave output (with Amp.)
OSmooth rotation for setting
ORoHS compliant
RoHS compliant
■ PART NUMBER DESIGNATION
RMS20 - 250 - 201 - 1
Series name
Output connection
1:Cable wire
Resolution (P/R)
Output phase
100, 250, 256
2:“A” & “B”
■ LIST OF PART NUMBERS
Resolution
Item
Input voltage
Part number
100 (P/R)
RMS20-100-201-1
250 (P/R)
5V
RMS20-250-201-1
256 (P/R)
RMS20-256-201-1
※Verify the above part numbers when placing orders.
■ STANDARD SPECIFICATIONS
OElectrical characteristics
OMechanical characteristics
Input voltage
DC5 V ± 5 %
Input current
15 mA maximum (No load)
Output wave form
Shaft loading
(When mounting)
A, B
(P/R)
100
Resolution
Phase difference of outputs A & B
Maximum frequency response
250
90° ± 45°
5 kHz
“1 (High)”
+ 4.5 V minimum
“0 (Low)”
+ 0.5 V maximum
Output signal
Magnetoresistive element
4.90 mN·m {50 gf·cm} maximum
2
3 g·cm maximum
Inertia
Square wave
Output phases
Sensor
Rotational torque
256
Radial
9.81 N {1 kgf} maximum
Axial
Rotational life
105 revolution
Net weight
Approx. 20 g
Strength of tighten screw
0.49 N·m {5 kgf·cm} maximum
OEnvironmental characteristics
Operating temp. range
− 10 ~ 60 °C
Storage temp. range
− 40 ~ 70 °C
Protection grade
IP40
RMS20
MAGNETIC ENCODERS
■ RELIABILITY TEST
The output shall satisfy the criteria below after the following tests.
Test item
Test conditions
Vibration
Power OFF
Amplitude : 1.52 mm or 98.1 m/s2 (10 G) whichever is smaller.
10 ~ 500 Hz excursion 15 min/cycle, 8 cycles each for X, Y, Z, directions.
Shock
Power OFF
3 times each in directions (X, Z) at 490 m/s2 (50 G), 11 ms.
High temperature
exposure
Power OFF
70 °C 96 h
Power ON
60 °C 96 h
Low temperature
exposure
Power OFF
− 40 °C 96 h
Humidity
Power OFF
40 °C Relative humidity 90 ∼ 95 % 96 h
(To be measured after wiping out moisture and leaving samples for 1 h at normal temperature and humidity after the test.)
Thermal shock
Power OFF
To be done 10 cycles with the following condition
(To be measured after leaving samples for 1 h at normal temperature and humidity after the test.)
70 °C 0.5 h、− 40 °C 0.5 h
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance: ± 0.4 (Unit: mm)
(100)
AWG28
0.75 max.
Unspecified tapped area
P = 0.75
12
2
φ 12
φ 6 – 00.05
24
8 – 00.2
M9
C1
14
M 9 × 0.75
〈Accessories〉
1. Nut
10
4.5
(0.85)
– 0.1
23.5
1
13.5
(37)
φ 9.4
φ 12.9
2. Washer
0.5
1
RMS20
MAGNETIC ENCODERS
■ OUTPUT
■ ELECTRICAL WIRING
CW
CCW
Output “A”
Red
Power B
Brown
Output “B”
White
Output “A”
Black
Power 0 (V)
Output “B”
a
b
c
d
T
T
a, b, c, d = T/4±T/8
T = ±T/8
■ OUTPUT CIRCUIT
Vcc 5 V (Red)
10 kΩ
IC
Output
“A” (White)
“B” (Brown)
0 V (Black)
Sink current 1 mA maximum (at 25 ℃)
很抱歉,暂时无法提供与“RMS20-256-201-1”相匹配的价格&库存,您可以联系我们找货
